  4. Sonoff-Adapter
Sonoff-Adapter
sonoff-adapter
102 Beiträge 8 Kommentatoren 16.5k Aufrufe 6 Beobachtet
  • L Offline
    Leon111
    das ist der letzte Log:
    sonoff.0 2019-06-08 12:12:35.939 info Starting MQTT authenticated server on port 1883
    sonoff.0 2019-06-08 12:12:35.864 info starting. Version 2.2.2 in /opt/iobroker/node_modules/iobroker.sonoff, node: v8.15.0
    host.raspberrypi 2019-06-08 12:12:34.514 info instance system.adapter.sonoff.0 started with pid 1050
    host.raspberrypi 2019-06-08 12:12:32.039 info instance system.adapter.sonoff.0 terminated with code 0 (OK)
    host.raspberrypi 2019-06-08 12:12:31.999 info stopInstance system.adapter.sonoff.0 killing pid 357
    host.raspberrypi 2019-06-08 12:12:31.998 info object change system.adapter.sonoff.0
    sonoff.0 2019-06-08 12:12:00.117 info Starting MQTT authenticated server on port 1883
    sonoff.0 2019-06-08 12:12:00.037 info starting. Version 2.2.2 in /opt/iobroker/node_modules/iobroker.sonoff, node: v8.15.0
    host.raspberrypi 2019-06-08 12:11:58.817 info instance system.adapter.sonoff.0 started with pid 357
    host.raspberrypi 2019-06-08 12:11:56.333 info instance system.adapter.sonoff.0 terminated with code 0 (OK)
    host.raspberrypi 2019-06-08 12:11:56.279 info stopInstance system.adapter.sonoff.0 killing pid 23179
    host.raspberrypi 2019-06-08 12:11:56.278 info stopInstance system.adapter.sonoff.0
    host.raspberrypi 2019-06-08 12:11:56.277 info object change system.adapter.sonoff.0
    info.0 2019-06-08 12:10:01.426 info Popup-News readed...
    sonoff.0 2019-06-08 12:02:52.403 info Starting MQTT server on port 1883
    sonoff.0 2019-06-08 12:02:52.277 info starting. Version 2.2.2 in /opt/iobroker/node_modules/iobroker.sonoff, node: v8.15.0
    sonoff.0 2019-06-08 12:02:47.015 error no connection to objects DB
    iobroker 2019-06-08 12:02:40.972 info exit 0
    iobroker 2019-06-08 12:02:40.946 info host.raspberrypi object system.adapter.sonoff.0 created
    host.raspberrypi 2019-06-08 12:02:40.935 info instance system.adapter.sonoff.0 started with pid 23179
    host.raspberrypi 2019-06-08 12:02:40.907 info object change system.adapter.sonoff.0
    iobroker 2019-06-08 12:02:40.859 info host.raspberrypi object system.adapter.sonoff.0.alive created
    iobroker 2019-06-08 12:02:40.823 info host.raspberrypi object system.adapter.sonoff.0.connected created
    iobroker 2019-06-08 12:02:40.787 info host.raspberrypi object system.adapter.sonoff.0.cpu created
    iobroker 2019-06-08 12:02:40.751 info host.raspberrypi object system.adapter.sonoff.0.cputime created
    iobroker 2019-06-08 12:02:40.714 info host.raspberrypi object system.adapter.sonoff.0.memHeapUsed created
    iobroker 2019-06-08 12:02:40.683 info host.raspberrypi object system.adapter.sonoff.0.memHeapTotal created
    iobroker 2019-06-08 12:02:40.651 info host.raspberrypi object system.adapter.sonoff.0.memRss created
    iobroker 2019-06-08 12:02:40.619 info host.raspberrypi object system.adapter.sonoff.0.uptime created
    iobroker 2019-06-08 12:02:40.586 info host.raspberrypi object system.adapter.sonoff.0.inputCount created
    iobroker 2019-06-08 12:02:40.551 info host.raspberrypi object system.adapter.sonoff.0.outputCount created
    iobroker 2019-06-08 12:02:40.520 info host.raspberrypi object sonoff.0.info created
    iobroker 2019-06-08 12:02:40.490 info host.raspberrypi object sonoff.0.info.connection created
    iobroker 2019-06-08 12:02:40.482 info host.raspberrypi create instance sonoff
    iobroker 2019-06-08 12:02:40.447 info host.raspberrypi object system.adapter.sonoff created
    v522533V 1 Antwort Letzte Antwort
    • L Leon111
      Hi, danke erstmal für Deine Hilfe. Nach der Neuinstalation bleibt der Adapter gelb und alle Geräte sind weg.
      crunchipC Abwesend
      crunchipC Abwesend
      @Leon111 denke das dein MQTT nicht passt, wie oben schon erwähnt
      siehe
      @Jan1 sagte in Sonoff-Adapter:
      Hast aber nicht zufällig noch den MQTT Adapter auf dem selben Port laufen?
      • L Leon111
        v522533V Offline
        v522533V Offline
        v522533
        @Leon111 sagte in Sonoff-Adapter:
        das sollte glaube ich auch nicht sein. frage mich aber bitte nicht wie man das repariert. Ich hatte das auch mal bei nem anderen adapter, da ging dann auch nichts mehr
        Gruß Chris
        • v522533V v522533
          Jan1
          @Leon111
          mach mal ein Screenshot von der Adapter Seite
          • J Jan1
            @Leon111
            v522533V Offline
            v522533V Offline
            v522533
            @Jan1
            ich glaube du meinst leon und nicht mich ;) bei mir geht alles
            Gruß Chris
            • L Offline
              Leon111
              Meinst Du Adapter- oder Instanzen-Seite?
              • L Leon111
                Jan1
                @Leon111
                Die Adapter Seite, da DU die Frage zum MQTT Adapter noch nicht beantwortet hast, möchte ich's einfach mal selber sehen 😀
                • L Offline
                  Leon111
                  • L Leon111
                    Jan1
                    @Leon111
                    OK, ich glaube Du hast da noch ein paar Probleme mehr als nur den Sonoff Adapter.
                    Was hats denn als Admin Version und bist auf default oder latest?
                    Dann deinstalliere bitte alles was gelb ist und bring Dein System auf einen aktuellen Stand, am besten auf latest.
                    Es wäre auch von Interesse, welche Node und NPM Version verwendet wird.
                    • L Offline
                      Leon111
                      MQTT habe ich deaktieviert, da ich die Sonoff-bridge nicht mehr benutze.
                      Wie Du siehst auch der Mihome adapter ist gelb und der Raspi. Alles Heute Morgen passiert. Mein Smart TV ist erst seit Heute online. Aber die IP-Nummer kolliediert nicht. Deshalb kann ich mir nicht erklären wodurch das passiert ist.
                      An alle die sich jetzt gedanken drüber machen und versuchen mir zu helfen Herzlichen Dank .
                      • L Offline
                        Leon111
                        lattform: linux
                        RAM: 927.1 MB
                        Node.js: v8.15.0
                        NPM: 6.4.1
                        • L Offline
                          Leon111
                          Admin 3.6.2
                          • L Leon111
                            Jan1
                            @Leon111
                            Die Sonoff Bridge läuft aber auch mit dem Sonoff Adapter wenn Tasmota drauf ist.
                            NPM ist etwas alt, aber daran liegt es nicht. MAch mal was ich geschrieben habe, alles was gelb ist deaktivieren oder besser deinstallieren und alles auf einen aktuellen Stand.
                            Auf alle Fälle mal Admin und Host.
                            • L Offline
                              Leon111
                              Plattform: linux
                              RAM: 927.1 MB
                              Node.js: v8.15.0
                              NPM: 6.4.1
                              raspberrypi
                              Typ: js-controller
                              Titel: JS controller
                              OS: linux
                              Verfügbar: 1.5.12
                              Eingerichtet: 1.5.12
                              Ereignisse: ⇥10 / ↦13
                              Admin 3.6.3
                              Es hat sich also nicht viel verändert
                              • L Offline
                                Leon111
                                beim updaten.....
                                root@raspberrypi:/opt/iobroker# sudo iobroker upgrade self
                                Update js-controller from @1.5.8 to @1.5.12
                                NPM version: 6.4.1
                                npm install iobroker.js-controller@1.5.12 --unsafe-perm --production --save --prefix "/opt/iobroker" (System call)
                                ../authenticate_pam.cc:30:31: fatal error: security/pam_appl.h: Datei oder Verzeichnis nicht gefunden
                                #include <security/pam_appl.h>
                                compilation terminated.
                                make: *** [Release/obj.target/authenticate_pam/authenticate_pam.o] Fehler 1
                                gyp ERR! build error
                                gyp ERR! stack Error: make failed with exit code: 2
                                gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)
                                gyp ERR! stack at emitTwo (events.js:126:13)
                                gyp ERR! stack at ChildProcess.emit (events.js:214:7)
                                gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:198:12)
                                gyp ERR! System Linux 4.14.79-v7+
                                gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                                gyp ERR! cwd /opt/iobroker/node_modules/authenticate-pam
                                gyp ERR! node -v v8.15.0
                                gyp ERR! node-gyp -v v3.8.0
                                gyp ERR! not ok
                                prebuild-install WARN install No prebuilt binaries found (target=8.15.0 runtime=node arch=arm libc= platform=linux)
                                In file included from ../src/./serialport.h:6:0,
                                from ../src/serialport.cpp:1:
                                ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:
                                ../src/serialport.cpp:291:12: internal compiler error: Speicherzugriffsfehler
                                NAN_METHOD(Get) {
                                ../node_modules/nan/nan.h:1566:33: note: in definition of macro ‘NAN_METHOD’
                                Nan::NAN_METHOD_RETURN_TYPE name(Nan::NAN_METHOD_ARGS_TYPE info)
                                Please submit a full bug report,
                                with preprocessed source if appropriate.
                                See <file:///usr/share/doc/gcc-6/README.Bugs> for instructions.
                                make: *** [Release/obj.target/bindings/src/serialport.o] Fehler 1
                                gyp ERR! cwd /opt/iobroker/node_modules/@serialport/bindings
                                gyp ERR! not ok
                                gyp ERR! not ok
                                npm WARN JSON.parse Failed to parse json
                                npm WARN JSON.parse Unexpected token
                                npm WARN JSON.parse in JSON at position 14 while parsing '{
                                npm WARN JSON.parse "_argsb: [
                                npm WARN JSON.parse [
                                npm WARN JSON.parse {
                                npm WARN JSON.parse $ "ra'
                                npm WARN bl@0.7.0 requires a peer of stream-browserify@* but none is installed. You must install peer dependencies yourself.
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.3 (node_modules/osx-temperature-sensor):
                                npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@0.1.4 (node_modules/xpc-connection):
                                npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 (node_modules/authenticate-pam):
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 install: node-gyp rebuild
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: @serialport/bindings@2.0.8 (node_modules/@serialport/bindings):
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: @serialport/bindings@2.0.8 install: prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
                                Host "raspberrypi" (linux) updated
                                Execute: chmod -R 777 /opt/iobroker
                                Chmod finished. Restart controller
                                Starting node restart.js
                                root@raspberrypi:/opt/iobroker# Please submit a full bug report,
                                -bash: Please: Kommando nicht gefunden.
                                root@raspberrypi:/opt/iobroker# with preprocessed source if appropriate.
                                -bash: with: Kommando nicht gefunden.
                                root@raspberrypi:/opt/iobroker# See <file:///usr/share/doc/gcc-6/README.Bugs> for instructions.
                                -bash: file:///usr/share/doc/gcc-6/README.Bugs: Datei oder Verzeichnis nicht gefunden
                                root@raspberrypi:/opt/iobroker# make: *** [Release/obj.target/bindings/src/serialport.o] Fehler 1
                                -bash: make:: Kommando nicht gefunden.
                                root@raspberrypi:/opt/iobroker# gyp ERR! build error
                                -bash: gyp: Kommando nicht gefunden.
                                root@raspberrypi:/opt/iobroker# gyp ERR! stack Error: make failed with exit code: 2
                                make: *** Es wurden keine Ziele angegeben und keine „make“-Steuerdatei gefunden. Schluss.
                                root@raspberrypi:/opt/iobroker# gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)
                                -bash: Syntaxfehler beim unerwarteten Wort (' root@raspberrypi:/opt/iobroker# gyp ERR! stack at emitTwo (events.js:126:13) -bash: Syntaxfehler beim unerwarteten Wort ('
                                root@raspberrypi:/opt/iobroker# gyp ERR! stack at ChildProcess.emit (events.js:214:7)
                                -bash: Syntaxfehler beim unerwarteten Wort (' root@raspberrypi:/opt/iobroker# gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:198:12) -bash: Syntaxfehler beim unerwarteten Wort ('
                                root@raspberrypi:/opt/iobroker# gyp ERR! System Linux 4.14.79-v7+
                                root@raspberrypi:/opt/iobroker# gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                                root@raspberrypi:/opt/iobroker# gyp ERR! cwd /opt/iobroker/node_modules/@serialport/bindings
                                root@raspberrypi:/opt/iobroker# gyp ERR! node -v v8.15.0
                                root@raspberrypi:/opt/iobroker# gyp ERR! node-gyp -v v3.8.0
                                root@raspberrypi:/opt/iobroker# gyp ERR! not ok
                                sind ja irgendwelche Fehler aufgetreten
                                • L Offline
                                  Leon111
                                  Plattform: linux
                                  RAM: 927.1 MB
                                  Node.js: v8.16.0
                                  NPM: v6.4.1
                                  raspberrypi
                                  Typ: js-controller
                                  OS: linux
                                  Verfügbar: 1.5.12
                                  visibility
                                  build
                                  Host raspberrypi
                                  ioBroker.admin 3.6.3
                                  • L Offline
                                    Leon111
                                    ein Update steht noch zur Verfügung und zwar Bluetooth von 0.5.2 zur 0.7.3 , aber wenn ich es ausfüre dann funktioniert der Adapter nicht mehr und dem entsprechen meine Bluetooth-Geräte , also lasse ich es lieber.
                                    Soll ich jetzt die Adapter "Sonoff" und "Mihome" wieder instalieren?
                                    • L Offline
                                      Leon111
                                      Der Sonoff-Adapter bleibt gelb....
                                      • L Leon111
                                        crunchipC Abwesend
                                        crunchipC Abwesend
                                        @Leon111 zeig mal
                                        und MQTT Einstellung eines deiner Sonoff Geräte
                                        • L Offline
                                          Leon111
                                          Der Port ist beim mir gleich 1883 im Adapter und in den Geräten
