  4. BackitUp NAS Error Speedport Smart 4
    5.5k
91 Beiträge 4 Kommentatoren 10.8k Aufrufe 3 Beobachtet
  • N noidea
    Ok. Das bedeutet, das in der Config jetzt SMB1 drin ist und im BackitUp Adapter auch. Trotzdem kommt immer noch die letzte Fehlermeldung....
    @noidea
    Welche?
    N 1 Antwort Letzte Antwort
      @noidea
      Welche?
      N Offline
      N Offline
      noidea
      Started iobroker ...
      [DEBUG] [mount] start with {"mountType":"CIFS","type":"storage","source":"local","mount":"//192.168.2.1","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"cifsDomain":"WORKGROUP","clientInodes":false,"deleteOldBackup":false,"ownDir":false,"dir":"/SanDisk-USBExtremePro/Backup/Speedport","dirMinimal":"sharename/backupDir","user":"speedport","pass":"****","ignoreErrors":false}
      [DEBUG] [mount] - noserverino option: false
      [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=speedport,password=****,domain=WORKGROUP,rw,file_mode=0777,dir_mode=0777,vers=1.0 //192.168.2.1/SanDisk-USBExtremePro/Backup/Speedport /opt/iobroker/backups"
      [DEBUG] [mount] - first mount attempt with smb option failed. try next mount attempt without smb option ...
      [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=speedport,password=****,domain=WORKGROUP,rw,file_mode=0777,dir_mode=0777 //192.168.2.1/SanDisk-USBExtremePro/Backup/Speedport /opt/iobroker/backups"
      [ERROR] [mount] - [undefined Error: Command failed: sudo mount -t cifs -o username=speedport,password=****,domain=WORKGROUP,rw,file_mode=0777,dir_mode=0777 //192.168.2.1/SanDisk-USBExtremePro/Backup/Speedport /opt/iobroker/backups
      mount error: Server abruptly closed the connection.
      This can happen if the server does not support the SMB version you are trying to use.
      The default SMB version recently changed from SMB1 to SMB2.1 and above. Try mounting with vers=1.0.
      mount error(112): Host is down
      Refer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
      [ERROR] [mount] - Error: Command failed: sudo mount -t cifs -o username=speedport,password=****,domain=WORKGROUP,rw,file_mode=0777,dir_mode=0777 //192.168.2.1/SanDisk-USBExtremePro/Backup/Speedport /opt/iobroker/backups
      • N noidea
        @noidea
        Keine Ahnung.
        • N noidea
          @noidea sagte in BackitUp NAS Error Speedport Smart 4:
          wirklich??
          klingt anders.
          Außerdem
          sagt, dass der Speedport wohl weg ist.
            wirklich??
            klingt anders.
            Außerdem
            N Offline
            N Offline
            noidea
            schrieb am zuletzt editiert von noidea
            SMB1 ist da eingestellt. Ich habe iobroker danach nochmal neugestartet.
            Der Router ist die ganze Zeit über da. Zumindest kann ich die ganze Zeit drauf zugreifen und Internet ist auch die ganze Zeit da.
            Deute ich die Fehlermeldung richtig, das versucht wird NICHT mit SMB1 die Verbindung aufzubauen, sondern mit SMB2.1? Liegt das Problem dann nicht eher an meinem System als am Router?
            • N noidea
              @noidea
              Wie sieht das Backup gerade im Log asu?
                @noidea
                N Offline
                N Offline
                noidea
                Leider genauso wie der letzte Eintrag weiter oben.
                • N noidea
                  @noidea
                  Wie sieht das Backup gerade JETZT im Log aus?
                    @noidea
                    N Offline
                    N Offline
                    noidea
                    Sorry, aber ich weiß nicht genau was du meinst. Ich habe das BAckup zum Testen jetzt immer manuell ausgelöst und dann den Text aus dem Fenster, das dan aufgeht rauskopiert. Ansonsten kenne ich keinen anderen Log
                    • N noidea
                      @noidea
                      Dann kopier den jetzt aktuellen output nochmal.
                      Dann muss man nicht a) nach oben scrollen und irgendwelche Einträge von vor zwei Stunden suchen und b) sieht man die aktuellen Fehlermeldungen aus dem System und nicht Stände von vor zwei Stunden.
                        @noidea
                        N Offline
                        N Offline
                        noidea
                        [DEBUG] [mount] start with {"mountType":"CIFS","type":"storage","source":"local","mount":"//192.168.2.1","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"cifsDomain":"WORKGROUP","clientInodes":false,"deleteOldBackup":false,"ownDir":false,"dir":"/Generic-MassStorage/partition1","dirMinimal":"sharename/backupDir","user":"speedport","pass":"****","ignoreErrors":false}
                        [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=speedport,password=****,domain=WORKGROUP,rw,file_mode=0777,dir_mode=0777,vers=1.0 //192.168.2.1/Generic-MassStorage/partition1 /opt/iobroker/backups"
                        [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=speedport,password=****,domain=WORKGROUP,rw,file_mode=0777,dir_mode=0777 //192.168.2.1/Generic-MassStorage/partition1 /opt/iobroker/backups"
                        [ERROR] [mount] - [undefined Error: Command failed: sudo mount -t cifs -o username=speedport,password=****,domain=WORKGROUP,rw,file_mode=0777,dir_mode=0777 //192.168.2.1/Generic-MassStorage/partition1 /opt/iobroker/backups
                        [ERROR] [mount] - Error: Command failed: sudo mount -t cifs -o username=speedport,password=****,domain=WORKGROUP,rw,file_mode=0777,dir_mode=0777 //192.168.2.1/Generic-MassStorage/partition1 /opt/iobroker/backups
                        • N noidea
                          Welche Version von backitup läuft da eigentlich?
                            N Offline
                            N Offline
                            noidea
                            2.5.9
                            Habe gerade gesehen, das die 2.5.10 Verfügbar ist. Aber irgendwie zweilfel ich daran, dass das alles ändern wird.
                            • N noidea
                              2.5.9
                              @noidea
                              Grundsätzlich hält man sein System auf Stand und fährt die letzten stabil verfügbaren Versionen.
                              • N noidea
                                2.5.9
                                @noidea was sagt iobroker update -i?
                                  N Offline
                                  N Offline
                                  noidea
                                  @homoran sagte in BackitUp NAS Error Speedport Smart 4:
                                  iobroker update -i
                                  Ein paar Instanzen brauchen ein update, u.a. der BackitPu und der Admin. Die habe ich jetzt mal durchgeführt, aber die Fehlermedlung ist leider immer noch die selbe
                                  • N noidea
                                    iobroker update -i
                                    iobroker update -i
                                    das ist nicht die vollständige Ausgabe
                                      iobroker update -i
                                      N Offline
                                      N Offline
                                      noidea
                                      Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
                                      Adapter    "backitup"     : 2.5.10   , installed 2.5.10
                                      Adapter    "discovery"    : 3.1.0    , installed 3.0.3  [Updatable]
                                      Adapter    "influxdb"     : 3.2.0    , installed 3.1.8  [Updatable]
                                      Adapter    "jarvis"       : 3.1.2    , installed 3.1.2
                                      Adapter    "javascript"   : 6.1.4    , installed 6.0.3  [Updatable]
                                      Controller "js-controller": 4.0.24   , installed 4.0.23 [Updatable]
                                      Adapter    "modbus"       : 5.0.11   , installed 5.0.5  [Updatable]
                                      Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
                                      Adapter    "node-red"     : 4.0.0    , installed 4.0.0
                                      Adapter    "robonect"     : 0.1.4    , installed 0.1.4
                                      Adapter    "sainlogic"    : 0.10.0   , installed 0.9.0  [Updatable]
                                      Adapter    "shelly"       : 6.0.0    , installed 6.0.0
                                      Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
                                      Adapter    "terminal"     : 1.0.0    , installed 0.2.6  [Updatable]
                                      Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
                                      • N noidea
                                        iobroker update -i
                                        Das kann nicht sein, weil der Backitup-Adapter jetzt etwas anders gemountet wird. Die Meldung muss (leicht) anders sein.
                                        Und bring die Kiste vollständig auf Stand.
                                        • N noidea
                                          @noidea wo kommt das jetzt her?
                                          kein Prompt, kein Pfad, kein Befehl??
