  4. [ESPHome] Beta release
591 Beiträge 48 Kommentatoren 238.9k Aufrufe 39 Beobachtet
  • K klassisch
    @dutchman Vielen Dank!
    Bei mir wird jetzt Version 2.1.0 angezeigt
    Installationslog:
    $ ./iobroker url "https://github.com/Drozmotix/ioBroker.esphome"
    install Drozmotix/ioBroker.esphome#d6e97181c1e6dfa4c928be3cce5b518875494f96
    NPM version: 6.11.3
    npm install Drozmotix/ioBroker.esphome#d6e97181c1e6dfa4c928be3cce5b518875494f96 --loglevel error (System call)
    node-aead-crypto not needed on this system, since all ciphers are natively supported
    C:\Program Files\Python39\lib\site-packages\setuptools\distutils_patch.py:25: UserWarning: Distutils was imported before Setuptools. This usage is discouraged and may exhibit undesirable behaviors or errors. Please use Setuptools' objects directly or at least import Setuptools first.
     warnings.warn(
    Cache entry deserialization failed, entry ignored
    upload [5] esphome.admin C:/Program Files/iobroker/ioBrMain026/node_modules/iobroker.esphome/admin/words.js words.js application/javascript
    upload [4] esphome.admin C:/Program Files/iobroker/ioBrMain026/node_modules/iobroker.esphome/admin/style.css style.css text/css
    upload [3] esphome.admin C:/Program Files/iobroker/ioBrMain026/node_modules/iobroker.esphome/admin/index_m.html index_m.html text/html
    upload [2] esphome.admin C:/Program Files/iobroker/ioBrMain026/node_modules/iobroker.esphome/admin/img/dashboard.png img/dashboard.png image/png
    upload [1] esphome.admin C:/Program Files/iobroker/ioBrMain026/node_modules/iobroker.esphome/admin/esphome.png esphome.png image/png
    upload [0] esphome.admin C:/Program Files/iobroker/ioBrMain026/node_modules/iobroker.esphome/admin/admin.d.ts admin.d.ts video/mp2t
    Update "system.adapter.esphome.0"
    process exited with code 0
    DutchmanD Offline
    DutchmanD Offline
    Dutchman
    schrieb am zuletzt editiert von Dutchman
    #151
    @klassisch sagte in [ESPHome] Beta release:
    Installationslog:
    0.2.1-0 ;)
    • DutchmanD Dutchman
      Installationslog:
      0.2.1-0 ;)
      klassisch
      #152
      @dutchman Ja, sorry 0.2.1-0
      • FredFF Online
        FredFF Online
        FredF
        Most Active Forum Testing
        schrieb am zuletzt editiert von FredF
        #153
        @Dutchman Das wird ja immer besser mit dem Adapter 😳 Super Arbeit 👏
        Kleiner Punkt: Ich musste bei der ESPHomeDashboardIP die IP meines Hosts eintragen, localhost klappt nicht. Ist eine Proxmox VM
        Edit: Noch was, das ist leer
        • FredFF FredF
          DutchmanD Offline
          DutchmanD Offline
          Dutchman
          #154
          @fredf sagte in [ESPHome] Beta release:
          browser refresh :)
          Johannes BauerstatterJ 1 Antwort Letzte Antwort
            browser refresh :)
            Johannes BauerstatterJ Offline
            schrieb am zuletzt editiert von Johannes Bauerstatter
            #155
            @dutchman Vielen Dank. Wahnsinn was du da auf die Beine stellst.
            Irgendwie hackt etwas bei mir:
            Dashboard ist da:
            Bei Update passiert nichts und das Dashboard bleibt leer:
            localhost hat nicht funktioniert, da es ein LXC in Proxmox ist. Nach Eingabe der IoBroker IP kommt das Dashboard.
            Esphome erstell ich auf dem Laptop. Müsste ich ESPHOME in den LXC - Container installieren (wo auch IoBroker läuft) und die Geräte in Zukunt über diesen programmieren? Wäre etwas blöd da dieser Server verbaut im Keller steht....
            A DutchmanD 3 Antworten Letzte Antwort
            • Johannes BauerstatterJ Johannes Bauerstatter
              Dashboard ist da:
              Ahnungsbefreit
              #156
              @johannes-bauerstatter Ich hatte die gleiche Frage. Damit die im Dashboard erscheinen, müssen die YAML-Dateien hier liegen:
              /opt/iobroker/node_modules/iobroker.esphome/config/
              Einfach hin kopieren und freuen...
                Dashboard ist da:
                DutchmanD Offline
                DutchmanD Offline
                Dutchman
                #157
                @johannes-bauerstatter sagte in [ESPHome] Beta release:
                doku gelesen ?
                https://drozmotix.github.io/languages/de/Adapter/ESPHome/03.adapterConfig.html#esphome-dashboard
                entweder du nimmst ESPHome vom adapter, oder hast irgendwo ESPHome laufen
                Egal auf welche art, der adapter kan sich mit alle ESP Geräten verbinden solange der richtige API. pass eingetragen ist
                Ihr könnt euch selber entscheiden ob ihr das ESPHomme dashboard in ioBroker oder woanders haben wollt ;)
                  doku gelesen ?
                  #158
                  @dutchman Sorry hatte die Doku noch nicht gelesen. Vielen Dank.
                    DutchmanD Offline
                    DutchmanD Offline
                    Dutchman
                    #159
                    😂 und ich hab mir soviel mühe gegeben :P
                      Dashboard ist da:
                      DutchmanD Offline
                      DutchmanD Offline
                      Dutchman
                      #160
                      btw.... wen du keine yaml konfiguriert hast passiert da auch nix, update ist dafuer da alle zu updaten (die konfiguriert sind :)
                      E 1 Antwort Letzte Antwort
                        e-s
                        #161
                        @dutchman
                        habe inzwischen auf time based Cover umgestellt zum testen. endstop teste ich die Tage noch mal.
                        Als DP wird mir position of cover angezeigt, dieser bleibt aber immer auf 0%, flackert aber immer wieder grün auf unter objekte(wird also neu geschrieben) im esphome log kann man aber andere %Werte sehen wenn man Up/Down drückt(Relays schalten auch Ordnungsgemäß)
                        Das PW Problem besteht auch weiterhin.
                        • E e-s
                          @dutchman
                          DutchmanD Offline
                          DutchmanD Offline
                          Dutchman
                          #162
                          @e-s sagte in [ESPHome] Beta release:
                          hmm ja problem ist das die werte nicht tumber die api rein kommen, da muessen wir bestimmt irgendwas zu basteln in ESPHome das er da auch ausgibt
                          Edit : Wen ich das so lesen muessen da noch automation Aktionen rein damit die werte gesetzt werden:
                          # Example configuration entry
                          cover:
                            - platform: template
                              lambda: |-
                                if (id(top_end_stop).state) {
                                  return COVER_OPEN;
                                } else {
                                  return COVER_CLOSED;
                              open_action:
                                - switch.turn_on: open_cover_switch
                              close_action:
                                - switch.turn_on: close_cover_switch
                              stop_action:
                                - switch.turn_on: stop_cover_switch
                              optimistic: true
                          https://esphome.io/components/cover/template.html
                          ScroungerS 1 Antwort Letzte Antwort
                            cover:
                                lambda: |-
                                    return COVER_OPEN;
                                  } else {
                                open_action:
                                close_action:
                                stop_action:
                                optimistic: true
                            ScroungerS Offline
                            ScroungerS Offline
                            Scrounger
                            #163
                            @dutchman
                            Erstmal vielen Dank für den nächsten super Adapter von Dir und die gute, sehr übersichtliche Doku 👍
                            Hab heute endlich mal ein bissle testen können. Folgende Sachen sind mir aufgefallen:
                            • Adapter lässt sich nur installieren, wenn pip3 auch installiert ist, evtl. willst das mit in die Doku aufnehmen?
                            • Per Admin Webinterface (Reiter esphome.0) lässt sich EspHome Dashboard nicht öffnen, folgende Fehlermeldung kommt (Firefox):
                            • Automatic device detection denkt das meine Unifi UDM ein ESP sei:
                            2021-04-02 17:42:37.468  - info: esphome.0 (1951) [AutoDiscovery] New ESPHome device found at IP 10.25.1.1
                            2021-04-02 17:42:37.469  - info: esphome.0 (1951) Try to connect to 10.25.1.1
                            2021-04-02 17:42:37.470  - debug: esphome.0 (1951) trying to connect to 10.25.1.1
                            2021-04-02 17:42:37.472  - error: esphome.0 (1951) ESPHome client 10.25.1.1 Error: connect ECONNREFUSED 10.25.1.1:6053
                            • Wenn ich den Adapter neustarte verliert er die Verbindung zu meinem Gerät. Ich muss dann in die Adapter settings gehen, mein Gerät anklicken, edit, PW neu eingeben und Adapter Config schließen. Dann ist das Gerät wieder verbunden. Allerdings werden die States nicht aktualisiert. Im Log steht meiner Meinung nach auch nicht wirklich was. Verbindung übers Dashboard geht immer.
                              Was für Infos kann ich dir hier zum debuggen zur Verfügung stellen?
                            • ScroungerS Scrounger
                              @dutchman
                              e-s
                              #164
                              @scrounger
                              Das pw Problem habe ich auch. Wenn man die pw neu eingeben hat und danach nicht speichert oder den Adapter neu startet, laufen die esps ohne Probleme durch.
                              Nur nach Adapter Neustart werden die esps nicht angesprochen. Im debug log ist nichts zu finden.
                              Alle anderen user scheinen keine pw zu verwenden...
                              Bei mir läuft das mit Firefox ohne Probleme.
                              • X Offline
                                X Offline
                                x-traxion
                                #165
                                Vielen Dank für den Adapter. Funktioniert inzwischen echt gut.
                                Was mich allerdings etwas Stört ist die Bezeichnung der Objekte bzw. Verzeichnisse.
                                in MQTT Sieht das ganze bei mir zB. so aus:
                                mqtt.0.esp32_eg.sensor.eg_badezimmer_temp.state
                                mit dem ESPHome Adapter dann leider so:
                                esphome.0.7C9EBD072534.Sensor.1227684867.state
                                Die Bezeichnung von MQTT gefällt mir deutlich besser, da ich in FLOT oder Grafana so auch sehe welcher Datenpunkt welcher Sensor ist.
                                Wenn ich die Daten vom ESPHome Adapter nehme muss ich immer in die Objektliste schauen welche Bezeichnung welcher Sensor mit welchem Messwert ist.
                                Ich bin noch nicht so tief im Thema ioBroker drin. Kann ich das irgendwo einstellen oder müsste hierfür am Adapter etwas geändert werden?
                                Ich habe hier 2 ESP32 mit insgesamt 10 Xiaomi lywsd03mmc am laufen.
                                • X x-traxion
                                  DutchmanD Offline
                                  DutchmanD Offline
                                  Dutchman
                                  #166
                                  @x-traxion sagte in [ESPHome] Beta release:
                                  Danke das freut mich ☺️
                                  Das ist bewusst so und werde ich nicht ändern den die object Strukturen müssen unaniem sein, ohne Sonderzeichen etc daher ist es eine feste deutliche Datenbank Struktur
                                  Genau dafür ist das alias/Geräte Verwaltung gedacht sonst würde Support und troubleshoot des Adapter jegliche Grenzen in Zeit und Komplexität sprengen
                                  X 1 Antwort Letzte Antwort
                                    X Offline
                                    X Offline
                                    x-traxion
                                    #167
                                    @dutchman danke für die Info, dann mache ich mich mal dran für die ganzen Sensoren Alias zu erstellen :)
                                    • SlowmanS Offline
                                      SlowmanS Offline
                                      Slowman
                                      schrieb am zuletzt editiert von Slowman
                                      #168
                                      Bekomme im Log jetzt ständig eine Fehlermeldung:
                                      esphome.0	2021-04-28 10:33:52.864	error	(14995) Client 192.168.2.112 incorrect password !
                                      Passwort ist korrekt, habe jetzt mal das Passwort bei api das Passwort weggelassen, aber Meldung kommt weiterhin. Auch die Vergabe eines neuen Passwortes brachte nichts.
                                      # Enable Home Assistant API
                                      api:
                                        password: "soNne8"
                                      ota:
                                        password: "soNne8"
                                      In der Instanz zeigt er mir aber das er verbunden ist.
                                      Log, bei einem Restart:
                                      esphome.0	2021-04-28 10:39:53.630	error	(14995) Client 192.168.2.112 incorrect password !
                                      esphome.0	2021-04-28 10:39:50.948	info	(14995) ESPHome client saunatemperatur on ip 192.168.2.112 initialized
                                      esphome.0	2021-04-28 10:39:50.897	info	(14995) saunatemperatur announced Switch "Sauna Restart"
                                      esphome.0	2021-04-28 10:39:50.862	info	(14995) saunatemperatur announced Sensor "Humidity"
                                      esphome.0	2021-04-28 10:39:50.844	info	(14995) saunatemperatur announced Sensor "Sauna Außentemperatur"
                                      esphome.0	2021-04-28 10:39:50.829	info	(14995) saunatemperatur announced Sensor "Sauna Vorraum"
                                      esphome.0	2021-04-28 10:39:50.824	info	(14995) saunatemperatur announced Sensor "Sauna Kabine"
                                      esphome.0	2021-04-28 10:39:50.775	info	(14995) saunatemperatur announced connectivity "Sauna Status"
                                      esphome.0	2021-04-28 10:39:50.741	info	(14995) ESPHome Device info received for saunatemperatur
                                      esphome.0	2021-04-28 10:39:50.724	info	(14995) ESPHome client 192.168.2.112 connected
                                      • SlowmanS Slowman
                                        api:
                                          password: "soNne8"
                                        ota:
                                          password: "soNne8"
                                        e-s
                                        #169
                                        @slowman
                                        Der Fehler ist bekannt, wenn du das Passwort eingeben hast, danach Instanz ohne speichern beenden. Dann passt das auch. Dutchman hat den Fehler auch schon gefunden kann diesen aber aus gesundheitlichen Gründen noch nicht beseitigen.
                                        SlowmanS 1 Antwort Letzte Antwort
                                        • E e-s
                                          @slowman
                                          SlowmanS Offline
                                          SlowmanS Offline
                                          Slowman
                                          #170
                                          @e-s
                                          Hmm... ich öffne esphome, öffne die Line ID und gebe das Passwort nochmals neu ein, schliessen und mit Abrechen aus esphome raus. Feher bleibt bestehen.
