  3. Off Topic
  4. Proxmox
  5. ioBroker in Proxmox nach Doku installiert, aber Fragen!
Geplant Angeheftet Gesperrt Verschoben Proxmox
145 Beiträge 8 Kommentatoren 29.5k Aufrufe 5 Beobachtet
    @homoran sagte in ioBroker in Proxmox nach Doku installiert, aber Fragen!:
    spuckt uns das in die Suppe.
    dachte das hast du rausgenommen
    scsi1
    #88
    @crunchip sagte in ioBroker in Proxmox nach Doku installiert, aber Fragen!:
    hab ich jetzt. überlebt das einen Neustart?
      und schwupps hat er wieder die falschen Rechte
      ja, weil nachträglich
      geändert! dann klappt's auch mit dem mount
      dann sollte backitup nun durchlaufen
      #89
      nope
      Started iobroker ...
      [DEBUG] [iobroker] start with {"type":"creator","workDir":"/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js","time":"02:40","debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"Copy","type":"storage","source":"local","mount":"","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":false,"ownDir":false,"dir":"/media/usbstick/backups","dirMinimal":"sharename/backupDir","user":"","pass":"****","ignoreErrors":false},"ignoreErrors":false,"dir":"/opt/iobroker","historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
      [DEBUG] [iobroker] - host.VM03 105 states saved
      [DEBUG] [iobroker] - host.VM03 144 objects saved
      [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2023_09_30-21_09_11_backupiobroker.tar.gz
      [DEBUG] [iobroker] - This backup can only be restored with js-controller version up from 4.1
      [DEBUG] [iobroker] - done
      [DEBUG] [cifs] - used copy path: /media/usbstick/backups
      [ERROR] [cifs] - Path "/media/usbstick/backups" not found
      [DEBUG] [cifs] start with {"mountType":"Copy","type":"storage","source":"local","mount":"","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":false,"ownDir":false,"dir":"/media/usbstick/backups","dirMinimal":"sharename/backupDir","user":"","pass":"****","ignoreErrors":false,"deleteBackupAfter":0}
      unter den mounts ist es drin /dev/sdc1 on /media/usbstick/backups type ext4 (rw,relatime)
        crunchipC Abwesend
        crunchipC Abwesend
        #90
        eigentlich nicht, soweit ich weiß
        gibts doch nicht🤔
          gibts doch nicht🤔
          #91
          gibts doch nicht
          hab schon alles durch was mir einfällt.
          /media/... oder ohne slash media/...
          cifs-utils sind installiert
          pi@VM03:~$ apt policy cifs-utils
          cifs-utils:
            Installiert:           2:7.0-2
            Installationskandidat: 2:7.0-2
            Versionstabelle:
           *** 2:7.0-2 500
                  500 http://debian.netcologne.de/debian bookworm/main amd64 Packages
          pi@VM03:~$
            gibts doch nicht
            cifs-utils:
              Versionstabelle:
             *** 2:7.0-2 500
            pi@VM03:~$
            crunchipC Abwesend
            crunchipC Abwesend
            #92
            @homoran komisch
            einzige was bei mir anders ist, ich hab nicht zusätzlich noch einen Unterordner angelegt
            ich hab
            mkdir /media/ext_usb
            mount /dev/sdb1 /media/ext_usb
            und meine Backups liegen in ext_usb
            Pfadangabe in der Instanz
            /media/ext_usb
            allerdings grad noch mal nach den Rechten gesehen, ich hab 777 vergeben
            hatte das ja heute mittag getestet und soeben nochmal gegengeprüft
            mario@IoBroker:~$ sudo ls -la /media/ext_usb
            insgesamt 219888
            drwxrwxrwx 3 root     root          4096 30. Sep 21:25 .
            drwxr-xr-x 4 root     root          4096 30. Sep 14:14 ..
            -rwxrwxrwx 1 root     root       2502737 30. Sep 14:23 historyDB_2023_09_30-14_23_06_backupiobroker.tar.gz
            -rw-r--r-- 1 iobroker iobroker   2518880 30. Sep 21:25 historyDB_2023_09_30-21_24_57_backupiobroker.tar.gz
            -rwxrwxrwx 1 root     root     108928731 30. Sep 14:23 iobroker_2023_09_30-14_22_27_backupiobroker.tar.gz
            -rw-r--r-- 1 iobroker iobroker 108932088 30. Sep 21:25 iobroker_2023_09_30-21_24_21_backupiobroker.tar.gz
            -rwxrwxrwx 1 root     root        121703 30. Sep 14:23 jarvis.0_2023_09_30-14_23_13_backupiobroker.tar.gz
            -rw-r--r-- 1 iobroker iobroker    121703 30. Sep 21:25 jarvis.0_2023_09_30-21_25_01_backupiobroker.tar.gz
            -rwxrwxrwx 1 root     root        988421 30. Sep 14:23 javascripts_2023_09_30-14_23_13_backupiobroker.tar.gz
            -rw-r--r-- 1 iobroker iobroker    988418 30. Sep 21:25 javascripts_2023_09_30-21_25_02_backupiobroker.tar.gz
            drwxrwxrwx 2 root     root         16384 30. Sep 14:05 lost+found
            -rwxrwxrwx 1 root     root          9152 30. Sep 14:23 zigbee.0_2023_09_30-14_23_12_backupiobroker.tar.gz
            -rw-r--r-- 1 iobroker iobroker      9152 30. Sep 21:25 zigbee.0_2023_09_30-21_25_01_backupiobroker.tar.gz
            heut mittag als root(warum auch immer) und jetzt als User iobroker
              @homoran komisch
              ich hab
              /media/ext_usb
              insgesamt 219888
              #93
              @crunchip mir ist gerade etwas aufgefallen
              das laufwerk existiert noch, hat allerdings jetzt 100GB
              wo immer das jetzt her kommt
              es ist der in der pve gemountete erste Versuch gewesen.
              der mount ist in der pve fstab auskommentiert und ich hab mehrfach rebootet
              mit 777 hab ich auch schon spielen wollen, jetzt wollte ich es umsetzen
              pi@VM03:~$ sudo chmod 777 -c -R /media/usbstick/backups
              [sudo] Passwort für pi:
              der Modus von '/media/usbstick/backups' wurde von 0766 (rwxrw-rw-) in 0777 (rwxrwxrwx) geändert
              der Modus von '/media/usbstick/backups/backups' wurde von 0755 (rwxr-xr-x) in 0777 (rwxrwxrwx) geändert
              der Modus von '/media/usbstick/backups/lost+found' wurde von 0766 (rwxrw-rw-) in 0777 (rwxrwxrwx) geändert
              pi@VM03:~$ sudo ls -la /media/usbstick
              insgesamt 12
              drwxrw-rw- 3 root root 4096 30. Sep 21:02 .
              drwxr-xr-x 4 root root 4096 29. Sep 13:39 ..
              drwxrwxrwx 4 root root 4096 30. Sep 20:19 backups
              pi@VM03:~$
              Obwohl er sagt, dass er es ändert ist es nicht so
              crunchipC ? 5 Antworten Letzte Antwort
                insgesamt 12
                pi@VM03:~$
                crunchipC Abwesend
                crunchipC Abwesend
                #94
                du hast schon nen sehr seltsamen Stick, halb eingesteckt 32GB, drin 64 und jetzt hast ihn wohl zu weit rein geschoben???😂 😂
                aber als storage zugefügt, das musst du auch löschen
                  insgesamt 12
                  pi@VM03:~$
                  crunchipC Abwesend
                  crunchipC Abwesend
                  #95
                  ist es doch
                  drwxrwxrwx
                    insgesamt 12
                    pi@VM03:~$
                    crunchipC Abwesend
                    crunchipC Abwesend
                    #96
                      #97
                      wott??
                      pi@VM03:~$ sudo ls -la /media/usbstick/backups
                      insgesamt 1264
                      drwxrwxrwx 4 root     root        4096 30. Sep 21:47 .
                      drwxrwxrwx 3 root     root        4096 30. Sep 21:02 ..
                      drwxrwxrwx 2 root     root        4096 30. Sep 20:19 backups
                      -rw-r--r-- 1 iobroker iobroker 1265480 30. Sep 21:47 iobroker_2023_09_30-21_47_13_backupiobroker.tar.gz
                      drwxrwxrwx 2 root     root       16384 30. Sep 17:20 lost+found
                      pi@VM03:~$
                      2023-09-30 21:47:17.343	debug	[iobroker/cifs] Copy iobroker_2023_09_30-21_47_13_backupiobroker.tar.gz...
                      backitup.0
                      	2023-09-30 21:47:17.343	debug	[iobroker/cifs] used copy path: /media/usbstick/backups
                      das biege ich auch noch hin
                        insgesamt 12
                        pi@VM03:~$
                        crunchipC Abwesend
                        crunchipC Abwesend
                        #98
                        du hast noch einen unterordner angelegt aber chmod direkt auf /media/usbstick/backups gelegt
                        korrekt wäre doch
                        -R steht doch für rekursiv ... alle folgenden Unterordner
                          korrekt wäre doch
                          #99
                          @crunchip danke, mach ich
                          aufgeräumt ist
                          pi@VM03:~$ rm /media/usbstick/backups/backups
                          rm: das Entfernen von '/media/usbstick/backups/backups' ist nicht möglich: Ist ein Verzeichnis
                          pi@VM03:~$ rm -r /media/usbstick/backups/backups
                          pi@VM03:~$
                          pi@VM03:~$
                          pi@VM03:~$
                          pi@VM03:~$
                          pi@VM03:~$
                          insgesamt 1260
                          drwxrwxrwx 3 root     root        4096 30. Sep 21:53 .
                          pi@VM03:~$
                          was muss jetzt in die fstab der VM?
                          dann reboote ich mal
                            wott??
                            insgesamt 1264
                            pi@VM03:~$
                            backitup.0
                            crunchipC Abwesend
                            crunchipC Abwesend
                            #100
                            drwxrwxrwx 4 root root 4096 30. Sep 21:47 . drwxrwxrwx 3 root root 4096 30. Sep 21:02 .. drwxrwxrwx 2 root root 4096 30. Sep 20:19 backups -rw-r--r-- 1 iobroker iobroker 1265480 30. Sep 21:47 iobroker_2023_09_30-21_47_13_backupiobroker.tar.gz drwxrwxrwx 2 root root 16384 30. Sep 17:20 lost+found
                            das passt doch jetzt, auch die Rechte, musst nur den einen Unterordner backup löschen
                              #101
                              hab ich schon
                                aufgeräumt ist
                                pi@VM03:~$
                                pi@VM03:~$
                                pi@VM03:~$
                                pi@VM03:~$
                                pi@VM03:~$
                                insgesamt 1260
                                pi@VM03:~$
                                crunchipC Abwesend
                                crunchipC Abwesend
                                #102
                                die uuid deines Sticks auslesen
                                und dann so wie auch in der Doku, in deinem Fall aber in der VM, nicht vom Host aus
                                UUID=BEZEI-CHNUNG /media/usbstick/backups ext4 defaults 0 0
                                du kannst vorher den Stick aushängen, dann den Eintrag tätigen, anschließend mit mount -a wieder einhängen und prüfen ob alles ok
                                sollte alles passen, kannst du rebooten
                                  #103
                                  so?
                                  pi@VM03:~$ sudo blkid
                                  /dev/sr0: BLOCK_SIZE="2048" UUID="2023-07-22-10-52-30-00" LABEL="Debian 12.1.0 amd64 n" TYPE="iso9660" PTUUID="3db87b5e" PTTYPE="dos"
                                  /dev/sdc1: UUID="60a9d942-0ebd-473c-8d77-b15e15a21df7" BLOCK_SIZE="4096" TYPE="ext4"
                                  /dev/sda5: UUID="fc17aa9c-8f67-44c1-a81e-596eaf6b932e" TYPE="swap" PARTUUID="f97472f3-05"
                                  /dev/sda1: UUID="8c135bc3-7ee2-40fa-b164-d21aab2f5661" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="f97472f3-01"
                                  pi@VM03:~$
                                  will meine kurze ID wiederhaben
                                    so?
                                    pi@VM03:~$
                                    crunchipC Abwesend
                                    crunchipC Abwesend
                                    #104
                                    Obi oder Hornbach😂 kannst ja nochmal von vorn und mit vfat probieren😜
                                      #105
                                      @crunchip danke, ich trau mich dann....
                                        crunchipC Abwesend
                                        crunchipC Abwesend
                                        #106
                                        @homoran die Spannung steigt🤔
                                          #107
                                          jepp
                                          i@VM03:~$ sudo mount -a
                                          mount: (hint) your fstab has been modified, but systemd still uses
                                                 the old version; use 'systemctl daemon-reload' to reload.
                                          pi@VM03:~$ sudo systemctl daemon-reload
                                          pi@VM03:~$
                                          mein juice (android) hatte dauernd die fstab umformatiert.
                                          ich hoffe alles ist heil
