  4. Sonoff-Adapter
Sonoff-Adapter
sonoff-adapter
102 Beiträge 8 Kommentatoren 16.5k Aufrufe 6 Beobachtet
  • L Leon111
    sonoff.0 2019-06-08 11:33:05.287 debug stateChange sonoff.0.Sonoff-Basic-7.alive: {"val":false,"ack":true,"ts":1559986385275,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1540338327116}
    sonoff.0 2019-06-08 11:33:05.287 debug stateChange sonoff.0.Sonoff-Basic-6.alive: {"val":false,"ack":true,"ts":1559986385275,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1541266636916}
    sonoff.0 2019-06-08 11:33:05.287 debug stateChange sonoff.0.Sonoff-Basic-5.alive: {"val":false,"ack":true,"ts":1559986385274,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1540338327116}
    sonoff.0 2019-06-08 11:33:05.286 debug stateChange sonoff.0.Sonoff-Basic-4.alive: {"val":false,"ack":true,"ts":1559986385271,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1559979121461}
    sonoff.0 2019-06-08 11:33:05.283 debug stateChange sonoff.0.Schlafzimmer-Licht.alive: {"val":false,"ack":true,"ts":1559986385271,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1559979121460}
    sonoff.0 2019-06-08 11:33:05.282 debug stateChange sonoff.0.Sonoff-Basic-3.alive: {"val":false,"ack":true,"ts":1559986385271,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1559979121460}
    sonoff.0 2019-06-08 11:33:05.282 debug stateChange sonoff.0.Sonoff-Basic-1.alive: {"val":false,"ack":true,"ts":1559986385270,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1559979121460}
    sonoff.0 2019-06-08 11:33:05.282 debug stateChange sonoff.0.Sonoff-Basic-2.alive: {"val":false,"ack":true,"ts":1559986385270,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1559979121460}
    sonoff.0 2019-06-08 11:33:05.277 debug stateChange sonoff.0.Sonoff-RF-Bridge.alive: {"val":false,"ack":true,"ts":1559986385269,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1522680641746}
    sonoff.0 2019-06-08 11:33:05.274 debug stateChange sonoff.0.Sonoff-S20-3.alive: {"val":false,"ack":true,"ts":1559986385265,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1559979121459}
    sonoff.0 2019-06-08 11:33:05.273 debug stateChange sonoff.0.Sonoff-S20-4.alive: {"val":false,"ack":true,"ts":1559986385265,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1548930526506}
    sonoff.0 2019-06-08 11:33:05.273 debug stateChange sonoff.0.Sonoff-S20-2.alive: {"val":false,"ack":true,"ts":1559986385264,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1559979121453}
    sonoff.0 2019-06-08 11:33:05.273 debug stateChange sonoff.0.Sonoff-S20-1.alive: {"val":false,"ack":true,"ts":1559986385263,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1559979121452}
    sonoff.0 2019-06-08 11:33:05.272 debug stateChange sonoff.0.Küche Vitrinen licht.alive: {"val":false,"ack":true,"ts":1559986385261,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1525357953249}
    sonoff.0 2019-06-08 11:33:05.272 debug stateChange sonoff.0.Küchenlicht.alive: {"val":false,"ack":true,"ts":1559986385258,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1559979121447}
    sonoff.0 2019-06-08 11:33:05.093 debug stateChange sonoff.0.info.connection: {"val":"","ack":true,"ts":1559986385084,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1559977521881}
    sonoff.0 2019-06-08 11:33:05.041 info Starting MQTT authenticated server on port 1883
    sonoff.0 2019-06-08 11:33:04.971 info starting. Version 2.2.2 in /opt/iobroker/node_modules/iobroker.sonoff, node: v8.15.0
    sonoff.0 2019-06-08 11:33:04.916 debug statesDB connected
    sonoff.0 2019-06-08 11:33:04.874 debug objectDB connected
    host.raspberrypi 2019-06-08 11:33:03.772 info instance system.adapter.sonoff.0 started with pid 24876
    host.raspberrypi 2019-06-08 11:33:01.312 info instance system.adapter.sonoff.0 terminated with code 0 (OK)
    host.raspberrypi 2019-06-08 11:33:01.244 info stopInstance system.adapter.sonoff.0 killing pid 23332
    host.raspberrypi 2019-06-08 11:33:01.243 info stopInstance system.adapter.sonoff.0
    host.raspberrypi 2019-06-08 11:33:01.242 info object change system.adapter.sonoff.0
    sonoff.0 2019-06-08 11:31:39.464 info Starting MQTT authenticated server on port 1883
    sonoff.0 2019-06-08 11:31:39.363 info starting. Version 2.2.2 in /opt/iobroker/node_modules/iobroker.sonoff, node: v8.15.0
    host.raspberrypi 2019-06-08 11:31:37.944 info instance system.adapter.sonoff.0 started with pid 23332
    host.raspberrypi 2019-06-08 11:31:35.464 info instance system.adapter.sonoff.0 terminated with code 0 (OK)
    host.raspberrypi 2019-06-08 11:31:35.421 info stopInstance system.adapter.sonoff.0 killing pid 671
    host.raspberrypi 2019-06-08 11:31:35.418 info object change system.adapter.sonoff.0
    Jan1
    @Leon111
    hast den Adapter jetzt schon mal neu installiert?
    Log bitte in Code poasten, ist übersichtlicher😉
    • L Offline
      Leon111
      Soll ich den Adapter erst deinstalieren und dann neuinstalieren?
      Alle Geräte gehen dan verlaren?
      • L Leon111
        Jan1
        @Leon111
        ja und der findet selbständig danach eh wieder alle
        • L Offline
          Leon111
          Hi, danke erstmal für Deine Hilfe. Nach der Neuinstalation bleibt der Adapter gelb und alle Geräte sind weg.
          J crunchipC 2 Antworten Letzte Antwort
          • L Leon111
            Jan1
            @Leon111
            die kommen ja auch nur wenn der Adapter grün wird und genau das sollte auch so sein.
            • L Offline
              Leon111
              ja richtig
              • L Offline
                Leon111
                das ist der letzte Log:
                sonoff.0 2019-06-08 12:12:35.939 info Starting MQTT authenticated server on port 1883
                sonoff.0 2019-06-08 12:12:35.864 info starting. Version 2.2.2 in /opt/iobroker/node_modules/iobroker.sonoff, node: v8.15.0
                host.raspberrypi 2019-06-08 12:12:34.514 info instance system.adapter.sonoff.0 started with pid 1050
                host.raspberrypi 2019-06-08 12:12:32.039 info instance system.adapter.sonoff.0 terminated with code 0 (OK)
                host.raspberrypi 2019-06-08 12:12:31.999 info stopInstance system.adapter.sonoff.0 killing pid 357
                host.raspberrypi 2019-06-08 12:12:31.998 info object change system.adapter.sonoff.0
                sonoff.0 2019-06-08 12:12:00.117 info Starting MQTT authenticated server on port 1883
                sonoff.0 2019-06-08 12:12:00.037 info starting. Version 2.2.2 in /opt/iobroker/node_modules/iobroker.sonoff, node: v8.15.0
                host.raspberrypi 2019-06-08 12:11:58.817 info instance system.adapter.sonoff.0 started with pid 357
                host.raspberrypi 2019-06-08 12:11:56.333 info instance system.adapter.sonoff.0 terminated with code 0 (OK)
                host.raspberrypi 2019-06-08 12:11:56.279 info stopInstance system.adapter.sonoff.0 killing pid 23179
                host.raspberrypi 2019-06-08 12:11:56.278 info stopInstance system.adapter.sonoff.0
                host.raspberrypi 2019-06-08 12:11:56.277 info object change system.adapter.sonoff.0
                info.0 2019-06-08 12:10:01.426 info Popup-News readed...
                sonoff.0 2019-06-08 12:02:52.403 info Starting MQTT server on port 1883
                sonoff.0 2019-06-08 12:02:52.277 info starting. Version 2.2.2 in /opt/iobroker/node_modules/iobroker.sonoff, node: v8.15.0
                sonoff.0 2019-06-08 12:02:47.015 error no connection to objects DB
                iobroker 2019-06-08 12:02:40.972 info exit 0
                iobroker 2019-06-08 12:02:40.946 info host.raspberrypi object system.adapter.sonoff.0 created
                host.raspberrypi 2019-06-08 12:02:40.935 info instance system.adapter.sonoff.0 started with pid 23179
                host.raspberrypi 2019-06-08 12:02:40.907 info object change system.adapter.sonoff.0
                iobroker 2019-06-08 12:02:40.859 info host.raspberrypi object system.adapter.sonoff.0.alive created
                iobroker 2019-06-08 12:02:40.823 info host.raspberrypi object system.adapter.sonoff.0.connected created
                iobroker 2019-06-08 12:02:40.787 info host.raspberrypi object system.adapter.sonoff.0.cpu created
                iobroker 2019-06-08 12:02:40.751 info host.raspberrypi object system.adapter.sonoff.0.cputime created
                iobroker 2019-06-08 12:02:40.714 info host.raspberrypi object system.adapter.sonoff.0.memHeapUsed created
                iobroker 2019-06-08 12:02:40.683 info host.raspberrypi object system.adapter.sonoff.0.memHeapTotal created
                iobroker 2019-06-08 12:02:40.651 info host.raspberrypi object system.adapter.sonoff.0.memRss created
                iobroker 2019-06-08 12:02:40.619 info host.raspberrypi object system.adapter.sonoff.0.uptime created
                iobroker 2019-06-08 12:02:40.586 info host.raspberrypi object system.adapter.sonoff.0.inputCount created
                iobroker 2019-06-08 12:02:40.551 info host.raspberrypi object system.adapter.sonoff.0.outputCount created
                iobroker 2019-06-08 12:02:40.520 info host.raspberrypi object sonoff.0.info created
                iobroker 2019-06-08 12:02:40.490 info host.raspberrypi object sonoff.0.info.connection created
                iobroker 2019-06-08 12:02:40.482 info host.raspberrypi create instance sonoff
                iobroker 2019-06-08 12:02:40.447 info host.raspberrypi object system.adapter.sonoff created
                v522533V 1 Antwort Letzte Antwort
                • L Leon111
                  crunchipC Abwesend
                  crunchipC Abwesend
                  @Leon111 denke das dein MQTT nicht passt, wie oben schon erwähnt
                  siehe
                  @Jan1 sagte in Sonoff-Adapter:
                  Hast aber nicht zufällig noch den MQTT Adapter auf dem selben Port laufen?
                  • L Leon111
                    v522533V Offline
                    v522533V Offline
                    v522533
                    @Leon111 sagte in Sonoff-Adapter:
                    das sollte glaube ich auch nicht sein. frage mich aber bitte nicht wie man das repariert. Ich hatte das auch mal bei nem anderen adapter, da ging dann auch nichts mehr
                    Gruß Chris
                    • v522533V v522533
                      Jan1
                      @Leon111
                      mach mal ein Screenshot von der Adapter Seite
                      • J Jan1
                        @Leon111
                        v522533V Offline
                        v522533V Offline
                        v522533
                        @Jan1
                        ich glaube du meinst leon und nicht mich ;) bei mir geht alles
                        Gruß Chris
                        • L Offline
                          Leon111
                          Meinst Du Adapter- oder Instanzen-Seite?
                          • L Leon111
                            Jan1
                            @Leon111
                            Die Adapter Seite, da DU die Frage zum MQTT Adapter noch nicht beantwortet hast, möchte ich's einfach mal selber sehen 😀
                            • L Offline
                              Leon111
                              • L Leon111
                                Jan1
                                @Leon111
                                OK, ich glaube Du hast da noch ein paar Probleme mehr als nur den Sonoff Adapter.
                                Was hats denn als Admin Version und bist auf default oder latest?
                                Dann deinstalliere bitte alles was gelb ist und bring Dein System auf einen aktuellen Stand, am besten auf latest.
                                Es wäre auch von Interesse, welche Node und NPM Version verwendet wird.
                                • L Offline
                                  Leon111
                                  MQTT habe ich deaktieviert, da ich die Sonoff-bridge nicht mehr benutze.
                                  Wie Du siehst auch der Mihome adapter ist gelb und der Raspi. Alles Heute Morgen passiert. Mein Smart TV ist erst seit Heute online. Aber die IP-Nummer kolliediert nicht. Deshalb kann ich mir nicht erklären wodurch das passiert ist.
                                  An alle die sich jetzt gedanken drüber machen und versuchen mir zu helfen Herzlichen Dank .
                                  • L Offline
                                    Leon111
                                    lattform: linux
                                    RAM: 927.1 MB
                                    Node.js: v8.15.0
                                    NPM: 6.4.1
                                    • L Offline
                                      Leon111
                                      Admin 3.6.2
                                      • L Leon111
                                        Jan1
                                        @Leon111
                                        Die Sonoff Bridge läuft aber auch mit dem Sonoff Adapter wenn Tasmota drauf ist.
                                        NPM ist etwas alt, aber daran liegt es nicht. MAch mal was ich geschrieben habe, alles was gelb ist deaktivieren oder besser deinstallieren und alles auf einen aktuellen Stand.
                                        Auf alle Fälle mal Admin und Host.
                                        • L Offline
                                          Leon111
                                          Plattform: linux
                                          RAM: 927.1 MB
                                          Node.js: v8.15.0
                                          NPM: 6.4.1
                                          raspberrypi
                                          Typ: js-controller
                                          Titel: JS controller
                                          OS: linux
                                          Verfügbar: 1.5.12
                                          Eingerichtet: 1.5.12
                                          Ereignisse: ⇥10 / ↦13
                                          Admin 3.6.3
                                          Es hat sich also nicht viel verändert
