  4. Test Adapter fb-checkpresence v1.1.x
avmfb-checkpresencefritzboxtr-064
948 Beiträge 89 Kommentatoren 393.5k Aufrufe 78 Beobachtet
    @afuerhoff
    fb-checkpresence.0	2020-10-26 21:38:54.036	debug	(3661) system.adapter.admin.0: logging true
    fb-checkpresence.0	2020-10-26 21:38:49.277	info	(3661) createGlobalObjects finished successfully
    fb-checkpresence.0	2020-10-26 21:38:49.192	warn	(3661) chkService: "service X_AVM-DE_HostFilter-GetWANAccessByIP is not supported! Can not find service file! Feature is deactivated"
    fb-checkpresence.0	2020-10-26 21:38:49.192	warn	(3661) chkService: "service X_AVM-DE_HostFilter-DisallowWANAccessByIP is not supported! Can not find service file! Feature is deactivated"
    fb-checkpresence.0	2020-10-26 21:38:49.192	info	(3661) service DeviceInfo1-GetInfo is supported
    fb-checkpresence.0	2020-10-26 21:38:49.180	info	(3661) service WLANConfiguration3-GetInfo is supported
    fb-checkpresence.0	2020-10-26 21:38:49.169	info	(3661) service WLANConfiguration3-SetEnable is supported
    fb-checkpresence.0	2020-10-26 21:38:49.159	info	(3661) service WANPPPConnection1-GetInfo is supported
    fb-checkpresence.0	2020-10-26 21:38:49.147	info	(3661) service DeviceInfo1-GetSecurityPort is supported
    fb-checkpresence.0	2020-10-26 21:38:49.133	info	(3661) service Hosts1-X_AVM-DE_GetSpecificHostEntryByIP is supported
    fb-checkpresence.0	2020-10-26 21:38:49.124	info	(3661) service Hosts1-GetSpecificHostEntry is supported
    fb-checkpresence.0	2020-10-26 21:38:49.112	info	(3661) service Hosts1-X_AVM-DE_GetMeshListPath is supported
    fb-checkpresence.0	2020-10-26 21:38:49.100	info	(3661) service Hosts1-X_AVM-DE_GetHostListPath is supported
    fb-checkpresence.0	2020-10-26 21:38:49.091	debug	(3661) ssl-port {"status":200,"result":true,"resultData":{"$":{"xmlns:u":"urn:dslforum-org:service:DeviceInfo:1"},"NewSecurityPort":"49443"},"errNo":0,"errorMsg":""}
    fb-checkpresence.0	2020-10-26 21:38:49.078	debug	(3661) services loaded successfully{"root":{"$":{"xmlns":"urn:dslforum-org:device-1-0"},"specVersion":{"major":"1","minor":"0"},"systemVersion":{"HW":"233","Major":"161","Minor":"7","Patch":"13","Bui
    fb-checkpresence.0	2020-10-26 21:38:49.042	debug	(3661) configuratuion mesh info: false
    fb-checkpresence.0	2020-10-26 21:38:49.042	debug	(3661) configuration fb-devices true
    fb-checkpresence.0	2020-10-26 21:38:49.042	debug	(3661) configuration familymembers: []
    fb-checkpresence.0	2020-10-26 21:38:49.042	debug	(3661) configuration dateformat: <yyyy.mm.dd HH:MM:ss>
    fb-checkpresence.0	2020-10-26 21:38:49.042	debug	(3661) configuration history: <>
    fb-checkpresence.0	2020-10-26 21:38:49.042	debug	(3661) configuration user:
    fb-checkpresence.0	2020-10-26 21:38:49.041	info	(3661) start fb-checkpresence: ip-address: "fritz.box" - interval devices: 1 Min. - interval members: 60 s
    fb-checkpresence.0	2020-10-26 21:38:49.031	info	(3661) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.fb-checkpresence, node: v12.19.0, js-controller: 3.1.6
    fb-checkpresence.0	2020-10-26 21:38:48.176	debug	(3661) statesDB connected
    fb-checkpresence.0	2020-10-26 21:38:48.175	debug	(3661) States connected to redis: 127.0.0.1:9000
    fb-checkpresence.0	2020-10-26 21:38:48.171	debug	(3661) States create System PubSub Client
    fb-checkpresence.0	2020-10-26 21:38:48.170	debug	(3661) States create User PubSub Client
    fb-checkpresence.0	2020-10-26 21:38:48.167	debug	(3661) Redis States: Use Redis connection: 127.0.0.1:9000
    fb-checkpresence.0	2020-10-26 21:38:48.166	debug	(3661) objectDB connected
    fb-checkpresence.0	2020-10-26 21:38:48.164	debug	(3661) Objects connected to redis: 127.0.0.1:9001
    fb-checkpresence.0	2020-10-26 21:38:48.156	debug	(3661) Objects client initialize lua scripts
    fb-checkpresence.0	2020-10-26 21:38:48.156	debug	(3661) Objects create User PubSub Client
    fb-checkpresence.0	2020-10-26 21:38:48.155	debug	(3661) Objects create System PubSub Client
    fb-checkpresence.0	2020-10-26 21:38:48.154	debug	(3661) Objects client ready ... initialize now
    fb-checkpresence.0	2020-10-26 21:38:48.141	debug	(3661) Redis Objects: Use Redis connection: 127.0.0.1:9001
    afuerhoffA Offline
    afuerhoffA Offline
    afuerhoff
    @Brainbug
    Hast du keinen User angegeben oder nur für das Log entfernt?
    • afuerhoffA afuerhoff
      @Brainbug
      @afuerhoff sagte in Test Adapter fb-checkpresence v1.1.x:
      @Brainbug
      Den hab ich entfernt und nein mehr kommt nicht.
        @Brainbug
        afuerhoffA Offline
        afuerhoffA Offline
        afuerhoff
        schrieb am zuletzt editiert von afuerhoff
        @Brainbug
        Hast du nach dem Update den Adapter gestoppt und wieder neu gestartet?
        Wie sehen die Datenpunkte lastUpdate und connection aus?
          @Brainbug
          @afuerhoff
          Reicht dir das:
          Bild Text
            @afuerhoff
            Reicht dir das:
            Bild Text
            afuerhoffA Offline
            afuerhoffA Offline
            afuerhoff
            @Brainbug
            Das sieht nicht gut aus. Passt eigentlich nicht zum Log. Fast die ganzen Dienste stehen auf false. Ich konnte das jetzt bei mir aber nachstellen. Du hast keine Familienmitglieder konfiguriert. Den Fall hatte ich nicht abgetestet, da dieser ja eigentlich die Hauptfunktion des Adapters ist.
            Kannst du mal ein Familienmitglied anlegen und dann neu testen.
              @Brainbug
              @afuerhoff
              Ich bekomme keine Geräte aus der FB in den Adapter eingelesen. Somit kann ich auch keine Familienmitglieder festlegen.
              Ich hatte den Adapter und die ganzen Objekte gelöscht und nun kommt nichts mehr rein.
                @afuerhoff
                afuerhoffA Offline
                afuerhoffA Offline
                afuerhoff
                @Brainbug
                Du könntest ein Familienmitglied auch manuell anlegen.
                Aber ich denke, dass ich das Problem damit finden kann.
                  @Brainbug
                  @afuerhoff
                  Das hab ich auch probiert und trotzdem ging es nicht.
                    @afuerhoff
                    afuerhoffA Offline
                    afuerhoffA Offline
                    afuerhoff
                    @Brainbug
                    Heute Abend gibt es ein Update.
                      @Brainbug
                      @Brainbug
                      Kein Stress, ich schalte nichts mit dem Adapter.
                        @Brainbug
                        afuerhoffA Offline
                        afuerhoffA Offline
                        afuerhoff
                        ich habe ein weitere Update auf Github hochgeladen. Das sollte die Probleme lösen.
                        Zusätzlich ist noch eine Reboot Funktion hinzugekommen.
                          @afuerhoff
                          Läuft wieder, danke.
                          E 1 Antwort Letzte Antwort
                            @afuerhoff
                            Ente
                            Kann ich die 1.1 Version direkt über die 1.04 via github drüber installieren (1.04 habe ich nicht direkt von github bezogen), oder muss die 1.04 vorher deinstalliert werden?
                            • E Ente
                              afuerhoffA Offline
                              afuerhoffA Offline
                              afuerhoff
                              @Ente
                              Kannst du direkt installieren. Ist aber erstmal eine Testversion.
                                @Ente
                                afuerhoffA Offline
                                afuerhoffA Offline
                                afuerhoff
                                ich wollte mal nachfragen, ob der Adapter bei euch stabil läuft und auch die neuen Funktionen ohne Probleme funktionieren?
                                NegaleinN ? 2 Antworten Letzte Antwort
                                  NegaleinN Offline
                                  NegaleinN Offline
                                  Negalein
                                  Ich hab ihn derzeit deaktiviert, da seit dem 7.21 Update der Fritz 7580 und dem 7.20 des 2400 Repeater dieses Klumpt nur noch spinnt.
                                  Geräte sind verbunden, werden aber als offline angezeigt, usw.
                                  Ich für meinen Teil steig nächste Woche auf Unifi um.
                                  ° Fixer ---> iob fix
                                    @afuerhoff Hi, ja, läuft einwandfrei.. :-)
                                    • P Offline
                                      paul.honka
                                      Ich habe in der 1.1 jede Minute ein An- und Abmelden der Teilnehmer gehabt. Bin wieder auf 1.04, da alles ok.
                                      Beste Grüße paul
                                      • P paul.honka
                                        Beste Grüße paul
                                        afuerhoffA Offline
                                        afuerhoffA Offline
                                        afuerhoff
                                        @paul-honka
                                        Kannst du mal auf Loglevel debug gehen und das Log posten.
                                          mr.mixx
                                          der Adapter läuft bei mir einwandfrei. Danke dafür.
                                          Wird es ggf. noch Möglichkeiten geben, auch die Zugangsprofile zu "schalten" und die Anlage von Gruppen im Adapter für das gleichzeitige aktivieren/deaktivieren des Internets/der Profile wäre auch klasse.😬
