  3. Einsteigerfragen
  4. Installation
  5. iobroker Installation ok, aber kein Zugriff über localhost
38 Beiträge 6 Kommentatoren 6.4k Aufrufe 6 Beobachtet
  • M mwolle
    @glasfaser keine Besserung
    GlasfaserG Offline
    GlasfaserG Offline
    @mwolle sagte in iobroker Installation ok, aber kein Zugriff über localhost:
    Dann zeigen :
    iobroker logs --watch
    • GlasfaserG Glasfaser
      Dann zeigen :
      mwolle
      @glasfaser oh ha...
      2022-12-22 08:34:28.871  - error: admin.0 (5429) Cannot read properties of null (reading '_acl')
      2022-12-22 08:34:28.895  - info: admin.0 (5429) terminating http server on port 8081
      2022-12-22 08:34:28.897  - info: admin.0 (5429) terminating
      2022-12-22 08:34:28.898  - warn: admin.0 (5429) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2022-12-22 08:34:29.136  - error: host.raspberrypi Caught by controller[0]: TypeError: Cannot read properties of null (reading '_acl')
      2022-12-22 08:34:29.136  - error: host.raspberrypi Caught by controller[0]:     at SocketCommandsAdmin.subscribe (/opt/iobroker/node_modules/@iobroker/socket-classes/lib/socketCommands.js:288:117)
      2022-12-22 08:34:29.136  - error: host.raspberrypi Caught by controller[0]:     at SocketAdmin.subscribe (/opt/iobroker/node_modules/@iobroker/socket-classes/lib/socketAdmin.js:181:23)
      2022-12-22 08:34:29.137  - error: host.raspberrypi Caught by controller[0]:     at initSocket (/opt/iobroker/node_modules/iobroker.admin/main.js:499:12)
      2022-12-22 08:34:29.137  - error: host.raspberrypi Caught by controller[0]:     at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/lib/web.js:1048:29)
      2022-12-22 08:34:29.137  - error: host.raspberrypi Caught by controller[0]:     at processImmediate (node:internal/timers:468:21)
      2022-12-22 08:34:29.137  - error: host.raspberrypi instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2022-12-22 08:34:29.137  - info: host.raspberrypi Restart adapter system.adapter.admin.0 because enabled
      2022-12-22 08:34:59.171  - info: host.raspberrypi instance system.adapter.admin.0 started with pid 5446
      2022-12-22 08:35:02.096  - info: admin.0 (5446) starting. Version 6.3.3 in /opt/iobroker/node_modules/iobroker.admin, node: v16.19.0, js-controller: 4.0.23
      2022-12-22 08:35:02.148  - info: admin.0 (5446) requesting all states
      2022-12-22 08:35:02.149  - info: admin.0 (5446) requesting all objects
      2022-12-22 08:35:02.250  - info: admin.0 (5446) received all objects
      2022-12-22 08:35:02.268  - warn: admin.0 (5446) Repository cannot be read: Active repo - stable
      2022-12-22 08:35:02.269  - warn: admin.0 (5446) Active repository "stable" cannot be read
      2022-12-22 08:35:02.372  - warn: admin.0 (5446) Cannot check node.js versions: Error: unexpected end of file
      2022-12-22 08:35:02.387  - info: admin.0 (5446) http server listening on port 8081
      2022-12-22 08:35:02.388  - info: admin.0 (5446) Use link "http://localhost:8081" to configure.
      2022-12-22 08:35:02.397  - info: admin.0 (5446) socket.io server listening on port 8081
      2022-12-22 08:35:02.406  - error: admin.0 (5446) uncaught exception: Cannot read properties of null (reading '_acl')
      2022-12-22 08:35:02.407  - error: admin.0 (5446) TypeError: Cannot read properties of null (reading '_acl')
      2022-12-22 08:35:02.407  - error: admin.0 (5446) Cannot read properties of null (reading '_acl')
      2022-12-22 08:35:02.433  - info: admin.0 (5446) terminating http server on port 8081
      2022-12-22 08:35:02.435  - info: admin.0 (5446) terminating
      2022-12-22 08:35:02.436  - warn: admin.0 (5446) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2022-12-22 08:35:02.627  - error: host.raspberrypi Caught by controller[0]: TypeError: Cannot read properties of null (reading '_acl')
      2022-12-22 08:35:02.628  - error: host.raspberrypi Caught by controller[0]:     at SocketCommandsAdmin.subscribe (/opt/iobroker/node_modules/@iobroker/socket-classes/lib/socketCommands.js:288:117)
      2022-12-22 08:35:02.628  - error: host.raspberrypi Caught by controller[0]:     at SocketAdmin.subscribe (/opt/iobroker/node_modules/@iobroker/socket-classes/lib/socketAdmin.js:181:23)
      2022-12-22 08:35:02.628  - error: host.raspberrypi Caught by controller[0]:     at initSocket (/opt/iobroker/node_modules/iobroker.admin/main.js:499:12)
      2022-12-22 08:35:02.628  - error: host.raspberrypi Caught by controller[0]:     at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/lib/web.js:1048:29)
      2022-12-22 08:35:02.628  - error: host.raspberrypi Caught by controller[0]:     at processImmediate (node:internal/timers:468:21)
      2022-12-22 08:35:02.629  - error: host.raspberrypi instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2022-12-22 08:35:02.629  - info: host.raspberrypi Restart adapter system.adapter.admin.0 because enabled
      2022-12-22 08:35:32.671  - info: host.raspberrypi instance system.adapter.admin.0 started with pid 5475
      2022-12-22 08:35:35.040  - info: admin.0 (5475) starting. Version 6.3.3 in /opt/iobroker/node_modules/iobroker.admin, node: v16.19.0, js-controller: 4.0.23
      2022-12-22 08:35:35.095  - info: admin.0 (5475) requesting all states
      2022-12-22 08:35:35.096  - info: admin.0 (5475) requesting all objects
      2022-12-22 08:35:35.191  - info: admin.0 (5475) received all objects
      2022-12-22 08:35:35.208  - warn: admin.0 (5475) Repository cannot be read: Active repo - stable
      2022-12-22 08:35:35.210  - warn: admin.0 (5475) Active repository "stable" cannot be read
      2022-12-22 08:35:35.311  - warn: admin.0 (5475) Cannot check node.js versions: Error: unexpected end of file
      2022-12-22 08:35:35.324  - info: admin.0 (5475) http server listening on port 8081
      2022-12-22 08:35:35.325  - info: admin.0 (5475) Use link "http://localhost:8081" to configure.
      2022-12-22 08:35:35.333  - info: admin.0 (5475) socket.io server listening on port 8081
      2022-12-22 08:35:35.342  - error: admin.0 (5475) uncaught exception: Cannot read properties of null (reading '_acl')
      2022-12-22 08:35:35.342  - error: admin.0 (5475) TypeError: Cannot read properties of null (reading '_acl')
      2022-12-22 08:35:35.343  - error: admin.0 (5475) Cannot read properties of null (reading '_acl')
      2022-12-22 08:35:35.371  - info: admin.0 (5475) terminating http server on port 8081
      2022-12-22 08:35:35.375  - info: admin.0 (5475) terminating
      2022-12-22 08:35:35.376  - warn: admin.0 (5475) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2022-12-22 08:35:35.597  - error: host.raspberrypi Caught by controller[0]: TypeError: Cannot read properties of null (reading '_acl')
      2022-12-22 08:35:35.597  - error: host.raspberrypi Caught by controller[0]:     at SocketCommandsAdmin.subscribe (/opt/iobroker/node_modules/@iobroker/socket-classes/lib/socketCommands.js:288:117)
      2022-12-22 08:35:35.597  - error: host.raspberrypi Caught by controller[0]:     at SocketAdmin.subscribe (/opt/iobroker/node_modules/@iobroker/socket-classes/lib/socketAdmin.js:181:23)
      2022-12-22 08:35:35.597  - error: host.raspberrypi Caught by controller[0]:     at initSocket (/opt/iobroker/node_modules/iobroker.admin/main.js:499:12)
      2022-12-22 08:35:35.598  - error: host.raspberrypi Caught by controller[0]:     at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/lib/web.js:1048:29)
      2022-12-22 08:35:35.598  - error: host.raspberrypi Caught by controller[0]:     at processImmediate (node:internal/timers:468:21)
      2022-12-22 08:35:35.598  - error: host.raspberrypi instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2022-12-22 08:35:35.598  - info: host.raspberrypi Restart adapter system.adapter.admin.0 because enabled
      2022-12-22 08:36:05.642  - info: host.raspberrypi instance system.adapter.admin.0 started with pid 5492
      2022-12-22 08:36:08.421  - info: admin.0 (5492) starting. Version 6.3.3 in /opt/iobroker/node_modules/iobroker.admin, node: v16.19.0, js-controller: 4.0.23
      GlasfaserG apollon77A 2 Antworten Letzte Antwort
      • M mwolle
        @glasfaser oh ha...
        GlasfaserG Offline
        GlasfaserG Offline
        Keine Ahnung was da passiert ist , bei einer :
        Normale iobroker Installation auf Raspi PI 4:
        ich würde es nochmal neu aufsetzen
        • M mwolle
          Moin zusammen,
          nach stundenlanger suche komme ich nicht weiter: Normale iobroker Installation auf Raspi PI 4:
          curl -sLf https://iobroker.net/install.sh | bash -
          Installation ist sauber durch gelaufen, aber mit localhost:8081 bekomme ich nur localhost hat die Verbindung abgelehnt
          Prüfung mit:
          iobroker status
          Objects type: jsonl
          States  type: jsonl
          sieht gut aus, ebenso
          iobroker list adapters
          system.adapter.admin                   : admin          - v6.3.3
          system.adapter.backitup                : backitup       - v2.5.9
          system.adapter.discovery               : discovery      - v3.1.0
          das einzige was mir auffällt ist unter:
          netstat -n -a -p TCP
          Aktive Internetverbindungen (Server und stehende Verbindungen)
          Proto Recv-Q Send-Q Local Address           Foreign Address         State       PID/Program name
          tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      -
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      -
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      -
          tcp        0      0 0.0.0.0:8888            0.0.0.0:*               LISTEN      -
          tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      -
          tcp        0      0 127.0.0.1:9001          127.0.0.1:59054         VERBUNDEN   -
          tcp        0      0 127.0.0.1:44330         127.0.0.1:9000          VERBUNDEN   -
          tcp        0      0 127.0.0.1:59060         127.0.0.1:9001          VERBUNDEN   -
          tcp        0      0 127.0.0.1:9001          127.0.0.1:59088         VERBUNDEN   -
          tcp        0      0 127.0.0.1:59062         127.0.0.1:9001          VERBUNDEN   -
          tcp        0      0 127.0.0.1:52256         127.0.0.1:9001          VERBUNDEN   -
          tcp        0      0 127.0.0.1:47924         127.0.0.1:9001          TIME_WAIT   -
          tcp        0      0 127.0.0.1:9000          127.0.0.1:50192         TIME_WAIT   -
          tcp        0      0 127.0.0.1:44314         127.0.0.1:9000          VERBUNDEN   -
          tcp        0      0 127.0.0.1:44320         127.0.0.1:9000          VERBUNDEN   -
          tcp        0      0 127.0.0.1:9001          127.0.0.1:59058         VERBUNDEN   -
          hier sehe ich keinen geforderten Eintrag zu 0.0.0.0:8081
          Was kann ich noch tun?
          GlasfaserG Offline
          GlasfaserG Offline
          Ist jetzt eine 6.3.4 schon raus ... eventuell klemmte da was ..
          • M mwolle
            Moin zusammen,
            Prüfung mit:
            iobroker status
            Objects type: jsonl
            States  type: jsonl
            Marc BergM Online
            Marc BergM Online
            Marc Berg
            Unter welchem User hast du das ausgeführt?
              mwolle
              @glasfaser der Installer nimmt den 6.3.3...was mir aufgefallen ist, bei der ersten frischen Installation meckert bzgl. der Node.js rum, dass die 12 nicht mehr gültig ist. Danach habe ich die aktuellste Version installiert und den Installer noch mal rüberlaufen lassen, da kann auch kein Fehler mehr, das gilt auch für iobroker fix.
              crunchipC GlasfaserG 2 Antworten Letzte Antwort
              • Marc BergM Marc Berg
                mwolle
                @marc-berg der Standard pi User bzw. von mir angelegte.
                • M mwolle
                  crunchipC Abwesend
                  crunchipC Abwesend
                  hast du node vorher manuell installiert?
                  • M mwolle
                    GlasfaserG Offline
                    GlasfaserG Offline
                    dann hast du alten Müll auf der Raspberry noch vorhanden und hast dann darauf ioBroker installiert !?
                    Zeige mal :
                    sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
                    uname -m && test -f /opt/scripts/.docker_config/.thisisdocker && echo "Docker-Installation" || echo "Kein Docker" && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && echo $DESKTOP_SESSION && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                      Zeige mal :
                      mwolle
                      @glasfaser
                      armv7l
                      Kein Docker
                      /usr/bin/nodejs
                      /usr/bin/node
                      /usr/bin/npm
                      v16.19.0
                      v16.19.0
                      8.19.3
                      4.0.23
                      pi
                      pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                      x11
                      LXDE-pi
                      /home/pi
                      OK:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                      OK:2 http://archive.raspberrypi.org/debian bullseye InRelease
                      OK:3 https://deb.nodesource.com/node_16.x bullseye InRelease
                      Alle Pakete sind aktuell.
                      nodejs:
                        Installiert:           16.19.0-deb-1nodesource1
                        Installationskandidat: 16.19.0-deb-1nodesource1
                        Versionstabelle:
                       *** 16.19.0-deb-1nodesource1 500
                              500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
                           12.22.12~dfsg-1~deb11u1 500
                      • M mwolle
                        @glasfaser
                        armv7l
                        Kein Docker
                        /usr/bin/nodejs
                        /usr/bin/node
                        /usr/bin/npm
                        v16.19.0
                        v16.19.0
                        8.19.3
                        4.0.23
                        pi
                        x11
                        LXDE-pi
                        /home/pi
                        nodejs:
                          Versionstabelle:
                        crunchipC Abwesend
                        crunchipC Abwesend
                        x11
                        desktop
                          mwolle
                          @crunchip im Original Noobs 3.8.0 ist scheinbar Node.js 12.22 installiert, ich habe dann ein Update auf die neuste Version gemacht, aber erst nachdem iobroker bei Installation gemeckert hat.
                            x11
                            desktop
                            mwolle
                            @crunchip said in iobroker Installation ok, aber kein Zugriff über localhost:
                            x11
                            desktop
                            ? Heißt? Ja ist Desktopversion
                            • M mwolle
                              x11
                              desktop
                              crunchipC Abwesend
                              crunchipC Abwesend
                              @mwolle iobroker = Serverbetrieb, heisst ohne Desktop
                              z.b https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                                mwolle
                                @crunchip grundsätzlich, ja verstehe ich, aber: ich habe das jetzt bestimmt 40x genauso installiert, alles war ok. Hat sich das jetzt mit der neusten Installerversion dann geändert? Am Ende wollte ich den iobroker auch so standalone haben.
                                • M mwolle
                                  @mwolle
                                  Noobs ist obsolet. Verwende den Imager.
                                    @mwolle
                                    mwolle
                                    autsch, also play it again Sam und noch mal neu aufsetzen. Aber Desktop wird weiter unterstützt oder bleibt es beim Serverbetrieb?
                                    • M mwolle
                                      crunchipC Abwesend
                                      crunchipC Abwesend
                                      @mwolle braucht halt unnötige Ressourcen
                                        mwolle
                                        @crunchip das wäre nicht schlimm, weil das DIng nichts anderes tun soll, als Heizungsdaten zu protokollieren und mit Flot anzuzeigen. Mehr soll der nicht machen.
                                        • M mwolle
                                          crunchipC Abwesend
                                          crunchipC Abwesend
                                          für was dann nen Desktop?
