  4. Neue Installationsroutine (für Linux)
installation
415 Beiträge 64 Kommentatoren 189.4k Aufrufe 31 Beobachtet
  • L LED
    Hallo
    Wollte eure Anleitung unter https://www.iobroker.net/#de/documentation/install/linux.md testen und habe Raspbian Buster Lite Image auf die SD gezogen und in den Raspberry PI 3 gesteckt. Dann der Anleitung gefolgt und Installation gestartet:
    pi@iobroker:~ $ node -v
    v10.16.0
    pi@iobroker:~ $ npm -v
    6.9.0
    pi@iobroker:~ $ curl -sL https://iobroker.net/install.sh | bash -
        Welcome to the ioBroker installer!
        Installer version: 2019-07-03
        You might need to enter your password a couple of times.
        Installing prerequisites (1/4)
    Installed acl
    Installed libavahi-compat-libdnssd-dev
    Installed libudev-dev
    Installed libpam0g-dev
    Installed git
        Creating ioBroker user and directory (2/4)
    User iobroker created
    Directory /opt/iobroker created
        Installing ioBroker (3/4)
    In file included from ../src/main.cpp:3:
    ../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
    ../../nan/nan.h:2298:62: warning: cast between incompatible function types from                                          ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka                                           void (*)(uv_work_s*, int)’} [-Wcast-function-type]
         , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
    ../src/main.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetDiskUsage(Nan::NAN_                                         METHOD_ARGS_TYPE)’:
    ../src/main.cpp:26:71: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Local<v8::                                         Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
             DiskUsage result = GetDiskUsage(*v8::String::Utf8Value(info[0]));
    In file included from /home/pi/.node-gyp/10.16.0/include/node/v8.h:26,
                     from /home/pi/.node-gyp/10.16.0/include/node/node.h:63,
                     from ../../nan/nan.h:54,
    /home/pi/.node-gyp/10.16.0/include/node/v8.h:2892:28: note: declared here
                       explicit Utf8Value(Local<v8::Value> obj));
    /home/pi/.node-gyp/10.16.0/include/node/v8config.h:324:3: note: in definition of                                          macro ‘V8_DEPRECATED’
       declarator __attribute__((deprecated(message)))
    In file included from ../../nan/nan.h:54,
    ../src/main.cpp: At global scope:
    /home/pi/.node-gyp/10.16.0/include/node/node.h:573:43: warning: cast between inc                                         ompatible function types from ‘void (*)(v8::Handle<v8::Object>)’ {aka ‘void (*)(                                         v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local                                         <v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
           (node::addon_register_func) (regfunc),                          \
    /home/pi/.node-gyp/10.16.0/include/node/node.h:607:3: note: in expansion of macr                                         o ‘NODE_MODULE_X’
       NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
    ../src/main.cpp:42:1: note: in expansion of macro ‘NODE_MODULE’
     NODE_MODULE(diskusage, Init)
    In file included from /home/pi/.node-gyp/10.16.0/include/node/node.h:63,
    /home/pi/.node-gyp/10.16.0/include/node/v8.h: In instantiation of ‘void v8::Pers                                         istentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakC                                         allbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallba                                         ckInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)]’:
    /home/pi/.node-gyp/10.16.0/include/node/node_object_wrap.h:84:78:   required fro                                         m here
    /home/pi/.node-gyp/10.16.0/include/node/v8.h:9502:16: warning: cast between inco                                         mpatible function types from ‘v8::WeakCallbackInfo<node::ObjectWrap>::Callback’                                          {aka ‘void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)’} to ‘Callback’ {a                                         ka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
                    reinterpret_cast<Callback>(callback), type);
    /home/pi/.node-gyp/10.16.0/include/node/v8.h: In instantiation of ‘void v8::Pers                                         istentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakC                                         allbackType) [with P = Nan::ObjectWrap; T = v8::Object; typename v8::WeakCallbac                                         kInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)]’:
    ../../nan/nan_object_wrap.h:65:61:   required from here
    /home/pi/.node-gyp/10.16.0/include/node/v8.h:9502:16: warning: cast between inco                                         mpatible function types from ‘v8::WeakCallbackInfo<Nan::ObjectWrap>::Callback’ {                                         aka ‘void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)’} to ‘Callback’ {aka                                          ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
    In file included from ../node_modules/nan/nan.h:190,
                     from ../src/unix_dgram.cc:5:
    ../node_modules/nan/nan_maybe_43_inl.h: In function ‘Nan::Maybe<bool> Nan::Force                                         Set(v8::Local<v8::Object>, v8::Local<v8::Value>, v8::Local<v8::Value>, v8::Prope                                         rtyAttribute)’:
    ../node_modules/nan/nan_maybe_43_inl.h:88:15: error: ‘class v8::Object’ has no m                                         ember named ‘ForceSet’
       return obj->ForceSet(GetCurrentContext(), key, value, attribs);
    In file included from ../src/unix_dgram.cc:5:
    ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> Nan::MakeCallback(v                                         8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’:
    ../node_modules/nan/nan.h:817:60: warning: ‘v8::Local<v8::Value> node::MakeCallb                                         ack(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local                                         <v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated                                         -declarations]
             v8::Isolate::GetCurrent(), target, func, argc, argv);
    In file included from ../node_modules/nan/nan.h:47,
    /home/pi/.node-gyp/10.16.0/include/node/node.h:177:50: note: declared here
                     NODE_EXTERN v8::Local<v8::Value> MakeCallback(
    /home/pi/.node-gyp/10.16.0/include/node/node.h:91:42: note: in definition of mac                                         ro ‘NODE_DEPRECATED’
         __attribute__((deprecated(message))) declarator
    ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> Nan::MakeCallback(v                                         8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’:
    ../node_modules/nan/nan.h:831:62: warning: ‘v8::Local<v8::Value> node::MakeCallb                                         ack(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v                                         8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-d                                         eclarations]
             v8::Isolate::GetCurrent(), target, symbol, argc, argv);
    /home/pi/.node-gyp/10.16.0/include/node/node.h:170:50: note: declared here
    ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> Nan::MakeCallback(v                                         8::Local<v8::Object>, const char*, int, v8::Local<v8::Value>*)’:
    ../node_modules/nan/nan.h:845:62: warning: ‘v8::Local<v8::Value> node::MakeCallb                                         ack(v8::Isolate*, v8::Local<v8::Object>, const char*, int, v8::Local<v8::Value>*                                         )’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declaration                                         s]
             v8::Isolate::GetCurrent(), target, method, argc, argv);
    /home/pi/.node-gyp/10.16.0/include/node/node.h:163:50: note: declared here
    ../node_modules/nan/nan.h: In member function ‘v8::Local<v8::Value> Nan::Callbac                                         k::Call_(v8::Isolate*, v8::Local<v8::Object>, int, v8::Local<v8::Value>*) const’                                         :
    ../node_modules/nan/nan.h:1463:5: warning: ‘v8::Local<v8::Value> node::MakeCallb                                         ack(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local                                         <v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated                                         -declarations]
    ../node_modules/nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWor                                         ker*)’:
    ../node_modules/nan/nan.h:1706:62: warning: cast between incompatible function t                                         ypes from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_                                         cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
    ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Sock                                         et(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/unix_dgram.cc:189:37: warning: ‘int32_t v8::Value::Int32Value() const’ is                                          deprecated: Use maybe version [-Wdeprecated-declarations]
       domain      = info[0]->Int32Value();
    /home/pi/.node-gyp/10.16.0/include/node/v8.h:2478:46: note: declared here
       V8_DEPRECATED("Use maybe version", int32_t Int32Value() const);
    ../src/unix_dgram.cc:190:37: warning: ‘int32_t v8::Value::Int32Value() const’ is                                          deprecated: Use maybe version [-Wdeprecated-declarations]
       type        = info[1]->Int32Value();
    ../src/unix_dgram.cc:191:37: warning: ‘int32_t v8::Value::Int32Value() const’ is                                          deprecated: Use maybe version [-Wdeprecated-declarations]
       protocol    = info[2]->Int32Value();
    ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Bind                                         (Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/unix_dgram.cc:230:28: warning: ‘int32_t v8::Value::Int32Value() const’ is                                          deprecated: Use maybe version [-Wdeprecated-declarations]
       fd = info[0]->Int32Value();
    ../src/unix_dgram.cc:231:33: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Loca                                         l<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
       String::Utf8Value path(info[1]);
    ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Send                                         To(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/unix_dgram.cc:258:28: warning: ‘int32_t v8::Value::Int32Value() const’ is                                          deprecated: Use maybe version [-Wdeprecated-declarations]
    SCHNIPP SCHNAPP
    Hab dann noch den Fixer ausgeführt und iobroker läuft. Also alles gut?
    LED
    Jan1
    #239
    @LED
    Der Fixer war nicht nötig, da das alles schon bei einer Neuinstallation mit drin ist, schadet aber auch nicht 😊
    • L LED
      Hallo
      v10.16.0
      6.9.0
      Installed acl
      Installed git
      SCHNIPP SCHNAPP
      LED
      AlCalzoneA Offline
      AlCalzoneA Offline
      AlCalzone
      #240
      @LED sagte in Neue Installationsroutine und neue Anleitungen (für Linux-basierte Systeme):
      Was ich nicht verstehe... Im Ankündigungspost zum Fixer steht:
      Mittels einem Kommando wird eine bestehende Installation in /opt/iobroker auf den gleichen Stand gebracht wie eine aktuelle neue Installation.
      Wie kommt man dann auf die Idee, diesen direkt nach einer nagelneuen Installation auszuführen? Ernst gemeinte Frage.
      L 1 Antwort Letzte Antwort
      • L Offline
        LED
        #241
        Hier noch der Rest
        ../src/unix_dgram.cc:259:27: warning: ‘v8::Local<v8::Object> v8::Value::ToObject                                         () const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
           buf = info[1]->ToObject();
        /home/pi/.node-gyp/10.16.0/include/node/v8.h:10046:15: note: declared here
         Local<Object> Value::ToObject() const {
        ../src/unix_dgram.cc:260:33: warning: ‘uint32_t v8::Value::Uint32Value() const’                                          is deprecated: Use maybe version [-Wdeprecated-declarations]
           offset = info[2]->Uint32Value();
        /home/pi/.node-gyp/10.16.0/include/node/v8.h:2477:47: note: declared here
           V8_DEPRECATED("Use maybe version", uint32_t Uint32Value() const);
        ../src/unix_dgram.cc:261:33: warning: ‘uint32_t v8::Value::Uint32Value() const’                                          is deprecated: Use maybe version [-Wdeprecated-declarations]
           length = info[3]->Uint32Value();
        ../src/unix_dgram.cc:262:33: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Loca                                         l<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
           String::Utf8Value path(info[4]);
        ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Send                                         (Nan::NAN_METHOD_ARGS_TYPE)’:
        ../src/unix_dgram.cc:302:28: warning: ‘int32_t v8::Value::Int32Value() const’ is                                          deprecated: Use maybe version [-Wdeprecated-declarations]
        ../src/unix_dgram.cc:303:27: warning: ‘v8::Local<v8::Object> v8::Value::ToObject                                         () const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
        ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Conn                                         ect(Nan::NAN_METHOD_ARGS_TYPE)’:
        ../src/unix_dgram.cc:340:28: warning: ‘int32_t v8::Value::Int32Value() const’ is                                          deprecated: Use maybe version [-Wdeprecated-declarations]
        ../src/unix_dgram.cc:341:33: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Loca                                         l<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
        ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Clos                                         e(Nan::NAN_METHOD_ARGS_TYPE)’:
        ../src/unix_dgram.cc:361:28: warning: ‘int32_t v8::Value::Int32Value() const’ is                                          deprecated: Use maybe version [-Wdeprecated-declarations]
        ../src/unix_dgram.cc: At global scope:
        /home/pi/.node-gyp/10.16.0/include/node/node.h:573:43: warning: cast between inc                                         ompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_                                         register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*                                         )’} [-Wcast-function-type]
        ../src/unix_dgram.cc:420:1: note: in expansion of macro ‘NODE_MODULE’
         NODE_MODULE(unix_dgram, Initialize)
        ../node_modules/nan/nan_object_wrap.h:66:61:   required from here
        make: *** [unix_dgram.target.mk:99: Release/obj.target/unix_dgram/src/unix_dgram                                         .o] Fehler 1
        gyp ERR! build error
        gyp ERR! stack Error: `make` failed with exit code: 2
        gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_module                                         s/node-gyp/lib/build.js:262:23)
        gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
        gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_proces                                         s.js:248:12)
        gyp ERR! System Linux 4.19.57-v7+
        gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gy                                         p/bin/node-gyp.js" "rebuild"
        gyp ERR! cwd /opt/iobroker/node_modules/unix-dgram
        gyp ERR! node -v v10.16.0
        gyp ERR! node-gyp -v v3.8.0
        gyp ERR! not ok
        In file included from ../src/./serialport.h:6,
                         from ../src/serialport.cpp:1:
        ../../nan/nan.h:2298:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
        ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:
        ../src/serialport.cpp:41:49: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
           v8::String::Utf8Value path(info[0]->ToString());
        ../src/serialport.cpp:48:53: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
           v8::Local<v8::Object> options = info[1]->ToObject();
        ../src/serialport.cpp:78:69: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
           uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen);
        ../src/serialport.cpp: In function ‘void EIO_AfterOpen(uv_work_t*)’:
        ../src/serialport.cpp:95:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
           data->callback.Call(2, argv);
        ../../nan/nan.h:1740:3: note: declared here
           Call(int argc, v8::Local<v8::Value> argv[]) const {
        ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:
        ../src/serialport.cpp:113:53: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
        ../src/serialport.cpp:135:71: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
           uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate);
        ../src/serialport.cpp: In function ‘void EIO_AfterUpdate(uv_work_t*)’:
        ../src/serialport.cpp:150:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
           data->callback.Call(1, argv);
        ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:
        ../src/serialport.cpp:175:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
           uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose);
        ../src/serialport.cpp: In function ‘void EIO_AfterClose(uv_work_t*)’:
        ../src/serialport.cpp:188:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
        ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:
        ../src/serialport.cpp:215:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
           uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush);
        ../src/serialport.cpp: In function ‘void EIO_AfterFlush(uv_work_t*)’:
        ../src/serialport.cpp:231:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
        ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
        ../src/serialport.cpp:250:53: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
        ../src/serialport.cpp:270:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
           uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet);
        ../src/serialport.cpp: In function ‘void EIO_AfterSet(uv_work_t*)’:
        ../src/serialport.cpp:285:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
        ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:
        ../src/serialport.cpp:314:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
           uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet);
        ../src/serialport.cpp: In function ‘void EIO_AfterGet(uv_work_t*)’:
        ../src/serialport.cpp:336:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
        ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’:
        ../src/serialport.cpp:363:76: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
           uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate);
        ../src/serialport.cpp: In function ‘void EIO_AfterGetBaudRate(uv_work_t*)’:
        ../src/serialport.cpp:383:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
        ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:
        ../src/serialport.cpp:409:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
           uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain);
        ../src/serialport.cpp: In function ‘void EIO_AfterDrain(uv_work_t*)’:
        ../src/serialport.cpp:424:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
        ../src/serialport.cpp: At global scope:
        ../src/serialport.cpp:430:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses]
         SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) {
        ../src/serialport.cpp:449:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses]
         SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) {
        /home/pi/.node-gyp/10.16.0/include/node/node.h:573:43: warning: cast between incompatible function types from ‘void (*)(v8::Handle<v8::Object>)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
        /home/pi/.node-gyp/10.16.0/include/node/node.h:607:3: note: in expansion of macro ‘NODE_MODULE_X’
        ../src/serialport.cpp:485:1: note: in expansion of macro ‘NODE_MODULE’
         NODE_MODULE(serialport, init);
        /home/pi/.node-gyp/10.16.0/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)]’:
        /home/pi/.node-gyp/10.16.0/include/node/node_object_wrap.h:84:78:   required from here
        /home/pi/.node-gyp/10.16.0/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<node::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
        /home/pi/.node-gyp/10.16.0/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = Nan::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)]’:
        /home/pi/.node-gyp/10.16.0/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<Nan::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)’} to ‘Callback’ {aka  void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
        In file included from ../src/serialport.h:6,
                         from ../src/serialport_unix.cpp:2:
        ../src/serialport_unix.cpp: In function ‘int setup(int, OpenBaton*)’:
        ../src/serialport_unix.cpp:176:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1005 [-Wformat-truncation=]
             snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path);
        ../src/serialport_unix.cpp:176:13: note: ‘snprintf’ output 20 or more bytes (assuming 1043) into a destination of size 1024
        ../src/serialport_unix.cpp: In function ‘void EIO_Open(uv_work_t*)’:
        ../src/serialport_unix.cpp:86:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1003 [-Wformat-truncation=]
             snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path);
        ../src/serialport_unix.cpp:86:13: note: ‘snprintf’ output 22 or more bytes (assuming 1045) into a destination of size 1024
        In file included from ../src/poller.cpp:1:
        ../src/poller.cpp: In static member function ‘static void Poller::onData(uv_poll_t*, int, int)’:
        ../src/poller.cpp:69:29: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
           obj->callback.Call(2, argv);
        • AlCalzoneA AlCalzone
          LED
          #242
          @AlCalzone said in Neue Installationsroutine und neue Anleitungen (für Linux-basierte Systeme):
          Na ja, wenn etwas nicht klappt und es einen Fixer gibt :-)
          Hat aber wohl nicht geschadet... ich lerne noch.
            Atticus68
            #243
            ich versuche gerade ioBroker auf einem Raspberry 4 mit Rasbian Buster zu installieren.
            Hier in diesem Beitrag gibt es ja links zu neuen Installationsanleitungen/Scripten...
            Leider kann ich keines diese Scripte nutzen, da die Links nicht funktionieren.
            Kann mir jemand helfen und einen Link zu einer funktionierenden Installationsanleitung posten?
            Thomas
            • L Offline
              LED
              schrieb am zuletzt editiert von LED
              #244
              Ich bin jetzt seit etwa 40h an dem Thema iobroker auf Raspberry dran und kann schon gar nicht mehr zählen wie oft ich auf tote Links geklickt habe. OK, ich bin auch ein totaler Linux Noob und hab immer nur Windows genutzt. Aber der Einstieg war schon echt schwer, obwohl es im Grunde so einfach sein könnte.
              • L LED
                AlCalzoneA Offline
                AlCalzoneA Offline
                AlCalzone
                #245
                Was denn? Lief ioBroker etwa nicht?
                • A Atticus68
                  Thomas
                  Jan1
                  #246
                  @TomsHome
                  Die toten Links kommen von der Neustrukturierung des Forum und sind in der Tat etwas nervig zumal die neue Doku die irgendwann mal alles zusammenfassen soll noch nicht fertig ist.
                  Im Grunde ist das wesentliche aber erreichbar und damit bekommt man ohne Probleme IOBroker installiert. Wie Rasbian auf dem Pi einzurichten ist, sollte eh nicht hier gesucht werden, sondern im entsprechenden Raspian Forum, da dort der Support eben darauf ausgelegt ist und hier der Schwerpunkt bei IOBroker liegt.
                  Oder man nimmt eben ein fertiges Image von hier und spart sich die Raspian Einrichtung. Meine Empfehlung ist aber das ganze selber zu machen, da nur so das Grundverständnis für spätere eventuelle Probleme gesammelt wird (wenn nicht eh schon vorhanden).
                    Atticus68
                    #247
                    Danke für Eure schnelle Hilfe, ich ab es gefunden.
                    Die Einrichtung von Rasbian auf dem Pi ist ja kein Problem, das war ja auch schon erledigt.
                    Ich hatte nur arge Probleme, ioBroker zu installieren und zum laufen zu bringen.
                    Jetzt hat es aber funktioniert.
                    ich hab den ioBroker deshalb auf meinem Testsystem neu aufgesetzt, weil ich darauf den SQL-Adapter nicht zum laufen bringen konnte. Hab den jetzt als erste installiert, jetzt läuft er.
                    Es sieht aber auch so aus, als ob die Installation von Adaptern jetzt anders abläuft, bzw. länger dauert, er wird im Installationsfenster jedenfalls viel mehr angezeigt als bei früheren Installationen.
                    Thomas
                    • J Jan1
                      @TomsHome
                      LED
                      #248
                      @Jan1 said in Neue Installationsroutine und neue Anleitungen (für Linux-basierte Systeme):
                      Ja, hab ich schon verstanden und inzwischen ist mir auch klar wo ich was finde. Für neue User aber in der Tat sehr nervig.
                      @TomsHome said in Neue Installationsroutine und neue Anleitungen (für Linux-basierte Systeme):
                      Ich hab inzwischen bestimmt 20x iobroker installiert, am Anfang über fertige Images um erst einmal zu verstehen was da so geht und wie es aussehen sollte und danach auch selbst installiert. Eine SD-Karte hab ich irgendwie geschrottet und mit den Berechtigungen unter Linux komme ich auch noch nicht wirklich klar. Auch wenn es nicht empfohlen wird, auf meinen Testsystemen arbeite ich erst einmal als Root.
                      Mit dem SQL Adapter hatte ich auch Probleme und eine Datenbank konnte ich auf dem fertigen IoBroker Image erst recht nicht installieren. Und das die Adapter jetzt ewig brauchen und es sehr viele (Fehler-)Meldungen gibt ist mir ebenfalls aufgefallen. Aber ich glaube ich hab da vorher auch einfach nicht drauf geachtet und die Ausgabe deaktiviert.
                      Trotzdem macht es mich unsicher, ob ich auf dem richtigen Weg bin und das alles so gewollt ist :-)
                        Atticus68
                        #249
                        Dann hab ich gleich noch eine Frage.
                        Benutzt jemand den BLE-Adapter, läuft der bei Euch?
                        Auf meinem "Arbeitssystem"(Node/js 10.16.0, npm 6.9.0, js-controller 1.5.11) ist die BLE Version 0.7.2 installiert.
                        Der BLE hat funktionert, aber ich meine seit dem ich den js-contoller auf 1.5.11 upgedate habe, läuft er nicht mehr. Hat jemand eine Idee?
                        Dake
                        Thomas
                        • L LED
                          #250
                          @LED Tote Links ... wenn Du Sie nochmal findest bitte melden.
                          Wir haben die Doku und Webseite umgestellt und jetzt müssen wir hier ggf solche Dinge nachziehen und fixen. Also hier im Forum bitte nicht davor scheuen totel Links zu melden! Und auch auf den Webseiten und so.
                          • L LED
                            #251
                            @LED Das bei einigen Adaptern "Warnungen" kommen ist unschön und wir sind immer versucht die zu fixen. Einige kommen aber auch abhängigen Paketen und von daher haben wir darauf nur einen bedingten Einfluss. Das ist leider eine Unschöne Eigenheit von Nodejs bzw der Art wie Pakete mit npm gemanaged werden. :-(
                            Eine SQL-Datenbank auf einem Raspi mit SD Karte würde ich auch nicht als Sinnvoll ansehen! Da ist deine SD Karte shcneller hin als Du schauen kannst und es sei denn DU nimmst einen Raspi 4 mit genug RAM das limitiert auch. Hier ist auch die sqlite3 Library grund für einige Warnjungen, die am Ende aber ignoriert werden können.
                            • A Atticus68
                              Dake
                              Thomas
                              AlCalzoneA Offline
                              AlCalzoneA Offline
                              AlCalzone
                              #252
                              @TomsHome sagte in Neue Installationsroutine und neue Anleitungen (für Linux-basierte Systeme):
                              Wie immer ist "läuft nicht" keine ausreichende Fehlerbeschreibung. Das mindeste was du liefern solltest, sind die passenden Logs. Anhand diesen findest du sicher auch ähnliche Probleme samt Lösung hier im Forum. Eine Abhängigkeit des Adapters ist leider etwas fragil, was Installationen angeht.
                              Und die Frage ist in einem Extra Thread eigentlich besser aufgehoben.
                                Atticus68
                                schrieb am zuletzt editiert von Atticus68
                                #253
                                @AlCalzone ja, das mach ich doch. Da ich aber noch recht neu in der Materie bin, die Frage, wo finde ich das passende Log?
                                Thomas
                                  Atticus68
                                  #254
                                  Und noch was, betrifft nur das Forum hier, kann ich meine Beiträge nicht editieren? Ich finde keinen Button, um den Beitrag zu ändern.
                                  • A Atticus68
                                    sigi234S Online
                                    sigi234S Online
                                    #255
                                      Atticus68
                                      #256
                                      Ok, danke
                                      • apollon77A apollon77
                                        Ich glaube du hast das gleiche Problem wie in einen anderen Thread von heute das in Debian 10 ein normaler User das Verzeichnis /usr/sbin nicht im Pfad hat. Dort liegen aber Programme wie usermod, visudo und so.
                                        Versuch mal:
                                        sudo su -
                                        Und dann den installer als root laufen lassen. Hat dort funktioniert
                                        1Topf1 Offline
                                        1Topf1 Offline
                                        1Topf
                                        #257
                                        @apollon77 sagte in Neue Installationsroutine und neue Anleitungen (für Linux-basierte Systeme):
                                        Versuch mal:
                                        sudo su -
                                        Sudo su - funzt nicht, aber su -. Und juhu, ioB läuft, zumindest die Grundinstallation 👍 . Werde demnächst mal eine Sicherung meines laufenden Sytems einspielen und schaun, ob das funzt. Vielen Dank! ☺
                                        • A Atticus68
                                          Thomas
                                          AlCalzoneA Offline
                                          AlCalzoneA Offline
                                          AlCalzone
                                          #258
                                          ioBroker-Admin -> Tab "Log" ;)
