  4. VIS: Keine gültige Lizenz gefunden
Geplant Angeheftet Gesperrt Verschoben Gelöst ioBroker Allgemein
lizenz
170 Beiträge 60 Kommentatoren 63.0k Aufrufe 43 Beobachtet
    SaschaS
    Bis jetzt runter bis auf 1.1.10..
    Hat leider auch nichts gebracht.
    FehlerLog
    host.raspberrypi	2020-03-16 17:16:31.313	info	instance system.adapter.vis.0 terminated while should be started once
    host.raspberrypi	2020-03-16 17:16:31.312	error	Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.vis/www/widgets/dwd/img/Prev_DwdAdapter.png' }
    host.raspberrypi	2020-03-16 17:16:31.312	error	Caught by controller[0]: syscall: 'open',
    host.raspberrypi	2020-03-16 17:16:31.312	error	Caught by controller[0]: code: 'EACCES',
    host.raspberrypi	2020-03-16 17:16:31.311	error	Caught by controller[0]: errno: -13,
    host.raspberrypi	2020-03-16 17:16:31.311	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.vis/lib/install.js:32:17
    host.raspberrypi	2020-03-16 17:16:31.310	error	Caught by controller[0]: at copyFolderRecursiveSync (/opt/iobroker/node_modules/iobroker.vis/lib/install.js:29:15)
    host.raspberrypi	2020-03-16 17:16:31.310	error	Caught by controller[0]: at Array.forEach (<anonymous>)
    host.raspberrypi	2020-03-16 17:16:31.310	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.vis/lib/install.js:32:17
    host.raspberrypi	2020-03-16 17:16:31.309	error	Caught by controller[0]: at Array.forEach (<anonymous>)
    host.raspberrypi	2020-03-16 17:16:31.309	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.vis/lib/install.js:34:17
    host.raspberrypi	2020-03-16 17:16:31.308	error	Caught by controller[0]: at copyFileSync (/opt/iobroker/node_modules/iobroker.vis/lib/install.js:14:8)
    host.raspberrypi	2020-03-16 17:16:31.308	error	Caught by controller[0]: at Object.fs.writeFileSync (fs.js:1299:33)
    host.raspberrypi	2020-03-16 17:16:31.308	error	Caught by controller[0]: at Object.fs.openSync (fs.js:646:18)
    host.raspberrypi	2020-03-16 17:16:31.307	error	Caught by controller[0]: { Error: EACCES: permission denied, open '/opt/iobroker/node_modules/iobroker.vis/www/widgets/dwd/img/Prev_DwdAdapter.png'
    vis.0	2020-03-16 17:16:30.756	info	(22386) Terminated (NO_ERROR): Without reason
    vis.0	2020-03-16 17:16:30.749	info	(22386) terminating
    vis.0	2020-03-16 17:16:30.193	error	(22386) Error: EACCES: permission denied, open '/opt/iobroker/node_modules/iobroker.vis/www/widgets/dwd/img/Prev_DwdAdapter.png' at Object.fs.openSync (fs.js:646:18) at Object.fs.writeFileSync
    vis.0	2020-03-16 17:16:30.192	error	(22386) uncaught exception: EACCES: permission denied, open '/opt/iobroker/node_modules/iobroker.vis/www/widgets/dwd/img/Prev_DwdAdapter.png'
    vis.0	2020-03-16 17:16:30.150	error	(22386) Cannot check license! Nothing updated. Error: OK
    vis.0	2020-03-16 17:16:30.124	info	(22386) vis license is OK.
    vis.0	2020-03-16 17:16:29.859	info	(22386) starting. Version 1.1.10 in /opt/iobroker/node_modules/iobroker.vis, node: v8.17.0```
    • S SaschaS
      FehlerLog
      @SaschaS hast du mal einen Upload gemacht?
        SaschaS
        @Homoran Was genau meinst du damit? Einen Upload wohin?
        • S SaschaS
          @SaschaS iobroker upload vis oder entsprechend über den admin im Expertenmodus
            SaschaS
            @Homoran Nein. Soetwas habe ich nicht gemacht.
              SaschaS
              Aber 😲 ich habe mit
              sudo iobroker upgrade vis@1.1.10
              die Version 1.1.10 installieren wollen.
              Angezeigt wird mir nach einen Neustart von ioBroker
              bzw.
              what the hell?
              • S SaschaS
                Aber 😲 ich habe mit
                bzw.
                what the hell?
                @SaschaS
                Kann es sein, dass du 2 iobroker Installationen hast?
                  @SaschaS
                  Sprite01
                  Das habe ich hier aktuell mit der 1.2.5 auch.
                  Nach Start der vis-Instanz erscheint im Log:
                  Cannot check license: Error: getaddrinfo ENOTFOUND iobroker1.net iobroker1.net:443
                  Dirk
                  http://www.DessauWetter.de
                  (ioBroker auf IntelNuc und Proxmox)
                  • S Sprite01
                    Sprite01
                    schrieb am zuletzt editiert von Sprite01
                    Liegt es daran, das mir in meinem Pro-Account keine Lizenzen mehr angezeigt werden ?
                    Der Login auf iobroker.pro funktioniert und der Fernzugriff- und auch Assistentzugriff gilt auch noch eine Weile.
                    PS:ein Downgrade auf 1.2.2 hat bei mir erst mal geholfen.
                    Dirk
                    • N nousefor82
                      Servus,
                      habe bei mir Admin und Vis auf den letzten Stand gebracht.
                      Seit dem bekomme ich in meiner Visualisierung folgende Meldung:
                      Bei der Lizenzprüfung im VIS Adapter bekomme ich ein grünes OK angezeigt.
                      Jemand eine Idee?
                      Danke!
                      Crockers
                      Leider habe ich auch das Problem.
                      Sowohl intern als auch extern.
                      VIS Adapter sagt "Linzenz prüfen -- OK"
                      App Key im Cloud Adapter ist auch in Ordnung.
                      Was kann ich machen?
                      VIS 1.2.6
                      Cloud Connection 3.0.4
                      IoT Assistants 1.6.3
                      sigi234S HomoranH 2 Antworten Letzte Antwort
                      • C Crockers
                        VIS 1.2.6
                        sigi234S Online
                        sigi234S Online
                        @Crockers
                        Host mal neu gestartet?
                        • C Crockers
                          VIS 1.2.6
                          @Crockers sagte in VIS: Keine gültige Lizenz gefunden:
                          Der hat aber nichts mit der vis Lizenz zu tun.
                          Ist die in der Konfig von vis eingetragen?
                          C 1 Antwort Letzte Antwort
                            Crockers
                            @Homoran said in VIS: Keine gültige Lizenz gefunden:
                            "Ist die in der Konfig von VIS eingetragen?"
                            Das kann ich nicht deuten. Was soll in der Konfig von VIS eingetragen sein?
                            In meinem VIS Adapter ist der Licence Key meines ioBroker Pro Accounts eingetragen "Fernzugriff für 1 Jahr" und gültig bis 12.12.2020.
                            FredFF HomoranH 2 Antworten Letzte Antwort
                            • C Crockers
                              FredFF Online
                              FredFF Online
                              FredF
                              Most Active Forum Testing
                              @Crockers
                              Für die vis brauchst du eine Lizenz über iobroker.net und nicht über .pro
                              Mit dem Knopf Lizenz prüfen wird die Richtigkeit geprüft.
                              Steht eigentlich alles bei der vis Adapterkonfig:
                              • C Crockers
                                die
                                @Homoran sagte in VIS: Keine gültige Lizenz gefunden:
                                vis Lizenz
                                  die
                                  vis Lizenz
                                  Crockers
                                  @Homoran @FredF
                                  Oh man das ist doch nicht mein Ernst.....Ich bin selber IT-ler und denke mir oft bei Beiträgen "Einfach mal lesen was dort steht, dann klappt es auch"
                                  --> Heute war ich der Depp. Lizenz von iobroker.net eingetragen und schon funktioniert es. Da hatte ich ein Brett vor dem Kopf.
                                  Danke euch trotzdem!
                                  HomoranH FredFF O 3 Antworten Letzte Antwort
                                  • C Crockers
                                    @Homoran @FredF
                                    • C Crockers
                                      @Homoran @FredF
                                      FredFF Online
                                      FredFF Online
                                      FredF
                                      Willkommen im Club 😎
                                      • FredFF FredF
                                        Crockers
                                        Sooo.... intern via WLAN funktioniert es jetzt.
                                        Von extern bekomme ich allerdings immernoch den Fehler. Hab ich noch mehr übersehen?
                                        • C Crockers
                                          #66
                                          Von extern
                                          Wie?
                                          App?
                                          VPN?
