  4. Test Adapter Linux Control v1.x.x
    6.0k
adaptercontrolhardwarelinuxsteuern
715 Beiträge 73 Kommentatoren 244.4k Aufrufe 65 Beobachtet
  • C Ceel
    @liv-in-sky
    Das ist mein Ergebnis aus sensors-detect:
    Driver `coretemp':
      * Chip `Intel digital thermal sensor' (confidence: 9)
    Driver `nct6775':
      * ISA bus, address 0x290
        Chip `Nuvoton NCT6793D Super IO Sensors' (confidence: 9)
    To load everything that is needed, add this to /etc/modules:
    #----cut here----
    # Chip drivers
    coretemp
    nct6775
    #----cut here----
    If you have some drivers built into your kernel, the list above will
    contain too many modules. Skip the appropriate ones!
    Do you want to add these lines automatically to /etc/modules? (yes/NO)yes
    Successful!
    liv-in-skyL Offline
    liv-in-skyL Offline
    liv-in-sky
    #181
    @Ceel sagte in Test Adapter Linux Control v0.x.x:
    nct6775
    vielleicht hier: https://bbs.archlinux.org/viewtopic.php?pid=1440350#p1440350
    C 1 Antwort Letzte Antwort
    • liv-in-skyL liv-in-sky
      nct6775
      Ceel
      #182
      @liv-in-sky ein sensors-detect und ein REBOOT reicht
      pch_cannonlake-virtual-0
      Adapter: Virtual device
      temp1:        +56.0°C
      coretemp-isa-0000
      Adapter: ISA adapter
      Package id 0:  +55.0°C  (high = +80.0°C, crit = +100.0°C)
      Core 0:        +48.0°C  (high = +80.0°C, crit = +100.0°C)
      Core 1:        +55.0°C  (high = +80.0°C, crit = +100.0°C)
      Core 2:        +48.0°C  (high = +80.0°C, crit = +100.0°C)
      Core 3:        +45.0°C  (high = +80.0°C, crit = +100.0°C)
      nct6793-isa-0290
      in0:                    +1.17 V  (min =  +0.00 V, max =  +1.74 V)
      in1:                    +1.86 V  (min =  +0.00 V, max =  +0.00 V)  ALARM
      in2:                    +3.31 V  (min =  +0.00 V, max =  +0.00 V)  ALARM
      in3:                    +3.36 V  (min =  +0.00 V, max =  +0.00 V)  ALARM
      in4:                    +0.27 V  (min =  +0.00 V, max =  +0.00 V)  ALARM
      in5:                    +0.15 V  (min =  +0.00 V, max =  +0.00 V)  ALARM
      in6:                    +0.69 V  (min =  +0.00 V, max =  +0.00 V)  ALARM
      in7:                    +3.30 V  (min =  +0.00 V, max =  +0.00 V)  ALARM
      in8:                    +3.07 V  (min =  +0.00 V, max =  +0.00 V)  ALARM
      in9:                    +1.06 V  (min =  +0.00 V, max =  +0.00 V)  ALARM
      in10:                   +0.18 V  (min =  +0.00 V, max =  +0.00 V)  ALARM
      in11:                   +0.15 V  (min =  +0.00 V, max =  +0.00 V)  ALARM
      in12:                   +1.86 V  (min =  +0.00 V, max =  +0.00 V)  ALARM
      in13:                   +1.72 V  (min =  +0.00 V, max =  +0.00 V)  ALARM
      in14:                   +0.21 V  (min =  +0.00 V, max =  +0.00 V)  ALARM
      fan1:                     0 RPM  (min =    0 RPM)
      fan2:                  1010 RPM  (min =    0 RPM)
      fan3:                     0 RPM  (min =    0 RPM)
      fan4:                     0 RPM  (min =    0 RPM)
      fan5:                     0 RPM  (min =    0 RPM)
      fan6:                     0 RPM  (min =    0 RPM)
      SYSTIN:                +111.0°C  (high =  +0.0°C, hyst =  +0.0°C)  sensor = thermistor
      CPUTIN:                 +47.5°C    sensor = thermistor
      AUXTIN0:                +44.0°C  (high =  +0.0°C, hyst =  +0.0°C)  ALARM  sensor = thermistor
      AUXTIN1:               +105.0°C    sensor = thermistor
      AUXTIN2:               +103.0°C    sensor = thermistor
      AUXTIN3:               +101.0°C    sensor = thermistor
      PECI Agent 0:           +56.5°C  (high = +80.0°C, hyst = +75.0°C)
                                       (crit = +100.0°C)
      PCH_CHIP_CPU_MAX_TEMP:   +0.0°C
      PCH_CHIP_TEMP:           +0.0°C
      PCH_CPU_TEMP:            +0.0°C
      intrusion0:            OK
      intrusion1:            ALARM
      beep_enable:           disabled
      • C Ceel
        temp1:        +56.0°C
        coretemp-isa-0000
        nct6793-isa-0290
                                         (crit = +100.0°C)
        intrusion0:            OK
        intrusion1:            ALARM
        liv-in-skyL Offline
        liv-in-skyL Offline
        liv-in-sky
        #183
        @Ceel
        cool - werden andere sicher auch noch gebrauchen können !
          @Ceel
          da_WoodyD Online
          da_WoodyD Online
          da_Woody
          #184
          @liv-in-sky neugierig wie ich mal bin:
          root@Homeserver:~# sensors
          nouveau-pci-0100
          Adapter: PCI adapter
          GPU core:     +0.88 V  (min =  +0.82 V, max =  +1.21 V)
          fan1:           0 RPM
          temp1:        +44.0°C  (high = +95.0°C, hyst =  +3.0°C)
                                 (crit = +105.0°C, hyst =  +5.0°C)
                                 (emerg = +135.0°C, hyst =  +5.0°C)
          power1:       22.57 W  (crit = 200.00 mW)
          acpitz-acpi-0
          Adapter: ACPI interface
          temp1:        +27.8°C  (crit = +105.0°C)
          temp2:        +29.8°C  (crit = +105.0°C)
          coretemp-isa-0000
          Package id 0:  +47.0°C  (high = +80.0°C, crit = +100.0°C)
          Core 0:        +47.0°C  (high = +80.0°C, crit = +100.0°C)
          Core 1:        +42.0°C  (high = +80.0°C, crit = +100.0°C)
          Core 2:        +40.0°C  (high = +80.0°C, crit = +100.0°C)
          Core 3:        +38.0°C  (high = +80.0°C, crit = +100.0°C)
          root@Homeserver:~#
          gruß vom Woody
          • da_WoodyD da_Woody
            nouveau-pci-0100
            fan1:           0 RPM
            acpitz-acpi-0
            coretemp-isa-0000
            root@Homeserver:~#
            liv-in-skyL Offline
            liv-in-skyL Offline
            liv-in-sky
            #185
            @da_Woody
            schaut doch gut aus
              @da_Woody
              schaut doch gut aus
              da_WoodyD Online
              da_WoodyD Online
              da_Woody
              #186
              @liv-in-sky jep. war noch zu faul die gfx auszubauen... :D
              gruß vom Woody
              • ScroungerS Scrounger
                Aktuelle Test Version 1.1.2
                Veröffentlichungsdatum 12.08.2020
                Github Link https://github.com/Scrounger/ioBroker.linux-control
                ich habe einen kleinen Adapter geschrieben, mit dem Ihr Eure Linux Geräte / VMs / LXCs mittels ssh Zugriff steuern und Informationen auslesen.
                Folgende Funktionen bietet der Adapter:
                • ssh login über Benutzer und Passwort oder per RSA Key (empfohlen!)
                • vordefinierte Datenpunkte, um das System zu steuern (Stopp, Reboot, Updates starten, etc.) und Informationen (Services, Updates, Neustart notwendig, etc.) auszulesen
                  Wichtig: Da es viele verschiedene Linux Distrubutionen gibt, ist es mir nicht möglich diese Funktionen für alle bereitzustellen, Support und Test von mir gibt es nur für Debian 10 und Ubuntu 18 / 20 LTS!
                • Informationen zu Ordner (Größe, Anzahl Dateien, letzte Änderung) auslesen
                • Meine Befehle - hier könnt Ihr Eure eigenen ganz individuellen Befehle ausführen lassen und z.B. einen Befehl ausführen oder Informationen in einen selbstdefinierten Datenpunkt zu schreiben.
                Alle notwendigen Informationen findet ihr in der Dokumentation.
                Vielen Dank fürs Testen!
                P.S.: Sollte die Tage auch im Latest sein.
                liv-in-skyL Offline
                liv-in-skyL Offline
                liv-in-sky
                #187
                @Scrounger
                ich habe immer wieder ein problem mit den selbst definierten buttons. es ist ein raspi 4 . der refresh button funktioniert noch aber alle selbstangelegten buttons nicht - es kommt auch kein eintrag im log, dass er etwas ausführen würde (beim refresh schon). andere daten (folder, befehle) werden auch geholt und upgedatet.
                es scheint sich auch nur um den einen client zu handeln - andere server mit ihen buttons funktionieren
                nachdem ich die instanz neustarte funktioniert es wieder - der raspi wird erst später eingeschalten (mein iobroker startet um 6:30 neu) .
                nochmal den ablauf
                • um 6:30 startet proxmox server mit allen containern
                • gegen 8 wird raspi4 eingeschalten - buttons funktionieren dann nicht
                • neustart der instanz
                • dann funktionieren die buttons - den restlichen tag über
                hast du eine idee dazu ?
                ScroungerS 2 Antworten Letzte Antwort
                  @Scrounger
                  nochmal den ablauf
                  ScroungerS Offline
                  ScroungerS Offline
                  Scrounger
                  #188
                  @liv-in-sky
                  Ja hab ne Idee woran das liegen könnte - schau ich mir an.
                    @Scrounger
                    nochmal den ablauf
                    ScroungerS Offline
                    ScroungerS Offline
                    Scrounger
                    #189
                    @liv-in-sky
                    Teste bitte die aktuelle github version, sollte jetzt wieder funktionieren.
                      @liv-in-sky
                      liv-in-skyL Offline
                      liv-in-skyL Offline
                      liv-in-sky
                      #190
                      @Scrounger ich installiere und schaue was morgen früh passiert - auf jeden fall schon mal danke
                      ScroungerS 1 Antwort Letzte Antwort
                        ScroungerS Offline
                        ScroungerS Offline
                        Scrounger
                        #191
                        @liv-in-sky hatte schon vermutet daß ich bis morgen 8h warten muss ;-)
                          liv-in-skyL Offline
                          liv-in-skyL Offline
                          liv-in-sky
                          #192
                          @Scrounger moin
                          sieht ganz gut aus - nutze "barrier" beim raspi und konnte dies sofort einschalten über button - adapter reagiert
                          danke fürs fixen
                          Mono990M 1 Antwort Letzte Antwort
                            @Scrounger moin
                            danke fürs fixen
                            Mono990M Offline
                            Mono990M Offline
                            Mono990
                            #193
                            Ich bekomme den adapter leider garnicht installiert. Er downloadet alles sagt dann das erfolgreich installiert wurde.
                            aber ich kann den adapter nirgentwo finden bei bei Instanzen oder Objekte.
                            Habe Raspi4
                            • Mono990M Mono990
                              Habe Raspi4
                              liv-in-skyL Offline
                              liv-in-skyL Offline
                              liv-in-sky
                              #194
                              @Mono990 wenn du über github installierst, musst du im adapter tab ein plus drücken (ganz rechts beim adapter by listview) und die instanz selber anlegen
                                @Ceel sagte in Material Design Widgets: Proxmox:
                                Ja das habe ich auch alles eingerichtet.
                                Ich bekomme einige Anfragen nur nicht hin.
                                Die Standart Sachen funktionieren.
                                Antwort gibts hier weil die Fragen den Adapter betreffen
                                needrestart
                                Das Paket muss auf dem Host installiert sein. Wenn es das nicht ist steht das per warn Meldung im Log sofern Datenpunkte davon aktiviert sind.
                                Nur nicht diese folder
                                Du musst hier nur den Pfad zu dem Ordner angeben und wenn du nicht alle Dateien darin mit einbeziehen willst, noch einen Filter jetzt setzen. Anbei ein paar Beispiele:
                                Mono990M Offline
                                Mono990M Offline
                                Mono990
                                #195
                                @Scrounger
                                Habe 2 server erfolgreich eingebunden aber mein Synology NAS macht noch schwierigkeiten. ich bekomme im Log diese fehlermeldung.
                                weiß jemand wie ich das beheben kann?
                                linux-control.0	2020-10-11 21:59:55.608	error	(30942) [getConnection] error: All configured authentication methods failed, stack: Error: All configured authentication methods failed at doNextAuth (/opt/iobroker/node_modules/ssh2/lib/client.js
                                linux-control.0	2020-10-11 21:59:55.605	error	(30942) [getConnection] Could not establish a connection to 'synology' (192.168.188.2:22)!
                                linux-control.0	2020-10-11 21:59:51.512	info	(30942) successful received data from debianiobroker (192.168.188.3:22)
                                linux-control.0	2020-10-11 21:59:50.843	info	(30942) getting data from synology (192.168.188.2:22)
                                linux-control.0	2020-10-11 21:59:43.999	info	(30942) getting data from debianiobroker (192.168.188.3:22)
                                linux-control.0	2020-10-11 21:59:39.544	info	(30942) successful received data from proxmox (192.168.188.4:22)
                                linux-control.0	2020-10-11 21:59:38.855	info	(30942) getting data from proxmox (192.168.188.4:22)
                                linux-control.0	2020-10-11 21:58:50.831	error	(30942) [getConnection] error: All configured authentication methods failed, stack: Error: All configured authentication methods failed at doNextAuth (/opt/iobroker/node_modules/ssh2/lib/client.js
                                linux-control.0	2020-10-11 21:58:50.827	error	(30942) [getConnection] Could not establish a connection to 'synology' (192.168.188.2:22)!
                                linux-control.0	2020-10-11 21:58:44.637	info	(30942) getting data from synology (192.168.188.2:22)
                                linux-control.0	2020-10-11 21:58:43.996	info	(30942) successful received data from debianiobroker (192.168.188.3:22)
                                linux-control.0	2020-10-11 21:58:38.852	info	(30942) successful received data from proxmox (192.168.188.4:22)
                                linux-control.0	2020-10-11 21:58:38.098	info	(30942) getting data from proxmox (192.168.188.4:22)
                                linux-control.0	2020-10-11 21:58:36.290	info	(30942) getting data from debianiobroker (192.168.188.3:22)
                                • Mono990M Mono990
                                  @Scrounger
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  Glasfaser
                                  #196
                                  @Mono990 sagte in Test Adapter Linux Control v0.x.x:
                                  Mit deinem Admin Benutzer sich anmelden , nicht mit einem angelegten Benutzer der auch Administrationsrechte zugewiesen hat .
                                  • GlasfaserG Glasfaser
                                    liv-in-skyL Offline
                                    liv-in-skyL Offline
                                    liv-in-sky
                                    #197
                                    @Glasfaser
                                    @Mono990
                                    wir haben uns mit dem admin user angemeldet - über putty geht's - aber der adapter bringt die fehler - ich habe keine synology erfahrung, daher dachten wir mal, wir versuchen es hier
                                      liv-in-skyL Offline
                                      liv-in-skyL Offline
                                      liv-in-sky
                                      #198
                                      @Glasfaser
                                      ps: falls du sowas anbietest - vielleicht magst du mit teamviewer mal draufsehen
                                      • liv-in-skyL Offline
                                        liv-in-skyL Offline
                                        liv-in-sky
                                        #199
                                        @Segway hat eine anleitung für die temp messung für linux gemacht
                                        https://forum.iobroker.net/topic/37925/temperatur-auslesen-eines-anderen-rechners-howto
                                        vielleicht braucht es jmd für diesen adapter
                                        • SegwayS Offline
                                          SegwayS Offline
                                          Segway
                                          #200
                                          So, ich probiere gerade diesen Adapter aus, da ich ursprünglich ja einen anderen Weg gegangen bin.
                                          Soweit alles gut - folgende Frage / Phänomen:
                                          Wenn die genrellen Tabs NICHT angeklickt sind ich aber die einzelnen zu den "Rechnern" hinzugefügt habe, scheinen die Datenpunkte nicht angelegt zu werden. Oder mache ich was falsch ?
                                          Gruß Dirk
