  4. [gelöst] Lichter zählen Script läuft nicht
156 Beiträge 33 Kommentatoren 36.2k Aufrufe 6 Beobachtet
    McMoneysack
    #118
    Der Log:
    018-11-07 20:29:31.723 - error: host.iobroker instance system.adapter.loxone.0 terminated with code 7 (Adapter already running)
    2018-11-07 20:29:31.723 - info: host.iobroker Restart adapter system.adapter.loxone.0 because enabled
    2018-11-07 20:30:01.726 - info: host.iobroker instance system.adapter.loxone.0 started with pid 22422
    2018-11-07 20:30:01.875 - error: host.iobroker instance system.adapter.loxone.0 terminated with code 7 (Adapter already running)
    2018-11-07 20:30:01.876 - info: host.iobroker Restart adapter system.adapter.loxone.0 because enabled
    2018-11-07 20:30:31.879 - info: host.iobroker instance system.adapter.loxone.0 started with pid 22432
    2018-11-07 20:30:32.033 - error: host.iobroker instance system.adapter.loxone.0 terminated with code 7 (Adapter already running)
    2018-11-07 20:30:32.033 - info: host.iobroker Restart adapter system.adapter.loxone.0 because enabled
    2018-11-07 20:31:02.036 - info: host.iobroker instance system.adapter.loxone.0 started with pid 22452
    2018-11-07 20:31:02.186 - error: host.iobroker instance system.adapter.loxone.0 terminated with code 7 (Adapter already running)
    2018-11-07 20:31:02.186 - info: host.iobroker Restart adapter system.adapter.loxone.0 because enabled
    2018-11-07 20:31:32.189 - info: host.iobroker instance system.adapter.loxone.0 started with pid 22462
    2018-11-07 20:31:32.339 - error: host.iobroker instance system.adapter.loxone.0 terminated with code 7 (Adapter already running)
    2018-11-07 20:31:32.339 - info: host.iobroker Restart adapter system.adapter.loxone.0 because enabled
    2018-11-07 20:31:46.378 - info: javascript.0 script.js.Test.Lichtfinal: Auslösender Schalter: loxone.0.0a41e8ce-0333-d48b-ffff86dfaf476a88.AI1.active: true
    2018-11-07 20:31:46.378 - info: javascript.0 script.js.Test.Lichtfinal: DP: Lichtsteuerung: Licht: active
    2018-11-07 20:31:46.379 - info: javascript.0 script.js.Test.Lichtfinal: Gerät: Licht
    2018-11-07 20:31:46.379 - info: javascript.0 script.js.Test.Lichtfinal: DP: Lich Büro Jill: LI13 Büro Angelo Spot Grau: active
    2018-11-07 20:31:46.379 - info: javascript.0 script.js.Test.Lichtfinal: Gerät: LI13 Büro Angelo Spot Grau
    2018-11-07 20:31:46.379 - info: javascript.0 script.js.Test.Lichtfinal: DP: BWM Steuerung Außen: Lampe Haustür: active
    2018-11-07 20:31:46.379 - info: javascript.0 script.js.Test.Lichtfinal: Gerät: Lampe Haustür
    2018-11-07 20:31:46.379 - info: javascript.0 script.js.Test.Lichtfinal: DP: Lichtsteuerung: Lampe Haustür: active
    2018-11-07 20:31:46.379 - info: javascript.0 script.js.Test.Lichtfinal: DP: Lichtsteuerung: EG Spot Decke: active
    2018-11-07 20:31:46.379 - info: javascript.0 script.js.Test.Lichtfinal: Gerät: EG Spot Decke
    2018-11-07 20:31:46.379 - info: javascript.0 script.js.Test.Lichtfinal: DP: Lichtsteuerung: EG Spot Boden: active
    2018-11-07 20:31:46.379 - info: javascript.0 script.js.Test.Lichtfinal: Gerät: EG Spot Boden
    2018-11-07 20:31:46.379 - info: javascript.0 script.js.Test.Lichtfinal: DP: Lichtsteuerung: Treppenlicht OG: active
    2018-11-07 20:31:46.379 - info: javascript.0 script.js.Test.Lichtfinal: Gerät: Treppenlicht OG
    2018-11-07 20:31:46.379 - info: javascript.0 script.js.Test.Lichtfinal: DP: Lichtsteuerung: Treppenlicht Keller: active
    2018-11-07 20:31:46.379 - info: javascript.0 script.js.Test.Lichtfinal: Gerät: Treppenlicht Keller
    2018-11-07 20:31:46.379 - info: javascript.0 script.js.Test.Lichtfinal: DP: Licht Flur OG: Flur OG Spot Decke: active
    2018-11-07 20:31:46.379 - info: javascript.0 script.js.Test.Lichtfinal: Gerät: Flur OG Spot Decke
    2018-11-07 20:31:46.379 - info: javascript.0 script.js.Test.Lichtfinal: DP: Licht Gästezimmer: Gäste Spot: active
    2018-11-07 20:31:46.379 - info: javascript.0 script.js.Test.Lichtfinal: Gerät: Gäste Spot
    2018-11-07 20:31:46.379 - info: javascript.0 script.js.Test.Lichtfinal: DP: Kellerlicht Unten: Keller Unten Licht: active
    2018-11-07 20:31:46.379 - info: javascript.0 script.js.Test.Lichtfinal: Gerät: Keller Unten Licht
    2018-11-07 20:31:46.379 - info: javascript.0 script.js.Test.Lichtfinal: DP: Kellerlicht Unten: Aktor (Relais) Q2: active
    2018-11-07 20:31:46.379 - info: javascript.0 script.js.Test.Lichtfinal: Gerät: Aktor (Relais) Q2
    2018-11-07 20:31:46.380 - info: javascript.0 script.js.Test.Lichtfinal: DP: Licht Klavierzimmer: Büro Klein Spot: active
    2018-11-07 20:31:46.380 - info: javascript.0 script.js.Test.Lichtfinal: Gerät: Büro Klein Spot
    2018-11-07 20:31:46.380 - info: javascript.0 script.js.Test.Lichtfinal: DP: Licht Technikraum: Lampe Technikraum: active
    2018-11-07 20:31:46.380 - info: javascript.0 script.js.Test.Lichtfinal: Gerät: Lampe Technikraum
    2018-11-07 20:31:46.380 - info: javascript.0 script.js.Test.Lichtfinal: DP: Licht Bad EG: Bad EG Spot: position
    2018-11-07 20:31:46.380 - info: javascript.0 script.js.Test.Lichtfinal: Gerät: Bad EG Spot
    2018-11-07 20:31:46.380 - info: javascript.0 script.js.Test.Lichtfinal: DP: Licht Bad OG: Bad OG Spot: position
    2018-11-07 20:31:46.380 - info: javascript.0 script.js.Test.Lichtfinal: Gerät: Bad OG Spot
    2018-11-07 20:31:46.380 - info: javascript.0 script.js.Test.Lichtfinal: DP: Licht Schlafzimmer: Lampe Angelo: position
    2018-11-07 20:31:46.380 - info: javascript.0 script.js.Test.Lichtfinal: Gerät: Lampe Angelo
    2018-11-07 20:31:46.380 - info: javascript.0 script.js.Test.Lichtfinal: DP: Licht Schlafzimmer: Lampe Jill: position
    2018-11-07 20:31:46.380 - info: javascript.0 script.js.Test.Lichtfinal: Gerät: Lampe Jill
    2018-11-07 20:31:46.380 - info: javascript.0 script.js.Test.Lichtfinal: DP: Licht Schlafzimmer: Bett Weiß: position
    2018-11-07 20:31:46.380 - info: javascript.0 script.js.Test.Lichtfinal: Gerät: Bett Weiß
    2018-11-07 20:31:46.380 - info: javascript.0 script.js.Test.Lichtfinal: DP: Esszimmer/Küche: Küche Spot: position
    2018-11-07 20:31:46.380 - info: javascript.0 script.js.Test.Lichtfinal: Gerät: Küche Spot
    2018-11-07 20:31:46.380 - info: javascript.0 script.js.Test.Lichtfinal: DP: Esszimmer/Küche: EssZi Spot: position
    2018-11-07 20:31:46.380 - info: javascript.0 script.js.Test.Lichtfinal: Gerät: EssZi Spot
    2018-11-07 20:31:46.380 - info: javascript.0 script.js.Test.Lichtfinal: DP: Wohnzimmer: WoZi Spot Kamin: position
    2018-11-07 20:31:46.380 - info: javascript.0 script.js.Test.Lichtfinal: Gerät: WoZi Spot Kamin
    2018-11-07 20:31:46.380 - info: javascript.0 script.js.Test.Lichtfinal: DP: Wohnzimmer: WoZi Spot Couch: position
    2018-11-07 20:31:46.380 - info: javascript.0 script.js.Test.Lichtfinal: Gerät: WoZi Spot Couch
    2018-11-07 20:31:46.380 - info: javascript.0 script.js.Test.Lichtfinal: Text: Büro Klein Spot
    2018-11-07 20:31:46.380 - info: javascript.0 script.js.Test.Lichtfinal: Anzahl Lichter: 23 # davon Lichter an: 1
    2018-11-07 20:31:53.106 - info: javascript.0 script.js.Test.Lichtfinal: Auslösender Schalter: loxone.0.0a41e8ce-0333-d48b-ffff86dfaf476a88.AI1.active: false
    2018-11-07 20:31:53.106 - info: javascript.0 script.js.Test.Lichtfinal: DP: Lichtsteuerung: Licht: active
    2018-11-07 20:31:53.106 - info: javascript.0 script.js.Test.Lichtfinal: Gerät: Licht
    2018-11-07 20:31:53.107 - info: javascript.0 script.js.Test.Lichtfinal: DP: Lich Büro Jill: LI13 Büro Angelo Spot Grau: active
    2018-11-07 20:31:53.107 - info: javascript.0 script.js.Test.Lichtfinal: Gerät: LI13 Büro Angelo Spot Grau
    2018-11-07 20:31:53.107 - info: javascript.0 script.js.Test.Lichtfinal: DP: BWM Steuerung Außen: Lampe Haustür: active
    2018-11-07 20:31:53.107 - info: javascript.0 script.js.Test.Lichtfinal: Gerät: Lampe Haustür
    2018-11-07 20:31:53.107 - info: javascript.0 script.js.Test.Lichtfinal: DP: Lichtsteuerung: Lampe Haustür: active
    2018-11-07 20:31:53.107 - info: javascript.0 script.js.Test.Lichtfinal: DP: Lichtsteuerung: EG Spot Decke: active
    2018-11-07 20:31:53.107 - info: javascript.0 script.js.Test.Lichtfinal: Gerät: EG Spot Decke
    2018-11-07 20:31:53.107 - info: javascript.0 script.js.Test.Lichtfinal: DP: Lichtsteuerung: EG Spot Boden: active
    2018-11-07 20:31:53.107 - info: javascript.0 script.js.Test.Lichtfinal: Gerät: EG Spot Boden
    2018-11-07 20:31:53.107 - info: javascript.0 script.js.Test.Lichtfinal: DP: Lichtsteuerung: Treppenlicht OG: active
    2018-11-07 20:31:53.107 - info: javascript.0 script.js.Test.Lichtfinal: Gerät: Treppenlicht OG
    2018-11-07 20:31:53.107 - info: javascript.0 script.js.Test.Lichtfinal: DP: Lichtsteuerung: Treppenlicht Keller: active
    2018-11-07 20:31:53.107 - info: javascript.0 script.js.Test.Lichtfinal: Gerät: Treppenlicht Keller
    2018-11-07 20:31:53.107 - info: javascript.0 script.js.Test.Lichtfinal: DP: Licht Flur OG: Flur OG Spot Decke: active
    2018-11-07 20:31:53.107 - info: javascript.0 script.js.Test.Lichtfinal: Gerät: Flur OG Spot Decke
    2018-11-07 20:31:53.107 - info: javascript.0 script.js.Test.Lichtfinal: DP: Licht Gästezimmer: Gäste Spot: active
    2018-11-07 20:31:53.107 - info: javascript.0 script.js.Test.Lichtfinal: Gerät: Gäste Spot
    2018-11-07 20:31:53.107 - info: javascript.0 script.js.Test.Lichtfinal: DP: Kellerlicht Unten: Keller Unten Licht: active
    2018-11-07 20:31:53.107 - info: javascript.0 script.js.Test.Lichtfinal: Gerät: Keller Unten Licht
    2018-11-07 20:31:53.107 - info: javascript.0 script.js.Test.Lichtfinal: DP: Kellerlicht Unten: Aktor (Relais) Q2: active
    2018-11-07 20:31:53.107 - info: javascript.0 script.js.Test.Lichtfinal: Gerät: Aktor (Relais) Q2
    2018-11-07 20:31:53.107 - info: javascript.0 script.js.Test.Lichtfinal: DP: Licht Klavierzimmer: Büro Klein Spot: active
    2018-11-07 20:31:53.107 - info: javascript.0 script.js.Test.Lichtfinal: Gerät: Büro Klein Spot
    2018-11-07 20:31:53.107 - info: javascript.0 script.js.Test.Lichtfinal: DP: Licht Technikraum: Lampe Technikraum: active
    2018-11-07 20:31:53.108 - info: javascript.0 script.js.Test.Lichtfinal: Gerät: Lampe Technikraum
    2018-11-07 20:31:53.108 - info: javascript.0 script.js.Test.Lichtfinal: DP: Licht Bad EG: Bad EG Spot: position
    2018-11-07 20:31:53.108 - info: javascript.0 script.js.Test.Lichtfinal: Gerät: Bad EG Spot
    2018-11-07 20:31:53.108 - info: javascript.0 script.js.Test.Lichtfinal: DP: Licht Bad OG: Bad OG Spot: position
    2018-11-07 20:31:53.108 - info: javascript.0 script.js.Test.Lichtfinal: Gerät: Bad OG Spot
    2018-11-07 20:31:53.108 - info: javascript.0 script.js.Test.Lichtfinal: DP: Licht Schlafzimmer: Lampe Angelo: position
    2018-11-07 20:31:53.108 - info: javascript.0 script.js.Test.Lichtfinal: Gerät: Lampe Angelo
    2018-11-07 20:31:53.108 - info: javascript.0 script.js.Test.Lichtfinal: DP: Licht Schlafzimmer: Lampe Jill: position
    2018-11-07 20:31:53.108 - info: javascript.0 script.js.Test.Lichtfinal: Gerät: Lampe Jill
    2018-11-07 20:31:53.108 - info: javascript.0 script.js.Test.Lichtfinal: DP: Licht Schlafzimmer: Bett Weiß: position
    2018-11-07 20:31:53.108 - info: javascript.0 script.js.Test.Lichtfinal: Gerät: Bett Weiß
    2018-11-07 20:31:53.108 - info: javascript.0 script.js.Test.Lichtfinal: DP: Esszimmer/Küche: Küche Spot: position
    2018-11-07 20:31:53.108 - info: javascript.0 script.js.Test.Lichtfinal: Gerät: Küche Spot
    2018-11-07 20:31:53.108 - info: javascript.0 script.js.Test.Lichtfinal: DP: Esszimmer/Küche: EssZi Spot: position
    2018-11-07 20:31:53.108 - info: javascript.0 script.js.Test.Lichtfinal: Gerät: EssZi Spot
    2018-11-07 20:31:53.108 - info: javascript.0 script.js.Test.Lichtfinal: DP: Wohnzimmer: WoZi Spot Kamin: position
    2018-11-07 20:31:53.108 - info: javascript.0 script.js.Test.Lichtfinal: Gerät: WoZi Spot Kamin
    2018-11-07 20:31:53.108 - info: javascript.0 script.js.Test.Lichtfinal: DP: Wohnzimmer: WoZi Spot Couch: position
    2018-11-07 20:31:53.108 - info: javascript.0 script.js.Test.Lichtfinal: Gerät: WoZi Spot Couch
    2018-11-07 20:31:53.108 - info: javascript.0 script.js.Test.Lichtfinal: Text:
    2018-11-07 20:31:53.108 - info: javascript.0 script.js.Test.Lichtfinal: Anzahl Lichter: 23 # davon Lichter an: 0
    2018-11-07 20:31:56.639 - info: javascript.0 script.js.Test.Lichtfinal: Auslösender Schalter: loxone.0.0a41e8ce-0333-d48b-ffff86dfaf476a88.AI1.active: true
    2018-11-07 20:31:56.639 - info: javascript.0 script.js.Test.Lichtfinal: DP: Lichtsteuerung: Licht: active
    2018-11-07 20:31:56.639 - info: javascript.0 script.js.Test.Lichtfinal: Gerät: Licht
    2018-11-07 20:31:56.639 - info: javascript.0 script.js.Test.Lichtfinal: DP: Lich Büro Jill: LI13 Büro Angelo Spot Grau: active
    2018-11-07 20:31:56.639 - info: javascript.0 script.js.Test.Lichtfinal: Gerät: LI13 Büro Angelo Spot Grau
    2018-11-07 20:31:56.639 - info: javascript.0 script.js.Test.Lichtfinal: DP: BWM Steuerung Außen: Lampe Haustür: active
    2018-11-07 20:31:56.639 - info: javascript.0 script.js.Test.Lichtfinal: Gerät: Lampe Haustür
    2018-11-07 20:31:56.639 - info: javascript.0 script.js.Test.Lichtfinal: DP: Lichtsteuerung: Lampe Haustür: active
    2018-11-07 20:31:56.639 - info: javascript.0 script.js.Test.Lichtfinal: DP: Lichtsteuerung: EG Spot Decke: active
    2018-11-07 20:31:56.639 - info: javascript.0 script.js.Test.Lichtfinal: Gerät: EG Spot Decke
    2018-11-07 20:31:56.640 - info: javascript.0 script.js.Test.Lichtfinal: DP: Lichtsteuerung: EG Spot Boden: active
    2018-11-07 20:31:56.640 - info: javascript.0 script.js.Test.Lichtfinal: Gerät: EG Spot Boden
    2018-11-07 20:31:56.640 - info: javascript.0 script.js.Test.Lichtfinal: DP: Lichtsteuerung: Treppenlicht OG: active
    2018-11-07 20:31:56.640 - info: javascript.0 script.js.Test.Lichtfinal: Gerät: Treppenlicht OG
    2018-11-07 20:31:56.640 - info: javascript.0 script.js.Test.Lichtfinal: DP: Lichtsteuerung: Treppenlicht Keller: active
    2018-11-07 20:31:56.640 - info: javascript.0 script.js.Test.Lichtfinal: Gerät: Treppenlicht Keller
    2018-11-07 20:31:56.640 - info: javascript.0 script.js.Test.Lichtfinal: DP: Licht Flur OG: Flur OG Spot Decke: active
    2018-11-07 20:31:56.640 - info: javascript.0 script.js.Test.Lichtfinal: Gerät: Flur OG Spot Decke
    2018-11-07 20:31:56.640 - info: javascript.0 script.js.Test.Lichtfinal: DP: Licht Gästezimmer: Gäste Spot: active
    2018-11-07 20:31:56.640 - info: javascript.0 script.js.Test.Lichtfinal: Gerät: Gäste Spot
    2018-11-07 20:31:56.640 - info: javascript.0 script.js.Test.Lichtfinal: DP: Kellerlicht Unten: Keller Unten Licht: active
    2018-11-07 20:31:56.640 - info: javascript.0 script.js.Test.Lichtfinal: Gerät: Keller Unten Licht
    2018-11-07 20:31:56.640 - info: javascript.0 script.js.Test.Lichtfinal: DP: Kellerlicht Unten: Aktor (Relais) Q2: active
    2018-11-07 20:31:56.640 - info: javascript.0 script.js.Test.Lichtfinal: Gerät: Aktor (Relais) Q2
    2018-11-07 20:31:56.640 - info: javascript.0 script.js.Test.Lichtfinal: DP: Licht Klavierzimmer: Büro Klein Spot: active
    2018-11-07 20:31:56.640 - info: javascript.0 script.js.Test.Lichtfinal: Gerät: Büro Klein Spot
    2018-11-07 20:31:56.640 - info: javascript.0 script.js.Test.Lichtfinal: DP: Licht Technikraum: Lampe Technikraum: active
    2018-11-07 20:31:56.640 - info: javascript.0 script.js.Test.Lichtfinal: Gerät: Lampe Technikraum
    2018-11-07 20:31:56.640 - info: javascript.0 script.js.Test.Lichtfinal: DP: Licht Bad EG: Bad EG Spot: position
    2018-11-07 20:31:56.640 - info: javascript.0 script.js.Test.Lichtfinal: Gerät: Bad EG Spot
    2018-11-07 20:31:56.640 - info: javascript.0 script.js.Test.Lichtfinal: DP: Licht Bad OG: Bad OG Spot: position
    2018-11-07 20:31:56.640 - info: javascript.0 script.js.Test.Lichtfinal: Gerät: Bad OG Spot
    2018-11-07 20:31:56.640 - info: javascript.0 script.js.Test.Lichtfinal: DP: Licht Schlafzimmer: Lampe Angelo: position
    2018-11-07 20:31:56.640 - info: javascript.0 script.js.Test.Lichtfinal: Gerät: Lampe Angelo
    2018-11-07 20:31:56.640 - info: javascript.0 script.js.Test.Lichtfinal: DP: Licht Schlafzimmer: Lampe Jill: position
    2018-11-07 20:31:56.640 - info: javascript.0 script.js.Test.Lichtfinal: Gerät: Lampe Jill
    2018-11-07 20:31:56.641 - info: javascript.0 script.js.Test.Lichtfinal: DP: Licht Schlafzimmer: Bett Weiß: position
    2018-11-07 20:31:56.641 - info: javascript.0 script.js.Test.Lichtfinal: Gerät: Bett Weiß
    2018-11-07 20:31:56.641 - info: javascript.0 script.js.Test.Lichtfinal: DP: Esszimmer/Küche: Küche Spot: position
    2018-11-07 20:31:56.641 - info: javascript.0 script.js.Test.Lichtfinal: Gerät: Küche Spot
    2018-11-07 20:31:56.641 - info: javascript.0 script.js.Test.Lichtfinal: DP: Esszimmer/Küche: EssZi Spot: position
    2018-11-07 20:31:56.641 - info: javascript.0 script.js.Test.Lichtfinal: Gerät: EssZi Spot
    2018-11-07 20:31:56.641 - info: javascript.0 script.js.Test.Lichtfinal: DP: Wohnzimmer: WoZi Spot Kamin: position
    2018-11-07 20:31:56.641 - info: javascript.0 script.js.Test.Lichtfinal: Gerät: WoZi Spot Kamin
    2018-11-07 20:31:56.641 - info: javascript.0 script.js.Test.Lichtfinal: DP: Wohnzimmer: WoZi Spot Couch: position
    2018-11-07 20:31:56.641 - info: javascript.0 script.js.Test.Lichtfinal: Gerät: WoZi Spot Couch
    2018-11-07 20:31:56.641 - info: javascript.0 script.js.Test.Lichtfinal: Text: Büro Klein Spot
    2018-11-07 20:31:56.641 - info: javascript.0 script.js.Test.Lichtfinal: Anzahl Lichter: 23 # davon Lichter an: 1
    2018-11-07 20:32:02.342 - info: host.iobroker instance system.adapter.loxone.0 started with pid 22482
    2018-11-07 20:32:02.494 - error: host.iobroker instance system.adapter.loxone.0 terminated with code 7 (Adapter already running)
    2018-11-07 20:32:02.494 - info: host.iobroker Restart adapter system.adapter.loxone.0 because enabled
    2018-11-07 20:32:06.968 - info: javascript.0 Stop script script.js.Test.Alexa_antwortet
    2018-11-07 20:32:06.971 - info: javascript.0 Start javascript script.js.Test.Alexa_antwortet
    2018-11-07 20:32:06.971 - info: javascript.0 script.js.Test.Alexa_antwortet: registered 0 subscriptions and 0 schedules
    2018-11-07 20:32:32.497 - info: host.iobroker instance system.adapter.loxone.0 started with pid 22492
    2018-11-07 20:32:32.647 - error: host.iobroker instance system.adapter.loxone.0 terminated with code 7 (Adapter already running)
    2018-11-07 20:32:32.647 - info: host.iobroker Restart adapter system.adapter.loxone.0 because enabled
    Dann Lichter aus:
    Ein Licht an:
    Und mein Blockly:
    var Ausgabetext, timeout, timeout2;
    setState("alexa2.0.History.#trigger"/*Trigger/Rescan*/, true);
    if (getState("javascript.0.Status.Lichter.Anzahl_ein").val == 0) {
      Ausgabetext = String('aktuell sind') + String(getState("javascript.0.Status.Lichter.Ansage").val);
      timeout = setTimeout(function () {
        // Wohnzimmer
        if (getState("alexa2.0.History.name").val == 'Wohnen') {
          setState("alexa2.0.Echo-Devices.ausgeblendet.Commands.speak"/*speak*/, Ausgabetext);
        // Küche
        if (getState("alexa2.0.History.name").val == 'Küche') {
          setState("alexa2.0.Echo-Devices.XXXXXX.Commands.speak", Ausgabetext);
        // Badezimmer
        if (getState("alexa2.0.History.name").val == 'Badezimmer') {
          setState("alexa2.0.Echo-Devices.XXXXX.Commands.speak", Ausgabetext);
        // Gästezimmer
        if (getState("alexa2.0.History.name").val == 'Gästezimmer') {
        // Flur
        if (getState("alexa2.0.History.name").val == 'Flur') {
        // Schlafzimmer
        if (getState("alexa2.0.History.name").val == 'Schlafzimmer') {
          setState("alexa2.0.Echo-Devices.XXXXXXX.Commands.speak", Ausgabetext);
        // Keller-Flur
        if (getState("alexa2.0.History.name").val == 'Keller-Flur') {
          setState("alexa2.0.Echo-Devices.XXXXXXXX.Commands.speak", Ausgabetext);
        // Werkstatt
        if (getState("alexa2.0.History.name").val == 'Werkstatt') {
          setState("alexa2.0.Echo-Devices.XXXXXXXXX.Commands.speak", Ausgabetext);
      }, 500);
    if (getState("javascript.0.Status.Lichter.Anzahl_ein").val != 0) {
      Ausgabetext = ['Im Moment sind im ',getState("javascript.0.Status.Lichter.Raum").val,'eingeschaltete Lampen'].join('');
      timeout2 = setTimeout(function () {
        // Wohnzimmer
        if (getState("alexa2.0.History.name").val == 'Wohnzimmer') {
          setState("alexa2.0.Echo-Devices.XXX.Commands.speak", Ausgabetext);
        // Küche
        // Badezimmer
          setState("alexa2.0.Echo-Devices.XXXXXXXXXX.Commands.speak", Ausgabetext);
        // Gästezimmer
        // Flur
        // Schlafzimmer
        // Keller-Flur
          setState("alexa2.0.Echo-Devices.XXXXXXXXXXX.Commands.speak", Ausgabetext);
        // Werkstatt
      }, 500);
    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
    • paul53P Offline
      #119
      @McMoneysack:
      sind die Lampen aus, bleibt Lichter eingeschaltet an… `
      Das kann ich im Skript nicht nachvollziehen.
      @McMoneysack:
      sobald Lichter an sind, sagt Alexa nüscht, `
      Mit Alexa kenne ich mich nicht aus (will ich auch nicht :lol: ).
        McMoneysack
        #120
        @paul53:
        Das kann ich im Skript nicht nachvollziehen. `
        Merkwürdig und Schade… Aber trotzdem bis hier vielen lieben Dank.
        @paul53:
        Mit Alexa kenne ich mich nicht aus (will ich auch nicht :lol: ). `
        Hehe, vielleicht will und kann da ja jemand anders was zu sagen :-)
        • paul53P Offline
          #121
          Die Ansageausgabe habe ich geändert und hue entfernt. Versuche es mal damit:
          /* Status Zahl Lichter
          zählt die Lichter in allen Räumen und meldet die Eingeschalteten namentlich
          Daten kommen vom Gewerk "Licht"
          const logging = true;
          const idAnzahlEin = 'javascript.0.Status.Lichter.Anzahl_ein',
                idAnzahl = 'javascript.0.Status.Lichter.Anzahl',
                idText = 'javascript.0.Status.Lichter.Text',
                idRaum = 'javascript.0.Status.Lichter.Raum', // <---- NEU
                idAnsage = 'javascript.0.Status.Lichter.Ansage';
          // Ab hier nix mehr ändern
          createState(idAnzahl, { // wenn benötigt: Anzahl der vorhandenen Lichter
              type: 'number',
              name: 'Anzahl aller Lichter',
              min: 0,
              def: 0,
              role: 'value'
          createState(idAnzahlEin, { // Anzahl der Lichter, die auf sind als Variable unter Javascript.0 anlegen
              type: 'number',
              name: 'Anzahl der eingeschalteten Lichter',
              min: 0,
              def: 0,
              role: 'value'
          createState(idText, { // Anzahl der brennenden Lichter und deren Namen als Variable unter Javascript.0 anlegen
              type: 'string',
              name: 'Eingeschaltete Lichter',
              desc: 'Namen der eingeschalteten Lichter',
              def: ' ',
              role: 'value'
          createState(idAnsage, {
              type: 'string',
              name: 'Eingeschaltete Lichter (Ansage)',
              desc: 'Namen der eingeschalteten Lichter (für Ansage aufbereitet)',
              def: ' ',
              role: 'value'
          createState(idRaum, { // Räume, in denen Lichter brennen // <---- NEU
              type: 'string',
              name: 'Räume mit eingeschalteten Lichter',
              desc: 'Namen der Räume, in denen Lichter eingeschaltet sind',
              def: ' ',
              role: 'value'
          // HM Schalter, HM Dimmer und Hue Schalter im Gewerk Licht
          const hmSTATE = $('device[state.id=*.active](functions=Beleuchtung)');
          const hmLEVEL = $('device[state.id=*.position](functions=Beleuchtung)');
          var anzahlLichterAn,
              anzahlLichter,
              textLichterAn,
              textRaum;
          // Aufbereitung für Ansage
          function strip_tags(data) {
              var rueckgabe = data.replace(/( |<([^>]+)>)/ig, " ");
              return (rueckgabe);
          function checkLicht(id, vorn, hinten) {
              var name = getObject(id).common.name;
              var devicename = name.substring(name.indexOf(':') + 2, name.indexOf(hinten)); //Zeichen vorn, State hinten aus Text entfernen
              if(logging) log('DP: ' + name);
              if(logging) log('Gerät: ' + devicename);
              var raum = getObject(id, "rooms").enumNames[0];
              if (getState(id).val) { // wenn Zustand != false / 0, dann wird die Anzahl der Lichter hochgezählt
                  ++anzahlLichterAn;
                  textLichterAn.push(devicename); // Zu Array hinzufügen
                  if(textRaum.indexOf(raum) == -1) textRaum.push(raum); // zu Array hinzu, wenn noch nicht vorhanden
              ++anzahlLichter; // Zählt die Anzahl der vorhandenen Lichter unabhängig vom Status
          function checkDevices() {
              // Setzt die Zähler vor dem Durchlauf aller Elemente *.STATE im Gewerk Licht auf 0
              anzahlLichterAn = 0;
              anzahlLichter = 0;
              textLichterAn = [];
              textRaum = [];
              hmSTATE.each(function(id, i) { // Schleife für jedes gefundenen Element *.active im Gewerk Licht
          	    checkLicht(id, 0, ': active');
              hmLEVEL.each(function(id, i) { // Schleife für jedes gefundenen Element *.position im Gewerk Licht
          	    checkLicht(id, 0, ': position');
              // Array mit Lichternamen sortieren
              textLichterAn.sort();
              textRaum.sort(); // <---- NEU
              // Schleife ist durchlaufen. Im Log wird der aktuelle Status (Anzahl, davon an) ausgegeben
              if (logging) log("Text: " + textLichterAn);
              if (logging) log("Anzahl Lichter: " + anzahlLichter + " # davon Lichter an: " + anzahlLichterAn);
              // die ermittelten Werte werden als javascript.0\. Variable in ioBroker gespeichert (z.B. für die Verarbeitung in VIS)
              //setState(idText, textLichterAn.join(',
          ')); // Schreibt die aktuelle Namen der eingeschalteten Lichter
              setState(idText, textLichterAn.join(', ')); // Schreibt die aktuelle Namen der eingeschalteten Lichter
              setState(idAnzahlEin, textLichterAn.length); // Schreibt die aktuelle Anzahl der eingeschalteten Lichter
              setState(idAnzahl, anzahlLichter); // Schreibt die aktuelle Anzahl der vorhandene Elemente im Gewerk Licht
              // setState(idRaum, textRaum.join(',
          ')); // Räume, in denen Licht brennt // <---- NEU
              setState(idRaum, textRaum.join(', ')); // Räume, in denen Licht brennt // <---- NEU
              var text = 'Alle Lichter sind ausgeschaltet';
              if(textLichterAn.length) text =  'Lichter eingeschaltet: ' + strip_tags(textLichterAn.join(', '));
              setState(idAnsage, text);
          // Trigger
          hmSTATE.on(function(obj) { // bei Zustandänderung *.STATE im Gewerk Licht
              if (logging) log('Auslösender Schalter: ' + obj.id + ': ' + obj.state.val); // Info im Log, welcher Zustand sich geändert hat
              checkDevices();
          hmLEVEL.on(function(obj) { // bei Zustandänderung *.LEVEL im Gewerk Licht
              if (logging) log('Auslösender Dimmer: ' + obj.id + ': ' + obj.state.val); // Info im Log, welcher Zustand sich geändert hat
              checkDevices();
          // Skriptstart
          setTimeout(function() {
              if (logging) log('Auslöser Skriptstart');
              checkDevices();
          }, 500);
            McMoneysack
            #122
            Super Service von Dir :-)
            Also, er springt wieder auf alle Lichter aus. Klasse! Das sagt mir Alexa jetzt auch an.
            Was sie mir weiterhin nicht ansagt, sind die eingeschalteten Lichter. Ich vermute, das liegt an meinem Blockly?!
            Vielleicht hat dazu ja noch jemand eine Idee?
            • totocotonioT Offline
              totocotonio
              #123
              @smartboart:
              Ok, war dann doch schneller… habs hinbekommen....
              hier das Script mit eingebundenen sonoffs ..
              Daten kommen vom Gewerk "licht"
              erstellt: 17.06.2015 nach diesem Vorbild: viewtopic.php?f=21&t=869&sid=f9ba5657489ff431a1990884f90779c1#p6564
              23.06.2015 globale Variablendefinition zählen_Lichter.textLichterAn fehlte und wurde hinzugefügt
              Log Ausgabe auskommentiert
              05.08.2015 STATE aus der Ausgabe entfernt nach Idee von stephan61 http://forum.iobroker.org/viewtopic.php ... t=20#p9267
              24.03.2016 keine Anzeigen von virtuellen Kanälen mehr (in Abhängigkeit der Abfrage des Namens)
              06.05.2016 Datenpunkt für Ansagen zugefügt
              02.07.2016 abgeschaltet, da Fehler
              03.07.2016 Zähl-Funktion getrennt nach Schalter und Dimmer
              search statt indexOf und RegEx für Suche nach Virtuellen Kanälen
              27.11.2016 Verschoben in Status
              Code optimiert
              23.12.2016 Räume eingebaut
              var logging = true;
              var idAnzahlEin = 'javascript.0.Status.Lichter.Anzahl_ein',
              type: 'number',
              min: 0,
              def: 0,
              role: 'value'
              type: 'number',
              min: 0,
              def: 0,
              role: 'value'
              type: 'string',
              def: ' ',
              role: 'value'
              type: 'string',
              def: ' ',
              role: 'value'
              type: 'string',
              def: ' ',
              role: 'value'
              var cacheSelectorState = $('channel[state.id=*.STATE](functions="licht")'); // Gewerk licht
              var cacheSelectorLevel = $('channel[state.id=*.level](functions="licht")');
              var cacheSelectorPOWER = $('channel[state.id=*.POWER](functions="licht")'); // Sonoff Lampen (müssen im Gewerk Licht sein)
              function checkDevices(obj) {
              // Setzt die Zähler vor dem Durchlauf aller Elemente *.STATE im Gewerk licht auf 0
              var anzahlLichterAn = 0;
              var anzahlLichter = 0;
              var textLichterAn = [];
              var textRaum = [];
              if (logging) {
              log('++++++ Lichter Anzahl ++++ ');
              log('#### SCHALTER ##### ');
              cacheSelectorState.each(function (id, i) { // Schleife für jedes gefundenen Element *.STATE im Gewerk Licht
              var obj = getObject(id);
              var status = getState(id).val; // Zustand *.STATE abfragen (jedes Element)
              var devicename = name.substring(0, name.indexOf(".STATE")); //.state aus Text entfernen
              var raumname = getObject(id, "rooms"); // <---- NEU
              // ########## Abfrage ob Virtueller Kanal? VK oder : im Namen)
              // if ( (devicename.search(/(CUX)|(K2)|(K3)|(VK)|(:)/ig) == -1) ) {
              if (logging) {
              log('-------');
              log('Kanal: ' + name);
              log('Status: ' + status);
              if (status) { // wenn Zustand = true, dann wird die ANzahl der Lichter hochgezählt
              ++anzahlLichterAn;
              textRaum.push(raumname.enumNames); // <---- NEU
              // } // ENDE VK-Abfrage
              if (logging) log('#### DIMMER ##### ');
              cacheSelectorLevel.each(function (id, i) { // Schleife für jedes gefundenen Element *.LEVEL im Gewerk Licht
              var status = getState(id).val; // Zustand *.LEVEL abfragen (jedes Element)
              var devicename = name.substring(0, name.indexOf(".LEVEL")); //.state aus Text entfernen
              // if ( (devicename.search(/(CUX)|(K2)|(K3)|(V10)|(VK)|(:)/ig) == -1) ) { // Geräte mit diesen Strings im namen nicht beachten
              if (logging) {
              log('-------');
              log('Status: ' + status + '%');
              if (parseFloat(status) > 0) { // Wenn Dimmwert über 0
              ++anzahlLichterAn;
              // } // Ende Abfrage VK
              if (logging) {
              cacheSelectorPOWER.each(function (id, i) { // Schleife für jedes gefundenen Element *.POWER im Gewerk Licht
              var devicename = name.substring(0, name.indexOf("POWER")); //.state aus Text entfernen
              if (logging) {
              log('-------');
              ++anzahlLichterAn;
              // Trigger
              cacheSelectorState.on(function(obj) { // bei Zustandänderung *.STATE im Gewerk licht
              checkDevices();
              cacheSelectorLevel.on(function(obj) { // bei Zustandänderung *.LEVEL im Gewerk licht
              checkDevices();
              cacheSelectorPOWER.on(function(obj) { // bei Zustandänderung *.STATE im Gewerk licht
              checkDevices();
              function main() {
              setTimeout(function(){
              checkDevices();
              }, 2000);
              main(); // Skriptstart-Auslöser
              return(rueckgabe);
              on(idText, function (obj) {
              var text = obj.state.val;
              text = (getState(idAnzahl).val > 0 ) ? 'Lichter eingeschaltet: ' + strip_tags(text) : 'Alle Lichter sind ausgeschaltet';
              ich habe das Script eingebunden.
              Jetzt werden mir keine Sonoff oder hm mehr angezeigt.
              Hat script einen Fehler?
              Gruß Totocotonio
              Bin noch Anfänger in Sachen IO-Broker und lerne gerne dazu. :P
              • N Offline
                N Offline
                noleck123
                #124
                Hallo ich habe das Fenster / Zählen Script und das Lichter Zählen Script Installiert.. Funktioniert soweit ganz gut, nur wird die Eingeschaltete Lichter / Fenster Variable nicht richtig angezeigt bzw ausgewertet.. 2453_io.jpg
                Code optimiert
                var logging = true;
                type: 'number',
                min: 0,
                def: 0,
                role: 'value'
                type: 'number',
                min: 0,
                def: 0,
                role: 'value'
                type: 'string',
                def: ' ',
                role: 'value'
                type: 'string',
                def: ' ',
                role: 'value'
                type: 'string',
                def: ' ',
                role: 'value'
                var cacheSelectorState = $('channel[state.id=*.STATE](functions="Licht")'); // Gewerk licht
                var cacheSelectorLevel = $('channel[state.id=*.level](functions="Licht")');
                var cacheSelectorPOWER = $('channel[state.id=*.POWER](functions="Licht")'); // Sonoff Lampen (müssen im Gewerk Licht sein)
                var textRaum = [];
                if (logging) {
                if (logging) {
                log('-------');
                ++anzahlLichterAn;
                if (logging) {
                log('-------');
                ++anzahlLichterAn;
                if (logging) {
                if (logging) {
                log('-------');
                ++anzahlLichterAn;
                // Trigger
                checkDevices();
                checkDevices();
                checkDevices();
                function main() {
                checkDevices();
                }, 2000);
                return(rueckgabe);
                // Status Fenster. Das Script zählt alle Fenster im Gewerk Fenster (Aufzählungen-Funktion)
                // Telegramnachricht bei Abwesenheit wenn sich der Fensterstatus ändert. Bei Anwesenheit in der Homezone keine Nachricht senden.
                // Anwesenheit Datenpunkte separat erstellt und durch die Adapter google-sharedlocation und Places geschaltet
                var logging = true;
                var
                idAnzahlAuf = 'javascript.0.Status.Fenster.Anzahl_auf',
                idAnzahl = 'javascript.0.Status.Fenster.Anzahl',
                idText = 'javascript.0.Status.Fenster.Text',
                idRaum = 'javascript.0.Status.Fenster.Raum',
                idAnsage = 'javascript.0.Status.Fenster.Ansage';
                createState(idAnzahl, { // wenn benötigt: Anzahl der vorhandenen Fenster
                type: 'number',
                name: 'Anzahl aller Fenster',
                min: 0,
                def: 0,
                role: 'value'
                createState(idAnzahlAuf, { // Anzahl der Fenster, die auf sind als Variable unter Javascript.0 anlegen
                type: 'number',
                name: 'Anzahl der geoeffneten Fenster',
                min: 0,
                def: 0,
                role: 'value'
                createState(idText, { // Anzahl der geoeffneten Fenster und deren Namen als Variable unter Javascript.0 anlegen
                type: 'string',
                name: 'geoeffnete Fenster',
                desc: 'Namen der geoeffneten Fenster',
                def: ' ',
                role: 'value'
                type: 'string',
                name: 'geoeffnete Fenster (Ansage)',
                desc: 'Namen der geoeffneten Fenster (für Ansage aufbereitet)',
                def: ' ',
                role: 'value'
                createState(idRaum, { // Räume, in denen Fenster geoeffnet sind
                type: 'string',
                name: 'Räume mit geoeffneten Fenster',
                desc: 'Namen der Räume, in denen Fenster geoeffnet sind',
                def: ' ',
                role: 'value'
                var cacheSelectorState = $('channel[state.id=*.STATE](functions="Fenster")'); // Gewerk Fenster
                // Setzt die Zähler vor dem Durchlauf aller Elemente *.STATE im Gewerk Fenster auf 0
                var anzahlFensterAuf = 0;
                var anzahlFenster = 0;
                var textFensterAuf = [];
                var textRaum = [];
                if (logging) {
                log('++++++ Fenster Anzahl ++++ ');
                cacheSelectorState.each(function(id, i) { // Schleife für jedes gefundenen Element *.STATE im Gewerk Fenster
                if (logging) {
                log('-------');
                if (status) { // wenn Zustand = true, dann wird die Anzahl der Fenster hochgezählt
                ++anzahlFensterAuf;
                textFensterAuf.push(devicename); // Zu Array hinzufügen
                ++anzahlFenster; // Zählt die Anzahl der vorhandenen Fenster unabhängig vom Status
                textRaum = deleteDuplicates(textRaum);
                // Array mit Fensternamen sortieren
                textFensterAuf.sort();
                textRaum.sort();
                // Schleife ist durchlaufen. Im Log wird der aktuelle Status (Anzahl, davon auf) ausgegeben
                if (logging) log("Text: " + textFensterAuf);
                if (logging) log("Anzahl Fenster: " + anzahlFenster + " # davon Fenster auf: " + anzahlFensterAuf);
                setState(idText, textFensterAuf.join(',\nund\n')); // Schreibt die aktuelle Namen der geoeffneten Fenster
                setState(idAnzahlAuf, textFensterAuf.length); // Schreibt die aktuelle Anzahl der geoeffneten Fenster
                setState(idAnzahl, anzahlFenster); // Schreibt die aktuelle Anzahl der vorhandene Elemente im Gewerk Fenster
                ')); // Räume, in denen Fenster geoeffnet sind
                setState(idRaum, textRaum.join(',\nund\n')); // Räume, in denen Fenster geoeffnet sind
                // Trigger
                cacheSelectorState.on(function(obj) { // bei Zustandänderung *.STATE im Gewerk Fenster
                checkDevices();
                function main() {
                checkDevices();
                }, 2000);
                return (rueckgabe);
                on(idText, function(obj) {
                text = (text.length > 1) ? ' ' + strip_tags(text) : 'Alle Fenster geschlossen';
                // Bei Anwesenheit zu Hause keine Telegramnachricht---Bei Abwesenheit sendet Telegram eine Nachricht
                // on({id: 'javascript.0.Status.Fenster.Ansage', change: "ne"}, function (obj) {
                // var value = obj.state.val;
                // var oldValue = obj.oldState.val;
                // if (getState("javascript.0.Anwesenheit.Heiko.Home.Heiko_Home").val === false) {
                // sendTo("telegram", "send", {
                // text: getState("javascript.0.Status.Fenster.Ansage").val,
                // disable_notification: true // ohne Ton am Handy
                  Thaibodo
                  #125
                  Ich benutze das Lichter-Skript (Danke dafür) und es funktioniert auch einigermaßen. Da ich kein Java beherrsche, verstehe ich das Skript so gut wie nicht. Bei mir werden zu viele Lichter gezählt (gesamt und eingeschaltet), außerdem wird bei den Räumen immer mein Bad mit angezeigt, auch wenn da alle Lampen aus sind. Die Lampen werden namentlich gar nicht angezeigt.
                  Nun also meine Frage:
                  wo genau holt sich das Skript die Daten her?
                  Vielleicht kann mir einer von euch helfen.
                  Grüße aus Thailand
                  Bodo
                  ioBroker auf Raspi 4
                  • T Thaibodo
                    Grüße aus Thailand
                    Bodo
                    Thaibodo
                    #126
                    @Thaibodo Es ist ja schon eine Weile her, als ich diese Frage gestellt habe. Da ich aber selbst noch kein Stück weiter gekommen bin, hoffe ich immer noch, dass mir jemand die Frage noch beantworte kann.
                    Viele Grüße
                    Bodo
                    • AsgothianA Offline
                      AsgothianA Offline
                      Asgothian
                      #127
                      Diese Zeile wählt alle Objekte aus die als Funktion “Fenster” im Objekt Baum eingetragen haben.
                      Vergleich einfach mal die Fenster Objekte die er anzeigt mit denen die er nicht anzeigt.
                      A.
                        Thaibodo
                        #128
                        Danke für die Antwort.
                        Bei den Aufzählungen habe ich 26 Lichter, im Status zeigt er aber 37 an. Ich habe keine Ahnung, wo das Script noch nachschaut.
                        • P Offline
                          PrinzEisenherz1
                          #129
                          @noleck123 sagte in [gelöst] Lichter zählen Script läuft nicht:
                          Code optimiert
                          var logging = true;
                          type: 'number',
                          min: 0,
                          def: 0,
                          role: 'value'
                          type: 'number',
                          min: 0,
                          def: 0,
                          role: 'value'
                          type: 'string',
                          def: ' ',
                          role: 'value'
                          type: 'string',
                          def: ' ',
                          role: 'value'
                          type: 'string',
                          def: ' ',
                          role: 'value'
                          var cacheSelectorState = $('channelstate.id=*.STATE'); // Gewerk licht
                          var cacheSelectorLevel = $('channelstate.id=*.level');
                          var cacheSelectorPOWER = $('channelstate.id=*.POWER'); // Sonoff Lampen (müssen im Gewerk Licht sein)
                          var textRaum = [];
                          if (logging) {
                          if (logging) {
                          log('-------');
                          ++anzahlLichterAn;
                          if (logging) {
                          log('-------');
                          ++anzahlLichterAn;
                          if (logging) {
                          if (logging) {
                          log('-------');
                          ++anzahlLichterAn;
                          // die ermittelten Werte werden als javascript.0. Variable in ioBroker gespeichert (z.B. für die Verarbeitung in VIS)
                          // Trigger
                          checkDevices();
                          checkDevices();
                          checkDevices();
                          function main() {
                          checkDevices();
                          }, 2000);
                          return(rueckgabe);
                          Hi zusammen!
                          Wollte jetzt auch mal das Script für meine Shelly 1 verwenden aber leider bekomme ich das irgendwie nicht gebacken.
                          Ich habe meine Shellys mit dem Shelly-Adapter in ioBroker eingebunden.
                          Wie muss ich das Script ändern damit diese abgefragt werden?
                          Der Datenpunkt der erfasst werden muss ist dieser:
                          Für Licht verwende ich nur Shellys.
                          Wie muss ich das Script ändern das alle meine Shellys abgefragt werden?
                          RAW vom Datenpunkt sieht so aus
                            "type": "state",
                            "common": {
                              "def": false,
                              "type": "boolean",
                              "read": true,
                              "write": true,
                              "role": "switch",
                              "name": "Switch",
                              "custom": {
                                "sql.0": {
                                  "enabled": true,
                                  "changesOnly": true,
                                  "debounce": "500",
                                  "maxLength": 10,
                                  "retention": "2678400",
                                  "changesRelogInterval": 0,
                                  "changesMinDelta": 0,
                                  "storageType": "Boolean",
                                  "aliasId": ""
                                "influxdb.0": {
                                  "enabled": true,
                                  "debounce": "500",
                                  "maxLength": 10,
                                  "aliasId": ""
                                "virtualpowermeter.0": {
                                  "enabled": true,
                                  "maxpower": "30",
                                  "group": "LichtWohnzimmer"
                            "native": {},
                            "from": "system.adapter.shelly.0",
                            "ts": 1551571293474,
                            "_id": "shelly.0.SHSW-1#2BDD14#1.Relay0.Switch",
                            "acl": {
                              "object": 1636,
                              "state": 1636,
                              "owner": "system.user.admin",
                            "user": "system.user.admin"
                          Johnny
                          Intel-NUC mit ProxMox: ioBroker,SQL, logging Strom- Gas- u. Wasserzähler;10Zoll Tab im Flur für VIS; weiteres: Homematic CCU2, Homeduino, Kameras, selbstgebaute Wetterstation;
                            mech
                            schrieb am zuletzt editiert von mech
                            #130
                            Die Frage von Johnny würde mich auch interessieren, würde das Script gerne für homematic und Shelly 1.5pm benutzen. Könnte das vielleicht jemand anpassen? :) Ich selbst habe leider keinen Bezug zur Programmierung und mich reizt dieses Script wahnsinnig. Habe selbst schon überall im Code "rumgespielt" aber komme hier leider zu keinem funktionierenden Ergebnis.
                            • FredFF Online
                              FredFF Online
                              FredF
                              Most Active Forum Testing
                              schrieb am zuletzt editiert von FredF
                              #131
                              @mech @PrinzEisenherz1
                              Das Skript schaut in den Objekten nach der Funktion Licht. Wenn eure Objekte also nicht mit dieser Funktion versehen sind, zählt das Skript auch nichts.
                              So gehts: Aufzählungen - Funktionen - Neue Aufzählung (+) - Licht
                              Danach in Objekte die gewünschte Objekt ID auswählen und in der Spalte Funktion mit dem Bleistift die Licht Funktion hinzufügen.
                                mech
                                #132
                                Hallo FredF,
                                unter Aufzählungen habe ich "Licht" bereits zugefügt und auch bei den Objekten.
                                    Code optimiert
                                    var logging = true;
                                    type: 'number',
                                    min: 0,
                                    def: 0,
                                    role: 'value'
                                    type: 'number',
                                    min: 0,
                                    def: 0,
                                    role: 'value'
                                    type: 'string',
                                    def: ' ',
                                    role: 'value'
                                    type: 'string',
                                    def: ' ',
                                    role: 'value'
                                    type: 'string',
                                    def: ' ',
                                    role: 'value'
                                    var cacheSelectorState = $('channelstate.id=.STATE'); // Gewerk licht
                                    var cacheSelectorLevel = $('channelstate.id=.level');
                                    var textRaum = [];
                                    if (logging) {
                                    if (logging) {
                                    log('-------');
                                    ++anzahlLichterAn;
                                    if (logging) {
                                    log('-------');
                                    ++anzahlLichterAn;
                                    if (logging) {
                                    if (logging) {
                                    log('-------');
                                    ++anzahlLichterAn;
                                    setState(idText, textLichterAn.join(',')); // Schreibt die aktuelle Namen der eingeschalteten Lichter
                                    // setState(idRaum, textRaum.join(',')); // Räume, in denen Licht brennt // <---- NEU
                                    // Trigger
                                    checkDevices();
                                    checkDevices();
                                    checkDevices();
                                    function main() {
                                    checkDevices();
                                    }, 2000);
                                    return(rueckgabe);
                                Hab mal ein paar mehr Informationen mit Screens angehangen, vielleicht kannst du ja so einen Fehler erkennen, über Hilfe bin ich echt dankbar :)
                                htreckslerH 1 Antwort Letzte Antwort
                                • M mech
                                  Hallo FredF,
                                      Code optimiert
                                      var logging = true;
                                      type: 'number',
                                      min: 0,
                                      def: 0,
                                      role: 'value'
                                      type: 'number',
                                      min: 0,
                                      def: 0,
                                      role: 'value'
                                      type: 'string',
                                      def: ' ',
                                      role: 'value'
                                      type: 'string',
                                      def: ' ',
                                      role: 'value'
                                      type: 'string',
                                      def: ' ',
                                      role: 'value'
                                      var textRaum = [];
                                      if (logging) {
                                      if (logging) {
                                      log('-------');
                                      ++anzahlLichterAn;
                                      if (logging) {
                                      log('-------');
                                      ++anzahlLichterAn;
                                      if (logging) {
                                      if (logging) {
                                      log('-------');
                                      ++anzahlLichterAn;
                                      // Trigger
                                      checkDevices();
                                      checkDevices();
                                      checkDevices();
                                      function main() {
                                      checkDevices();
                                      }, 2000);
                                      return(rueckgabe);
                                  htreckslerH Offline
                                  htreckslerH Offline
                                  htrecksler
                                  Forum Testing
                                  #133
                                  @mech hast du den Javascript Adapter danach neu gestartet? Ich meine mich zu erinnern das das nötig ist.
                                  Gruss Hermann
                                  • htreckslerH htrecksler
                                    mech
                                    #134
                                    @htrecksler
                                    Ja das habe ich bereits erledigt.
                                    Ich denke das diese abfragen bestimmt nicht auf einen Shelly ausgelegt sind:
                                    • M mech
                                      @htrecksler
                                      htreckslerH Offline
                                      htreckslerH Offline
                                      htrecksler
                                      Forum Testing
                                      #135
                                      @mech haben die Shelly denn einen Datenpunkt STATE, level, oder POWER?
                                      Ich hatte mal einen und ich meine mich zu erinnern das der einen Datenpunkt "Switch" (true/false) hat
                                      Gruss Hermann
                                        mech
                                        #136
                                        Hey , für mich sieht es nach "switch" aus.
                                        htreckslerH paul53P 2 Antworten Letzte Antwort
                                        • M mech
                                          htreckslerH Offline
                                          htreckslerH Offline
                                          htrecksler
                                          Forum Testing
                                          #137
                                          @mech genau, aber den (Groß- /Kleinschreibung beachten) berücksichtigt das Script ja nicht. Das Script schaut ja nur auf STATE, level und POWER
                                          Gruss Hermann
