  3. Off Topic
  4. Proxmox
  5. ioBroker in Proxmox nach Doku installiert, aber Fragen!
Geplant Angeheftet Gesperrt Verschoben Proxmox
145 Beiträge 8 Kommentatoren 29.5k Aufrufe 5 Beobachtet
    @homoran sagte in ioBroker in Proxmox nach Doku installiert, aber Fragen!:
    und schwupps hat er wieder die falschen Rechte
    ja, weil nachträglich
    geändert! dann klappt's auch mit dem mount
    dann sollte backitup nun durchlaufen
    #89
    @crunchip sagte in ioBroker in Proxmox nach Doku installiert, aber Fragen!:
    nope
    Started iobroker ...
    [DEBUG] [iobroker] start with {"type":"creator","workDir":"/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js","time":"02:40","debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"Copy","type":"storage","source":"local","mount":"","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":false,"ownDir":false,"dir":"/media/usbstick/backups","dirMinimal":"sharename/backupDir","user":"","pass":"****","ignoreErrors":false},"ignoreErrors":false,"dir":"/opt/iobroker","historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
    [DEBUG] [iobroker] - host.VM03 105 states saved
    [DEBUG] [iobroker] - host.VM03 144 objects saved
    [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2023_09_30-21_09_11_backupiobroker.tar.gz
    [DEBUG] [iobroker] - This backup can only be restored with js-controller version up from 4.1
    [DEBUG] [iobroker] - done
    [DEBUG] [cifs] - used copy path: /media/usbstick/backups
    [ERROR] [cifs] - Path "/media/usbstick/backups" not found
    [DEBUG] [cifs] start with {"mountType":"Copy","type":"storage","source":"local","mount":"","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":false,"ownDir":false,"dir":"/media/usbstick/backups","dirMinimal":"sharename/backupDir","user":"","pass":"****","ignoreErrors":false,"deleteBackupAfter":0}
    unter den mounts ist es drin /dev/sdc1 on /media/usbstick/backups type ext4 (rw,relatime)
      dachte das hast du rausgenommen
      hab ich jetzt. überlebt das einen Neustart?
      crunchipC Abwesend
      crunchipC Abwesend
      #90
      eigentlich nicht, soweit ich weiß
      gibts doch nicht🤔
        gibts doch nicht🤔
        #91
        gibts doch nicht
        hab schon alles durch was mir einfällt.
        /media/... oder ohne slash media/...
        cifs-utils sind installiert
        pi@VM03:~$ apt policy cifs-utils
        cifs-utils:
          Installiert:           2:7.0-2
          Installationskandidat: 2:7.0-2
          Versionstabelle:
         *** 2:7.0-2 500
                500 http://debian.netcologne.de/debian bookworm/main amd64 Packages
        pi@VM03:~$
          gibts doch nicht
          cifs-utils:
            Versionstabelle:
           *** 2:7.0-2 500
          pi@VM03:~$
          crunchipC Abwesend
          crunchipC Abwesend
          #92
          @homoran komisch
          einzige was bei mir anders ist, ich hab nicht zusätzlich noch einen Unterordner angelegt
          ich hab
          mkdir /media/ext_usb
          mount /dev/sdb1 /media/ext_usb
          und meine Backups liegen in ext_usb
          Pfadangabe in der Instanz
          /media/ext_usb
          allerdings grad noch mal nach den Rechten gesehen, ich hab 777 vergeben
          hatte das ja heute mittag getestet und soeben nochmal gegengeprüft
          mario@IoBroker:~$ sudo ls -la /media/ext_usb
          insgesamt 219888
          drwxrwxrwx 3 root     root          4096 30. Sep 21:25 .
          drwxr-xr-x 4 root     root          4096 30. Sep 14:14 ..
          -rwxrwxrwx 1 root     root       2502737 30. Sep 14:23 historyDB_2023_09_30-14_23_06_backupiobroker.tar.gz
          -rw-r--r-- 1 iobroker iobroker   2518880 30. Sep 21:25 historyDB_2023_09_30-21_24_57_backupiobroker.tar.gz
          -rwxrwxrwx 1 root     root     108928731 30. Sep 14:23 iobroker_2023_09_30-14_22_27_backupiobroker.tar.gz
          -rw-r--r-- 1 iobroker iobroker 108932088 30. Sep 21:25 iobroker_2023_09_30-21_24_21_backupiobroker.tar.gz
          -rwxrwxrwx 1 root     root        121703 30. Sep 14:23 jarvis.0_2023_09_30-14_23_13_backupiobroker.tar.gz
          -rw-r--r-- 1 iobroker iobroker    121703 30. Sep 21:25 jarvis.0_2023_09_30-21_25_01_backupiobroker.tar.gz
          -rwxrwxrwx 1 root     root        988421 30. Sep 14:23 javascripts_2023_09_30-14_23_13_backupiobroker.tar.gz
          -rw-r--r-- 1 iobroker iobroker    988418 30. Sep 21:25 javascripts_2023_09_30-21_25_02_backupiobroker.tar.gz
          drwxrwxrwx 2 root     root         16384 30. Sep 14:05 lost+found
          -rwxrwxrwx 1 root     root          9152 30. Sep 14:23 zigbee.0_2023_09_30-14_23_12_backupiobroker.tar.gz
          -rw-r--r-- 1 iobroker iobroker      9152 30. Sep 21:25 zigbee.0_2023_09_30-21_25_01_backupiobroker.tar.gz
          heut mittag als root(warum auch immer) und jetzt als User iobroker
            @homoran komisch
            ich hab
            /media/ext_usb
            insgesamt 219888
            #93
            @crunchip mir ist gerade etwas aufgefallen
            das laufwerk existiert noch, hat allerdings jetzt 100GB
            wo immer das jetzt her kommt
            es ist der in der pve gemountete erste Versuch gewesen.
            der mount ist in der pve fstab auskommentiert und ich hab mehrfach rebootet
            mit 777 hab ich auch schon spielen wollen, jetzt wollte ich es umsetzen
            pi@VM03:~$ sudo chmod 777 -c -R /media/usbstick/backups
            [sudo] Passwort für pi:
            der Modus von '/media/usbstick/backups' wurde von 0766 (rwxrw-rw-) in 0777 (rwxrwxrwx) geändert
            der Modus von '/media/usbstick/backups/backups' wurde von 0755 (rwxr-xr-x) in 0777 (rwxrwxrwx) geändert
            der Modus von '/media/usbstick/backups/lost+found' wurde von 0766 (rwxrw-rw-) in 0777 (rwxrwxrwx) geändert
            pi@VM03:~$ sudo ls -la /media/usbstick
            insgesamt 12
            drwxrw-rw- 3 root root 4096 30. Sep 21:02 .
            drwxr-xr-x 4 root root 4096 29. Sep 13:39 ..
            drwxrwxrwx 4 root root 4096 30. Sep 20:19 backups
            pi@VM03:~$
            Obwohl er sagt, dass er es ändert ist es nicht so
            crunchipC ? 5 Antworten Letzte Antwort
              insgesamt 12
              pi@VM03:~$
              crunchipC Abwesend
              crunchipC Abwesend
              #94
              du hast schon nen sehr seltsamen Stick, halb eingesteckt 32GB, drin 64 und jetzt hast ihn wohl zu weit rein geschoben???😂 😂
              aber als storage zugefügt, das musst du auch löschen
                insgesamt 12
                pi@VM03:~$
                crunchipC Abwesend
                crunchipC Abwesend
                #95
                ist es doch
                drwxrwxrwx
                  insgesamt 12
                  pi@VM03:~$
                  crunchipC Abwesend
                  crunchipC Abwesend
                  #96
                    #97
                    wott??
                    pi@VM03:~$ sudo ls -la /media/usbstick/backups
                    insgesamt 1264
                    drwxrwxrwx 4 root     root        4096 30. Sep 21:47 .
                    drwxrwxrwx 3 root     root        4096 30. Sep 21:02 ..
                    drwxrwxrwx 2 root     root        4096 30. Sep 20:19 backups
                    -rw-r--r-- 1 iobroker iobroker 1265480 30. Sep 21:47 iobroker_2023_09_30-21_47_13_backupiobroker.tar.gz
                    drwxrwxrwx 2 root     root       16384 30. Sep 17:20 lost+found
                    pi@VM03:~$
                    2023-09-30 21:47:17.343	debug	[iobroker/cifs] Copy iobroker_2023_09_30-21_47_13_backupiobroker.tar.gz...
                    backitup.0
                    	2023-09-30 21:47:17.343	debug	[iobroker/cifs] used copy path: /media/usbstick/backups
                    das biege ich auch noch hin
                      insgesamt 12
                      pi@VM03:~$
                      crunchipC Abwesend
                      crunchipC Abwesend
                      #98
                      du hast noch einen unterordner angelegt aber chmod direkt auf /media/usbstick/backups gelegt
                      korrekt wäre doch
                      -R steht doch für rekursiv ... alle folgenden Unterordner
                        korrekt wäre doch
                        #99
                        @crunchip danke, mach ich
                        aufgeräumt ist
                        pi@VM03:~$ rm /media/usbstick/backups/backups
                        rm: das Entfernen von '/media/usbstick/backups/backups' ist nicht möglich: Ist ein Verzeichnis
                        pi@VM03:~$ rm -r /media/usbstick/backups/backups
                        pi@VM03:~$
                        pi@VM03:~$
                        pi@VM03:~$
                        pi@VM03:~$
                        pi@VM03:~$
                        insgesamt 1260
                        drwxrwxrwx 3 root     root        4096 30. Sep 21:53 .
                        pi@VM03:~$
                        was muss jetzt in die fstab der VM?
                        dann reboote ich mal
                          wott??
                          insgesamt 1264
                          pi@VM03:~$
                          backitup.0
                          crunchipC Abwesend
                          crunchipC Abwesend
                          #100
                          drwxrwxrwx 4 root root 4096 30. Sep 21:47 . drwxrwxrwx 3 root root 4096 30. Sep 21:02 .. drwxrwxrwx 2 root root 4096 30. Sep 20:19 backups -rw-r--r-- 1 iobroker iobroker 1265480 30. Sep 21:47 iobroker_2023_09_30-21_47_13_backupiobroker.tar.gz drwxrwxrwx 2 root root 16384 30. Sep 17:20 lost+found
                          das passt doch jetzt, auch die Rechte, musst nur den einen Unterordner backup löschen
                            #101
                            hab ich schon
                              aufgeräumt ist
                              pi@VM03:~$
                              pi@VM03:~$
                              pi@VM03:~$
                              pi@VM03:~$
                              pi@VM03:~$
                              insgesamt 1260
                              pi@VM03:~$
                              crunchipC Abwesend
                              crunchipC Abwesend
                              #102
                              die uuid deines Sticks auslesen
                              und dann so wie auch in der Doku, in deinem Fall aber in der VM, nicht vom Host aus
                              UUID=BEZEI-CHNUNG /media/usbstick/backups ext4 defaults 0 0
                              du kannst vorher den Stick aushängen, dann den Eintrag tätigen, anschließend mit mount -a wieder einhängen und prüfen ob alles ok
                              sollte alles passen, kannst du rebooten
                                #103
                                so?
                                pi@VM03:~$ sudo blkid
                                /dev/sr0: BLOCK_SIZE="2048" UUID="2023-07-22-10-52-30-00" LABEL="Debian 12.1.0 amd64 n" TYPE="iso9660" PTUUID="3db87b5e" PTTYPE="dos"
                                /dev/sdc1: UUID="60a9d942-0ebd-473c-8d77-b15e15a21df7" BLOCK_SIZE="4096" TYPE="ext4"
                                /dev/sda5: UUID="fc17aa9c-8f67-44c1-a81e-596eaf6b932e" TYPE="swap" PARTUUID="f97472f3-05"
                                /dev/sda1: UUID="8c135bc3-7ee2-40fa-b164-d21aab2f5661" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="f97472f3-01"
                                pi@VM03:~$
                                will meine kurze ID wiederhaben
                                  so?
                                  pi@VM03:~$
                                  crunchipC Abwesend
                                  crunchipC Abwesend
                                  #104
                                  Obi oder Hornbach😂 kannst ja nochmal von vorn und mit vfat probieren😜
                                    #105
                                    @crunchip danke, ich trau mich dann....
                                      crunchipC Abwesend
                                      crunchipC Abwesend
                                      #106
                                      @homoran die Spannung steigt🤔
                                        #107
                                        jepp
                                        i@VM03:~$ sudo mount -a
                                        mount: (hint) your fstab has been modified, but systemd still uses
                                               the old version; use 'systemctl daemon-reload' to reload.
                                        pi@VM03:~$ sudo systemctl daemon-reload
                                        pi@VM03:~$
                                        mein juice (android) hatte dauernd die fstab umformatiert.
                                        ich hoffe alles ist heil
                                          jepp
                                          pi@VM03:~$
                                          crunchipC Abwesend
                                          crunchipC Abwesend
                                          #108
                                          sowas macht man auch nicht auf der Couch vom Tablet aus😜
