  4. Test Adapter TrashSchedule
adaptercalendaricalkalendermülltrash
1.4k Beiträge 186 Kommentatoren 684.6k Aufrufe 171 Beobachtet
    SMARTY.ML
    #341
    Habe nach kurzen Abständen immer nachfolgenden Fehler:
    host.ioBroker 2020-03-14 13:49:23.214 error instance system.adapter.trashschedule.0 terminated with code 156 (156)
    Die Instanz startet dann neu. Kann jemand helfen?
    • S SMARTY.ML
      Thomas BraunT Offline
      #342
      @SMARTY-ML Die Zeilen davor (und auch danach) können interessant sein.
        SMARTY.ML
        #343
        @SMARTY-ML said in Test Adapter TrashSchedule v0.0.x:
        host.raspberrypi	2020-05-30 08:42:05.941	info	Do not restart adapter system.adapter.trashschedule.0 because disabled or deleted
        host.raspberrypi	2020-05-30 08:42:05.940	error	instance system.adapter.trashschedule.0 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND)
        trashschedule.0	2020-05-30 08:42:05.422	warn	(31485) Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
        trashschedule.0	2020-05-30 08:42:05.384	error	(31485) adapter disabled
        host.raspberrypi	2020-05-30 08:42:00.593	info	instance system.adapter.trashschedule.0 terminated with code 156 (156)
        trashschedule.0	2020-05-30 08:42:00.102	info	(31026) Got terminate signal TERMINATE_YOURSELF
        host.raspberrypi	2020-05-30 08:42:00.100	info	stopInstance system.adapter.trashschedule.0 send kill signal
        host.raspberrypi	2020-05-30 08:42:00.093	info	stopInstance system.adapter.trashschedule.0 (force=false, process=true)
        host.raspberrypi	2020-05-30 08:42:00.092	info	"system.adapter.trashschedule.0" disabled
        trashschedule.0	2020-05-30 08:42:00.088	info	(31026) Adapter is disabled => stop
        host.raspberrypi	2020-05-30 08:42:00.066	info	stopInstance system.adapter.trashschedule.0 send kill signal
        trashschedule.0	2020-05-30 08:42:00.073	info	(31026) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        trashschedule.0	2020-05-30 08:42:00.072	info	(31026) terminating
        trashschedule.0	2020-05-30 08:42:00.071	info	(31026) cleaned everything up...
        trashschedule.0	2020-05-30 08:42:00.070	info	(31026) Got terminate signal TERMINATE_YOURSELF
        host.raspberrypi	2020-05-30 08:42:00.059	info	stopInstance system.adapter.trashschedule.0 (force=false, process=true)
        • haus-automatisierungH Offline
          #344
          Ich habe auf GitHub mal ein FAQ zusammengeschrieben, da die gleichen Fragen immer wieder auftauchen:
          https://github.com/klein0r/ioBroker.trashschedule/blob/master/faq_de.md
          📚 Meine Dokumentation
            SBorgS Offline
            SBorgS Offline
            SBorg
            schrieb am zuletzt editiert von SBorg
            #345
            @haus-automatisierung Danke Matthias 👍
            Ein Passus ist aber nicht so ganz richtig :
            Die verbleibenden Tage aktualisieren sich nicht
            Die Idee ist, dass der iCal-Adapter regelmäßig den Kalender neu holt. Daher sollte hier ein Intervall definiert werden, wie oft
            die Daten aus der iCal-Datei / iCal-Url neu gelesen werden. Es ist nicht nötig, den Trashschedule-Adapter regelmäßig
            neustarten zu lassen (dieser würde ja nur wieder die gleichen/alten Daten vom iCal lesen). iCal ist also führend und muss
            dafür sorgen, dass immer aktuelle Termine vorliegen. Es sollte also mindestens einmal täglich (möglichst früh am Tag) die
            iCal-Instanz neugestartet werden.
            die iCal-Instanz neugestartet werden.
            Nicht den ganzen Adapter/Instanz neu starten, sondern lediglich einen schedule in der Instanz dafür eintragen, wann er das nächste mal die Daten abfragen soll.Bild 1.png (hier mal alle 6 Stunden genau zur Minute 0)
            Das meinst du zwar zu 100pro, aber gerade für den Anfänger ist dann ein "Neustart der Instanz" ev. verwirrend.
            LG SBorg ( SBorg auf GitHub)
            • SBorgS SBorg
              #346
              @SBorg Der Schedule ist technisch aber ein Neustart?! Oder etwa nicht :)
              K SBorgS 2 Antworten Letzte Antwort
                Kueppert
                #347
                @haus-automatisierung naja, ich würde mit dir als Softwareentwickler jetzt nicht diskutieren hahaha.
                Off-Topic: Ich finde deinen Youtube-Channel klasse. Bin natürlich Abonent. Würde gern mehr von deinem Häusschen sehen ;)
                  SBorgS Offline
                  SBorgS Offline
                  SBorg
                  #348
                  @haus-automatisierung Technisch gesehen gute Frage. Ich würde es eher als "Restart" ansehen, der cron läuft ja eh im Hintergrund weiter :)
                  Der Neuling der die FAQ aber durchliest, wird dann verzweifelt nach dem "Neustart" suchen, gerade weil es den Knopf bei der Instanz gibt. Wie man es jetzt genau nennt ist eigentlich nicht sooo maßgeblich, nur sehe ich dann einfach trotz FAQ wieder die Frage auftauchen "wie mache ich einen Neustart der Instanz?"
                    R1Snake
                    #349
                    ich bekomme den Adapter irgendwie nicht ans laufen.
                    Im Log steht immer das keine passenden Events gefunden werden können.
                    Hier meine Objekte:
                    Wie man sehen kann, werden die Termine erkannt und bei einem Abholtermin wird "true" gesetzt.
                    Hier die Konfiguration vom Trash Schedule:
                    Und das passende Log:
                    Hat jemand ne Idee woran es liegt?
                    • R R1Snake
                      Hier meine Objekte:
                      #350
                      @R1Snake
                      Der Adapter trashschedule hat nichts mit den Events (Ereignisse) des ical zu tun.
                      Wie sieht denn dein Inhalt des ical - Kalenderabrufes aus?
                        R1Snake
                        #351
                        Was genau willst du sehen? Die URL vom Kalendar?
                        K HomoranH 2 Antworten Letzte Antwort
                          R1Snake
                          #352
                          • R R1Snake
                            Kueppert
                            schrieb am zuletzt editiert von Kueppert
                            #353
                            @R1Snake der Adapter Trashshedule benötigt nicht den Calendar-Adapter sondern den ical-Adapter - OK hat sich erledigt ^^
                            • R R1Snake
                              #354
                              @R1Snake sagte in Test Adapter TrashSchedule v0.0.x:
                              nein, den Inhalt des (HTML) Datenpunktes.
                              bin nicht an meiner Installation, daher kann ich das nur aus dem Kopf machen
                              • K Kueppert
                                #355
                                @Kueppert sagte in Test Adapter TrashSchedule v0.0.x:
                                hat er doch
                                  R1Snake
                                  schrieb am zuletzt editiert von R1Snake
                                  #356
                                  Das steht bei meinem HTML drin:
                                  <span style="font-weight: bold; color: orange"><span class="icalPreWarn iCal-Kalendar">Morgen  </span></span><span style="font-weight: normal; color: orange"><span class='icalPreWarn2 iCal-Kalendar2'>  Abfuhrtermin Sperrmüll (-)</span></span><br/><span style="font-weight: bold; color: white"><span class="icalNormal iCal-Kalendar">In 6 Tagen  </span></span><span style="font-weight: normal; color: white"><span class='icalNormal2 iCal-Kalendar2'> Fronleichnam</span></span><br/><span style="font-weight: bold; color: white"><span class="icalNormal iCal-Kalendar">In 6 Tagen  </span></span><span style="font-weight: normal; color: white"><span class='icalNormal2 iCal-Kalendar2'> Fronleichnam</span></span>
                                  Was irgendwie etwas wenig ist oder?
                                  • R R1Snake
                                    #357
                                    @R1Snake
                                    ich sehe da nur einen Sperrmüll.
                                    Den hast du in trashschedule gar nicht konfiguriert
                                    Wie lange hast du denn die "Vorlaufzeit" in ical definiert?
                                    • sehe gerade 20 Tage - da wird dann wohl der Müllkalender aus irgendeinem Grund nicht abgerufen
                                    Stimmt der URL denn überhaupt? kommt mir sehr seltsam vor
                                      R1Snake
                                      #358
                                      Die Vorlaufzeit steht in der Config auf 20 Tage.
                                      Habe gerade auf 30 Tage erhöht und irgendwie werden nur die Sperrmüll Tage angezeigt...
                                      <span style="font-weight: bold; color: orange"><span class="icalPreWarn iCal-Kalendar">Morgen  </span></span><span style="font-weight: normal; color: orange"><span class='icalPreWarn2 iCal-Kalendar2'>  Abfuhrtermin Sperrmüll (-)</span></span><br/><span style="font-weight: bold; color: white"><span class="icalNormal iCal-Kalendar">In 6 Tagen  </span></span><span style="font-weight: normal; color: white"><span class='icalNormal2 iCal-Kalendar2'> Fronleichnam</span></span><br/><span style="font-weight: bold; color: white"><span class="icalNormal iCal-Kalendar">In 6 Tagen  </span></span><span style="font-weight: normal; color: white"><span class='icalNormal2 iCal-Kalendar2'> Fronleichnam</span></span><br/><span style="font-weight: bold; color: white"><span class="icalNormal iCal-Kalendar">27.06.2020  </span></span><span style="font-weight: normal; color: white"><span class='icalNormal2 iCal-Kalendar2'> Jahrestag</span></span><br/><span style="font-weight: bold; color: white"><span class="icalNormal iCal-Kalendar">29.06.2020  </span></span><span style="font-weight: normal; color: white"><span class='icalNormal2 iCal-Kalendar2'> Paul Namenstag</span></span><br/><span style="font-weight: bold; color: white"><span class="icalNormal iCal-Kalendar">03.07.2020  </span></span><span style="font-weight: normal; color: white"><span class='icalNormal2 iCal-Kalendar2'>  Abfuhrtermin Sperrmüll (-)</span></span>
                                      Meine Kalender URL ist: https://calendar.google.com/calendar/ical/verschleiert/public/basic.ics
                                      • R R1Snake
                                        #359
                                        Da sind die Termine ja auch drin:
                                        DESCRIPTION:Abfuhrtermin Wertstofftonne / gelber Sack
                                        Aber die steht doch nicht im ical-Adpter
                                        EDIT: habe deine URL verschleiert - muss ja nicht jeder deine privaten Daten haben
                                          R1Snake
                                          #360
                                          Jetzt komm ich nicht mehr mit...
                                          Was muss ich jetzt tun?
