  4. Server Cannot start inMem-objects on port 9001
429 Beiträge 40 Kommentatoren 132.6k Aufrufe 39 Beobachtet
    Tungild
    #389
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Model           : Raspberry Pi 4 Model B Rev 1.4
    Architecture    : armv7l
    Docker          : false
    Virtualization  : none
    Distributor ID: Raspbian
    Description:    Raspbian GNU/Linux 10 (buster)
    Release:        10
    Codename:       buster
    PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
    NAME="Raspbian GNU/Linux"
    VERSION_ID="10"
    VERSION="10 (buster)"
    VERSION_CODENAME=buster
    ID=raspbian
    ID_LIKE=debian
    HOME_URL="http://www.raspbian.org/"
    SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
    BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
    Systemuptime and Load:
     18:30:28 up  1:21,  1 user,  load average: 1.01, 1.08, 0.98
    CPU threads: 4
    Raspberry only:
    throttled=0x0
    Other values than 0x0 hint to temperature/voltage problems
    temp=74.0'C
    volt=0.8700V
    *** Time and Time Zones ***
                   Local time: Fri 2023-04-28 18:30:28 CEST
               Universal time: Fri 2023-04-28 16:30:28 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:           7.9G        196M        6.3G        8.0M        1.4G        7.4G
    Swap:           99M          0B         99M
    Total:         8.0G        196M        6.4G
             7898 M total memory
              198 M used memory
             1256 M active memory
              258 M inactive memory
             6253 M free memory
              115 M buffer memory
             1331 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FILESYSTEM ***
    /dev/root      ext4       59G  5.2G   51G  10% /
    devtmpfs       devtmpfs  3.7G     0  3.7G   0% /dev
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     3.9G  8.4M  3.9G   1% /run
    tmpfs          tmpfs     3.9G     0  3.9G   0% /sys/fs/cgroup
    /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
    tmpfs          tmpfs     790M     0  790M   0% /run/user/1000
    [Fri Apr 28 17:09:06 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:BE:A6:4B vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=9fa8c098-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
    [Fri Apr 28 17:09:07 2023] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
    [Fri Apr 28 17:09:07 2023] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
    [Fri Apr 28 17:09:07 2023] EXT4-fs (mmcblk0p2): recovery complete
    [Fri Apr 28 17:09:07 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [Fri Apr 28 17:09:07 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Fri Apr 28 17:09:09 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    TARGET        SOURCE         FSTYPE OPTIONS
    /             /dev/mmcblk0p2 ext4   rw,noatime
    |-/sys/fs/bpf none           bpf    rw,nosuid,nodev,noexec,relatime,mode=700
    `-/boot       /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    307M    /var/
    109M    /var/cache
    104M    /var/cache/apt
    92M     /var/lib
    69M     /var/lib/apt/lists
    Archived and active journals take up 8.0M in the file system.
    /opt/iobroker/backups:
    312M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.7G    /opt/iobroker/iobroker-data/
    147M    /opt/iobroker/iobroker-data/files
    97M     /opt/iobroker/iobroker-data/backup-objects
    42M     /opt/iobroker/iobroker-data/files/vis
    35M     /opt/iobroker/iobroker-data/files/vis/widgets
    1.5G    /opt/iobroker/iobroker-data/objects.jsonl
    16M     /opt/iobroker/iobroker-data/files/vis.0/IMG/Grundriss 1 EG.jpg
    12M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.ea6ad656.chunk.js.map
    6.4M    /opt/iobroker/iobroker-data/objects.json.migrated
    6.4M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v16.15.1
    /usr/bin/node           v16.15.1
    /usr/bin/npm            8.13.1
    /usr/bin/npx            8.13.1
    nodejs:
      Installed: 16.15.1-deb-1nodesource1
      Candidate: 16.20.0-deb-1nodesource1
      Version table:
         16.20.0-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
     *** 16.15.1-deb-1nodesource1 100
         10.24.0~dfsg-1~deb10u3 500
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
    Core adapters versions
    js-controller:  4.0.23
    admin:          6.1.9
    javascript:     5.7.0
    Adapters from github:   0
    Adapter State
    ioBroker-Repositories
    Installed ioBroker-Instances
    Objects and States
    Objects:        1
    States:         1
    Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
    Hit:2 https://deb.nodesource.com/node_16.x buster InRelease
    Hit:3 http://archive.raspberrypi.org/debian buster InRelease
    Reading package lists...
    Pending Updates: 142
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15294      560/sshd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          15296      560/sshd
    udp        0      0 0.0.0.0:34139           0.0.0.0:*                           108        14057      387/avahi-daemon: r
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14989      552/dhcpcd
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14055      387/avahi-daemon: r
    udp6       0      0 :::60976                :::*                                108        14058      387/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        14056      387/avahi-daemon: r
    2023-04-28 18:30:10.471  - info: host.raspberrypi4-iob ip addresses: 192.168.188.44 fe80::4f78:66f9:8f3d:2aca
    2023-04-28 18:30:40.494  - error: host.raspberrypi4-iob No connection to databases possible, restart
    2023-04-28 18:30:40.509  - info: host.raspberrypi4-iob iobroker _restart
    2023-04-28 18:30:46.435  - info: host.raspberrypi4-iob iobroker.js-controller version 4.0.23 js-controller starting
    2023-04-28 18:30:46.443  - info: host.raspberrypi4-iob Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
    2023-04-28 18:30:46.444  - info: host.raspberrypi4-iob hostname: raspberrypi4-iob, node: v16.15.1
    2023-04-28 18:30:46.445  - info: host.raspberrypi4-iob ip addresses: 192.168.188.44 fe80::4f78:66f9:8f3d:2aca
    2023-04-28 18:31:16.477  - error: host.raspberrypi4-iob No connection to databases possible, restart
    2023-04-28 18:31:16.499  - info: host.raspberrypi4-iob iobroker _restart
    2023-04-28 18:31:22.410  - info: host.raspberrypi4-iob iobroker.js-controller version 4.0.23 js-controller starting
    2023-04-28 18:31:22.417  - info: host.raspberrypi4-iob Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
    2023-04-28 18:31:22.418  - info: host.raspberrypi4-iob hostname: raspberrypi4-iob, node: v16.15.1
    2023-04-28 18:31:22.419  - info: host.raspberrypi4-iob ip addresses: 192.168.188.44 fe80::4f78:66f9:8f3d:2aca
    2023-04-28 18:31:52.441  - error: host.raspberrypi4-iob No connection to databases possible, restart
    2023-04-28 18:31:52.455  - info: host.raspberrypi4-iob iobroker _restart
    2023-04-28 18:31:58.463  - info: host.raspberrypi4-iob iobroker.js-controller version 4.0.23 js-controller starting
    2023-04-28 18:31:58.470  - info: host.raspberrypi4-iob Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
    2023-04-28 18:31:58.471  - info: host.raspberrypi4-iob hostname: raspberrypi4-iob, node: v16.15.1
    2023-04-28 18:31:58.472  - info: host.raspberrypi4-iob ip addresses: 192.168.188.44 fe80::4f78:66f9:8f3d:2aca
    2023-04-28 18:32:28.520  - error: host.raspberrypi4-iob No connection to databases possible, restart
    2023-04-28 18:32:28.534  - info: host.raspberrypi4-iob iobroker _restart
    2023-04-28 18:32:34.447  - info: host.raspberrypi4-iob iobroker.js-controller version 4.0.23 js-controller starting
    2023-04-28 18:32:34.454  - info: host.raspberrypi4-iob Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
    2023-04-28 18:32:34.456  - info: host.raspberrypi4-iob hostname: raspberrypi4-iob, node: v16.15.1
    2023-04-28 18:32:34.457  - info: host.raspberrypi4-iob ip addresses: 192.168.188.44 fe80::4f78:66f9:8f3d:2aca
    iob diag has finished.
                         v.2023-04-16
    Operatingsystem:        Raspbian GNU/Linux 10 (buster)
    Kernel:                 5.10.63-v7l+
    Installation:           Native
    User-ID:                1000
    X-Server:               false
    Pending OS-Updates:     142
    Pending iob updates:    0
    Nodejs-Installation:    /usr/bin/nodejs         v16.15.1
                            /usr/bin/npm            8.13.1
                            /usr/bin/npx            8.13.1
    Recommended versions are nodejs 18.x.y and npm 9.x.y
    MEMORY:
    Mem:           7.9G         78M        6.4G        8.0M        1.4G        7.6G
    Swap:           99M          0B         99M
    Total:         8.0G         78M        6.5G
    Active iob-Instances:   0
    ioBroker Core:          js-controller           4.0.23
                            admin                   6.1.9
    ioBroker Status:        Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
    Objects:                1
    States:                 1
    Size of iob-Database:
    592K    /opt/iobroker/iobroker-data/states.jsonl
    500K    /opt/iobroker/iobroker-data/states.json.migrated
    500K    /opt/iobroker/iobroker-data/states.json.bak.migrated
    0       /opt/iobroker/iobroker-data/states.json.broken
    Ergebnisse von
     iob diagt
    crunchipC Thomas BraunT 2 Antworten Letzte Antwort
    • T Tungild
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Docker          : false
      Release:        10
      Codename:       buster
      VERSION_ID="10"
      ID=raspbian
      ID_LIKE=debian
      CPU threads: 4
      Raspberry only:
      throttled=0x0
      temp=74.0'C
      volt=0.8700V
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      pi
      /home/pi
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:           99M          0B         99M
               7898 M total memory
                198 M used memory
               6253 M free memory
                115 M buffer memory
               1331 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /var:
      307M    /var/
      109M    /var/cache
      104M    /var/cache/apt
      92M     /var/lib
      /usr/bin/npm            8.13.1
      /usr/bin/npx            8.13.1
      nodejs:
        Version table:
      ioBroker Status
      admin:          6.1.9
      javascript:     5.7.0
      Adapter State
      Objects and States
      Objects:        1
      States:         1
                           v.2023-04-16
      User-ID:                1000
      X-Server:               false
                              /usr/bin/npm            8.13.1
                              /usr/bin/npx            8.13.1
      MEMORY:
      Swap:           99M          0B         99M
                              admin                   6.1.9
      Objects:                1
      States:                 1
      Ergebnisse von
       iob diagt
      crunchipC Abwesend
      crunchipC Abwesend
      #390
      @tungild da mal nachgesehen
      https://forum.iobroker.net/topic/43325/mini-howto-cannot-find-view-system-for-search-host?_=1682692860885
      bzw
      https://forum.iobroker.net/post/796544
      • T Tungild
        Skript v.2023-04-16
        *** BASE SYSTEM ***
        Docker          : false
        Release:        10
        Codename:       buster
        VERSION_ID="10"
        ID=raspbian
        ID_LIKE=debian
        CPU threads: 4
        Raspberry only:
        throttled=0x0
        temp=74.0'C
        volt=0.8700V
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        pi
        /home/pi
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:           99M          0B         99M
                 7898 M total memory
                  198 M used memory
                 6253 M free memory
                  115 M buffer memory
                 1331 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        Raspberry only:
        oom events: 0
        *** FILESYSTEM ***
        /var:
        307M    /var/
        109M    /var/cache
        104M    /var/cache/apt
        92M     /var/lib
        /usr/bin/npm            8.13.1
        /usr/bin/npx            8.13.1
        nodejs:
          Version table:
        ioBroker Status
        admin:          6.1.9
        javascript:     5.7.0
        Adapter State
        Objects and States
        Objects:        1
        States:         1
                             v.2023-04-16
        User-ID:                1000
        X-Server:               false
                                /usr/bin/npm            8.13.1
                                /usr/bin/npx            8.13.1
        MEMORY:
        Swap:           99M          0B         99M
                                admin                   6.1.9
        Objects:                1
        States:                 1
        Ergebnisse von
         iob diagt
        #391
        @tungild
        Da würde ich zuerst Mal ran und das ganze System auf eine aktuelle Basis setzen. Dann das Bullseye-Release draufwerfen.
        Die Kiste wird auch etwas zu warm
        temp=74.0'C
        Und die load ist mit 1 auch etwas hoch, der iobroker läuft ja nicht mal.
        Was treibt da also die Auslastung so weit nach oben?
        Die Datenbank ist auch zu fett:
        Hast du den Fixer schonmal ausgeführt?
        • T Tungild
          ich habe seit heute dasselbe Problem. Habe auf meinen Raspberry nur iobroker laufen und das letzte Mal etwas vor ca. einem halben Jahr gemacht. Lief alles ohne Probleme.
          Wollte eigentlich nur über die Weboberfläche für meine Automation etwas umstellen und gesehen das es neue Updates gibt.
          Hab mich dann über Putty eingeloggt und „iobroker stop“ ausgeführt. Das war der Anfang vom Ende.
          Muss gestehen das ich ein absoluter Anfänger bin und schon über zwei Stunden den Forumseintrag hier lese ohne, dass ich ein Erfolg verzeichnen kann.
          pi@raspberrypi4-iob:~ $ iobroker status
          No connection to databases possible ...
          pi@raspberrypi4-iob:~ $ iobroker stop
          pi@raspberrypi4-iob:~ $ iobroker start
          pi@raspberrypi4-iob:~ $ iob start admin
          No connection to databases possibleServer Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
          Iobroker Fix ohne erfolg.
          Würde mich über Hilfe sehr freuen.
          #392
          @tungild iob fix ohne Erfolg? Zeig mal die Ausgaben bitte.
          • apollon77A apollon77
            Tungild
            #393
            @apollon77 entschuldigt bitte meine späte Antwort.
            Habe heute Nacht den Fixer nochmals laufen lassen, scheinbar diesmal mit Erfolg. Gestern hatte ich dies schon mehrfach ohne Erfolg versucht.
            Die Weboberfläche läuft wieder und kann alles wie gewohnt benutzen. Wieso es nun auf einmal wieder geht, kann ich nicht sagen.
            pi@raspberrypi4-iob:~ $ iobroker fix
            library: loaded
            Library version=2022-12-09
                Welcome to the ioBroker installation fixer!
                Script version: 2023-04-02
                You might need to enter your password a couple of times.
                Installing prerequisites (1/5)
            Holen:1 http://raspbian.raspberrypi.org/raspbian buster InRelease [15,0 kB]
            OK:2 http://archive.raspberrypi.org/debian buster InRelease
            OK:3 https://deb.nodesource.com/node_16.x buster InRelease
            Es wurden 15,0 kB in 1 s geholt (14,1 kB/s).
            Installed gcc-c++
                Checking ioBroker user and directory permissions (2/5)
                Check and cleanup npm temporary directories (3/5)
            Done.
                Database maintenance (4/5)
            Checking for uncompressed JSONL databases... This might take a while!
            Compressing /opt/iobroker/iobroker-data/states.jsonl
            Compressing /opt/iobroker/iobroker-data/objects.jsonl
            Compressed 2 JSONL files. Done
                Checking autostart (5/5)
            Enabling autostart...
            Autostart enabled!
                Your installation was fixed successfully
                Run iobroker start to start ioBroker again!
            pi@raspberrypi4-iob:~ $ iobroker start admin
            Objects type: jsonl
            States  type: jsonl
            Ich werde nun mal versuchen alles auf den neusten Stand zu bringen und hoffe das dann weiterhin alles läuft.
            Danke euch schonmal für eure Beiträge.
            Werde nochmals berichten.
            • T Tungild
              library: loaded
              Installed gcc-c++
              Done.
              Autostart enabled!
              Objects type: jsonl
              States  type: jsonl
              crunchipC Abwesend
              crunchipC Abwesend
              #394
              @tungild sagte in Server Cannot start inMem-objects on port 9001:
              wahrscheinlich
              @thomas-braun sagte in Server Cannot start inMem-objects on port 9001:
              diese hat der fixer komprimiert
                Tungild
                #395
                So, hoffe ich habe nun alles auf dem neusten Stand. Aktuell funktioniert alles.
                                     v.2023-04-16
                User-ID:                1000
                X-Server:               false
                Pending OS-Updates:     0
                Nodejs-Installation:    /usr/bin/nodejs         v18.16.0
                                        /usr/bin/node           v18.16.0
                                        /usr/bin/npm            9.5.1
                                        /usr/bin/npx            9.5.1
                MEMORY:
                Mem:           7.9G        686M        4.3G         16M        2.9G        6.9G
                Swap:           99M          0B         99M
                Total:         8.0G        686M        4.4G
                Active iob-Instances:   11
                Active repo(s): beta
                ioBroker Core:          js-controller           4.0.24
                                        admin                   6.4.3
                Objects type: jsonl
                States  type: jsonl
                + system.adapter.admin.0                  : admin                 : raspberrypi4-iob                         -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                + system.adapter.web.0                    : web                   : raspberrypi4-iob                         -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                Objects:                2058
                States:                 1693
                9.7M    /opt/iobroker/iobroker-data/objects.jsonl
                4.7M    /opt/iobroker/iobroker-data/states.jsonl
                Besten Dank nochmals 😀
                • T Tungild
                                       v.2023-04-16
                  User-ID:                1000
                  X-Server:               false
                                          /usr/bin/npm            9.5.1
                                          /usr/bin/npx            9.5.1
                  MEMORY:
                  Swap:           99M          0B         99M
                                          admin                   6.4.3
                  Objects type: jsonl
                  States  type: jsonl
                  Objects:                2058
                  States:                 1693
                  GlasfaserG Offline
                  GlasfaserG Offline
                  #396
                  Dir ist schon bekannt , das du dein Repo auf BETA hast bzw. auch ein Beta Tester bist !?
                  EDIT :
                  ich denke mal unbewußt , denn du hast zuvor diese Versionen gehabt :
                  admin:          6.1.9
                  javascript:     5.7.0
                  und
                  du hast noch Buster , Bullseye ist der aktuelle Stand !
                  U 1 Antwort Letzte Antwort
                  • GlasfaserG Glasfaser
                    EDIT :
                    admin:          6.1.9
                    javascript:     5.7.0
                    und
                    U Offline
                    U Offline
                    UncleB
                    #397
                    Guten Abend,
                    Gleiches Problem auch bei mir..
                    Der Fix hat nix gebracht.
                    iob diag spuckt folgendes aus:
                    Skript v.2023-04-16
                    *** BASE SYSTEM ***
                    Model           : Raspberry Pi 3 Model B Rev 1.2
                    Architecture    : aarch64
                    Docker          : false
                    Distributor ID: Debian
                    Description:    Debian GNU/Linux 11 (bullseye)
                    Release:        11
                    Codename:       bullseye
                    PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
                    NAME="Debian GNU/Linux"
                    VERSION_ID="11"
                    VERSION="11 (bullseye)"
                    VERSION_CODENAME=bullseye
                    ID=debian
                    HOME_URL="https://www.debian.org/"
                    SUPPORT_URL="https://www.debian.org/support"
                    BUG_REPORT_URL="https://bugs.debian.org/"
                     23:12:09 up 1 min,  1 user,  load average: 1.24, 0.46, 0.17
                    CPU threads: 4
                    Raspberry only:
                    throttled=0x0
                    temp=71.4'C
                    volt=1.3438V
                                   Local time: Fri 2023-05-12 23:12:10 CEST
                               Universal time: Fri 2023-05-12 21:12:10 UTC
                                     RTC time: n/a
                                  NTP service: active
                              RTC in local TZ: no
                    pi
                    /home/pi
                    pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                    X-Server:       false
                    Desktop:
                    Terminal:       tty
                    Boot Target:    multi-user.target
                    *** MEMORY ***
                    Mem:            909M        162M        156M        0.0K        590M        691M
                    Swap:            99M          0B         99M
                    Total:          1.0G        162M        256M
                              909 M total memory
                              162 M used memory
                              215 M active memory
                              458 M inactive memory
                              156 M free memory
                               19 M buffer memory
                              570 M swap cache
                               99 M total swap
                                0 M used swap
                               99 M free swap
                    Raspberry only:
                    oom events: 0
                    *** FILESYSTEM ***
                    /dev/root      ext4       15G  4.8G  8.9G  36% /
                    devtmpfs       devtmpfs  325M     0  325M   0% /dev
                    tmpfs          tmpfs     455M     0  455M   0% /dev/shm
                    tmpfs          tmpfs     182M  968K  181M   1% /run
                    /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
                    tmpfs          tmpfs      91M     0   91M   0% /run/user/1000
                    [Fri May 12 23:10:54 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=Composite-1:720x480@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=0c797088-02 rootfstype=ext4 fsck.repair=yes rootwait
                    [Fri May 12 23:10:57 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                    [Fri May 12 23:10:57 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                    [Fri May 12 23:11:00 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                    /       /dev/mmcblk0p2 ext4   rw,noatime,commit=600
                    /var:
                    993M    /var/
                    536M    /var/log
                    521M    /var/log/journal/556ce5c3a8d54c0c89d73703db3b1f8c
                    209M    /var/cache
                    Archived and active journals take up 520.1M in the file system.
                    33M     /opt/iobroker/backups/
                    704M    /opt/iobroker/iobroker-data/
                    169M    /opt/iobroker/iobroker-data/files
                    64M     /opt/iobroker/iobroker-data/backup-objects
                    51M     /opt/iobroker/iobroker-data/files/javascript.admin
                    48M     /opt/iobroker/iobroker-data/files/telegram.admin
                    467M    /opt/iobroker/iobroker-data/objects.jsonl
                    15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
                    7.2M    /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js
                    6.9M    /opt/iobroker/iobroker-data/files/telegram.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.8fdf8cb7.chunk.js.map
                    6.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.de0231c9.chunk.js.map
                    /usr/bin/nodejs         v16.20.0
                    /usr/bin/node           v16.20.0
                    /usr/bin/npm            8.19.4
                    /usr/bin/npx            8.19.4
                    nodejs:
                      Installed: 16.20.0-deb-1nodesource1
                      Version table:
                     *** 16.20.0-deb-1nodesource1 500
                            500 https://deb.nodesource.com/node_16.x bullseye/main arm64 Packages
                         12.22.12~dfsg-1~deb11u4 500
                            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                         12.22.12~dfsg-1~deb11u3 500
                            500 http://deb.debian.org/debian bullseye/main arm64 Packages
                    ioBroker Status
                    admin:          6.3.5
                    javascript:     6.1.4
                    Adapters from github:   1
                    Adapter State
                    Objects and States
                    Objects:        1
                    States:         1
                    Hit:1 http://deb.debian.org/debian bullseye InRelease
                    Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
                    Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
                    Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                    Hit:5 https://deb.nodesource.com/node_16.x bullseye InRelease
                    Pending Updates: 0
                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14495      523/sshd: /usr/sbin
                    tcp6       0      0 :::22                   :::*                    LISTEN      0          14497      523/sshd: /usr/sbin
                    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          1794       623/dhcpcd
                    udp        0      0 0.0.0.0:51820           0.0.0.0:*                           0          1886       -
                    udp        0      0 0.0.0.0:41124           0.0.0.0:*                           108        14448      368/avahi-daemon: r
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14446      368/avahi-daemon: r
                    udp6       0      0 :::51820                :::*                                0          1887       -
                    udp6       0      0 :::5353                 :::*                                108        14447      368/avahi-daemon: r
                    udp6       0      0 :::49432                :::*                                108        14449      368/avahi-daemon: r
                    2023-05-12 23:14:20.573  - info: host.raspberrypi ip addresses: 192.168.30.6 fe80::6b2f:cbb4:2470:70a3 10.110.183.1
                    2023-05-12 23:14:50.621  - error: host.raspberrypi No connection to databases possible, restart
                    2023-05-12 23:14:50.656  - info: host.raspberrypi iobroker _restart
                    2023-05-12 23:14:57.929  - info: host.raspberrypi iobroker.js-controller version 4.0.23 js-controller starting
                    2023-05-12 23:14:57.944  - info: host.raspberrypi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                    2023-05-12 23:14:57.946  - info: host.raspberrypi hostname: raspberrypi, node: v16.20.0
                    2023-05-12 23:14:57.948  - info: host.raspberrypi ip addresses: 192.168.30.6 fe80::6b2f:cbb4:2470:70a3 10.110.183.1
                    2023-05-12 23:15:27.989  - error: host.raspberrypi No connection to databases possible, restart
                    2023-05-12 23:15:28.019  - info: host.raspberrypi iobroker _restart
                    2023-05-12 23:15:35.553  - info: host.raspberrypi iobroker.js-controller version 4.0.23 js-controller starting
                    2023-05-12 23:15:35.571  - info: host.raspberrypi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                    2023-05-12 23:15:35.574  - info: host.raspberrypi hostname: raspberrypi, node: v16.20.0
                    2023-05-12 23:15:35.577  - info: host.raspberrypi ip addresses: 192.168.30.6 fe80::6b2f:cbb4:2470:70a3 10.110.183.1
                    2023-05-12 23:15:37.722  - error: host.raspberrypi-Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
                    2023-05-12 23:15:44.388  - info: host.raspberrypi iobroker.js-controller version 4.0.23 js-controller starting
                    2023-05-12 23:15:44.405  - info: host.raspberrypi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                    2023-05-12 23:15:44.408  - info: host.raspberrypi hostname: raspberrypi, node: v16.20.0
                    2023-05-12 23:15:44.411  - info: host.raspberrypi ip addresses: 192.168.30.6 fe80::6b2f:cbb4:2470:70a3 10.110.183.1
                    2023-05-12 23:15:46.561  - error: host.raspberrypi-Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
                    2023-05-12 23:15:53.085  - info: host.raspberrypi iobroker.js-controller version 4.0.23 js-controller starting
                    2023-05-12 23:15:53.101  - info: host.raspberrypi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                    2023-05-12 23:15:53.103  - info: host.raspberrypi hostname: raspberrypi, node: v16.20.0
                    2023-05-12 23:15:53.106  - info: host.raspberrypi ip addresses: 192.168.30.6 fe80::6b2f:cbb4:2470:70a3 10.110.183.1
                    2023-05-12 23:16:23.156  - error: host.raspberrypi No connection to databases possible, restart
                    2023-05-12 23:16:23.213  - info: host.raspberrypi iobroker _restart
                    Press any key for a summary
                    Woran kanns liegen?
                    • U UncleB
                      Guten Abend,
                      Skript v.2023-04-16
                      *** BASE SYSTEM ***
                      Docker          : false
                      Release:        11
                      Codename:       bullseye
                      VERSION_ID="11"
                      ID=debian
                      CPU threads: 4
                      Raspberry only:
                      throttled=0x0
                      temp=71.4'C
                      volt=1.3438V
                                       RTC time: n/a
                                    NTP service: active
                                RTC in local TZ: no
                      pi
                      /home/pi
                      X-Server:       false
                      Desktop:
                      Terminal:       tty
                      *** MEMORY ***
                      Swap:            99M          0B         99M
                                909 M total memory
                                162 M used memory
                                215 M active memory
                                156 M free memory
                                 19 M buffer memory
                                570 M swap cache
                                 99 M total swap
                                  0 M used swap
                                 99 M free swap
                      Raspberry only:
                      oom events: 0
                      *** FILESYSTEM ***
                      /var:
                      993M    /var/
                      536M    /var/log
                      209M    /var/cache
                      /usr/bin/npm            8.19.4
                      /usr/bin/npx            8.19.4
                      nodejs:
                        Version table:
                      ioBroker Status
                      admin:          6.3.5
                      javascript:     6.1.4
                      Adapter State
                      Objects and States
                      Objects:        1
                      States:         1
                      Pending Updates: 0
                      Woran kanns liegen?
                      #398
                      @uncleb Und "iob fix" hat echt nichts geholfen? Bitte versuch nochmal und poste noch die Ausgabe von fix und diag danach. Wenn dein "Objects.jsonl" so gross bleibt hast Du dir einiges an Objekten angesammelt
                        bot1000
                        #399
                        ich habe den gleichen Fehler. Zuerst lief alles wie gewünscht. Doch nach einiger Zeit (Monate? Hab es nicht konstant geprüft) konnte ich nicht mehr auf das Webinterface von iobroker zugreifen. Jetzt untersuche ich es genauer und bekomme bei "iob status" den Fehler:
                        Nach "iob fix" und "reboot" funktioniert es immer noch nicht
                        Die "iob diag" gibt folgendes aus:
                                             v.2023-04-16
                        Operatingsystem:        Raspbian GNU/Linux 11 (bullseye)
                        Kernel:                 5.15.68-v7+
                        User-ID:                1000
                        X-Server:               false
                        Pending OS-Updates:     105
                        Nodejs-Installation:    /usr/bin/nodejs         v16.17.0
                                                /usr/bin/node           v16.17.0
                                                /usr/bin/npm            8.15.0
                                                /usr/bin/npx            8.15.0
                        MEMORY:
                        Mem:            922M        234M         74M        0.0K        613M        632M
                        Swap:            99M        1.0M         98M
                        Total:          1.0G        235M        173M
                                                admin                   6.2.22
                        ioBroker Status:        No connection to databases possible ...
                        Objects:                1
                        States:                 1
                        628M    /opt/iobroker/iobroker-data/objects.jsonl
                        88K     /opt/iobroker/iobroker-data/states.jsonl
                        Jemand eine Idee was ich noch machen kann? Wollte nicht wirklich den ganzen Rasperry neu aufsetzen.
                        Ich dachte erst durch mein dauerndest Loggen von Messwerten in meiner HomeAutomation wäre der Speicher vollgelaufen. Das scheint aber nicht zu sein:
                        df
                        Filesystem     1K-blocks    Used Available Use% Mounted on
                        /dev/root       14563544 5695448   8243064  41% /
                        devtmpfs          340548       0    340548   0% /dev
                        tmpfs             472132       0    472132   0% /dev/shm
                        tmpfs             188856     988    187868   1% /run
                        tmpfs               5120       4      5116   1% /run/lock
                        /dev/mmcblk0p1    261108   50962    210146  20% /boo
                        crunchipC apollon77A 2 Antworten Letzte Antwort
                        • B bot1000
                                               v.2023-04-16
                          Kernel:                 5.15.68-v7+
                          User-ID:                1000
                          X-Server:               false
                                                  /usr/bin/npm            8.15.0
                                                  /usr/bin/npx            8.15.0
                          MEMORY:
                          Swap:            99M        1.0M         98M
                                                  admin                   6.2.22
                          Objects:                1
                          States:                 1
                          df
                          crunchipC Abwesend
                          crunchipC Abwesend
                          #400
                          @bot1000 sagte in Server Cannot start inMem-objects on port 9001:
                          https://forum.iobroker.net/post/985102
                          • B bot1000
                                                 v.2023-04-16
                            Kernel:                 5.15.68-v7+
                            User-ID:                1000
                            X-Server:               false
                                                    /usr/bin/npm            8.15.0
                                                    /usr/bin/npx            8.15.0
                            MEMORY:
                            Swap:            99M        1.0M         98M
                                                    admin                   6.2.22
                            Objects:                1
                            States:                 1
                            df
                            #401
                            @bot1000 Die Ausgabe von iob fix würde mich echt interessieren bei so einem großen objects file ... lass nochmal fixlaufen und schon ob das kleiner wird.
                            • Thomas BraunT Online
                              #402
                              @bot1000
                              System aktuell halten.
                              Und was ist /boo für ein mountpunkt?
                                @bot1000
                                bot1000
                                #403
                                System aktualisiert -> Fehler ist gleich
                                boo hatte ich abgeschnittenb es ist "boot"
                                  bot1000
                                  #404
                                  @crunchip
                                  Timeout beide auf 30000 gesetzt. Immer noch der gleiche Fehler
                                  • B bot1000
                                    DJMarc75D Offline
                                    DJMarc75D Offline
                                    DJMarc75
                                    #405
                                    keine Nacherzählungen sonder auch jetzt wieder zeigen:
                                    iob diag
                                    Lehrling seit 1975 !!!
                                      bot1000
                                      #406
                                      @apollon77
                                      System upgedatet
                                      Und dann "iob fix" nochmal ausgeführt. Object file immer noch so groß:
                                      iob fix Ausgabe:
                                      library: loaded
                                      Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                                      Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                                      Hit:3 https://deb.nodesource.com/node_16.x bullseye InRelease
                                      Get:4 https://repos.influxdata.com/debian stable InRelease [6,892 B]
                                      Get:5 https://packages.grafana.com/oss/deb stable InRelease [5,984 B]
                                      Err:4 https://repos.influxdata.com/debian stable InRelease
                                        The following signatures couldn't be verified because the public key is not av        ailable: NO_PUBKEY D8FF8E1F7DF8B07E
                                      Err:5 https://packages.grafana.com/oss/deb stable InRelease
                                        The following signatures couldn't be verified because the public key is not av        ailable: NO_PUBKEY 9E439B102CF3C0C6
                                      Fetched 6,892 B in 4s (1,829 B/s)
                                      Reading package lists... Done
                                      W: An error occurred during the signature verification. The repository is not up        dated and the previous index files will be used. GPG error: https://repos.influx        data.com/debian stable InRelease: The following signatures couldn't be verified        because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                                      W: An error occurred during the signature verification. The repository is not up        dated and the previous index files will be used. GPG error: https://packages.gra        fana.com/oss/deb stable InRelease: The following signatures couldn't be verified        because the public key is not available: NO_PUBKEY 9E439B102CF3C0C6
                                      W: Failed to fetch https://packages.grafana.com/oss/deb/dists/stable/InRelease        The following signatures couldn't be verified because the public key is not avai        lable: NO_PUBKEY 9E439B102CF3C0C6
                                      W: Failed to fetch https://repos.influxdata.com/debian/dists/stable/InRelease  T        he following signatures couldn't be verified because the public key is not avail        able: NO_PUBKEY D8FF8E1F7DF8B07E
                                      W: Some index files failed to download. They have been ignored, or old ones used        instead.
                                      Installed gcc-c++
                                      Done.
                                      Cannot compress objects.jsonl: Error: Failed to lock DB file "/opt/iobroker/iobr        oker-data/objects.jsonl"!
                                          at JsonlDB.open (/home/iobroker/.npm/_npx/36bee06d4228a674/node_modules/@alc        alzone/jsonl-db/build/lib/db.js:185:19)
                                          at async compressDB (/home/iobroker/.npm/_npx/36bee06d4228a674/node_modules/        @iobroker/jsonltool/index.js:37:9)
                                          at async main (/home/iobroker/.npm/_npx/36bee06d4228a674/node_modules/@iobro        ker/jsonltool/index.js:93:17)
                                      Compressed 1 JSONL files. Done
                                      Autostart enabled!
                                      iob diag Ausgabe "Summary":
                                                           v.2023-04-16
                                      Kernel:                 6.1.21-v7+
                                      User-ID:                1000
                                      X-Server:               false
                                      Nodejs-Installation:    /usr/bin/nodejs         v16.20.0
                                                              /usr/bin/npm            8.19.4
                                                              /usr/bin/npx            8.19.4
                                      MEMORY:
                                      Mem:            921M        213M        101M        0.0K        606M        684M
                                      Swap:            99M         32M         67M
                                      Total:          1.0G        245M        169M
                                                              admin                   6.2.22
                                      Objects:                1
                                      States:                 1
                                      • B bot1000
                                        @apollon77
                                        System upgedatet
                                        iob fix Ausgabe:
                                        library: loaded
                                        Installed gcc-c++
                                        Done.
                                        Autostart enabled!
                                                             v.2023-04-16
                                        Kernel:                 6.1.21-v7+
                                        User-ID:                1000
                                        X-Server:               false
        /usr/bin/npm            8.19.4
        /usr/bin/npx            8.19.4
                                        MEMORY:
                                        Swap:            99M         32M         67M
        admin                   6.2.22
                                        Objects:                1
                                        States:                 1
                                        bot1000
                                        #407
                                        Jemand noch ne Idee?
                                        • B bot1000
                                          DJMarc75D Offline
                                          DJMarc75D Offline
                                          DJMarc75
                                          #408
                                          ja, wie wäre es wenn Du tatsächlich Deine Installation auf den aktuellen Stand bringen würdest ?
                                          Also Node auf die empfohlene Version bringen.
                                          https://forum.iobroker.net/topic/64032/update-nodejs-best-practise-supported-16-und-18
