  4. JavaScript
  5. Script fürTabelle der Batterie Zustände
javascriptmonitoringtemplate
1.4k Beiträge 67 Kommentatoren 819.6k Aufrufe 86 Beobachtet
    @Meister-Mopper Es schaukelt sich offenbar zeitlich auf:
    javascript.0	2020-01-23 19:50:00.306	error	(1487) at Timer.processTimers (timers.js:223:10)
    javascript.0	2020-01-23 19:50:00.305	error	(1487) at listOnTimeout (timers.js:263:5)
    javascript.0	2020-01-23 19:50:00.279	error	(1487) at tryOnTimeout (timers.js:300:5)
    javascript.0	2020-01-23 19:50:00.278	error	(1487) at ontimeout (timers.js:436:11)
    javascript.0	2020-01-23 19:50:00.278	error	(1487) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:501:7)
    javascript.0	2020-01-23 19:50:00.269	error	(1487) at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:543:11
    javascript.0	2020-01-23 19:50:00.268	error	(1487) at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:173:10)
    javascript.0	2020-01-23 19:50:00.268	error	(1487) at Job.nodeSchedule.scheduleJob [as job] (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1319:34)
    javascript.0	2020-01-23 19:50:00.268	error	(1487) at Object.<anonymous> (script.js.java.sonstige.Batterien:1687:1)
    javascript.0	2020-01-23 19:50:00.267	error	(1487) at writeHTML (script.js.java.sonstige.Batterien:1671:52)
    javascript.0	2020-01-23 19:50:00.266	error	(1487) Error in callback: ReferenceError: wantAmessage is not defined
    host.raspberrypi	2020-01-23 19:50:00.067	info	instance system.adapter.dwd.0 started with pid 7920
    javascript.0	2020-01-23 19:46:53.630	error	(1487) at Script.runInContext (vm.js:133:20)
    javascript.0	2020-01-23 19:46:53.630	error	(1487) at script.js.java.sonstige.Batterien:1693:1
    javascript.0	2020-01-23 19:46:53.630	error	(1487) at writeHTML (script.js.java.sonstige.Batterien:1671:52)
    javascript.0	2020-01-23 19:46:53.629	error	(1487) ReferenceError: wantAmessage is not defined
    javascript.0	2020-01-23 19:46:53.629	error	(1487) ^
    javascript.0	2020-01-23 19:46:53.629	error	(1487) if (AkkuMessageLengthAlt < AkkuAlarm.length && wantAmessage) {setState(dpAlarmMessage,alarmMessage.toString()); AkkuMessageLengthAlt=AkkuAlarm.length}
    javascript.0	2020-01-23 19:46:53.629	error	(1487) script.js.java.sonstige.Batterien: script.js.java.sonstige.Batterien:1671
    javascript.0	2020-01-23 19:46:53.579	info	(1487) Start javascript script.js.java.sonstige.Batterien
    javascript.0	2020-01-23 19:46:44.664	info	(1487) Stop script script.js.java.sonstige.Batterien
    host.raspberrypi	2020-01-23 19:46:04.565	info	instance system.adapter.tvspielfilm.0 terminated with code 0 (NO_ERROR)
    javascript.0	2020-01-23 19:45:54.083	error	(1487) at Script.runInContext (vm.js:133:20)
    javascript.0	2020-01-23 19:45:54.083	error	(1487) at script.js.java.sonstige.Batterien:1693:1
    javascript.0	2020-01-23 19:45:54.083	error	(1487) at writeHTML (script.js.java.sonstige.Batterien:1671:52)
    javascript.0	2020-01-23 19:45:54.083	error	(1487) ReferenceError: wantAmessage is not defined
    javascript.0	2020-01-23 19:45:54.083	error	(1487) ^
    javascript.0	2020-01-23 19:45:54.082	error	(1487) if (AkkuMessageLengthAlt < AkkuAlarm.length && wantAmessage) {setState(dpAlarmMessage,alarmMessage.toString()); AkkuMessageLengthAlt=AkkuAlarm.length}
    javascript.0	2020-01-23 19:45:54.082	error	(1487) script.js.java.sonstige.Batterien: script.js.java.sonstige.Batterien:1671
    javascript.0	2020-01-23 19:45:54.009	info	(1487) Start javascript script.js.java.sonstige.Batterien
    javascript.0	2020-01-23 19:45:45.071	info	(1487) Stop script script.js.java.sonstige.Batterien
    host.raspberrypi	2020-01-23 19:45:08.720	info	instance system.adapter.dwd.0 terminated with code 0 (NO_ERROR)
    host.raspberrypi	2020-01-23 19:45:04.078	info	instance system.adapter.dwd.0 started with pid 7231
    host.raspberrypi	2020-01-23 19:45:00.043	info	instance system.adapter.tvspielfilm.0 started with pid 7189
    host.raspberrypi	2020-01-23 19:41:07.283	info	instance system.adapter.tvspielfilm.0 terminated with code 0 (NO_ERROR)
    javascript.0	2020-01-23 19:40:31.061	info	(1487) script.js.Wohnzimmer.Energie.Smartphones_laden: registered 4 subscriptions and 0 schedules
    javascript.0	2020-01-23 19:40:31.049	info	(1487) Start javascript script.js.Wohnzimmer.Energie.Smartphones_laden
    javascript.0	2020-01-23 19:40:30.922	info	(1487) Stop script script.js.Wohnzimmer.Energie.Smartphones_laden
    host.raspberrypi	2020-01-23 19:40:07.436	info	instance system.adapter.dwd.0 terminated with code 0 (NO_ERROR)
    host.raspberrypi	2020-01-23 19:40:04.092	info	instance system.adapter.tvspielfilm.0 started with pid 6475
    javascript.0	2020-01-23 19:40:00.238	error	(1487) at Timer.processTimers (timers.js:223:10)
    javascript.0	2020-01-23 19:40:00.238	error	(1487) at listOnTimeout (timers.js:263:5)
    javascript.0	2020-01-23 19:40:00.237	error	(1487) at tryOnTimeout (timers.js:300:5)
    javascript.0	2020-01-23 19:40:00.237	error	(1487) at ontimeout (timers.js:436:11)
    javascript.0	2020-01-23 19:40:00.237	error	(1487) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:501:7)
    javascript.0	2020-01-23 19:40:00.236	error	(1487) at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:543:11
    javascript.0	2020-01-23 19:40:00.234	error	(1487) at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:173:10)
    javascript.0	2020-01-23 19:40:00.229	error	(1487) at Job.nodeSchedule.scheduleJob [as job] (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1319:34)
    javascript.0	2020-01-23 19:40:00.229	error	(1487) at Object.<anonymous> (script.js.java.sonstige.Batterien:1687:1)
    javascript.0	2020-01-23 19:40:00.228	error	(1487) at writeHTML (script.js.java.sonstige.Batterien:1671:52)
    javascript.0	2020-01-23 19:40:00.227	error	(1487) Error in callback: ReferenceError: wantAmessage is not defined
    host.raspberrypi	2020-01-23 19:40:00.053	info	instance system.adapter.dwd.0 started with pid 6420
    javascript.0	2020-01-23 19:37:38.711	info	(1487) script.js.Wohnzimmer.Energie.Smartphones_laden: registered 4 subscriptions and 0 schedules
    javascript.0	2020-01-23 19:37:38.699	info	(1487) Start javascript script.js.Wohnzimmer.Energie.Smartphones_laden
    javascript.0	2020-01-23 19:37:38.585	info	(1487) Stop script script.js.Wohnzimmer.Energie.Smartphones_laden
    host.raspberrypi	2020-01-23 19:36:05.127	info	instance system.adapter.tvspielfilm.0 terminated with code 0 (NO_ERROR)
    host.raspberrypi	2020-01-23 19:35:09.089	info	instance system.adapter.dwd.0 terminated with code 0 (NO_ERROR)
    host.raspberrypi	2020-01-23 19:35:04.703	info	instance system.adapter.dwd.0 started with pid 5688
    host.raspberrypi	2020-01-23 19:35:00.668	info	instance system.adapter.tvspielfilm.0 started with pid 5667
    host.raspberrypi	2020-01-23 19:31:07.615	info	instance system.adapter.tvspielfilm.0 terminated with code 0 (NO_ERROR)
    host.raspberrypi	2020-01-23 19:30:25.138	info	instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
    host.raspberrypi	2020-01-23 19:30:08.192	info	instance system.adapter.dwd.0 terminated with code 0 (NO_ERROR)
    host.raspberrypi	2020-01-23 19:30:08.110	info	instance system.adapter.daswetter.0 started with pid 4925
    host.raspberrypi	2020-01-23 19:30:04.077	info	instance system.adapter.tvspielfilm.0 started with pid 4905
    javascript.0	2020-01-23 19:30:00.257	error	(1487) at Timer.processTimers (timers.js:223:10)
    javascript.0	2020-01-23 19:30:00.256	error	(1487) at listOnTimeout (timers.js:263:5)
    javascript.0	2020-01-23 19:30:00.256	error	(1487) at tryOnTimeout (timers.js:300:5)
    javascript.0	2020-01-23 19:30:00.255	error	(1487) at ontimeout (timers.js:436:11)
    javascript.0	2020-01-23 19:30:00.255	error	(1487) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:501:7)
    javascript.0	2020-01-23 19:30:00.254	error	(1487) at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:543:11
    javascript.0	2020-01-23 19:30:00.254	error	(1487) at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:173:10)
    javascript.0	2020-01-23 19:30:00.253	error	(1487) at Job.nodeSchedule.scheduleJob [as job] (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1319:34)
    javascript.0	2020-01-23 19:30:00.253	error	(1487) at Object.<anonymous> (script.js.java.sonstige.Batterien:1687:1)
    javascript.0	2020-01-23 19:30:00.252	error	(1487) at writeHTML (script.js.java.sonstige.Batterien:1671:52)
    javascript.0	2020-01-23 19:30:00.251	error	(1487) Error in callback: ReferenceError: wantAmessage is not defined
    liv-in-skyL
    liv-in-skyL
    #605
    @Meister-Mopper hast du das ?
    • liv-in-skyL
      liv-in-skyL
      #606
      gibt es ein problem mit der anzeige - überschneidet sich etwas bei homeatic ?
      • tugsiT tugsi
        Hey @liv-in-sky ,
        hab gestern Abend Dein Script schnell mal zum testen eingebaut, klappt soweit.
        Danke dafür!
        Könntest Du auch noch ZWave mit einbinden?
        Bei meinen Fensterkontakten gibt es für die Batterie folgenden Datenpunkt:
        zwave.0.NODE4.BATTERY.Battery_Level_1
        Zum Beispiel.
        Wird ist 0-100% dann.
        Gruß Thomas
        liv-in-skyL
        liv-in-skyL
        #607
        @tugsi im ersten post mit zwave
        tugsiT 1 Antwort Letzte Antwort
        • liv-in-skyL liv-in-sky
          Meister MopperM
          Meister MopperM
          Meister Mopper
          #608
          @liv-in-sky sagte in Script fürTabelle der Batterie Zustände:
          Jetzt ja, hatte beim letzten mal den Beginn nicht mitkopiert. Es ändert sich ja in den kürzesten Zeitabständen 😁
          Fehler ist weg!
          Proxmox und HA ...
            Fehler ist weg!
            liv-in-skyL
            liv-in-skyL
            #609
            @Meister-Mopper die updates werden weniger mit der zeit
            O 1 Antwort Letzte Antwort
              O
              O
              Oli
              #610
              @liv-in-sky
              ist es möglich die Hintergrundfarbe Zeile für Zeile zu definieren, also zB
              Gerade Zeilennummern Schwarz und ungeraden Zeilennummern Grau?
              Oliver
              • O Oli
                @liv-in-sky
                liv-in-skyL
                liv-in-skyL
                #611
                @Oli nein - habe ich auch schon überlegt aber die mehrtabellenanzeige macht es problematisch - wenn mir mal eine math. formel einfällt, die ich anwenden kann, gebe ich bescheid
                  O
                  O
                  Oli
                  #612
                  @liv-in-sky
                  Würde es bei einer einzelnen Tabellenansicht gehen?
                  Oliver
                  liv-in-skyL GlasfaserG 2 Antworten Letzte Antwort
                  • O Oli
                    @liv-in-sky
                    liv-in-skyL
                    liv-in-skyL
                    #613
                    @Oli habe geheime formel gefunden - muss das noch umsetzen - geht mit allen spalten instellungen und farbe werden über var iable eingestellt
                    update später - muss jetzt weg
                    beidspiel meiner test tabelle
                      O
                      O
                      Oli
                      #614
                      @liv-in-sky
                      Cool
                      Oliver
                        tugsiT
                        tugsiT
                        tugsi
                        #615
                        @liv-in-sky
                        Danke! Hat geklappt! 1a.
                        Hast oben im ersten Post noch kein ZWave mit angegeben ;)
                        Master ioBroker in Proxmox als LXC auf 1. Tiny-Lenovo, Proxmox-VM als Slave auf 2. Tinyi-Lenovo mit Zigbee und Monitor zur Visualisierung, Hauptautomatisierung über S7 auf Beckhoff CX, dazu noch Shelly, Homematic...
                        • O Oli
                          @liv-in-sky
                          GlasfaserG
                          GlasfaserG
                          #616
                          @Oli
                          Du kannst es auch über CSS verändern ….
                          mdui-table mdui-table-ascard-r250-l mdui-table-striped noSwipe
                          • GlasfaserG Glasfaser
                            @Oli
                            NegaleinN
                            NegaleinN
                            Negalein
                            #617
                            @Glasfaser sagte in Script fürTabelle der Batterie Zustände:
                            Cool
                            Danke für den Tipp
                            ° Fixer ---> iob fix
                            Z 1 Antwort Letzte Antwort
                            • NegaleinN Negalein
                              Cool
                              Danke für den Tipp
                              Z
                              Z
                              zahnheinrich
                              #618
                              @liv-in-sky
                              Betreibe einige CuxD Geräte in einer separaten hm-rpc Instanz.
                              Diese Geräte haben sämtlich, da virtuell, KEINE Werte für Spannung o.ä.
                              Da sie aber zu den HM Geräten sortiert werden, kommen bei Skripterstellung entsprechende Fehlermeldungen.
                              Kannst du diese Geräte oder besser/einfacher die ganze Instanz ausklammern?
                              Die Werte:
                              hm-rpc.0.json
                              Das Bild:
                              MfG Ulrich
                              HomoranH liv-in-skyL 2 Antworten Letzte Antwort
                              • Z zahnheinrich
                                @liv-in-sky
                                Die Werte:
                                hm-rpc.0.json
                                Das Bild:
                                #619
                                @zahnheinrich sagte in Script fürTabelle der Batterie Zustände:
                                Dazu gäbe es das Filter-Array ganz zu Beginn.
                                Ob das einfach mit wildcards klappt um sich Schreibarbeit zu ersparen habe ich noch nicht getestet
                                var filterArray=["hm-rpc.0.MEQ1097293.0.LOWBAT","hm-rpc.0.LEQ0397071.0.LOWBAT","hm-rpc.0.MEQ0082816.0,LOWBAT",...
                                Was mich allerdings wundert ist dass diese Geräte gefunden werden, obwohl sie kinene LOWBAT Datenpunkt haben
                                Z HomoranH 3 Antworten Letzte Antwort
                                  Z
                                  Z
                                  zahnheinrich
                                  #620
                                  @Homoran
                                  Ahh ja, guter Hinweis! Danke
                                  MfG Ulrich
                                  • Z zahnheinrich
                                    @liv-in-sky
                                    Die Werte:
                                    hm-rpc.0.json
                                    Das Bild:
                                    liv-in-skyL
                                    liv-in-skyL
                                    #621
                                    @zahnheinrich ich sehe kein LOW_BAT und kein BATTERY_STATE - oder übersehe ich da was
                                    das script sollte diese geräte garnicht finden und aufnehmen
                                      #622
                                      @Homoran sagte in Script fürTabelle der Batterie Zustände:
                                      Mein Reden!
                                      • Z zahnheinrich
                                        @Homoran
                                        liv-in-skyL
                                        liv-in-skyL
                                        #623
                                        @zahnheinrich zeig mal die fehlermeldung vom log, wenn das script startet
                                          Z
                                          Z
                                          zahnheinrich
                                          schrieb am zuletzt editiert von zahnheinrich
                                          #624
                                          @Homoran
                                          Finden tut er sie aber trotzdem:
                                          javascript.0	2020-01-25 20:15:00.078	warn	(28218) at writeHTML (script.js.common.Tabellen.BatterieSpannung:611:26)
                                          javascript.0	2020-01-25 20:15:00.078	warn	(28218) at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:846:29)
                                          javascript.0	2020-01-25 20:15:00.077	warn	(28218) at script.js.common.Tabellen.BatterieSpannung:625:17
                                          javascript.0	2020-01-25 20:15:00.076	warn	(28218) getState "hm-rpc.0.CUX9000001.0.LOWBAT" not found (3) states[id]=null
                                          OK, wenn ich den nicht existierenden z.B.
                                          "hm-rpc.0.CUX9002003.0.LOWBAT"
                                          in die Filterliste eintrage, gehts.
                                          MfG Ulrich
                                          84.1k
