  4. Test Adapter Linux Control v1.x.x
    6.1k
adaptercontrolhardwarelinuxsteuern
715 Beiträge 73 Kommentatoren 245.6k Aufrufe 65 Beobachtet
  • RoddiEFR RoddiEF
    @Thomas-Braun sagte in Test Adapter Linux Control v1.x.x:
    Warum? Der user iobroker hat eigentlich auch ein home. Das Modul wird bewusst nicht in /opt/iobroker installiert sondern außerhalb des Installationsverzeichnisses.
    Ok dann hier im Original ohne Anpassung:
    cd /home/iobroker || exit
        sudo -H -u iobroker npm i is-my-node-vulnerable
        sudo -H -u iobroker npx is-my-node-vulnerable
    npm error code EACCES
    npm error syscall mkdir
    npm error path /home/iobroker/node_modules
    npm error errno -13
    npm error Error: EACCES: permission denied, mkdir '/home/iobroker/node_modules'
    npm error     at async mkdir (node:internal/fs/promises:860:10)
    npm error     at async /usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/reify.js:624:20
    npm error     at async Promise.allSettled (index 0)
    npm error     at async [reifyPackages] (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/reify.js:325:11)
    npm error     at async Arborist.reify (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/reify.js:142:5)
    npm error     at async Install.exec (/usr/lib/node_modules/npm/lib/commands/install.js:150:5)
    npm error     at async Npm.exec (/usr/lib/node_modules/npm/lib/npm.js:207:9)
    npm error     at async module.exports (/usr/lib/node_modules/npm/lib/cli/entry.js:74:5) {
    npm error   errno: -13,
    npm error   code: 'EACCES',
    npm error   syscall: 'mkdir',
    npm error   path: '/home/iobroker/node_modules'
    npm error }
    npm error
    npm error The operation was rejected by your operating system.
    npm error It is likely you do not have the permissions to access this file as the current user
    npm error
    npm error If you believe this might be a permissions issue, please double-check the
    npm error permissions of the file and its containing directories, or try running
    npm error the command again as root/Administrator.
    npm error A complete log of this run can be found in: /opt/iobroker/.npm/_logs/2026-01-13T10_24_12_176Z-debug-0.log
    #701
    @RoddiEF
    Welcher user macht den Aufruf?
    Und in welchen Gruppen ist dieser user enthalten?
    Wie sehen die Rechte an
    ls -lAh /home/
    aus?
    Keine Ahnung, ob der Docker-Container an der Stelle anders aufgesetzt wurde, grundsätzlich funktioniert 'iob diag' aber in einem üblichen Docker-Setup.
    • RoddiEFR Offline
      RoddiEFR Offline
      RoddiEF
      #702
      Der Aufruf erfolgt über: docker exec -it iobroker bash was dann so aussieht:
      root@Odin:/opt/iobroker#
      Dann der Befehl und das Ergebniss:
      root@Odin:/opt/iobroker# ls -lAh /home/
      total 0
      drwxr-xr-x 1 1000 1000 70 Jan 12 20:54 iobroker
      Wie gesagt zu dem Aufbau des Docker-Containers kann ich nichts sagen, ist der schon genannte.
      Ich bin wie ich bin, was anderes bekommt man nicht !!
      • RoddiEFR RoddiEF
        total 0
        #703
        @RoddiEF
        Da ist doch das home des 'iobroker'.
        Keine Ahnung warum das bei dir nicht so funktioniert wie in den anderen Dockern.
        • RoddiEFR Offline
          RoddiEFR Offline
          RoddiEF
          #704
          ich habe mal das Script aus deiner Signatur ausprobiert (curl -sLf -o diag.sh https://iobroker.net/diag.sh && bash diag.sh) und das Ergebniss sieht man hier:
          ```bash
          Script v.2025-08-09
          *** BASE SYSTEM ***
          Hardware Vendor : Micro-Star International Co., Ltd
          Kernel          : x86_64
          Userland        : 64 bit
          Docker          : v11.0.0
          Virtualization  : docker
          Kernel          : x86_64
          Userland        : 64 bit
          Systemuptime and Load:
           12:40:13 up 8 days, 17:44,  0 user,  load average: 1.26, 1.38, 1.34
          CPU threads: 12
          *** LIFE CYCLE STATUS ***
          Debian 'bookworm' is the current oldstable version. Please upgrade to the latest stable release 'trixie' in due time!
          *** TIME AND TIMEZONES ***
          Tue Jan 13 11:40:13 UTC 2026
          Tue Jan 13 12:40:13 CET 2026
          CET +0100
          Etc/UTC
          *** Users and Groups ***
          User that called 'iob diag':
          root
          HOME=/root
          GROUPS=root
          iobroker
          HOME=/opt/iobroker
          GROUPS=users tty dialout audio video plugdev
          *** DISPLAY-SERVER SETUP ***
          Display-Server:         false
          System has not been booted with systemd as init system (PID 1). Can't operate.
          Failed to connect to bus: Host is down
          Display-Manager:
          Desktop:
          Session:
          *** MEMORY ***
          Mem:             29G         15G        416M        2.3G         15G         13G
          Swap:             0B          0B          0B
          Total:           29G         15G        416M
          Active iob-Instances:   23
                  27968 M total memory
                  14802 M used memory
                  15167 M active memory
                  10392 M inactive memory
                    397 M free memory
                      0 M buffer memory
                  15219 M swap cache
                      0 M total swap
                      0 M used swap
                      0 M free swap
          top - 12:40:13 up 8 days, 17:45,  0 user,  load average: 1.26, 1.38, 1.34
          Tasks:  29 total,   1 running,  28 sleeping,   0 stopped,   0 zombie
          %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
          MiB Mem :  27968.4 total,    397.1 free,  14802.3 used,  15219.9 buff/cache
          MiB Swap:      0.0 total,      0.0 free,      0.0 used.  13166.1 avail Mem
          *** DMESG CRITICAL ERRORS ***
          dmesg: read kernel buffer failed: Operation not permitted
          No critical errors detected
          *** FILESYSTEM ***
          Filesystem     Type   Size  Used Avail Use% Mounted on
          /dev/nvme0n1p1 btrfs  932G  351G  567G  39% /
          tmpfs          tmpfs   64M     0   64M   0% /dev
          shm            tmpfs   64M     0   64M   0% /dev/shm
          /dev/nvme0n1p1 btrfs  932G  351G  567G  39% /opt/iobroker
          /dev/md3p1     xfs    2.8T  1.1T  1.8T  37% /opt/iobroker/backups
          tmpfs          tmpfs   14G     0   14G   0% /proc/acpi
          tmpfs          tmpfs   14G     0   14G   0% /sys/firmware
          tmpfs          tmpfs   14G     0   14G   0% /sys/devices/virtual/powercap
          Show mounted filesystems:
          TARGET        SOURCE        FSTYPE OPTIONS
          /             /dev/nvme0n1p1[/appdata/docker/docker/btrfs/subvolumes/0ac7ae18a35cd26f43a67b63e17fd433dd434f4edfc9ecc1fee56aa6a727b86b]
        btrfs  rw,noat
          |-/opt/userscripts
          |             /dev/nvme0n1p1[/appdata/iobroker/scripts]        btrfs  rw,noat
          |-/opt/iobroker
          |             /dev/nvme0n1p1[/appdata/iobroker/data]        btrfs  rw,noat
          | `-/opt/iobroker/backups
          |             /dev/md3p1[/Server-Backup/iobroker]        xfs    rw,noat
          |-/etc/resolv.conf
          |             /dev/nvme0n1p1[/appdata/docker/docker/containers/43a4efcdf9735a215297032e411bba77a9cb460b0d487fc6db042afb3d9c716a/resolv.conf]
          |        btrfs  rw,noat
          |-/etc/hostname
          |             /dev/nvme0n1p1[/appdata/docker/docker/containers/43a4efcdf9735a215297032e411bba77a9cb460b0d487fc6db042afb3d9c716a/hostname]
          |        btrfs  rw,noat
          `-/etc/hosts  /dev/nvme0n1p1[/appdata/docker/docker/containers/43a4efcdf9735a215297032e411bba77a9cb460b0d487fc6db042afb3d9c716a/hosts]
        btrfs  rw,noat
          /var:
          35M     /var/
          33M     /var/lib
          19M     /var/lib/apt/lists
          19M     /var/lib/apt
          14M     /var/lib/dpkg
          /opt/iobroker/backups:
          5.5G    /opt/iobroker/backups/
          3.3G    /opt/iobroker/backups/2025-Backups
          1.5G    /opt/iobroker/backups/2026-Januar
          4.0K    /opt/iobroker/backups/.stfolder
          /opt/iobroker/iobroker-data:
          4.2G    /opt/iobroker/iobroker-data/
          3.4G    /opt/iobroker/iobroker-data/history
          640M    /opt/iobroker/iobroker-data/backup-objects
          122M    /opt/iobroker/iobroker-data/files
          47M     /opt/iobroker/iobroker-data/files/admin.admin
          48M     /opt/iobroker/iobroker-data/objects.jsonl
          27M     /opt/iobroker/iobroker-data/backup-objects/2026-01-13_12-14_objects.jsonl.gz
          27M     /opt/iobroker/iobroker-data/backup-objects/2026-01-13_10-14_objects.jsonl.gz
          27M     /opt/iobroker/iobroker-data/backup-objects/2026-01-13_08-14_objects.jsonl.gz
          27M     /opt/iobroker/iobroker-data/backup-objects/2026-01-13_04-13_objects.jsonl.gz
          USB-Devices by-id:
          No Devices found 'by-id'
          zigbee.X
          Extended Pan ID:
          *** MASKED ***
          Pan ID:
          *** MASKED ***
          Channel:
          *** MASKED ***
          Network Key:
          *** MASKED ***
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v22.21.0
          /usr/bin/node           v22.21.0
          /usr/bin/npm            10.9.4
          /usr/bin/npx            10.9.4
          /usr/bin/corepack       0.34.0
          nodejs:
            Installed: 22.21.0-1nodesource1
            Candidate: 22.21.0-1nodesource1
            Version table:
           *** 22.21.0-1nodesource1 1001
                  500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages
                  100 /var/lib/dpkg/status
               22.20.0-1nodesource1 1001
               22.19.0-1nodesource1 1001
               22.18.0-1nodesource1 1001
               22.17.1-1nodesource1 1001
               22.17.0-1nodesource1 1001
               22.16.0-1nodesource1 1001
               22.15.1-1nodesource1 1001
               22.15.0-1nodesource1 1001
               22.14.0-1nodesource1 1001
               22.13.1-1nodesource1 1001
               22.13.0-1nodesource1 1001
               22.12.0-1nodesource1 1001
               22.11.0-1nodesource1 1001
               22.10.0-1nodesource1 1001
               22.9.0-1nodesource1 1001
               22.8.0-1nodesource1 1001
               22.7.0-1nodesource1 1001
               22.6.0-1nodesource1 1001
               22.5.1-1nodesource1 1001
               22.5.0-1nodesource1 1001
               22.4.1-1nodesource1 1001
               22.4.0-1nodesource1 1001
               22.3.0-1nodesource1 1001
               22.2.0-1nodesource1 1001
               22.1.0-1nodesource1 1001
               22.0.0-1nodesource1 1001
               18.20.4+dfsg-1~deb12u1 500
                  500 http://deb.debian.org/debian bookworm/main amd64 Packages
                  500 http://deb.debian.org/debian-security bookworm-security/main amd64 Packages
          No problems detected
          Errors in npm tree: 0
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          Odin                Odin (version: 7.0.7, hostname: Odin          , alive, uptime: 23131)
          Core adapters versions
          js-controller:  7.0.7
          admin:          7.7.19
          javascript:     9.0.11
          nodejs modules from github:     2
          +-- iobroker.nebenkosten-monitor@1.3.5 (git+ssh://git@github.com/fischi87/ioBroker.nebenkosten-monitor.git#6d2aa917c772506c0ce5be8fb1d2dce3d59254c2)
          +-- iobroker.sourceanalytix@0.4.15-alpha.1 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.sourceanalytix.git#fd3b7f9f362a348741cbe18d70a130d2bfee6727)
          Adapter State
          + system.adapter.admin.0                  : admin                 : Odin                                     -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.alexa2.0                 : alexa2                : Odin                                     -  enabled
          + system.adapter.backitup.0               : backitup              : Odin                                     -  enabled
            system.adapter.device-reminder.0        : device-reminder       : Odin                                     - disabled
          + system.adapter.discovery.0              : discovery             : Odin                                     -  enabled
          + system.adapter.history.0                : history               : Odin                                     -  enabled
          + system.adapter.influxdb.0               : influxdb              : Odin                                     -  enabled, port: 8086
          + system.adapter.influxdb.1               : influxdb              : Odin                                     -  enabled, port: 8086
          + system.adapter.influxdb.2               : influxdb              : Odin                                     -  enabled, port: 8086
          + system.adapter.influxdb.3               : influxdb              : Odin                                     -  enabled, port: 8086
          + system.adapter.influxdb.4               : influxdb              : Odin                                     -  enabled, port: 8086
          + system.adapter.influxdb.5               : influxdb              : Odin                                     -  enabled, port: 8086
          + system.adapter.influxdb.6               : influxdb              : Odin                                     -  enabled, port: 8086
          + system.adapter.influxdb.7               : influxdb              : Odin                                     -  enabled, port: 8086
          + system.adapter.javascript.0             : javascript            : Odin                                     -  enabled
          + system.adapter.linux-control.0          : linux-control         : Odin                                     -  enabled
          + system.adapter.nebenkosten-monitor.0    : nebenkosten-monitor   : Odin                                     -  enabled
          + system.adapter.pirate-weather.0         : pirate-weather        : Odin                                     -  enabled
          + system.adapter.shelly.0                 : shelly                : Odin                                     -  enabled, port: 1882, bind: 0.0.0.0
          + system.adapter.shelly.1                 : shelly                : Odin                                     -  enabled, port: 1888, bind: 0.0.0.0
          + system.adapter.sonoff.0                 : sonoff                : Odin                                     -  enabled, port: 1883, bind: 0.0.0.0
          + system.adapter.sourceanalytix.0         : sourceanalytix        : Odin                                     -  enabled
            system.adapter.telegram.0               : telegram              : Odin                                     - disabled, port: 8443, bind: 0.0.0.0
            system.adapter.web.0                    : web                   : Odin                                     - disabled, port: 8082, bind: 0.0.0.0, run as: admin
          + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : Odin                                     -  enabled
          + instance is alive
          ioBroker-Repositories
          Active repo(s): stable
          Upgrade policy: none
          Installed ioBroker-Adapters
          Used repository: stable
          Adapter    "admin"        : 7.7.19   , installed 7.7.19
          Adapter    "alexa2"       : 3.27.4   , installed 3.27.4
          Adapter    "backitup"     : 3.3.13   , installed 3.3.13
          Adapter    "device-reminder": 3.1.2  , installed 3.1.2
          Adapter    "javascript"   : 9.0.11   , installed 9.0.11
          Controller "js-controller": 7.0.7    , installed 7.0.7
          Adapter    "linux-control": 1.1.5    , installed 1.1.5
          Adapter    "pirate-weather": 0.8.0   , installed 0.8.0
          Adapter    "shelly"       : 10.4.1   , installed 10.4.1
          Adapter    "socketio"     : 6.7.1    , installed 6.7.1
          Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
          Adapter    "web"          : 7.0.8    , installed 7.0.8
          Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
          Adapter    "ws"           : 2.6.2    , installed 2.6.2
          Objects and States
          Objects:        6579
          States:         6176
          Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
          Hit:3 https://repos.influxdata.com/debian stable InRelease
          Hit:4 http://deb.debian.org/debian-security bookworm-security InRelease
          Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
          Reading package lists... Done
          Pending Updates: 41
          *** Listening Ports ***
          tcp        0      0 0.0.0.0:3000            0.0.0.0:*               LISTEN      0          1901499105 -
          tcp        0      0 0.0.0.0:3306            0.0.0.0:*               LISTEN      0          1901512963 -
          tcp        0      0 0.0.0.0:3333            0.0.0.0:*               LISTEN      0          1901428797 -
          tcp        0      0 0.0.0.0:3702            0.0.0.0:*               LISTEN      0          1901893145 -
          tcp        0      0 0.0.0.0:3702            0.0.0.0:*               LISTEN      0          1901893144 -
          tcp        0      0 0.0.0.0:20211           0.0.0.0:*               LISTEN      20211      90440      -
          tcp        0      0 0.0.0.0:20212           0.0.0.0:*               LISTEN      20211      119413     -
          tcp        0      0 0.0.0.0:4040            0.0.0.0:*               LISTEN      0          80056      -
          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          41297      -
          tcp        0      0 0.0.0.0:49517           0.0.0.0:*               LISTEN      32         33308      -
          tcp        0      0 192.168.122.1:53        0.0.0.0:*               LISTEN      0          80114      -
          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      99         1901945074 -
          tcp        0      0 0.0.0.0:1888            0.0.0.0:*               LISTEN      99         1901933537 -
          tcp        0      0 0.0.0.0:7634            0.0.0.0:*               LISTEN      0          1901887528 -
          tcp        0      0 127.0.0.1:443           0.0.0.0:*               LISTEN      0          23972      -
          tcp        0      0 127.0.0.1:445           0.0.0.0:*               LISTEN      0          4519       -
          tcp        0      0 0.0.0.0:7878            0.0.0.0:*               LISTEN      0          1901311380 -
          tcp        0      0 127.0.0.1:16509         0.0.0.0:*               LISTEN      0          84317      -
          tcp        0      0 127.0.0.1:80            0.0.0.0:*               LISTEN      0          23970      -
          tcp        0      0 0.0.0.0:8088            0.0.0.0:*               LISTEN      0          1901810497 -
          tcp        0      0 0.0.0.0:8083            0.0.0.0:*               LISTEN      0          1901816074 -
          tcp        0      0 0.0.0.0:8080            0.0.0.0:*               LISTEN      0          1901892215 -
          tcp        0      0 0.0.0.0:8086            0.0.0.0:*               LISTEN      0          1901810494 -
          tcp        0      0 0.0.0.0:8074            0.0.0.0:*               LISTEN      0          1901879426 -
          tcp        0      0 0.0.0.0:8073            0.0.0.0:*               LISTEN      0          1901873765 -
          tcp        0      0 0.0.0.0:8072            0.0.0.0:*               LISTEN      0          1901877377 -
          tcp        0      0 127.0.0.1:139           0.0.0.0:*               LISTEN      0          4520       -
          tcp        0      0 0.0.0.0:8191            0.0.0.0:*               LISTEN      0          1901299071 -
          tcp        0      0 0.0.0.0:37361           0.0.0.0:*               LISTEN      0          123277     -
          tcp        0      0 0.0.0.0:5055            0.0.0.0:*               LISTEN      0          1901385399 -
          tcp        0      0 0.0.0.0:5355            0.0.0.0:*               LISTEN      0          1901893151 -
          tcp        0      0 0.0.0.0:5355            0.0.0.0:*               LISTEN      0          1901893150 -
          tcp        0      0 0.0.0.0:5432            0.0.0.0:*               LISTEN      0          1901423247 -
          tcp        0      0 0.0.0.0:5800            0.0.0.0:*               LISTEN      99         1901879756 -
          tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      99         1901874471 -
          tcp        0      0 127.0.0.1:2049          0.0.0.0:*               LISTEN      0          126346     -
          tcp        0      0 0.0.0.0:43363           0.0.0.0:*               LISTEN      0          123309     -
          tcp        0      0 0.0.0.0:44835           0.0.0.0:*               LISTEN      0          123204     -
          tcp        0      0 0.0.0.0:8192            0.0.0.0:*               LISTEN      0          1901296062 -
          tcp        0      0 0.0.0.0:8666            0.0.0.0:*               LISTEN      0          1901809079 -
          tcp        0      0 0.0.0.0:8686            0.0.0.0:*               LISTEN      0          1901297198 -
          tcp        0      0 0.0.0.0:8765            0.0.0.0:*               LISTEN      0          1901878464 -
          tcp        0      0 0.0.0.0:8989            0.0.0.0:*               LISTEN      0          1901294199 -
          tcp        0      0 0.0.0.0:9090            0.0.0.0:*               LISTEN      0          1901885772 -
          tcp        0      0 0.0.0.0:42283           0.0.0.0:*               LISTEN      0          123293     -
          tcp        0      0 0.0.0.0:9705            0.0.0.0:*               LISTEN      0          1901356900 -
          tcp        0      0 0.0.0.0:9696            0.0.0.0:*               LISTEN      0          1901356111 -
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      99         1901886699 -
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      99         1901886694 -
          tcp        0      0 192.168.0.60:22         0.0.0.0:*               LISTEN      0          259        -
          tcp        0      0 192.168.0.60:80         0.0.0.0:*               LISTEN      0          23971      -
          tcp        0      0 192.168.0.60:139        0.0.0.0:*               LISTEN      0          4522       -
          tcp        0      0 192.168.0.60:443        0.0.0.0:*               LISTEN      0          23973      -
          tcp        0      0 192.168.0.60:445        0.0.0.0:*               LISTEN      0          4521       -
          tcp        0      0 192.168.0.60:2049       0.0.0.0:*               LISTEN      0          126331     -
          tcp6       0      0 :::3000                 :::*                    LISTEN      0          1901505032 -
          tcp6       0      0 :::3306                 :::*                    LISTEN      0          1901490001 -
          tcp6       0      0 :::3333                 :::*                    LISTEN      0          1901421084 -
          tcp6       0      0 :::4040                 :::*                    LISTEN      0          62252      -
          tcp6       0      0 :::111                  :::*                    LISTEN      0          41301      -
          tcp6       0      0 :::33163                :::*                    LISTEN      32         33314      -
          tcp6       0      0 :::33953                :::*                    LISTEN      0          123206     -
          tcp6       0      0 :::7878                 :::*                    LISTEN      0          1901344007 -
          tcp6       0      0 :::8088                 :::*                    LISTEN      0          1901817072 -
          tcp6       0      0 :::8083                 :::*                    LISTEN      0          1901816079 -
          tcp6       0      0 :::8081                 :::*                    LISTEN      99         1901890266 -
          tcp6       0      0 :::8080                 :::*                    LISTEN      0          1901880195 -
          tcp6       0      0 :::8086                 :::*                    LISTEN      0          1901816082 -
          tcp6       0      0 :::8074                 :::*                    LISTEN      0          1901880383 -
          tcp6       0      0 :::8073                 :::*                    LISTEN      0          1901865752 -
          tcp6       0      0 :::8072                 :::*                    LISTEN      0          1901873756 -
          tcp6       0      0 :::8096                 :::*                    LISTEN      2          1901505881 -
          tcp6       0      0 :::8191                 :::*                    LISTEN      0          1901303139 -
          tcp6       0      0 :::5055                 :::*                    LISTEN      0          1901421869 -
          tcp6       0      0 :::5432                 :::*                    LISTEN      0          1901423252 -
          tcp6       0      0 :::38271                :::*                    LISTEN      0          123317     -
          tcp6       0      0 ::1:9666                :::*                    LISTEN      99         1901883564 -
          tcp6       0      0 :::5800                 :::*                    LISTEN      99         1901879757 -
          tcp6       0      0 :::5900                 :::*                    LISTEN      99         1901874472 -
          tcp6       0      0 :::8192                 :::*                    LISTEN      0          1901300620 -
          tcp6       0      0 :::8666                 :::*                    LISTEN      0          1901763435 -
          tcp6       0      0 :::8686                 :::*                    LISTEN      0          1901292370 -
          tcp6       0      0 :::8765                 :::*                    LISTEN      0          1901876568 -
          tcp6       0      0 :::8989                 :::*                    LISTEN      0          1901335552 -
          tcp6       0      0 :::9100                 :::*                    LISTEN      0          28877      -
          tcp6       0      0 :::9090                 :::*                    LISTEN      0          1901888603 -
          tcp6       0      0 :::9705                 :::*                    LISTEN      0          1901353537 -
          tcp6       0      0 :::9696                 :::*                    LISTEN      0          1901350776 -
          tcp6       0      0 127.0.0.1:9666          :::*                    LISTEN      99         1901883563 -
          tcp6       0      0 127.0.0.1:9665          :::*                    LISTEN      99         1901878132 -
          tcp6       0      0 :::47875                :::*                    LISTEN      0          123285     -
          tcp6       0      0 :::45245                :::*                    LISTEN      0          123301     -
          udp        0      0 0.0.0.0:64470           0.0.0.0:*                           0          41295      -
          udp        0      0 192.168.122.1:53        0.0.0.0:*                           0          80113      -
          udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          80110      -
          udp        0      0 192.168.0.60:111        0.0.0.0:*                           0          41294      -
          udp        0      0 127.0.0.1:111           0.0.0.0:*                           0          41293      -
          udp        0      0 192.168.0.60:123        0.0.0.0:*                           44         64291      -
          udp        0      0 127.0.0.1:123           0.0.0.0:*                           0          6358       -
          udp        0      0 192.168.0.60:137        0.0.0.0:*                           0          9540       -
          udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          9528       -
          udp        0      0 192.168.0.60:138        0.0.0.0:*                           0          9541       -
          udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          9529       -
          udp        0      0 0.0.0.0:161             0.0.0.0:*                           0          29054      -
          udp        0      0 127.0.0.1:768           0.0.0.0:*                           0          33300      -
          udp        0      0 0.0.0.0:50739           0.0.0.0:*                           0          123203     -
          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           2          1901511752 -
          udp        0      0 127.0.0.1:2049          0.0.0.0:*                           0          126347     -
          udp        0      0 192.168.0.60:2049       0.0.0.0:*                           0          126345     -
          udp        0      0 0.0.0.0:3702            0.0.0.0:*                           0          1901893143 -
          udp        0      0 0.0.0.0:3702            0.0.0.0:*                           0          1901893141 -
          udp        0      0 0.0.0.0:53703           0.0.0.0:*                           0          123273     -
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           61         4507       -
          udp        0      0 0.0.0.0:5355            0.0.0.0:*                           0          1901893149 -
          udp        0      0 0.0.0.0:5355            0.0.0.0:*                           0          1901893147 -
          udp        0      0 0.0.0.0:5683            0.0.0.0:*                           99         1901943017 -
          udp        0      0 0.0.0.0:55039           0.0.0.0:*                           0          123289     -
          udp        0      0 0.0.0.0:38712           0.0.0.0:*                           2          1901511753 -
          udp        0      0 0.0.0.0:39495           0.0.0.0:*                           32         33305      -
          udp        0      0 0.0.0.0:57063           0.0.0.0:*                           0          66665      -
          udp        0      0 0.0.0.0:57934           0.0.0.0:*                           0          123305     -
          udp        0      0 0.0.0.0:59085           0.0.0.0:*                           61         4508       -
          udp        0      0 192.168.0.60:43253      0.0.0.0:*                           2          1901511754 -
          udp        0      0 127.0.0.1:60511         0.0.0.0:*                           2          1901511755 -
          udp        0      0 192.168.0.60:45542      0.0.0.0:*                           0          24034      -
          udp6       0      0 :::63538                :::*                                0          41300      -
          udp6       0      0 ::1:111                 :::*                                0          41298      -
          udp6       0      0 :::52657                :::*                                0          123297     -
          udp6       0      0 :::36464                :::*                                0          123281     -
          udp6       0      0 :::53036                :::*                                0          123205     -
          udp6       0      0 :::55493                :::*                                0          123313     -
          udp6       0      0 :::56257                :::*                                32         33311      -
          udp6       0      0 :::7359                 :::*                                2          1901503302 -
          2026-01-13 12:30:00.002  - info: javascript.0 (307) script.js.common.Shelly_COAP: Shelly Verbrauch: Verbrauchswerte aktualisiert: 2 | Reboots korrigiert: 0 | Unveränderte Werte: 2
          2026-01-13 12:30:00.004  - info: javascript.0 (307) script.js.common.Tasmo_Sono_Kosten: Sonoff/Tasmota Kosten: Verwende Strompreis von 0.3159 €/kWh für diese Berechnung.
          2026-01-13 12:30:00.005  - info: javascript.0 (307) script.js.common.Tasmo_Sono_Kosten: Sonoff/Tasmota Kosten: Update abgeschlossen. Geräte mit Verbrauch: 3 | Reboots erkannt: 0 | Fehler: 0
          2026-01-13 12:30:00.010  - info: javascript.0 (307) script.js.common.Shelly_MQTT: Shelly Verbrauch: Verbrauchswerte aktualisiert: 3 | Reboots korrigiert: 0 | Unveränderte Werte: 2
          2026-01-13 12:30:57.312  - info: linux-control.0 (693) successful received data from RPi-HA (192.168.0.11:22)
          2026-01-13 12:31:13.962  - info: linux-control.0 (693) getting data from Pihole2 (192.168.0.6:22)
          2026-01-13 12:31:23.817  - info: linux-control.0 (693) getting data from RPi-KUE (192.168.0.10:22)
          2026-01-13 12:31:35.373  - info: linux-control.0 (693) successful received data from RPi-KUE (192.168.0.10:22)
          2026-01-13 12:31:40.379  - info: linux-control.0 (693) successful received data from Pihole2 (192.168.0.6:22)
          2026-01-13 12:32:34.402  - info: linux-control.0 (693) getting data from Pihole1 (192.168.0.3:22)
          2026-01-13 12:32:44.027  - info: linux-control.0 (693) successful received data from Pihole1 (192.168.0.3:22)
          2026-01-13 12:34:35.374  - info: linux-control.0 (693) getting data from RPi-KUE (192.168.0.10:22)
          2026-01-13 12:34:45.048  - info: linux-control.0 (693) successful received data from RPi-KUE (192.168.0.10:22)
          2026-01-13 12:35:57.313  - info: linux-control.0 (693) getting data from RPi-HA (192.168.0.11:22)
          2026-01-13 12:36:02.319  - error: linux-control.0 (693) [getConnection] Could not establish a connection to 'RPi-HA' (192.168.0.11:22)!
          2026-01-13 12:36:02.319  - error: linux-control.0 (693) [getConnection] error: Timed out while waiting for handshake, stack: Error: Timed out while waiting for handshake
              at Timeout._onTimeout (/opt/iobroker/node_modules/ssh2/lib/client.js:1114:23)
              at listOnTimeout (node:internal/timers:588:17)
              at process.processTimers (node:internal/timers:523:7)
          2026-01-13 12:36:40.380  - info: linux-control.0 (693) getting data from Pihole2 (192.168.0.6:22)
          2026-01-13 12:37:07.329  - info: linux-control.0 (693) successful received data from Pihole2 (192.168.0.6:22)
          2026-01-13 12:37:44.028  - info: linux-control.0 (693) getting data from Pihole1 (192.168.0.3:22)
          2026-01-13 12:37:45.047  - info: linux-control.0 (693) getting data from RPi-KUE (192.168.0.10:22)
          2026-01-13 12:37:53.486  - info: linux-control.0 (693) successful received data from RPi-KUE (192.168.0.10:22)
          2026-01-13 12:37:53.687  - info: linux-control.0 (693) successful received data from Pihole1 (192.168.0.3:22)
          iob diag has finished.
          Vielleicht hilft das ja weiter.
          • RoddiEFR RoddiEF
            ```bash
            Script v.2025-08-09
            *** BASE SYSTEM ***
            Kernel          : x86_64
            Userland        : 64 bit
            Docker          : v11.0.0
            Kernel          : x86_64
            Userland        : 64 bit
            CPU threads: 12
            CET +0100
            Etc/UTC
            root
            HOME=/root
            GROUPS=root
            iobroker
            HOME=/opt/iobroker
            Display-Manager:
            Desktop:
            Session:
            *** MEMORY ***
            Swap:             0B          0B          0B
            Total:           29G         15G        416M
                    14802 M used memory
                      397 M free memory
                        0 M buffer memory
                    15219 M swap cache
                        0 M total swap
                        0 M used swap
                        0 M free swap
            *** FILESYSTEM ***
        btrfs  rw,noat
            |-/opt/userscripts
            |-/opt/iobroker
            |-/etc/resolv.conf
            |        btrfs  rw,noat
            |-/etc/hostname
            |        btrfs  rw,noat
        btrfs  rw,noat
            /var:
            35M     /var/
            33M     /var/lib
            19M     /var/lib/apt
            14M     /var/lib/dpkg
            USB-Devices by-id:
            zigbee.X
            Extended Pan ID:
            *** MASKED ***
            Pan ID:
            *** MASKED ***
            Channel:
            *** MASKED ***
            Network Key:
            *** MASKED ***
            /usr/bin/npm            10.9.4
            /usr/bin/npx            10.9.4
            nodejs:
              Version table:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Hosts:
            admin:          7.7.19
            javascript:     9.0.11
            Adapter State
            + instance is alive
            Objects and States
            Objects:        6579
            States:         6176
            Pending Updates: 41
            #705
            @RoddiEF sagte in Test Adapter Linux Control v1.x.x:
            dein Problem müsste hier zu suchen sein
            2026-01-13 12:36
            RoddiEFR 1 Antwort Letzte Antwort
              2026-01-13 12:36
              RoddiEFR Offline
              RoddiEFR Offline
              RoddiEF
              schrieb am zuletzt editiert von RoddiEF
              #706
              @Homoran sagte in Test Adapter Linux Control v1.x.x:
              error: linux-control.0 (693) [getConnection] Could not establish a connection to 'RPi->HA' (192.168.0.11:22)!
              2026-01-13 12:36
              Das kam daher das ich gleichzeitig den RPi, der da auftaucht, geupdatet sowie ein Reboot gemacht habe (was ich immer mache nach Updates) und er deshalb nicht erreichbar war. Kann mir also nicht Vorstellen das es daran liegen sollte.
              • RoddiEFR RoddiEF
                2026-01-13 12:36
                #707
                @RoddiEF und was läuft jetzt nicht?
                Alle anderen Einträge im log sehen doch gut aus.
                  RoddiEFR Offline
                  RoddiEFR Offline
                  RoddiEF
                  #708
                  Im Kern des ganzen ging es darum das der Adapter einen Fehler ins Log schreibt wenn er gestartet wird.
                  Daten liefert er ja, aber jeden Morgen (nach dem Backup vom ioBroker) bringt er den Fehler und das macht mich kirre im Kopf.
                  Edit: bild hinzugefügt
                  • RoddiEFR RoddiEF
                    #709
                    wenn das alles ist, kannst du das ignorieren
                    • 1Topf1 Offline
                      1Topf1 Offline
                      1Topf
                      #710
                      Hat zu meinem Problem niemand eine Idee? 😕
                      https://forum.iobroker.net/post/1316457
                      Ich hab da auch mal ne Frage. Ich hab jetzt einen Raspi3 eingebunden, auf welchem 2 Kameras (Garten u. Hof) auf einem USB-Stick Bilder ablegen. Beide Ordner enthalten aktuell jeweils >20GB Daten. Wieso wird das nicht korrekt dargestellt? Hat da jemand eine Idee? Die Anzahl der Dateien hingegen stimmt.
                      • 1Topf1 1Topf
                        crunchipC Abwesend
                        crunchipC Abwesend
                        #711
                        @1Topf sagte in Test Adapter Linux Control v1.x.x:
                        und wie sind die jeweils ins System eingebunden?
                        1Topf1 1 Antwort Letzte Antwort
                          1Topf1 Offline
                          1Topf1 Offline
                          1Topf
                          #712
                          @crunchip sagte in Test Adapter Linux Control v1.x.x:
                          Tja, mal kurz überlegen (is schon ne Weile her ...).
                          Auf dem Raspi3 läuft Debian GNU/Linux 12 (bookworm), raspios ohne GUI. Die Bilder werden von den Kameras per FTP auf den Raspi geschickt.
                          Der Stick ist normal 🤷‍♂️ eingebunden:
                          Dateisystem Größe Benutzt Verf. Verw% Eingehängt auf
                          /dev/sda1 __ 58G __ 50G _ 8,3G _ 86% _ /media/usbstick
                          Die beiden Ordner liegen unter /media/usbstick/Garten bzw. .../Hof.
                          Oder welche Info genau hättest Du gern?
                            @D3ltoroxp die Frage ist eher, was da genau läuft auf deinen Systemen. Hat ja nichts mit den Befehlen zu tun.
                            D3ltoroxpD Offline
                            D3ltoroxpD Offline
                            D3ltoroxp
                            schrieb am zuletzt editiert von D3ltoroxp
                            #713
                            Also das ist einmal nen LXC mit Mainsail / Klipper drauf und einmal ein PVE Host. Die beiden habe ich angelegt. Daraus erstellt er dann die DP's. Das ding lief auch schon mal. Ich befürchte seit irgendeinem Update läuft das bei mir nicht mehr richtig.
                            Wenn ich ihn starte dreht die Log komplett durch.
                            host.iobroker
                            2026-01-13 21:50:47.913	error	instance system.adapter.linux-control.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                            host.iobroker
                            2026-01-13 21:50:47.913	error	Caught by controller[9]: at processTicksAndRejections (node:internal/process/task_queues:105:5)
                            host.iobroker
                            2026-01-13 21:50:47.913	error	Caught by controller[9]: at StateRedisClient.subscribe (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1124:27)
                            host.iobroker
                            2026-01-13 21:50:47.913	error	Caught by controller[9]: at Module.pattern2RegEx (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2507:15)
                            host.iobroker
                            2026-01-13 21:50:47.913	error	Caught by controller[9]: Error: The pattern "io.linux-control.0.Mainsail.services.●.start" is not a valid ID pattern
                            host.iobroker
                            2026-01-13 21:50:47.913	error	Caught by controller[9]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                            host.iobroker
                            2026-01-13 21:50:47.913	error	Caught by controller[8]: at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
                            host.iobroker
                            2026-01-13 21:50:47.913	error	Caught by controller[8]: at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12)
                            host.iobroker
                            2026-01-13 21:50:47.913	error	Caught by controller[8]: ReplyError: Error The pattern "linux-control.0.Mainsail.services.●.stop" is not a valid ID pattern
                            host.iobroker
                            2026-01-13 21:50:47.913	error	Caught by controller[7]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                            host.iobroker
                            2026-01-13 21:50:47.913	error	Caught by controller[6]: at processTicksAndRejections (node:internal/process/task_queues:105:5)
                            host.iobroker
                            2026-01-13 21:50:47.913	error	Caught by controller[6]: at StateRedisClient.subscribe (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1124:27)
                            host.iobroker
                            2026-01-13 21:50:47.913	error	Caught by controller[6]: at Module.pattern2RegEx (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2507:15)
                            host.iobroker
                            2026-01-13 21:50:47.913	error	Caught by controller[6]: Error: The pattern "io.linux-control.0.Mainsail.services.●.start" is not a valid ID pattern
                            host.iobroker
                            2026-01-13 21:50:47.913	error	Caught by controller[5]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                            host.iobroker
                            2026-01-13 21:50:47.912	error	Caught by controller[4]: at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
                            host.iobroker
                            2026-01-13 21:50:47.912	error	Caught by controller[4]: at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12)
                            host.iobroker
                            2026-01-13 21:50:47.912	error	Caught by controller[4]: ReplyError: Error The pattern "linux-control.0.Mainsail.services.●.stop" is not a valid ID pattern
                            host.iobroker
                            2026-01-13 21:50:47.912	error	Caught by controller[3]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                            host.iobroker
                            2026-01-13 21:50:47.912	error	Caught by controller[2]: at processTicksAndRejections (node:internal/process/task_queues:105:5)
                            host.iobroker
                            2026-01-13 21:50:47.912	error	Caught by controller[2]: at StateRedisClient.subscribe (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1124:27)
                            host.iobroker
                            2026-01-13 21:50:47.912	error	Caught by controller[2]: at Module.pattern2RegEx (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2507:15)
                            host.iobroker
                            2026-01-13 21:50:47.912	error	Caught by controller[2]: Error: The pattern "io.linux-control.0.Mainsail.services.●.start" is not a valid ID pattern
                            host.iobroker
                            2026-01-13 21:50:47.912	error	Caught by controller[2]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                            host.iobroker
                            2026-01-13 21:50:47.912	error	Caught by controller[1]: at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
                            host.iobroker
                            2026-01-13 21:50:47.912	error	Caught by controller[1]: at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12)
                            host.iobroker
                            2026-01-13 21:50:47.912	error	Caught by controller[1]: ReplyError: Error The pattern "linux-control.0.Mainsail.services.●.restart" is not a valid ID pattern
                            host.iobroker
                            2026-01-13 21:50:47.912	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                            linux-control.0
                            2026-01-13 21:50:47.810	info	terminating
                            linux-control.0
                            linux-control.0
                            2026-01-13 21:50:47.782	warn	Used invalid characters: linux-control.0.Mainsail.services.●.stop changed to linux-control.0.Mainsail.services._.stop
                            linux-control.0
                            2026-01-13 21:50:47.781	error	Error: The pattern "io.linux-control.0.Mainsail.services.●.start" is not a valid ID pattern at Module.pattern2RegEx (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2507:15) at StateRedisClient.subscribe (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1124:27) at processTicksAndRejections (node:internal/process/task_queues:105:5)
                            linux-control.0
                            2026-01-13 21:50:47.780	error	unhandled promise rejection: The pattern "io.linux-control.0.Mainsail.services.●.start" is not a valid ID pattern
                            linux-control.0
                            2026-01-13 21:50:47.780	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                            linux-control.0
                            2026-01-13 21:50:47.779	warn	Used invalid characters: linux-control.0.Mainsail.services.●.start changed to linux-control.0.Mainsail.services._.start
                            linux-control.0
                            2026-01-13 21:50:47.778	warn	Used invalid characters: linux-control.0.Mainsail.services.●.restart changed to linux-control.0.Mainsail.services._.restart
                            linux-control.0
                            2026-01-13 21:50:47.736	warn	State "linux-control.0.Mainsail.services.●.description" has no existing object, this might lead to an error in future versions
                            linux-control.0
                            2026-01-13 21:50:47.734	warn	Used invalid characters: linux-control.0.Mainsail.services.●.description changed to linux-control.0.Mainsail.services._.description
                            linux-control.0
                            2026-01-13 21:50:47.687	warn	State "linux-control.0.Mainsail.services.●.running" has no existing object, this might lead to an error in future versions
                            linux-control.0
                            2026-01-13 21:50:47.686	warn	Used invalid characters: linux-control.0.Mainsail.services.●.running changed to linux-control.0.Mainsail.services._.running
                            linux-control.0
                            2026-01-13 21:50:47.642	warn	State "linux-control.0.Mainsail.services.●.active" has no existing object, this might lead to an error in future versions
                            linux-control.0
                            2026-01-13 21:50:47.638	warn	Used invalid characters: linux-control.0.Mainsail.services.●.active changed to linux-control.0.Mainsail.services._.active
                            linux-control.0
                            2026-01-13 21:50:47.593	warn	State "linux-control.0.Mainsail.services.●.load" has no existing object, this might lead to an error in future versions
                            linux-control.0
                            2026-01-13 21:50:47.591	warn	Used invalid characters: linux-control.0.Mainsail.services.●.load changed to linux-control.0.Mainsail.services._.load
                            linux-control.0
                            2026-01-13 21:50:47.589	error	ReplyError: Error The pattern "linux-control.0.Mainsail.services.●.stop" is not a valid ID pattern at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12) at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
                            linux-control.0
                            2026-01-13 21:50:47.589	error	unhandled promise rejection: Error The pattern "linux-control.0.Mainsail.services.●.stop" is not a valid ID pattern
                            linux-control.0
                            2026-01-13 21:50:47.589	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                            host.iobroker
                            2026-01-13 21:50:47.588	warn	host.iobroker-Server States 127.0.0.1:44596 Error from InMemDB: Error: The pattern "linux-control.0.Mainsail.services.●.stop" is not a valid ID pattern at Module.pattern2RegEx (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2507:15) at StatesInMemoryServer.handleSubscribe (file:///opt/iobroker/node_modules/@iobroker/db-base/src/lib/inMemFileDB.ts:323:59) at StatesInMemoryServer._subscribeForClient (file:///opt/iobroker/node_modules/@iobroker/db-states-file/src/lib/states/statesInMemFileDB.js:240:14) at RedisHandler.<anonymous> (file:///opt/iobroker/node_modules/@iobroker/db-states-jsonl/src/lib/states/statesInMemServerRedis.js:380:26) at RedisHandler.emit (node:events:519:28) at Immediate._onImmediate (file:///opt/iobroker/node_modules/@iobroker/db-base/src/lib/redisHandler.ts:210:37) at processImmediate (node:internal/timers:485:21) at process.callbackTrampoline (node:internal/async_hooks:130:17)
                            linux-control.0
                            2026-01-13 21:50:47.587	warn	Used invalid characters: linux-control.0.Mainsail.services.●.stop changed to linux-control.0.Mainsail.services._.stop
                            linux-control.0
                            2026-01-13 21:50:47.585	error	Error: The pattern "io.linux-control.0.Mainsail.services.●.start" is not a valid ID pattern at Module.pattern2RegEx (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2507:15) at StateRedisClient.subscribe (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1124:27) at processTicksAndRejections (node:internal/process/task_queues:105:5)
                            linux-control.0
                            2026-01-13 21:50:47.584	error	unhandled promise rejection: The pattern "io.linux-control.0.Mainsail.services.●.start" is not a valid ID pattern
                            linux-control.0
                            2026-01-13 21:50:47.584	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                            linux-control.0
                            2026-01-13 21:50:47.583	warn	Used invalid characters: linux-control.0.Mainsail.services.●.start changed to linux-control.0.Mainsail.services._.start
                            linux-control.0
                            2026-01-13 21:50:47.582	warn	Used invalid characters: linux-control.0.Mainsail.services.●.restart changed to linux-control.0.Mainsail.services._.restart
                            linux-control.0
                            2026-01-13 21:50:47.539	warn	State "linux-control.0.Mainsail.services.●.description" has no existing object, this might lead to an error in future versions
                            linux-control.0
                            2026-01-13 21:50:47.538	warn	Used invalid characters: linux-control.0.Mainsail.services.●.description changed to linux-control.0.Mainsail.services._.description
                            linux-control.0
                            2026-01-13 21:50:47.492	warn	State "linux-control.0.Mainsail.services.●.running" has no existing object, this might lead to an error in future versions
                            linux-control.0
                            2026-01-13 21:50:47.490	warn	Used invalid characters: linux-control.0.Mainsail.services.●.running changed to linux-control.0.Mainsail.services._.running
                            linux-control.0
                            2026-01-13 21:50:47.443	warn	State "linux-control.0.Mainsail.services.●.active" has no existing object, this might lead to an error in future versions
                            linux-control.0
                            2026-01-13 21:50:47.442	warn	Used invalid characters: linux-control.0.Mainsail.services.●.active changed to linux-control.0.Mainsail.services._.active
                            linux-control.0
                            2026-01-13 21:50:47.399	warn	State "linux-control.0.Mainsail.services.●.load" has no existing object, this might lead to an error in future versions
                            linux-control.0
                            2026-01-13 21:50:47.398	warn	Used invalid characters: linux-control.0.Mainsail.services.●.load changed to linux-control.0.Mainsail.services._.load
                            linux-control.0
                            2026-01-13 21:50:47.396	error	ReplyError: Error The pattern "linux-control.0.Mainsail.services.●.stop" is not a valid ID pattern at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12) at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
                            linux-control.0
                            2026-01-13 21:50:47.396	error	unhandled promise rejection: Error The pattern "linux-control.0.Mainsail.services.●.stop" is not a valid ID pattern
                            linux-control.0
                            2026-01-13 21:50:47.395	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                            host.iobroker
                            2026-01-13 21:50:47.395	warn	host.iobroker-Server States 127.0.0.1:44596 Error from InMemDB: Error: The pattern "linux-control.0.Mainsail.services.●.stop" is not a valid ID pattern at Module.pattern2RegEx (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2507:15) at StatesInMemoryServer.handleSubscribe (file:///opt/iobroker/node_modules/@iobroker/db-base/src/lib/inMemFileDB.ts:323:59) at StatesInMemoryServer._subscribeForClient (file:///opt/iobroker/node_modules/@iobroker/db-states-file/src/lib/states/statesInMemFileDB.js:240:14) at RedisHandler.<anonymous> (file:///opt/iobroker/node_modules/@iobroker/db-states-jsonl/src/lib/states/statesInMemServerRedis.js:380:26) at RedisHandler.emit (node:events:519:28) at Immediate._onImmediate (file:///opt/iobroker/node_modules/@iobroker/db-base/src/lib/redisHandler.ts:210:37) at processImmediate (node:internal/timers:485:21) at process.callbackTrampoline (node:internal/async_hooks:130:17)
                            linux-control.0
                            2026-01-13 21:50:47.390	warn	Used invalid characters: linux-control.0.Mainsail.services.●.stop changed to linux-control.0.Mainsail.services._.stop
                            linux-control.0
                            2026-01-13 21:50:47.389	error	Error: The pattern "io.linux-control.0.Mainsail.services.●.start" is not a valid ID pattern at Module.pattern2RegEx (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2507:15) at StateRedisClient.subscribe (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1124:27) at processTicksAndRejections (node:internal/process/task_queues:105:5)
                            linux-control.0
                            2026-01-13 21:50:47.338	error	unhandled promise rejection: The pattern "io.linux-control.0.Mainsail.services.●.start" is not a valid ID pattern
                            linux-control.0
                            2026-01-13 21:50:47.338	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                            linux-control.0
                            2026-01-13 21:50:47.310	warn	Used invalid characters: linux-control.0.Mainsail.services.●.start changed to linux-control.0.Mainsail.services._.start
                            linux-control.0
                            2026-01-13 21:50:47.309	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                            Das ist aktiv.
                            • D3ltoroxpD D3ltoroxp
                              host.iobroker
                              host.iobroker
                              host.iobroker
                              host.iobroker
                              host.iobroker
                              host.iobroker
                              host.iobroker
                              host.iobroker
                              host.iobroker
                              host.iobroker
                              host.iobroker
                              host.iobroker
                              host.iobroker
                              host.iobroker
                              host.iobroker
                              host.iobroker
                              host.iobroker
                              host.iobroker
                              host.iobroker
                              host.iobroker
                              host.iobroker
                              host.iobroker
                              host.iobroker
                              host.iobroker
                              host.iobroker
                              host.iobroker
                              host.iobroker
                              host.iobroker
                              linux-control.0
                              linux-control.0
                              linux-control.0
                              linux-control.0
                              linux-control.0
                              linux-control.0
                              linux-control.0
                              linux-control.0
                              linux-control.0
                              linux-control.0
                              linux-control.0
                              linux-control.0
                              linux-control.0
                              linux-control.0
                              linux-control.0
                              linux-control.0
                              linux-control.0
                              linux-control.0
                              linux-control.0
                              host.iobroker
                              linux-control.0
                              linux-control.0
                              linux-control.0
                              linux-control.0
                              linux-control.0
                              linux-control.0
                              linux-control.0
                              linux-control.0
                              linux-control.0
                              linux-control.0
                              linux-control.0
                              linux-control.0
                              linux-control.0
                              linux-control.0
                              linux-control.0
                              linux-control.0
                              linux-control.0
                              host.iobroker
                              linux-control.0
                              linux-control.0
                              linux-control.0
                              linux-control.0
                              linux-control.0
                              linux-control.0
                              Das ist aktiv.
                              crunchipC Abwesend
                              crunchipC Abwesend
                              #714
                              @D3ltoroxp sagte in Test Adapter Linux Control v1.x.x:
                              https://github.com/mainsail-crew/MainsailOS/releases/tag/2.2.2
                              Musst du halt mal vergleichen
                              Das ist aktiv
                              Vllt mal die Service ausschließen für deinen PI
                              • D3ltoroxpD Offline
                                D3ltoroxpD Offline
                                D3ltoroxp
                                #715
                                @crunchip Mit dem Update meinte ich vom Linux Control Adapter. Hab jetzt mal alles deaktiviert, bis auf den oberen Block Infos zum Host. Die Log ist recht sauber und ruhig. Funktionieren dann einfach die anderen Optionen nicht am System. Wie gesagt, beides mal Linux was da werkelt, einmal Proxmox Host und einmal nen LXC mit Mainsail.
