  4. [Major Update] SourceAnalytix v0.4.7-beta.0 released !
    6.6k
sourceanalytixtestenadapterupdate
1.1k Beiträge 103 Kommentatoren 440.6k Aufrufe 93 Beobachtet
  • G gerald123
    @Dutchman hab ich vergessen 🙄
    sourceanalytix.0	2020-08-28 17:45:27.691	debug	(31627) Update osf state javascript.0.scriptDatenPunkte.Hilfsobjekte.Wasser.Test_Wasser received with equal value 11.565 ignoring
    sourceanalytix.0	2020-08-28 17:45:27.691	debug	(31627) state javascript.0.scriptDatenPunkte.Hilfsobjekte.Wasser.Test_Wasser changed : {"val":11.565,"ack":true,"ts":1598629527679,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin
    sourceanalytix.0	2020-08-28 17:45:27.686	debug	(31627) Update osf state javascript.0.scriptDatenPunkte.Hilfsobjekte.Wasser.Wasserverbrauch received with equal value 11.565 ignoring
    sourceanalytix.0	2020-08-28 17:45:27.685	debug	(31627) state javascript.0.scriptDatenPunkte.Hilfsobjekte.Wasser.Wasserverbrauch changed : {"val":11.565,"ack":true,"ts":1598629527679,"q":0,"from":"system.adapter.javascript.0","user":"system.user.a
    sourceanalytix.0	2020-08-28 17:45:09.864	error	at process.topLevelDomainCallback (domain.js:126:23)
    sourceanalytix.0	2020-08-28 17:45:09.864	error	at processImmediate (timers.js:658:5)
    sourceanalytix.0	2020-08-28 17:45:09.864	error	at tryOnImmediate (timers.js:676:5)
    sourceanalytix.0	2020-08-28 17:45:09.864	error	at runCallback (timers.js:705:18)
    sourceanalytix.0	2020-08-28 17:45:09.864	error	at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5388:34)
    sourceanalytix.0	2020-08-28 17:45:09.864	error	at Sourceanalytix.EventEmitter.emit (domain.js:448:20)
    sourceanalytix.0	2020-08-28 17:45:09.864	error	at Sourceanalytix.emit (events.js:198:13)
    sourceanalytix.0	2020-08-28 17:45:09.864	error	at Sourceanalytix.onStateChange (/opt/iobroker/node_modules/iobroker.sourceanalytix/main.js:489:11)
    sourceanalytix.0	2020-08-28 17:45:09.864	error	at Sourceanalytix.calculationHandler (/opt/iobroker/node_modules/iobroker.sourceanalytix/main.js:736:78)
    sourceanalytix.0	2020-08-28 17:45:09.864	error	(31627) [calculationHandler javascript.0.scriptDatenPunkte.Hilfsobjekte.Wasser.Test_Wasser] error: Cannot read property 'cathegorie' of undefined, stack: TypeError: Cannot read property 'cathegorie'
    sourceanalytix.0	2020-08-28 17:45:09.862	debug	(31627) state javascript.0.scriptDatenPunkte.Hilfsobjekte.Wasser.Test_Wasser changed : {"val":11.565,"ack":true,"ts":1598629509852,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin
    sourceanalytix.0	2020-08-28 17:45:09.860	error	at process.topLevelDomainCallback (domain.js:126:23)
    sourceanalytix.0	2020-08-28 17:45:09.860	error	at processImmediate (timers.js:658:5)
    sourceanalytix.0	2020-08-28 17:45:09.860	error	at tryOnImmediate (timers.js:676:5)
    sourceanalytix.0	2020-08-28 17:45:09.860	error	at runCallback (timers.js:705:18)
    sourceanalytix.0	2020-08-28 17:45:09.860	error	at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5388:34)
    sourceanalytix.0	2020-08-28 17:45:09.860	error	at Sourceanalytix.EventEmitter.emit (domain.js:448:20)
    sourceanalytix.0	2020-08-28 17:45:09.860	error	at Sourceanalytix.emit (events.js:198:13)
    sourceanalytix.0	2020-08-28 17:45:09.860	error	at Sourceanalytix.onStateChange (/opt/iobroker/node_modules/iobroker.sourceanalytix/main.js:489:11)
    sourceanalytix.0	2020-08-28 17:45:09.860	error	at Sourceanalytix.calculationHandler (/opt/iobroker/node_modules/iobroker.sourceanalytix/main.js:736:78)
    sourceanalytix.0	2020-08-28 17:45:09.860	error	(31627) [calculationHandler javascript.0.scriptDatenPunkte.Hilfsobjekte.Wasser.Wasserverbrauch] error: Cannot read property 'cathegorie' of undefined, stack: TypeError: Cannot read property 'cathegor
    sourceanalytix.0	2020-08-28 17:45:09.859	debug	(31627) state javascript.0.scriptDatenPunkte.Hilfsobjekte.Wasser.Wasserverbrauch changed : {"val":11.565,"ack":true,"ts":1598629509852,"q":0,"from":"system.adapter.javascript.0","user":"system.user.a
    DutchmanD Offline
    DutchmanD Offline
    Dutchman
    #341
    @gerald123 sagte in [Major Update] SourceAnalytix 0.4.0 complete code rebuild:
    er kan bei dir aus irgend einem Grund die cathegorie nicht lesen .....
    Ok danke fuer raw object, damit kan ich den DP 100% reproduzieren und es mir mal bei mir local anschauen.
    Ich versprechen nichts fuer heute oder nieste Woche aber schaue es mir an, muss erstmal wieder bissl fuss fassen
    G 1 Antwort Letzte Antwort
    • DutchmanD Dutchman
      gerald123
      #342
      @Dutchman Ist Zeitlich kein Problem, bin froh das mir wer hilft und noch dazu so Professionell!!
      Ich bin auch übers Wochenende unterwegs und kann nur eingeschränkt aufs Forum zugreifen.
      Gerald
      Synology 918+ 4GB; ioBroker auf RPI4; Zigbee; Sonoff
      • G gerald123
        Gerald
        crunchipC Offline
        crunchipC Offline
        #343
        @gerald123 du könntest spasses/testhalber mal zurück auf die 0.4.2 und probieren. Aber da als Unit m3 im DP hinterlegen, bin mir nicht sicher ob in dieser Version m³ funktioniert
        min/max Werte kannst übrigens auch weg lassen, bei deinem erstellten DP
        G 2 Antworten Letzte Antwort
          gerald123
          #344
          @crunchip das kann ich dann erst am Sontag Abend testen
            gerald123
            #345
            @crunchip leider sachaffe ich es nicht die 0.4.2 zu installieren.
            Ich habe alles gelöscht ( Objekte, Instanz, Adapter) dann Adapter neu installiert und dann im Expertmod auf 0.4.2 installiert, er tut auch so als würde er ihn installieren und wenn er fertig ist zeigt er wieder 0.4.5 an.
            Muss ich da nochwas machen?
            • G gerald123
              DutchmanD Offline
              DutchmanD Offline
              Dutchman
              #346
              Wen es keine Eile hat, bitte ne Woche warten es kommt ne neue Version
                gerald123
                #347
                @Dutchman Kein Problem, ich warte gerne auf die neue Version
                • H Offline
                  hetti72
                  schrieb am zuletzt editiert von hetti72
                  #348
                  ich teste seit einer Woche sourceanalytix 0.4.2 und habe mal eine Verständnisfrage: Warum setzt Sourceanalytix den Datenpunkt meines Stromzählers jede Nacht auf Null?
                  Ich meine damit nicht einen Datenpunkt von Sourceanalytix sondern den Datenpunkt in dem ich per Script den Verbrauch (ermittelt per S0 Impulszähler) schreiben lasse.
                  Was ich auch nicht verstehe ist, das danach der "01_current_day" Datenpunkt von Sourceanalytix einen negativen Wert hat.
                  Ist das jetzt ein normales Verhalten oder ein Bug?
                  gruß,
                  Frank
                  • H hetti72
                    gruß,
                    Frank
                    DutchmanD Offline
                    DutchmanD Offline
                    Dutchman
                    #349
                    @hetti72 sagte in [Major Update] SourceAnalytix 0.4.0 complete code rebuild:
                    Das ist leider ein Breaking bug in SA momentan ich arbeite an einem fix welcher mit 0.5.0-beta.x demnächst freigegeben wird
                    Palm_ManiacP H 2 Antworten Letzte Antwort
                      Palm_ManiacP Offline
                      Palm_Maniac
                      #350
                      @Dutchman
                      Es ist schön, dass du wieder da bist und es weiter geht. Da fühlt man sich gleich wieder viel wohler mit seinem System.
                      Ich danke dir. :)
                        MyMeyer
                        #351
                        wollte meine Gas Werte jetzt mit dem Adapter laufen lassen und bekommen die Meldung im LOG:
                        sourceanalytix.0	2020-08-31 14:40:26.151	error	(25102) [calculationHandler javascript.0.Datenpunkte.Gas.Verbrauch_Volumen] error: Cannot read property 'cathegorie' of undefined, stack: TypeError: Cannot read property 'cathegorie' of undefined
                        sourceanalytix.0	2020-08-31 14:40:25.161	error	at Sourceanalytix.onObjectChange (/opt/iobroker/node_modules/iobroker.sourceanalytix/main.js:438:7)
                        sourceanalytix.0	2020-08-31 14:40:25.161	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
                        sourceanalytix.0	2020-08-31 14:40:25.161	error	at runMicrotasks (<anonymous>)
                        sourceanalytix.0	2020-08-31 14:40:25.161	error	at Sourceanalytix.initialize (/opt/iobroker/node_modules/iobroker.sourceanalytix/main.js:394:16)
                        sourceanalytix.0	2020-08-31 14:40:25.161	error	at Sourceanalytix.calculationHandler (/opt/iobroker/node_modules/iobroker.sourceanalytix/main.js:736:78)
                        sourceanalytix.0	2020-08-31 14:40:25.161	error	(25102) [calculationHandler javascript.0.Datenpunkte.Gas.Verbrauch_Volumen] error: Cannot read property 'cathegorie' of undefined, stack: TypeError: Cannot read property 'cathegorie' of undefined
                        Was ist Problem hier ? Unter SourceAnalytix habe ich "m³" eingestellt. Ich verstehe die Meldung mit 'cathegorie' leider nicht.
                        MyMeyer
                        >>> Hardware: Intel I5 mit ****Debian ProxMox OS: Debian **** <<< >>> Network with UniFi <<<
                        >>> HomeMatic CCU-2 (Wired und Funk) / Philips HUE / Echo.DOT / Echo.SHOW / Xiaomi Smart-Home / Xiaomi Robot Vacuum Cleaner / Synology DS 918+ / Shelly 1&2 <<<
                          hetti72
                          #352
                          @Dutchman sagte in [Major Update] SourceAnalytix 0.4.0 complete code rebuild:
                          Top 👍 , vielen Dank. Dann halte ich mal die Füsse still und warte ab. War mir echt nicht sicher ob hier ein Layer 8 Problem vorliegt 😀
                          gruß,
                          Frank
                          • M MyMeyer
                            crunchipC Offline
                            crunchipC Offline
                            #353
                            @MyMeyer selbe wie schon in den vorherigen Threads, blätter ein paar Zeilen hoch....ist in arbeit
                              DutchmanD Offline
                              DutchmanD Offline
                              Dutchman
                              #354
                              Leute, frage zum NULL Fehler bug ....
                              Tritt dieser bei jeder art von Datenpunkten auf, oder nur bei denjenigen mit Watt ? (also nicht kWh oder m3 etc)
                              Habe da par Sachen gefunden was eventuell die routcause ist, dafür brauche ich aber dringend diese info :)
                              Dutch
                              ? 1 Antwort Letzte Antwort
                                Dutch
                                #355
                                @Dutchman
                                Bin mir nicht sicher ob dir dies hilft. Bei mir sind es Datenquellen in Watt und lasse mir über SourceAnalytix die Summe in kwh bilden + ausgeben. Diese Kwh Datenpunkte haben den NULL Fehler Bug bei mir.
                                  @Dutchman
                                  DutchmanD Offline
                                  DutchmanD Offline
                                  Dutchman
                                  #356
                                  @Pete0815 sagte in [Major Update] SourceAnalytix 0.4.0 complete code rebuild:
                                  @Dutchman
                                  Danke @Pete0815 Genau das hilft mir weiter ! Vermutung war bereits das es nur mit W (watt) werten passiert die nach kWh gerechnet werden.
                                  Wie siehts bei anderen aus (die eventuell auch andere quellen loggen)
                                  Fehler nur bei Watt werten oder allgemein (ich meine damit den Datenpunkt welchen man zu loggen auswählt !)
                                    @Dutchman
                                    gerald123
                                    #357
                                    @Dutchman es tritt bei mir mit den m³ auf, andere Werte habe ich derzeit nicht in Verwendung.
                                    • G gerald123
                                      DutchmanD Offline
                                      DutchmanD Offline
                                      Dutchman
                                      #358
                                      hmm moment ist es bei dir auch NULL, dachte da war der Fehler im log bezueglich cathegorie oder verwechsle ich jetzt etwas ?
                                        gerald123
                                        #359
                                        @Dutchman in den SA Objekten wird bei allen nur 0m³ angezeigt obwohl das Objekt für den Wasserverbrauch z.B. 11.303m³ hat.
                                        Im Logeintrag , da hast du recht, steht dann der Fehler mit der cathegorie
                                        sourceanalytix.0	2020-08-28 14:01:04.659	error	(9868) [calculationHandler javascript.0.scriptDatenPunkte.Hilfsobjekte.Wasser.Wasserverbrauch] error: Cannot read property 'cathegorie' of undefined, stack: TypeError: Cannot read property 'cathegorie
                                        • G gerald123
                                          DutchmanD Offline
                                          DutchmanD Offline
                                          Dutchman
                                          schrieb am zuletzt editiert von Dutchman
                                          #360
                                          Ok das ist aber ein anderes Problem, da steht 0 (nicht NULL) weil er keine Berechnungen macht.
                                          Der Grund dafür ist die Meldung der cathegorie
                                          Ich suche nach dem Problem das SA rechnet, aber bei Tages Wechsel einen NULL wert schreibt
