  3. Marktplatz
  4. [Verkaufe] Zigbee LAN/USB/WLAN Gateway CC2652P
Geplant Angeheftet Gesperrt Verschoben Marktplatz
236 Beiträge 54 Kommentatoren 99.7k Aufrufe 53 Beobachtet
  • qqolliQ qqolli
    @dimaiv
    Ok, sorry:
    zigbee.0
    2022-07-23 16:41:49.738	error	Error herdsman start
    zigbee.0
    2022-07-23 16:41:49.738	error	Failed to start Zigbee
    zigbee.0
    2022-07-23 16:41:49.737	error	Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
    zigbee.0
    2022-07-23 16:41:49.736	error	Re-commissioning your network will require re-pairing of all devices!
    zigbee.0
    2022-07-23 16:41:49.736	error	If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
    zigbee.0
    2022-07-23 16:41:49.736	error	Please update configuration to prevent further issues.
    zigbee.0
    2022-07-23 16:41:49.736	error	- Channel List: configured=11, adapter=11
    zigbee.0
    2022-07-23 16:41:49.736	error	- Network Key: configured=01030507090b0d0f00020406080a0c0d, adapter=01030507090b0d0f00020406080a0c0d
    zigbee.0
    2022-07-23 16:41:49.736	error	- Extended PAN ID: configured=4d1517db8593869a, adapter=00124b00257910df
    zigbee.0
    2022-07-23 16:41:49.735	error	- PAN ID: configured=6745, adapter=6754
    zigbee.0
    2022-07-23 16:41:49.735	error	Configuration is not consistent with adapter state/backup!
    zigbee.0
    2022-07-23 16:41:48.537	info	Installed Version: iobroker.zigbee@1.7.5
    zigbee.0
    2022-07-23 16:41:48.535	debug	Starting zigbee-herdsman...
    zigbee.0
    2022-07-23 16:41:48.535	info	Starting Zigbee npm ...
    zigbee.0
    2022-07-23 16:41:48.534	info	Try to reconnect.
    Wie gesagt, Hatte die erweiterte Pan ID und Pan ID geändert, Transportschlüssel erstmal so gelassen. Jetzt meckert er deswegen :-)
    Edit: Oder soll ich mal, wie weiter oben empfohlen die unter /opt/iobroker/iobroker-data/zigbee_0 die vorhandenen Dateien (shepherd.db, nvbackup.json) löschen und Adapter neu starten?
    Dominik F.D
    Dominik F.D
    Dominik F.
    #183
    @qqolli
    Ich hatte auch folgende Unterschiede gehabt und hab das die genommen, die der Adapter hatte und dann hat es funktioniert:
    zigbee.0
    zigbee.0
    • D dimaiv
      @qqolli
      1. Stoppen Zigbee Adapter!!!
      2. Mach das was im Log steht "If you wish to...."
      3. Starte Zigbee Gateway neu.
      4. Starte Zigbee Adapter.
      qqolliQ
      qqolliQ
      qqolli
      #184
      @dimaiv
      Na super! Jetzt geht er. Und die Werte von @Dominik-F hatte ich auch noch eingetragen:
      Vielen Dank!
      • BananaJoeB
        BananaJoeB
        BananaJoe
        #185
        @qqolli eines von beiden hätte es getan :-) Aber so ist auch ok
        qqolliQ 1 Antwort Letzte Antwort
        • BananaJoeB BananaJoe
          qqolliQ
          qqolliQ
          qqolli
          #186
          @bananajoe
          Stimmt, aber du weißt ja: Viel hilft viel 😀
          Jetzt graut es mir nur noch vor der Umstellung, da ich mein Produktivsystem immer noch auf Raspi mit ConBee 2 laufen habe. ioB auf Proxmox mit dem Gateway läuft super und die Umstellung wird interessant :-) Obwohl es eigentlich per BackitUp "einfach" gehen müsste; soweit die Theorie.
          • D dimaiv
            Hersteller " Ich "
            Model "CC2652P + WT32-ETH01, Einsatzbereit"
            Anzahl 1, Sofort verfügbar
            *Preis pro Stück 60 €, Anfragen über Chat Nachricht oder Telegramm: https://t.me/Zigbee1
            Versand "in DE inkl., mit Verfolgungsnummer"
            Beschreibung "Leistungsstarke ZigBee Stick / LAN Gateway mit Z-Stack 3.x.0, Update über LAN/USB, mit 3 dBi Antenne und Gehäuse"
            Es gibt ab sofort Diskussion-Thread:
            FAQ. Zigbee Gateway
            M
            M
            michihorn
            schrieb am zuletzt editiert von michihorn
            #187
            @dimaiv Danke für die super schnelle Lieferung.
            Installation war einfach, klappte auf Anhieb, dass Übertragen der Daten dauert zuerst ein paar Minuten.
            Der Leistungsgewinn ist überragend.
            Habe den Stick im übrigen im Ferienhaus installiert, das ist über VPN mit der Heimat verbunden ist. Ich habe eine zusätzliche Zigbee Instance aufgelegt. So entfällt die MQTT Übertragung. 👍
            • R
              R
              Rushmed
              schrieb am zuletzt editiert von Rushmed
              #188
              @dimaiv Danke für die schnelle Lieferung. Stick läuft. Danke auch für die Anleitung.
              Das Ding hat ja sogar WiFi.
              • T
                T
                Tobias 0
                schrieb am zuletzt editiert von Tobias 0
                #189
                @dimaiv Danke für die schnelle Lieferung und die Erklärung vorab per telegram. Es war schon fast zu einfach. Anstecken, IP-Eintragen und warten bis der Adapter Grün wurde. Alle geräte blieben erhalten beim Wechsel und die angezeigte Leistung hat sich beim schwächsten Empfänger um 50 verbessert. Also was soll man sagen einfach perfekt! 👍
                • D dimaiv
                  Hersteller " Ich "
                  FAQ. Zigbee Gateway
                  liv-in-skyL
                  liv-in-skyL
                  #190
                  @dimaiv
                  erstmal vielen dank für die schnelle lieferung :-)
                  ich wollte das ganze nun mit zigbee2mqtt installieren
                  meine configuration.yaml sieht so aus:
                  homeassistant: false
                  permit_join: true
                  frontend:
                     port: 8080
                     host: 0.0.0.0
                  mqtt:
                     base_topic: zigbee2mqtt
                     server: mqtt://192.168.178.59:1890
                  serial:
                     port: 'tcp://192.168.178.141:6638'
                  advanced:
                     pan_id: 0x1A79
                     ext_pan_id: [0xDD, 0xDD, 0xDD, 0xDD, 0xAA, 0xAD, 0xDD, 0xDD]
                     channel: 14
                     network_key: [0x01, 0x03, 0x05, 0x07, 0x09, 0x0B, 0x0D, 0x0F, 0x00, 0x02, 0x04, 0x06, 0x08, 0x0A>
                     last_seen: ISO_8601_local
                     homeassistant_legacy_entity_attributes: false
                     legacy_api: false
                     legacy_availability_payload: false
                     output: json
                     transmit_power: 20
                     log_level: warn
                  device_options:
                     legacy: false
                  availability: true
                  beim aufruf des servers kommt aber:
                  $ npm start
                  > zigbee2mqtt@1.28.2 start
                  > node index.js
                  Zigbee2MQTT:info  2022-11-20 08:33:09: Logging to console and directory: '/opt/zigbee2mqtt/data/log/2022-11-20.08-33-09' filename: log.txt
                  Zigbee2MQTT:info  2022-11-20 08:33:09: Starting Zigbee2MQTT version 1.28.2 (commit #e66fe85)
                  Zigbee2MQTT:info  2022-11-20 08:33:09: Starting zigbee-herdsman (0.14.68)
                  Zigbee2MQTT:error 2022-11-20 08:33:09: Error while starting zigbee-herdsman
                  Zigbee2MQTT:error 2022-11-20 08:33:09: Failed to start zigbee
                  Zigbee2MQTT:error 2022-11-20 08:33:09: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
                  Zigbee2MQTT:error 2022-11-20 08:33:09: Exiting...
                  Zigbee2MQTT:error 2022-11-20 08:33:09: Error: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0'
                      at SerialPort.<anonymous> (/opt/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/z-stack/znp/znp.ts:146:28)
                      at SerialPort._error (/opt/zigbee2mqtt/node_modules/@serialport/stream/lib/index.js:198:14)
                      at /opt/zigbee2mqtt/node_modules/@serialport/stream/lib/index.js:242:12
                  irgendwie will er /dev/ttyACM0 - ist aber anders konfiguriert - hättest du eine idee für mich
                  crunchipC D 2 Antworten Letzte Antwort
                  • liv-in-skyL liv-in-sky
                    @dimaiv
                    permit_join: true
                    frontend:
                       port: 8080
                       host: 0.0.0.0
                    mqtt:
                    serial:
                    advanced:
                       pan_id: 0x1A79
                       channel: 14
                       legacy_api: false
                       output: json
                       transmit_power: 20
                       log_level: warn
                    device_options:
                       legacy: false
                    availability: true
                    $ npm start
                    > node index.js
                    crunchipC
                    crunchipC
                    Developer Global Moderator Most Active Forum Testing
                    #191
                    @liv-in-sky hast du z2m auch neu gestartet?
                      liv-in-skyL
                      liv-in-skyL
                      #192
                      @crunchip ja - habe ich
                        crunchipC
                        crunchipC
                        #193
                        @liv-in-sky sagte in [Verkaufe] Zigbee LAN/USB/WLAN Gateway CC2652P:
                        bei mir ist das so eingetragen, vllt liegts daran
                        serial:
                          port: tcp://10.1.20.7:20108
                          serial:
                          liv-in-skyL
                          liv-in-skyL
                          #194
                          @crunchip habe es lt: https://forum.iobroker.net/post/693392 gemacht
                          aber habe auch mal deines getestet - kommt leider die selbe fehlermeldung
                            crunchipC
                            crunchipC
                            #195
                            @liv-in-sky na ich meine ohne die ' '
                            stick ist erreichbar?
                            liv-in-skyL 3 Antworten Letzte Antwort
                              liv-in-skyL
                              liv-in-skyL
                              #196
                              @crunchip ohne und mit probiert - mit habe probiert, weil hier:
                              aber ich denke da fehlt was anderes, weil im fehler immer auf den cannot open /dev/ttyACM0 hingewiesen wird
                                liv-in-skyL
                                liv-in-skyL
                                #197
                                @crunchip sagte in [Verkaufe] Zigbee LAN/USB/WLAN Gateway CC2652P:
                                wie stell ich das fest - weiß nur er ist im netzwerk mit ip
                                  liv-in-skyL
                                  liv-in-skyL
                                  #198
                                  @crunchip
                                  könnte es ein problem sein, weil proxmox lxc ??
                                    crunchipC
                                    crunchipC
                                    #199
                                    @liv-in-sky vllt passt der port nicht
                                    weil proxmox lxc
                                    hab ich auch
                                    hab von hier installiert
                                      @dimaiv
                                      permit_join: true
                                      frontend:
                                         port: 8080
                                         host: 0.0.0.0
                                      mqtt:
                                      serial:
                                      advanced:
                                         pan_id: 0x1A79
                                         channel: 14
                                         legacy_api: false
                                         output: json
                                         transmit_power: 20
                                         log_level: warn
                                      device_options:
                                         legacy: false
                                      availability: true
                                      $ npm start
                                      > node index.js
                                      D
                                      D
                                      dimaiv
                                      #200
                                      @liv-in-sky
                                      Hier werden nur Verkaufsfragen beantwortet.
                                      Bitte für Z2M ein eigenen Thread auf machen.
                                      Danke.
                                      ioBroker- NUC8i3 / Proxmox / VM
                                      Node.js v24.23.3
                                      NPM v11.19.1
                                      JS controller 7.2.5
                                      Admin 8.3.15
                                      ZigBee Adapter 3.6.1
                                      Zigbee LAN Gateway CC2652P
                                      Zigbee Firmware 20250321
                                      liv-in-skyL CodierknechtC 2 Antworten Letzte Antwort
                                        weil proxmox lxc
                                        hab ich auch
                                        liv-in-skyL
                                        liv-in-skyL
                                        #201
                                        @crunchip hast du die anleitung auf der zigbee2mqtt anleitung für linux gemacht ?
                                        • D dimaiv
                                          @liv-in-sky
                                          Danke.
                                          liv-in-skyL
                                          liv-in-skyL
                                          #202
                                          @dimaiv sorry - mach ich
                                          33.2k
                                          84.3k
