  4. Test Adapter fb-checkpresence v1.1.x
avmfb-checkpresencefritzboxtr-064
948 Beiträge 89 Kommentatoren 393.4k Aufrufe 78 Beobachtet
    @afuerhoff
    Nach dem Update:
    fb-checkpresence.0	2020-10-26 18:24:12.959	warn	(11135) chkService: "service X_AVM-DE_HostFilter-GetWANAccessByIP is not supported! Can not find service file! Feature is deactivated"
    fb-checkpresence.0	2020-10-26 18:24:12.959	warn	(11135) chkService: "service X_AVM-DE_HostFilter-DisallowWANAccessByIP is not supported! Can not find service file! Feature is deactivated"
    Bleibt Gelb
    afuerhoffA Offline
    afuerhoffA Offline
    afuerhoff
    @Brainbug
    Kannst du mal auf Loglevel debug schalten und dann den Log posten.
    • afuerhoffA afuerhoff
      @Brainbug
      @afuerhoff
      fb-checkpresence.0	2020-10-26 21:38:54.036	debug	(3661) system.adapter.admin.0: logging true
      fb-checkpresence.0	2020-10-26 21:38:49.277	info	(3661) createGlobalObjects finished successfully
      fb-checkpresence.0	2020-10-26 21:38:49.192	warn	(3661) chkService: "service X_AVM-DE_HostFilter-GetWANAccessByIP is not supported! Can not find service file! Feature is deactivated"
      fb-checkpresence.0	2020-10-26 21:38:49.192	warn	(3661) chkService: "service X_AVM-DE_HostFilter-DisallowWANAccessByIP is not supported! Can not find service file! Feature is deactivated"
      fb-checkpresence.0	2020-10-26 21:38:49.192	info	(3661) service DeviceInfo1-GetInfo is supported
      fb-checkpresence.0	2020-10-26 21:38:49.180	info	(3661) service WLANConfiguration3-GetInfo is supported
      fb-checkpresence.0	2020-10-26 21:38:49.169	info	(3661) service WLANConfiguration3-SetEnable is supported
      fb-checkpresence.0	2020-10-26 21:38:49.159	info	(3661) service WANPPPConnection1-GetInfo is supported
      fb-checkpresence.0	2020-10-26 21:38:49.147	info	(3661) service DeviceInfo1-GetSecurityPort is supported
      fb-checkpresence.0	2020-10-26 21:38:49.133	info	(3661) service Hosts1-X_AVM-DE_GetSpecificHostEntryByIP is supported
      fb-checkpresence.0	2020-10-26 21:38:49.124	info	(3661) service Hosts1-GetSpecificHostEntry is supported
      fb-checkpresence.0	2020-10-26 21:38:49.112	info	(3661) service Hosts1-X_AVM-DE_GetMeshListPath is supported
      fb-checkpresence.0	2020-10-26 21:38:49.100	info	(3661) service Hosts1-X_AVM-DE_GetHostListPath is supported
      fb-checkpresence.0	2020-10-26 21:38:49.091	debug	(3661) ssl-port {"status":200,"result":true,"resultData":{"$":{"xmlns:u":"urn:dslforum-org:service:DeviceInfo:1"},"NewSecurityPort":"49443"},"errNo":0,"errorMsg":""}
      fb-checkpresence.0	2020-10-26 21:38:49.078	debug	(3661) services loaded successfully{"root":{"$":{"xmlns":"urn:dslforum-org:device-1-0"},"specVersion":{"major":"1","minor":"0"},"systemVersion":{"HW":"233","Major":"161","Minor":"7","Patch":"13","Bui
      fb-checkpresence.0	2020-10-26 21:38:49.042	debug	(3661) configuratuion mesh info: false
      fb-checkpresence.0	2020-10-26 21:38:49.042	debug	(3661) configuration fb-devices true
      fb-checkpresence.0	2020-10-26 21:38:49.042	debug	(3661) configuration familymembers: []
      fb-checkpresence.0	2020-10-26 21:38:49.042	debug	(3661) configuration dateformat: <yyyy.mm.dd HH:MM:ss>
      fb-checkpresence.0	2020-10-26 21:38:49.042	debug	(3661) configuration history: <>
      fb-checkpresence.0	2020-10-26 21:38:49.042	debug	(3661) configuration user:
      fb-checkpresence.0	2020-10-26 21:38:49.041	info	(3661) start fb-checkpresence: ip-address: "fritz.box" - interval devices: 1 Min. - interval members: 60 s
      fb-checkpresence.0	2020-10-26 21:38:49.031	info	(3661) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.fb-checkpresence, node: v12.19.0, js-controller: 3.1.6
      fb-checkpresence.0	2020-10-26 21:38:48.176	debug	(3661) statesDB connected
      fb-checkpresence.0	2020-10-26 21:38:48.175	debug	(3661) States connected to redis: 127.0.0.1:9000
      fb-checkpresence.0	2020-10-26 21:38:48.171	debug	(3661) States create System PubSub Client
      fb-checkpresence.0	2020-10-26 21:38:48.170	debug	(3661) States create User PubSub Client
      fb-checkpresence.0	2020-10-26 21:38:48.167	debug	(3661) Redis States: Use Redis connection: 127.0.0.1:9000
      fb-checkpresence.0	2020-10-26 21:38:48.166	debug	(3661) objectDB connected
      fb-checkpresence.0	2020-10-26 21:38:48.164	debug	(3661) Objects connected to redis: 127.0.0.1:9001
      fb-checkpresence.0	2020-10-26 21:38:48.156	debug	(3661) Objects client initialize lua scripts
      fb-checkpresence.0	2020-10-26 21:38:48.156	debug	(3661) Objects create User PubSub Client
      fb-checkpresence.0	2020-10-26 21:38:48.155	debug	(3661) Objects create System PubSub Client
      fb-checkpresence.0	2020-10-26 21:38:48.154	debug	(3661) Objects client ready ... initialize now
      fb-checkpresence.0	2020-10-26 21:38:48.141	debug	(3661) Redis Objects: Use Redis connection: 127.0.0.1:9001
      afuerhoffA 2 Antworten Letzte Antwort
        @afuerhoff
        afuerhoffA Offline
        afuerhoffA Offline
        afuerhoff
        @Brainbug
        Könntest du ein etwas längeres Log senden. Oder kommt da nicht mehr.
          @afuerhoff
          afuerhoffA Offline
          afuerhoffA Offline
          afuerhoff
          @Brainbug
          Hast du keinen User angegeben oder nur für das Log entfernt?
            @Brainbug
            @afuerhoff sagte in Test Adapter fb-checkpresence v1.1.x:
            @Brainbug
            Den hab ich entfernt und nein mehr kommt nicht.
              @Brainbug
              afuerhoffA Offline
              afuerhoffA Offline
              afuerhoff
              schrieb am zuletzt editiert von afuerhoff
              @Brainbug
              Hast du nach dem Update den Adapter gestoppt und wieder neu gestartet?
              Wie sehen die Datenpunkte lastUpdate und connection aus?
                @Brainbug
                @afuerhoff
                Reicht dir das:
                Bild Text
                  @afuerhoff
                  Reicht dir das:
                  Bild Text
                  afuerhoffA Offline
                  afuerhoffA Offline
                  afuerhoff
                  @Brainbug
                  Das sieht nicht gut aus. Passt eigentlich nicht zum Log. Fast die ganzen Dienste stehen auf false. Ich konnte das jetzt bei mir aber nachstellen. Du hast keine Familienmitglieder konfiguriert. Den Fall hatte ich nicht abgetestet, da dieser ja eigentlich die Hauptfunktion des Adapters ist.
                  Kannst du mal ein Familienmitglied anlegen und dann neu testen.
                    @Brainbug
                    @afuerhoff
                    Ich bekomme keine Geräte aus der FB in den Adapter eingelesen. Somit kann ich auch keine Familienmitglieder festlegen.
                    Ich hatte den Adapter und die ganzen Objekte gelöscht und nun kommt nichts mehr rein.
                      @afuerhoff
                      afuerhoffA Offline
                      afuerhoffA Offline
                      afuerhoff
                      @Brainbug
                      Du könntest ein Familienmitglied auch manuell anlegen.
                      Aber ich denke, dass ich das Problem damit finden kann.
                        @Brainbug
                        @afuerhoff
                        Das hab ich auch probiert und trotzdem ging es nicht.
                          @afuerhoff
                          afuerhoffA Offline
                          afuerhoffA Offline
                          afuerhoff
                          @Brainbug
                          Heute Abend gibt es ein Update.
                            @Brainbug
                            @Brainbug
                            Kein Stress, ich schalte nichts mit dem Adapter.
                              @Brainbug
                              afuerhoffA Offline
                              afuerhoffA Offline
                              afuerhoff
                              ich habe ein weitere Update auf Github hochgeladen. Das sollte die Probleme lösen.
                              Zusätzlich ist noch eine Reboot Funktion hinzugekommen.
                                @afuerhoff
                                Läuft wieder, danke.
                                E 1 Antwort Letzte Antwort
                                  @afuerhoff
                                  Ente
                                  Kann ich die 1.1 Version direkt über die 1.04 via github drüber installieren (1.04 habe ich nicht direkt von github bezogen), oder muss die 1.04 vorher deinstalliert werden?
                                  • E Ente
                                    afuerhoffA Offline
                                    afuerhoffA Offline
                                    afuerhoff
                                    @Ente
                                    Kannst du direkt installieren. Ist aber erstmal eine Testversion.
                                      @Ente
                                      afuerhoffA Offline
                                      afuerhoffA Offline
                                      afuerhoff
                                      ich wollte mal nachfragen, ob der Adapter bei euch stabil läuft und auch die neuen Funktionen ohne Probleme funktionieren?
                                      NegaleinN ? 2 Antworten Letzte Antwort
                                        NegaleinN Offline
                                        NegaleinN Offline
                                        Negalein
                                        Ich hab ihn derzeit deaktiviert, da seit dem 7.21 Update der Fritz 7580 und dem 7.20 des 2400 Repeater dieses Klumpt nur noch spinnt.
                                        Geräte sind verbunden, werden aber als offline angezeigt, usw.
                                        Ich für meinen Teil steig nächste Woche auf Unifi um.
                                        ° Fixer ---> iob fix
                                          @afuerhoff Hi, ja, läuft einwandfrei.. :-)
