  4. [ESPHome] Beta release
591 Beiträge 48 Kommentatoren 238.9k Aufrufe 39 Beobachtet
  • S steimi
    Hi, ich versuche den Adapter zu installieren - bekomme jedoch immer die Fehlermeldung 25. Ich habe mit 'apt install python-pip' das PIP mMn installiert. Was kann ich noch tun? Iobroker läuft bei mir in einer Debian10-VM unter Proxmox. JS-Controller ist die 3.3.14 mit NODE.JS: V12.22.1 und NPM: 6.14.12
    $ iobroker add esphome auto --host iobroker-dev-01
    NPM version: 6.14.12
    npm install iobroker.esphome@0.2.3 --loglevel error --prefix "/opt/iobroker" (System call)
    Traceback (most recent call last): File "/opt/iobroker/node_modules/nopy/src/get-pip.py", line 20061, in <module> main() File "/opt/iobroker/node_modules/nopy/src/get-pip.py", line 194, in main bootstrap(tmpdir=tmpdir) File "/opt/iobroker/node_modules/nopy/src/get-pip.py", line 82, in bootstrap import pip File "/tmp/tmpcti0_mvt/pip.zip/pip/__init__.py", line 26, in <module> File "/tmp/tmpcti0_mvt/pip.zip/pip/utils/__init__.py", line 23, in <module> File "/tmp/tmpcti0_mvt/pip.zip/pip/locations.py", line 9, in <module>ImportError: cannot import name 'sysconfig' from 'distutils' (/usr/lib/python3.7/distutils/__init__.py)
    Error: Exited with code 1. at ChildProcess.<anonymous> (/opt/iobroker/node_modules/nopy/src/api.js:277:20) at ChildProcess.emit (events.js:314:20) at maybeClose (internal/child_process.js:1022:16) at Process.ChildProcess._handle.onexit (internal/child_process.js:287:5)
    npm ERR! code ELIFECYCLEnpm ERR! errno 1
    npm ERR! iobroker.esphome@0.2.3 install: `npip install`
    npm ERR! Exit status 1npm ERR! npm ERR! Failed at the iobroker.esphome@0.2.3 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
    npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2021-07-01T17_35_58_005Z-debug.log
    host.iobroker-dev-01 Cannot install iobroker.esphome@0.2.3: 1
    ERROR: Process exited with code 25
    DutchmanD Offline
    DutchmanD Offline
    Dutchman
    #198
    @steimi sagte in [ESPHome] Beta release:
    Welche Python Version?
    • DutchmanD Dutchman
      steimi
      schrieb am zuletzt editiert von steimi
      #199
      @dutchman Python: 2.7.16 und Python3: 3.7.3
      • S steimi
        DutchmanD Offline
        DutchmanD Offline
        Dutchman
        #200
        Python3: 3.7.3
        Hmm sollte passen 🤔
          Python3: 3.7.3
          Hmm sollte passen 🤔
          steimi
          #201
          @dutchman Lösung gefunden: ich musste noch mit 'apt install python3-distutils' einen Python-Teil nachinstallieren. EVtl noch was für die Doku?!
            steimi
            #202
            bei der automatischen Geräteerkennung kommt immer ein Eintrag im Log
            esphome.0 2021-07-02 09:47:35.244	error	ESPHome client 192.168.10.1 Error: connect ECONNREFUSED 192.168.10.1:6053
            Hier handelt es sich um die Gateway-Adresse meines Unifi-USG für das IoT-Netz. Was kann ich tun ausser die Geräteerkennung zu deaktivieren?
            • SlowmanS Offline
              SlowmanS Offline
              Slowman
              #203
              Habe irgendwo mir einen Fehler beim Updaten mit den Rechten, die gesicherten YAML, ins Verzeichnis kopiert, auf CMOD777 gesetzt. Speichern klappt wieder, aber leider reagiert der Log nicht (es öffnet sich das Fenster nicht). Beim Flashen geht es auf und bleibt auch.
              Irgendwelche Rechte noch vergessen zu setzen?
              • S steimi
                DutchmanD Offline
                DutchmanD Offline
                Dutchman
                #204
                das sieht eher so aus also fuer das geraet die API nicht aktiviert ist... er meldet sich per Broadcast per acceptiert dan keine verindung
                • SlowmanS Slowman
                  DutchmanD Offline
                  DutchmanD Offline
                  Dutchman
                  #205
                  @slowman sagte in [ESPHome] Beta release:
                  niemals CHMOD 777 im ioroke4r Verzeichnis, nimm bitte den fixer :
                  cd /opt/iobroker
                  iobroker stop
                  iobroker fix
                  iobroker start
                  SlowmanS 1 Antwort Letzte Antwort
                  • S steimi
                    DutchmanD Offline
                    DutchmanD Offline
                    Dutchman
                    #206
                    hattest du iobroker mit dem installer installiert oder ?
                      steimi
                      #207
                      @dutchman ja, über den Installer.
                        steimi
                        #208
                        @dutchman wie meinst du das? Die192.168.10.1 ist der Gateway meines 10er-VLANs (Ubiquity) und kein ESPhome-Device.
                        • S steimi
                          DutchmanD Offline
                          DutchmanD Offline
                          Dutchman
                          #209
                          achso, lol.... welche version vom adapter haste drauf dachte das ich diese false positives alle raus gefiltert hatte scheinbar wohl nicht
                          • S steimi
                            DutchmanD Offline
                            DutchmanD Offline
                            Dutchman
                            #210
                            und wie lange ist das ungefaehr her ? Ich habe naemlich nichts nach installieren muessen
                            A S 2 Antworten Letzte Antwort
                              Ahnungsbefreit
                              #211
                              @dutchman ich auch nicht.
                                steimi
                                #212
                                @dutchman 06.07.2019
                                  steimi
                                  #213
                                  @dutchman Version 0.2.3
                                  • S steimi
                                    DutchmanD Offline
                                    DutchmanD Offline
                                    Dutchman
                                    #214
                                    Ah ok das erklärt es glaube damals waren die Python Sachen noch nicht im installer drin
                                      cd /opt/iobroker
                                      iobroker stop
                                      iobroker fix
                                      iobroker start
                                      SlowmanS Offline
                                      SlowmanS Offline
                                      Slowman
                                      #215
                                      @dutchman
                                      Leider hat dies nichts gebracht. Problem bleibt bestehen.
                                      • SlowmanS Slowman
                                        @dutchman
                                        mrjeschke
                                        #216
                                        @slowman
                                        Hallo, hast du mal einen anderen Browser probiert. Ich habe auch das Problem das beim Klick auf Log nichts passiert.
                                        Aber nur beim Edge Browser. Bei meinen Apple-Geräten (Safari/Chrome) klappt es ohne Probleme.
                                        Der Edge-Browser bringt wohl eine Fehlermeldung.
                                        Uncaught (in promise) TypeError: t.filter is not a function
                                        at c.2472ed8e.js:1
                                        • M mrjeschke
                                          @slowman
                                          at c.2472ed8e.js:1
                                          SlowmanS Offline
                                          SlowmanS Offline
                                          Slowman
                                          #217
                                          @maik-0
                                          Mit Firefox funktioniert es, Vivaldi mag es nicht mehr. Vor dem Update ging es mit Vivaldi noch.
