  4. Test Adapter powerfox v0.0.2-x
powerfoxenergy meterenergy monitorenergy
147 Beiträge 28 Kommentatoren 30.5k Aufrufe 23 Beobachtet
    ATARI
    #124
    Skript v.2023-06-20
    *** BASE SYSTEM ***
       Static hostname: pi
             Icon name: computer
            Machine ID: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
               Boot ID: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    Model           : Raspberry Pi 4 Model B Rev 1.5
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : arm64
    Systemuptime and Load:
     16:10:12 up  5:12,  1 user,  load average: 0.44, 0.82, 1.35
    CPU threads: 4
    Raspberry only:
    throttled=0x0
    Other values than 0x0 hint to temperature/voltage problems
    temp=40.9'C
    volt=0.9360V
    *** Time and Time Zones ***
                   Local time: Mon 2023-09-25 16:10:12 CEST
               Universal time: Mon 2023-09-25 14:10:12 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    admin
    /home/admin
    admin adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            7.8G        1.4G        5.7G        1.0M        717M        6.3G
    Swap:            99M          0B         99M
    Total:          7.9G        1.4G        5.8G
             7812 M total memory
             1394 M used memory
             1476 M active memory
              479 M inactive memory
             5700 M free memory
               76 M buffer memory
              641 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FILESYSTEM ***
    /dev/root      ext4       59G  3.2G   53G   6% /
    devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     1.6G  1.1M  1.6G   1% /run
    /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
    tmpfs          tmpfs     782M     0  782M   0% /run/user/1000
    [Mon Sep 25 10:58:06 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:66:1B:1C vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=b80df8ab-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Mon Sep 25 10:58:07 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Mon Sep 25 10:58:07 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Mon Sep 25 10:58:09 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    634M    /var/
    207M    /var/log
    193M    /var/log/journal/a8c446969d5b4d38975daa054bdd92b5
    180M    /var/cache
    Archived and active journals take up 192.0M in the file system.
    /opt/iobroker/backups:
    38M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    242M    /opt/iobroker/iobroker-data/
    113M    /opt/iobroker/iobroker-data/files
    88M     /opt/iobroker/iobroker-data/backup-objects
    52M     /opt/iobroker/iobroker-data/files/javascript.admin
    34M     /opt/iobroker/iobroker-data/files/javascript.admin/static
    27M     /opt/iobroker/iobroker-data/objects.jsonl
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
    16M     /opt/iobroker/iobroker-data/states.jsonl
    8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js
    7.1M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.f22de4ab.chunk.js.map
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.17.1
    /usr/bin/node           v18.17.1
    /usr/bin/npm            9.6.7
    /usr/bin/npx            9.6.7
    nodejs:
      Installed: 18.17.1-deb-1nodesource1
      Candidate: 18.17.1-deb-1nodesource1
      Version table:
     *** 18.17.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
         12.22.12~dfsg-1~deb11u4 500
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
         12.22.12~dfsg-1~deb11u3 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
    No problems detected
    npm ERR! code ELSPROBLEMS
    npm ERR! missing: http@^0.0.1-security, required by iobroker.javascript@7.1.4
    npm ERR! missing: modbus-serial@^8.0.13, required by iobroker.javascript@7.1.4
    npm ERR! missing: serial@^0.0.9, required by iobroker.javascript@7.1.4
    npm ERR! missing: usb@^2.10.0, required by iobroker.javascript@7.1.4
    npm ERR! A complete log of this run can be found in: /home/admin/.npm/_logs/2023-09-25T14_10_18_185Z-debug-0.log
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    No configuration change needed.
    Multihost discovery server: disabled
    Discovery authentication:   enabled
    Persistent activation:      disabled
    Objects:                    jsonl on 127.0.0.1
    States:                     jsonl on 127.0.0.1
    Core adapters versions
    js-controller:  5.0.12
    admin:          6.10.1
    javascript:     7.1.4
    Adapters from github:   1
    Adapter State
    + system.adapter.admin.0                  : admin                 : pi                                       -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : pi                                       -  enabled
    + system.adapter.backitup.0               : backitup              : pi                                       -  enabled
    + system.adapter.discovery.0              : discovery             : pi                                       -  enabled
    + system.adapter.email.0                  : email                 : pi                                       -  enabled
    + system.adapter.fb-checkpresence.0       : fb-checkpresence      : pi                                       -  enabled
      system.adapter.feiertage.0              : feiertage             : pi                                       -  enabled
    + system.adapter.followthesun.0           : followthesun          : pi                                       -  enabled
      system.adapter.homepilot.0              : homepilot             : pi                                       - disabled
    + system.adapter.info.0                   : info                  : pi                                       -  enabled
    + system.adapter.javascript.0             : javascript            : pi                                       -  enabled
      system.adapter.netatmo-crawler.0        : netatmo-crawler       : pi                                       -  enabled
    + system.adapter.netatmo.0                : netatmo               : pi                                       -  enabled
      system.adapter.powerfox2.0              : powerfox2             : pi                                       -  enabled
      system.adapter.schoolfree.0             : schoolfree            : pi                                       -  enabled
    + system.adapter.shelly.0                 : shelly                : pi                                       -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.simple-api.0             : simple-api            : pi                                       -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.smartgarden.0            : smartgarden           : pi                                       -  enabled
    + system.adapter.sonos.0                  : sonos                 : pi                                       -  enabled
    + system.adapter.sony-bravia.0            : sony-bravia           : pi                                       -  enabled
    + system.adapter.sony-bravia.1            : sony-bravia           : pi                                       -  enabled
    + system.adapter.tr-064.0                 : tr-064                : pi                                       -  enabled
    + system.adapter.web.0                    : web                   : pi                                       -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.10.1   , installed 6.10.1
    Adapter    "alexa2"       : 3.25.2   , installed 3.25.2
    Adapter    "backitup"     : 2.8.1    , installed 2.8.1
    Adapter    "email"        : 1.2.0    , installed 1.2.0
    Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
    Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
    Adapter    "followthesun" : 0.4.2    , installed 0.4.2
    Adapter    "homepilot"    : 1.1.6    , installed 1.1.6
    Adapter    "javascript"   : 7.1.4    , installed 7.1.4
    Controller "js-controller": 5.0.12   , installed 5.0.12
    Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
    Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
    Adapter    "powerfox2"    : 0.0.12   , installed 0.0.12
    Adapter    "schoolfree"   : 1.1.2    , installed 1.1.2
    Adapter    "shelly"       : 6.4.1    , installed 6.4.1
    Adapter    "smartgarden"  : 2.0.0    , installed 2.0.0
    Adapter    "socketio"     : 6.5.5    , installed 6.5.5
    Adapter    "sonos"        : 2.3.1    , installed 2.3.1
    Adapter    "sony-bravia"  : 1.0.9    , installed 1.0.9
    Adapter    "web"          : 6.1.2    , installed 6.1.2
    Adapter    "ws"           : 2.5.5    , installed 2.5.5
    Objects and States
    Objects:        6757
    States:         5200
    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:2 http://deb.debian.org/debian bullseye InRelease
    Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:5 https://deb.nodesource.com/node_18.x bullseye InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       143047     20981/iobroker.js-c
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       143040     20981/iobroker.js-c
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13563      544/sshd: /usr/sbin
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       145602     21318/io.simple-api
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       147174     21470/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       143101     21000/io.admin.0
    tcp6       0      0 :::3500                 :::*                    LISTEN      1001       143148     21084/io.sonos.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          13565      544/sshd: /usr/sbin
    udp        0      0 192.168.0.101:5353      0.0.0.0:*                           1001       145461     21169/io.tr-064.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        15368      394/avahi-daemon: r
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       144211     21065/io.shelly.0
    udp        0      0 0.0.0.0:51391           0.0.0.0:*                           1001       155154     21065/io.shelly.0
    udp        0      0 0.0.0.0:60589           0.0.0.0:*                           108        15370      394/avahi-daemon: r
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          11804      737/dhcpcd
    udp6       0      0 :::546                  :::*                                0          12706      737/dhcpcd
    udp6       0      0 :::5353                 :::*                                108        15369      394/avahi-daemon: r
    udp6       0      0 :::51198                :::*                                108        15371      394/avahi-daemon: r
    2023-09-25 16:10:34.690  - info: javascript.0 (21042) script.js.common.Huawei.get_data: Triggering read of inverter 1 at address 37100 with length 114
    2023-09-25 16:10:37.690  - info: javascript.0 (21042) script.js.common.Huawei.get_data: Triggering read of inverter 1 at address 32000 with length 116
    2023-09-25 16:10:40.040  - info: host.pi instance system.adapter.powerfox2.0 started with pid 23068
    2023-09-25 16:10:40.700  - info: javascript.0 (21042) script.js.common.Huawei.get_data: Triggering read of inverter 1 at address 37000 with length 68
    2023-09-25 16:10:41.836  - error: host.pi instance system.adapter.powerfox2.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2023-09-25 16:10:43.701  - info: javascript.0 (21042) script.js.common.Huawei.get_data: Triggering read of inverter 1 at address 37700 with length 100
    2023-09-25 16:10:46.701  - info: javascript.0 (21042) script.js.common.Huawei.get_data: Triggering read of inverter 1 at address 37800 with length 100
    2023-09-25 16:10:49.701  - info: javascript.0 (21042) script.js.common.Huawei.get_data: Triggering read of inverter 1 at address 38200 with length 100
    2023-09-25 16:10:50.043  - info: host.pi instance system.adapter.powerfox2.0 started with pid 23102
    2023-09-25 16:10:51.201  - error: host.pi instance system.adapter.powerfox2.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2023-09-25 16:10:52.701  - info: javascript.0 (21042) script.js.common.Huawei.get_data: Triggering read of inverter 1 at address 38300 with length 100
    2023-09-25 16:10:55.701  - info: javascript.0 (21042) script.js.common.Huawei.get_data: Triggering read of inverter 1 at address 38400 with length 100
    2023-09-25 16:10:56.976  - info: javascript.0 (21042) script.js.common.Huawei.Sonnen_Azimuth: -131.5
    2023-09-25 16:10:58.702  - info: javascript.0 (21042) script.js.common.Huawei.get_data: Triggering read of inverter 1 at address 35300 with length 40
    2023-09-25 16:11:00.066  - info: host.pi instance system.adapter.powerfox2.0 started with pid 23135
    2023-09-25 16:11:01.134  - error: host.pi instance system.adapter.powerfox2.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2023-09-25 16:11:01.702  - info: javascript.0 (21042) script.js.common.Huawei.get_data: Processing new data...
    2023-09-25 16:11:01.710  - info: javascript.0 (21042) script.js.common.Huawei.get_data: Processing done!
    2023-09-25 16:11:01.711  - info: javascript.0 (21042) script.js.common.Huawei.get_data: Triggering read of inverter 1 at address 30000 with length 81
    2023-09-25 16:11:04.703  - info: javascript.0 (21042) script.js.common.Huawei.get_data: Triggering read of inverter 1 at address 37100 with length 114
    2023-09-25 16:11:07.704  - info: javascript.0 (21042) script.js.common.Huawei.get_data: Triggering read of inverter 1 at address 32000 with length 116
    2023-09-25 16:11:10.048  - info: host.pi instance system.adapter.powerfox2.0 started with pid 23556
    2023-09-25 16:11:10.705  - info: javascript.0 (21042) script.js.common.Huawei.get_data: Triggering read of inverter 1 at address 37000 with length 68
    2023-09-25 16:11:11.332  - error: host.pi instance system.adapter.powerfox2.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2023-09-25 16:11:13.705  - info: javascript.0 (21042) script.js.common.Huawei.get_data: Triggering read of inverter 1 at address 37700 with length 100
    ATARI
    Raspberry Pi 5B (ioB via pi OS_lite(64bit) | Synology NAS (ioB via Docker)
    Fibaro Home Center 2 & Home Center 3 | Homematic IP | EMS-ESP32 Gateway
    Aeotec Z-Wave | Tuya 4 in 1 Gateway | Zigbee & BLE Gateway
    • A ATARI
      Skript v.2023-06-20
      *** BASE SYSTEM ***
         Static hostname: pi
               Icon name: computer
            Architecture: arm64
      Docker          : false
      Kernel          : aarch64
      Userland        : arm64
      CPU threads: 4
      Raspberry only:
      throttled=0x0
      temp=40.9'C
      volt=0.9360V
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      admin
      /home/admin
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:            99M          0B         99M
               7812 M total memory
               1394 M used memory
               5700 M free memory
                 76 M buffer memory
                641 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /var:
      634M    /var/
      207M    /var/log
      180M    /var/cache
      /usr/bin/npm            9.6.7
      /usr/bin/npx            9.6.7
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.10.1
      javascript:     7.1.4
      Adapter State
      + instance is alive
      Objects and States
      Objects:        6757
      States:         5200
      Pending Updates: 0
      #125
      @atari sagte in Test Adapter powerfox v0.0.2-x:
      Installier den nochmal:
      iobroker upgrade iobroker.javascript@7.1.4
        ATARI
        schrieb am zuletzt editiert von ATARI
        #126
        JS Upgrade ändert nix.
        Der Adapter erkennt zwar meinen PowerFox als Gerät
        (somit ist die Anmeldung korrekt) aber es werden unter
        "/Objekte/powerfox2/0/devices" keine weiteren Datenpunkte
        angelegt.
        ATARI
        • A ATARI
          angelegt.
          #127
          @atari
          Sind die Fehlermeldungen nun weg?
          Hast du den
          iob fix
          mal ausgeführt?
          Du könntest auch den 'node fix' aus meiner Signatur ausführen, dann wärst du auch an der Stelle auf dem aktuellen Stand.
          A 3 Antworten Letzte Antwort
            @atari
            Hast du den
            iob fix
            mal ausgeführt?
            ATARI
            #128
            Die Fehlermeldungen bzgl. JavaScript 'modbus-serial' etc. sind weg.
            iob fix
            "...schon rauf und runter..."
            iob stop
            iob update
            iob fix
            iob ubgrade self
            iob start
            sudo apt update && sudo apt upgrade...
            das Alles mit und ohne abschließendem sudo reboot,
            Host-Neustart, Adapter-Neustart, Adapter gelöscht, neuinstalliert,
            auch ältere Versionen, aus dem GitHub.... usw.
            Werde mal Dein 'node fix' testen.
            ATARI
              @atari
              Hast du den
              iob fix
              mal ausgeführt?
              ATARI
              #129
              @thomas-braun sagte in Test Adapter powerfox v0.0.2-x:
              Nach Deinem 'node fix' ist Node.js und NPM sind jetzt 'top aktuell', leider ändert auch das nichts an dem Prob. mit powerfox2.
              Wie gesagt, mein powerfox Gerät wird erkannt und ist 'aktiviert'.
              Unter: '/Objekte/powerfox2/0/devices/' wird aber kein weiterer Datenpunkt erstellt.
              Bin nach dem 'Tod' meines TinkerBoards S bin ich bewusst, wegen besserem Support und höherer Kompatibiltät, auf Raspi umgestiegen...,
              und nun so'n scheiß...
              ATARI
                @atari
                Hast du den
                iob fix
                mal ausgeführt?
                ATARI
                #130
                @thomas-braun (nicht persönlich nehmen)
                Habe jetzt, nur zum Testen, das akt. Raspi OS (64bit lite) und akt. ioB auf einer anderen microSD installiert. (btw. erneut nach Deiner hervorgenden Installationsanleitung aus diesem Forum)
                Neues ioB mit:
                node.js v18.17.1
                npm v9.6.7
                js-controller v4.0.24
                -> powerfox2 funktioniert, auch nach admin update auf v6.10.x.
                Leider funktioniert nach einem Restore des letzten Backups, über BackItUp, ioBroker nicht mehr. Über ssh ist der Raspi weiterhin erreichbar, aber über :8081 nicht. Evtl. diff. zwischen js-controller.
                ATARI
                • A ATARI
                  Neues ioB mit:
                  node.js v18.17.1
                  npm v9.6.7
                  #131
                  Logisch. Hat ja auch nichts miteinander zu tun.
                  iob diag
                  sagt?
                    iob diag
                    sagt?
                    ATARI
                    #132
                    sorry Thomas, aber ich bastel jetzt seit 4 Tagen an dem Prob. herum.
                    Habe das Test-System wieder gelöscht.
                    Da ich noch einen ioBroker auf einer Synology DS habe und ich z.Zt. nur 2 Datenpunkte vom powerfox brauche,
                    habe ich das Ganze jetzt erstmal mit MQTT (Syno DS -> Raspi) gelöst.
                    Vllt. finde ich in den nächsten Tage ja nochmal die Muse...
                    Schon merkwürdig, das es auf der Syno mit gleichen Versionen funktioniert.
                    Vielen Dank für Deinen Support!
                    ATARI
                      ATARI
                      #133
                      ...es lies mir dann doch keine Ruhe...
                      • Pi OS Lite(64bit) neu geflasht
                      • sudo apt update && sudo apt full-upgrade
                      • sudo reboot
                      • curl -sLf https://iobroker.net/install.sh | bash -
                      • iob diag (unauffällig)
                      • curl https://raw.githubusercontent.com/Grothesk242/iob_diag/main/iob_node_update > iob_node_update chmod 744 iob_node_update ./iob_node_update
                      • iobroker Assistent absolviert
                      • Update Adapter admin.0 auf v6.10.1
                      • Adapter powerfox2 (v0.0.12) installiert, ### volle Funktion ###
                      • danach den js-controller von v4.0.24 auf v5.0.12 aktualisiert
                      Jetzt ist alles 'hübsch'. Nun muss ich nur noch alle anderen Adapter
                      wieder nachinstallieren.
                      ATARI
                      F 1 Antwort Letzte Antwort
                      • A ATARI
                        • sudo reboot
                        Flopsi
                        #134
                        ist es normal das in dem Datenpunkt
                        powerfox2.0.devices......currentFeedIn
                        kein Wert bzw. der Wert 0 W angezeigt wird, ich hätte hier den Einspeisewert meines Balkonkraftwerkes erwartet ....
                        • F Flopsi
                          ATARI
                          #135
                          @Flopsi vermutlich ist Dein Eigenverbrauch höher als die Einspeiseleistung der PV-Anlage.
                          Einen 2-Wege Zähler hast Du?
                          Ich speise gerade 6 Watt ein, weil mein Eigenbedarf die Solarleistung "frisst".
                          ATARI
                          • A ATARI
                            Flopsi
                            schrieb am zuletzt editiert von Flopsi
                            #136
                            @atari
                            ja der Eigenverbracuh ist höher als die Einspeisung, einen 2 Wege Zähler habe ich
                            OK schade dachte man würde sehen können was mein Balkonkraftwerk aktuell macht
                            ich speise 36 Watt nach meinem Zwischenstecker ein auch mega LOL
                            • F Flopsi
                              @atari
                              ATARI
                              #137
                              @flopsi sagte in Test Adapter powerfox v0.0.2-x:
                              Gibt es für Deine PV-Analge kein Adapter im ioBroker?
                              Damit könntest Du die Werte direkt auslesen.
                              ATARI
                              • A ATARI
                                Flopsi
                                #138
                                @atari
                                habe einen Wechselrichter von hoymiles... der mit 600 Watt der hat kein W-Lan muss, da einen Adapter für kaufen oder so ein DTU teil ...
                                habe noch nicht geschaut welcher Adapter da passen könnte ....
                                • F Flopsi
                                  @atari
                                  #139
                                  @flopsi
                                  Ich kann da opendtu empfehlen.
                                    @flopsi
                                    Flopsi
                                    #140
                                    opendtu
                                    OK welcher Bausatz wäre das (das gibt es ja schon unterschiede)
                                    • F Flopsi
                                      opendtu
                                      #141
                                      @flopsi
                                      Ich hab mir 'irgendeinen' bei ebay geschossen. Hatte keine Lust auf selber basteln.
                                        @flopsi
                                        Flopsi
                                        #142
                                        hast du einen 600 Watt Wechselrichter ?
                                        • F Flopsi
                                          #143
                                          @flopsi
                                          Den HM-600
