  4. BackitUp NAS Error Speedport Smart 4
    5.5k
91 Beiträge 4 Kommentatoren 10.8k Aufrufe 3 Beobachtet
  • N noidea
    @noidea
    Ok. Ich habe es zumindest so hinbekommen, das ich jetzt das habe:
    user@iobroker:~$ smbclient -L 192.168.2.1 -U speedport
    Password for [WORKGROUP\speedport]:
            Sharename       Type      Comment
            speedport       Disk
            IPC$            IPC       IPC Service (Speedport Smart 4 Typ A File-Server)
    Reconnecting with SMB1 for workgroup listing.
            Server               Comment
            Workgroup            Master
            WORKGROUP            SPEEDPORT
    user@iobroker:~$
    Ich habe dazu in der smb.conf unter Global die Zeile "client min protocol = NT1" hinzugefügt.
    Dann habe ich, euphorisch wie ich bin, nochmal über BackitUp versucht, ob es jetzt klappt.
    Jetzt kommt einen andere Fehlermeldung:
    Started iobroker ...
    [DEBUG] [mount] start with {"mountType":"CIFS","type":"storage","source":"local","mount":"//192.168.2.1","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"WORKGROUP","clientInodes":false,"deleteOldBackup":false,"ownDir":false,"dir":"/SanDisk-USBExtremePro/Backup/Speedport","dirMinimal":"sharename/backupDir","user":"speedport","pass":"****","ignoreErrors":false}
    [DEBUG] [mount] - noserverino option: false
    [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=speedport,password=****,domain=WORKGROUP,rw,file_mode=0777,dir_mode=0777,vers=3.0 //192.168.2.1/SanDisk-USBExtremePro/Backup/Speedport /opt/iobroker/backups"
    [DEBUG] [mount] - first mount attempt with smb option failed. try next mount attempt without smb option ...
    [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=speedport,password=****,domain=WORKGROUP,rw,file_mode=0777,dir_mode=0777 //192.168.2.1/SanDisk-USBExtremePro/Backup/Speedport /opt/iobroker/backups"
    [ERROR] [mount] - [undefined Error: Command failed: sudo mount -t cifs -o username=speedport,password=****,domain=WORKGROUP,rw,file_mode=0777,dir_mode=0777 //192.168.2.1/SanDisk-USBExtremePro/Backup/Speedport /opt/iobroker/backups
    mount error: Server abruptly closed the connection.
    This can happen if the server does not support the SMB version you are trying to use.
    The default SMB version recently changed from SMB1 to SMB2.1 and above. Try mounting with vers=1.0.
    mount error(112): Host is down
    Refer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
    [ERROR] [mount] - Error: Command failed: sudo mount -t cifs -o username=speedport,password=****,domain=WORKGROUP,rw,file_mode=0777,dir_mode=0777 //192.168.2.1/SanDisk-USBExtremePro/Backup/Speedport /opt/iobroker/backups
    Ist das jetzt ein Schritt in die richtige Richtung oder einfach nur ein anderes Problem?
    Thomas BraunT Offline
    @noidea sagte in BackitUp NAS Error Speedport Smart 4:
    smb.conf
    Die /etc/samba/smb.conf hat nix mit dem Server auf dem Router zu tun, das betrifft eine lokal laufenden Samba-Server. Nimm die Einstellung wieder raus, das drückt die Protokoll-Version auf v1, das will niemand mehr.
    Stell mal die smb-Version im Backitup-Adapter auf 3.1.1.
    N 1 Antwort Letzte Antwort
      smb.conf
      N Offline
      N Offline
      noidea
      Das hat leider nichts geändert. Immer noch die selbe Fehlermeldung wie oben beschrieben.
      Hat das vielleicht einen Einfluss:
      root@iobroker:~# sudo mount.cifs --version
      mount.cifs version: 6.14
      • N noidea
        root@iobroker
        Wie oft noch? Lass das bleiben!!!!!!!!!!!!!!!!!
        • N noidea
          @noidea
          Die Kiste spricht angeblich nur SMB v1:
          https://telekomhilft.telekom.de/t5/Geraete-Zubehoer/Unterstuetzt-das-SPEEDPORT-Smart-4-smb-2-oder-smb-3-fuer-die/m-p/5752406#M565773
          Das sollte im Jahre 2023 natürlich überhaupt nicht mehr der Fall sein.
            @noidea
            N Offline
            N Offline
            noidea
            Ja das ist wirlich ärgerlich. Das ist wahrscheinlich der Grund, warum die meisten mit der FritzBox unterwegs sind 🤔
            Was muss ich denn jetzt umstellen, damit die Version SMB1 funktioniert? Wenn ich das in BackitUp einstelle, kommt immer noch dieselbe Fehlermeldung.
            • N noidea
              @noidea
              Dann stell doch mal in der smb.conf wieder v1 ein, ebenso im Backitup-Adapter.
              Wer rechnet denn auch mit smb v1 bei so einem aktuellen Router...
                @noidea
                N Offline
                N Offline
                noidea
                schrieb am zuletzt editiert von noidea
                Also wenn ich in der Config folgendes schreibe:
                client min protocol = SMB1
                Dann bekomme ich folgende Fehlermeldung:
                WARNING: Ignoring invalid value 'SMB1' for parameter 'client min protocol'
                Can't load /etc/samba/smb.conf - run testparm to debug it
                protocol negotiation failed: NT_STATUS_CONNECTION_DISCONNECTED
                user@iobroker:~$
                Wenn ich dann wieder statt SMB1 NT1 da eintrage, dann geht es wieder.
                Wenn ich das dank Google richtig verstanden habe, dann scheint NT1 aber SMB1 zu sein.
                Aber warum klappt es dann immer noch nicht? Oder muss ich in der Config was anderes für SMB1 eintragen?
                • N noidea
                  user@iobroker:~$
                  @noidea
                  NT1 ist ja auch der richtige Parameter.
                    @noidea
                    N Offline
                    N Offline
                    noidea
                    Ok. Das bedeutet, das in der Config jetzt SMB1 drin ist und im BackitUp Adapter auch. Trotzdem kommt immer noch die letzte Fehlermeldung....
                    • N noidea
                      @noidea
                      Welche?
                        @noidea
                        Welche?
                        N Offline
                        N Offline
                        noidea
                        [DEBUG] [mount] start with {"mountType":"CIFS","type":"storage","source":"local","mount":"//192.168.2.1","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"cifsDomain":"WORKGROUP","clientInodes":false,"deleteOldBackup":false,"ownDir":false,"dir":"/SanDisk-USBExtremePro/Backup/Speedport","dirMinimal":"sharename/backupDir","user":"speedport","pass":"****","ignoreErrors":false}
                        [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=speedport,password=****,domain=WORKGROUP,rw,file_mode=0777,dir_mode=0777,vers=1.0 //192.168.2.1/SanDisk-USBExtremePro/Backup/Speedport /opt/iobroker/backups"
                        • N noidea
                          @noidea
                          Keine Ahnung.
                          • N noidea
                            wirklich??
                            klingt anders.
                            Außerdem
                            sagt, dass der Speedport wohl weg ist.
                              wirklich??
                              klingt anders.
                              Außerdem
                              N Offline
                              N Offline
                              noidea
                              SMB1 ist da eingestellt. Ich habe iobroker danach nochmal neugestartet.
                              Der Router ist die ganze Zeit über da. Zumindest kann ich die ganze Zeit drauf zugreifen und Internet ist auch die ganze Zeit da.
                              Deute ich die Fehlermeldung richtig, das versucht wird NICHT mit SMB1 die Verbindung aufzubauen, sondern mit SMB2.1? Liegt das Problem dann nicht eher an meinem System als am Router?
                              • N noidea
                                @noidea
                                Wie sieht das Backup gerade im Log asu?
                                  @noidea
                                  N Offline
                                  N Offline
                                  noidea
                                  Leider genauso wie der letzte Eintrag weiter oben.
                                  • N noidea
                                    @noidea
                                    Wie sieht das Backup gerade JETZT im Log aus?
                                      @noidea
                                      N Offline
                                      N Offline
                                      noidea
                                      Sorry, aber ich weiß nicht genau was du meinst. Ich habe das BAckup zum Testen jetzt immer manuell ausgelöst und dann den Text aus dem Fenster, das dan aufgeht rauskopiert. Ansonsten kenne ich keinen anderen Log
                                      • N noidea
                                        @noidea
                                        Dann kopier den jetzt aktuellen output nochmal.
                                        Dann muss man nicht a) nach oben scrollen und irgendwelche Einträge von vor zwei Stunden suchen und b) sieht man die aktuellen Fehlermeldungen aus dem System und nicht Stände von vor zwei Stunden.
                                          @noidea
                                          N Offline
                                          N Offline
                                          noidea
                                          [DEBUG] [mount] start with {"mountType":"CIFS","type":"storage","source":"local","mount":"//192.168.2.1","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"cifsDomain":"WORKGROUP","clientInodes":false,"deleteOldBackup":false,"ownDir":false,"dir":"/Generic-MassStorage/partition1","dirMinimal":"sharename/backupDir","user":"speedport","pass":"****","ignoreErrors":false}
                                          [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=speedport,password=****,domain=WORKGROUP,rw,file_mode=0777,dir_mode=0777,vers=1.0 //192.168.2.1/Generic-MassStorage/partition1 /opt/iobroker/backups"
                                          [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=speedport,password=****,domain=WORKGROUP,rw,file_mode=0777,dir_mode=0777 //192.168.2.1/Generic-MassStorage/partition1 /opt/iobroker/backups"
                                          [ERROR] [mount] - [undefined Error: Command failed: sudo mount -t cifs -o username=speedport,password=****,domain=WORKGROUP,rw,file_mode=0777,dir_mode=0777 //192.168.2.1/Generic-MassStorage/partition1 /opt/iobroker/backups
                                          [ERROR] [mount] - Error: Command failed: sudo mount -t cifs -o username=speedport,password=****,domain=WORKGROUP,rw,file_mode=0777,dir_mode=0777 //192.168.2.1/Generic-MassStorage/partition1 /opt/iobroker/backups
