  4. Neue Installationsroutine (für Linux)
installation
415 Beiträge 64 Kommentatoren 183.7k Aufrufe 31 Beobachtet
  • L Offline
    LED
    #241
    Hier noch der Rest
    In file included from /home/pi/.node-gyp/10.16.0/include/node/v8.h:26,
                     from /home/pi/.node-gyp/10.16.0/include/node/node.h:63,
                     from ../node_modules/nan/nan.h:47,
                     from ../src/unix_dgram.cc:5:
    /home/pi/.node-gyp/10.16.0/include/node/v8.h:2478:46: note: declared here
       V8_DEPRECATED("Use maybe version", int32_t Int32Value() const);
    /home/pi/.node-gyp/10.16.0/include/node/v8config.h:324:3: note: in definition of                                          macro ‘V8_DEPRECATED’
       declarator __attribute__((deprecated(message)))
    ../src/unix_dgram.cc:259:27: warning: ‘v8::Local<v8::Object> v8::Value::ToObject                                         () const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
       buf = info[1]->ToObject();
    In file included from /home/pi/.node-gyp/10.16.0/include/node/node.h:63,
    /home/pi/.node-gyp/10.16.0/include/node/v8.h:10046:15: note: declared here
     Local<Object> Value::ToObject() const {
    ../src/unix_dgram.cc:260:33: warning: ‘uint32_t v8::Value::Uint32Value() const’                                          is deprecated: Use maybe version [-Wdeprecated-declarations]
       offset = info[2]->Uint32Value();
    /home/pi/.node-gyp/10.16.0/include/node/v8.h:2477:47: note: declared here
       V8_DEPRECATED("Use maybe version", uint32_t Uint32Value() const);
    ../src/unix_dgram.cc:261:33: warning: ‘uint32_t v8::Value::Uint32Value() const’                                          is deprecated: Use maybe version [-Wdeprecated-declarations]
       length = info[3]->Uint32Value();
    ../src/unix_dgram.cc:262:33: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Loca                                         l<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
       String::Utf8Value path(info[4]);
    /home/pi/.node-gyp/10.16.0/include/node/v8.h:2892:28: note: declared here
                       explicit Utf8Value(Local<v8::Value> obj));
    ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Send                                         (Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/unix_dgram.cc:302:28: warning: ‘int32_t v8::Value::Int32Value() const’ is                                          deprecated: Use maybe version [-Wdeprecated-declarations]
       fd = info[0]->Int32Value();
    ../src/unix_dgram.cc:303:27: warning: ‘v8::Local<v8::Object> v8::Value::ToObject                                         () const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
    ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Conn                                         ect(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/unix_dgram.cc:340:28: warning: ‘int32_t v8::Value::Int32Value() const’ is                                          deprecated: Use maybe version [-Wdeprecated-declarations]
    ../src/unix_dgram.cc:341:33: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Loca                                         l<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
       String::Utf8Value path(info[1]);
    ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Clos                                         e(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/unix_dgram.cc:361:28: warning: ‘int32_t v8::Value::Int32Value() const’ is                                          deprecated: Use maybe version [-Wdeprecated-declarations]
    In file included from ../node_modules/nan/nan.h:47,
    ../src/unix_dgram.cc: At global scope:
    /home/pi/.node-gyp/10.16.0/include/node/node.h:573:43: warning: cast between inc                                         ompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_                                         register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*                                         )’} [-Wcast-function-type]
           (node::addon_register_func) (regfunc),                          \
    /home/pi/.node-gyp/10.16.0/include/node/node.h:607:3: note: in expansion of macr                                         o ‘NODE_MODULE_X’
       NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
    ../src/unix_dgram.cc:420:1: note: in expansion of macro ‘NODE_MODULE’
     NODE_MODULE(unix_dgram, Initialize)
    /home/pi/.node-gyp/10.16.0/include/node/v8.h: In instantiation of ‘void v8::Pers                                         istentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakC                                         allbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallba                                         ckInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)]’:
    /home/pi/.node-gyp/10.16.0/include/node/node_object_wrap.h:84:78:   required fro                                         m here
    /home/pi/.node-gyp/10.16.0/include/node/v8.h:9502:16: warning: cast between inco                                         mpatible function types from ‘v8::WeakCallbackInfo<node::ObjectWrap>::Callback’                                          {aka ‘void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)’} to ‘Callback’ {a                                         ka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
                    reinterpret_cast<Callback>(callback), type);
    /home/pi/.node-gyp/10.16.0/include/node/v8.h: In instantiation of ‘void v8::Pers                                         istentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakC                                         allbackType) [with P = Nan::ObjectWrap; T = v8::Object; typename v8::WeakCallbac                                         kInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)]’:
    ../node_modules/nan/nan_object_wrap.h:66:61:   required from here
    /home/pi/.node-gyp/10.16.0/include/node/v8.h:9502:16: warning: cast between inco                                         mpatible function types from ‘v8::WeakCallbackInfo<Nan::ObjectWrap>::Callback’ {                                         aka ‘void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)’} to ‘Callback’ {aka                                          ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
    make: *** [unix_dgram.target.mk:99: Release/obj.target/unix_dgram/src/unix_dgram                                         .o] Fehler 1
    gyp ERR! build error
    gyp ERR! stack Error: `make` failed with exit code: 2
    gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_module                                         s/node-gyp/lib/build.js:262:23)
    gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_proces                                         s.js:248:12)
    gyp ERR! System Linux 4.19.57-v7+
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gy                                         p/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/unix-dgram
    gyp ERR! node -v v10.16.0
    gyp ERR! node-gyp -v v3.8.0
    gyp ERR! not ok
    In file included from ../src/./serialport.h:6,
                     from ../src/serialport.cpp:1:
    ../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
    ../../nan/nan.h:2298:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
         , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:41:49: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
       v8::String::Utf8Value path(info[0]->ToString());
                     from ../../nan/nan.h:54,
    ../src/serialport.cpp:48:53: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
       v8::Local<v8::Object> options = info[1]->ToObject();
    ../src/serialport.cpp:78:69: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen);
    ../src/serialport.cpp: In function ‘void EIO_AfterOpen(uv_work_t*)’:
    ../src/serialport.cpp:95:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
       data->callback.Call(2, argv);
    ../../nan/nan.h:1740:3: note: declared here
       Call(int argc, v8::Local<v8::Value> argv[]) const {
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:113:53: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
    ../src/serialport.cpp:135:71: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate);
    ../src/serialport.cpp: In function ‘void EIO_AfterUpdate(uv_work_t*)’:
    ../src/serialport.cpp:150:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
       data->callback.Call(1, argv);
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:175:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose);
    ../src/serialport.cpp: In function ‘void EIO_AfterClose(uv_work_t*)’:
    ../src/serialport.cpp:188:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:215:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush);
    ../src/serialport.cpp: In function ‘void EIO_AfterFlush(uv_work_t*)’:
    ../src/serialport.cpp:231:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:250:53: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
    ../src/serialport.cpp:270:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet);
    ../src/serialport.cpp: In function ‘void EIO_AfterSet(uv_work_t*)’:
    ../src/serialport.cpp:285:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:314:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet);
    ../src/serialport.cpp: In function ‘void EIO_AfterGet(uv_work_t*)’:
    ../src/serialport.cpp:336:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:363:76: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate);
    ../src/serialport.cpp: In function ‘void EIO_AfterGetBaudRate(uv_work_t*)’:
    ../src/serialport.cpp:383:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:409:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain);
    ../src/serialport.cpp: In function ‘void EIO_AfterDrain(uv_work_t*)’:
    ../src/serialport.cpp:424:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
    ../src/serialport.cpp: At global scope:
    ../src/serialport.cpp:430:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses]
     SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) {
    ../src/serialport.cpp:449:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses]
     SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) {
    In file included from ../../nan/nan.h:54,
    /home/pi/.node-gyp/10.16.0/include/node/node.h:573:43: warning: cast between incompatible function types from ‘void (*)(v8::Handle<v8::Object>)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
    /home/pi/.node-gyp/10.16.0/include/node/node.h:607:3: note: in expansion of macro ‘NODE_MODULE_X’
    ../src/serialport.cpp:485:1: note: in expansion of macro ‘NODE_MODULE’
     NODE_MODULE(serialport, init);
    /home/pi/.node-gyp/10.16.0/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)]’:
    /home/pi/.node-gyp/10.16.0/include/node/node_object_wrap.h:84:78:   required from here
    /home/pi/.node-gyp/10.16.0/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<node::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
    /home/pi/.node-gyp/10.16.0/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = Nan::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)]’:
    ../../nan/nan_object_wrap.h:65:61:   required from here
    /home/pi/.node-gyp/10.16.0/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<Nan::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)’} to ‘Callback’ {aka  void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
    In file included from ../src/serialport.h:6,
                     from ../src/serialport_unix.cpp:2:
    ../src/serialport_unix.cpp: In function ‘int setup(int, OpenBaton*)’:
    ../src/serialport_unix.cpp:176:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1005 [-Wformat-truncation=]
         snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path);
    ../src/serialport_unix.cpp:176:13: note: ‘snprintf’ output 20 or more bytes (assuming 1043) into a destination of size 1024
    ../src/serialport_unix.cpp: In function ‘void EIO_Open(uv_work_t*)’:
    ../src/serialport_unix.cpp:86:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1003 [-Wformat-truncation=]
         snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path);
    ../src/serialport_unix.cpp:86:13: note: ‘snprintf’ output 22 or more bytes (assuming 1045) into a destination of size 1024
    In file included from ../src/poller.cpp:1:
    ../src/poller.cpp: In static member function ‘static void Poller::onData(uv_poll_t*, int, int)’:
    ../src/poller.cpp:69:29: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
       obj->callback.Call(2, argv);
    • AlCalzoneA AlCalzone
      @LED sagte in Neue Installationsroutine und neue Anleitungen (für Linux-basierte Systeme):
      Hab dann noch den Fixer ausgeführt und iobroker läuft
      Was ich nicht verstehe... Im Ankündigungspost zum Fixer steht:
      Mittels einem Kommando wird eine bestehende Installation in /opt/iobroker auf den gleichen Stand gebracht wie eine aktuelle neue Installation.
      Wie kommt man dann auf die Idee, diesen direkt nach einer nagelneuen Installation auszuführen? Ernst gemeinte Frage.
      LED
      #242
      @AlCalzone said in Neue Installationsroutine und neue Anleitungen (für Linux-basierte Systeme):
      Na ja, wenn etwas nicht klappt und es einen Fixer gibt :-)
      Hat aber wohl nicht geschadet... ich lerne noch.
        Atticus68
        #243
        ich versuche gerade ioBroker auf einem Raspberry 4 mit Rasbian Buster zu installieren.
        Hier in diesem Beitrag gibt es ja links zu neuen Installationsanleitungen/Scripten...
        Leider kann ich keines diese Scripte nutzen, da die Links nicht funktionieren.
        Kann mir jemand helfen und einen Link zu einer funktionierenden Installationsanleitung posten?
        Thomas
        J 1 Antwort Letzte Antwort
        • L Offline
          LED
          schrieb am zuletzt editiert von LED
          #244
          https://www.iobroker.net/#de/documentation/install/linux.md
          Ich bin jetzt seit etwa 40h an dem Thema iobroker auf Raspberry dran und kann schon gar nicht mehr zählen wie oft ich auf tote Links geklickt habe. OK, ich bin auch ein totaler Linux Noob und hab immer nur Windows genutzt. Aber der Einstieg war schon echt schwer, obwohl es im Grunde so einfach sein könnte.
          • L LED
            AlCalzoneA Offline
            AlCalzoneA Offline
            AlCalzone
            #245
            Was denn? Lief ioBroker etwa nicht?
            • A Atticus68
              Thomas
              Jan1
              #246
              @TomsHome
              Die toten Links kommen von der Neustrukturierung des Forum und sind in der Tat etwas nervig zumal die neue Doku die irgendwann mal alles zusammenfassen soll noch nicht fertig ist.
              Im Grunde ist das wesentliche aber erreichbar und damit bekommt man ohne Probleme IOBroker installiert. Wie Rasbian auf dem Pi einzurichten ist, sollte eh nicht hier gesucht werden, sondern im entsprechenden Raspian Forum, da dort der Support eben darauf ausgelegt ist und hier der Schwerpunkt bei IOBroker liegt.
              Oder man nimmt eben ein fertiges Image von hier und spart sich die Raspian Einrichtung. Meine Empfehlung ist aber das ganze selber zu machen, da nur so das Grundverständnis für spätere eventuelle Probleme gesammelt wird (wenn nicht eh schon vorhanden).
              L 1 Antwort Letzte Antwort
                Atticus68
                #247
                Danke für Eure schnelle Hilfe, ich ab es gefunden.
                Die Einrichtung von Rasbian auf dem Pi ist ja kein Problem, das war ja auch schon erledigt.
                Ich hatte nur arge Probleme, ioBroker zu installieren und zum laufen zu bringen.
                Jetzt hat es aber funktioniert.
                ich hab den ioBroker deshalb auf meinem Testsystem neu aufgesetzt, weil ich darauf den SQL-Adapter nicht zum laufen bringen konnte. Hab den jetzt als erste installiert, jetzt läuft er.
                Es sieht aber auch so aus, als ob die Installation von Adaptern jetzt anders abläuft, bzw. länger dauert, er wird im Installationsfenster jedenfalls viel mehr angezeigt als bei früheren Installationen.
                Thomas
                • J Jan1
                  @TomsHome
                  LED
                  #248
                  @Jan1 said in Neue Installationsroutine und neue Anleitungen (für Linux-basierte Systeme):
                  Ja, hab ich schon verstanden und inzwischen ist mir auch klar wo ich was finde. Für neue User aber in der Tat sehr nervig.
                  @TomsHome said in Neue Installationsroutine und neue Anleitungen (für Linux-basierte Systeme):
                  Ich hab inzwischen bestimmt 20x iobroker installiert, am Anfang über fertige Images um erst einmal zu verstehen was da so geht und wie es aussehen sollte und danach auch selbst installiert. Eine SD-Karte hab ich irgendwie geschrottet und mit den Berechtigungen unter Linux komme ich auch noch nicht wirklich klar. Auch wenn es nicht empfohlen wird, auf meinen Testsystemen arbeite ich erst einmal als Root.
                  Mit dem SQL Adapter hatte ich auch Probleme und eine Datenbank konnte ich auf dem fertigen IoBroker Image erst recht nicht installieren. Und das die Adapter jetzt ewig brauchen und es sehr viele (Fehler-)Meldungen gibt ist mir ebenfalls aufgefallen. Aber ich glaube ich hab da vorher auch einfach nicht drauf geachtet und die Ausgabe deaktiviert.
                  Trotzdem macht es mich unsicher, ob ich auf dem richtigen Weg bin und das alles so gewollt ist :-)
                    Atticus68
                    #249
                    Dann hab ich gleich noch eine Frage.
                    Benutzt jemand den BLE-Adapter, läuft der bei Euch?
                    Auf meinem "Arbeitssystem"(Node/js 10.16.0, npm 6.9.0, js-controller 1.5.11) ist die BLE Version 0.7.2 installiert.
                    Der BLE hat funktionert, aber ich meine seit dem ich den js-contoller auf 1.5.11 upgedate habe, läuft er nicht mehr. Hat jemand eine Idee?
                    Dake
                    Thomas
                    • L LED
                      #250
                      @LED Tote Links ... wenn Du Sie nochmal findest bitte melden.
                      Wir haben die Doku und Webseite umgestellt und jetzt müssen wir hier ggf solche Dinge nachziehen und fixen. Also hier im Forum bitte nicht davor scheuen totel Links zu melden! Und auch auf den Webseiten und so.
                      • L LED
                        #251
                        @LED Das bei einigen Adaptern "Warnungen" kommen ist unschön und wir sind immer versucht die zu fixen. Einige kommen aber auch abhängigen Paketen und von daher haben wir darauf nur einen bedingten Einfluss. Das ist leider eine Unschöne Eigenheit von Nodejs bzw der Art wie Pakete mit npm gemanaged werden. :-(
                        Eine SQL-Datenbank auf einem Raspi mit SD Karte würde ich auch nicht als Sinnvoll ansehen! Da ist deine SD Karte shcneller hin als Du schauen kannst und es sei denn DU nimmst einen Raspi 4 mit genug RAM das limitiert auch. Hier ist auch die sqlite3 Library grund für einige Warnjungen, die am Ende aber ignoriert werden können.
                        • A Atticus68
                          Dake
                          Thomas
                          AlCalzoneA Offline
                          AlCalzoneA Offline
                          AlCalzone
                          #252
                          @TomsHome sagte in Neue Installationsroutine und neue Anleitungen (für Linux-basierte Systeme):
                          Wie immer ist "läuft nicht" keine ausreichende Fehlerbeschreibung. Das mindeste was du liefern solltest, sind die passenden Logs. Anhand diesen findest du sicher auch ähnliche Probleme samt Lösung hier im Forum. Eine Abhängigkeit des Adapters ist leider etwas fragil, was Installationen angeht.
                          Und die Frage ist in einem Extra Thread eigentlich besser aufgehoben.
                            Atticus68
                            schrieb am zuletzt editiert von Atticus68
                            #253
                            @AlCalzone ja, das mach ich doch. Da ich aber noch recht neu in der Materie bin, die Frage, wo finde ich das passende Log?
                            Thomas
                              Atticus68
                              #254
                              Und noch was, betrifft nur das Forum hier, kann ich meine Beiträge nicht editieren? Ich finde keinen Button, um den Beitrag zu ändern.
                              • A Atticus68
                                sigi234S Online
                                sigi234S Online
                                sigi234
                                #255
                                Immer Daten sichern!
                                  Atticus68
                                  #256
                                  Ok, danke
                                  • apollon77A apollon77
                                    Ich glaube du hast das gleiche Problem wie in einen anderen Thread von heute das in Debian 10 ein normaler User das Verzeichnis /usr/sbin nicht im Pfad hat. Dort liegen aber Programme wie usermod, visudo und so.
                                    Versuch mal:
                                    sudo su -
                                    Und dann den installer als root laufen lassen. Hat dort funktioniert
                                    1Topf1 Offline
                                    1Topf1 Offline
                                    1Topf
                                    #257
                                    @apollon77 sagte in Neue Installationsroutine und neue Anleitungen (für Linux-basierte Systeme):
                                    Versuch mal:
                                    sudo su -
                                    Sudo su - funzt nicht, aber su -. Und juhu, ioB läuft, zumindest die Grundinstallation 👍 . Werde demnächst mal eine Sicherung meines laufenden Sytems einspielen und schaun, ob das funzt. Vielen Dank! ☺
                                    • A Atticus68
                                      Thomas
                                      AlCalzoneA Offline
                                      AlCalzoneA Offline
                                      AlCalzone
                                      #258
                                      ioBroker-Admin -> Tab "Log" ;)
                                        AlCalzoneA Offline
                                        AlCalzoneA Offline
                                        AlCalzone
                                        #259
                                        Ich würde mich freuen, wenn der ein oder andere mit Buster mal den neuen Patch für den Installer/Fixer testen könnte. Dazu bitte folgendes auf einem frischen System ausführen (als normaler User, nicht als root!):
                                        curl -sL https://raw.githubusercontent.com/ioBroker/ioBroker/buster/installer.sh | bash -
                                        J 1Topf1 2 Antworten Letzte Antwort
                                          Jan1
                                          #260
                                          @AlCalzone
                                          Ist zwar nicht frisch, aber habs trotzdem mal laufen lassen:
                                          System kam nach einem Reboot wieder hoch, allerdings hab nun Admin wieder auf 3.6.2, den JS-Controller auf 1.5.11 und den Discovery Adapter den ich vorher überhaupt nicht hatte. Muss das so sein?
                                          Log als Dateianhang, weil als Spoiler über 5000 Zeichen.
                                          LOG.txt
                                          AlCalzoneA apollon77A 2 Antworten Letzte Antwort
