  4. js-controller 3.3 jetzt im STABLE!
    apollon77A
344 Beiträge 61 Kommentatoren 140.6k Aufrufe 46 Beobachtet
  • SMSS SMS
    @thomas-braun also das ist keine Desktop Version, sondern die "Lite". Gerade mal bei den anderen PI's geschaut, dort gibt es den Eintrag "GPU_mem" auch nicht.
    Thomas BraunT
    Thomas BraunT
    #268
    @sms
    Hast du den denn jetzt eingetragen?
    SMSS 1 Antwort Letzte Antwort
      @sms
      SMSS
      SMSS
      SMS
      schrieb am zuletzt editiert von SMS
      #269
      @thomas-braun ausprobiert ja, keine Änderung
      # For more options and information see
      # http://rpf.io/configtxt
      # Some settings may impact device functionality. See link above for details
      # uncomment if you get no picture on HDMI for a default "safe" mode
      #hdmi_safe=1
      # uncomment this if your display has a black border of unused pixels visible
      # and your display can output without overscan
      #disable_overscan=1
      # uncomment the following to adjust overscan. Use positive numbers if console
      # goes off screen, and negative if there is too much border
      #overscan_left=16
      #overscan_right=16
      #overscan_top=16
      #overscan_bottom=16
      # uncomment to force a console size. By default it will be display's size minus
      # overscan.
      #framebuffer_width=1280
      #framebuffer_height=720
      # uncomment if hdmi display is not detected and composite is being output
      #hdmi_force_hotplug=1
      # uncomment to force a specific HDMI mode (this will force VGA)
      #hdmi_group=1
      #hdmi_mode=1
      # uncomment to force a HDMI mode rather than DVI. This can make audio work in
      # DMT (computer monitor) modes
      #hdmi_drive=2
      # uncomment to increase signal to HDMI, if you have interference, blanking, or
      # no display
      #config_hdmi_boost=4
      # uncomment for composite PAL
      #sdtv_mode=2
      #uncomment to overclock the arm. 700 MHz is the default.
      #arm_freq=800
      # Uncomment some or all of these to enable the optional hardware interfaces
      dtparam=i2c_arm=on
      #dtparam=i2s=on
      dtparam=spi=off
      # Uncomment this to enable infrared communication.
      #dtoverlay=gpio-ir,gpio_pin=17
      #dtoverlay=gpio-ir-tx,gpio_pin=18
      # Additional overlays and parameters are documented /boot/overlays/README
      # Enable audio (loads snd_bcm2835)
      dtparam=audio=on
      [pi4]
      # Enable DRM VC4 V3D driver on top of the dispmanx display stack
      dtoverlay=vc4-fkms-v3d
      max_framebuffers=2
      [all]
      #dtoverlay=vc4-fkms-v3d
      enable_uart=1
      dtoverlay=w1-gpio
      gpu_mem=32
      Trage ich 16 statt 32 ein, kommt zwar keine Fehlermeldung, aber der TV wird dunkel und es geht nicht weiter ...
      • NegaleinN
        NegaleinN
        Negalein
        #270
        Hallo
        Habe heute den JS-Controller auf 3.3.22 upgedatet.
        Lt. Info ist er jetzt auf 3.3.22
        Aber ich bekam Fehler beim Update.
        Was haben die zu bedeuten?
        nega@ioBroker:~$ iob upgrade self
        Update js-controller from @3.3.19 to @3.3.22
        NPM version: 6.14.13
        npm install iobroker.js-controller@3.3.22 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
        /bin/sh: 1: cmake: not found
        make: *** [config_deps.target.mk:13: /opt/iobroker/node_modules/cpu-features/deps/cpu_features/build/Makefile] Error 127
        gyp ERR! build error
        gyp ERR! stack Error: `make` failed with exit code: 2
        gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
        gyp ERR! stack     at ChildProcess.emit (events.js:375:28)
        gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:277:12)
        gyp ERR! System Linux 5.11.22-5-pve
        gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
        gyp ERR! cwd /opt/iobroker/node_modules/cpu-features
        gyp ERR! node -v v14.17.1
        gyp ERR! node-gyp -v v5.1.0
        gyp ERR! not ok
        ° Fixer ---> iob fix
        liv-in-skyL Thomas BraunT 2 Antworten Letzte Antwort
        • NegaleinN Negalein
          Hallo
          gyp ERR! not ok
          liv-in-skyL
          liv-in-skyL
          #271
          @negalein
          evtl hilft das
          https://forum.iobroker.net/topic/50461/error-bei-adapter-updates-bin-sh-1-cmake-not-foundmake?_=1640161794760
          oder hier
          https://forum.iobroker.net/topic/47576/adapter-updates-fehler-cmake-not-found?_=1640161794767
          • liv-in-skyL liv-in-sky
            @negalein
            evtl hilft das
            oder hier
            NegaleinN
            NegaleinN
            Negalein
            #272
            @liv-in-sky sagte in js-controller 3.3 jetzt im STABLE!:
            evtl hilft das
            Merci
            hab gesucht und nichts gefunden.
            Aber hätt ich nach cmake und nicht nach ckmake gesucht, wäre ich fündig geworden! 😂
              Hallo
              gyp ERR! not ok
              Thomas BraunT
              Thomas BraunT
              #273
              @negalein
              cmake: not found
              bedeutet, dass das Paket cmake fehlt. Nachinstallieren.
              NegaleinN apollon77A 2 Antworten Letzte Antwort
                @negalein
                cmake: not found
                NegaleinN
                NegaleinN
                Negalein
                #274
                @thomas-braun sagte in js-controller 3.3 jetzt im STABLE!:
                cmake: not found
                schon erledigt :)
                  evtl hilft das
                  Merci
                  liv-in-skyL
                  liv-in-skyL
                  #275
                  @negalein
                  hatte das problem auch - @Thomas-Braun hatte damals geholfen - daher wußte ich, dass es threads gibt :-)
                  • crunchipC
                    crunchipC
                    Developer Global Moderator Most Active Forum Testing
                    #276
                    gerade das update angestoßen, daher nun die Frage, ging da was schief bzw ist das relevant?
                    root@IoBroker:~# iob upgrade self
                    Update js-controller from @3.3.21 to @3.3.22
                    NPM version: 6.14.15
                    In file included from ../src/binding.cc:1:
                    /home/iobroker/.cache/node-gyp/14.18.2/include/node/node.h:787:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUN                            CTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)                            ’} [-Wcast-function-type]
                           (node::addon_register_func) (regfunc),                          \
                    /home/iobroker/.cache/node-gyp/14.18.2/include/node/node.h:821:3: note: in expansion of macro ‘NODE_MODULE_X’
                       NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
                    ../src/binding.cc:153:1: note: in expansion of macro ‘NODE_MODULE’
                     NODE_MODULE(cpufeatures, init)
                      Thomas BraunT
                      Thomas BraunT
                      #277
                      @crunchip
                      Nö, das ist normaler Output beim bauen von nodejs-Modulen.
                        @negalein
                        cmake: not found
                        apollon77A
                        apollon77A
                        #278
                        @thomas-braun Wir werden es im Installer hinzufügen
                        • apollon77A apollon77
                          Thomas BraunT
                          Thomas BraunT
                          #279
                          @apollon77
                          Okay. Hab noch nicht geschaut wer da immer nach cmake ruft. Auf meinem System (Raspberrry 4 / 8 GB) ist es jedenfalls nicht drauf.
                            @apollon77
                            apollon77A
                            apollon77A
                            #280
                            @thomas-braun Ein nerviges Modul node_modules/cpu-features ... https://github.com/mscdex/cpu-features/issues/1#issuecomment-930124519 :-)
                              Thomas BraunT
                              Thomas BraunT
                              #281
                              @apollon77
                              Das kommt direkt aus der nodeJS-Runtime?
                                @apollon77
                                apollon77A
                                apollon77A
                                #282
                                @thomas-braun Nee. ein npm Modul was dann irgend wo drin ist und dann in irgendeinam adapter benötigt wird nutzt cmake um seinen binären Teil zu "Builden" ... aber keiner braucht bisher cmake also ists in keinen build-essentials Paketen und nirgends sonst drin
                                  Thomas BraunT
                                  Thomas BraunT
                                  #283
                                  @apollon77
                                  Ja, cmake ist schon etwas 'exotisch'.
                                    @apollon77
                                    apollon77A
                                    apollon77A
                                    #284
                                    @thomas-braun Jupp. Ich glaube es kommt "zu uns" über ein npm modul wie ssh2 oder so was einige User im JavaScript Adapter nutzen :-)
                                    Der Installer/Fixer wird im Rahmen des Controller 4.0 Releases cmake mit als dep dazu bekommen und so überall installieren.
                                    • H
                                      H
                                      hegse
                                      schrieb am zuletzt editiert von hegse
                                      #285
                                      Gerade das Update auf die aktuellste Version gemacht.
                                      Bekomme folgende Meldung angezeigt:
                                      hegse@Iobroker:~$ iobroker upgrade self
                                      In file included from ../authenticate_pam.cc:23:
                                      ../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
                                      ../../nan/nan.h:2294:7: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                       2294 |     , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
                                      ../authenticate_pam.cc: In function ‘void after_doing_auth(uv_work_t*, int)’:
                                      ../authenticate_pam.cc:107:87: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]
                                        107 |   Nan::MakeCallback(Nan::GetCurrentContext()->Global(), Nan::New(m->callback), 1, args);
                                      ../../nan/nan.h:1026:46: note: declared here
                                       1026 |   NAN_DEPRECATED inline v8::Local<v8::Value> MakeCallback(
                                      ../authenticate_pam.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE Authenticate(Nan::NAN_METHOD_ARGS_TYPE)’:
                                      ../authenticate_pam.cc:147:83: error: no matching function for call to ‘v8::Array::Get(v8::Local<v8::String>)’
                                        147 |   Local<Value> res = options->Get(Nan::New<String>("serviceName").ToLocalChecked());
                                      In file included from /home/iobroker/.cache/node-gyp/14.18.1/include/node/node.h:67,
                                                       from ../../nan/nan.h:56,
                                      /home/iobroker/.cache/node-gyp/14.18.1/include/node/v8.h:3717:43: note: candidate: ‘v8::MaybeLocal<v8::Value> v8::Object::Get(v8::Local<v8::Context>, v8::Local<v8::Value>)’
                                       3717 |   V8_WARN_UNUSED_RESULT MaybeLocal<Value> Get(Local<Context> context,
                                      /home/iobroker/.cache/node-gyp/14.18.1/include/node/v8.h:3717:43: note:   candidate expects 2 arguments, 1 provided
                                      /home/iobroker/.cache/node-gyp/14.18.1/include/node/v8.h:3720:43: note: candidate: ‘v8::MaybeLocal<v8::Value> v8::Object::Get(v8::Local<v8::Context>, uint32_t)’
                                       3720 |   V8_WARN_UNUSED_RESULT MaybeLocal<Value> Get(Local<Context> context,
                                      /home/iobroker/.cache/node-gyp/14.18.1/include/node/v8.h:3720:43: note:   candidate expects 2 arguments, 1 provided
                                      ../authenticate_pam.cc:150:30: error: cannot convert ‘char [128]’ to ‘v8::Isolate*’
                                        150 |    serviceName->WriteUtf8(m->serviceName, sizeof(m->serviceName) - 1);
                                            |                              char [128]
                                      /home/iobroker/.cache/node-gyp/14.18.1/include/node/v8.h:3037:26: note:   initializing argument 1 of ‘int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const’ 3037 |   int WriteUtf8(Isolate* isolate, char* buffer, int length = -1,
                                      ../authenticate_pam.cc:152:69: error: no matching function for call to ‘v8::Array::Get(v8::Local<v8::String>)’
                                        152 |   res = options->Get(Nan::New<String>("remoteHost").ToLocalChecked());
                                      ../authenticate_pam.cc:155:29: error: cannot convert ‘char [128]’ to ‘v8::Isolate*’
                                        155 |    remoteHost->WriteUtf8(m->remoteHost, sizeof(m->remoteHost) - 1);
                                            |                             char [128]
                                      ../authenticate_pam.cc:160:25: error: cannot convert ‘char [128]’ to ‘v8::Isolate*’
                                        160 |  username->WriteUtf8(m->username, sizeof(m->username) - 1);
                                            |                         char [128]
                                      ../authenticate_pam.cc:161:25: error: cannot convert ‘char [128]’ to ‘v8::Isolate*’
                                        161 |  password->WriteUtf8(m->password, sizeof(m->password) - 1);
                                            |                         char [128]
                                      ../authenticate_pam.cc: At global scope:
                                      ../authenticate_pam.cc:170:6: error: variable or field ‘init’ declared void
                                        170 | void init(Handle<Object> exports) {
                                      ../authenticate_pam.cc:170:11: error: ‘Handle’ was not declared in this scope
                                      ../authenticate_pam.cc:170:24: error: expected primary-expression before ‘>’ token
                                      ../authenticate_pam.cc:170:26: error: ‘exports’ was not declared in this scope
                                      In file included from ../../nan/nan.h:56,
                                      ../authenticate_pam.cc:175:31: error: ‘init’ was not declared in this scope; did you mean ‘int’?
                                        175 | NODE_MODULE(authenticate_pam, init);
                                      /home/iobroker/.cache/node-gyp/14.18.1/include/node/node.h:787:36: note: in definition of macro ‘NODE_MODULE_X’
                                        787 |       (node::addon_register_func) (regfunc),                          \
                                      ../authenticate_pam.cc:175:1: note: in expansion of macro ‘NODE_MODULE’
                                      make: *** [authenticate_pam.target.mk:111: Release/obj.target/authenticate_pam/authenticate_pam.o] Fehler 1
                                      gyp ERR! stack     at ChildProcess.emit (events.js:400:28)
                                      gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:282:12)
                                      gyp ERR! System Linux 5.10.0-9-amd64
                                      gyp ERR! cwd /opt/iobroker/node_modules/authenticate-pam
                                      gyp ERR! node -v v14.18.1
                                      gyp ERR! not ok
                                      Soweit läuft alles nach dem Update.
                                      • H hegse
                                              |                              char [128]
                                              |                             char [128]
                                              |                         char [128]
                                              |                         char [128]
                                        gyp ERR! not ok
                                        Thomas BraunT
                                        Thomas BraunT
                                        #286
                                        @hegse
                                        Ist da zufällig der Adapter terminal installiert? Dann schmeiß den raus.
                                        H 1 Antwort Letzte Antwort
                                          @hegse
                                          H
                                          H
                                          hegse
                                          #287
                                          @thomas-braun ja der ist installiert.
                                          Alles klar, dann schmeiß ich den mal raus. Besten Dank!
                                          83.9k
