  3. Einsteigerfragen
  4. Installation
  5. iobroker Installation ok, aber kein Zugriff über localhost
38 Beiträge 6 Kommentatoren 6.4k Aufrufe 6 Beobachtet
  • M mwolle
    @glasfaser oh ha...
    2022-12-22 08:34:28.871  - error: admin.0 (5429) Cannot read properties of null (reading '_acl')
    2022-12-22 08:34:28.895  - info: admin.0 (5429) terminating http server on port 8081
    2022-12-22 08:34:28.897  - info: admin.0 (5429) terminating
    2022-12-22 08:34:28.898  - warn: admin.0 (5429) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2022-12-22 08:34:29.136  - error: host.raspberrypi Caught by controller[0]: TypeError: Cannot read properties of null (reading '_acl')
    2022-12-22 08:34:29.136  - error: host.raspberrypi Caught by controller[0]:     at SocketCommandsAdmin.subscribe (/opt/iobroker/node_modules/@iobroker/socket-classes/lib/socketCommands.js:288:117)
    2022-12-22 08:34:29.136  - error: host.raspberrypi Caught by controller[0]:     at SocketAdmin.subscribe (/opt/iobroker/node_modules/@iobroker/socket-classes/lib/socketAdmin.js:181:23)
    2022-12-22 08:34:29.137  - error: host.raspberrypi Caught by controller[0]:     at initSocket (/opt/iobroker/node_modules/iobroker.admin/main.js:499:12)
    2022-12-22 08:34:29.137  - error: host.raspberrypi Caught by controller[0]:     at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/lib/web.js:1048:29)
    2022-12-22 08:34:29.137  - error: host.raspberrypi Caught by controller[0]:     at processImmediate (node:internal/timers:468:21)
    2022-12-22 08:34:29.137  - error: host.raspberrypi instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2022-12-22 08:34:29.137  - info: host.raspberrypi Restart adapter system.adapter.admin.0 because enabled
    2022-12-22 08:34:59.171  - info: host.raspberrypi instance system.adapter.admin.0 started with pid 5446
    2022-12-22 08:35:02.096  - info: admin.0 (5446) starting. Version 6.3.3 in /opt/iobroker/node_modules/iobroker.admin, node: v16.19.0, js-controller: 4.0.23
    2022-12-22 08:35:02.148  - info: admin.0 (5446) requesting all states
    2022-12-22 08:35:02.149  - info: admin.0 (5446) requesting all objects
    2022-12-22 08:35:02.250  - info: admin.0 (5446) received all objects
    2022-12-22 08:35:02.268  - warn: admin.0 (5446) Repository cannot be read: Active repo - stable
    2022-12-22 08:35:02.269  - warn: admin.0 (5446) Active repository "stable" cannot be read
    2022-12-22 08:35:02.372  - warn: admin.0 (5446) Cannot check node.js versions: Error: unexpected end of file
    2022-12-22 08:35:02.387  - info: admin.0 (5446) http server listening on port 8081
    2022-12-22 08:35:02.388  - info: admin.0 (5446) Use link "http://localhost:8081" to configure.
    2022-12-22 08:35:02.397  - info: admin.0 (5446) socket.io server listening on port 8081
    2022-12-22 08:35:02.406  - error: admin.0 (5446) uncaught exception: Cannot read properties of null (reading '_acl')
    2022-12-22 08:35:02.407  - error: admin.0 (5446) TypeError: Cannot read properties of null (reading '_acl')
    2022-12-22 08:35:02.407  - error: admin.0 (5446) Cannot read properties of null (reading '_acl')
    2022-12-22 08:35:02.433  - info: admin.0 (5446) terminating http server on port 8081
    2022-12-22 08:35:02.435  - info: admin.0 (5446) terminating
    2022-12-22 08:35:02.436  - warn: admin.0 (5446) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2022-12-22 08:35:02.627  - error: host.raspberrypi Caught by controller[0]: TypeError: Cannot read properties of null (reading '_acl')
    2022-12-22 08:35:02.628  - error: host.raspberrypi Caught by controller[0]:     at SocketCommandsAdmin.subscribe (/opt/iobroker/node_modules/@iobroker/socket-classes/lib/socketCommands.js:288:117)
    2022-12-22 08:35:02.628  - error: host.raspberrypi Caught by controller[0]:     at SocketAdmin.subscribe (/opt/iobroker/node_modules/@iobroker/socket-classes/lib/socketAdmin.js:181:23)
    2022-12-22 08:35:02.628  - error: host.raspberrypi Caught by controller[0]:     at initSocket (/opt/iobroker/node_modules/iobroker.admin/main.js:499:12)
    2022-12-22 08:35:02.628  - error: host.raspberrypi Caught by controller[0]:     at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/lib/web.js:1048:29)
    2022-12-22 08:35:02.628  - error: host.raspberrypi Caught by controller[0]:     at processImmediate (node:internal/timers:468:21)
    2022-12-22 08:35:02.629  - error: host.raspberrypi instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2022-12-22 08:35:02.629  - info: host.raspberrypi Restart adapter system.adapter.admin.0 because enabled
    2022-12-22 08:35:32.671  - info: host.raspberrypi instance system.adapter.admin.0 started with pid 5475
    2022-12-22 08:35:35.040  - info: admin.0 (5475) starting. Version 6.3.3 in /opt/iobroker/node_modules/iobroker.admin, node: v16.19.0, js-controller: 4.0.23
    2022-12-22 08:35:35.095  - info: admin.0 (5475) requesting all states
    2022-12-22 08:35:35.096  - info: admin.0 (5475) requesting all objects
    2022-12-22 08:35:35.191  - info: admin.0 (5475) received all objects
    2022-12-22 08:35:35.208  - warn: admin.0 (5475) Repository cannot be read: Active repo - stable
    2022-12-22 08:35:35.210  - warn: admin.0 (5475) Active repository "stable" cannot be read
    2022-12-22 08:35:35.311  - warn: admin.0 (5475) Cannot check node.js versions: Error: unexpected end of file
    2022-12-22 08:35:35.324  - info: admin.0 (5475) http server listening on port 8081
    2022-12-22 08:35:35.325  - info: admin.0 (5475) Use link "http://localhost:8081" to configure.
    2022-12-22 08:35:35.333  - info: admin.0 (5475) socket.io server listening on port 8081
    2022-12-22 08:35:35.342  - error: admin.0 (5475) uncaught exception: Cannot read properties of null (reading '_acl')
    2022-12-22 08:35:35.342  - error: admin.0 (5475) TypeError: Cannot read properties of null (reading '_acl')
    2022-12-22 08:35:35.343  - error: admin.0 (5475) Cannot read properties of null (reading '_acl')
    2022-12-22 08:35:35.371  - info: admin.0 (5475) terminating http server on port 8081
    2022-12-22 08:35:35.375  - info: admin.0 (5475) terminating
    2022-12-22 08:35:35.376  - warn: admin.0 (5475) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2022-12-22 08:35:35.597  - error: host.raspberrypi Caught by controller[0]: TypeError: Cannot read properties of null (reading '_acl')
    2022-12-22 08:35:35.597  - error: host.raspberrypi Caught by controller[0]:     at SocketCommandsAdmin.subscribe (/opt/iobroker/node_modules/@iobroker/socket-classes/lib/socketCommands.js:288:117)
    2022-12-22 08:35:35.597  - error: host.raspberrypi Caught by controller[0]:     at SocketAdmin.subscribe (/opt/iobroker/node_modules/@iobroker/socket-classes/lib/socketAdmin.js:181:23)
    2022-12-22 08:35:35.597  - error: host.raspberrypi Caught by controller[0]:     at initSocket (/opt/iobroker/node_modules/iobroker.admin/main.js:499:12)
    2022-12-22 08:35:35.598  - error: host.raspberrypi Caught by controller[0]:     at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/lib/web.js:1048:29)
    2022-12-22 08:35:35.598  - error: host.raspberrypi Caught by controller[0]:     at processImmediate (node:internal/timers:468:21)
    2022-12-22 08:35:35.598  - error: host.raspberrypi instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2022-12-22 08:35:35.598  - info: host.raspberrypi Restart adapter system.adapter.admin.0 because enabled
    2022-12-22 08:36:05.642  - info: host.raspberrypi instance system.adapter.admin.0 started with pid 5492
    2022-12-22 08:36:08.421  - info: admin.0 (5492) starting. Version 6.3.3 in /opt/iobroker/node_modules/iobroker.admin, node: v16.19.0, js-controller: 4.0.23
    GlasfaserG Offline
    GlasfaserG Offline
    @mwolle sagte in iobroker Installation ok, aber kein Zugriff über localhost:
    Keine Ahnung was da passiert ist , bei einer :
    Normale iobroker Installation auf Raspi PI 4:
    ich würde es nochmal neu aufsetzen
    • M mwolle
      Moin zusammen,
      nach stundenlanger suche komme ich nicht weiter: Normale iobroker Installation auf Raspi PI 4:
      curl -sLf https://iobroker.net/install.sh | bash -
      Installation ist sauber durch gelaufen, aber mit localhost:8081 bekomme ich nur localhost hat die Verbindung abgelehnt
      Prüfung mit:
      iobroker status
      Objects type: jsonl
      States  type: jsonl
      sieht gut aus, ebenso
      iobroker list adapters
      system.adapter.admin                   : admin          - v6.3.3
      system.adapter.backitup                : backitup       - v2.5.9
      system.adapter.discovery               : discovery      - v3.1.0
      das einzige was mir auffällt ist unter:
      netstat -n -a -p TCP
      Aktive Internetverbindungen (Server und stehende Verbindungen)
      Proto Recv-Q Send-Q Local Address           Foreign Address         State       PID/Program name
      tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      -
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      -
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      -
      tcp        0      0 0.0.0.0:8888            0.0.0.0:*               LISTEN      -
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      -
      tcp        0      0 127.0.0.1:9001          127.0.0.1:59054         VERBUNDEN   -
      tcp        0      0 127.0.0.1:44330         127.0.0.1:9000          VERBUNDEN   -
      tcp        0      0 127.0.0.1:59060         127.0.0.1:9001          VERBUNDEN   -
      tcp        0      0 127.0.0.1:9001          127.0.0.1:59088         VERBUNDEN   -
      tcp        0      0 127.0.0.1:59062         127.0.0.1:9001          VERBUNDEN   -
      tcp        0      0 127.0.0.1:52256         127.0.0.1:9001          VERBUNDEN   -
      tcp        0      0 127.0.0.1:47924         127.0.0.1:9001          TIME_WAIT   -
      tcp        0      0 127.0.0.1:9000          127.0.0.1:50192         TIME_WAIT   -
      tcp        0      0 127.0.0.1:44314         127.0.0.1:9000          VERBUNDEN   -
      tcp        0      0 127.0.0.1:44320         127.0.0.1:9000          VERBUNDEN   -
      tcp        0      0 127.0.0.1:9001          127.0.0.1:59058         VERBUNDEN   -
      hier sehe ich keinen geforderten Eintrag zu 0.0.0.0:8081
      Was kann ich noch tun?
      GlasfaserG Offline
      GlasfaserG Offline
      Ist jetzt eine 6.3.4 schon raus ... eventuell klemmte da was ..
      • M mwolle
        Moin zusammen,
        Prüfung mit:
        iobroker status
        Objects type: jsonl
        States  type: jsonl
        Marc BergM Online
        Marc BergM Online
        Marc Berg
        Unter welchem User hast du das ausgeführt?
        • GlasfaserG Glasfaser
          mwolle
          @glasfaser der Installer nimmt den 6.3.3...was mir aufgefallen ist, bei der ersten frischen Installation meckert bzgl. der Node.js rum, dass die 12 nicht mehr gültig ist. Danach habe ich die aktuellste Version installiert und den Installer noch mal rüberlaufen lassen, da kann auch kein Fehler mehr, das gilt auch für iobroker fix.
          crunchipC GlasfaserG 2 Antworten Letzte Antwort
          • Marc BergM Marc Berg
            mwolle
            @marc-berg der Standard pi User bzw. von mir angelegte.
            • M mwolle
              crunchipC Abwesend
              crunchipC Abwesend
              hast du node vorher manuell installiert?
              • M mwolle
                GlasfaserG Offline
                GlasfaserG Offline
                dann hast du alten Müll auf der Raspberry noch vorhanden und hast dann darauf ioBroker installiert !?
                Zeige mal :
                sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
                uname -m && test -f /opt/scripts/.docker_config/.thisisdocker && echo "Docker-Installation" || echo "Kein Docker" && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && echo $DESKTOP_SESSION && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                  Zeige mal :
                  mwolle
                  @glasfaser
                  armv7l
                  Kein Docker
                  /usr/bin/nodejs
                  /usr/bin/node
                  /usr/bin/npm
                  v16.19.0
                  v16.19.0
                  8.19.3
                  4.0.23
                  pi
                  pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                  x11
                  LXDE-pi
                  /home/pi
                  OK:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                  OK:2 http://archive.raspberrypi.org/debian bullseye InRelease
                  OK:3 https://deb.nodesource.com/node_16.x bullseye InRelease
                  Alle Pakete sind aktuell.
                  nodejs:
                    Installiert:           16.19.0-deb-1nodesource1
                    Installationskandidat: 16.19.0-deb-1nodesource1
                    Versionstabelle:
                   *** 16.19.0-deb-1nodesource1 500
                          500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
                       12.22.12~dfsg-1~deb11u1 500
                  • M mwolle
                    @glasfaser
                    armv7l
                    Kein Docker
                    /usr/bin/nodejs
                    /usr/bin/node
                    /usr/bin/npm
                    v16.19.0
                    v16.19.0
                    8.19.3
                    4.0.23
                    pi
                    x11
                    LXDE-pi
                    /home/pi
                    nodejs:
                      Versionstabelle:
                    crunchipC Abwesend
                    crunchipC Abwesend
                    x11
                    desktop
                      mwolle
                      @crunchip im Original Noobs 3.8.0 ist scheinbar Node.js 12.22 installiert, ich habe dann ein Update auf die neuste Version gemacht, aber erst nachdem iobroker bei Installation gemeckert hat.
                        x11
                        desktop
                        mwolle
                        @crunchip said in iobroker Installation ok, aber kein Zugriff über localhost:
                        x11
                        desktop
                        ? Heißt? Ja ist Desktopversion
                        • M mwolle
                          x11
                          desktop
                          crunchipC Abwesend
                          crunchipC Abwesend
                          @mwolle iobroker = Serverbetrieb, heisst ohne Desktop
                          z.b https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                            mwolle
                            @crunchip grundsätzlich, ja verstehe ich, aber: ich habe das jetzt bestimmt 40x genauso installiert, alles war ok. Hat sich das jetzt mit der neusten Installerversion dann geändert? Am Ende wollte ich den iobroker auch so standalone haben.
                            • M mwolle
                              @mwolle
                              Noobs ist obsolet. Verwende den Imager.
                                @mwolle
                                mwolle
                                autsch, also play it again Sam und noch mal neu aufsetzen. Aber Desktop wird weiter unterstützt oder bleibt es beim Serverbetrieb?
                                • M mwolle
                                  crunchipC Abwesend
                                  crunchipC Abwesend
                                  @mwolle braucht halt unnötige Ressourcen
                                    mwolle
                                    @crunchip das wäre nicht schlimm, weil das DIng nichts anderes tun soll, als Heizungsdaten zu protokollieren und mit Flot anzuzeigen. Mehr soll der nicht machen.
                                    • M mwolle
                                      crunchipC Abwesend
                                      crunchipC Abwesend
                                      für was dann nen Desktop?
                                        mwolle
                                        @crunchip weil die Kiste dann extern bei einem "Kunden" stehen wird, ich per VNC darauf zugreife und mir dann die Daten anschaue die protokolliert wurden. Mir die externe IP geben lassen vom "Kunden" halte ich für schwierig ;)...DynDNS wollte ich da nicht einrichten...
                                        • M mwolle
                                          @mwolle
                                          Und ich halte es für noch schwieriger aus Sicherheitsaspekten RDP über das Internet zu routen. Ist Harakiri.
