  3. Marktplatz
  4. [Verkaufe] Zigbee LAN/USB/WLAN Gateway CC2652P
    apollon77A
Geplant Angeheftet Gesperrt Verschoben Marktplatz
236 Beiträge 54 Kommentatoren 80.7k Aufrufe 53 Beobachtet
  • liv-in-skyL liv-in-sky
    @dimaiv
    erstmal vielen dank für die schnelle lieferung :-)
    ich wollte das ganze nun mit zigbee2mqtt installieren
    meine configuration.yaml sieht so aus:
    homeassistant: false
    permit_join: true
    frontend:
       port: 8080
       host: 0.0.0.0
    mqtt:
       base_topic: zigbee2mqtt
       server: mqtt://192.168.178.59:1890
    serial:
       port: 'tcp://192.168.178.141:6638'
    advanced:
       pan_id: 0x1A79
       ext_pan_id: [0xDD, 0xDD, 0xDD, 0xDD, 0xAA, 0xAD, 0xDD, 0xDD]
       channel: 14
       network_key: [0x01, 0x03, 0x05, 0x07, 0x09, 0x0B, 0x0D, 0x0F, 0x00, 0x02, 0x04, 0x06, 0x08, 0x0A>
       last_seen: ISO_8601_local
       homeassistant_legacy_entity_attributes: false
       legacy_api: false
       legacy_availability_payload: false
       output: json
       transmit_power: 20
       log_level: warn
    device_options:
       legacy: false
    availability: true
    beim aufruf des servers kommt aber:
    $ npm start
    > zigbee2mqtt@1.28.2 start
    > node index.js
    Zigbee2MQTT:info  2022-11-20 08:33:09: Logging to console and directory: '/opt/zigbee2mqtt/data/log/2022-11-20.08-33-09' filename: log.txt
    Zigbee2MQTT:info  2022-11-20 08:33:09: Starting Zigbee2MQTT version 1.28.2 (commit #e66fe85)
    Zigbee2MQTT:info  2022-11-20 08:33:09: Starting zigbee-herdsman (0.14.68)
    Zigbee2MQTT:error 2022-11-20 08:33:09: Error while starting zigbee-herdsman
    Zigbee2MQTT:error 2022-11-20 08:33:09: Failed to start zigbee
    Zigbee2MQTT:error 2022-11-20 08:33:09: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
    Zigbee2MQTT:error 2022-11-20 08:33:09: Exiting...
    Zigbee2MQTT:error 2022-11-20 08:33:09: Error: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0'
        at SerialPort.<anonymous> (/opt/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/z-stack/znp/znp.ts:146:28)
        at SerialPort._error (/opt/zigbee2mqtt/node_modules/@serialport/stream/lib/index.js:198:14)
        at /opt/zigbee2mqtt/node_modules/@serialport/stream/lib/index.js:242:12
    irgendwie will er /dev/ttyACM0 - ist aber anders konfiguriert - hättest du eine idee für mich
    crunchipC
    crunchipC
    Developer Global Moderator Most Active Forum Testing
    #191
    @liv-in-sky hast du z2m auch neu gestartet?
      liv-in-skyL
      liv-in-skyL
      #192
      @crunchip ja - habe ich
        crunchipC
        crunchipC
        #193
        @liv-in-sky sagte in [Verkaufe] Zigbee LAN/USB/WLAN Gateway CC2652P:
        bei mir ist das so eingetragen, vllt liegts daran
        serial:
          port: tcp://10.1.20.7:20108
          serial:
          liv-in-skyL
          liv-in-skyL
          #194
          @crunchip habe es lt: https://forum.iobroker.net/post/693392 gemacht
          aber habe auch mal deines getestet - kommt leider die selbe fehlermeldung
            crunchipC
            crunchipC
            #195
            @liv-in-sky na ich meine ohne die ' '
            stick ist erreichbar?
            liv-in-skyL 3 Antworten Letzte Antwort
              liv-in-skyL
              liv-in-skyL
              #196
              @crunchip ohne und mit probiert - mit habe probiert, weil hier:
              aber ich denke da fehlt was anderes, weil im fehler immer auf den cannot open /dev/ttyACM0 hingewiesen wird
                liv-in-skyL
                liv-in-skyL
                #197
                @crunchip sagte in [Verkaufe] Zigbee LAN/USB/WLAN Gateway CC2652P:
                wie stell ich das fest - weiß nur er ist im netzwerk mit ip
                  liv-in-skyL
                  liv-in-skyL
                  #198
                  @crunchip
                  könnte es ein problem sein, weil proxmox lxc ??
                    crunchipC
                    crunchipC
                    #199
                    @liv-in-sky vllt passt der port nicht
                    weil proxmox lxc
                    hab ich auch
                    hab von hier installiert
                      @dimaiv
                      permit_join: true
                      frontend:
                         port: 8080
                         host: 0.0.0.0
                      mqtt:
                      serial:
                      advanced:
                         pan_id: 0x1A79
                         channel: 14
                         legacy_api: false
                         output: json
                         transmit_power: 20
                         log_level: warn
                      device_options:
                         legacy: false
                      availability: true
                      $ npm start
                      > node index.js
                      D
                      D
                      dimaiv
                      #200
                      @liv-in-sky
                      Hier werden nur Verkaufsfragen beantwortet.
                      Bitte für Z2M ein eigenen Thread auf machen.
                      Danke.
                      ioBroker- NUC8i3 / Proxmox / VM
                      Node.js v22.21.0
                      NPM v10.9.4
                      JS controller 7.1.0
                      Admin 7.7.20
                      ZigBee Adapter 3.3.1alpha.0
                      Zigbee LAN Gateway CC2652P
                      Zigbee Firmware 20250321
                      liv-in-skyL CodierknechtC 2 Antworten Letzte Antwort
                        weil proxmox lxc
                        hab ich auch
                        liv-in-skyL
                        liv-in-skyL
                        #201
                        @crunchip hast du die anleitung auf der zigbee2mqtt anleitung für linux gemacht ?
                        • D dimaiv
                          @liv-in-sky
                          Danke.
                          liv-in-skyL
                          liv-in-skyL
                          #202
                          @dimaiv sorry - mach ich
                          • T
                            T
                            toralt
                            schrieb am zuletzt editiert von toralt
                            #203
                            @dimaiv said in [Verkaufe] Zigbee LAN/USB/WLAN Gateway CC2652P:
                            CC1352P2_CC2652P_launchpad_coordinator_xxxxxxxx
                            @dimaiv nachdem ich gestern ein FW update gemacht hatte mir der o.g. Datei ging bei mir leider gar nichts mehr. Alles war langsam, keine Geräte wurden mehr gefunden. Es hat eine Weile gedauert, bis ich darauf gekommen bin, dass ich die falsche FW Datei hatte.
                            Laut https://zig-star.com/radio-docs/quick-start/#1plug-your-device-in konnte ich dann feststellen, dass der Ebyte E72 Chip, welcher bei mir verbaut ist, die CC1352P2_CC2652P_other_coordinator_xxxxxxxxx FW benötigt. Die Erkenntnis hat eine Weile gebraucht. Nochmal neu geflasht und alles ging wieder. Hast Du zwischenzeitlich den Chip gewechselt?
                            Die CC1352P2_CC2652P_launchpad_coordinator_xxxxxxxx FW ist laut Zigstar nur für den RF-STAR Chip. Oder müssten beide gehen und ich hab da was falsch verstanden? Will nur anderen evtl Kummer ersparen 🤘
                            << ioBroker im Docker auf Synology DS1821+, 10GBit, 32GB RAM>>
                            • KusselinK
                              KusselinK
                              Kusselin
                              schrieb am zuletzt editiert von Kusselin
                              #204
                              Hallo Zusammen, ich habe mir jetzt auch solch ein Stick bei Dimaiv bestellt da mein CC2531 langsam abschmiert.
                              Nun meine Fragen:
                              1. wenn der Stick kommt, schließe ich den direkt per lAN an dien Unifi switch an... lasse ich da meinen jetzigen CC2531 noch dran und richte parallel den neuen ein.. und ziehe erst dann den CC2531 ab, oder ziehe ich gleich den CC2531 ab?
                              2. kann ich den neuen Stick jetzt auch mit POE versorgen..langt das?
                              3. Wenn nicht kann ich mit usb zb Strom vom usb der Fritzbox 7590 holen? Hab keine Steckdosen mehr 🙈
                              4. Der Port 6638 ist immer gleich oder muss ich den selbst konfigurieren und einstellen?
                              5. Muss ich zwingend was vor dem Anschließen des neuen Sticks was an der PAN ID ändern oder so?
                              6. Muss der Adapter zwingend erst ausgeschaltet werden beim anstecken des neuen Sticks?
                              Sorry für die vielen Fragen..will halt nix falsch machen.
                              Über die Beantwortung herzlichen Dank.
                              Gruss
                              AsgothianA BananaJoeB 2 Antworten Letzte Antwort
                              • KusselinK Kusselin
                                Nun meine Fragen:
                                Gruss
                                AsgothianA
                                AsgothianA
                                Asgothian
                                #205
                                @kusselin sagte in [Verkaufe] Zigbee LAN/USB/WLAN Gateway CC2652P:
                                Nun meine Fragen:
                                Du kannst ihn direkt anschliessen und die Einrichtung des Sticks selber durchführen (IP herausfinden, sicherstellen das er strom hat etc.
                                1. kann ich den neuen Stick jetzt auch mit POE versorgen..langt das?
                                soweit ich weiss nicht.
                                1. Wenn nicht kann ich mit usb zb Strom vom usb der Fritzbox 7590 holen? Hab keine Steckdosen mehr 🙈
                                Das müsste eigentlich gehen.
                                1. Der Port 6638 ist immer gleich oder muss ich den selbst konfigurieren und einstellen?
                                2. Muss ich zwingend was vor dem Anschließen des neuen Sticks was an der PAN ID ändern oder so?
                                Nein - das sind alles Parameter des Adapters. Die werden erst interessant wenn du dem Adapter den neuen Stick bekannt machst.
                                1. Muss der Adapter zwingend erst ausgeschaltet werden beim anstecken des neuen Sticks?
                                Beim Anstecken - nein. Allerdings macht es Sinn den Adapter anzuhalten wenn du den bestehenden CC2531 abziehst, dann etwas warten und dann erst den Adapter mit den Parametern für den neuen Stick starten (TCP Verbindung, etc.)
                                Gruss
                                  Nun meine Fragen:
                                  Gruss
                                  BananaJoeB
                                  BananaJoeB
                                  BananaJoe
                                  #206
                                  kannst du, siehe Beiträge weiter oben. Du brauchst einen Adapter der aus dem PoE die 5V auf USB-C raushoolt und das Netzwerk durchreicht, z.B. https://www.amazon.de/gp/product/B08HS6NDM2
                                  Ein USB-Kabel von der FritzBox und deren USB Port sollte auch gehen
                                  Wenn du die IP rausbekommen hast - das Ding hat auch eine Weboberfläche wo man dann z.B. auch eine feste IP-Adresse einstellen kann
                                  KusselinK 1 Antwort Letzte Antwort
                                  • BananaJoeB BananaJoe
                                    KusselinK
                                    KusselinK
                                    Kusselin
                                    #207
                                    @bananajoe hi danke dir...ich habe von ubiquiti den poe 24 layer 2 switch.....
                                    Also so direkt über den LAN Port dann gehts nicht?
                                      BananaJoeB
                                      BananaJoeB
                                      BananaJoe
                                      #208
                                      @kusselin nein, nur mit dem Adapter dazwischen. Da ist keine PoE Logik in diesem Gateway. Da passiert dann einfach nichts. Erst wenn du dann extern mit Strom versorgst
                                        KusselinK
                                        KusselinK
                                        Kusselin
                                        #209
                                        @bananajoe ok danke Dir dann mach ich’s über die usb Buchse der nebenstehenden fritz7590 die ich für die Telefonie verwende👍
                                        • D dimaiv
                                          @liv-in-sky
                                          Danke.
                                          CodierknechtC
                                          CodierknechtC
                                          Codierknecht
                                          #210
                                          @dimaiv
                                          Danke für die prompte Lieferung 👍
                                          Inbetriebnahme lief etwas holprig, da er sich am GB-Switch nicht sauber verbinden wollte.
                                          Nachdem ich auf einen freien Port meines PoE-Switches gewechselt habe. lief alles auf Anhieb.
                                          HmIP|ZigBee|Tasmota|Unifi
                                          Zabbix Certified Specialist
                                          83.9k
