  5. Mit Blockly das Shelly 1 ein/aus über Solar Ertrag.
220 Beiträge 11 Kommentatoren 38.0k Aufrufe 8 Beobachtet
  • W WilliKlein
      <variables>
        <variable id="%f2p3[xiEK;T;hxSX|t5">shelly</variable>
      </variables>
      <block type="variables_set" id="k)@FiWDGHXsZ,SHM}1zS" x="300" y="-111">
        <field name="VAR" id="%f2p3[xiEK;T;hxSX|t5">shelly</field>
        <value name="VALUE">
          <block type="get_value" id="MfV3iIf5#Fx*F#SPbAd`">
            <field name="OID">shelly.0.shellyplus1#7c87ce63d85c#1.Relay0.Switch</field>
          </block>
        </value>
        <next>
          <block type="on_ext" id="_f?n?9+^x32}4r=j(lF0">
            <value name="OID0">
              <shadow type="field_oid" id="Bbh1E/},e./{_Yf3_;px">
                <field name="oid">growatt.0.1030054.devices.DFK0BKD00C.historyLast.ppv</field>
              </shadow>
            </value>
            <statement name="STATEMENT">
              <block type="controls_if" id="5^_]~A*IAxXr.+z+,O|g">
                <value name="IF0">
                  <block type="logic_compare" id="9@jz$j=TVGPXYwK_N1tl">
                    <field name="OP">LT</field>
                    <value name="A">
                      <block type="on_source" id="3O1($TjuU2zLP#.u6(]l">
                      </block>
                    </value>
                    <value name="B">
                      <block type="math_number" id=")G`AERK`8@25wu`}x;HJ">
                        <field name="NUM">3000</field>
                      </block>
                    </value>
                  </block>
                </value>
                <statement name="DO0">
                  <block type="variables_set" id="eb+o#xx@Yv#zEjH3[c8,">
                      <block type="logic_boolean" id="^9S9/{$K~z:7}vXy+vXd">
                      </block>
                    </value>
                  </block>
                </statement>
                <value name="IF1">
                  <block type="logic_compare" id="Hk1ghg;eIF}mNq~qg2$N">
                    <field name="OP">GT</field>
                    <value name="A">
                      <block type="on_source" id=";GgYm,hYSX3/.3FCVqb^">
                      </block>
                    </value>
                    <value name="B">
                      <block type="math_number" id="`=4-0(|xgYJ{WIg_dctO">
                        <field name="NUM">3500</field>
                      </block>
                    </value>
                  </block>
                </value>
                <statement name="DO1">
                  <block type="variables_set" id="SDx9dFe8-XqT~?PP,265">
                      <block type="logic_boolean" id="^aFhyq!(ta2DJm$2qCtt">
                      </block>
                    </value>
                  </block>
                </statement>
                <next>
                  <block type="controls_if" id="9q!Zk#Vc?c9EX$:Z9zUK">
                    <value name="IF0">
                      <block type="logic_compare" id="43Vu=|/wYh`tM*c*dc-J">
                        <field name="OP">NEQ</field>
                        <value name="A">
                          <block type="variables_get" id="*xID|?TLTij`-[+2G4K[">
                          </block>
                        </value>
                        <value name="B">
                          <block type="get_value" id="}|Y8Zi|6j(ivB?Z+tt}8">
                          </block>
                        </value>
                      </block>
                    </value>
                      <block type="control" id="12N5$JSuj7~#-O,zt39W">
                        <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="true"></mutation>
                        <field name="DELAY_MS">1000</field>
                        <field name="UNIT">ms</field>
                          <block type="variables_get" id="P@N|PbiTOZ:Bo}3[.)SG">
                          </block>
                        </value>
                      </block>
                    </statement>
                  </block>
                </next>
              </block>
            </statement>
          </block>
        </next>
      </block>
    </xml>
    W Offline
    W Offline
    WilliKlein
    @williklein said in Mit Blockly das Shelly 1 ein/aus über Solar Ertrag.:
    ich weiss nicht wie ich das zurückschicken kann
    DJMarc75D paul53P 2 Antworten Letzte Antwort
    • W WilliKlein
      DJMarc75D Offline
      DJMarc75D Offline
      DJMarc75
      @williklein @paul53 hat Dir ein Blockly geschickt.... was willst Du denn warum zurückschicken ??
      Lehrling seit 1975 !!!
      • W WilliKlein
        @williklein sagte: ich weiss nicht wie ich das zurückschicken kann
        Als Bild.
        Was soll das?
        W 1 Antwort Letzte Antwort
          Als Bild.
          Was soll das?
          W Offline
          W Offline
          WilliKlein
          ich wollte meine Änderung exportieren. Ich bin nicht gut in der Bedienung. Du hast mir das geschickt, ich habe es importiert, dann geändert und wollte es zurückschicken, ob ich es richtig gemacht habe. Das ist wohl daneben gegangen.
          • W WilliKlein
            @williklein sagte: Das ist wohl daneben gegangen.
            Nein, aber die Bedingungen lauten jetzt bei dir: Bei hohem Solarertrag Shelly ausschalten und bei niedrigem Solarertrag Shelly einschalten.
              W Offline
              W Offline
              WilliKlein
              ja ich möchte das natürlich testen und im Moment ist der Ertrag 0.
              Ich habe an demshelly eine Lampe und möchte die zum Leuchten bringen.
              Ich habe im Leitfaden gelesen, habs aber auch nicht verstanden
              If Then variable <10
              Schalter ein
              else
              Schalter aus
              endif
              Das ist für mich logisch. In Blockly kriege ich das nicht hin.
              crunchipC HomoranH 2 Antworten Letzte Antwort
              • W WilliKlein
                Schalter ein
                else
                Schalter aus
                endif
                crunchipC Abwesend
                crunchipC Abwesend
                  W Offline
                  W Offline
                  WilliKlein
                  @crunchip
                  OK, der shelly spinet von false auf true um, aber das Licht geht nicht an.
                  Ist das dann der falsch é Datenpunkt ?
                  DJMarc75D crunchipC W 3 Antworten Letzte Antwort
                  • W WilliKlein
                    @crunchip
                    DJMarc75D Offline
                    DJMarc75D Offline
                    DJMarc75
                    @williklein Wenn Du uns das Blockly zeigen würdest dann kann man bestimmt auch helfen.
                    • W WilliKlein
                      Schalter ein
                      else
                      Schalter aus
                      endif
                      @williklein sagte in Mit Blockly das Shelly 1 ein/aus über Solar Ertrag.:
                      wenn das dein Kriterium sein soll muss das hier der Trigger sein.
                      und die anschließende Logik machst du genau so wie dort.
                      • W WilliKlein
                        @crunchip
                        crunchipC Abwesend
                        crunchipC Abwesend
                        @williklein das musst du im shelly einstellen, ob schalter, steckdose, taster, ob`s relais geschaltet werden soll....
                        hier als Beispiel
                        • W WilliKlein
                          @crunchip
                          W Offline
                          W Offline
                          WilliKlein
                          @crunchip
                          Warum schaltet der shelly nicht, steht immer noch auf false
                          • W WilliKlein
                            @crunchip
                            wie sollte er?
                            @homoran sagte in Mit Blockly das Shelly 1 ein/aus über Solar Ertrag.:
                            die Zeit muss in die Logik.
                            der Auslöser soll doch die Solareinspeisung/produktion sein
                            bei dir löst die Uhrzeit (heute 0:01 -0:59) aus
                              wie sollte er?
                              W Offline
                              W Offline
                              WilliKlein
                              OK ich hatte nicht alle Stunden eingestellt. Jetzt schaltet der ein. Ich wollte erst mal sehen ob der überhaupt schaltet.
                              Unten steht jetzt die Version wie ich sie gerne erstmal zum Schalten bringen möchte. Das geht jetzt noch nicht.
                              HomoranH paul53P crunchipC 3 Antworten Letzte Antwort
                              • W WilliKlein
                                ist trotzdem Blödsinn.
                                dann lass lieben den Trigger weg, dann passiertvder Rest einmalig beim Skriptstart/abspeichern.
                                ich denke das letzte falls gehört unter das andere falls/sonstfalls und nich in das sonstfalls
                                  W Offline
                                  W Offline
                                  WilliKlein
                                  des erste war nur ein Test, weil ich den shelly überhaupt nicht zum schalten bekommen habe, das lösche ich natürlich.
                                  • W WilliKlein
                                    Tests sind wichtig. Muss man aber richtig machen!
                                    ein Zeitraum als Trigger nutzt gar nichts bei diesem Skript. er ist nur gestartet, weil du es innerhalb des Zeitraums gespeichert hast
                                    • W WilliKlein
                                      @williklein sagte: Unten steht jetzt die Version wie ich sie gerne erstmal zum Schalten bringen möchte. Das geht jetzt noch nicht.
                                      Ist auch falsch. Richtig:
                                      • W WilliKlein
                                        crunchipC Abwesend
                                        crunchipC Abwesend
                                        einfach den Datenpunkt in den Objekten umschalten, dann weisst du ob er schaltet, aber wie gesagt, du musst den shelly erstmal einstellen
                                          W Offline
                                          W Offline
                                          WilliKlein
                                          @crunchip
                                          jetzt passen der Wert und das shelly Dings da nicht rein.
                                          HomoranH W crunchipC 3 Antworten Letzte Antwort
