  3. Entwicklung
  4. ZigBee neue/unbekannte Geräte - ab 1.0.0
zigbeezigbee 3.xneuer converter
402 Beiträge 87 Kommentatoren 113.3k Aufrufe 76 Beobachtet
  • L Offline
    locito09
    #125
    Hallo
    Wurde diese LED Streifen schon hinzugefügt?
    • arteckA arteck
      @gd84 ist mir auch schon aufgefallen.. der liefert den nicht.
      gd84
      schrieb am zuletzt editiert von gd84
      #126
      @arteck
      Irgend was stimmt nicht
      zigbee.1	2020-02-27 20:23:56.995	error	(655) Device 083800b8d1f00000 "Panel TW 595 UGR22" not described in statesMapping.
      zigbee.1	2020-02-27 20:18:56.906	error	(655) Device 083800b8d1f00000 "Panel TW 595 UGR22" not described in statesMapping.
      zigbee.1	2020-02-27 20:13:56.818	error	(655) Device 083800b8d1f00000 "Panel TW 595 UGR22" not described in statesMapping.
      zigbee.1	2020-02-27 20:08:56.732	error	(655) Device 083800b8d1f00000 "Panel TW 595 UGR22" not described in statesMapping.
      zigbee.1	2020-02-27 20:03:56.645	error	(655) Device 083800b8d1f00000 "Panel TW 595 UGR22" not described in statesMapping.
      zigbee.1	2020-02-27 19:59:36.218	info	(655) Zigbee: stop joining
      zigbee.1	2020-02-27 19:58:56.557	info	(655) Device '0x083800b8d1f00000' is supported, identified as: OSRAM OSRAM LED panel TW 595 UGR22 (595UGR22)
      zigbee.1	2020-02-27 19:58:56.557	info	(655) Successfully interviewed '0x083800b8d1f00000', device has succesfully been paired
      zigbee.1	2020-02-27 19:58:56.556	error	(655) Device 083800b8d1f00000 "Panel TW 595 UGR22" not described in statesMapping.
      zigbee.1	2020-02-27 19:58:56.448	error	(655) Device 083800b8d1f00000 "Panel TW 595 UGR22" not described in statesMapping.
      zigbee.1	2020-02-27 19:58:56.327	error	(655) Device 083800b8d1f00000 "Panel TW 595 UGR22" not described in statesMapping.
      zigbee.1	2020-02-27 19:58:56.190	error	(655) Device 083800b8d1f00000 "Panel TW 595 UGR22" not described in statesMapping.
      zigbee.1	2020-02-27 19:58:56.071	error	(655) Device 083800b8d1f00000 "Panel TW 595 UGR22" not described in statesMapping.
      zigbee.1	2020-02-27 19:58:44.382	info	(655) Starting interview of '0x083800b8d1f00000'
      zigbee.1	2020-02-27 19:58:35.143	error	at processTimers (internal/timers.js:475:7))
      zigbee.1	2020-02-27 19:58:35.143	error	at listOnTimeout (internal/timers.js:531:17)
      zigbee.1	2020-02-27 19:58:35.143	error	at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/dist/utils/waitress.js:44:24)
      zigbee.1	2020-02-27 19:58:35.143	error	(655) Failed to do action 0x4a3900b8d1f00000 Panel TW 595 UGR22, attempt 1 (Error: AREQ - ZDO - mgmtLeaveRsp after 10000ms
      zigbee.1	2020-02-27 19:58:31.869	info	(655) Zigbee: allowing new devices to join.
      zigbee.1	2020-02-27 19:58:25.141	info	(655) Do action on 0x4a3900b8d1f00000 Panel TW 595 UGR22
      zigbee.1	2020-02-27 19:58:22.570	info	(655) Do action succesfully 0x083800b8d1f00000 Panel TW 595 UGR22
      zigbee.1	2020-02-27 19:58:19.573	info	(655) Do action on 0x083800b8d1f00000 Panel TW 595 UGR22
      zigbee.1	2020-02-27 19:58:01.993	info	(655) Zigbee started
      Über die Instanz / Analyse kann ich aber Daten abfragen und schalten.
      • G gd84
        @arteck
        arteckA Offline
        arteckA Offline
        arteck
        #127
        @gd84 sagte in ZigBee neue/unbekannte Geräte - ab 1.0.0:
        0x083800b8d1f00000
        installier nochmal bitte .. hatte noch ein fehler
        G 1 Antwort Letzte Antwort
        • L locito09
          Hallo
          arteckA Offline
          arteckA Offline
          arteck
          #128
          @locito09 jetzt
          L 1 Antwort Letzte Antwort
          • arteckA arteck
            0x083800b8d1f00000
            gd84
            #129
            @arteck
            Super jetzt geht alles.
            Ein anderes Problem das ich habe ist das Binding.
            Ein Hue Bewegungsmelder sollte mit einer Hue Lampe Verbunden werden.
            Das ist die Fehlermeldung:
            zigbee.1	2020-02-28 09:52:00.182	warn	at processImmediate (internal/timers.js:439:21)
            zigbee.1	2020-02-28 09:52:00.182	warn	at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:227:41)
            zigbee.1	2020-02-28 09:52:00.182	warn	at change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4808:34)
            zigbee.1	2020-02-28 09:52:00.182	warn	at Zigbee.emit (events.js:228:7)
            zigbee.1	2020-02-28 09:52:00.182	warn	at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:50:26)
            zigbee.1	2020-02-28 09:52:00.182	warn	at Developer.getLibData (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:69:39)
            zigbee.1	2020-02-28 09:52:00.182	warn	at Object.getCluster (/opt/iobroker/node_modules/zigbee-herdsman/dist/zcl/utils.js:59:15)
            zigbee.1	2020-02-28 09:52:00.182	warn	(1152) Error: Cluster with key '' does not exist
            zigbee.1	2020-02-28 09:52:00.181	warn	(1152) States system pmessage io.messagebox.system.adapter.zigbee.1 {"command":"getLibData","message":{"key":"cmdListFunctional","cid":""},"from":"system.adapter.admin.0","callback":{"message":{"key"
            • G gd84
              @arteck
              arteckA Offline
              arteckA Offline
              arteck
              #130
              @gd84 das binding geht nicht mit jedem Gerät...
              was geht sind die Tradfri komponenten..
              • arteckA arteck
                gd84
                #131
                @arteck
                Ah ok, ist das ein prinzipielles problem der Firmware der Geräte oder fehlen nur Angaben in der Datenbank.
                • arteckA arteck
                  @locito09 jetzt
                  locito09
                  #132
                  @arteck
                  • G gd84
                    @arteck
                    arteckA Offline
                    arteckA Offline
                    arteck
                    #133
                    @gd84 mit der Datenbank hat das nix zu tun..
                    Nicht alle Geräte machen da mit
                    • ? Offline
                      #134
                      Habe ein Problem mit dem Rauchmelder Heiman SmokeSensor-N-3.0, zigbee erkennt ihn aber bekomme folgende Fehlermeldung:
                      Device 00158d0004c34730 "SmokeSensor-N-3.0" not described in statesMapping.
                      • arteckA arteck
                        gd84
                        #135
                        @arteck
                        Ah ok.
                        Kann man eigentlich schon die Ota Funktion nutzen? Soll ja für Tradfri und Osram schon gehen.
                          Saxnot
                          #136
                          vielen Dank für die tolle Arbeit, die ihr macht!
                          Bitte das folgende Gerät aufnehmen:
                          Produkt: Innr RS 230 C (Smart Spot Colour GU10)
                          Link: https://www.innr.com/en/product/smart-spot-colour/
                          Kachel:
                          Eigentlich wollte ich auch noch die Innr RS 228 T (https://www.innr.com/en/product/smart-spot-comfort-4pack/) aufnehmen. Da scheitere ich aber schon am Pairing. Dabei kommt auch keine Meldung. Was muss man in solchen Fällen machen? Vielen Dank!
                          • S Saxnot
                            Kachel:
                            arteckA Offline
                            arteckA Offline
                            arteck
                            #137
                            @Saxnot drin
                            • arteckA arteck
                              @Saxnot drin
                              Saxnot
                              #138
                              @arteck said in ZigBee neue/unbekannte Geräte - ab 1.0.0:
                              @Saxnot drin
                              Wahnsinn, wie schnell du bist👍 Die RS 230 C wird jetzt erkannt! Zur RS 228 T kann ich nichts berichten, bekomme sie einfach nicht verbunden... Aber besten Dank!
                              • Z Offline
                                Z Offline
                                Zentapher
                                #139
                                Meine neue Steckdose mag nicht so richtig...
                                Adapter ist aktuell aus GitHub::
                                starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v10.18.1
                                Ich verwende einen CC1352P-2 mit aktueller Z-Stack_3.x.0 Firmware:
                                Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20191106}}
                                Device Details:
                                Device details
                                model:ZNCZ04LM
                                vendor:Xiaomi
                                description:Mi power plug ZigBee EU
                                supports:on/off, power measurement
                                model:lumi.plug.mmeu01
                                type:Router
                                nwk:54748
                                manuf id:4447
                                manufacturer:LUMI
                                power:Mains (single phase)
                                app version:22
                                hard version:1
                                zcl version:3
                                stack version:2
                                date code:09-06-2019
                                interviewed:true
                                configured:false
                                endpoint:1
                                profile:260
                                input clusters:genBasic (0)
                                genDeviceTempCfg (2)
                                genIdentify (3)
                                genGroups (4)
                                genScenes (5)
                                genOnOff (6)
                                aqaraOpple (64704)
                                output clusters:genTime (10)
                                genOta (25)
                                endpoint:21
                                profile:260
                                input clusters:genAnalogInput (12)
                                endpoint:22
                                profile:260
                                endpoint:242
                                profile:41440
                                output clusters:33
                                Pairing Logs:
                                New device joined '0x04cf8cdf3c75a3d1' model lumi.plug.mmeu01
                                Interview successful: {"friendly_name":"0x04cf8cdf3c75a3d1","model":"ZNCZ04LM","vendor":"Xiaomi","description":"Mi power plug ZigBee EU","supported":true}
                                Error: Device 04cf8cdf3c75a3d1 "lumi.plug.mmeu01" not described in statesMapping.. undefined
                                Device '0x04cf8cdf3c75a3d1' announced itself
                                Interview started: 0x04cf8cdf3c75a3d1
                                • FredFF Offline
                                  FredFF Offline
                                  FredF
                                  Most Active Forum Testing
                                  #140
                                  Ich nutze den FLS-PP3/Mega23M12 mit dem Adapter 1.0.3
                                  Das ist ein RGBW controller, nur leider wird der W Anteil nicht in den Datenpunkten angeboten bzw. mit eingabe einem 8 stelligen Hex code in color passiert nichts.
                                  Ist der richtig eingebunden oder mache ich was falsch?
                                  Details
                                  model:Mega23M12
                                  vendor:Dresden Elektronik
                                  description:ZigBee Light Link wireless electronic ballast
                                  supports:on/off, brightness, color temperature, color xy
                                  model:FLS-PP3
                                  type:Router
                                  nwk:29323
                                  manuf id:4405
                                  manufacturer:dresden elektronik
                                  app version:2
                                  hard version:1
                                  zcl version:1
                                  stack version:3
                                  date code:20180517
                                  build:0214.201000EB
                                  interviewed:true
                                  configured:false
                                  endpoint:10
                                  profile:49246
                                  input clusters:0,4096,4,3,5,6,8,768,64718
                                  output clusters:25
                                  endpoint:11
                                  profile:49246
                                  output clusters:
                                  • Z Zentapher
                                    Device Details:
                                    Device details
                                    model:ZNCZ04LM
                                    vendor:Xiaomi
                                    type:Router
                                    nwk:54748
                                    manuf id:4447
                                    manufacturer:LUMI
                                    app version:22
                                    hard version:1
                                    zcl version:3
                                    stack version:2
                                    interviewed:true
                                    configured:false
                                    endpoint:1
                                    profile:260
                                    genIdentify (3)
                                    genGroups (4)
                                    genScenes (5)
                                    genOnOff (6)
                                    aqaraOpple (64704)
                                    genOta (25)
                                    endpoint:21
                                    profile:260
                                    endpoint:22
                                    profile:260
                                    endpoint:242
                                    profile:41440
                                    output clusters:33
                                    Pairing Logs:
                                    arteckA Offline
                                    arteckA Offline
                                    arteck
                                    #141
                                    @Zentapher sagte in ZigBee neue/unbekannte Geräte - ab 1.0.0:
                                    lumi.plug.mmeu01
                                    probiermal
                                    @FredF
                                    supports: on/off, brightness, color temperature, color xy
                                    das wird supported.. da steht nix von W
                                    FredFF Z Robi1010MDR 3 Antworten Letzte Antwort
                                    • arteckA arteck
                                      lumi.plug.mmeu01
                                      probiermal
                                      @FredF
                                      FredFF Offline
                                      FredFF Offline
                                      FredF
                                      #142
                                      @arteck sagte in ZigBee neue/unbekannte Geräte - ab 1.0.0:
                                      • arteckA arteck
                                        lumi.plug.mmeu01
                                        probiermal
                                        @FredF
                                        Z Offline
                                        Z Offline
                                        Zentapher
                                        #143
                                        @arteck
                                        Super, funktioniert! Vielen Dank.
                                        • A aSilentSniper
                                          so ich habe es für heute aufgeben nachdem ich nochmal die neuste version von github installiert habe hat er zwar die remote erkannt aber ich konnte das Rollo nicht mehr steuern also habe ich es erstmal aufgeben und nutze das rollo nun nur mit der remote ohn iobroker leider
                                          chiroptera
                                          schrieb am zuletzt editiert von chiroptera
                                          #144
                                          @Asgothian Ich habe das selbe Problem mit der open/close Remote. Das Rollo kann mit dem CC2531 Stick gepairt werden und ist auch über ioBroker steuerbar. Wenn man versucht die Fernbedienung direkt mit dem Rollo zu pairen, dann ist das Pairing des Rollos wieder entfernt. Rollo und Fernbedienung lassen sich mit dem CC2531 Stick pairen, dann kommt aber die Fehlermeldung wie oben im Screenshot "not described in statesMapping" bei jedem Tastendruck. Das Profil der Fernbedienung ist auch nicht ordentlich vorhanden - keine Zustände. Das Rollo lässt sich in diesem Zustand über ioBroker aber noch steuern.
                                          Es scheint also nicht möglich das Rollo mit der Fernbedienung zu pairen und gleichzeitig über zigbee2mqqt. Beide Geräte Rollo und Fernbedienung lassen sich über zigbee2mqqt pairen.
                                          Nachtrag: Wenn man nur die Fernbedienung allein pairt, dann kommt die selbe Fehlermeldung bei jedem Tastendruck.
                                          Edit:
                                          Gerade erst gesehen - ich schau mal welche Version ich einsetze und gebe Rückmeldung ob es mit 1.0.3 funktioniert.
                                          Edit:
                                          Funktioniert einwandfrei mit V1.0.3 :-)
