  4. Sonoff-Adapter
Sonoff-Adapter
sonoff-adapter
102 Beiträge 8 Kommentatoren 16.5k Aufrufe 6 Beobachtet
  • L Leon111
    Sorry,
    sonoff.0 2019-06-08 10:34:23.516 info Starting MQTT authenticated server on port 1883
    sonoff.0 2019-06-08 10:34:23.433 info starting. Version 2.2.2 in /opt/iobroker/node_modules/iobroker.sonoff, node: v8.15.0
    host.raspberrypi 2019-06-08 10:34:22.046 info instance system.adapter.sonoff.0 started with pid 4519
    host.raspberrypi 2019-06-08 10:34:19.579 info instance system.adapter.sonoff.0 terminated with code 0 (OK)
    host.raspberrypi 2019-06-08 10:34:19.520 info stopInstance system.adapter.sonoff.0 killing pid 668
    host.raspberrypi 2019-06-08 10:34:19.519 info stopInstance system.adapter.sonoff.0
    host.raspberrypi 2019-06-08 10:34:19.514 info object change system.adapter.sonoff.0
    Jan1
    @Leon111
    OK, stell mal den Adapter auf debug, in dem LOG steht nur, dass er beendet wurde.
    Alternativ kannst den auch mal frisch installieren und schauen, ob sich das Problem von alleine löst.
    Hast aber nicht zufällig noch den MQTT Adapter auf dem selben Port laufen?
    • L Offline
      Leon111
      sonoff.0 2019-06-08 11:33:05.287 debug stateChange sonoff.0.Sonoff-Basic-7.alive: {"val":false,"ack":true,"ts":1559986385275,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1540338327116}
      sonoff.0 2019-06-08 11:33:05.287 debug stateChange sonoff.0.Sonoff-Basic-6.alive: {"val":false,"ack":true,"ts":1559986385275,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1541266636916}
      sonoff.0 2019-06-08 11:33:05.287 debug stateChange sonoff.0.Sonoff-Basic-5.alive: {"val":false,"ack":true,"ts":1559986385274,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1540338327116}
      sonoff.0 2019-06-08 11:33:05.286 debug stateChange sonoff.0.Sonoff-Basic-4.alive: {"val":false,"ack":true,"ts":1559986385271,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1559979121461}
      sonoff.0 2019-06-08 11:33:05.283 debug stateChange sonoff.0.Schlafzimmer-Licht.alive: {"val":false,"ack":true,"ts":1559986385271,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1559979121460}
      sonoff.0 2019-06-08 11:33:05.282 debug stateChange sonoff.0.Sonoff-Basic-3.alive: {"val":false,"ack":true,"ts":1559986385271,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1559979121460}
      sonoff.0 2019-06-08 11:33:05.282 debug stateChange sonoff.0.Sonoff-Basic-1.alive: {"val":false,"ack":true,"ts":1559986385270,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1559979121460}
      sonoff.0 2019-06-08 11:33:05.282 debug stateChange sonoff.0.Sonoff-Basic-2.alive: {"val":false,"ack":true,"ts":1559986385270,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1559979121460}
      sonoff.0 2019-06-08 11:33:05.277 debug stateChange sonoff.0.Sonoff-RF-Bridge.alive: {"val":false,"ack":true,"ts":1559986385269,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1522680641746}
      sonoff.0 2019-06-08 11:33:05.274 debug stateChange sonoff.0.Sonoff-S20-3.alive: {"val":false,"ack":true,"ts":1559986385265,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1559979121459}
      sonoff.0 2019-06-08 11:33:05.273 debug stateChange sonoff.0.Sonoff-S20-4.alive: {"val":false,"ack":true,"ts":1559986385265,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1548930526506}
      sonoff.0 2019-06-08 11:33:05.273 debug stateChange sonoff.0.Sonoff-S20-2.alive: {"val":false,"ack":true,"ts":1559986385264,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1559979121453}
      sonoff.0 2019-06-08 11:33:05.273 debug stateChange sonoff.0.Sonoff-S20-1.alive: {"val":false,"ack":true,"ts":1559986385263,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1559979121452}
      sonoff.0 2019-06-08 11:33:05.272 debug stateChange sonoff.0.Küche Vitrinen licht.alive: {"val":false,"ack":true,"ts":1559986385261,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1525357953249}
      sonoff.0 2019-06-08 11:33:05.272 debug stateChange sonoff.0.Küchenlicht.alive: {"val":false,"ack":true,"ts":1559986385258,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1559979121447}
      sonoff.0 2019-06-08 11:33:05.093 debug stateChange sonoff.0.info.connection: {"val":"","ack":true,"ts":1559986385084,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1559977521881}
      sonoff.0 2019-06-08 11:33:05.041 info Starting MQTT authenticated server on port 1883
      sonoff.0 2019-06-08 11:33:04.971 info starting. Version 2.2.2 in /opt/iobroker/node_modules/iobroker.sonoff, node: v8.15.0
      sonoff.0 2019-06-08 11:33:04.916 debug statesDB connected
      sonoff.0 2019-06-08 11:33:04.874 debug objectDB connected
      host.raspberrypi 2019-06-08 11:33:03.772 info instance system.adapter.sonoff.0 started with pid 24876
      host.raspberrypi 2019-06-08 11:33:01.312 info instance system.adapter.sonoff.0 terminated with code 0 (OK)
      host.raspberrypi 2019-06-08 11:33:01.244 info stopInstance system.adapter.sonoff.0 killing pid 23332
      host.raspberrypi 2019-06-08 11:33:01.243 info stopInstance system.adapter.sonoff.0
      host.raspberrypi 2019-06-08 11:33:01.242 info object change system.adapter.sonoff.0
      sonoff.0 2019-06-08 11:31:39.464 info Starting MQTT authenticated server on port 1883
      sonoff.0 2019-06-08 11:31:39.363 info starting. Version 2.2.2 in /opt/iobroker/node_modules/iobroker.sonoff, node: v8.15.0
      host.raspberrypi 2019-06-08 11:31:37.944 info instance system.adapter.sonoff.0 started with pid 23332
      host.raspberrypi 2019-06-08 11:31:35.464 info instance system.adapter.sonoff.0 terminated with code 0 (OK)
      host.raspberrypi 2019-06-08 11:31:35.421 info stopInstance system.adapter.sonoff.0 killing pid 671
      host.raspberrypi 2019-06-08 11:31:35.418 info object change system.adapter.sonoff.0
      • L Leon111
        Jan1
        @Leon111
        hast den Adapter jetzt schon mal neu installiert?
        Log bitte in Code poasten, ist übersichtlicher😉
        • L Offline
          Leon111
          Soll ich den Adapter erst deinstalieren und dann neuinstalieren?
          Alle Geräte gehen dan verlaren?
          • L Leon111
            Jan1
            @Leon111
            ja und der findet selbständig danach eh wieder alle
            • L Offline
              Leon111
              Hi, danke erstmal für Deine Hilfe. Nach der Neuinstalation bleibt der Adapter gelb und alle Geräte sind weg.
              J crunchipC 2 Antworten Letzte Antwort
              • L Leon111
                Jan1
                @Leon111
                die kommen ja auch nur wenn der Adapter grün wird und genau das sollte auch so sein.
                • L Offline
                  Leon111
                  ja richtig
                  • L Offline
                    Leon111
                    das ist der letzte Log:
                    sonoff.0 2019-06-08 12:12:35.939 info Starting MQTT authenticated server on port 1883
                    sonoff.0 2019-06-08 12:12:35.864 info starting. Version 2.2.2 in /opt/iobroker/node_modules/iobroker.sonoff, node: v8.15.0
                    host.raspberrypi 2019-06-08 12:12:34.514 info instance system.adapter.sonoff.0 started with pid 1050
                    host.raspberrypi 2019-06-08 12:12:32.039 info instance system.adapter.sonoff.0 terminated with code 0 (OK)
                    host.raspberrypi 2019-06-08 12:12:31.999 info stopInstance system.adapter.sonoff.0 killing pid 357
                    host.raspberrypi 2019-06-08 12:12:31.998 info object change system.adapter.sonoff.0
                    sonoff.0 2019-06-08 12:12:00.117 info Starting MQTT authenticated server on port 1883
                    sonoff.0 2019-06-08 12:12:00.037 info starting. Version 2.2.2 in /opt/iobroker/node_modules/iobroker.sonoff, node: v8.15.0
                    host.raspberrypi 2019-06-08 12:11:58.817 info instance system.adapter.sonoff.0 started with pid 357
                    host.raspberrypi 2019-06-08 12:11:56.333 info instance system.adapter.sonoff.0 terminated with code 0 (OK)
                    host.raspberrypi 2019-06-08 12:11:56.279 info stopInstance system.adapter.sonoff.0 killing pid 23179
                    host.raspberrypi 2019-06-08 12:11:56.278 info stopInstance system.adapter.sonoff.0
                    host.raspberrypi 2019-06-08 12:11:56.277 info object change system.adapter.sonoff.0
                    info.0 2019-06-08 12:10:01.426 info Popup-News readed...
                    sonoff.0 2019-06-08 12:02:52.403 info Starting MQTT server on port 1883
                    sonoff.0 2019-06-08 12:02:52.277 info starting. Version 2.2.2 in /opt/iobroker/node_modules/iobroker.sonoff, node: v8.15.0
                    sonoff.0 2019-06-08 12:02:47.015 error no connection to objects DB
                    iobroker 2019-06-08 12:02:40.972 info exit 0
                    iobroker 2019-06-08 12:02:40.946 info host.raspberrypi object system.adapter.sonoff.0 created
                    host.raspberrypi 2019-06-08 12:02:40.935 info instance system.adapter.sonoff.0 started with pid 23179
                    host.raspberrypi 2019-06-08 12:02:40.907 info object change system.adapter.sonoff.0
                    iobroker 2019-06-08 12:02:40.859 info host.raspberrypi object system.adapter.sonoff.0.alive created
                    iobroker 2019-06-08 12:02:40.823 info host.raspberrypi object system.adapter.sonoff.0.connected created
                    iobroker 2019-06-08 12:02:40.787 info host.raspberrypi object system.adapter.sonoff.0.cpu created
                    iobroker 2019-06-08 12:02:40.751 info host.raspberrypi object system.adapter.sonoff.0.cputime created
                    iobroker 2019-06-08 12:02:40.714 info host.raspberrypi object system.adapter.sonoff.0.memHeapUsed created
                    iobroker 2019-06-08 12:02:40.683 info host.raspberrypi object system.adapter.sonoff.0.memHeapTotal created
                    iobroker 2019-06-08 12:02:40.651 info host.raspberrypi object system.adapter.sonoff.0.memRss created
                    iobroker 2019-06-08 12:02:40.619 info host.raspberrypi object system.adapter.sonoff.0.uptime created
                    iobroker 2019-06-08 12:02:40.586 info host.raspberrypi object system.adapter.sonoff.0.inputCount created
                    iobroker 2019-06-08 12:02:40.551 info host.raspberrypi object system.adapter.sonoff.0.outputCount created
                    iobroker 2019-06-08 12:02:40.520 info host.raspberrypi object sonoff.0.info created
                    iobroker 2019-06-08 12:02:40.490 info host.raspberrypi object sonoff.0.info.connection created
                    iobroker 2019-06-08 12:02:40.482 info host.raspberrypi create instance sonoff
                    iobroker 2019-06-08 12:02:40.447 info host.raspberrypi object system.adapter.sonoff created
                    v522533V 1 Antwort Letzte Antwort
                    • L Leon111
                      crunchipC Abwesend
                      crunchipC Abwesend
                      @Leon111 denke das dein MQTT nicht passt, wie oben schon erwähnt
                      siehe
                      @Jan1 sagte in Sonoff-Adapter:
                      • L Leon111
                        v522533V Offline
                        v522533V Offline
                        v522533
                        @Leon111 sagte in Sonoff-Adapter:
                        das sollte glaube ich auch nicht sein. frage mich aber bitte nicht wie man das repariert. Ich hatte das auch mal bei nem anderen adapter, da ging dann auch nichts mehr
                        Gruß Chris
                        • v522533V v522533
                          Jan1
                          @Leon111
                          mach mal ein Screenshot von der Adapter Seite
                          • J Jan1
                            @Leon111
                            v522533V Offline
                            v522533V Offline
                            v522533
                            @Jan1
                            ich glaube du meinst leon und nicht mich ;) bei mir geht alles
                            Gruß Chris
                            • L Offline
                              Leon111
                              Meinst Du Adapter- oder Instanzen-Seite?
                              • L Leon111
                                Jan1
                                @Leon111
                                Die Adapter Seite, da DU die Frage zum MQTT Adapter noch nicht beantwortet hast, möchte ich's einfach mal selber sehen 😀
                                • L Offline
                                  Leon111
                                  • L Leon111
                                    Jan1
                                    @Leon111
                                    OK, ich glaube Du hast da noch ein paar Probleme mehr als nur den Sonoff Adapter.
                                    Was hats denn als Admin Version und bist auf default oder latest?
                                    Dann deinstalliere bitte alles was gelb ist und bring Dein System auf einen aktuellen Stand, am besten auf latest.
                                    Es wäre auch von Interesse, welche Node und NPM Version verwendet wird.
                                    • L Offline
                                      Leon111
                                      MQTT habe ich deaktieviert, da ich die Sonoff-bridge nicht mehr benutze.
                                      Wie Du siehst auch der Mihome adapter ist gelb und der Raspi. Alles Heute Morgen passiert. Mein Smart TV ist erst seit Heute online. Aber die IP-Nummer kolliediert nicht. Deshalb kann ich mir nicht erklären wodurch das passiert ist.
                                      An alle die sich jetzt gedanken drüber machen und versuchen mir zu helfen Herzlichen Dank .
                                      • L Offline
                                        Leon111
                                        lattform: linux
                                        RAM: 927.1 MB
                                        Node.js: v8.15.0
                                        NPM: 6.4.1
                                        • L Offline
                                          Leon111
                                          Admin 3.6.2
