  4. Server Cannot start inMem-objects on port 9001
429 Beiträge 40 Kommentatoren 132.6k Aufrufe 39 Beobachtet
  • T Tungild
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Model           : Raspberry Pi 4 Model B Rev 1.4
    Architecture    : armv7l
    Docker          : false
    Virtualization  : none
    Distributor ID: Raspbian
    Description:    Raspbian GNU/Linux 10 (buster)
    Release:        10
    Codename:       buster
    PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
    NAME="Raspbian GNU/Linux"
    VERSION_ID="10"
    VERSION="10 (buster)"
    VERSION_CODENAME=buster
    ID=raspbian
    ID_LIKE=debian
    HOME_URL="http://www.raspbian.org/"
    SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
    BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
    Systemuptime and Load:
     18:30:28 up  1:21,  1 user,  load average: 1.01, 1.08, 0.98
    CPU threads: 4
    Raspberry only:
    throttled=0x0
    Other values than 0x0 hint to temperature/voltage problems
    temp=74.0'C
    volt=0.8700V
    *** Time and Time Zones ***
                   Local time: Fri 2023-04-28 18:30:28 CEST
               Universal time: Fri 2023-04-28 16:30:28 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:           7.9G        196M        6.3G        8.0M        1.4G        7.4G
    Swap:           99M          0B         99M
    Total:         8.0G        196M        6.4G
             7898 M total memory
              198 M used memory
             1256 M active memory
              258 M inactive memory
             6253 M free memory
              115 M buffer memory
             1331 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FILESYSTEM ***
    /dev/root      ext4       59G  5.2G   51G  10% /
    devtmpfs       devtmpfs  3.7G     0  3.7G   0% /dev
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     3.9G  8.4M  3.9G   1% /run
    tmpfs          tmpfs     3.9G     0  3.9G   0% /sys/fs/cgroup
    /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
    tmpfs          tmpfs     790M     0  790M   0% /run/user/1000
    [Fri Apr 28 17:09:06 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:BE:A6:4B vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=9fa8c098-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
    [Fri Apr 28 17:09:07 2023] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
    [Fri Apr 28 17:09:07 2023] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
    [Fri Apr 28 17:09:07 2023] EXT4-fs (mmcblk0p2): recovery complete
    [Fri Apr 28 17:09:07 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [Fri Apr 28 17:09:07 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Fri Apr 28 17:09:09 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    TARGET        SOURCE         FSTYPE OPTIONS
    /             /dev/mmcblk0p2 ext4   rw,noatime
    |-/sys/fs/bpf none           bpf    rw,nosuid,nodev,noexec,relatime,mode=700
    `-/boot       /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    307M    /var/
    109M    /var/cache
    104M    /var/cache/apt
    92M     /var/lib
    69M     /var/lib/apt/lists
    Archived and active journals take up 8.0M in the file system.
    /opt/iobroker/backups:
    312M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.7G    /opt/iobroker/iobroker-data/
    147M    /opt/iobroker/iobroker-data/files
    97M     /opt/iobroker/iobroker-data/backup-objects
    42M     /opt/iobroker/iobroker-data/files/vis
    35M     /opt/iobroker/iobroker-data/files/vis/widgets
    1.5G    /opt/iobroker/iobroker-data/objects.jsonl
    16M     /opt/iobroker/iobroker-data/files/vis.0/IMG/Grundriss 1 EG.jpg
    12M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.ea6ad656.chunk.js.map
    6.4M    /opt/iobroker/iobroker-data/objects.json.migrated
    6.4M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v16.15.1
    /usr/bin/node           v16.15.1
    /usr/bin/npm            8.13.1
    /usr/bin/npx            8.13.1
    nodejs:
      Installed: 16.15.1-deb-1nodesource1
      Candidate: 16.20.0-deb-1nodesource1
      Version table:
         16.20.0-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
     *** 16.15.1-deb-1nodesource1 100
         10.24.0~dfsg-1~deb10u3 500
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
    Core adapters versions
    js-controller:  4.0.23
    admin:          6.1.9
    javascript:     5.7.0
    Adapters from github:   0
    Adapter State
    ioBroker-Repositories
    Installed ioBroker-Instances
    Objects and States
    Objects:        1
    States:         1
    Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
    Hit:2 https://deb.nodesource.com/node_16.x buster InRelease
    Hit:3 http://archive.raspberrypi.org/debian buster InRelease
    Reading package lists...
    Pending Updates: 142
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15294      560/sshd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          15296      560/sshd
    udp        0      0 0.0.0.0:34139           0.0.0.0:*                           108        14057      387/avahi-daemon: r
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14989      552/dhcpcd
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14055      387/avahi-daemon: r
    udp6       0      0 :::60976                :::*                                108        14058      387/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        14056      387/avahi-daemon: r
    2023-04-28 18:30:10.471  - info: host.raspberrypi4-iob ip addresses: 192.168.188.44 fe80::4f78:66f9:8f3d:2aca
    2023-04-28 18:30:40.494  - error: host.raspberrypi4-iob No connection to databases possible, restart
    2023-04-28 18:30:40.509  - info: host.raspberrypi4-iob iobroker _restart
    2023-04-28 18:30:46.435  - info: host.raspberrypi4-iob iobroker.js-controller version 4.0.23 js-controller starting
    2023-04-28 18:30:46.443  - info: host.raspberrypi4-iob Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
    2023-04-28 18:30:46.444  - info: host.raspberrypi4-iob hostname: raspberrypi4-iob, node: v16.15.1
    2023-04-28 18:30:46.445  - info: host.raspberrypi4-iob ip addresses: 192.168.188.44 fe80::4f78:66f9:8f3d:2aca
    2023-04-28 18:31:16.477  - error: host.raspberrypi4-iob No connection to databases possible, restart
    2023-04-28 18:31:16.499  - info: host.raspberrypi4-iob iobroker _restart
    2023-04-28 18:31:22.410  - info: host.raspberrypi4-iob iobroker.js-controller version 4.0.23 js-controller starting
    2023-04-28 18:31:22.417  - info: host.raspberrypi4-iob Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
    2023-04-28 18:31:22.418  - info: host.raspberrypi4-iob hostname: raspberrypi4-iob, node: v16.15.1
    2023-04-28 18:31:22.419  - info: host.raspberrypi4-iob ip addresses: 192.168.188.44 fe80::4f78:66f9:8f3d:2aca
    2023-04-28 18:31:52.441  - error: host.raspberrypi4-iob No connection to databases possible, restart
    2023-04-28 18:31:52.455  - info: host.raspberrypi4-iob iobroker _restart
    2023-04-28 18:31:58.463  - info: host.raspberrypi4-iob iobroker.js-controller version 4.0.23 js-controller starting
    2023-04-28 18:31:58.470  - info: host.raspberrypi4-iob Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
    2023-04-28 18:31:58.471  - info: host.raspberrypi4-iob hostname: raspberrypi4-iob, node: v16.15.1
    2023-04-28 18:31:58.472  - info: host.raspberrypi4-iob ip addresses: 192.168.188.44 fe80::4f78:66f9:8f3d:2aca
    2023-04-28 18:32:28.520  - error: host.raspberrypi4-iob No connection to databases possible, restart
    2023-04-28 18:32:28.534  - info: host.raspberrypi4-iob iobroker _restart
    2023-04-28 18:32:34.447  - info: host.raspberrypi4-iob iobroker.js-controller version 4.0.23 js-controller starting
    2023-04-28 18:32:34.454  - info: host.raspberrypi4-iob Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
    2023-04-28 18:32:34.456  - info: host.raspberrypi4-iob hostname: raspberrypi4-iob, node: v16.15.1
    2023-04-28 18:32:34.457  - info: host.raspberrypi4-iob ip addresses: 192.168.188.44 fe80::4f78:66f9:8f3d:2aca
    iob diag has finished.
                         v.2023-04-16
    Operatingsystem:        Raspbian GNU/Linux 10 (buster)
    Kernel:                 5.10.63-v7l+
    Installation:           Native
    User-ID:                1000
    X-Server:               false
    Pending OS-Updates:     142
    Pending iob updates:    0
    Nodejs-Installation:    /usr/bin/nodejs         v16.15.1
                            /usr/bin/npm            8.13.1
                            /usr/bin/npx            8.13.1
    Recommended versions are nodejs 18.x.y and npm 9.x.y
    MEMORY:
    Mem:           7.9G         78M        6.4G        8.0M        1.4G        7.6G
    Swap:           99M          0B         99M
    Total:         8.0G         78M        6.5G
    Active iob-Instances:   0
    ioBroker Core:          js-controller           4.0.23
                            admin                   6.1.9
    ioBroker Status:        Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
    Objects:                1
    States:                 1
    Size of iob-Database:
    592K    /opt/iobroker/iobroker-data/states.jsonl
    500K    /opt/iobroker/iobroker-data/states.json.migrated
    500K    /opt/iobroker/iobroker-data/states.json.bak.migrated
    0       /opt/iobroker/iobroker-data/states.json.broken
    Ergebnisse von
     iob diagt
    #391
    @tungild
    Da würde ich zuerst Mal ran und das ganze System auf eine aktuelle Basis setzen. Dann das Bullseye-Release draufwerfen.
    Die Kiste wird auch etwas zu warm
    temp=74.0'C
    Und die load ist mit 1 auch etwas hoch, der iobroker läuft ja nicht mal.
    Was treibt da also die Auslastung so weit nach oben?
    Die Datenbank ist auch zu fett:
    Hast du den Fixer schonmal ausgeführt?
    • T Tungild
      ich habe seit heute dasselbe Problem. Habe auf meinen Raspberry nur iobroker laufen und das letzte Mal etwas vor ca. einem halben Jahr gemacht. Lief alles ohne Probleme.
      Wollte eigentlich nur über die Weboberfläche für meine Automation etwas umstellen und gesehen das es neue Updates gibt.
      Hab mich dann über Putty eingeloggt und „iobroker stop“ ausgeführt. Das war der Anfang vom Ende.
      Muss gestehen das ich ein absoluter Anfänger bin und schon über zwei Stunden den Forumseintrag hier lese ohne, dass ich ein Erfolg verzeichnen kann.
      pi@raspberrypi4-iob:~ $ iobroker status
      No connection to databases possible ...
      pi@raspberrypi4-iob:~ $ iobroker stop
      pi@raspberrypi4-iob:~ $ iobroker start
      pi@raspberrypi4-iob:~ $ iob start admin
      No connection to databases possibleServer Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
      Iobroker Fix ohne erfolg.
      Würde mich über Hilfe sehr freuen.
      #392
      @tungild iob fix ohne Erfolg? Zeig mal die Ausgaben bitte.
      • apollon77A apollon77
        Tungild
        #393
        @apollon77 entschuldigt bitte meine späte Antwort.
        Habe heute Nacht den Fixer nochmals laufen lassen, scheinbar diesmal mit Erfolg. Gestern hatte ich dies schon mehrfach ohne Erfolg versucht.
        Die Weboberfläche läuft wieder und kann alles wie gewohnt benutzen. Wieso es nun auf einmal wieder geht, kann ich nicht sagen.
        pi@raspberrypi4-iob:~ $ iobroker fix
        library: loaded
        Library version=2022-12-09
            Welcome to the ioBroker installation fixer!
            Script version: 2023-04-02
            You might need to enter your password a couple of times.
            Installing prerequisites (1/5)
        Holen:1 http://raspbian.raspberrypi.org/raspbian buster InRelease [15,0 kB]
        OK:2 http://archive.raspberrypi.org/debian buster InRelease
        OK:3 https://deb.nodesource.com/node_16.x buster InRelease
        Es wurden 15,0 kB in 1 s geholt (14,1 kB/s).
        Installed gcc-c++
            Checking ioBroker user and directory permissions (2/5)
            Check and cleanup npm temporary directories (3/5)
        Done.
            Database maintenance (4/5)
        Checking for uncompressed JSONL databases... This might take a while!
        Compressing /opt/iobroker/iobroker-data/states.jsonl
        Compressing /opt/iobroker/iobroker-data/objects.jsonl
        Compressed 2 JSONL files. Done
            Checking autostart (5/5)
        Enabling autostart...
        Autostart enabled!
            Your installation was fixed successfully
            Run iobroker start to start ioBroker again!
        pi@raspberrypi4-iob:~ $ iobroker start admin
        Objects type: jsonl
        States  type: jsonl
        Ich werde nun mal versuchen alles auf den neusten Stand zu bringen und hoffe das dann weiterhin alles läuft.
        Danke euch schonmal für eure Beiträge.
        Werde nochmals berichten.
        • T Tungild
          library: loaded
          Installed gcc-c++
          Done.
          Autostart enabled!
          Objects type: jsonl
          States  type: jsonl
          crunchipC Abwesend
          crunchipC Abwesend
          #394
          @tungild sagte in Server Cannot start inMem-objects on port 9001:
          wahrscheinlich
          @thomas-braun sagte in Server Cannot start inMem-objects on port 9001:
          diese hat der fixer komprimiert
            Tungild
            #395
            So, hoffe ich habe nun alles auf dem neusten Stand. Aktuell funktioniert alles.
                                 v.2023-04-16
            User-ID:                1000
            X-Server:               false
            Pending OS-Updates:     0
            Nodejs-Installation:    /usr/bin/nodejs         v18.16.0
                                    /usr/bin/node           v18.16.0
                                    /usr/bin/npm            9.5.1
                                    /usr/bin/npx            9.5.1
            MEMORY:
            Mem:           7.9G        686M        4.3G         16M        2.9G        6.9G
            Swap:           99M          0B         99M
            Total:         8.0G        686M        4.4G
            Active iob-Instances:   11
            Active repo(s): beta
            ioBroker Core:          js-controller           4.0.24
                                    admin                   6.4.3
            Objects type: jsonl
            States  type: jsonl
            + system.adapter.admin.0                  : admin                 : raspberrypi4-iob                         -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            + system.adapter.web.0                    : web                   : raspberrypi4-iob                         -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
            Objects:                2058
            States:                 1693
            9.7M    /opt/iobroker/iobroker-data/objects.jsonl
            4.7M    /opt/iobroker/iobroker-data/states.jsonl
            Besten Dank nochmals 😀
            • T Tungild
                                   v.2023-04-16
              User-ID:                1000
              X-Server:               false
                                      /usr/bin/npm            9.5.1
                                      /usr/bin/npx            9.5.1
              MEMORY:
              Swap:           99M          0B         99M
                                      admin                   6.4.3
              Objects type: jsonl
              States  type: jsonl
              Objects:                2058
              States:                 1693
              GlasfaserG Offline
              GlasfaserG Offline
              #396
              Dir ist schon bekannt , das du dein Repo auf BETA hast bzw. auch ein Beta Tester bist !?
              EDIT :
              ich denke mal unbewußt , denn du hast zuvor diese Versionen gehabt :
              admin:          6.1.9
              javascript:     5.7.0
              und
              du hast noch Buster , Bullseye ist der aktuelle Stand !
              U 1 Antwort Letzte Antwort
              • GlasfaserG Glasfaser
                EDIT :
                admin:          6.1.9
                javascript:     5.7.0
                und
                U Offline
                U Offline
                UncleB
                #397
                Guten Abend,
                Gleiches Problem auch bei mir..
                Der Fix hat nix gebracht.
                iob diag spuckt folgendes aus:
                Skript v.2023-04-16
                *** BASE SYSTEM ***
                Model           : Raspberry Pi 3 Model B Rev 1.2
                Architecture    : aarch64
                Docker          : false
                Distributor ID: Debian
                Description:    Debian GNU/Linux 11 (bullseye)
                Release:        11
                Codename:       bullseye
                PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
                NAME="Debian GNU/Linux"
                VERSION_ID="11"
                VERSION="11 (bullseye)"
                VERSION_CODENAME=bullseye
                ID=debian
                HOME_URL="https://www.debian.org/"
                SUPPORT_URL="https://www.debian.org/support"
                BUG_REPORT_URL="https://bugs.debian.org/"
                 23:12:09 up 1 min,  1 user,  load average: 1.24, 0.46, 0.17
                CPU threads: 4
                Raspberry only:
                throttled=0x0
                temp=71.4'C
                volt=1.3438V
                               Local time: Fri 2023-05-12 23:12:10 CEST
                           Universal time: Fri 2023-05-12 21:12:10 UTC
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                pi
                /home/pi
                pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                X-Server:       false
                Desktop:
                Terminal:       tty
                Boot Target:    multi-user.target
                *** MEMORY ***
                Mem:            909M        162M        156M        0.0K        590M        691M
                Swap:            99M          0B         99M
                Total:          1.0G        162M        256M
                          909 M total memory
                          162 M used memory
                          215 M active memory
                          458 M inactive memory
                          156 M free memory
                           19 M buffer memory
                          570 M swap cache
                           99 M total swap
                            0 M used swap
                           99 M free swap
                Raspberry only:
                oom events: 0
                *** FILESYSTEM ***
                /dev/root      ext4       15G  4.8G  8.9G  36% /
                devtmpfs       devtmpfs  325M     0  325M   0% /dev
                tmpfs          tmpfs     455M     0  455M   0% /dev/shm
                tmpfs          tmpfs     182M  968K  181M   1% /run
                /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
                tmpfs          tmpfs      91M     0   91M   0% /run/user/1000
                [Fri May 12 23:10:54 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=Composite-1:720x480@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=0c797088-02 rootfstype=ext4 fsck.repair=yes rootwait
                [Fri May 12 23:10:57 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                [Fri May 12 23:10:57 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                [Fri May 12 23:11:00 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                /       /dev/mmcblk0p2 ext4   rw,noatime,commit=600
                /var:
                993M    /var/
                536M    /var/log
                521M    /var/log/journal/556ce5c3a8d54c0c89d73703db3b1f8c
                209M    /var/cache
                Archived and active journals take up 520.1M in the file system.
                33M     /opt/iobroker/backups/
                704M    /opt/iobroker/iobroker-data/
                169M    /opt/iobroker/iobroker-data/files
                64M     /opt/iobroker/iobroker-data/backup-objects
                51M     /opt/iobroker/iobroker-data/files/javascript.admin
                48M     /opt/iobroker/iobroker-data/files/telegram.admin
                467M    /opt/iobroker/iobroker-data/objects.jsonl
                15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
                7.2M    /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js
                6.9M    /opt/iobroker/iobroker-data/files/telegram.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.8fdf8cb7.chunk.js.map
                6.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.de0231c9.chunk.js.map
                /usr/bin/nodejs         v16.20.0
                /usr/bin/node           v16.20.0
                /usr/bin/npm            8.19.4
                /usr/bin/npx            8.19.4
                nodejs:
                  Installed: 16.20.0-deb-1nodesource1
                  Version table:
                 *** 16.20.0-deb-1nodesource1 500
                        500 https://deb.nodesource.com/node_16.x bullseye/main arm64 Packages
                     12.22.12~dfsg-1~deb11u4 500
                        500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                     12.22.12~dfsg-1~deb11u3 500
                        500 http://deb.debian.org/debian bullseye/main arm64 Packages
                ioBroker Status
                admin:          6.3.5
                javascript:     6.1.4
                Adapters from github:   1
                Adapter State
                Objects and States
                Objects:        1
                States:         1
                Hit:1 http://deb.debian.org/debian bullseye InRelease
                Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
                Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
                Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                Hit:5 https://deb.nodesource.com/node_16.x bullseye InRelease
                Pending Updates: 0
                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14495      523/sshd: /usr/sbin
                tcp6       0      0 :::22                   :::*                    LISTEN      0          14497      523/sshd: /usr/sbin
                udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          1794       623/dhcpcd
                udp        0      0 0.0.0.0:51820           0.0.0.0:*                           0          1886       -
                udp        0      0 0.0.0.0:41124           0.0.0.0:*                           108        14448      368/avahi-daemon: r
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14446      368/avahi-daemon: r
                udp6       0      0 :::51820                :::*                                0          1887       -
                udp6       0      0 :::5353                 :::*                                108        14447      368/avahi-daemon: r
                udp6       0      0 :::49432                :::*                                108        14449      368/avahi-daemon: r
                2023-05-12 23:14:20.573  - info: host.raspberrypi ip addresses: 192.168.30.6 fe80::6b2f:cbb4:2470:70a3 10.110.183.1
                2023-05-12 23:14:50.621  - error: host.raspberrypi No connection to databases possible, restart
                2023-05-12 23:14:50.656  - info: host.raspberrypi iobroker _restart
                2023-05-12 23:14:57.929  - info: host.raspberrypi iobroker.js-controller version 4.0.23 js-controller starting
                2023-05-12 23:14:57.944  - info: host.raspberrypi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                2023-05-12 23:14:57.946  - info: host.raspberrypi hostname: raspberrypi, node: v16.20.0
                2023-05-12 23:14:57.948  - info: host.raspberrypi ip addresses: 192.168.30.6 fe80::6b2f:cbb4:2470:70a3 10.110.183.1
                2023-05-12 23:15:27.989  - error: host.raspberrypi No connection to databases possible, restart
                2023-05-12 23:15:28.019  - info: host.raspberrypi iobroker _restart
                2023-05-12 23:15:35.553  - info: host.raspberrypi iobroker.js-controller version 4.0.23 js-controller starting
                2023-05-12 23:15:35.571  - info: host.raspberrypi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                2023-05-12 23:15:35.574  - info: host.raspberrypi hostname: raspberrypi, node: v16.20.0
                2023-05-12 23:15:35.577  - info: host.raspberrypi ip addresses: 192.168.30.6 fe80::6b2f:cbb4:2470:70a3 10.110.183.1
                2023-05-12 23:15:37.722  - error: host.raspberrypi-Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
                2023-05-12 23:15:44.388  - info: host.raspberrypi iobroker.js-controller version 4.0.23 js-controller starting
                2023-05-12 23:15:44.405  - info: host.raspberrypi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                2023-05-12 23:15:44.408  - info: host.raspberrypi hostname: raspberrypi, node: v16.20.0
                2023-05-12 23:15:44.411  - info: host.raspberrypi ip addresses: 192.168.30.6 fe80::6b2f:cbb4:2470:70a3 10.110.183.1
                2023-05-12 23:15:46.561  - error: host.raspberrypi-Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
                2023-05-12 23:15:53.085  - info: host.raspberrypi iobroker.js-controller version 4.0.23 js-controller starting
                2023-05-12 23:15:53.101  - info: host.raspberrypi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                2023-05-12 23:15:53.103  - info: host.raspberrypi hostname: raspberrypi, node: v16.20.0
                2023-05-12 23:15:53.106  - info: host.raspberrypi ip addresses: 192.168.30.6 fe80::6b2f:cbb4:2470:70a3 10.110.183.1
                2023-05-12 23:16:23.156  - error: host.raspberrypi No connection to databases possible, restart
                2023-05-12 23:16:23.213  - info: host.raspberrypi iobroker _restart
                Press any key for a summary
                Woran kanns liegen?
                • U UncleB
                  Guten Abend,
                  Skript v.2023-04-16
                  *** BASE SYSTEM ***
                  Docker          : false
                  Release:        11
                  Codename:       bullseye
                  VERSION_ID="11"
                  ID=debian
                  CPU threads: 4
                  Raspberry only:
                  throttled=0x0
                  temp=71.4'C
                  volt=1.3438V
                                   RTC time: n/a
                                NTP service: active
                            RTC in local TZ: no
                  pi
                  /home/pi
                  X-Server:       false
                  Desktop:
                  Terminal:       tty
                  *** MEMORY ***
                  Swap:            99M          0B         99M
                            909 M total memory
                            162 M used memory
                            215 M active memory
                            156 M free memory
                             19 M buffer memory
                            570 M swap cache
                             99 M total swap
                              0 M used swap
                             99 M free swap
                  Raspberry only:
                  oom events: 0
                  *** FILESYSTEM ***
                  /var:
                  993M    /var/
                  536M    /var/log
                  209M    /var/cache
                  /usr/bin/npm            8.19.4
                  /usr/bin/npx            8.19.4
                  nodejs:
                    Version table:
                  ioBroker Status
                  admin:          6.3.5
                  javascript:     6.1.4
                  Adapter State
                  Objects and States
                  Objects:        1
                  States:         1
                  Pending Updates: 0
                  Woran kanns liegen?
                  #398
                  @uncleb Und "iob fix" hat echt nichts geholfen? Bitte versuch nochmal und poste noch die Ausgabe von fix und diag danach. Wenn dein "Objects.jsonl" so gross bleibt hast Du dir einiges an Objekten angesammelt
                    bot1000
                    #399
                    ich habe den gleichen Fehler. Zuerst lief alles wie gewünscht. Doch nach einiger Zeit (Monate? Hab es nicht konstant geprüft) konnte ich nicht mehr auf das Webinterface von iobroker zugreifen. Jetzt untersuche ich es genauer und bekomme bei "iob status" den Fehler:
                    Nach "iob fix" und "reboot" funktioniert es immer noch nicht
                    Die "iob diag" gibt folgendes aus:
                                         v.2023-04-16
                    Operatingsystem:        Raspbian GNU/Linux 11 (bullseye)
                    Kernel:                 5.15.68-v7+
                    User-ID:                1000
                    X-Server:               false
                    Pending OS-Updates:     105
                    Nodejs-Installation:    /usr/bin/nodejs         v16.17.0
                                            /usr/bin/node           v16.17.0
                                            /usr/bin/npm            8.15.0
                                            /usr/bin/npx            8.15.0
                    MEMORY:
                    Mem:            922M        234M         74M        0.0K        613M        632M
                    Swap:            99M        1.0M         98M
                    Total:          1.0G        235M        173M
                                            admin                   6.2.22
                    ioBroker Status:        No connection to databases possible ...
                    Objects:                1
                    States:                 1
                    628M    /opt/iobroker/iobroker-data/objects.jsonl
                    88K     /opt/iobroker/iobroker-data/states.jsonl
                    Jemand eine Idee was ich noch machen kann? Wollte nicht wirklich den ganzen Rasperry neu aufsetzen.
                    Ich dachte erst durch mein dauerndest Loggen von Messwerten in meiner HomeAutomation wäre der Speicher vollgelaufen. Das scheint aber nicht zu sein:
                    df
                    Filesystem     1K-blocks    Used Available Use% Mounted on
                    /dev/root       14563544 5695448   8243064  41% /
                    devtmpfs          340548       0    340548   0% /dev
                    tmpfs             472132       0    472132   0% /dev/shm
                    tmpfs             188856     988    187868   1% /run
                    tmpfs               5120       4      5116   1% /run/lock
                    /dev/mmcblk0p1    261108   50962    210146  20% /boo
                    crunchipC apollon77A 2 Antworten Letzte Antwort
                    • B bot1000
                                           v.2023-04-16
                      Kernel:                 5.15.68-v7+
                      User-ID:                1000
                      X-Server:               false
                                              /usr/bin/npm            8.15.0
                                              /usr/bin/npx            8.15.0
                      MEMORY:
                      Swap:            99M        1.0M         98M
                                              admin                   6.2.22
                      Objects:                1
                      States:                 1
                      df
                      crunchipC Abwesend
                      crunchipC Abwesend
                      #400
                      @bot1000 sagte in Server Cannot start inMem-objects on port 9001:
                      https://forum.iobroker.net/post/985102
                      • B bot1000
                                             v.2023-04-16
                        Kernel:                 5.15.68-v7+
                        User-ID:                1000
                        X-Server:               false
                                                /usr/bin/npm            8.15.0
                                                /usr/bin/npx            8.15.0
                        MEMORY:
                        Swap:            99M        1.0M         98M
                                                admin                   6.2.22
                        Objects:                1
                        States:                 1
                        df
                        #401
                        @bot1000 Die Ausgabe von iob fix würde mich echt interessieren bei so einem großen objects file ... lass nochmal fixlaufen und schon ob das kleiner wird.
                        • Thomas BraunT Online
                          #402
                          @bot1000
                          System aktuell halten.
                          Und was ist /boo für ein mountpunkt?
                            @bot1000
                            bot1000
                            #403
                            System aktualisiert -> Fehler ist gleich
                            boo hatte ich abgeschnittenb es ist "boot"
                              bot1000
                              #404
                              @crunchip
                              Timeout beide auf 30000 gesetzt. Immer noch der gleiche Fehler
                              • B bot1000
                                DJMarc75D Offline
                                DJMarc75D Offline
                                DJMarc75
                                #405
                                keine Nacherzählungen sonder auch jetzt wieder zeigen:
                                iob diag
                                Lehrling seit 1975 !!!
                                  bot1000
                                  #406
                                  @apollon77
                                  System upgedatet
                                  Und dann "iob fix" nochmal ausgeführt. Object file immer noch so groß:
                                  iob fix Ausgabe:
                                  library: loaded
                                  Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                                  Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                                  Hit:3 https://deb.nodesource.com/node_16.x bullseye InRelease
                                  Get:4 https://repos.influxdata.com/debian stable InRelease [6,892 B]
                                  Get:5 https://packages.grafana.com/oss/deb stable InRelease [5,984 B]
                                  Err:4 https://repos.influxdata.com/debian stable InRelease
                                    The following signatures couldn't be verified because the public key is not av        ailable: NO_PUBKEY D8FF8E1F7DF8B07E
                                  Err:5 https://packages.grafana.com/oss/deb stable InRelease
                                    The following signatures couldn't be verified because the public key is not av        ailable: NO_PUBKEY 9E439B102CF3C0C6
                                  Fetched 6,892 B in 4s (1,829 B/s)
                                  Reading package lists... Done
                                  W: An error occurred during the signature verification. The repository is not up        dated and the previous index files will be used. GPG error: https://repos.influx        data.com/debian stable InRelease: The following signatures couldn't be verified        because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                                  W: An error occurred during the signature verification. The repository is not up        dated and the previous index files will be used. GPG error: https://packages.gra        fana.com/oss/deb stable InRelease: The following signatures couldn't be verified        because the public key is not available: NO_PUBKEY 9E439B102CF3C0C6
                                  W: Failed to fetch https://packages.grafana.com/oss/deb/dists/stable/InRelease        The following signatures couldn't be verified because the public key is not avai        lable: NO_PUBKEY 9E439B102CF3C0C6
                                  W: Failed to fetch https://repos.influxdata.com/debian/dists/stable/InRelease  T        he following signatures couldn't be verified because the public key is not avail        able: NO_PUBKEY D8FF8E1F7DF8B07E
                                  W: Some index files failed to download. They have been ignored, or old ones used        instead.
                                  Installed gcc-c++
                                  Done.
                                  Cannot compress objects.jsonl: Error: Failed to lock DB file "/opt/iobroker/iobr        oker-data/objects.jsonl"!
                                      at JsonlDB.open (/home/iobroker/.npm/_npx/36bee06d4228a674/node_modules/@alc        alzone/jsonl-db/build/lib/db.js:185:19)
                                      at async compressDB (/home/iobroker/.npm/_npx/36bee06d4228a674/node_modules/        @iobroker/jsonltool/index.js:37:9)
                                      at async main (/home/iobroker/.npm/_npx/36bee06d4228a674/node_modules/@iobro        ker/jsonltool/index.js:93:17)
                                  Compressed 1 JSONL files. Done
                                  Autostart enabled!
                                  iob diag Ausgabe "Summary":
                                                       v.2023-04-16
                                  Kernel:                 6.1.21-v7+
                                  User-ID:                1000
                                  X-Server:               false
                                  Nodejs-Installation:    /usr/bin/nodejs         v16.20.0
                                                          /usr/bin/npm            8.19.4
                                                          /usr/bin/npx            8.19.4
                                  MEMORY:
                                  Mem:            921M        213M        101M        0.0K        606M        684M
                                  Swap:            99M         32M         67M
                                  Total:          1.0G        245M        169M
                                                          admin                   6.2.22
                                  Objects:                1
                                  States:                 1
                                  • B bot1000
                                    @apollon77
                                    System upgedatet
                                    iob fix Ausgabe:
                                    library: loaded
                                    Installed gcc-c++
                                    Done.
                                    Autostart enabled!
                                                         v.2023-04-16
                                    Kernel:                 6.1.21-v7+
                                    User-ID:                1000
                                    X-Server:               false
                                                            /usr/bin/npm            8.19.4
                                                            /usr/bin/npx            8.19.4
                                    MEMORY:
                                    Swap:            99M         32M         67M
                                                            admin                   6.2.22
                                    Objects:                1
                                    States:                 1
                                    bot1000
                                    #407
                                    Jemand noch ne Idee?
                                    • B bot1000
                                      DJMarc75D Offline
                                      DJMarc75D Offline
                                      DJMarc75
                                      #408
                                      ja, wie wäre es wenn Du tatsächlich Deine Installation auf den aktuellen Stand bringen würdest ?
                                      Also Node auf die empfohlene Version bringen.
                                      https://forum.iobroker.net/topic/64032/update-nodejs-best-practise-supported-16-und-18
                                      • B bot1000
                                        @crunchip
                                        crunchipC Abwesend
                                        crunchipC Abwesend
                                        #409
                                        @bot1000 dann probier spasseshalber mal mit 60000
                                        Ausserdem musst du deine keys für grafana und influx anpassen
                                          bot1000
                                          #410
                                          @crunchip
                                          Kurzen Tipp wo ich weitere Infos bekomme wie das funktioniert?
