  3. Off Topic
  4. Pflege des Betriebssystems
  5. Upgrade von Debian 12 'Bookworm' auf Debian 13 'Trixie'
Geplant Angeheftet Gesperrt Verschoben Pflege des Betriebssystems
265 Beiträge 50 Kommentatoren 77.1k Aufrufe 56 Beobachtet
  • M marcelinho
    @Thomas-Braun danke für deine Hilfe, anbei:
    ```bash
    Script v.2025-08-09
    *** BASE SYSTEM ***
     Static hostname: raspberrypi
           Icon name: computer
              Kernel: Linux 6.12.47+rpt-rpi-v8
        Architecture: arm64
    OS is similar to:
    Model           : Raspberry Pi 4 Model B Rev 1.5
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     18:31:23 up 8 min,  3 users,  load average: 3.00, 4.20, 2.57
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Debian 'bookworm' is the current oldstable version. Please upgrade to the latest stable release 'trixie' in due time!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Fri 2026-01-02 18:31:23 CET
               Universal time: Fri 2026-01-02 17:31:23 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    pi
    HOME=/home/pi
    GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         false
    Unit display-manager.service could not be found.
    Display-Manager:
    Desktop:
    Session:                tty
    *** MEMORY ***
    Mem:            4.0G        3.2G        319M         69K        583M        811M
    Swap:           209M        159M         50M
    Total:          4.2G        3.3G        369M
    Active iob-Instances:   27
             3796 M total memory
             3022 M used memory
             1966 M active memory
             1326 M inactive memory
              304 M free memory
               48 M buffer memory
              508 M swap cache
              199 M total swap
              151 M used swap
               48 M free swap
    top - 18:31:24 up 8 min,  3 users,  load average: 3.00, 4.20, 2.57
    Tasks: 237 total,   1 running, 236 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us, 14.3 sy,  0.0 ni, 85.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   3796.9 total,    304.0 free,   3023.2 used,    557.0 buff/cache
    MiB Swap:    200.0 total,     48.1 free,    151.9 used.    773.7 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  1.6G     0  1.6G   0% /dev
    tmpfs          tmpfs     760M  1.3M  759M   1% /run
    /dev/mmcblk0p2 ext4       29G   18G  9.6G  65% /
    tmpfs          tmpfs     1.9G  8.0K  1.9G   1% /dev/shm
    tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
    /dev/mmcblk0p1 vfat      510M   78M  433M  16% /boot/firmware
    tmpfs          tmpfs     380M   44K  380M   1% /run/user/1000
    [Fri Jan  2 18:22:34 2026] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  numa=fake=2 system_heap.max_order=0 smsc95xx.macaddr=D8:3A:DD:1A:71:9B vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=1e048ecb-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [Fri Jan  2 18:22:36 2026] EXT4-fs (mmcblk0p2): mounted filesystem cb6f0e18-5add-4177-ab98-e9f0235e06b3 ro with ordered data mode. Quota mode: none.
    [Fri Jan  2 18:22:37 2026] EXT4-fs (mmcblk0p2): re-mounted cb6f0e18-5add-4177-ab98-e9f0235e06b3 r/w.
    Show mounted filesystems:
    TARGET           SOURCE         FSTYPE OPTIONS
    /                /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    3.4G    /var/
    1.8G    /var/cache/apt
    1.8G    /var/cache
    1.7G    /var/cache/apt/archives
    911M    /var/log
    Archived and active journals take up 908.7M in the file system.
    /opt/iobroker/backups:
    145M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.8G    /opt/iobroker/iobroker-data/
    1.4G    /opt/iobroker/iobroker-data/history
    236M    /opt/iobroker/iobroker-data/files
    109M    /opt/iobroker/iobroker-data/backup-objects
    47M     /opt/iobroker/iobroker-data/files/admin.admin
    44M     /opt/iobroker/iobroker-data/objects.jsonl
    24M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map
    9.8M    /opt/iobroker/iobroker-data/files/vis-2/material-icons/knx-uf.json
    9.8M    /opt/iobroker/iobroker-data/files/homekit-controller.admin/static/js/main.f592ece1.js
    9.3M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js
    USB-Devices by-id:
    /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_c4452914ae9ded11bf33d1a5a7669f5d-if00-port0
    *** ZigBee Settings ***
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v22.21.1
    /usr/bin/node           v22.21.1
    /usr/bin/npm            11.6.4
    /usr/bin/npx            11.6.4
    /usr/bin/corepack       0.34.0
    nodejs:
      Installed: 22.21.1-1nodesource1
      Candidate: 22.21.1-1nodesource1
      Version table:
     *** 22.21.1-1nodesource1 100
            100 /var/lib/dpkg/status
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    raspberrypi         raspberrypi (version: 7.0.7, hostname: raspberrypi   , alive, uptime: 508)
    Core adapters versions
    js-controller:  7.0.7
    admin:          7.7.19
    javascript:     9.0.11
    nodejs modules from github:     1
    +-- homebridge-tapo@1.4.17 (git+ssh://git@github.com/apatsufas/homebridge-tapo-p100.git#8d25f8ab9ffc1d7cca1118cd0081d1ba28fd3cd1)
    Adapter State
    + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.awtrix-light.0           : awtrix-light          : raspberrypi                              -  enabled
    + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
    + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
    + system.adapter.daikin-cloud.0           : daikin-cloud          : raspberrypi                              -  enabled
    + system.adapter.daikin.0                 : daikin                : raspberrypi                              -  enabled
    + system.adapter.daikin.1                 : daikin                : raspberrypi                              -  enabled
    + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
    + system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : raspberrypi                              -  enabled
    + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: raspberrypi                              -  enabled
    + system.adapter.history.0                : history               : raspberrypi                              -  enabled
    + system.adapter.homeconnect.0            : homeconnect           : raspberrypi                              -  enabled
    + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
    + system.adapter.iqontrol.0               : iqontrol              : raspberrypi                              -  enabled
    + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
    + system.adapter.lg-thinq.0               : lg-thinq              : raspberrypi                              -  enabled
    + system.adapter.meross.0                 : meross                : raspberrypi                              -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1885, bind: 0.0.0.0
    + system.adapter.myenergi.0               : myenergi              : raspberrypi                              -  enabled
    + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.statistics.0             : statistics            : raspberrypi                              -  enabled
    + system.adapter.sun2000.0                : sun2000               : raspberrypi                              -  enabled, port: 502
    + system.adapter.tesla-motors.0           : tesla-motors          : raspberrypi                              -  enabled
    + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
      system.adapter.vis-2.0                  : vis-2                 : raspberrypi                              - disabled
    + system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : raspberrypi                              -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "admin"        : 7.7.19   , installed 7.7.19
    Adapter    "awtrix-light" : 3.0.0    , installed 3.0.0
    Adapter    "backitup"     : 3.3.10   , installed 3.3.10
    Adapter    "cloud"        : 5.0.1    , installed 5.0.1
    Adapter    "daikin"       : 1.5.1    , installed 1.5.1
    Adapter    "daikin-cloud" : 0.4.12   , installed 0.4.12
    Adapter    "ecovacs-deebot": 1.4.15  , installed 1.4.15
    Adapter    "energiefluss-erweitert": 0.8.1, installed 0.8.1
    Adapter    "homeconnect"  : 1.4.3    , installed 1.4.3
    Adapter    "homekit-controller": 0.5.11, installed 0.5.11
    Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
    Adapter    "javascript"   : 9.0.11   , installed 9.0.11
    Controller "js-controller": 7.0.7    , installed 7.0.7
    Adapter    "lg-thinq"     : 1.1.3    , installed 1.1.3
    Adapter    "meross"       : 1.17.0   , installed 1.17.0
    Adapter    "modbus"       : 6.3.2    , installed 6.3.2
    Adapter    "mqtt"         : 6.1.4    , installed 6.1.4
    Adapter    "mqtt-client"  : 3.0.0    , installed 3.0.0
    Adapter    "myenergi"     : 0.0.3    , installed 0.0.3
    Adapter    "openhab"      : 1.2.0    , installed 1.2.0
    Adapter    "shelly"       : 10.4.1   , installed 10.4.1
    Adapter    "socketio"     : 6.7.1    , installed 6.7.1
    Adapter    "statistics"   : 2.4.0    , installed 2.4.0
    Adapter    "sun2000"      : 2.3.5    , installed 2.3.5
    Adapter    "tesla-motors" : 1.3.2    , installed 1.3.2
    Adapter    "tuya"         : 3.16.0   , installed 3.16.0
    Adapter    "vis-2"        : 2.13.4   , installed 2.13.8
    Adapter    "web"          : 7.0.8    , installed 7.0.8
    Adapter    "ws"           : 2.6.2    , installed 2.6.2
    Adapter    "zigbee"       : 3.1.5    , installed 3.1.5
    Adapter    "zigbee2mqtt"  : 3.0.9    , installed 3.0.9
    Objects and States
    Objects:        6444
    States:         5058
    Hit:1 http://archive.raspberrypi.org/debian bookworm InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian bookworm InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:38713         0.0.0.0:*               LISTEN      112        7895       1261/homebridge: ho
    tcp        0      0 0.0.0.0:8080            0.0.0.0:*               LISTEN      1001       11993      2134/node
    tcp        0      0 127.0.0.1:42175         0.0.0.0:*               LISTEN      112        8001       1241/homebridge: ho
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      114        7397       770/mosquitto
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       11907      1988/io.shelly.0
    tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       12592      1995/io.mqtt.0
    tcp        0      0 127.0.0.1:34053         0.0.0.0:*               LISTEN      112        7913       1248/homebridge: @0
    tcp        0      0 127.0.0.1:42345         0.0.0.0:*               LISTEN      112        8650       1240/homebridge: ho
    tcp        0      0 127.0.0.1:38275         0.0.0.0:*               LISTEN      112        7997       1279/homebridge: ho
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          1979       762/cupsd
    tcp        0      0 127.0.0.1:45787         0.0.0.0:*               LISTEN      112        7902       1247/homebridge: ho
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       8426       991/iobroker.js-con
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       9438       991/iobroker.js-con
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          5880       775/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:45135         0.0.0.0:*               LISTEN      112        9653       1259/homebridge: ho
    tcp        0      0 127.0.0.1:37043         0.0.0.0:*               LISTEN      112        8660       1267/homebridge: ho
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          1978       762/cupsd
    tcp6       0      0 :::52403                :::*                    LISTEN      112        9624       1247/homebridge: ho
    tcp6       0      0 :::44253                :::*                    LISTEN      112        7858       1267/homebridge: ho
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       9997       1464/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       19110      3344/io.web.0
    tcp6       0      0 :::8086                 :::*                    LISTEN      999        7168       878/influxd
    tcp6       0      0 :::32570                :::*                    LISTEN      112        10548      1261/homebridge: ho
    tcp6       0      0 :::1883                 :::*                    LISTEN      114        7398       770/mosquitto
    tcp6       0      0 :::8581                 :::*                    LISTEN      112        10450      1108/hb-service
    tcp6       0      0 :::37356                :::*                    LISTEN      112        8572       1248/homebridge: @0
    tcp6       0      0 :::53299                :::*                    LISTEN      112        7931       1259/homebridge: ho
    tcp6       0      0 :::22                   :::*                    LISTEN      0          5882       775/sshd: /usr/sbin
    tcp6       0      0 :::3000                 :::*                    LISTEN      113        8468       990/grafana
    tcp6       0      0 :::52120                :::*                    LISTEN      112        9612       1279/homebridge: ho
    tcp6       0      0 :::47961                :::*                    LISTEN      112        7846       1240/homebridge: ho
    tcp6       0      0 :::39667                :::*                    LISTEN      112        10537      1241/homebridge: ho
    tcp6       0      0 :::51798                :::*                    LISTEN      112        7831       1206/homebridge
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           112        7868       1241/homebridge: ho
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           112        10447      1108/hb-service
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        5759       593/avahi-daemon: r
    udp        0      0 0.0.0.0:57147           0.0.0.0:*                           104        5761       593/avahi-daemon: r
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       14474      1766/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       14481      1766/io.tuya.0
    udp6       0      0 :::5353                 :::*                                104        5760       593/avahi-daemon: r
    udp6       0      0 :::52580                :::*                                104        5762       593/avahi-daemon: r
    udp6       0      0 fe80::81a3:20c2:583:546 :::*                                0          7484       704/NetworkManager
    iob diag has finished.
    Thomas BraunT Offline
    #221
    @marcelinho
    Das System ist stabil, ein Dist-Upgrade geht also nach obiger Anleitung.
    • H Online
      H Online
      hoschi2007
      #222
      @marcelinho ich würde dir empfehlen vor dem Upgrade ein komplettes Image deiner SD-Karte/SSD/..., was auch immer du nutzt, zu erstellen. Ich verwende dazu unter Windows den Win32 Disk Imager. Wenn etwas komplett daneben gehen sollte, kannst du das Image wiederherstellen.
      meuteM 1 Antwort Letzte Antwort
      • H hoschi2007
        meuteM Offline
        meuteM Offline
        meute
        #223
        @hoschi2007 sagte in Upgrade von Debian 12 'Bookworm' auf Debian 13 'Trixie':
        https://sourceforge.net/projects/win32diskimager/
        fraenk for friends Code: MATF103
        • HomoranH Homoran hat dieses Thema am aufgespalten
        • wendy2702W Online
          wendy2702W Online
          wendy2702
          #224
          Frohes neues zusammen.
          Hatte jemand bei einem Upgrade PI5 ohne IOB installation schonmal diese Fehlermeldung und/oder weiss was zu tun ist:
          Nach Ausführen von:
          sudo apt full-upgrade
          kommt irgendwann dass:
          dpkg: libfm-extra4:arm64: dependency problems, but removing anyway as you requested:
           libfm-modules:arm64 depends on libfm-extra4 (>= 1.2.0).
          (Reading database ... 158179 files and directories currently installed.)
          Removing libfm-extra4:arm64 (1.3.2-1+rpt18) ...
          Selecting previously unselected package libfm-extra4t64:arm64.
          (Reading database ... 158172 files and directories currently installed.)
          Preparing to unpack .../libfm-extra4t64_1.4.0-2+rpt8_arm64.deb ...
          Unpacking libfm-extra4t64:arm64 (1.4.0-2+rpt8) ...
          Preparing to unpack .../libfm-modules_1.4.0-2+rpt8_arm64.deb ...
          Unpacking libfm-modules:arm64 (1.4.0-2+rpt8) over (1.3.2-1+rpt18) ...
          Preparing to unpack .../lxpanel-data_0.11.1-1_all.deb ...
          Unpacking lxpanel-data (0.11.1-1) over (0.10.1-2+rpt22) ...
          Preparing to unpack .../wireless-tools_30~pre9-18+b1_arm64.deb ...
          Unpacking wireless-tools (30~pre9-18+b1) over (30~pre9-14) ...
          dpkg: libiw30:arm64: dependency problems, but removing anyway as you requested:
           lxpanel depends on libiw30 (>= 30~pre1).
          (Reading database ... 158152 files and directories currently installed.)
          Removing libiw30:arm64 (30~pre9-14) ...
          Selecting previously unselected package libiw30t64:arm64.
          (Reading database ... 158148 files and directories currently installed.)
          Preparing to unpack .../libiw30t64_30~pre9-18+b1_arm64.deb ...
          Adding 'diversion of /lib/aarch64-linux-gnu/libiw.so.30 to /lib/aarch64-linux-gnu/libiw.so.30.usr-is-merged by libiw30t64'
          Unpacking libiw30t64:arm64 (30~pre9-18+b1) ...
          Preparing to unpack .../lxpanel_0.11.1-1_arm64.deb ...
          Unpacking lxpanel (0.11.1-1) over (0.10.1-2+rpt22) ...
          dpkg: error processing archive /var/cache/apt/archives/lxpanel_0.11.1-1_arm64.deb (--unpack):
           trying to overwrite '/usr/lib/aarch64-linux-gnu/lxpanel/plugins/batt.so', which is also in package lxplug-batt (0.23)
          Errors were encountered while processing:
          /usr/bin/gdbus: symbol lookup error: /usr/bin/gdbus: undefined symbol: g_string_free_and_steal
          E: Sub-process /usr/bin/dpkg returned an error code (1)
          • wendy2702W wendy2702
            Nach Ausführen von:
            #225
            @wendy2702
            sudo apt update
            sudo apt upgrade
            sagt? Die Meldungen kämen nicht auf einem System OHNE installierten Desktop...
            • wendy2702W Online
              wendy2702W Online
              wendy2702
              #226
              Hallo Thomas,
              Danke für die Antwort. Da ist ein Desktop drauf da es einer meiner PIs zur VIS Anzeige ist.
              Setze den neu auf, geht wahrscheinlich genauso schnell.
              • CyberraphC Offline
                CyberraphC Offline
                Cyberraph
                #227
                Hallo Thomas!
                Vielen vielen Dank für die tolle Anleitung hier.
                Zusammen mit dem Kurs von Matthias @haus-automatisierung
                hatte ich Zuversicht alles sauber hochzuheben.
                Vielen Vielen Dank auch dafür an dieser Stelle von mir.
                Weiter mit der tollen Arbeit. :-)
                bash
                Script v.2025-08-09
                *** BASE SYSTEM ***
                Operating System: Debian GNU/Linux 13 (trixie)
                Static hostname: iobroker
                      Icon name: computer
                         Kernel: Linux 6.12.62+rpt-rpi-2712
                   Architecture: arm64
                OS is similar to:
                Model           : Raspberry Pi 5 Model B Rev 1.0
                Docker          : false
                Kernel          : aarch64
                Userland        : 64 bit
                17:47:47 up 3 min,  1 user,  load average: 1.29, 0.79, 0.33
                CPU threads: 4
                Operating System is the current Debian stable version codenamed 'trixie'!
                Current issues:
                              Local time: Sun 2026-01-25 17:47:47 CET
                          Universal time: Sun 2026-01-25 16:47:47 UTC
                                RTC time: Sun 2026-01-25 16:47:47
                               Time zone: Europe/Vienna (CET, +0100)
                             NTP service: active
                         RTC in local TZ: no
                pi
                HOME=/home/pi
                GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                iobroker
                HOME=/home/iobroker
                SUDO_HOME=/home/pi
                Display-Manager:
                Desktop:
                Session:                tty
                *** MEMORY ***
                Mem:            8.5G        2.8G        4.7G         17M        1.1G        5.7G
                Swap:           209M          0B        209M
                Total:          8.7G        2.8G        4.9G
                Active iob-Instances:   29
                        8062 M total memory
                        2632 M used memory
                        2593 M active memory
                         623 M inactive memory
                        4447 M free memory
                         101 M buffer memory
                         980 M swap cache
                         199 M total swap
                           0 M used swap
                         199 M free swap
                top - 17:47:47 up 3 min,  1 user,  load average: 1.29, 0.79, 0.33
                Tasks: 243 total,   1 running, 242 sleeping,   0 stopped,   0 zombie
                %Cpu(s):  2.2 us,  0.0 sy,  0.0 ni, 95.7 id,  2.2 wa,  0.0 hi,  0.0 si,  0.0 st
                MiB Mem :   8062.9 total,   4446.0 free,   2632.7 used,   1084.2 buff/cache
                MiB Swap:    200.0 total,    200.0 free,      0.0 used.   5430.2 avail Mem
                *** FILESYSTEM ***
                udev           devtmpfs  3.9G     0  3.9G   0% /dev
                tmpfs          tmpfs     1.6G   15M  1.6G   1% /run
                /dev/mmcblk0p2 ext4       59G   20G   36G  36% /
                tmpfs          tmpfs     4.0G     0  4.0G   0% /dev/shm
                tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
                tmpfs          tmpfs     4.0G  1.2M  4.0G   1% /tmp
                tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
                /dev/mmcblk0p1 vfat      510M   74M  437M  15% /boot/firmware
                tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/serial-getty@ttyAMA10.service
                tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
                tmpfs          tmpfs     807M   48K  807M   1% /run/user/1000
                [Sun Jan 25 17:44:13 2026] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0  numa=fake=8 system_heap.max_order=0 smsc95xx.macaddr=2C:CF:67:32:3A:99 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=c4e97527-02 rootfstype=ext4 fsck.repair=yes rootwait
                [Sun Jan 25 17:44:16 2026] EXT4-fs (mmcblk0p2): mounted filesystem 56f80fa2-e005-4cca-86e6-19da1069914d ro with ordered data mode. Quota mode: none.
                [Sun Jan 25 17:44:18 2026] EXT4-fs (mmcblk0p2): re-mounted 56f80fa2-e005-4cca-86e6-19da1069914d r/w.
                /var:
                5.0G    /var/
                4.0G    /var/log/journal/f74ba98ec8ff4148b6d00ad2f3b131b8
                4.0G    /var/log
                575M    /var/lib
                Archived and active journals take up 3.9G in the file system.
                3.7M    /opt/iobroker/backups/
                6.0G    /opt/iobroker/iobroker-data/
                5.4G    /opt/iobroker/iobroker-data/history
                546M    /opt/iobroker/iobroker-data/files
                163M    /opt/iobroker/iobroker-data/files/vis-2
                121M    /opt/iobroker/iobroker-data/files/vis-2/widgets
                33M     /opt/iobroker/iobroker-data/objects.jsonl
                32M     /opt/iobroker/iobroker-data/files/mytime.admin/custom/assets/index-B_3WOu59.js.map
                26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
                26M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
                24M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.70a15e1f.js.map
                USB-Devices by-id:
                No Devices found 'by-id'
                HINT:
                Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
                tcp
                zigbee.X
                Extended Pan ID:
                *** MASKED ***
                Pan ID:
                *** MASKED ***
                Channel:
                *** MASKED ***
                Network Key:
                *** MASKED ***
                /usr/bin/nodejs         v22.22.0
                /usr/bin/node           v22.22.0
                /usr/bin/npm            10.9.4
                /usr/bin/npx            10.9.4
                nodejs:
                 Installed: 22.22.0-1nodesource1
                 Candidate: 22.22.0-1nodesource1
                 Version table:
                *** 22.22.0-1nodesource1 600
                       500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
                    22.21.0-1nodesource1 600
                    22.20.0-1nodesource1 600
                    22.19.0-1nodesource1 600
                    22.18.0-1nodesource1 600
                    22.17.1-1nodesource1 600
                    22.17.0-1nodesource1 600
                    22.16.0-1nodesource1 600
                    22.15.1-1nodesource1 600
                    22.15.0-1nodesource1 600
                    22.14.0-1nodesource1 600
                    22.13.1-1nodesource1 600
                    22.13.0-1nodesource1 600
                    22.12.0-1nodesource1 600
                    22.11.0-1nodesource1 600
                    22.10.0-1nodesource1 600
                    22.9.0-1nodesource1 600
                    22.8.0-1nodesource1 600
                    22.7.0-1nodesource1 600
                    22.6.0-1nodesource1 600
                    22.5.1-1nodesource1 600
                    22.5.0-1nodesource1 600
                    22.4.1-1nodesource1 600
                    22.4.0-1nodesource1 600
                    22.3.0-1nodesource1 600
                    22.2.0-1nodesource1 600
                    22.1.0-1nodesource1 600
                    22.0.0-1nodesource1 600
                    20.20.0-1nodesource1 600
                       500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                    20.19.6-1nodesource1 600
                    20.19.5-1nodesource1 600
                    20.19.4-1nodesource1 600
                    20.19.3-1nodesource1 600
                    20.19.2+dfsg-1 500
                       500 http://deb.debian.org/debian trixie/main arm64 Packages
                    20.19.2-1nodesource1 600
                    20.19.1-1nodesource1 600
                    20.19.0-1nodesource1 600
                    20.18.3-1nodesource1 600
                    20.18.2-1nodesource1 600
                    20.18.1-1nodesource1 600
                    20.18.0-1nodesource1 600
                    20.17.0-1nodesource1 600
                    20.16.0-1nodesource1 600
                    20.15.1-1nodesource1 600
                    20.15.0-1nodesource1 600
                    20.14.0-1nodesource1 600
                    20.13.1-1nodesource1 600
                    20.13.0-1nodesource1 600
                    20.12.2-1nodesource1 600
                    20.12.1-1nodesource1 600
                    20.12.0-1nodesource1 600
                    20.11.1-1nodesource1 600
                    20.11.0-1nodesource1 600
                    20.10.0-1nodesource1 600
                    20.9.0-1nodesource1 600
                    20.8.1-1nodesource1 600
                    20.8.0-1nodesource1 600
                    20.7.0-1nodesource1 600
                    20.6.1-1nodesource1 600
                    20.6.0-1nodesource1 600
                    20.5.1-1nodesource1 600
                    20.5.0-1nodesource1 600
                    20.4.0-1nodesource1 600
                    20.3.1-1nodesource1 600
                    20.3.0-1nodesource1 600
                    20.2.0-1nodesource1 600
                    20.1.0-1nodesource1 600
                    20.0.0-1nodesource1 600
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                Hosts:
                iobroker            iobroker (version: 7.0.7, hostname: iobroker      , alive, uptime: 213)
                admin:          7.7.22
                javascript:     9.0.11
                nodejs modules from github:     0
                Adapter State
                + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
                + system.adapter.awtrix-light.0           : awtrix-light          : iobroker                                 -  enabled
                + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
                 system.adapter.daswetter.0              : daswetter             : iobroker                                 - disabled
                + system.adapter.denon.0                  : denon                 : iobroker                                 -  enabled
                 system.adapter.devices.0                : devices               : iobroker                                 -  enabled
                + system.adapter.discord.0                : discord               : iobroker                                 -  enabled
                + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
                 system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker                                 - disabled
                + system.adapter.fronius.0                : fronius               : iobroker                                 -  enabled
                + system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled
                + system.adapter.history.0                : history               : iobroker                                 -  enabled
                + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
                + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled
                 system.adapter.homeconnect.0            : homeconnect           : iobroker                                 - disabled
                 system.adapter.icons-eclipse-smarthome-classic.0: icons-eclipse-smarthome-classic: iobroker                                 -  enabled
                 system.adapter.icons-freepic.0          : icons-freepic         : iobroker                                 -  enabled
                 system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 -  enabled
                 system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 -  enabled
                 system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
                 system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker                                 -  enabled
                 system.adapter.influxdb.0               : influxdb              : iobroker                                 - disabled, port: 8086
                + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
                + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                + system.adapter.lgtv.0                   : lgtv                  : iobroker                                 -  enabled
                + system.adapter.moma.0                   : moma                  : iobroker                                 -  enabled
                + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                + system.adapter.mytime.0                 : mytime                : iobroker                                 -  enabled
                + system.adapter.nanoleaf-lightpanels.0   : nanoleaf-lightpanels  : iobroker                                 -  enabled, port: 16021
                + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
                 system.adapter.sayit.0                  : sayit                 : iobroker                                 - disabled
                + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                + system.adapter.statistics.0             : statistics            : iobroker                                 -  enabled
                 system.adapter.tr-064.0                 : tr-064                : iobroker                                 - disabled
                + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
                 system.adapter.vis-2-widgets-collection.0: vis-2-widgets-collection: iobroker                                 -  enabled
                 system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : iobroker                                 -  enabled
                 system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : iobroker                                 -  enabled
                 system.adapter.vis-2-widgets-icontwo.0  : vis-2-widgets-icontwo : iobroker                                 -  enabled
                 system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: iobroker                                 -  enabled
                 system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker                                 -  enabled
                 system.adapter.vis-2-widgets-radar-trap.0: vis-2-widgets-radar-trap: iobroker                                 -  enabled
                + system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
                 system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 -  enabled
                 system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 -  enabled
                + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.178.67:6638
                 system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : iobroker                                 - disabled
                + instance is alive
                Adapter    "admin"        : 7.7.22   , installed 7.7.22
                Adapter    "alexa2"       : 3.27.4   , installed 3.27.4
                Adapter    "backitup"     : 3.3.13   , installed 3.3.13
                Adapter    "daswetter"    : 3.2.8    , installed 3.2.8
                Adapter    "denon"        : 1.15.12  , installed 1.15.12
                Adapter    "devices"      : 1.2.8    , installed 1.2.9
                Adapter    "discord"      : 2.6.1    , installed 2.6.1
                Adapter    "echarts"      : 1.9.2    , installed 1.9.2
                Adapter    "fronius"      : 2.1.1    , installed 2.1.1
                Adapter    "fullybrowser" : 3.1.2    , installed 3.1.2
                Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
                Adapter    "homeconnect"  : 1.5.2    , installed 1.5.2
                Adapter    "icons-eclipse-smarthome-classic": 1.0.0, installed 1.0.0
                Adapter    "icons-freepic": 1.0.0    , installed 1.0.0
                Adapter    "icons-material-png": 0.1.0, installed 0.1.0
                Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
                Adapter    "icons-ultimate-png": 1.0.1, installed 1.0.1
                Adapter    "iot"          : 5.0.7    , installed 5.0.7
                Adapter    "lgtv"         : 2.5.0    , installed 2.5.0
                Adapter    "moma"         : 1.2.9    , installed 1.2.9
                Adapter    "mytime"       : 2.3.2    , installed 2.3.2
                Adapter    "nanoleaf-lightpanels": 1.4.0, installed 1.4.0
                Adapter    "ping"         : 1.7.9    , installed 1.7.9
                Adapter    "sayit"        : 5.0.0    , installed 5.0.0
                Adapter    "shelly"       : 10.5.2   , installed 10.5.2
                Adapter    "socketio"     : 6.7.1    , installed 7.0.8
                Adapter    "vis-2"        : 2.13.4   , installed 2.13.4
                Adapter    "vis-2-widgets-collection": 1.8.1, installed 1.8.1
                Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
                Adapter    "vis-2-widgets-gauges": 2.0.1, installed 2.0.1
                Adapter    "vis-2-widgets-icontwo": 1.25.0, installed 1.25.0
                Adapter    "vis-2-widgets-inventwo": 0.5.5, installed 0.5.5
                Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
                Adapter    "vis-2-widgets-radar-trap": 2.3.0, installed 2.3.0
                Adapter    "vis-google-fonts": 1.0.4 , installed 1.0.4
                Adapter    "vis-icontwo"  : 1.18.0   , installed 1.18.0
                Adapter    "zigbee2mqtt"  : 3.0.10   , installed 3.0.10
                Objects and States
                Objects:        4557
                States:         2678
                W: https://deb.nodesource.com/node_20.x/dists/nodistro/InRelease: Policy will reject signature within a year, see --audit for details
                Hit:1 http://archive.raspberrypi.com/debian trixie InRelease
                Hit:2 http://deb.debian.org/debian trixie InRelease
                Hit:3 http://security.debian.org/debian-security trixie-security InRelease
                Hit:4 https://repos.influxdata.com/debian stable InRelease
                Hit:5 https://apt.grafana.com stable InRelease
                Hit:6 http://deb.debian.org/debian trixie-updates InRelease
                Hit:7 https://deb.nodesource.com/node_22.x nodistro InRelease
                Hit:8 https://deb.nodesource.com/node_20.x nodistro InRelease
                Hit:9 https://repo.mosquitto.org/debian trixie InRelease
                Pending Updates: 0
                tcp        0      0 192.168.178.63:42010    0.0.0.0:*               LISTEN      1001       8971       1436/io.hm-rpc.0
                tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          6867       1181/exim4
                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          8546       913/sshd: /usr/sbin
                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       9491       1246/iobroker.js-co
                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       9486       1246/iobroker.js-co
                tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       11711      1774/io.shelly.0
                tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      107        5796       910/mosquitto
                tcp6       0      0 :::8082                 :::*                    LISTEN      1001       11780      1852/io.web.0
                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       9579       1267/io.admin.0
                tcp6       0      0 ::1:25                  :::*                    LISTEN      0          6868       1181/exim4
                tcp6       0      0 :::22                   :::*                    LISTEN      0          8548       913/sshd: /usr/sbin
                tcp6       0      0 :::1883                 :::*                    LISTEN      107        5797       910/mosquitto
                tcp6       0      0 :::5201                 :::*                    LISTEN      109        7844       894/iperf3
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        5624       654/avahi-daemon: r
                udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       14670      2200/io.nanoleaf-li
                udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       12340      1642/io.tuya.0
                udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       12341      1642/io.tuya.0
                udp        0      0 0.0.0.0:40234           0.0.0.0:*                           104        5626       654/avahi-daemon: r
                udp6       0      0 :::5353                 :::*                                104        5625       654/avahi-daemon: r
                udp6       0      0 :::50815                :::*                                104        5627       654/avahi-daemon: r
                2026-01-25 17:46:06.218  - info: iot.0 (2153) Connection changed: connect "raphael_krknjak_outlook_at"
                2026-01-25 17:46:07.990  - info: host.iobroker instance system.adapter.nanoleaf-lightpanels.0 in version "1.4.0" started with pid 2200
                2026-01-25 17:46:08.785  - info: nanoleaf-lightpanels.0 (2200) starting. Version 1.4.0 in /opt/iobroker/node_modules/iobroker.nanoleaf-lightpanels, node: v22.22.0, js-controller: 7.0.7
                2026-01-25 17:46:08.794  - info: nanoleaf-lightpanels.0 (2200) Nanoleaf adapter 'nanoleaf-lightpanels.0' started.
                2026-01-25 17:46:08.796  - info: nanoleaf-lightpanels.0 (2200) Connecting to '192.168.178.73:16021'...
                2026-01-25 17:46:08.836  - info: nanoleaf-lightpanels.0 (2200) Connected to '192.168.178.73:16021'
                2026-01-25 17:46:09.929  - info: shelly.0 (1774) [MQTT] Device with client id "shellypro1-f8b3b77d1de0" connected from 192.168.178.77!
                2026-01-25 17:46:11.008  - info: shelly.0 (1774) [MQTT] Device with client id "shellypro1-f8b3b77d1de0" initialized.
                2026-01-25 17:46:11.103  - info: cloud.0 (1792) Trying to connect as system.user.admin to cloud
                2026-01-25 17:46:11.221  - info: cloud.0 (1792) Connection changed: connect
                2026-01-25 17:46:12.006  - info: host.iobroker instance system.adapter.vis-2.0 in version "2.13.4" started with pid 2269
                2026-01-25 17:46:12.889  - info: vis-2.0 (2269) starting. Version 2.13.4 in /opt/iobroker/node_modules/iobroker.vis-2, node: v22.22.0, js-controller: 7.0.7
                2026-01-25 17:46:13.051  - info: vis-2.0 (2269) vis-2 license is OK.
                2026-01-25 17:46:16.883  - info: vis-google-fonts.0 (2327) starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.vis-google-fonts, node: v22.22.0, js-controller: 7.0.7
                2026-01-25 17:46:17.551  - info: vis-google-fonts.0 (2327) Terminated (NO_ERROR): Without reason
                2026-01-25 17:46:18.111  - info: host.iobroker instance system.adapter.vis-google-fonts.0 terminated while should be started once
                2026-01-25 17:46:19.985  - info: host.iobroker instance system.adapter.mytime.0 in version "2.3.2" started with pid 2394
                2026-01-25 17:46:20.792  - info: mytime.0 (2394) starting. Version 2.3.2 in /opt/iobroker/node_modules/iobroker.mytime, node: v22.22.0, js-controller: 7.0.7
                2026-01-25 17:46:24.025  - info: host.iobroker instance system.adapter.awtrix-light.0 in version "3.0.0" started with pid 2448
                2026-01-25 17:46:25.284  - info: awtrix-light.0 (2448) starting. Version 3.0.0 in /opt/iobroker/node_modules/iobroker.awtrix-light, node: v22.22.0, js-controller: 7.0.7
                2026-01-25 17:46:25.363  - info: awtrix-light.0 (2448) Starting - connecting to http://192.168.178.86:80/
                2026-01-25 17:48:07.785  - info: admin.0 (1267) <== Disconnect system.user.admin from ::ffff:192.168.178.49 admin
                2026-01-25 17:48:07.830  - info: admin.0 (1267) ==> Connected system.user.admin from ::ffff:192.168.178.49
                2026-01-25 17:48:07.852  - info: admin.0 (1267) <== Disconnect system.user.admin from ::ffff:192.168.178.49 admin
                2026-01-25 17:48:08.552  - info: admin.0 (1267) ==> Connected system.user.admin from ::ffff:192.168.178.49
                Beste Grüße!
                io-Broker Neuling 2024 :-)
                Bislang jedoch einiges an Beiträgen und Grundlagen eingeflößt, um etwas besser empor zu irren.
                • F Offline
                  franc
                  #228
                  Hallo, ich hatte diesen Beitrag noch nicht entdeckt, sondern war nach dieser Anleitung: Anleitung zum inoffiziellen Upgrade von Raspberry Pi OS Bookworm zu Trixie: https://forum-raspberrypi.de/forum/thread/64882-anleitung-zum-inoffiziellen-upgrade-von-raspberry-pi-os-bookworm-zu-trixie/ vorgegangen, um meinen Raspberry Pi 5 (8GB) von Bookworm auf Trixie zu aktualisieren.
                  Allerdings hatte ich danach zahlreiche unerfüllte Abhängigkeiten, so dass ich lieber mein Backup (von rpi-clone) genutzt hatte und die Backup-SD umgesteckt.
                  Kann das mit dieser Variante hier auch passieren? Woran könnte es liegen?
                  Den Desktop (die GUI) brauche ich auf jeden Fall auf dem RP5.
                  Danke für Tipps. franc
                  • F franc
                    #229
                    @franc sagte in Upgrade von Debian 12 'Bookworm' auf Debian 13 'Trixie':
                    Möglicherweise.
                    An deinem unnötig komplexen Aufbau der Abhängigkeiten.
                    Macht die Abhängigkeiten halt komplizierter.
                    • hotspot_2H Offline
                      hotspot_2H Offline
                      hotspot_2
                      schrieb am zuletzt editiert von hotspot_2
                      #230
                      Guten Morgen, ich habe bei meinem debian trixie heute morgen Warnungen erhalten. Wollte mal nachfragen ob da Handlungsbedarf besteht.
                      marcus@iobroker:~$ sudo apt update
                      [sudo] password for marcus:
                      Get:1 http://security.debian.org trixie-security InRelease [43.4 kB]
                      Get:3 http://deb.debian.org/debian trixie-updates InRelease [47.3 kB]
                      Get:4 http://security.debian.org trixie-security/main amd64 Packages [100 kB]
                      Get:5 https://packages.grafana.com/oss/deb stable InRelease [7660 B]
                      Get:6 http://security.debian.org trixie-security/main Translation-en [64.2 kB]
                      Get:7 https://packages.grafana.com/oss/deb stable/main amd64 Packages [462 kB]
                      Hit:8 https://deb.nodesource.com/node_22.x nodistro InRelease
                      Err:8 https://deb.nodesource.com/node_22.x nodistro InRelease
                        Sub-process /usr/bin/sqv returned an error code (1), error message is: Signing key on 6F71F525282841EEDAF851B42F59B5F99B1BE0B4 is not bound:            No binding signature at time 2026-01-23T18:12:38Z   because: Policy rejected non-revocation signature (PositiveCertification) requiring second pre-image resistance   because: SHA1 is not considered secure since 2026-02-01T00:00:00Z
                      Fetched 725 kB in 0s (3419 kB/s)
                      All packages are up to date.
                      Warning: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. OpenPGP signature verification failed: https://deb.nodesource.com/node_22.x nodistro InRelease: Sub-process /usr/bin/sqv returned an error code (1), error message is: Signing key on 6F71F525282841EEDAF851B42F59B5F99B1BE0B4 is not bound:            No binding signature at time 2026-01-23T18:12:38Z   because: Policy rejected non-revocation signature (PositiveCertification) requiring second pre-image resistance   because: SHA1 is not considered secure since 2026-02-01T00:00:00Z
                      Warning: Failed to fetch https://deb.nodesource.com/node_22.x/dists/nodistro/InRelease  Sub-process /usr/bin/sqv returned an error code (1), error message is: Signing key on 6F71F525282841EEDAF851B42F59B5F99B1BE0B4 is not bound:            No binding signature at time 2026-01-23T18:12:38Z   because: Policy rejected non-revocation signature (PositiveCertification) requiring second pre-image resistance   because: SHA1 is not considered secure since 2026-02-01T00:00:00Z
                      Warning: Some index files failed to download. They have been ignored, or old ones used instead.
                      • hotspot_2H hotspot_2
                        #231
                        @hotspot_2 sagte in Upgrade von Debian 12 'Bookworm' auf Debian 13 'Trixie':
                        ja!
                        https://forum.iobroker.net/post/1324258
                        • SteffS Offline
                          SteffS Offline
                          Steff
                          #232
                          Vielen Dank für diese Update-Anleitung. Ich konnte damit mein System heute erfolgreich von Bookworm zu Trixie updaten!
                          ioBroker auf Intel NUC 7CJYH / Debian 13 "Trixie" / States & Objects in JSONL / Repo --> Beta / HM CCU2 V2.61.7 / Siemens LOGO! (0BA7 / 0BA8)
                          Admin V7.8.24 / Node V22.22.2 / NPM V10.9.7 / JSC V7.1.2 / JSE V9.2.2
                          • H Offline
                            Hadebe
                            #233
                            ich habe mich mit ThomasBraun Rezept an das Upgrade gewagt. sudo apt upgrade --without-new-pkgs lief noch fehlerfrei. Aber der sudo apt full-upgrade lief in den Error:
                            /tmp/apt-dpkg-install-3wpKJZ/36-pi-greeter_1.2_arm64.deb
                            Nochmal apt update und apt full-upgrade liefert eine endlose Liste mit unmet dependencies und der Empfehlung
                            E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
                            ausgeführt, zwischendurch kommt Fehlermeldung
                            86 upgraded, 96 newly installed, 41 to remove and 330 not upgraded.
                            397 not fully installed or removed.
                            Need to get 0 B/116 MB of archives.
                            After this operation, 180 MB of additional disk space will be used.
                            Do you want to continue? [Y/n] Y
                            Traceback (most recent call last):
                              File "/usr/lib/python3.13/tempfile.py", line 44, in <module>
                                import shutil as _shutil
                            ModuleNotFoundError: No module named 'shutil'
                              File "/usr/bin/apt-listchanges", line 5, in <module>
                                from apt_listchanges.apt_listchanges import main
                              File "/usr/lib/python3/dist-packages/apt_listchanges/apt_listchanges.py", line 33, in <module>
                                import tempfile
                              File "/usr/lib/python3.13/tempfile.py", line 152, in <module>
                                _use_fd_functions = ({os.open, os.stat, os.unlink, os.rmdir} <=
                            NameError: name 'os' is not defined. Did you mean: '_os'? Or did you forget to import 'os'?
                            Extracting templates from packages: 100%
                            und abschließend
                            Ich brauche dringend Unterstützung, bin rat- und hilflos. Wie bekomme ich meinen iob wieder an den Start?
                            • H Hadebe
                                  import tempfile
                              und abschließend
                              #234
                              @Hadebe sagte:
                              Das kommt davon, wenn man da einen Desktop mitschleifft...
                              MACHT MAN NICHT, VERDAMMTE AXT...
                              Schon 1000x gesagt...
                              Wo kommst du mit dem System her?
                              sudo apt update
                              sagt?
                              • H Offline
                                Hadebe
                                #235
                                pi@raspi01:~ $ sudo apt update
                                Hit:1 http://deb.debian.org/debian trixie InRelease
                                Get:2 http://deb.debian.org/debian-security trixie-security InRelease [43.4 kB]
                                Hit:3 http://archive.raspberrypi.com/debian trixie InRelease
                                Hit:4 http://deb.debian.org/debian trixie-updates InRelease
                                Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
                                Fetched 43.4 kB in 0s (95.9 kB/s)
                                Reading package lists... Done
                                Building dependency tree... Done
                                366 packages can be upgraded. Run 'apt list --upgradable' to see them.
                                Kann ich Desktop noch löschen damit alles läuft - wenn das der einzige Grund ist?
                                • H Hadebe
                                      import tempfile
                                  und abschließend
                                  #236
                                  @Hadebe sagte:
                                  lxplug-batt
                                  Schmeiß das raus.
                                  sudo apt remove lxplug-batt
                                  • H Offline
                                    Hadebe
                                    schrieb am zuletzt editiert von Hadebe
                                    #237
                                    pi@raspi01:~ $ sudo apt remove lxplug-batt
                                    You might want to run 'apt --fix-broken install' to correct these.
                                    The following packages have unmet dependencies:
                                     chromium : Depends: libatk-bridge2.0-0t64 (>= 2.5.3) but it is not going to be installed
                                                Depends: libatspi2.0-0t64 (>= 2.9.90) but it is not going to be installed
                                                Depends: libglib2.0-0t64 (>= 2.40.0) but it is not going to be installed
                                     evince : Depends: libglib2.0-0t64 (>= 2.83.0) but it is not going to be installed
                                              Depends: libgtk-3-0t64 (>= 3.22.0) but it is not going to be installed
                                     galculator : Depends: libglib2.0-0t64 (>= 2.16.0) but it is not going to be installed
                                                  Depends: libgtk-3-0t64 (>= 3.3.16) but it is not going to be installed
                                     gcr : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                     gcr4 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                     geany : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                             Depends: libgtk-3-0t64 (>= 3.21.5) but it is not going to be installed
                                     gir1.2-glib-2.0 : Depends: libglib2.0-0t64 (= 2.84.4-3~deb13u3) but it is not going to be installed
                                     gir1.2-gtk-3.0 : Depends: libgtk-3-0t64 (>= 3.24.36-2+rpt1) but it is not going to be installed
                                     girepository-tools : Depends: libglib2.0-0t64 (= 2.84.4-3~deb13u3) but it is not going to be installed
                                     gstreamer1.0-plugins-bad : Depends: libglib2.0-0t64 (>= 2.83.0) but it is not going to be installed
        Depends: libgtk-3-0t64 (>= 3.15.0) but it is not going to be installed
                                     gstreamer1.0-plugins-base : Depends: libglib2.0-0t64 (>= 2.81.1) but it is not going to be installed
                                     gstreamer1.0-plugins-good : Depends: libglib2.0-0t64 (>= 2.81.1) but it is not going to be installed
                                     gtk-nop : Depends: libgtk-3-0t64 (>= 3.24) but it is not going to be installed
                                     gui-pkinst : Depends: libglib2.0-0t64 (>= 2.22.0) but it is not going to be installed
                                     gui-updater : Depends: libglib2.0-0t64 (>= 2.14.0) but it is not going to be installed
                                     gvfs : Depends: libglib2.0-0t64 (>= 2.83.0) but it is not going to be installed
                                     gvfs-backends : Depends: libglib2.0-0t64 (>= 2.83.0) but it is not going to be installed
                                                     Recommends: wsdd but it is not installable
                                     gvfs-daemons : Depends: libglib2.0-0t64 (>= 2.83.0) but it is not going to be installed
                                     gvfs-fuse : Depends: libglib2.0-0t64 (>= 2.83.0) but it is not going to be installed
                                     gvfs-libs : Depends: libglib2.0-0t64 (>= 2.83.0) but it is not going to be installed
                                     libadwaita-1-0 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                     libappstream5 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                     libatk1.0-0t64 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                     libatkmm-1.6-1v5 : Depends: libglib2.0-0t64 (>= 2.34.0) but it is not going to be installed
                                     libavahi-glib1 : Depends: libglib2.0-0t64 (>= 2.16.0) but it is not going to be installed
                                     libavcodec61 : Depends: libglib2.0-0t64 (>= 2.12.0) but it is not going to be installed
                                     libayatana-ido3-0.4-0 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                                             Depends: libgtk-3-0t64 (>= 3.21.4) but it is not going to be installed
                                     libayatana-indicator3-7 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                     libbabeltrace1 : Depends: libglib2.0-0t64 (>= 2.76.0) but it is not going to be installed
                                     libcairo-gobject2 : Depends: libglib2.0-0t64 (>= 2.68.0) but it is not going to be installed
                                     libcamera0.5 : Depends: libcamera-ipa (= 0.5.2+rpt20250903-1~bpo12+1) but 0.7.1+rpt20260609-1 is to be installed
                                     libcloudproviders0 : Depends: libglib2.0-0t64 (>= 2.56.0) but it is not going to be installed
                                     libevdocument3-4t64 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                     libevview3-3t64 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                     libfm-extra4t64 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                     libfm-gtk3-4t64 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                     libfm-modules : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                                     Depends: libgtk-3-0t64 (>= 3.0.0) but it is not going to be installed
                                     libfm4t64 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                     libgck-1-0 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                     libgck-2-2 : Depends: libglib2.0-0t64 (>= 2.74.0) but it is not going to be installed
                                     libgcr-4-4 : Depends: libglib2.0-0t64 (>= 2.74.0) but it is not going to be installed
                                     libgcr-base-3-1 : Depends: libglib2.0-0t64 (>= 2.83.0) but it is not going to be installed
                                     libgcr-ui-3-1 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                     libgio-2.0-dev : Depends: libglib2.0-0t64 (= 2.84.4-3~deb13u3) but it is not going to be installed
                                     libgio-2.0-dev-bin : Depends: libglib2.0-0t64 (= 2.84.4-3~deb13u3) but it is not going to be installed
                                     libgirepository-1.0-1 : Depends: libglib2.0-0t64 (>= 2.82.0) but it is not going to be installed
                                     libgirepository-2.0-0 : Depends: libglib2.0-0t64 (= 2.84.4-3~deb13u3) but it is not going to be installed
                                     libglib2.0-bin : Depends: libglib2.0-0t64 (= 2.84.4-3~deb13u3) but it is not going to be installed
                                     libglibmm-2.4-1t64 : Depends: libglib2.0-0t64 (>= 2.62.0) but it is not going to be installed
                                     libgnome-desktop-3-20t64 : Depends: libglib2.0-0t64 (>= 2.83.0) but it is not going to be installed
        Depends: libgtk-3-0t64 (>= 3.9.10) but it is not going to be installed
                                     libgoa-1.0-0b : Depends: libglib2.0-0t64 (>= 2.83.0) but it is not going to be installed
                                     libgraphene-1.0-0 : Depends: libglib2.0-0t64 (>= 2.14.0) but it is not going to be installed
                                     libgspell-1-3 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                                     Depends: libgtk-3-0t64 (>= 3.20) but it is not going to be installed
                                     libgstreamer-gl1.0-0 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                                            Recommends: gstreamer1.0-gl but it is not going to be installed
                                     libgstreamer-plugins-bad1.0-0 : Depends: libglib2.0-0t64 (>= 2.81.1) but it is not going to be installed
                                     libgstreamer-plugins-base1.0-0 : Depends: libglib2.0-0t64 (>= 2.81.1) but it is not going to be installed
                                     libgstreamer1.0-0 : Depends: libglib2.0-0t64 (>= 2.81.1) but it is not going to be installed
                                     libgtk-4-1 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                                  Recommends: libgtk-4-bin
                                                  Recommends: libgtk-4-media-gstreamer
                                     libgtk-layer-shell0 : Depends: libglib2.0-0t64 (>= 2.42.0) but it is not going to be installed
                                                           Depends: libgtk-3-0t64 (>= 3.24.48) but it is not going to be installed
                                     libgtkmm-3.0-1t64 : Depends: libglib2.0-0t64 (>= 2.42.0) but it is not going to be installed
                                                         Depends: libgtk-3-0t64 (>= 3.24.0) but it is not going to be installed
                                     libgtksourceview-4-0 : Depends: libglib2.0-0t64 (>= 2.48.0) but it is not going to be installed
                                     libgxps2t64 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                     libhandy-1-0 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                                    Depends: libgtk-3-0t64 (>= 3.23.1) but it is not going to be installed
                                     libharfbuzz-gobject0 : Depends: libglib2.0-0t64 (>= 2.14.0) but it is not going to be installed
                                     libharfbuzz0b : Depends: libglib2.0-0t64 (>= 2.32.0) but it is not going to be installed
                                     libinput-tools : Depends: libglib2.0-0t64 (>= 2.30.0) but it is not going to be installed
                                                      Depends: libgtk-3-0t64 (>= 3.19.12) but it is not going to be installed
                                     libinput10 : Depends: libmtdev1t64 (>= 1.1.0) but it is not going to be installed
                                     libjavascriptcoregtk-4.1-0 : Depends: libglib2.0-0t64 (>= 2.66.0) but it is not going to be installed
                                     libkeybinder-3.0-0 : Depends: libglib2.0-0t64 (>= 2.12.0) but it is not going to be installed
                                     libmate-desktop-2-17t64 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                     libmenu-cache-bin : Depends: libglib2.0-0t64 (>= 2.76.0) but it is not going to be installed
                                     libmousepad0 : Depends: libglib2.0-0t64 (>= 2.56.0) but it is not going to be installed
                                     libmsgraph-1-1 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                     libnetplan1 : Depends: libglib2.0-0t64 (>= 2.76.0) but it is not going to be installed
                                     libnm0 : Depends: libglib2.0-0t64 (>= 2.44.0) but it is not going to be installed
                                     libnma0 : Depends: libglib2.0-0t64 (>= 2.38.0) but it is not going to be installed
                                     libpango-1.0-0 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                     libpangocairo-1.0-0 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                     libpangoft2-1.0-0 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                     libpangomm-1.4-1v5 : Depends: libglib2.0-0t64 (>= 2.34.0) but it is not going to be installed
                                     libpangoxft-1.0-0 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                     libpeas-1.0-0 : Depends: libglib2.0-0t64 (>= 2.44.0) but it is not going to be installed
                                     libpipewire-0.3-modules : Depends: libglib2.0-0t64 (>= 2.32.0) but it is not going to be installed
                                     libpoppler-glib8t64 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                     libproxy1v5 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                     libqt5ct-common1.8 : Depends: libqt5core5t64 (>= 5.9~) but it is not going to be installed
                                                          Depends: libqt5gui5t64 (>= 5.9~) but it is not going to be installed or
        libqt5gui5-gles (>= 5.9~) but it is not going to be installed
                                     libqt6core6t64 : Depends: libglib2.0-0t64 (>= 2.26.0) but it is not going to be installed
                                     libqt6gui6 : Depends: libglib2.0-0t64 (>= 2.26.0) but it is not going to be installed
                                                  Depends: libmtdev1t64 (>= 1.0.8) but it is not going to be installed
                                                  Recommends: qt6-svg-plugins but it is not going to be installed
                                                  Recommends: qt6-wayland but it is not going to be installed
                                     libqt6network6 : Depends: libglib2.0-0t64 (>= 2.46.0) but it is not going to be installed
                                     libqt6opengl6 : Depends: libmtdev1t64 (>= 1.0.8) but it is not going to be installed
                                     libsane1 : Depends: libglib2.0-0t64 (>= 2.34.0) but it is not going to be installed
                                     libspa-0.2-bluetooth : Depends: libglib2.0-0t64 (>= 2.83.0) but it is not going to be installed
                                     libudev-dev : Depends: libudev1 (= 257.13-1~deb13u1) but 252.39-1~deb12u2 is to be installed
                                     libvolume-key1 : Depends: libglib2.0-0t64 (>= 2.18.0) but it is not going to be installed
                                     libvte-2.91-0 : Depends: libglib2.0-0t64 (>= 2.78.0) but it is not going to be installed
                                     libwacom9 : Depends: libglib2.0-0t64 (>= 2.68.0) but it is not going to be installed
                                     libwebkit2gtk-4.1-0 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                                           Depends: libgtk-3-0t64 (>= 3.23.0) but it is not going to be installed
                                     libwnck-3-0 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                     libxfce4ui-2-0 : Depends: libglib2.0-0t64 (>= 2.70.0) but it is not going to be installed
                                     libxfce4util7 : Depends: libglib2.0-0t64 (>= 2.70.0) but it is not going to be installed
                                                     Recommends: libxfce4util-bin but it is not going to be installed
                                     libxfconf-0-3 : Depends: libglib2.0-0t64 (>= 2.56.0) but it is not going to be installed
                                     libxmlb2 : Depends: libglib2.0-0t64 (>= 2.54.0) but it is not going to be installed
                                     lightdm-gtk-greeter : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                                           Recommends: gnome-themes-extra but it is not going to be installed
                                     lp-connection-editor : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                     lxpanel : Depends: libfm-gtk4 (>= 1.3.2-1+rpt18) but it is not installable
                                               Depends: lxpanel-data (= 0.10.1-2+rpt22) but 0.11.1-1 is to be installed
                                               Recommends: pavucontrol but it is not going to be installed or
                                                           gnome-alsamixer but it is not installable
                                               Recommends: libnotify-bin but it is not going to be installed
                                     lxtask : Depends: libglib2.0-0t64 (>= 2.14.0) but it is not going to be installed
                                     lxterminal : Depends: libglib2.0-0t64 (>= 2.28.0) but it is not going to be installed
                                     mate-polkit : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                                   Depends: libgtk-3-0t64 (>= 3.16.2) but it is not going to be installed
                                     mousepad : Depends: libglib2.0-0t64 (>= 2.38.0) but it is not going to be installed
                                                Depends: libgtk-3-0t64 (>= 3.13.7) but it is not going to be installed
                                     netplan-generator : Depends: libglib2.0-0t64 (>= 2.70.0) but it is not going to be installed
                                     netplan.io : Depends: libglib2.0-0t64 (>= 2.70.0) but it is not going to be installed
                                                  Recommends: python3-rich but it is not going to be installed
                                     network-manager : Depends: libglib2.0-0t64 (>= 2.68.0) but it is not going to be installed
                                                       Recommends: network-manager-l10n but it is not going to be installed
                                     notification-daemon : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                     obconf : Depends: libglib2.0-0t64 (>= 2.36.0) but it is not going to be installed
                                     openssh-sftp-server : Depends: openssh-client (= 1:9.2p1-2+deb12u10)
                                     pango1.0-tools : Depends: libglib2.0-0t64 (>= 2.80) but it is not going to be installed
                                     pcmanfm : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                     pi-package : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                     pi-package-session : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                     piclone : Depends: libglib2.0-0t64 (>= 2.32.0) but it is not going to be installed
                                     pipanel : Depends: libglib2.0-0t64 (>= 2.36.0) but it is not going to be installed
                                     pishutdown : Depends: libglib2.0-0t64 (>= 2.26.0) but it is not going to be installed
                                     piwiz : Depends: libglib2.0-0t64 (>= 2.32.0) but it is not going to be installed
                                     python3-dbus : Depends: libglib2.0-0t64 (>= 2.16.0) but it is not going to be installed
                                     python3-gi : Depends: libglib2.0-0t64 (>= 2.78.0) but it is not going to be installed
                                     python3-pyqt5 : Depends: libqt5printsupport5 (>= 5.15)
                                     qt5-gtk-platformtheme : Depends: libglib2.0-0t64 (>= 2.34.0) but it is not going to be installed
                                                             Depends: libqt5core5t64 (>= 5.15.1) but it is not going to be installed
                                                             Depends: libqt5dbus5t64 (>= 5.14.1) but it is not going to be installed
                                                             Depends: libqt5gui5t64 (>= 5.14.1) but it is not going to be installed or
        libqt5gui5-gles (>= 5.14.1) but it is not going to be installed
                                                             Depends: qtbase-abi-5-15-15
                                     qt6-gtk-platformtheme : Depends: libglib2.0-0t64 (>= 2.34.0) but it is not going to be installed
                                     raindrop : Depends: libglib2.0-0t64 (>= 2.40.0) but it is not going to be installed
                                     rasputin : Depends: libglib2.0-0t64 (>= 2.26.0) but it is not going to be installed
                                     rc-gui : Depends: libglib2.0-0t64 (>= 2.32.0) but it is not going to be installed
                                     rp-bookshelf : Depends: libglib2.0-0t64 (>= 2.36.0) but it is not going to be installed
                                     rp-prefapps : Depends: libglib2.0-0t64 (>= 2.26.0) but it is not going to be installed
                                     sudopwd : Depends: libglib2.0-0t64 (>= 2.32.0) but it is not going to be installed
                                     vlc : Depends: vlc-bin (= 1:3.0.23-0+deb13u1+rpt2) but 1:3.0.23-0+deb12u1+rpt1 is to be installed
                                           Depends: vlc-plugin-qt (= 1:3.0.23-0+deb13u1+rpt2) but 1:3.0.23-0+deb12u1+rpt1 is to be installed
                                           Recommends: vlc-plugin-notify (= 1:3.0.23-0+deb13u1+rpt2) but 1:3.0.23-0+deb12u1+rpt1 is to be installed
                                     vlc-plugin-access-extra : Depends: vlc-plugin-abi-3-0-0ft64
                                     vlc-plugin-base : Depends: libaribb24-0t64 (>= 1.0.3) but it is not going to be installed
                                                       Depends: libixml11t64 (>= 1:1.14.0) but it is not going to be installed
                                                       Depends: liblirc-client0t64 (>= 0.10.2) but it is not going to be installed
                                                       Depends: libprotobuf-lite32t64 (>= 3.21.12) but it is not going to be installed
                                                       Depends: libspatialaudio0t64 (>= 0.3.0+git20180730+dfsg1) but it is not going to be installed
                                                       Depends: libupnp17t64 (>= 1:1.14.0) but it is not going to be installed
                                     vlc-plugin-samba : Depends: vlc-plugin-abi-3-0-0ft64
                                     vlc-plugin-skins2 : Depends: vlc-plugin-qt (= 1:3.0.23-0+deb13u1+rpt2) but 1:3.0.23-0+deb12u1+rpt1 is to be installed
                                     vlc-plugin-video-output : Depends: vlc-plugin-abi-3-0-0ft64
                                     vlc-plugin-video-splitter : Depends: vlc-plugin-abi-3-0-0ft64
                                     vlc-plugin-visualization : Depends: vlc-plugin-abi-3-0-0ft64
                                     wayfire : Depends: libglib2.0-0t64 (>= 2.12.0) but it is not going to be installed
                                     wf-panel-pi : Depends: libglib2.0-0t64 (>= 2.74.0) but it is not going to be installed
                                                   Recommends: wfplug-clock but it is not going to be installed
                                     wfplug-batt : Depends: libglib2.0-0t64 (>= 2.16.0) but it is not going to be installed
                                     wfplug-bluetooth : Depends: libglib2.0-0t64 (>= 2.30.0) but it is not going to be installed
                                     wfplug-connect : Depends: libglib2.0-0t64 (>= 2.28.0) but it is not going to be installed
                                     wfplug-cpu : Depends: libglib2.0-0t64 (>= 2.12.0) but it is not going to be installed
                                     wfplug-cputemp : Depends: libglib2.0-0t64 (>= 2.12.0) but it is not going to be installed
                                     wfplug-ejecter : Depends: libglib2.0-0t64 (>= 2.28.0) but it is not going to be installed
                                     wfplug-gpu : Depends: libglib2.0-0t64 (>= 2.12.0) but it is not going to be installed
                                     wfplug-menu : Depends: libglib2.0-0t64 (>= 2.36.0) but it is not going to be installed
                                     wfplug-netman : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                     wfplug-power : Depends: libglib2.0-0t64 (>= 2.36.0) but it is not going to be installed
                                     wfplug-squeek : Depends: libglib2.0-0t64 (>= 2.26.0) but it is not going to be installed
                                     wfplug-updater : Depends: libglib2.0-0t64 (>= 2.32.0) but it is not going to be installed
                                     wfplug-volumepulse : Depends: libglib2.0-0t64 (>= 2.30.0) but it is not going to be installed
                                     xarchiver : Depends: libglib2.0-0t64 (>= 2.76.0) but it is not going to be installed
                                                 Recommends: 7zip but it is not going to be installed
                                     xdg-desktop-portal-gtk : Depends: libglib2.0-0t64 (>= 2.83.0) but it is not going to be installed
                                     xfconf : Depends: libglib2.0-0t64 (>= 2.56.0) but it is not going to be installed
                                     zenity : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                     zenoty : Depends: libglib2.0-0t64 (>= 2.12.0) but it is not going to be installed
                                    E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).```
                                    code_text
                                    • H Hadebe
                                      code_text
                                      #238
                                      @Hadebe
                                      Alles GUI-Gedrisse...
                                      Versuch es damit:
                                      sudo apt purge xserver* lightdm* raspberrypi-ui-mods vlc* lxde* chromium* desktop* gnome* gstreamer* gtk* hicolor-icon-theme* lx* mesa*
                                      • H Offline
                                        Hadebe
                                        #239
                                        sieht für mich nicht besser aus
                                        pi@raspi01:~ $ sudo apt purge xserver* lightdm* raspberrypi-ui-mods vlc* lxde* chromium* desktop* gnome* gstreamer* gtk* hicolor-icon-theme* lx* mesa*
                                        Note, selecting 'xserver-xorg-video-nouveau' for glob 'xserver*'
                                        Note, selecting 'xserver-xorg-input-evdev' for glob 'xserver*'
                                        Note, selecting 'xserver-xorg-video-fbturbo-dbgsym' for glob 'xserver*'
                                        Note, selecting 'xserver-xorg-input-mouse' for glob 'xserver*'
                                        Note, selecting 'xserver-xorg-input-evtouch' for glob 'xserver*'
                                        Note, selecting 'xserver-xorg-video-amdgpu' for glob 'xserver*'
                                        Note, selecting 'xserver-xorg-video-mach64' for glob 'xserver*'
                                        Note, selecting 'xserver-xorg-core' for glob 'xserver*'
                                        Note, selecting 'xserver-xephyr-dbgsym' for glob 'xserver*'
                                        Note, selecting 'xserver-xorg-video-fbturbo' for glob 'xserver*'
                                        Note, selecting 'xserver-xorg-video-modesetting' for glob 'xserver*'
                                        Note, selecting 'xserver-x2gokdrive' for glob 'xserver*'
                                        Note, selecting 'xserver-xorg-input-all' for glob 'xserver*'
                                        Note, selecting 'xserver-xorg-video-intel' for glob 'xserver*'
                                        Note, selecting 'xserver-xorg-input-kbd' for glob 'xserver*'
                                        Note, selecting 'xserver-xorg-video-r128' for glob 'xserver*'
                                        Note, selecting 'xserver-xorg' for glob 'xserver*'
                                        Note, selecting 'xserver-xorg-input-joystick' for glob 'xserver*'
                                        Note, selecting 'xserver-xorg-input-xwiimote' for glob 'xserver*'
                                        Note, selecting 'xserver-xorg-video-vesa' for glob 'xserver*'
                                        Note, selecting 'xserver-xorg-input-elographics' for glob 'xserver*'
                                        Note, selecting 'xserver-xorg-video-dummy' for glob 'xserver*'
                                        Note, selecting 'xserver-xorg-input-aiptek' for glob 'xserver*'
                                        Note, selecting 'xserver-xorg-legacy' for glob 'xserver*'
                                        Note, selecting 'xserver-xorg-video-nvidia-any' for glob 'xserver*'
                                        Note, selecting 'xserver-common' for glob 'xserver*'
                                        Note, selecting 'xserver-xorg-video-radeon' for glob 'xserver*'
                                        Note, selecting 'xserver-xorg-input-synaptics' for glob 'xserver*'
                                        Note, selecting 'xserver-xorg-dev' for glob 'xserver*'
                                        Note, selecting 'xserver-xorg-video-vmware' for glob 'xserver*'
                                        Note, selecting 'xserver-xorg-video-neomagic' for glob 'xserver*'
                                        Note, selecting 'xserver-xorg-input-mtrack' for glob 'xserver*'
                                        Note, selecting 'xserver-xorg-input-libinput' for glob 'xserver*'
                                        Note, selecting 'xserver-xorg-video-siliconmotion' for glob 'xserver*'
                                        Note, selecting 'xserver-xorg-input-evdev-dev' for glob 'xserver*'
                                        Note, selecting 'xserver-xorg-video-sisusb' for glob 'xserver*'
                                        Note, selecting 'xserver-xorg-video-cirrus' for glob 'xserver*'
                                        Note, selecting 'xserver-xorg-input-wacom' for glob 'xserver*'
                                        Note, selecting 'xserver' for glob 'xserver*'
                                        Note, selecting 'xserver-xorg-core-dbgsym' for glob 'xserver*'
                                        Note, selecting 'xserver-xephyr' for glob 'xserver*'
                                        Note, selecting 'xserver-xorg-driver-all' for glob 'xserver*'
                                        Note, selecting 'xserver-xorg-input-joystick-dev' for glob 'xserver*'
                                        Note, selecting 'xserver-xorg-video-nvidia-tesla-535' for glob 'xserver*'
                                        Note, selecting 'xserver-xorg-legacy-dbgsym' for glob 'xserver*'
                                        Note, selecting 'xserver-xorg-input-libinput-dev' for glob 'xserver*'
                                        Note, selecting 'xserver-xorg-video-savage' for glob 'xserver*'
                                        Note, selecting 'xserver-xorg-input-synaptics-dev' for glob 'xserver*'
                                        Note, selecting 'xserver-xorg-video-all' for glob 'xserver*'
                                        Note, selecting 'xserver-xorg-video-ast' for glob 'xserver*'
                                        Note, selecting 'xserver-xorg-video-ati' for glob 'xserver*'
                                        Note, selecting 'xserver-xorg-video-fbdev' for glob 'xserver*'
                                        Note, selecting 'xserver-xorg-video-nvidia' for glob 'xserver*'
                                        Note, selecting 'xserver-xorg-video-nvidia-legacy-304xx' for glob 'xserver*'
                                        Note, selecting 'xserver-xorg-input-multitouch' for glob 'xserver*'
                                        Note, selecting 'xserver-xorg-video-mga' for glob 'xserver*'
                                        Note, selecting 'xserver-xorg-video-qxl' for glob 'xserver*'
                                        Package 'xserver-xorg-video-vmware' is not installed, so not removed
                                        Package 'xserver-xorg-video-intel' is not installed, so not removed
                                        Package 'xserver-xorg-driver-all' is not installed, so not removed
                                        Package 'xserver-xorg-input-evtouch' is not installed, so not removed
                                        Note, selecting 'xserver-xorg-core' instead of 'xserver-xorg-video-modesetting'
                                        Package 'xserver-xorg-video-nvidia-legacy-304xx' is not installed, so not removed
                                        Package 'xserver-xorg-video-ast' is not installed, so not removed
                                        Note, selecting 'lightdm-dbgsym' for glob 'lightdm*'
                                        Note, selecting 'lightdm-gtk-greeter-settings' for glob 'lightdm*'
                                        Note, selecting 'lightdm-autologin-greeter' for glob 'lightdm*'
                                        Note, selecting 'lightdm-gtk-greeter' for glob 'lightdm*'
                                        Note, selecting 'lightdm' for glob 'lightdm*'
                                        Note, selecting 'lightdm-remote-session-x2go' for glob 'lightdm*'
                                        Note, selecting 'lightdm-greeter' for glob 'lightdm*'
                                        Note, selecting 'lightdm-vala' for glob 'lightdm*'
                                        Note, selecting 'lightdm-settings' for glob 'lightdm*'
                                        Note, selecting 'vlc-plugin-qt' for glob 'vlc*'
                                        Note, selecting 'vlc-plugin-samba-dbgsym' for glob 'vlc*'
                                        Note, selecting 'vlc-data' for glob 'vlc*'
                                        Note, selecting 'vlc-plugin-abi-3-0-0ft64' for glob 'vlc*'
                                        Note, selecting 'vlc-bin-dbgsym' for glob 'vlc*'
                                        Note, selecting 'vlc-plugin-bittorrent' for glob 'vlc*'
                                        Note, selecting 'vlc-plugin-jack-dbgsym' for glob 'vlc*'
                                        Note, selecting 'vlc' for glob 'vlc*'
                                        Note, selecting 'vlc-bin' for glob 'vlc*'
                                        Note, selecting 'vlc-l10n' for glob 'vlc*'
                                        Note, selecting 'vlc-plugin-bittorent' for glob 'vlc*'
                                        Note, selecting 'vlc-plugin-pipewire' for glob 'vlc*'
                                        Note, selecting 'vlc-plugin-video-output-dbgsym' for glob 'vlc*'
                                        Note, selecting 'vlc-plugin-jack' for glob 'vlc*'
                                        Note, selecting 'vlc-plugin-samba' for glob 'vlc*'
                                        Note, selecting 'vlc-plugin-qt-dbgsym' for glob 'vlc*'
                                        Note, selecting 'vlc-plugin-access-extra-dbgsym' for glob 'vlc*'
                                        Note, selecting 'vlc-plugin-notify' for glob 'vlc*'
                                        Note, selecting 'vlc-plugin-fluidsynth' for glob 'vlc*'
                                        Note, selecting 'vlc-plugin-visualization-dbgsym' for glob 'vlc*'
                                        Note, selecting 'vlc-plugin-abi-3-0-0f' for glob 'vlc*'
                                        Note, selecting 'vlc-plugin-fluidsynth-dbgsym' for glob 'vlc*'
                                        Note, selecting 'vlc-plugin-access-extra' for glob 'vlc*'
                                        Note, selecting 'vlc-plugin-notify-dbgsym' for glob 'vlc*'
                                        Note, selecting 'vlc-plugin-skins2' for glob 'vlc*'
                                        Note, selecting 'vlc-plugin-svg' for glob 'vlc*'
                                        Note, selecting 'vlc-plugin-video-splitter' for glob 'vlc*'
                                        Note, selecting 'vlc-plugin-video-output' for glob 'vlc*'
                                        Note, selecting 'vlc-plugin-svg-dbgsym' for glob 'vlc*'
                                        Note, selecting 'vlc-plugin-base-dbgsym' for glob 'vlc*'
                                        Note, selecting 'vlc-plugin-skins2-dbgsym' for glob 'vlc*'
                                        Note, selecting 'vlc-plugin-video-splitter-dbgsym' for glob 'vlc*'
                                        Note, selecting 'vlc-plugin-base' for glob 'vlc*'
                                        Note, selecting 'vlc-plugin-visualization' for glob 'vlc*'
                                        Package 'vlc-plugin-bittorent' is not installed, so not removed
                                        Note, selecting 'libvlccore9' instead of 'vlc-plugin-abi-3-0-0ft64'
                                        Note, selecting 'lxde-settings-daemon-dbgsym' for glob 'lxde*'
                                        Note, selecting 'lxde-common' for glob 'lxde*'
                                        Note, selecting 'lxde-core' for glob 'lxde*'
                                        Note, selecting 'lxde' for glob 'lxde*'
                                        Note, selecting 'lxde-icon-theme' for glob 'lxde*'
                                        Note, selecting 'lxde-settings-daemon' for glob 'lxde*'
                                        Note, selecting 'lxde-session' for glob 'lxde*'
                                        Note, selecting 'openbox-lxde-session' instead of 'lxde-session'
                                        Note, selecting 'chromium-bsu' for glob 'chromium*'
                                        Note, selecting 'chromium-sandbox' for glob 'chromium*'
                                        Note, selecting 'chromium-codecs-ffmpeg-extra:armhf' for glob 'chromium*'
                                        Note, selecting 'chromium-shell-dbgsym' for glob 'chromium*'
                                        Note, selecting 'chromium-driver' for glob 'chromium*'
                                        Note, selecting 'chromium-shell' for glob 'chromium*'
                                        Note, selecting 'chromium-dbgsym' for glob 'chromium*'
                                        Note, selecting 'chromium-sandbox-dbgsym' for glob 'chromium*'
                                        Note, selecting 'chromium' for glob 'chromium*'
                                        Note, selecting 'chromium-headless-shell' for glob 'chromium*'
                                        Note, selecting 'chromium-data' for glob 'chromium*'
                                        Note, selecting 'chromium-browser' for glob 'chromium*'
                                        Note, selecting 'chromium-chromedriver' for glob 'chromium*'
                                        Note, selecting 'chromium-lwn4chrome' for glob 'chromium*'
                                        Note, selecting 'chromium-l10n' for glob 'chromium*'
                                        Note, selecting 'chromium-common' for glob 'chromium*'
                                        Note, selecting 'chromium-headless-shell-dbgsym' for glob 'chromium*'
                                        Note, selecting 'chromium-common-dbgsym' for glob 'chromium*'
                                        Note, selecting 'chromium-tt-rss-notifier' for glob 'chromium*'
                                        Note, selecting 'chromium-bsu-data' for glob 'chromium*'
                                        Note, selecting 'chromium-browser-l10n' for glob 'chromium*'
                                        Package 'chromium-tt-rss-notifier' is not installed, so not removed
                                        Package 'chromium-data' is not installed, so not removed
                                        Package 'chromium-codecs-ffmpeg-extra:armhf' is not installed, so not removed
                                        Note, selecting 'desktop-base' for glob 'desktop*'
                                        Note, selecting 'desktop-autoloader' for glob 'desktop*'
                                        Note, selecting 'desktop-file-utils' for glob 'desktop*'
                                        Note, selecting 'desktopfolder' for glob 'desktop*'
                                        Note, selecting 'gnome-shell-extension-dashtodock' for glob 'gnome*'
                                        Note, selecting 'gnome-text-editor' for glob 'gnome*'
                                        Note, selecting 'gnome-shell-extension-dash-to-dock' for glob 'gnome*'
                                        Note, selecting 'gnomekiss' for glob 'gnome*'
                                        Note, selecting 'gnome-kiosk-script-session' for glob 'gnome*'
                                        Note, selecting 'gnome-shell-extension-light-style' for glob 'gnome*'
                                        Note, selecting 'gnome-shell-extension-launch-new-instance' for glob 'gnome*'
                                        Note, selecting 'gnome-shell-pomodoro-data' for glob 'gnome*'
                                        Note, selecting 'gnome-user-docs' for glob 'gnome*'
                                        Note, selecting 'gnome-wine-icon-theme' for glob 'gnome*'
                                        Note, selecting 'gnome-power-manager' for glob 'gnome*'
                                        Note, selecting 'gnome-panel' for glob 'gnome*'
                                        Note, selecting 'gnome-shell-extension-hard-disk-led' for glob 'gnome*'
                                        Note, selecting 'gnome-video-effects-frei0r' for glob 'gnome*'
                                        Note, selecting 'gnome-breakout' for glob 'gnome*'
                                        Note, selecting 'gnome-sound-recorder' for glob 'gnome*'
                                        Note, selecting 'gnome-sudoku' for glob 'gnome*'
                                        Note, selecting 'gnome-themes-standard-data' for glob 'gnome*'
                                        Note, selecting 'gnome-software-plugin' for glob 'gnome*'
                                        Note, selecting 'gnome-font-viewer' for glob 'gnome*'
                                        Note, selecting 'gnome-online-accounts-gtk' for glob 'gnome*'
                                        Note, selecting 'gnome-shell-extension-workspace-indicator' for glob 'gnome*'
                                        Note, selecting 'gnome-human-icon-theme' for glob 'gnome*'
                                        Note, selecting 'gnome-software' for glob 'gnome*'
                                        Note, selecting 'gnome-alsamixer' for glob 'gnome*'
                                        Note, selecting 'gnome-software-plugin-fwupd' for glob 'gnome*'
                                        Note, selecting 'gnome-initial-setup' for glob 'gnome*'
                                        Note, selecting 'gnome-user-share' for glob 'gnome*'
                                        Note, selecting 'gnome-weather' for glob 'gnome*'
                                        Note, selecting 'gnome-session-flashback' for glob 'gnome*'
                                        Note, selecting 'gnome-klotski' for glob 'gnome*'
                                        Note, selecting 'gnome-software-common' for glob 'gnome*'
                                        Note, selecting 'gnome-commander' for glob 'gnome*'
                                        Note, selecting 'gnome-mplayer' for glob 'gnome*'
                                        Note, selecting 'gnome-video-arcade' for glob 'gnome*'
                                        Note, selecting 'gnome-shell-extension-taskbar' for glob 'gnome*'
                                        Note, selecting 'gnome-shell-extension-runcat' for glob 'gnome*'
                                        Note, selecting 'gnome-shell-extension-tiling-assistant' for glob 'gnome*'
                                        Note, selecting 'gnome-ponytail-daemon' for glob 'gnome*'
                                        Note, selecting 'gnome-themes-extras' for glob 'gnome*'
                                        Note, selecting 'gnome-bluetooth-3-common' for glob 'gnome*'
                                        Note, selecting 'gnome-applets-data' for glob 'gnome*'
                                        Note, selecting 'gnome-nibbles' for glob 'gnome*'
                                        Note, selecting 'gnome-shell-extension-gpaste' for glob 'gnome*'
                                        Note, selecting 'gnome-audio' for glob 'gnome*'
                                        Note, selecting 'gnome-network-displays' for glob 'gnome*'
                                        Note, selecting 'gnome-color-manager' for glob 'gnome*'
                                        Note, selecting 'gnome-connections' for glob 'gnome*'
                                        Note, selecting 'gnome-games-app' for glob 'gnome*'
                                        Note, selecting 'gnome-desktop-3-tests' for glob 'gnome*'
                                        Note, selecting 'gnome-shell-extension-native-window-placement' for glob 'gnome*'
                                        Note, selecting 'gnome-icon-theme-yasis' for glob 'gnome*'
                                        Note, selecting 'gnome-shell-extensions-extra' for glob 'gnome*'
                                        Note, selecting 'gnome-shell-extension-gsconnect-browsers' for glob 'gnome*'
                                        Note, selecting 'gnome-dictionary' for glob 'gnome*'
                                        Note, selecting 'gnome-boxes' for glob 'gnome*'
                                        Note, selecting 'gnome-software-plugin-deb' for glob 'gnome*'
                                        Note, selecting 'gnome-shell-extension-vertical-workspaces' for glob 'gnome*'
                                        Note, selecting 'gnome-control-center-signon' for glob 'gnome*'
                                        Note, selecting 'gnome-shell-extension-kimpanel' for glob 'gnome*'
                                        Note, selecting 'gnome-session-bin' for glob 'gnome*'
                                        Note, selecting 'gnome-flashback-common' for glob 'gnome*'
                                        Note, selecting 'gnome-shell-extension-middleclickclose' for glob 'gnome*'
                                        Note, selecting 'gnome-shell-extension-auto-move-windows' for glob 'gnome*'
                                        Note, selecting 'gnome-shell-pomodoro' for glob 'gnome*'
                                        Note, selecting 'gnome-tweaks' for glob 'gnome*'
                                        Note, selecting 'gnome-shell-extension-window-list' for glob 'gnome*'
                                        Note, selecting 'gnome-system-monitor' for glob 'gnome*'
                                        Note, selecting 'gnome-panel-data' for glob 'gnome*'
                                        Note, selecting 'gnome-noble-icon-theme' for glob 'gnome*'
                                        Note, selecting 'gnome-shell-extension-apps-menu' for glob 'gnome*'
                                        Note, selecting 'gnome-shell-extension-disable-workspace-switcher' for glob 'gnome*'
                                        Note, selecting 'gnome' for glob 'gnome*'
                                        Note, selecting 'gnome-cards-data' for glob 'gnome*'
                                        Note, selecting 'gnome-remote-desktop' for glob 'gnome*'
                                        Note, selecting 'gnome-tweak-tool' for glob 'gnome*'
                                        Note, selecting 'gnome-applets' for glob 'gnome*'
                                        Note, selecting 'gnome-icon-theme' for glob 'gnome*'
                                        Note, selecting 'gnome-colors-common' for glob 'gnome*'
                                        Note, selecting 'gnome-icon-theme-full' for glob 'gnome*'
                                        Note, selecting 'gnome-power-statistics' for glob 'gnome*'
                                        Note, selecting 'gnome-pass-search-provider' for glob 'gnome*'
                                        Note, selecting 'gnome-shell-extension-easyscreencast' for glob 'gnome*'
                                        Note, selecting 'gnome-kiosk' for glob 'gnome*'
                                        Note, selecting 'gnome-shell-extension-flypie' for glob 'gnome*'
                                        Note, selecting 'gnome-calendar' for glob 'gnome*'
                                        Note, selecting 'gnome-screensaver' for glob 'gnome*'
                                        Note, selecting 'gnome-shell-extensions' for glob 'gnome*'
                                        Note, selecting 'gnome-panel-control-dbgsym' for glob 'gnome*'
                                        Note, selecting 'gnome-shell' for glob 'gnome*'
                                        Note, selecting 'gnome-shell-extension-status-icons' for glob 'gnome*'
                                        Note, selecting 'gnome-mime-data' for glob 'gnome*'
                                        Note, selecting 'gnome-shell-extension-weather' for glob 'gnome*'
                                        Note, selecting 'gnome-classic' for glob 'gnome*'
                                        Note, selecting 'gnome-settings-daemon-common' for glob 'gnome*'
                                        Note, selecting 'gnome-software-dev' for glob 'gnome*'
                                        Note, selecting 'gnome-software-doc' for glob 'gnome*'
                                        Note, selecting 'gnome-feeds' for glob 'gnome*'
                                        Note, selecting 'gnome-session-xsession' for glob 'gnome*'
                                        Note, selecting 'gnome-mines' for glob 'gnome*'
                                        Note, selecting 'gnome-icon-theme-gartoon' for glob 'gnome*'
                                        Note, selecting 'gnome-usage' for glob 'gnome*'
                                        Note, selecting 'gnome-software-plugin-snap' for glob 'gnome*'
                                        Note, selecting 'gnome-logs' for glob 'gnome*'
                                        Note, selecting 'gnome-core-devel' for glob 'gnome*'
                                        Note, selecting 'gnome-themes-standard' for glob 'gnome*'
                                        Note, selecting 'gnome-extra-icons' for glob 'gnome*'
                                        Note, selecting 'gnome-snapshot' for glob 'gnome*'
                                        Note, selecting 'gnome-devel' for glob 'gnome*'
                                        Note, selecting 'gnome-metronome' for glob 'gnome*'
                                        Note, selecting 'gnome-robots' for glob 'gnome*'
                                        Note, selecting 'gnome-packagekit' for glob 'gnome*'
                                        Note, selecting 'gnome-mastermind' for glob 'gnome*'
                                        Note, selecting 'gnome-calculator' for glob 'gnome*'
                                        Note, selecting 'gnome-shell-extension-desktop-icons-ng' for glob 'gnome*'
                                        Note, selecting 'gnome-shell-extension-just-perfection' for glob 'gnome*'
                                        Note, selecting 'gnome-2048' for glob 'gnome*'
                                        Note, selecting 'gnome-themes-extra-data' for glob 'gnome*'
                                        Note, selecting 'gnome-video-trimmer' for glob 'gnome*'
                                        Note, selecting 'gnome-shell-extension-top-icons-plus' for glob 'gnome*'
                                        Note, selecting 'gnome-icon-theme-nuovo' for glob 'gnome*'
                                        Note, selecting 'gnome-extensions-app' for glob 'gnome*'
                                        Note, selecting 'gnome-settings-daemon' for glob 'gnome*'
                                        Note, selecting 'gnome-shell-extension-appindicator' for glob 'gnome*'
                                        Note, selecting 'gnome-shell-extension-desktop-icons' for glob 'gnome*'
                                        Note, selecting 'gnome-shell-extension-autohidetopbar' for glob 'gnome*'
                                        Note, selecting 'gnome-illustrious-icon-theme' for glob 'gnome*'
                                        Note, selecting 'gnome-epub-thumbnailer' for glob 'gnome*'
                                        Note, selecting 'gnome-shell-extension-places-menu' for glob 'gnome*'
                                        Note, selecting 'gnome-photos' for glob 'gnome*'
                                        Note, selecting 'gnome-maps' for glob 'gnome*'
                                        Note, selecting 'gnome-multi-writer' for glob 'gnome*'
                                        Note, selecting 'gnome-shell-extension-freon' for glob 'gnome*'
                                        Note, selecting 'gnome-package-updater' for glob 'gnome*'
                                        Note, selecting 'gnome-contacts' for glob 'gnome*'
                                        Note, selecting 'gnome-mahjongg' for glob 'gnome*'
                                        Note, selecting 'gnome-commander-data' for glob 'gnome*'
                                        Note, selecting 'gnome-packagekit-data' for glob 'gnome*'
                                        Note, selecting 'gnome-desktop3-data' for glob 'gnome*'
                                        Note, selecting 'gnome-podcasts' for glob 'gnome*'
                                        Note, selecting 'gnome-colors' for glob 'gnome*'
                                        Note, selecting 'gnome-disk-utility' for glob 'gnome*'
                                        Note, selecting 'gnome-firmware' for glob 'gnome*'
                                        Note, selecting 'gnome-notes' for glob 'gnome*'
                                        Note, selecting 'gnome-classic-xsession' for glob 'gnome*'
                                        Note, selecting 'gnome-desktop-testing' for glob 'gnome*'
                                        Note, selecting 'gnome-icon-theme-suede' for glob 'gnome*'
                                        Note, selecting 'gnome-online-accounts' for glob 'gnome*'
                                        Note, selecting 'gnome-backgrounds' for glob 'gnome*'
                                        Note, selecting 'gnome-system-tools' for glob 'gnome*'
                                        Note, selecting 'gnome-shell-extension-no-annoyance' for glob 'gnome*'
                                        Note, selecting 'gnome-settings-daemon-dev' for glob 'gnome*'
                                        Note, selecting 'gnome-shell-extension-screenshot-window-sizer' for glob 'gnome*'
                                        Note, selecting 'gnome-screensaver-flags' for glob 'gnome*'
                                        Note, selecting 'gnome-bluetooth-sendto' for glob 'gnome*'
                                        Note, selecting 'gnome-screenshot' for glob 'gnome*'
                                        Note, selecting 'gnome-calls' for glob 'gnome*'
                                        Note, selecting 'gnome-shell-common' for glob 'gnome*'
                                        Note, selecting 'gnome-media' for glob 'gnome*'
                                        Note, selecting 'gnome-control-center-data' for glob 'gnome*'
                                        Note, selecting 'gnome-music' for glob 'gnome*'
                                        Note, selecting 'gnome-tetravex' for glob 'gnome*'
                                        Note, selecting 'gnome-platform-devel' for glob 'gnome*'
                                        Note, selecting 'gnome-theme-gilouche' for glob 'gnome*'
                                        Note, selecting 'gnome-keyring' for glob 'gnome*'
                                        Note, selecting 'gnome-icon-theme-symbolic' for glob 'gnome*'
                                        Note, selecting 'gnome-hwp-support' for glob 'gnome*'
                                        Note, selecting 'gnome-authenticator' for glob 'gnome*'
                                        Note, selecting 'gnome-mpv' for glob 'gnome*'
                                        Note, selecting 'gnome-pkg-tools' for glob 'gnome*'
                                        Note, selecting 'gnome-shell-extension-manager' for glob 'gnome*'
                                        Note, selecting 'gnome-shell-extension-workspaces-to-dock' for glob 'gnome*'
                                        Note, selecting 'gnome-menus' for glob 'gnome*'
                                        Note, selecting 'gnome-shell-extension-arc-menu' for glob 'gnome*'
                                        Note, selecting 'gnome-wise-icon-theme' for glob 'gnome*'
                                        Note, selecting 'gnome-shell-extension-hibernate-status' for glob 'gnome*'
                                        Note, selecting 'gnome-panel-control' for glob 'gnome*'
                                        Note, selecting 'gnome-pie' for glob 'gnome*'
                                        Note, selecting 'gnome-shell-extension-windows-navigator' for glob 'gnome*'
                                        Note, selecting 'gnome-shell-extension-shortcuts' for glob 'gnome*'
                                        Note, selecting 'gnome-brave-icon-theme' for glob 'gnome*'
                                        Note, selecting 'gnome-shell-extension-dash-to-panel' for glob 'gnome*'
                                        Note, selecting 'gnome-video-effects' for glob 'gnome*'
                                        Note, selecting 'gnome-session' for glob 'gnome*'
                                        Note, selecting 'gnome-common' for glob 'gnome*'
                                        Note, selecting 'gnome-dust-icon-theme' for glob 'gnome*'
                                        Note, selecting 'gnome-control-center' for glob 'gnome*'
                                        Note, selecting 'gnome-shell-extension-gamemode' for glob 'gnome*'
                                        Note, selecting 'gnome-terminal-data' for glob 'gnome*'
                                        Note, selecting 'gnome-settings-daemon-schemas' for glob 'gnome*'
                                        Note, selecting 'gnome-shell-extension-drive-menu' for glob 'gnome*'
                                        Note, selecting 'gnome-www-browser' for glob 'gnome*'
                                        Note, selecting 'gnome-games' for glob 'gnome*'
                                        Note, selecting 'gnome-flashback' for glob 'gnome*'
                                        Note, selecting 'gnome-session-canberra' for glob 'gnome*'
                                        Note, selecting 'gnome-genius' for glob 'gnome*'
                                        Note, selecting 'gnome-shell-extension-blur-my-shell' for glob 'gnome*'
                                        Note, selecting 'gnome-browser-connector' for glob 'gnome*'
                                        Note, selecting 'gnome-video-effects-dev' for glob 'gnome*'
                                        Note, selecting 'gnome-core' for glob 'gnome*'
                                        Note, selecting 'gnome-shell-extension-system-monitor' for glob 'gnome*'
                                        Note, selecting 'gnome-terminal' for glob 'gnome*'
                                        Note, selecting 'gnome-software-plugin-flatpak' for glob 'gnome*'
                                        Note, selecting 'gnome-shell-extension-impatience' for glob 'gnome*'
                                        Note, selecting 'gnome-characters' for glob 'gnome*'
                                        Note, selecting 'gnome-bluetooth' for glob 'gnome*'
                                        Note, selecting 'gnome-packagekit-common' for glob 'gnome*'
                                        Note, selecting 'gnome-sushi' for glob 'gnome*'
                                        Note, selecting 'gnome-activity-journal' for glob 'gnome*'
                                        Note, selecting 'gnome-shell-extension-onboard' for glob 'gnome*'
                                        Note, selecting 'gnome-api-docs' for glob 'gnome*'
                                        Note, selecting 'gnome-accessibility-themes' for glob 'gnome*'
                                        Note, selecting 'gnome-keysign' for glob 'gnome*'
                                        Note, selecting 'gnome-model-thumbnailer' for glob 'gnome*'
                                        Note, selecting 'gnome-themes-extra' for glob 'gnome*'
                                        Note, selecting 'gnome-shell-extensions-common' for glob 'gnome*'
                                        Note, selecting 'gnome-mousetrap' for glob 'gnome*'
                                        Note, selecting 'gnome-recipes' for glob 'gnome*'
                                        Note, selecting 'gnome-nettool' for glob 'gnome*'
                                        Note, selecting 'gnome-keyring-pkcs11' for glob 'gnome*'
                                        Note, selecting 'gnome-shell-extension-prefs' for glob 'gnome*'
                                        Note, selecting 'gnome-chess' for glob 'gnome*'
                                        Note, selecting 'gnome-shell-extension-no-overview' for glob 'gnome*'
                                        Note, selecting 'gnome-taquin' for glob 'gnome*'
                                        Note, selecting 'gnome-shell-extension-user-theme' for glob 'gnome*'
                                        Note, selecting 'gnome-decoder' for glob 'gnome*'
                                        Note, selecting 'gnome-shell-extension-caffeine' for glob 'gnome*'
                                        Note, selecting 'gnome-video-effects-extra' for glob 'gnome*'
                                        Note, selecting 'gnome-todo' for glob 'gnome*'
                                        Note, selecting 'gnome-shell-extension-hamster' for glob 'gnome*'
                                        Note, selecting 'gnome-tour' for glob 'gnome*'
                                        Note, selecting 'gnome-shell-extensions-gpaste' for glob 'gnome*'
                                        Note, selecting 'gnome-builder' for glob 'gnome*'
                                        Note, selecting 'gnome-shell-extension-hide-activities' for glob 'gnome*'
                                        Note, selecting 'gnome-shell-extension-gsconnect' for glob 'gnome*'
                                        Note, selecting 'gnome-console' for glob 'gnome*'
                                        Note, selecting 'gnome-nds-thumbnailer' for glob 'gnome*'
                                        Note, selecting 'gnome-recipes-data' for glob 'gnome*'
                                        Note, selecting 'gnome-photos-tests' for glob 'gnome*'
                                        Note, selecting 'gnome-calls-doc' for glob 'gnome*'
                                        Note, selecting 'gnome-control-center-dev' for glob 'gnome*'
                                        Note, selecting 'gnome-clocks' for glob 'gnome*'
                                        Note, selecting 'gnome-session-common' for glob 'gnome*'
                                        Note, selecting 'gnome-latex' for glob 'gnome*'
                                        Note, selecting 'gnome-codec-install' for glob 'gnome*'
                                        Note, selecting 'gnome-kiosk-search-appliance' for glob 'gnome*'
                                        Package 'gnome-themes-standard-data' is not installed, so not removed
                                        Note, selecting 'adwaita-icon-theme' instead of 'gnome-icon-theme-symbolic'
                                        Package 'gnome-bluetooth' is not installed, so not removed
                                        Package 'gnome-power-statistics' is not installed, so not removed
                                        Package 'gnome-control-center-signon' is not installed, so not removed
                                        Note, selecting 'bijiben' instead of 'gnome-notes'
                                        Package 'gnome-mpv' is not installed, so not removed
                                        Package 'gnome-mime-data' is not installed, so not removed
                                        Package 'gnome-video-arcade' is not installed, so not removed
                                        Package 'gnome-dictionary' is not installed, so not removed
                                        Package 'gnome-mplayer' is not installed, so not removed
                                        Note, selecting 'endeavour' instead of 'gnome-todo'
                                        Note, selecting 'enter-tex' instead of 'gnome-latex'
                                        Package 'gnome-packagekit-data' is not installed, so not removed
                                        Note, selecting 'gnome-settings-daemon-common' instead of 'gnome-settings-daemon-schemas'
                                        Package 'gnome-shell-extension-desktop-icons' is not installed, so not removed
                                        Package 'gnome-shell-extension-taskbar' is not installed, so not removed
                                        Package 'gnome-shell-extension-top-icons-plus' is not installed, so not removed
                                        Package 'gnome-shell-extension-workspaces-to-dock' is not installed, so not removed
                                        Note, selecting 'gnome-shell-extension-prefs' instead of 'gnome-extensions-app'
                                        Note, selecting 'gnome-shell-extension-dashtodock' instead of 'gnome-shell-extension-dash-to-dock'
                                        Note, selecting 'gnome-shell-extensions-extra' instead of 'gnome-shell-extension-disable-workspace-switcher'
                                        Note, selecting 'gnome-shell-extensions-extra' instead of 'gnome-shell-extension-hibernate-status'
                                        Note, selecting 'gnome-shell-extensions-extra' instead of 'gnome-shell-extension-just-perfection'
                                        Note, selecting 'gnome-shell-extensions-extra' instead of 'gnome-shell-extension-middleclickclose'
                                        Note, selecting 'gnome-shell-extensions-extra' instead of 'gnome-shell-extension-no-overview'
                                        Note, selecting 'gnome-shell-extensions-extra' instead of 'gnome-shell-extension-vertical-workspaces'
                                        Package 'gnome-media' is not installed, so not removed
                                        Note, selecting 'gnome-tweaks' instead of 'gnome-tweak-tool'
                                        Package 'gnome-video-effects-extra' is not installed, so not removed
                                        Package 'gnome-shell-extensions-gpaste' is not installed, so not removed
                                        Package 'gnome-games-app' is not installed, so not removed
                                        Package 'gnome-core-devel' is not installed, so not removed
                                        Package 'gnome-shell-extension-onboard' is not installed, so not removed
                                        Package 'gnome-codec-install' is not installed, so not removed
                                        Package 'gnome-icon-theme-full' is not installed, so not removed
                                        Package 'gnome-alsamixer' is not installed, so not removed
                                        Package 'gnome-themes-extras' is not installed, so not removed
                                        Package 'gnome-themes-standard' is not installed, so not removed
                                        Note, selecting 'gstreamer1.0-qt5' for glob 'gstreamer*'
                                        Note, selecting 'gstreamer1.0-qt6' for glob 'gstreamer*'
                                        Note, selecting 'gstreamer1.0-wpe' for glob 'gstreamer*'
                                        Note, selecting 'gstreamer1.0-plugins-ugly' for glob 'gstreamer*'
                                        Note, selecting 'gstreamer1.0-packagekit' for glob 'gstreamer*'
                                        Note, selecting 'gstreamer1.0-plugins-bad-apps-dbgsym' for glob 'gstreamer*'
                                        Note, selecting 'gstreamer1.0-gl' for glob 'gstreamer*'
                                        Note, selecting 'gstreamer1.0-plugins-base-apps-dbgsym' for glob 'gstreamer*'
                                        Note, selecting 'gstreamer1.0-fluendo-mp3' for glob 'gstreamer*'
                                        Note, selecting 'gstreamer1.0-clutter-3.0' for glob 'gstreamer*'
                                        Note, selecting 'gstreamer1.0-autogain-pulseeffects' for glob 'gstreamer*'
                                        Note, selecting 'gstreamer1.0-python-dbg-plugin-loader' for glob 'gstreamer*'
                                        Note, selecting 'gstreamer1.0-plugins-base-dbgsym' for glob 'gstreamer*'
                                        Note, selecting 'gstreamer1.0-plugins-bad-videoparsers' for glob 'gstreamer*'
                                        Note, selecting 'gstreamer1.0-pispconvert' for glob 'gstreamer*'
                                        Note, selecting 'gstreamer1.0-adapter-pulseeffects' for glob 'gstreamer*'
                                        Note, selecting 'gstreamer1.0-videosource' for glob 'gstreamer*'
                                        Note, selecting 'gstreamer1.0-tools' for glob 'gstreamer*'
                                        Note, selecting 'gstreamer1.0-espeak' for glob 'gstreamer*'
                                        Note, selecting 'gstreamer1.0-plugins-really-bad' for glob 'gstreamer*'
                                        Note, selecting 'gstreamer1.0-lame' for glob 'gstreamer*'
                                        Note, selecting 'gstreamer1.0-plugins-base-apps' for glob 'gstreamer*'
                                        Note, selecting 'gstreamer1.0-alsa' for glob 'gstreamer*'
                                        Note, selecting 'gstreamer1.0-pipewire-dbgsym' for glob 'gstreamer*'
                                        Note, selecting 'gstreamer1.0-audiosource' for glob 'gstreamer*'
                                        Note, selecting 'gstreamer1.0-gl-dbgsym' for glob 'gstreamer*'
                                        Note, selecting 'gstreamer1.0-audiosink' for glob 'gstreamer*'
                                        Note, selecting 'gstreamer1.0-visualization' for glob 'gstreamer*'
                                        Note, selecting 'gstreamer1.0-x' for glob 'gstreamer*'
                                        Note, selecting 'gstreamer1.0-gtk3' for glob 'gstreamer*'
                                        Note, selecting 'gstreamer1.0-gtk4' for glob 'gstreamer*'
                                        Note, selecting 'gstreamer1.0-pocketsphinx' for glob 'gstreamer*'
                                        Note, selecting 'gstreamer1.0-rtsp' for glob 'gstreamer*'
                                        Note, selecting 'gstreamer1.0-libcamera' for glob 'gstreamer*'
                                        Note, selecting 'gstreamer1.0-plugins-good' for glob 'gstreamer*'
                                        Note, selecting 'gstreamer1.0-plugins-bad-faad' for glob 'gstreamer*'
                                        Note, selecting 'gstreamer1.0-plugins-base' for glob 'gstreamer*'
                                        Note, selecting 'gstreamer1.0-crystalhd' for glob 'gstreamer*'
                                        Note, selecting 'gstreamer1.0-pipewire' for glob 'gstreamer*'
                                        Note, selecting 'gstreamer1.0-python3-plugin-loader' for glob 'gstreamer*'
                                        Note, selecting 'gstreamer0.10-packagekit' for glob 'gstreamer*'
                                        Note, selecting 'gstreamer1.0-plugins-bad-dbgsym' for glob 'gstreamer*'
                                        Note, selecting 'gstreamer1.0-vaapi-doc' for glob 'gstreamer*'
                                        Note, selecting 'gstreamer1.0-videosink' for glob 'gstreamer*'
                                        Note, selecting 'gstreamer1.0-plugins-base-doc' for glob 'gstreamer*'
                                        Note, selecting 'gstreamer1.0-x-dbgsym' for glob 'gstreamer*'
                                        Note, selecting 'gstreamer1.0-opencv-dbgsym' for glob 'gstreamer*'
                                        Note, selecting 'gstreamer1.0-convolver-pulseeffects' for glob 'gstreamer*'
                                        Note, selecting 'gstreamer1.0-pispconvert-dbgsym' for glob 'gstreamer*'
                                        Note, selecting 'gstreamer1.0-python3-dbg-plugin-loader' for glob 'gstreamer*'
                                        Note, selecting 'gstreamer1.0-plugins-bad-apps' for glob 'gstreamer*'
                                        Note, selecting 'gstreamer1.0-opencv' for glob 'gstreamer*'
                                        Note, selecting 'gstreamer1.0-vaapi' for glob 'gstreamer*'
                                        Note, selecting 'gstreamer1.0-nice' for glob 'gstreamer*'
                                        Note, selecting 'gstreamer1.0-libcamera-dbgsym' for glob 'gstreamer*'
                                        Note, selecting 'gstreamer1.0-crystalizer-pulseeffects' for glob 'gstreamer*'
                                        Note, selecting 'gstreamer1.0-plugins-bad' for glob 'gstreamer*'
                                        Note, selecting 'gstreamer1.0-pulseaudio' for glob 'gstreamer*'
                                        Note, selecting 'gstreamer1.0-python-plugin-loader' for glob 'gstreamer*'
                                        Note, selecting 'gstreamer1.0-libav' for glob 'gstreamer*'
                                        Note, selecting 'gstreamer1.0-alsa-dbgsym' for glob 'gstreamer*'
                                        Note, selecting 'gstreamer1.0-plugins-rtp' for glob 'gstreamer*'
                                        Note, selecting 'gstreamer1.0-doc' for glob 'gstreamer*'
                                        Note, selecting 'gstreamer1.0-fdkaac' for glob 'gstreamer*'
                                        Note, selecting 'gstreamer1.0-wpe-dbgsym' for glob 'gstreamer*'
                                        Note, selecting 'gstreamer-sharp-1.0' for glob 'gstreamer*'
                                        Package 'gstreamer1.0-doc' is not installed, so not removed
                                        Package 'gstreamer1.0-plugins-base-doc' is not installed, so not removed
                                        Package 'gstreamer-sharp-1.0' is not installed, so not removed
                                        Package 'gstreamer1.0-crystalhd' is not installed, so not removed
                                        Note, selecting 'gstreamer1.0-plugins-bad' instead of 'gstreamer1.0-plugins-bad-faad'
                                        Note, selecting 'gstreamer1.0-plugins-bad' instead of 'gstreamer1.0-plugins-bad-videoparsers'
                                        Package 'gstreamer1.0-python-dbg-plugin-loader' is not installed, so not removed
                                        Package 'gstreamer1.0-python-plugin-loader' is not installed, so not removed
                                        Package 'gstreamer1.0-python3-dbg-plugin-loader' is not installed, so not removed
                                        Package 'gstreamer1.0-vaapi-doc' is not installed, so not removed
                                        Package 'gstreamer1.0-fluendo-mp3' is not installed, so not removed
                                        Package 'gstreamer0.10-packagekit' is not installed, so not removed
                                        Package 'gstreamer1.0-lame' is not installed, so not removed
                                        Package 'gstreamer1.0-plugins-really-bad' is not installed, so not removed
                                        Note, selecting 'gtk-3-examples-dbgsym' for glob 'gtk*'
                                        Note, selecting 'gtkmorph-example' for glob 'gtk*'
                                        Note, selecting 'gtk2-engines-clearlookspix-dbgsym' for glob 'gtk*'
                                        Note, selecting 'gtk-layer-shell-doc' for glob 'gtk*'
                                        Note, selecting 'gtk2-engines-qtcurve' for glob 'gtk*'
                                        Note, selecting 'gtkhash' for glob 'gtk*'
                                        Note, selecting 'gtk2-engines-clearlookspix' for glob 'gtk*'
                                        Note, selecting 'gtk4-layer-shell-examples' for glob 'gtk*'
                                        Note, selecting 'gtk3-binver-3.0.0' for glob 'gtk*'
                                        Note, selecting 'gtkatlantic' for glob 'gtk*'
                                        Note, selecting 'gtk-im-libthai' for glob 'gtk*'
                                        Note, selecting 'gtklock-userinfo-module' for glob 'gtk*'
                                        Note, selecting 'gtkterm' for glob 'gtk*'
                                        Note, selecting 'gtk2-engines-pixbuf-dbgsym' for glob 'gtk*'
                                        Note, selecting 'gtk2hs-buildtools' for glob 'gtk*'
                                        Note, selecting 'gtklock-playerctl-module' for glob 'gtk*'
                                        Note, selecting 'gtk-nop' for glob 'gtk*'
                                        Note, selecting 'gtkballs' for glob 'gtk*'
                                        Note, selecting 'gtk2-engines-aurora' for glob 'gtk*'
                                        Note, selecting 'gtkam' for glob 'gtk*'
                                        Note, selecting 'gtk-redshift' for glob 'gtk*'
                                        Note, selecting 'gtklp' for glob 'gtk*'
                                        Note, selecting 'gtk-meshtastic-client' for glob 'gtk*'
                                        Note, selecting 'gtk4-binver-4.0.0' for glob 'gtk*'
                                        Note, selecting 'gtkguitune' for glob 'gtk*'
                                        Note, selecting 'gtk2-engines-murrine' for glob 'gtk*'
                                        Note, selecting 'gtk4-layer-shell-doc' for glob 'gtk*'
                                        Note, selecting 'gtk3-nocsd' for glob 'gtk*'
                                        Note, selecting 'gtk-4-examples' for glob 'gtk*'
                                        Note, selecting 'gtkgreet' for glob 'gtk*'
                                        Note, selecting 'gtk-nop-dbgsym' for glob 'gtk*'
                                        Note, selecting 'gtkpool' for glob 'gtk*'
                                        Note, selecting 'gtk-session-lock-examples' for glob 'gtk*'
                                        Note, selecting 'gtk2-engines' for glob 'gtk*'
                                        Note, selecting 'gtk2-engines-sugar' for glob 'gtk*'
                                        Note, selecting 'gtkman' for glob 'gtk*'
                                        Note, selecting 'gtk-layer-shell-examples' for glob 'gtk*'
                                        Note, selecting 'gtkpod' for glob 'gtk*'
                                        Note, selecting 'gtkcrypto' for glob 'gtk*'
                                        Note, selecting 'gtk-theme-switch' for glob 'gtk*'
                                        Note, selecting 'gtkmm-documentation' for glob 'gtk*'
                                        Note, selecting 'gtk2-engines-pixbuf' for glob 'gtk*'
                                        Note, selecting 'gtk-3-examples' for glob 'gtk*'
                                        Note, selecting 'gtk-chtheme' for glob 'gtk*'
                                        Note, selecting 'gtk-update-icon-cache' for glob 'gtk*'
                                        Note, selecting 'gtk-doc-tools' for glob 'gtk*'
                                        Note, selecting 'gtkwave' for glob 'gtk*'
                                        Note, selecting 'gtk2-engines-pixflat' for glob 'gtk*'
                                        Note, selecting 'gtklick' for glob 'gtk*'
                                        Note, selecting 'gtkboard' for glob 'gtk*'
                                        Note, selecting 'gtklock' for glob 'gtk*'
                                        Note, selecting 'gtk3-im-libthai' for glob 'gtk*'
                                        Note, selecting 'gtk2-engines-pixflat-dbgsym' for glob 'gtk*'
                                        Note, selecting 'gtk-4-tests' for glob 'gtk*'
                                        Note, selecting 'gtk-recordmydesktop' for glob 'gtk*'
                                        Note, selecting 'gtk2.0-binver-2.10.0' for glob 'gtk*'
                                        Note, selecting 'gtk2-engines-gartoon' for glob 'gtk*'
                                        Package 'gtkboard' is not installed, so not removed
                                        Package 'gtkpool' is not installed, so not removed
                                        Package 'gtkguitune' is not installed, so not removed
                                        Package 'gtklick' is not installed, so not removed
                                        Note, selecting 'gnome-icon-theme-gartoon' instead of 'gtk2-engines-gartoon'
                                        Package 'gtkpod' is not installed, so not removed
                                        Note, selecting 'libgtk-4-1' instead of 'gtk4-binver-4.0.0'
                                        Package 'gtk-recordmydesktop' is not installed, so not removed
                                        Package 'gtk-redshift' is not installed, so not removed
                                        Package 'gtk2-engines-sugar' is not installed, so not removed
                                        Note, selecting 'hicolor-icon-theme' for glob 'hicolor-icon-theme*'
                                        Note, selecting 'lxplug-ejecter' for glob 'lx*'
                                        Note, selecting 'lxpanel-pi-dbgsym' for glob 'lx*'
                                        Note, selecting 'lxd-tools' for glob 'lx*'
                                        Note, selecting 'lxqt-powermanagement-l10n' for glob 'lx*'
                                        Note, selecting 'lxpanel-pi' for glob 'lx*'
                                        Note, selecting 'lxplug-volumepulse' for glob 'lx*'
                                        Note, selecting 'lximage-qt-l10n' for glob 'lx*'
                                        Note, selecting 'lxpanel-dev' for glob 'lx*'
                                        Note, selecting 'lxqt-panel' for glob 'lx*'
                                        Note, selecting 'lxlauncher' for glob 'lx*'
                                        Note, selecting 'lxpanel-data' for glob 'lx*'
                                        Note, selecting 'lxqt-theme-debian' for glob 'lx*'
                                        Note, selecting 'lxqt-archiver' for glob 'lx*'
                                        Note, selecting 'lxterminal' for glob 'lx*'
                                        Note, selecting 'lxqt-system-theme' for glob 'lx*'
                                        Note, selecting 'lxc' for glob 'lx*'
                                        Note, selecting 'lxd' for glob 'lx*'
                                        Note, selecting 'lxqt-admin' for glob 'lx*'
                                        Note, selecting 'lxi-tools' for glob 'lx*'
                                        Note, selecting 'lxqt-openssh-askpass-l10n' for glob 'lx*'
                                        Note, selecting 'lxpolkit' for glob 'lx*'
                                        Note, selecting 'lxqt-powermanagement' for glob 'lx*'
                                        Note, selecting 'lxsession' for glob 'lx*'
                                        Note, selecting 'lxsession-data' for glob 'lx*'
                                        Note, selecting 'lxde-settings-daemon-dbgsym' for glob 'lx*'
                                        Note, selecting 'lxde-common' for glob 'lx*'
                                        Note, selecting 'lxlock' for glob 'lx*'
                                        Note, selecting 'lxqt-sudo-l10n' for glob 'lx*'
                                        Note, selecting 'lxcfs' for glob 'lx*'
                                        Note, selecting 'lxctl' for glob 'lx*'
                                        Note, selecting 'lxqt-openssh-askpass' for glob 'lx*'
                                        Note, selecting 'lxmenu-data' for glob 'lx*'
                                        Note, selecting 'lxd-client' for glob 'lx*'
                                        Note, selecting 'lxqt-qtplugin' for glob 'lx*'
                                        Note, selecting 'lxde-core' for glob 'lx*'
                                        Note, selecting 'lxqt-qtplugin6' for glob 'lx*'
                                        Note, selecting 'lxplug-updater' for glob 'lx*'
                                        Note, selecting 'lxplug-cpu' for glob 'lx*'
                                        Note, selecting 'lxqt-runner-l10n' for glob 'lx*'
                                        Note, selecting 'lxd-migrate' for glob 'lx*'
                                        Note, selecting 'lxpanel' for glob 'lx*'
                                        Note, selecting 'lxqt-sudo' for glob 'lx*'
                                        Note, selecting 'lxc-dev' for glob 'lx*'
                                        Note, selecting 'lxqt-admin-l10n' for glob 'lx*'
                                        Note, selecting 'lxsession-edit' for glob 'lx*'
                                        Note, selecting 'lxqt-policykit-l10n' for glob 'lx*'
                                        Note, selecting 'lxrandr' for glob 'lx*'
                                        Note, selecting 'lxqt-core' for glob 'lx*'
                                        Note, selecting 'lxqt-archiver-l10n' for glob 'lx*'
                                        Note, selecting 'lxqt-theme' for glob 'lx*'
                                        Note, selecting 'lxplug-bluetooth' for glob 'lx*'
                                        Note, selecting 'lxplug-cputemp' for glob 'lx*'
                                        Note, selecting 'lxqt-globalkeys-l10n' for glob 'lx*'
                                        Note, selecting 'lxappearance-obconf' for glob 'lx*'
                                        Note, selecting 'lxqt-branding-debian' for glob 'lx*'
                                        Note, selecting 'lxde' for glob 'lx*'
                                        Note, selecting 'lxdm' for glob 'lx*'
                                        Note, selecting 'lxqt' for glob 'lx*'
                                        Note, selecting 'lxplug-magnifier' for glob 'lx*'
                                        Note, selecting 'lxinput' for glob 'lx*'
                                        Note, selecting 'lxshortcut' for glob 'lx*'
                                        Note, selecting 'lxpolkit-dbgsym' for glob 'lx*'
                                        Note, selecting 'lxqt-branding' for glob 'lx*'
                                        Note, selecting 'lxqt-qt5plugin' for glob 'lx*'
                                        Note, selecting 'lxtask' for glob 'lx*'
                                        Note, selecting 'lxqt-policykit' for glob 'lx*'
                                        Note, selecting 'lxplug-netman' for glob 'lx*'
                                        Note, selecting 'lxsession-logout' for glob 'lx*'
                                        Note, selecting 'lxplug-batt' for glob 'lx*'
                                        Note, selecting 'lxqt-panel-l10n' for glob 'lx*'
                                        Note, selecting 'lxpanel-pi-dev-dbgsym' for glob 'lx*'
                                        Note, selecting 'lx-gdb' for glob 'lx*'
                                        Note, selecting 'lxc-tests' for glob 'lx*'
                                        Note, selecting 'lxplug-menu' for glob 'lx*'
                                        Note, selecting 'lxhotkey-core' for glob 'lx*'
                                        Note, selecting 'lxqt-common' for glob 'lx*'
                                        Note, selecting 'lxsession-default-apps' for glob 'lx*'
                                        Note, selecting 'lxsession-edit-dbgsym' for glob 'lx*'
                                        Note, selecting 'lxqt-about' for glob 'lx*'
                                        Note, selecting 'lxde-icon-theme' for glob 'lx*'
                                        Note, selecting 'lxc-templates' for glob 'lx*'
                                        Note, selecting 'lxhotkey-data' for glob 'lx*'
                                        Note, selecting 'lxqt-session-l10n' for glob 'lx*'
                                        Note, selecting 'lximage-qt' for glob 'lx*'
                                        Note, selecting 'lxhotkey-dev' for glob 'lx*'
                                        Note, selecting 'lxqt-runner' for glob 'lx*'
                                        Note, selecting 'lxqt-build-tools-qt5' for glob 'lx*'
                                        Note, selecting 'lxhotkey-gtk' for glob 'lx*'
                                        Note, selecting 'lxhotkey-gui' for glob 'lx*'
                                        Note, selecting 'lxqt-menu-data' for glob 'lx*'
                                        Note, selecting 'lxplug-ptbatt' for glob 'lx*'
                                        Note, selecting 'lxsession-dbgsym' for glob 'lx*'
                                        Note, selecting 'lxqt-themes' for glob 'lx*'
                                        Note, selecting 'lxhotkey-plugin-openbox' for glob 'lx*'
                                        Note, selecting 'lxqt-build-tools' for glob 'lx*'
                                        Note, selecting 'lxqt-config' for glob 'lx*'
                                        Note, selecting 'lxpanel-pi-dev' for glob 'lx*'
                                        Note, selecting 'lxtask-dbgsym' for glob 'lx*'
                                        Note, selecting 'lxqt-about-l10n' for glob 'lx*'
                                        Note, selecting 'lxqt-session' for glob 'lx*'
                                        Note, selecting 'lxde-settings-daemon' for glob 'lx*'
                                        Note, selecting 'lxqt-config-l10n' for glob 'lx*'
                                        Note, selecting 'lxd-agent' for glob 'lx*'
                                        Note, selecting 'lxqt-globalkeys' for glob 'lx*'
                                        Note, selecting 'lxmusic' for glob 'lx*'
                                        Note, selecting 'lxde-session' for glob 'lx*'
                                        Note, selecting 'lxsession-logout-dbgsym' for glob 'lx*'
                                        Note, selecting 'lxqt-notificationd' for glob 'lx*'
                                        Note, selecting 'lxsession-default-apps-dbgsym' for glob 'lx*'
                                        Note, selecting 'lxappearance' for glob 'lx*'
                                        Note, selecting 'lxterminal-dbgsym' for glob 'lx*'
                                        Note, selecting 'lxqt-notificationd-l10n' for glob 'lx*'
                                        Note, selecting 'libfm-tools' instead of 'lxshortcut'
                                        Note, selecting 'lxhotkey-gtk' instead of 'lxhotkey-gui'
                                        Note, selecting 'lxqt-branding-debian' instead of 'lxqt-branding'
                                        Package 'lxqt-qtplugin6' is not installed, so not removed
                                        Package 'lxqt-common' is not installed, so not removed
                                        Package 'lxplug-ptbatt' is not installed, so not removed
                                        Package 'lxplug-menu' is not installed, so not removed
                                        Note, selecting 'mesa-opencl-icd' for glob 'mesa*'
                                        Note, selecting 'mesa-test-tools' for glob 'mesa*'
                                        Note, selecting 'mesa-glide2-dev' for glob 'mesa*'
                                        Note, selecting 'mesag-dev' for glob 'mesa*'
                                        Note, selecting 'mesa-common-dev' for glob 'mesa*'
                                        Note, selecting 'mesa-vulkan-drivers-dbgsym' for glob 'mesa*'
                                        Note, selecting 'mesag3+ggi-dev' for glob 'mesa*'
                                        Note, selecting 'mesa-libgallium' for glob 'mesa*'
                                        Note, selecting 'mesa-drm-shim' for glob 'mesa*'
                                        Note, selecting 'mesa-va-drivers' for glob 'mesa*'
                                        Note, selecting 'mesa-libgallium-dbgsym' for glob 'mesa*'
                                        Note, selecting 'mesaflash' for glob 'mesa*'
                                        Note, selecting 'mesa-utils-bin' for glob 'mesa*'
                                        Note, selecting 'mesa-vulkan-drivers' for glob 'mesa*'
                                        Note, selecting 'mesa-drm-shim-dbgsym' for glob 'mesa*'
                                        Note, selecting 'mesa-utils-extra' for glob 'mesa*'
                                        Note, selecting 'mesa-teflon-delegate' for glob 'mesa*'
                                        Note, selecting 'mesa-opencl-icd-dbgsym' for glob 'mesa*'
                                        Note, selecting 'mesa-teflon-delegate-dbgsym' for glob 'mesa*'
                                        Note, selecting 'mesag3-widgets' for glob 'mesa*'
                                        Note, selecting 'mesa-utils' for glob 'mesa*'
                                        Note, selecting 'mesag3' for glob 'mesa*'
                                        Note, selecting 'mesa-vdpau-drivers' for glob 'mesa*'
                                        Note, selecting 'mesag-widgets-dev' for glob 'mesa*'
                                        Package 'mesa-test-tools' is not installed, so not removed
                                        Note, selecting 'libglw1-mesa-dev' instead of 'mesag-widgets-dev'
                                        Note, selecting 'libglw1-mesa-dev' instead of 'mesag3-widgets'
                                        Package 'mesag3' is not installed, so not removed
                                        Package 'mesa-glide2-dev' is not installed, so not removed
                                        Package 'mesag-dev' is not installed, so not removed
                                        Package 'mesag3+ggi-dev' is not installed, so not removed
                                        Note, selecting 'mesa-utils' instead of 'mesa-utils-extra'
                                        Package 'xserver-xephyr' is not installed, so not removed
                                        Package 'xserver-xorg-input-wacom' is not installed, so not removed
                                        Package 'xserver-xorg-input-synaptics' is not installed, so not removed
                                        Package 'xserver-x2gokdrive' is not installed, so not removed
                                        Package 'xserver-xorg-input-mtrack' is not installed, so not removed
                                        Package 'xserver-xorg-input-multitouch' is not installed, so not removed
                                        Package 'xserver-xorg-input-xwiimote' is not installed, so not removed
                                        Package 'xserver-xorg-dev' is not installed, so not removed
                                        Package 'xserver-xorg-legacy' is not installed, so not removed
                                        Package 'xserver-xorg-input-aiptek' is not installed, so not removed
                                        Package 'xserver-xorg-input-elographics' is not installed, so not removed
                                        Package 'xserver-xorg-input-evdev' is not installed, so not removed
                                        Package 'xserver-xorg-input-evdev-dev' is not installed, so not removed
                                        Package 'xserver-xorg-input-joystick' is not installed, so not removed
                                        Package 'xserver-xorg-input-joystick-dev' is not installed, so not removed
                                        Package 'xserver-xorg-input-kbd' is not installed, so not removed
                                        Package 'xserver-xorg-input-libinput-dev' is not installed, so not removed
                                        Package 'xserver-xorg-input-mouse' is not installed, so not removed
                                        Package 'xserver-xorg-input-synaptics-dev' is not installed, so not removed
                                        Package 'xserver-xorg-video-r128' is not installed, so not removed
                                        Package 'xserver-xorg-video-mach64' is not installed, so not removed
                                        Package 'xserver-xorg-video-cirrus' is not installed, so not removed
                                        Package 'xserver-xorg-video-dummy' is not installed, so not removed
                                        Package 'xserver-xorg-video-mga' is not installed, so not removed
                                        Package 'xserver-xorg-video-neomagic' is not installed, so not removed
                                        Package 'xserver-xorg-video-qxl' is not installed, so not removed
                                        Package 'xserver-xorg-video-savage' is not installed, so not removed
                                        Package 'xserver-xorg-video-siliconmotion' is not installed, so not removed
                                        Package 'xserver-xorg-video-sisusb' is not installed, so not removed
                                        Package 'xserver-xorg-video-nvidia' is not installed, so not removed
                                        Package 'xserver-xorg-video-nvidia-tesla-535' is not installed, so not removed
                                        Package 'xserver-xephyr-dbgsym' is not installed, so not removed
                                        Package 'xserver-xorg-core-dbgsym' is not installed, so not removed
                                        Package 'xserver-xorg-legacy-dbgsym' is not installed, so not removed
                                        Package 'xserver-xorg-video-fbturbo-dbgsym' is not installed, so not removed
                                        Package 'lightdm-remote-session-x2go' is not installed, so not removed
                                        Package 'lightdm-vala' is not installed, so not removed
                                        Package 'lightdm-autologin-greeter' is not installed, so not removed
                                        Package 'lightdm-gtk-greeter-settings' is not installed, so not removed
                                        Package 'lightdm-settings' is not installed, so not removed
                                        Package 'lightdm-dbgsym' is not installed, so not removed
                                        Package 'vlc-plugin-jack' is not installed, so not removed
                                        Package 'vlc-plugin-fluidsynth' is not installed, so not removed
                                        Package 'vlc-plugin-pipewire' is not installed, so not removed
                                        Package 'vlc-plugin-svg' is not installed, so not removed
                                        Package 'vlc-plugin-bittorrent' is not installed, so not removed
                                        Package 'vlc-bin-dbgsym' is not installed, so not removed
                                        Package 'vlc-plugin-access-extra-dbgsym' is not installed, so not removed
                                        Package 'vlc-plugin-base-dbgsym' is not installed, so not removed
                                        Package 'vlc-plugin-fluidsynth-dbgsym' is not installed, so not removed
                                        Package 'vlc-plugin-jack-dbgsym' is not installed, so not removed
                                        Package 'vlc-plugin-notify-dbgsym' is not installed, so not removed
                                        Package 'vlc-plugin-qt-dbgsym' is not installed, so not removed
                                        Package 'vlc-plugin-samba-dbgsym' is not installed, so not removed
                                        Package 'vlc-plugin-skins2-dbgsym' is not installed, so not removed
                                        Package 'vlc-plugin-svg-dbgsym' is not installed, so not removed
                                        Package 'vlc-plugin-video-output-dbgsym' is not installed, so not removed
                                        Package 'vlc-plugin-video-splitter-dbgsym' is not installed, so not removed
                                        Package 'vlc-plugin-visualization-dbgsym' is not installed, so not removed
                                        Package 'lxde-settings-daemon' is not installed, so not removed
                                        Package 'lxde-settings-daemon-dbgsym' is not installed, so not removed
                                        Package 'chromium-lwn4chrome' is not installed, so not removed
                                        Package 'chromium-shell' is not installed, so not removed
                                        Package 'chromium-driver' is not installed, so not removed
                                        Package 'chromium-headless-shell' is not installed, so not removed
                                        Package 'chromium-bsu' is not installed, so not removed
                                        Package 'chromium-bsu-data' is not installed, so not removed
                                        Package 'chromium-browser-l10n' is not installed, so not removed
                                        Package 'chromium-chromedriver' is not installed, so not removed
                                        Package 'chromium-common-dbgsym' is not installed, so not removed
                                        Package 'chromium-dbgsym' is not installed, so not removed
                                        Package 'chromium-headless-shell-dbgsym' is not installed, so not removed
                                        Package 'chromium-sandbox-dbgsym' is not installed, so not removed
                                        Package 'chromium-shell-dbgsym' is not installed, so not removed
                                        Package 'desktop-autoloader' is not installed, so not removed
                                        Package 'desktopfolder' is not installed, so not removed
                                        Package 'gnome-control-center' is not installed, so not removed
                                        Package 'gnome-screensaver' is not installed, so not removed
                                        Package 'gnome-themes-extra' is not installed, so not removed
                                        Package 'gnome-cards-data' is not installed, so not removed
                                        Package 'gnome-package-updater' is not installed, so not removed
                                        Package 'gnome-terminal' is not installed, so not removed
                                        Package 'gnome-panel-data' is not installed, so not removed
                                        Package 'gnome-common' is not installed, so not removed
                                        Package 'gnome-shell-extension-appindicator' is not installed, so not removed
                                        Package 'gnome-session-canberra' is not installed, so not removed
                                        Package 'gnome-settings-daemon' is not installed, so not removed
                                        Package 'gnome-user-docs' is not installed, so not removed
                                        Package 'gnome-user-share' is not installed, so not removed
                                        Package 'gnome-software' is not installed, so not removed
                                        Package 'gnome-packagekit' is not installed, so not removed
                                        Package 'gnome-calculator' is not installed, so not removed
                                        Package 'gnome-power-manager' is not installed, so not removed
                                        Package 'gnome-calls' is not installed, so not removed
                                        Package 'gnome-video-effects' is not installed, so not removed
                                        Package 'gnome-video-effects-frei0r' is not installed, so not removed
                                        Package 'gnome-backgrounds' is not installed, so not removed
                                        Package 'gnome-online-accounts-gtk' is not installed, so not removed
                                        Package 'gnome-text-editor' is not installed, so not removed
                                        Package 'gnome-screenshot' is not installed, so not removed
                                        Package 'gnome-snapshot' is not installed, so not removed
                                        Package 'gnome-characters' is not installed, so not removed
                                        Package 'gnome-disk-utility' is not installed, so not removed
                                        Package 'gnome-font-viewer' is not installed, so not removed
                                        Package 'gnome-games' is not installed, so not removed
                                        Package 'gnome-logs' is not installed, so not removed
                                        Package 'gnome-sound-recorder' is not installed, so not removed
                                        Package 'gnome-system-monitor' is not installed, so not removed
                                        Package 'gnome-connections' is not installed, so not removed
                                        Package 'gnome-color-manager' is not installed, so not removed
                                        Package 'gnome-desktop-testing' is not installed, so not removed
                                        Package 'gnome-accessibility-themes' is not installed, so not removed
                                        Package 'gnome-builder' is not installed, so not removed
                                        Package 'gnome-mines' is not installed, so not removed
                                        Package 'gnome-mahjongg' is not installed, so not removed
                                        Package 'gnomekiss' is not installed, so not removed
                                        Package 'gnome-clocks' is not installed, so not removed
                                        Package 'gnome-nibbles' is not installed, so not removed
                                        Package 'gnome-sudoku' is not installed, so not removed
                                        Package 'gnome-metronome' is not installed, so not removed
                                        Package 'gnome-pkg-tools' is not installed, so not removed
                                        Package 'gnome' is not installed, so not removed
                                        Package 'gnome-ponytail-daemon' is not installed, so not removed
                                        Package 'gnome-human-icon-theme' is not installed, so not removed
                                        Package 'gnome-epub-thumbnailer' is not installed, so not removed
                                        Package 'gnome-shell-extension-gamemode' is not installed, so not removed
                                        Package 'gnome-icon-theme-gartoon' is not installed, so not removed
                                        Package 'gnome-session' is not installed, so not removed
                                        Package 'gnome-session-bin' is not installed, so not removed
                                        Package 'gnome-session-common' is not installed, so not removed
                                        Package 'gnome-shell' is not installed, so not removed
                                        Package 'gnome-genius' is not installed, so not removed
                                        Package 'gnome-initial-setup' is not installed, so not removed
                                        Package 'gnome-maps' is not installed, so not removed
                                        Package 'gnome-2048' is not installed, so not removed
                                        Package 'gnome-activity-journal' is not installed, so not removed
                                        Package 'gnome-applets' is not installed, so not removed
                                        Package 'gnome-applets-data' is not installed, so not removed
                                        Package 'gnome-panel' is not installed, so not removed
                                        Package 'gnome-flashback' is not installed, so not removed
                                        Package 'gnome-audio' is not installed, so not removed
                                        Package 'gnome-core' is not installed, so not removed
                                        Package 'gnome-authenticator' is not installed, so not removed
                                        Package 'gnome-bluetooth-3-common' is not installed, so not removed
                                        Package 'gnome-bluetooth-sendto' is not installed, so not removed
                                        Package 'gnome-boxes' is not installed, so not removed
                                        Package 'gnome-breakout' is not installed, so not removed
                                        Package 'gnome-browser-connector' is not installed, so not removed
                                        Package 'gnome-calendar' is not installed, so not removed
                                        Package 'gnome-contacts' is not installed, so not removed
                                        Package 'gnome-calls-doc' is not installed, so not removed
                                        Package 'gnome-chess' is not installed, so not removed
                                        Package 'gnome-brave-icon-theme' is not installed, so not removed
                                        Package 'gnome-colors-common' is not installed, so not removed
                                        Package 'gnome-colors' is not installed, so not removed
                                        Package 'gnome-dust-icon-theme' is not installed, so not removed
                                        Package 'gnome-illustrious-icon-theme' is not installed, so not removed
                                        Package 'gnome-noble-icon-theme' is not installed, so not removed
                                        Package 'gnome-wine-icon-theme' is not installed, so not removed
                                        Package 'gnome-wise-icon-theme' is not installed, so not removed
                                        Package 'gnome-commander' is not installed, so not removed
                                        Package 'gnome-commander-data' is not installed, so not removed
                                        Package 'gnome-console' is not installed, so not removed
                                        Package 'gnome-control-center-data' is not installed, so not removed
                                        Package 'gnome-online-accounts' is not installed, so not removed
                                        Package 'gnome-remote-desktop' is not installed, so not removed
                                        Package 'gnome-control-center-dev' is not installed, so not removed
                                        Package 'gnome-decoder' is not installed, so not removed
                                        Package 'gnome-desktop-3-tests' is not installed, so not removed
                                        Package 'gnome-extra-icons' is not installed, so not removed
                                        Package 'gnome-feeds' is not installed, so not removed
                                        Package 'gnome-firmware' is not installed, so not removed
                                        Package 'gnome-flashback-common' is not installed, so not removed
                                        Package 'gnome-session-flashback' is not installed, so not removed
                                        Package 'gnome-hwp-support' is not installed, so not removed
                                        Package 'gnome-icon-theme-nuovo' is not installed, so not removed
                                        Package 'gnome-icon-theme-yasis' is not installed, so not removed
                                        Package 'gnome-keyring-pkcs11' is not installed, so not removed
                                        Package 'gnome-keysign' is not installed, so not removed
                                        Package 'gnome-kiosk' is not installed, so not removed
                                        Package 'gnome-kiosk-search-appliance' is not installed, so not removed
                                        Package 'gnome-kiosk-script-session' is not installed, so not removed
                                        Package 'gnome-klotski' is not installed, so not removed
                                        Package 'gnome-mastermind' is not installed, so not removed
                                        Package 'gnome-model-thumbnailer' is not installed, so not removed
                                        Package 'gnome-mousetrap' is not installed, so not removed
                                        Package 'gnome-multi-writer' is not installed, so not removed
                                        Package 'gnome-music' is not installed, so not removed
                                        Package 'gnome-nds-thumbnailer' is not installed, so not removed
                                        Package 'gnome-nettool' is not installed, so not removed
                                        Package 'gnome-network-displays' is not installed, so not removed
                                        Package 'gnome-packagekit-common' is not installed, so not removed
                                        Package 'gnome-pass-search-provider' is not installed, so not removed
                                        Package 'gnome-photos' is not installed, so not removed
                                        Package 'gnome-photos-tests' is not installed, so not removed
                                        Package 'gnome-pie' is not installed, so not removed
                                        Package 'gnome-podcasts' is not installed, so not removed
                                        Package 'gnome-settings-daemon-common' is not installed, so not removed
                                        Package 'gnome-recipes' is not installed, so not removed
                                        Package 'gnome-recipes-data' is not installed, so not removed
                                        Package 'gnome-robots' is not installed, so not removed
                                        Package 'gnome-screensaver-flags' is not installed, so not removed
                                        Package 'gnome-session-xsession' is not installed, so not removed
                                        Package 'gnome-settings-daemon-dev' is not installed, so not removed
                                        Package 'gnome-shell-common' is not installed, so not removed
                                        Package 'gnome-shell-extension-dash-to-panel' is not installed, so not removed
                                        Package 'gnome-shell-extension-dashtodock' is not installed, so not removed
                                        Package 'gnome-shell-extension-desktop-icons-ng' is not installed, so not removed
                                        Package 'gnome-shell-extensions' is not installed, so not removed
                                        Package 'gnome-shell-extension-prefs' is not installed, so not removed
                                        Package 'gnome-shell-extension-arc-menu' is not installed, so not removed
                                        Package 'gnome-shell-extension-autohidetopbar' is not installed, so not removed
                                        Package 'gnome-shell-extension-blur-my-shell' is not installed, so not removed
                                        Package 'gnome-shell-extension-caffeine' is not installed, so not removed
                                        Package 'gnome-shell-extension-manager' is not installed, so not removed
                                        Package 'gnome-shell-extension-easyscreencast' is not installed, so not removed
                                        Package 'gnome-shell-extension-flypie' is not installed, so not removed
                                        Package 'gnome-shell-extension-freon' is not installed, so not removed
                                        Package 'gnome-shell-extension-gsconnect' is not installed, so not removed
                                        Package 'gnome-shell-extension-gsconnect-browsers' is not installed, so not removed
                                        Package 'gnome-shell-extension-hamster' is not installed, so not removed
                                        Package 'gnome-shell-extension-hard-disk-led' is not installed, so not removed
                                        Package 'gnome-shell-extension-hide-activities' is not installed, so not removed
                                        Package 'gnome-shell-extension-impatience' is not installed, so not removed
                                        Package 'gnome-shell-extension-kimpanel' is not installed, so not removed
                                        Package 'gnome-shell-extension-no-annoyance' is not installed, so not removed
                                        Package 'gnome-shell-extension-runcat' is not installed, so not removed
                                        Package 'gnome-shell-extension-shortcuts' is not installed, so not removed
                                        Package 'gnome-shell-extension-tiling-assistant' is not installed, so not removed
                                        Package 'gnome-shell-extension-weather' is not installed, so not removed
                                        Package 'gnome-classic' is not installed, so not removed
                                        Package 'gnome-shell-extension-apps-menu' is not installed, so not removed
                                        Package 'gnome-shell-extension-places-menu' is not installed, so not removed
                                        Package 'gnome-shell-extension-launch-new-instance' is not installed, so not removed
                                        Package 'gnome-shell-extension-window-list' is not installed, so not removed
                                        Package 'gnome-classic-xsession' is not installed, so not removed
                                        Package 'gnome-shell-extensions-common' is not installed, so not removed
                                        Package 'gnome-shell-extension-auto-move-windows' is not installed, so not removed
                                        Package 'gnome-shell-extension-drive-menu' is not installed, so not removed
                                        Package 'gnome-shell-extension-light-style' is not installed, so not removed
                                        Package 'gnome-shell-extension-native-window-placement' is not installed, so not removed
                                        Package 'gnome-shell-extension-screenshot-window-sizer' is not installed, so not removed
                                        Package 'gnome-shell-extension-status-icons' is not installed, so not removed
                                        Package 'gnome-shell-extension-system-monitor' is not installed, so not removed
                                        Package 'gnome-shell-extension-user-theme' is not installed, so not removed
                                        Package 'gnome-shell-extension-windows-navigator' is not installed, so not removed
                                        Package 'gnome-shell-extension-workspace-indicator' is not installed, so not removed
                                        Package 'gnome-shell-extensions-extra' is not installed, so not removed
                                        Package 'gnome-tweaks' is not installed, so not removed
                                        Package 'gnome-shell-pomodoro' is not installed, so not removed
                                        Package 'gnome-shell-pomodoro-data' is not installed, so not removed
                                        Package 'gnome-software-plugin-deb' is not installed, so not removed
                                        Package 'gnome-software-common' is not installed, so not removed
                                        Package 'gnome-software-plugin-fwupd' is not installed, so not removed
                                        Package 'gnome-software-plugin-flatpak' is not installed, so not removed
                                        Package 'gnome-software-plugin-snap' is not installed, so not removed
                                        Package 'gnome-software-dev' is not installed, so not removed
                                        Package 'gnome-software-doc' is not installed, so not removed
                                        Package 'gnome-sushi' is not installed, so not removed
                                        Package 'gnome-system-tools' is not installed, so not removed
                                        Package 'gnome-taquin' is not installed, so not removed
                                        Package 'gnome-terminal-data' is not installed, so not removed
                                        Package 'gnome-tetravex' is not installed, so not removed
                                        Package 'gnome-tour' is not installed, so not removed
                                        Package 'gnome-usage' is not installed, so not removed
                                        Package 'gnome-video-effects-dev' is not installed, so not removed
                                        Package 'gnome-video-trimmer' is not installed, so not removed
                                        Package 'gnome-weather' is not installed, so not removed
                                        Package 'gnome-shell-extension-gpaste' is not installed, so not removed
                                        Package 'gnome-api-docs' is not installed, so not removed
                                        Package 'gnome-devel' is not installed, so not removed
                                        Package 'gnome-platform-devel' is not installed, so not removed
                                        Package 'gnome-theme-gilouche' is not installed, so not removed
                                        Package 'gnome-panel-control' is not installed, so not removed
                                        Package 'gnome-icon-theme-suede' is not installed, so not removed
                                        Package 'gnome-panel-control-dbgsym' is not installed, so not removed
                                        Package 'gstreamer1.0-plugins-ugly' is not installed, so not removed
                                        Package 'gstreamer1.0-pipewire' is not installed, so not removed
                                        Package 'gstreamer1.0-pulseaudio' is not installed, so not removed
                                        Package 'gstreamer1.0-tools' is not installed, so not removed
                                        Package 'gstreamer1.0-clutter-3.0' is not installed, so not removed
                                        Package 'gstreamer1.0-nice' is not installed, so not removed
                                        Package 'gstreamer1.0-gl' is not installed, so not removed
                                        Package 'gstreamer1.0-gtk3' is not installed, so not removed
                                        Package 'gstreamer1.0-gtk4' is not installed, so not removed
                                        Package 'gstreamer1.0-libcamera' is not installed, so not removed
                                        Package 'gstreamer1.0-opencv' is not installed, so not removed
                                        Package 'gstreamer1.0-plugins-bad-apps' is not installed, so not removed
                                        Package 'gstreamer1.0-wpe' is not installed, so not removed
                                        Package 'gstreamer1.0-plugins-base-apps' is not installed, so not removed
                                        Package 'gstreamer1.0-espeak' is not installed, so not removed
                                        Package 'gstreamer1.0-qt5' is not installed, so not removed
                                        Package 'gstreamer1.0-qt6' is not installed, so not removed
                                        Package 'gstreamer1.0-plugins-rtp' is not installed, so not removed
                                        Package 'gstreamer1.0-python3-plugin-loader' is not installed, so not removed
                                        Package 'gstreamer1.0-rtsp' is not installed, so not removed
                                        Package 'gstreamer1.0-vaapi' is not installed, so not removed
                                        Package 'gstreamer1.0-packagekit' is not installed, so not removed
                                        Package 'gstreamer1.0-pocketsphinx' is not installed, so not removed
                                        Package 'gstreamer1.0-adapter-pulseeffects' is not installed, so not removed
                                        Package 'gstreamer1.0-autogain-pulseeffects' is not installed, so not removed
                                        Package 'gstreamer1.0-convolver-pulseeffects' is not installed, so not removed
                                        Package 'gstreamer1.0-crystalizer-pulseeffects' is not installed, so not removed
                                        Package 'gstreamer1.0-fdkaac' is not installed, so not removed
                                        Package 'gstreamer1.0-alsa-dbgsym' is not installed, so not removed
                                        Package 'gstreamer1.0-gl-dbgsym' is not installed, so not removed
                                        Package 'gstreamer1.0-libcamera-dbgsym' is not installed, so not removed
                                        Package 'gstreamer1.0-opencv-dbgsym' is not installed, so not removed
                                        Package 'gstreamer1.0-pipewire-dbgsym' is not installed, so not removed
                                        Package 'gstreamer1.0-pispconvert' is not installed, so not removed
                                        Package 'gstreamer1.0-pispconvert-dbgsym' is not installed, so not removed
                                        Package 'gstreamer1.0-plugins-bad-apps-dbgsym' is not installed, so not removed
                                        Package 'gstreamer1.0-plugins-bad-dbgsym' is not installed, so not removed
                                        Package 'gstreamer1.0-plugins-base-apps-dbgsym' is not installed, so not removed
                                        Package 'gstreamer1.0-plugins-base-dbgsym' is not installed, so not removed
                                        Package 'gstreamer1.0-wpe-dbgsym' is not installed, so not removed
                                        Package 'gstreamer1.0-x-dbgsym' is not installed, so not removed
                                        Package 'gtk2-engines-murrine' is not installed, so not removed
                                        Package 'gtkmm-documentation' is not installed, so not removed
                                        Package 'gtkwave' is not installed, so not removed
                                        Package 'gtkatlantic' is not installed, so not removed
                                        Package 'gtkballs' is not installed, so not removed
                                        Package 'gtklp' is not installed, so not removed
                                        Package 'gtk-3-examples' is not installed, so not removed
                                        Package 'gtk-chtheme' is not installed, so not removed
                                        Package 'gtk-doc-tools' is not installed, so not removed
                                        Package 'gtk-im-libthai' is not installed, so not removed
                                        Package 'gtk3-im-libthai' is not installed, so not removed
                                        Package 'gtk-layer-shell-doc' is not installed, so not removed
                                        Package 'gtk-layer-shell-examples' is not installed, so not removed
                                        Package 'gtk-meshtastic-client' is not installed, so not removed
                                        Package 'gtk-session-lock-examples' is not installed, so not removed
                                        Package 'gtk-theme-switch' is not installed, so not removed
                                        Package 'gtk2-engines-aurora' is not installed, so not removed
                                        Package 'gtk2hs-buildtools' is not installed, so not removed
                                        Package 'gtk3-nocsd' is not installed, so not removed
                                        Package 'gtk-4-examples' is not installed, so not removed
                                        Package 'gtk-4-tests' is not installed, so not removed
                                        Package 'gtk4-layer-shell-doc' is not installed, so not removed
                                        Package 'gtk4-layer-shell-examples' is not installed, so not removed
                                        Package 'gtkam' is not installed, so not removed
                                        Package 'gtkcrypto' is not installed, so not removed
                                        Package 'gtkgreet' is not installed, so not removed
                                        Package 'gtkhash' is not installed, so not removed
                                        Package 'gtklock' is not installed, so not removed
                                        Package 'gtklock-playerctl-module' is not installed, so not removed
                                        Package 'gtklock-userinfo-module' is not installed, so not removed
                                        Package 'gtkman' is not installed, so not removed
                                        Package 'gtkterm' is not installed, so not removed
                                        Package 'gtk2-engines-qtcurve' is not installed, so not removed
                                        Package 'gtkmorph-example' is not installed, so not removed
                                        Package 'gtk-3-examples-dbgsym' is not installed, so not removed
                                        Package 'gtk-nop-dbgsym' is not installed, so not removed
                                        Package 'gtk2-engines-clearlookspix' is not installed, so not removed
                                        Package 'gtk2-engines-clearlookspix-dbgsym' is not installed, so not removed
                                        Package 'gtk2-engines-pixbuf-dbgsym' is not installed, so not removed
                                        Package 'gtk2-engines-pixflat-dbgsym' is not installed, so not removed
                                        Package 'lxc' is not installed, so not removed
                                        Package 'lxd' is not installed, so not removed
                                        Package 'lxqt-policykit' is not installed, so not removed
                                        Package 'lxi-tools' is not installed, so not removed
                                        Package 'lxc-dev' is not installed, so not removed
                                        Package 'lxqt-menu-data' is not installed, so not removed
                                        Package 'lxcfs' is not installed, so not removed
                                        Package 'lxd-tools' is not installed, so not removed
                                        Package 'lxqt-build-tools' is not installed, so not removed
                                        Package 'lx-gdb' is not installed, so not removed
                                        Package 'lxc-templates' is not installed, so not removed
                                        Package 'lxc-tests' is not installed, so not removed
                                        Package 'lxctl' is not installed, so not removed
                                        Package 'lxd-client' is not installed, so not removed
                                        Package 'lxd-agent' is not installed, so not removed
                                        Package 'lxd-migrate' is not installed, so not removed
                                        Package 'lxlock' is not installed, so not removed
                                        Package 'lxlauncher' is not installed, so not removed
                                        Package 'lxinput' is not installed, so not removed
                                        Package 'lxmusic' is not installed, so not removed
                                        Package 'lxdm' is not installed, so not removed
                                        Package 'lxhotkey-plugin-openbox' is not installed, so not removed
                                        Package 'lxhotkey-data' is not installed, so not removed
                                        Package 'lxhotkey-dev' is not installed, so not removed
                                        Package 'lximage-qt' is not installed, so not removed
                                        Package 'lximage-qt-l10n' is not installed, so not removed
                                        Package 'lxpanel-dev' is not installed, so not removed
                                        Package 'lxqt-about' is not installed, so not removed
                                        Package 'lxqt-about-l10n' is not installed, so not removed
                                        Package 'lxqt-qtplugin' is not installed, so not removed
                                        Package 'lxqt-admin' is not installed, so not removed
                                        Package 'lxqt-admin-l10n' is not installed, so not removed
                                        Package 'lxqt-archiver' is not installed, so not removed
                                        Package 'lxqt-archiver-l10n' is not installed, so not removed
                                        Package 'lxqt-branding-debian' is not installed, so not removed
                                        Package 'lxqt-theme-debian' is not installed, so not removed
                                        Package 'lxqt-system-theme' is not installed, so not removed
                                        Package 'lxqt-build-tools-qt5' is not installed, so not removed
                                        Package 'lxqt-config' is not installed, so not removed
                                        Package 'lxqt-config-l10n' is not installed, so not removed
                                        Package 'lxqt-powermanagement' is not installed, so not removed
                                        Package 'lxqt-session' is not installed, so not removed
                                        Package 'lxqt' is not installed, so not removed
                                        Package 'lxqt-core' is not installed, so not removed
                                        Package 'lxqt-globalkeys' is not installed, so not removed
                                        Package 'lxqt-globalkeys-l10n' is not installed, so not removed
                                        Package 'lxqt-panel' is not installed, so not removed
                                        Package 'lxqt-openssh-askpass' is not installed, so not removed
                                        Package 'lxqt-sudo' is not installed, so not removed
                                        Package 'lxqt-themes' is not installed, so not removed
                                        Package 'lxqt-notificationd' is not installed, so not removed
                                        Package 'lxqt-runner' is not installed, so not removed
                                        Package 'lxqt-notificationd-l10n' is not installed, so not removed
                                        Package 'lxqt-openssh-askpass-l10n' is not installed, so not removed
                                        Package 'lxqt-panel-l10n' is not installed, so not removed
                                        Package 'lxqt-policykit-l10n' is not installed, so not removed
                                        Package 'lxqt-powermanagement-l10n' is not installed, so not removed
                                        Package 'lxqt-qt5plugin' is not installed, so not removed
                                        Package 'lxqt-runner-l10n' is not installed, so not removed
                                        Package 'lxqt-session-l10n' is not installed, so not removed
                                        Package 'lxqt-sudo-l10n' is not installed, so not removed
                                        Package 'lxsession-default-apps' is not installed, so not removed
                                        Package 'lxpanel-pi' is not installed, so not removed
                                        Package 'lxpanel-pi-dbgsym' is not installed, so not removed
                                        Package 'lxpanel-pi-dev' is not installed, so not removed
                                        Package 'lxpanel-pi-dev-dbgsym' is not installed, so not removed
                                        Package 'lxpolkit-dbgsym' is not installed, so not removed
                                        Package 'lxsession-dbgsym' is not installed, so not removed
                                        Package 'lxsession-default-apps-dbgsym' is not installed, so not removed
                                        Package 'lxsession-edit-dbgsym' is not installed, so not removed
                                        Package 'lxsession-logout-dbgsym' is not installed, so not removed
                                        Package 'lxtask-dbgsym' is not installed, so not removed
                                        Package 'lxterminal-dbgsym' is not installed, so not removed
                                        Package 'mesa-utils' is not installed, so not removed
                                        Package 'mesa-common-dev' is not installed, so not removed
                                        Package 'mesa-opencl-icd' is not installed, so not removed
                                        Package 'mesa-va-drivers' is not installed, so not removed
                                        Package 'mesaflash' is not installed, so not removed
                                        Package 'mesa-drm-shim' is not installed, so not removed
                                        Package 'mesa-teflon-delegate' is not installed, so not removed
                                        Package 'mesa-vulkan-drivers' is not installed, so not removed
                                        Package 'mesa-utils-bin' is not installed, so not removed
                                        Package 'mesa-drm-shim-dbgsym' is not installed, so not removed
                                        Package 'mesa-libgallium-dbgsym' is not installed, so not removed
                                        Package 'mesa-opencl-icd-dbgsym' is not installed, so not removed
                                        Package 'mesa-teflon-delegate-dbgsym' is not installed, so not removed
                                        Package 'mesa-vulkan-drivers-dbgsym' is not installed, so not removed
                                        You might want to run 'apt --fix-broken install' to correct these.
                                        The following packages have unmet dependencies:
                                         adwaita-icon-theme : Depends: gtk-update-icon-cache
                                                              Depends: hicolor-icon-theme but it is not going to be installed
                                         alacarte : Depends: gnome-menus (>= 3.5.3) but it is not going to be installed
                                         evince : Depends: libglib2.0-0t64 (>= 2.83.0) but it is not going to be installed
                                                  Depends: libgtk-3-0t64 (>= 3.22.0) but it is not going to be installed
                                         galculator : Depends: libglib2.0-0t64 (>= 2.16.0) but it is not going to be installed
                                                      Depends: libgtk-3-0t64 (>= 3.3.16) but it is not going to be installed
                                         gcr : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                         gcr4 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                         geany : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                                 Depends: libgtk-3-0t64 (>= 3.21.5) but it is not going to be installed
                                         gir1.2-glib-2.0 : Depends: libglib2.0-0t64 (= 2.84.4-3~deb13u3) but it is not going to be installed
                                         gir1.2-gtk-3.0 : Depends: libgtk-3-0t64 (>= 3.24.36-2+rpt1) but it is not going to be installed
                                         girepository-tools : Depends: libglib2.0-0t64 (= 2.84.4-3~deb13u3) but it is not going to be installed
                                         gui-pkinst : Depends: libglib2.0-0t64 (>= 2.22.0) but it is not going to be installed
                                                      Depends: libgtk-3-0t64 (>= 3.24) but it is not going to be installed
                                         gui-updater : Depends: libglib2.0-0t64 (>= 2.14.0) but it is not going to be installed
                                         gvfs : Depends: libglib2.0-0t64 (>= 2.83.0) but it is not going to be installed
                                         gvfs-backends : Depends: libglib2.0-0t64 (>= 2.83.0) but it is not going to be installed
                                                         Recommends: gnome-keyring or
        kwalletmanager but it is not going to be installed
                                                         Recommends: wsdd but it is not installable
                                         gvfs-common : Depends: desktop-file-utils
                                         gvfs-daemons : Depends: libglib2.0-0t64 (>= 2.83.0) but it is not going to be installed
                                         gvfs-fuse : Depends: libglib2.0-0t64 (>= 2.83.0) but it is not going to be installed
                                         gvfs-libs : Depends: libglib2.0-0t64 (>= 2.83.0) but it is not going to be installed
                                         libadwaita-1-0 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                         libappstream5 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                         libatk1.0-0t64 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                         libatkmm-1.6-1v5 : Depends: libglib2.0-0t64 (>= 2.34.0) but it is not going to be installed
                                         libavahi-glib1 : Depends: libglib2.0-0t64 (>= 2.16.0) but it is not going to be installed
                                         libavcodec61 : Depends: libglib2.0-0t64 (>= 2.12.0) but it is not going to be installed
                                         libayatana-ido3-0.4-0 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
        Depends: libgtk-3-0t64 (>= 3.21.4) but it is not going to be installed
                                         libayatana-indicator3-7 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                         libbabeltrace1 : Depends: libglib2.0-0t64 (>= 2.76.0) but it is not going to be installed
                                         libcairo-gobject2 : Depends: libglib2.0-0t64 (>= 2.68.0) but it is not going to be installed
                                         libcamera0.5 : Depends: libcamera-ipa (= 0.5.2+rpt20250903-1~bpo12+1) but 0.7.1+rpt20260609-1 is to be installed
                                         libcloudproviders0 : Depends: libglib2.0-0t64 (>= 2.56.0) but it is not going to be installed
                                         libegl-mesa0 : Depends: mesa-libgallium (= 25.0.7-2+rpt4) but it is not going to be installed
                                         libevdocument3-4t64 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                         libevview3-3t64 : Depends: gstreamer1.0-plugins-base but it is not going to be installed
                                         libfm-extra4t64 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                         libfm-gtk3-4t64 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                         libfm-modules : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                                         Depends: libgtk-3-0t64 (>= 3.0.0) but it is not going to be installed
                                         libfm4t64 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                                     Depends: lxmenu-data but it is not going to be installed
                                         libgbm1 : Depends: mesa-libgallium (= 25.0.7-2+rpt4) but it is not going to be installed
                                         libgck-1-0 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                         libgck-2-2 : Depends: libglib2.0-0t64 (>= 2.74.0) but it is not going to be installed
                                         libgcr-4-4 : Depends: libglib2.0-0t64 (>= 2.74.0) but it is not going to be installed
                                         libgcr-base-3-1 : Depends: libglib2.0-0t64 (>= 2.83.0) but it is not going to be installed
                                         libgcr-ui-3-1 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                         libgio-2.0-dev : Depends: libglib2.0-0t64 (= 2.84.4-3~deb13u3) but it is not going to be installed
                                         libgio-2.0-dev-bin : Depends: libglib2.0-0t64 (= 2.84.4-3~deb13u3) but it is not going to be installed
                                         libgirepository-1.0-1 : Depends: libglib2.0-0t64 (>= 2.82.0) but it is not going to be installed
                                         libgirepository-2.0-0 : Depends: libglib2.0-0t64 (= 2.84.4-3~deb13u3) but it is not going to be installed
                                         libglib2.0-bin : Depends: libglib2.0-0t64 (= 2.84.4-3~deb13u3) but it is not going to be installed
                                         libglibmm-2.4-1t64 : Depends: libglib2.0-0t64 (>= 2.62.0) but it is not going to be installed
                                         libglx-mesa0 : Depends: mesa-libgallium (= 25.0.7-2+rpt4) but it is not going to be installed
                                         libgnome-desktop-3-20t64 : Depends: gnome-desktop3-data (>= 44.3-3) but it is not going to be installed
        Depends: gnome-desktop3-data (< 45~) but it is not going to be installed
        Depends: libgtk-3-0t64 (>= 3.9.10) but it is not going to be installed
                                         libgoa-1.0-0b : Depends: libglib2.0-0t64 (>= 2.83.0) but it is not going to be installed
                                         libgraphene-1.0-0 : Depends: libglib2.0-0t64 (>= 2.14.0) but it is not going to be installed
                                         libgspell-1-3 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                                         Depends: libgtk-3-0t64 (>= 3.20) but it is not going to be installed
                                         libgstreamer-gl1.0-0 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
        Recommends: gstreamer1.0-gl but it is not going to be installed
                                         libgstreamer-plugins-bad1.0-0 : Depends: libglib2.0-0t64 (>= 2.81.1) but it is not going to be installed
                                         libgstreamer-plugins-base1.0-0 : Depends: libglib2.0-0t64 (>= 2.81.1) but it is not going to be installed
        Recommends: gstreamer1.0-plugins-base but it is not going to be installed
                                         libgstreamer1.0-0 : Depends: libglib2.0-0t64 (>= 2.81.1) but it is not going to be installed
                                         libgtk-3-0 : Depends: hicolor-icon-theme but it is not going to be installed
                                                      Recommends: libgtk-3-bin
                                         libgtk-4-1 : Depends: hicolor-icon-theme but it is not going to be installed
                                                      Recommends: libgtk-4-bin
                                                      Recommends: libgtk-4-media-gstreamer
                                         libgtk-layer-shell0 : Depends: libglib2.0-0t64 (>= 2.42.0) but it is not going to be installed
                                                               Depends: libgtk-3-0t64 (>= 3.24.48) but it is not going to be installed
                                         libgtk2.0-0 : Depends: hicolor-icon-theme but it is not going to be installed
                                                       Recommends: libgail-common but it is not going to be installed
                                         libgtk2.0-bin : Depends: gtk-update-icon-cache
                                         libgtkmm-3.0-1t64 : Depends: libglib2.0-0t64 (>= 2.42.0) but it is not going to be installed
                                                             Depends: libgtk-3-0t64 (>= 3.24.0) but it is not going to be installed
                                         libgtksourceview-4-0 : Depends: libglib2.0-0t64 (>= 2.48.0) but it is not going to be installed
                                         libgxps2t64 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                         libhandy-1-0 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                                        Depends: libgtk-3-0t64 (>= 3.23.1) but it is not going to be installed
                                         libharfbuzz-gobject0 : Depends: libglib2.0-0t64 (>= 2.14.0) but it is not going to be installed
                                         libharfbuzz0b : Depends: libglib2.0-0t64 (>= 2.32.0) but it is not going to be installed
                                         libinput-tools : Depends: libglib2.0-0t64 (>= 2.30.0) but it is not going to be installed
                                                          Depends: libgtk-3-0t64 (>= 3.19.12) but it is not going to be installed
                                         libinput10 : Depends: libmtdev1t64 (>= 1.1.0) but it is not going to be installed
                                         libjavascriptcoregtk-4.1-0 : Depends: libglib2.0-0t64 (>= 2.66.0) but it is not going to be installed
                                         libkeybinder-3.0-0 : Depends: libglib2.0-0t64 (>= 2.12.0) but it is not going to be installed
                                         libmate-desktop-2-17t64 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                         libmenu-cache-bin : Depends: libglib2.0-0t64 (>= 2.76.0) but it is not going to be installed
                                         libmousepad0 : Depends: libglib2.0-0t64 (>= 2.56.0) but it is not going to be installed
                                         libmsgraph-1-1 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                         libnetplan1 : Depends: libglib2.0-0t64 (>= 2.76.0) but it is not going to be installed
                                         libnm0 : Depends: libglib2.0-0t64 (>= 2.44.0) but it is not going to be installed
                                         libnma0 : Depends: libglib2.0-0t64 (>= 2.38.0) but it is not going to be installed
                                         libpango-1.0-0 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                         libpangocairo-1.0-0 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                         libpangoft2-1.0-0 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                         libpangomm-1.4-1v5 : Depends: libglib2.0-0t64 (>= 2.34.0) but it is not going to be installed
                                         libpangoxft-1.0-0 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                         libpeas-1.0-0 : Depends: libglib2.0-0t64 (>= 2.44.0) but it is not going to be installed
                                         libpipewire-0.3-modules : Depends: libglib2.0-0t64 (>= 2.32.0) but it is not going to be installed
                                         libpoppler-glib8t64 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                         libproxy1v5 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                         libqt5ct-common1.8 : Depends: libqt5core5t64 (>= 5.9~) but it is not going to be installed
                                                              Depends: libqt5gui5t64 (>= 5.9~) but it is not going to be installed or
        libqt5gui5-gles (>= 5.9~) but it is not going to be installed
                                         libqt6core6t64 : Depends: libglib2.0-0t64 (>= 2.26.0) but it is not going to be installed
                                         libqt6gui6 : Depends: libglib2.0-0t64 (>= 2.26.0) but it is not going to be installed
                                                      Depends: libmtdev1t64 (>= 1.0.8) but it is not going to be installed
                                                      Recommends: qt6-svg-plugins but it is not going to be installed
                                                      Recommends: qt6-wayland but it is not going to be installed
                                         libqt6network6 : Depends: libglib2.0-0t64 (>= 2.46.0) but it is not going to be installed
                                         libqt6opengl6 : Depends: libmtdev1t64 (>= 1.0.8) but it is not going to be installed
                                         libsane1 : Depends: libglib2.0-0t64 (>= 2.34.0) but it is not going to be installed
                                         libspa-0.2-bluetooth : Depends: libglib2.0-0t64 (>= 2.83.0) but it is not going to be installed
                                         libudev-dev : Depends: libudev1 (= 257.13-1~deb13u1) but 252.39-1~deb12u2 is to be installed
                                         libvolume-key1 : Depends: libglib2.0-0t64 (>= 2.18.0) but it is not going to be installed
                                         libvte-2.91-0 : Depends: libglib2.0-0t64 (>= 2.78.0) but it is not going to be installed
                                         libwacom9 : Depends: libglib2.0-0t64 (>= 2.68.0) but it is not going to be installed
                                         libwebkit2gtk-4.1-0 : Depends: gstreamer1.0-plugins-base but it is not going to be installed
                                                               Depends: gstreamer1.0-plugins-good but it is not going to be installed
                                                               Depends: libgtk-3-0t64 (>= 3.23.0) but it is not going to be installed
                                                               Recommends: gstreamer1.0-libav but it is not going to be installed
                                                               Recommends: gstreamer1.0-plugins-bad but it is not going to be installed
                                         libwnck-3-0 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                         libxfce4ui-2-0 : Depends: libglib2.0-0t64 (>= 2.70.0) but it is not going to be installed
                                         libxfce4util7 : Depends: libglib2.0-0t64 (>= 2.70.0) but it is not going to be installed
                                                         Recommends: libxfce4util-bin but it is not going to be installed
                                         libxfconf-0-3 : Depends: libglib2.0-0t64 (>= 2.56.0) but it is not going to be installed
                                         libxmlb2 : Depends: libglib2.0-0t64 (>= 2.54.0) but it is not going to be installed
                                         lp-connection-editor : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                         mate-polkit : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                                       Depends: libgtk-3-0t64 (>= 3.16.2) but it is not going to be installed
                                         mousepad : Depends: libglib2.0-0t64 (>= 2.38.0) but it is not going to be installed
                                                    Depends: libgtk-3-0t64 (>= 3.13.7) but it is not going to be installed
                                         netplan-generator : Depends: libglib2.0-0t64 (>= 2.70.0) but it is not going to be installed
                                         netplan.io : Depends: libglib2.0-0t64 (>= 2.70.0) but it is not going to be installed
                                                      Recommends: python3-rich but it is not going to be installed
                                         network-manager : Depends: libglib2.0-0t64 (>= 2.68.0) but it is not going to be installed
                                                           Recommends: network-manager-l10n but it is not going to be installed
                                         notification-daemon : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                         obconf : Depends: libglib2.0-0t64 (>= 2.36.0) but it is not going to be installed
                                         openbox-lxde-session : Depends: lxde-common but it is not going to be installed
        Depends: lxsession but it is not going to be installed
                                         openssh-sftp-server : Depends: openssh-client (= 1:9.2p1-2+deb12u10)
                                         pango1.0-tools : Depends: libglib2.0-0t64 (>= 2.80) but it is not going to be installed
                                         pcmanfm : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                                   Recommends: lxde-icon-theme but it is not going to be installed or
                                                               gnome-icon-theme but it is not going to be installed or
                                                               oxygen-icon-theme but it is not going to be installed or
                                                               tango-icon-theme but it is not going to be installed
                                         pi-package : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                         pi-package-session : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                         piclone : Depends: libglib2.0-0t64 (>= 2.32.0) but it is not going to be installed
                                         pipanel : Depends: libglib2.0-0t64 (>= 2.36.0) but it is not going to be installed
                                         pishutdown : Depends: libglib2.0-0t64 (>= 2.26.0) but it is not going to be installed
                                         piwiz : Depends: libglib2.0-0t64 (>= 2.32.0) but it is not going to be installed
                                         pixflat-theme : Depends: gtk2-engines-pixbuf but it is not going to be installed
                                                         Depends: gtk2-engines-pixflat but it is not going to be installed
                                         pplug-ejecter-data : Depends: gtk-update-icon-cache
                                         pplug-power-data : Depends: gtk-update-icon-cache
                                         pplug-updater-data : Depends: gtk-update-icon-cache
                                         python3-dbus : Depends: libglib2.0-0t64 (>= 2.16.0) but it is not going to be installed
                                         python3-gi : Depends: libglib2.0-0t64 (>= 2.78.0) but it is not going to be installed
                                         python3-pyqt5 : Depends: libqt5printsupport5 (>= 5.15)
                                         qt5-gtk-platformtheme : Depends: libglib2.0-0t64 (>= 2.34.0) but it is not going to be installed
        Depends: libqt5core5t64 (>= 5.15.1) but it is not going to be installed
        Depends: libqt5dbus5t64 (>= 5.14.1) but it is not going to be installed
        Depends: libqt5gui5t64 (>= 5.14.1) but it is not going to be installed or
        libqt5gui5-gles (>= 5.14.1) but it is not going to be installed
        Depends: qtbase-abi-5-15-15
                                         qt6-gtk-platformtheme : Depends: gnome-themes-extra-data but it is not going to be installed
                                         raindrop : Depends: libglib2.0-0t64 (>= 2.40.0) but it is not going to be installed
                                                    Depends: lightdm but it is not going to be installed
                                         rasputin : Depends: libglib2.0-0t64 (>= 2.26.0) but it is not going to be installed
                                         rc-gui : Depends: libglib2.0-0t64 (>= 2.32.0) but it is not going to be installed
                                         rp-bookshelf : Depends: libglib2.0-0t64 (>= 2.36.0) but it is not going to be installed
                                         rp-prefapps : Depends: libglib2.0-0t64 (>= 2.26.0) but it is not going to be installed
                                         rpi-chromium-mods : Depends: chromium (>= 92) but it is not going to be installed
                                         sudopwd : Depends: libglib2.0-0t64 (>= 2.32.0) but it is not going to be installed
                                         vdpau-driver-all : Depends: mesa-vdpau-drivers but it is not going to be installed
                                         wayfire : Depends: libglib2.0-0t64 (>= 2.12.0) but it is not going to be installed
                                         wf-panel-pi : Depends: libglib2.0-0t64 (>= 2.74.0) but it is not going to be installed
                                                       Recommends: wfplug-clock but it is not going to be installed
                                         wfplug-batt : Depends: libglib2.0-0t64 (>= 2.16.0) but it is not going to be installed
                                         wfplug-bluetooth : Depends: libglib2.0-0t64 (>= 2.30.0) but it is not going to be installed
                                         wfplug-connect : Depends: libglib2.0-0t64 (>= 2.28.0) but it is not going to be installed
                                         wfplug-cpu : Depends: libglib2.0-0t64 (>= 2.12.0) but it is not going to be installed
                                         wfplug-cputemp : Depends: libglib2.0-0t64 (>= 2.12.0) but it is not going to be installed
                                         wfplug-ejecter : Depends: libglib2.0-0t64 (>= 2.28.0) but it is not going to be installed
                                         wfplug-gpu : Depends: libglib2.0-0t64 (>= 2.12.0) but it is not going to be installed
                                         wfplug-menu : Depends: libglib2.0-0t64 (>= 2.36.0) but it is not going to be installed
                                         wfplug-netman : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                         wfplug-power : Depends: libglib2.0-0t64 (>= 2.36.0) but it is not going to be installed
                                         wfplug-squeek : Depends: libglib2.0-0t64 (>= 2.26.0) but it is not going to be installed
                                         wfplug-updater : Depends: libglib2.0-0t64 (>= 2.32.0) but it is not going to be installed
                                         wfplug-volumepulse : Depends: libglib2.0-0t64 (>= 2.30.0) but it is not going to be installed
                                         xarchiver : Depends: libglib2.0-0t64 (>= 2.76.0) but it is not going to be installed
                                                     Recommends: 7zip but it is not going to be installed
                                         xdg-desktop-portal-gtk : Depends: libglib2.0-0t64 (>= 2.83.0) but it is not going to be installed
                                         xfconf : Depends: libglib2.0-0t64 (>= 2.56.0) but it is not going to be installed
                                         xorg : Depends: xserver-xorg (>= 1:7.7+24+deb13u1) but it is not going to be installed
                                                Depends: xterm or
                                                         x-terminal-emulator
                                         xorgxrdp : Depends: xorg-input-abi-24
                                                    Depends: xorg-video-abi-25
                                                    Depends: xserver-xorg-core (>= 2:21.1.1) but it is not going to be installed
                                         xwayland : Depends: xserver-common but it is not going to be installed
                                         zenity : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                         zenoty : Depends: libglib2.0-0t64 (>= 2.12.0) but it is not going to be installed
                                        E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
                                        • H Hadebe
                                          sieht für mich nicht besser aus
                                          pi@raspi01:~ $ sudo apt purge xserver* lightdm* raspberrypi-ui-mods vlc* lxde* chromium* desktop* gnome* gstreamer* gtk* hicolor-icon-theme* lx* mesa*
                                          Reading package lists... Done
                                          Building dependency tree... Done
                                          Note, selecting 'xserver-xorg-video-nouveau' for glob 'xserver*'
                                          Note, selecting 'xserver-xorg-input-evdev' for glob 'xserver*'
                                          Note, selecting 'xserver-xorg-video-fbturbo-dbgsym' for glob 'xserver*'
                                          Note, selecting 'xserver-xorg-input-mouse' for glob 'xserver*'
                                          Note, selecting 'xserver-xorg-input-evtouch' for glob 'xserver*'
                                          Note, selecting 'xserver-xorg-video-amdgpu' for glob 'xserver*'
                                          Note, selecting 'xserver-xorg-video-mach64' for glob 'xserver*'
                                          Note, selecting 'xserver-xorg-core' for glob 'xserver*'
                                          Note, selecting 'xserver-xephyr-dbgsym' for glob 'xserver*'
                                          Note, selecting 'xserver-xorg-video-fbturbo' for glob 'xserver*'
                                          Note, selecting 'xserver-xorg-video-modesetting' for glob 'xserver*'
                                          Note, selecting 'xserver-x2gokdrive' for glob 'xserver*'
                                          Note, selecting 'xserver-xorg-input-all' for glob 'xserver*'
                                          Note, selecting 'xserver-xorg-video-intel' for glob 'xserver*'
                                          Note, selecting 'xserver-xorg-input-kbd' for glob 'xserver*'
                                          Note, selecting 'xserver-xorg-video-r128' for glob 'xserver*'
                                          Note, selecting 'xserver-xorg' for glob 'xserver*'
                                          Note, selecting 'xserver-xorg-input-joystick' for glob 'xserver*'
                                          Note, selecting 'xserver-xorg-input-xwiimote' for glob 'xserver*'
                                          Note, selecting 'xserver-xorg-video-vesa' for glob 'xserver*'
                                          Note, selecting 'xserver-xorg-input-elographics' for glob 'xserver*'
                                          Note, selecting 'xserver-xorg-video-dummy' for glob 'xserver*'
                                          Note, selecting 'xserver-xorg-input-aiptek' for glob 'xserver*'
                                          Note, selecting 'xserver-xorg-legacy' for glob 'xserver*'
                                          Note, selecting 'xserver-xorg-video-nvidia-any' for glob 'xserver*'
                                          Note, selecting 'xserver-common' for glob 'xserver*'
                                          Note, selecting 'xserver-xorg-video-radeon' for glob 'xserver*'
                                          Note, selecting 'xserver-xorg-input-synaptics' for glob 'xserver*'
                                          Note, selecting 'xserver-xorg-dev' for glob 'xserver*'
                                          Note, selecting 'xserver-xorg-video-vmware' for glob 'xserver*'
                                          Note, selecting 'xserver-xorg-video-neomagic' for glob 'xserver*'
                                          Note, selecting 'xserver-xorg-input-mtrack' for glob 'xserver*'
                                          Note, selecting 'xserver-xorg-input-libinput' for glob 'xserver*'
                                          Note, selecting 'xserver-xorg-video-siliconmotion' for glob 'xserver*'
                                          Note, selecting 'xserver-xorg-input-evdev-dev' for glob 'xserver*'
                                          Note, selecting 'xserver-xorg-video-sisusb' for glob 'xserver*'
                                          Note, selecting 'xserver-xorg-video-cirrus' for glob 'xserver*'
                                          Note, selecting 'xserver-xorg-input-wacom' for glob 'xserver*'
                                          Note, selecting 'xserver' for glob 'xserver*'
                                          Note, selecting 'xserver-xorg-core-dbgsym' for glob 'xserver*'
                                          Note, selecting 'xserver-xephyr' for glob 'xserver*'
                                          Note, selecting 'xserver-xorg-driver-all' for glob 'xserver*'
                                          Note, selecting 'xserver-xorg-input-joystick-dev' for glob 'xserver*'
                                          Note, selecting 'xserver-xorg-video-nvidia-tesla-535' for glob 'xserver*'
                                          Note, selecting 'xserver-xorg-legacy-dbgsym' for glob 'xserver*'
                                          Note, selecting 'xserver-xorg-input-libinput-dev' for glob 'xserver*'
                                          Note, selecting 'xserver-xorg-video-savage' for glob 'xserver*'
                                          Note, selecting 'xserver-xorg-input-synaptics-dev' for glob 'xserver*'
                                          Note, selecting 'xserver-xorg-video-all' for glob 'xserver*'
                                          Note, selecting 'xserver-xorg-video-ast' for glob 'xserver*'
                                          Note, selecting 'xserver-xorg-video-ati' for glob 'xserver*'
                                          Note, selecting 'xserver-xorg-video-fbdev' for glob 'xserver*'
                                          Note, selecting 'xserver-xorg-video-nvidia' for glob 'xserver*'
                                          Note, selecting 'xserver-xorg-video-nvidia-legacy-304xx' for glob 'xserver*'
                                          Note, selecting 'xserver-xorg-input-multitouch' for glob 'xserver*'
                                          Note, selecting 'xserver-xorg-video-mga' for glob 'xserver*'
                                          Note, selecting 'xserver-xorg-video-qxl' for glob 'xserver*'
                                          Package 'xserver-xorg-video-vmware' is not installed, so not removed
                                          Package 'xserver-xorg-video-intel' is not installed, so not removed
                                          Package 'xserver-xorg-driver-all' is not installed, so not removed
                                          Package 'xserver-xorg-input-evtouch' is not installed, so not removed
                                          Note, selecting 'xserver-xorg-core' instead of 'xserver-xorg-video-modesetting'
                                          Package 'xserver-xorg-video-nvidia-legacy-304xx' is not installed, so not removed
                                          Package 'xserver-xorg-video-ast' is not installed, so not removed
                                          Note, selecting 'lightdm-dbgsym' for glob 'lightdm*'
                                          Note, selecting 'lightdm-gtk-greeter-settings' for glob 'lightdm*'
                                          Note, selecting 'lightdm-autologin-greeter' for glob 'lightdm*'
                                          Note, selecting 'lightdm-gtk-greeter' for glob 'lightdm*'
                                          Note, selecting 'lightdm' for glob 'lightdm*'
                                          Note, selecting 'lightdm-remote-session-x2go' for glob 'lightdm*'
                                          Note, selecting 'lightdm-greeter' for glob 'lightdm*'
                                          Note, selecting 'lightdm-vala' for glob 'lightdm*'
                                          Note, selecting 'lightdm-settings' for glob 'lightdm*'
                                          Note, selecting 'vlc-plugin-qt' for glob 'vlc*'
                                          Note, selecting 'vlc-plugin-samba-dbgsym' for glob 'vlc*'
                                          Note, selecting 'vlc-data' for glob 'vlc*'
                                          Note, selecting 'vlc-plugin-abi-3-0-0ft64' for glob 'vlc*'
                                          Note, selecting 'vlc-bin-dbgsym' for glob 'vlc*'
                                          Note, selecting 'vlc-plugin-bittorrent' for glob 'vlc*'
                                          Note, selecting 'vlc-plugin-jack-dbgsym' for glob 'vlc*'
                                          Note, selecting 'vlc' for glob 'vlc*'
                                          Note, selecting 'vlc-bin' for glob 'vlc*'
                                          Note, selecting 'vlc-l10n' for glob 'vlc*'
                                          Note, selecting 'vlc-plugin-bittorent' for glob 'vlc*'
                                          Note, selecting 'vlc-plugin-pipewire' for glob 'vlc*'
                                          Note, selecting 'vlc-plugin-video-output-dbgsym' for glob 'vlc*'
                                          Note, selecting 'vlc-plugin-jack' for glob 'vlc*'
                                          Note, selecting 'vlc-plugin-samba' for glob 'vlc*'
                                          Note, selecting 'vlc-plugin-qt-dbgsym' for glob 'vlc*'
                                          Note, selecting 'vlc-plugin-access-extra-dbgsym' for glob 'vlc*'
                                          Note, selecting 'vlc-plugin-notify' for glob 'vlc*'
                                          Note, selecting 'vlc-plugin-fluidsynth' for glob 'vlc*'
                                          Note, selecting 'vlc-plugin-visualization-dbgsym' for glob 'vlc*'
                                          Note, selecting 'vlc-plugin-abi-3-0-0f' for glob 'vlc*'
                                          Note, selecting 'vlc-plugin-fluidsynth-dbgsym' for glob 'vlc*'
                                          Note, selecting 'vlc-plugin-access-extra' for glob 'vlc*'
                                          Note, selecting 'vlc-plugin-notify-dbgsym' for glob 'vlc*'
                                          Note, selecting 'vlc-plugin-skins2' for glob 'vlc*'
                                          Note, selecting 'vlc-plugin-svg' for glob 'vlc*'
                                          Note, selecting 'vlc-plugin-video-splitter' for glob 'vlc*'
                                          Note, selecting 'vlc-plugin-video-output' for glob 'vlc*'
                                          Note, selecting 'vlc-plugin-svg-dbgsym' for glob 'vlc*'
                                          Note, selecting 'vlc-plugin-base-dbgsym' for glob 'vlc*'
                                          Note, selecting 'vlc-plugin-skins2-dbgsym' for glob 'vlc*'
                                          Note, selecting 'vlc-plugin-video-splitter-dbgsym' for glob 'vlc*'
                                          Note, selecting 'vlc-plugin-base' for glob 'vlc*'
                                          Note, selecting 'vlc-plugin-visualization' for glob 'vlc*'
                                          Package 'vlc-plugin-bittorent' is not installed, so not removed
                                          Note, selecting 'libvlccore9' instead of 'vlc-plugin-abi-3-0-0ft64'
                                          Note, selecting 'lxde-settings-daemon-dbgsym' for glob 'lxde*'
                                          Note, selecting 'lxde-common' for glob 'lxde*'
                                          Note, selecting 'lxde-core' for glob 'lxde*'
                                          Note, selecting 'lxde' for glob 'lxde*'
                                          Note, selecting 'lxde-icon-theme' for glob 'lxde*'
                                          Note, selecting 'lxde-settings-daemon' for glob 'lxde*'
                                          Note, selecting 'lxde-session' for glob 'lxde*'
                                          Note, selecting 'openbox-lxde-session' instead of 'lxde-session'
                                          Note, selecting 'chromium-bsu' for glob 'chromium*'
                                          Note, selecting 'chromium-sandbox' for glob 'chromium*'
                                          Note, selecting 'chromium-codecs-ffmpeg-extra:armhf' for glob 'chromium*'
                                          Note, selecting 'chromium-shell-dbgsym' for glob 'chromium*'
                                          Note, selecting 'chromium-driver' for glob 'chromium*'
                                          Note, selecting 'chromium-shell' for glob 'chromium*'
                                          Note, selecting 'chromium-dbgsym' for glob 'chromium*'
                                          Note, selecting 'chromium-sandbox-dbgsym' for glob 'chromium*'
                                          Note, selecting 'chromium' for glob 'chromium*'
                                          Note, selecting 'chromium-headless-shell' for glob 'chromium*'
                                          Note, selecting 'chromium-data' for glob 'chromium*'
                                          Note, selecting 'chromium-browser' for glob 'chromium*'
                                          Note, selecting 'chromium-chromedriver' for glob 'chromium*'
                                          Note, selecting 'chromium-lwn4chrome' for glob 'chromium*'
                                          Note, selecting 'chromium-l10n' for glob 'chromium*'
                                          Note, selecting 'chromium-common' for glob 'chromium*'
                                          Note, selecting 'chromium-headless-shell-dbgsym' for glob 'chromium*'
                                          Note, selecting 'chromium-common-dbgsym' for glob 'chromium*'
                                          Note, selecting 'chromium-tt-rss-notifier' for glob 'chromium*'
                                          Note, selecting 'chromium-bsu-data' for glob 'chromium*'
                                          Note, selecting 'chromium-browser-l10n' for glob 'chromium*'
                                          Package 'chromium-tt-rss-notifier' is not installed, so not removed
                                          Package 'chromium-data' is not installed, so not removed
                                          Package 'chromium-codecs-ffmpeg-extra:armhf' is not installed, so not removed
                                          Note, selecting 'desktop-base' for glob 'desktop*'
                                          Note, selecting 'desktop-autoloader' for glob 'desktop*'
                                          Note, selecting 'desktop-file-utils' for glob 'desktop*'
                                          Note, selecting 'desktopfolder' for glob 'desktop*'
                                          Note, selecting 'gnome-shell-extension-dashtodock' for glob 'gnome*'
                                          Note, selecting 'gnome-text-editor' for glob 'gnome*'
                                          Note, selecting 'gnome-shell-extension-dash-to-dock' for glob 'gnome*'
                                          Note, selecting 'gnomekiss' for glob 'gnome*'
                                          Note, selecting 'gnome-kiosk-script-session' for glob 'gnome*'
                                          Note, selecting 'gnome-shell-extension-light-style' for glob 'gnome*'
                                          Note, selecting 'gnome-shell-extension-launch-new-instance' for glob 'gnome*'
                                          Note, selecting 'gnome-shell-pomodoro-data' for glob 'gnome*'
                                          Note, selecting 'gnome-user-docs' for glob 'gnome*'
                                          Note, selecting 'gnome-wine-icon-theme' for glob 'gnome*'
                                          Note, selecting 'gnome-power-manager' for glob 'gnome*'
                                          Note, selecting 'gnome-panel' for glob 'gnome*'
                                          Note, selecting 'gnome-shell-extension-hard-disk-led' for glob 'gnome*'
                                          Note, selecting 'gnome-video-effects-frei0r' for glob 'gnome*'
                                          Note, selecting 'gnome-breakout' for glob 'gnome*'
                                          Note, selecting 'gnome-sound-recorder' for glob 'gnome*'
                                          Note, selecting 'gnome-sudoku' for glob 'gnome*'
                                          Note, selecting 'gnome-themes-standard-data' for glob 'gnome*'
                                          Note, selecting 'gnome-software-plugin' for glob 'gnome*'
                                          Note, selecting 'gnome-font-viewer' for glob 'gnome*'
                                          Note, selecting 'gnome-online-accounts-gtk' for glob 'gnome*'
                                          Note, selecting 'gnome-shell-extension-workspace-indicator' for glob 'gnome*'
                                          Note, selecting 'gnome-human-icon-theme' for glob 'gnome*'
                                          Note, selecting 'gnome-software' for glob 'gnome*'
                                          Note, selecting 'gnome-alsamixer' for glob 'gnome*'
                                          Note, selecting 'gnome-software-plugin-fwupd' for glob 'gnome*'
                                          Note, selecting 'gnome-initial-setup' for glob 'gnome*'
                                          Note, selecting 'gnome-user-share' for glob 'gnome*'
                                          Note, selecting 'gnome-weather' for glob 'gnome*'
                                          Note, selecting 'gnome-session-flashback' for glob 'gnome*'
                                          Note, selecting 'gnome-klotski' for glob 'gnome*'
                                          Note, selecting 'gnome-software-common' for glob 'gnome*'
                                          Note, selecting 'gnome-commander' for glob 'gnome*'
                                          Note, selecting 'gnome-mplayer' for glob 'gnome*'
                                          Note, selecting 'gnome-video-arcade' for glob 'gnome*'
                                          Note, selecting 'gnome-shell-extension-taskbar' for glob 'gnome*'
                                          Note, selecting 'gnome-shell-extension-runcat' for glob 'gnome*'
                                          Note, selecting 'gnome-shell-extension-tiling-assistant' for glob 'gnome*'
                                          Note, selecting 'gnome-ponytail-daemon' for glob 'gnome*'
                                          Note, selecting 'gnome-themes-extras' for glob 'gnome*'
                                          Note, selecting 'gnome-bluetooth-3-common' for glob 'gnome*'
                                          Note, selecting 'gnome-applets-data' for glob 'gnome*'
                                          Note, selecting 'gnome-nibbles' for glob 'gnome*'
                                          Note, selecting 'gnome-shell-extension-gpaste' for glob 'gnome*'
                                          Note, selecting 'gnome-audio' for glob 'gnome*'
                                          Note, selecting 'gnome-network-displays' for glob 'gnome*'
                                          Note, selecting 'gnome-color-manager' for glob 'gnome*'
                                          Note, selecting 'gnome-connections' for glob 'gnome*'
                                          Note, selecting 'gnome-games-app' for glob 'gnome*'
                                          Note, selecting 'gnome-desktop-3-tests' for glob 'gnome*'
                                          Note, selecting 'gnome-shell-extension-native-window-placement' for glob 'gnome*'
                                          Note, selecting 'gnome-icon-theme-yasis' for glob 'gnome*'
                                          Note, selecting 'gnome-shell-extensions-extra' for glob 'gnome*'
                                          Note, selecting 'gnome-shell-extension-gsconnect-browsers' for glob 'gnome*'
                                          Note, selecting 'gnome-dictionary' for glob 'gnome*'
                                          Note, selecting 'gnome-boxes' for glob 'gnome*'
                                          Note, selecting 'gnome-software-plugin-deb' for glob 'gnome*'
                                          Note, selecting 'gnome-shell-extension-vertical-workspaces' for glob 'gnome*'
                                          Note, selecting 'gnome-control-center-signon' for glob 'gnome*'
                                          Note, selecting 'gnome-shell-extension-kimpanel' for glob 'gnome*'
                                          Note, selecting 'gnome-session-bin' for glob 'gnome*'
                                          Note, selecting 'gnome-flashback-common' for glob 'gnome*'
                                          Note, selecting 'gnome-shell-extension-middleclickclose' for glob 'gnome*'
                                          Note, selecting 'gnome-shell-extension-auto-move-windows' for glob 'gnome*'
                                          Note, selecting 'gnome-shell-pomodoro' for glob 'gnome*'
                                          Note, selecting 'gnome-tweaks' for glob 'gnome*'
                                          Note, selecting 'gnome-shell-extension-window-list' for glob 'gnome*'
                                          Note, selecting 'gnome-system-monitor' for glob 'gnome*'
                                          Note, selecting 'gnome-panel-data' for glob 'gnome*'
                                          Note, selecting 'gnome-noble-icon-theme' for glob 'gnome*'
                                          Note, selecting 'gnome-shell-extension-apps-menu' for glob 'gnome*'
                                          Note, selecting 'gnome-shell-extension-disable-workspace-switcher' for glob 'gnome*'
                                          Note, selecting 'gnome' for glob 'gnome*'
                                          Note, selecting 'gnome-cards-data' for glob 'gnome*'
                                          Note, selecting 'gnome-remote-desktop' for glob 'gnome*'
                                          Note, selecting 'gnome-tweak-tool' for glob 'gnome*'
                                          Note, selecting 'gnome-applets' for glob 'gnome*'
                                          Note, selecting 'gnome-icon-theme' for glob 'gnome*'
                                          Note, selecting 'gnome-colors-common' for glob 'gnome*'
                                          Note, selecting 'gnome-icon-theme-full' for glob 'gnome*'
                                          Note, selecting 'gnome-power-statistics' for glob 'gnome*'
                                          Note, selecting 'gnome-pass-search-provider' for glob 'gnome*'
                                          Note, selecting 'gnome-shell-extension-easyscreencast' for glob 'gnome*'
                                          Note, selecting 'gnome-kiosk' for glob 'gnome*'
                                          Note, selecting 'gnome-shell-extension-flypie' for glob 'gnome*'
                                          Note, selecting 'gnome-calendar' for glob 'gnome*'
                                          Note, selecting 'gnome-screensaver' for glob 'gnome*'
                                          Note, selecting 'gnome-shell-extensions' for glob 'gnome*'
                                          Note, selecting 'gnome-panel-control-dbgsym' for glob 'gnome*'
                                          Note, selecting 'gnome-shell' for glob 'gnome*'
                                          Note, selecting 'gnome-shell-extension-status-icons' for glob 'gnome*'
                                          Note, selecting 'gnome-mime-data' for glob 'gnome*'
                                          Note, selecting 'gnome-shell-extension-weather' for glob 'gnome*'
                                          Note, selecting 'gnome-classic' for glob 'gnome*'
                                          Note, selecting 'gnome-settings-daemon-common' for glob 'gnome*'
                                          Note, selecting 'gnome-software-dev' for glob 'gnome*'
                                          Note, selecting 'gnome-software-doc' for glob 'gnome*'
                                          Note, selecting 'gnome-feeds' for glob 'gnome*'
                                          Note, selecting 'gnome-session-xsession' for glob 'gnome*'
                                          Note, selecting 'gnome-mines' for glob 'gnome*'
                                          Note, selecting 'gnome-icon-theme-gartoon' for glob 'gnome*'
                                          Note, selecting 'gnome-usage' for glob 'gnome*'
                                          Note, selecting 'gnome-software-plugin-snap' for glob 'gnome*'
                                          Note, selecting 'gnome-logs' for glob 'gnome*'
                                          Note, selecting 'gnome-core-devel' for glob 'gnome*'
                                          Note, selecting 'gnome-themes-standard' for glob 'gnome*'
                                          Note, selecting 'gnome-extra-icons' for glob 'gnome*'
                                          Note, selecting 'gnome-snapshot' for glob 'gnome*'
                                          Note, selecting 'gnome-devel' for glob 'gnome*'
                                          Note, selecting 'gnome-metronome' for glob 'gnome*'
                                          Note, selecting 'gnome-robots' for glob 'gnome*'
                                          Note, selecting 'gnome-packagekit' for glob 'gnome*'
                                          Note, selecting 'gnome-mastermind' for glob 'gnome*'
                                          Note, selecting 'gnome-calculator' for glob 'gnome*'
                                          Note, selecting 'gnome-shell-extension-desktop-icons-ng' for glob 'gnome*'
                                          Note, selecting 'gnome-shell-extension-just-perfection' for glob 'gnome*'
                                          Note, selecting 'gnome-2048' for glob 'gnome*'
                                          Note, selecting 'gnome-themes-extra-data' for glob 'gnome*'
                                          Note, selecting 'gnome-video-trimmer' for glob 'gnome*'
                                          Note, selecting 'gnome-shell-extension-top-icons-plus' for glob 'gnome*'
                                          Note, selecting 'gnome-icon-theme-nuovo' for glob 'gnome*'
                                          Note, selecting 'gnome-extensions-app' for glob 'gnome*'
                                          Note, selecting 'gnome-settings-daemon' for glob 'gnome*'
                                          Note, selecting 'gnome-shell-extension-appindicator' for glob 'gnome*'
                                          Note, selecting 'gnome-shell-extension-desktop-icons' for glob 'gnome*'
                                          Note, selecting 'gnome-shell-extension-autohidetopbar' for glob 'gnome*'
                                          Note, selecting 'gnome-illustrious-icon-theme' for glob 'gnome*'
                                          Note, selecting 'gnome-epub-thumbnailer' for glob 'gnome*'
                                          Note, selecting 'gnome-shell-extension-places-menu' for glob 'gnome*'
                                          Note, selecting 'gnome-photos' for glob 'gnome*'
                                          Note, selecting 'gnome-maps' for glob 'gnome*'
                                          Note, selecting 'gnome-multi-writer' for glob 'gnome*'
                                          Note, selecting 'gnome-shell-extension-freon' for glob 'gnome*'
                                          Note, selecting 'gnome-package-updater' for glob 'gnome*'
                                          Note, selecting 'gnome-contacts' for glob 'gnome*'
                                          Note, selecting 'gnome-mahjongg' for glob 'gnome*'
                                          Note, selecting 'gnome-commander-data' for glob 'gnome*'
                                          Note, selecting 'gnome-packagekit-data' for glob 'gnome*'
                                          Note, selecting 'gnome-desktop3-data' for glob 'gnome*'
                                          Note, selecting 'gnome-podcasts' for glob 'gnome*'
                                          Note, selecting 'gnome-colors' for glob 'gnome*'
                                          Note, selecting 'gnome-disk-utility' for glob 'gnome*'
                                          Note, selecting 'gnome-firmware' for glob 'gnome*'
                                          Note, selecting 'gnome-notes' for glob 'gnome*'
                                          Note, selecting 'gnome-classic-xsession' for glob 'gnome*'
                                          Note, selecting 'gnome-desktop-testing' for glob 'gnome*'
                                          Note, selecting 'gnome-icon-theme-suede' for glob 'gnome*'
                                          Note, selecting 'gnome-online-accounts' for glob 'gnome*'
                                          Note, selecting 'gnome-backgrounds' for glob 'gnome*'
                                          Note, selecting 'gnome-system-tools' for glob 'gnome*'
                                          Note, selecting 'gnome-shell-extension-no-annoyance' for glob 'gnome*'
                                          Note, selecting 'gnome-settings-daemon-dev' for glob 'gnome*'
                                          Note, selecting 'gnome-shell-extension-screenshot-window-sizer' for glob 'gnome*'
                                          Note, selecting 'gnome-screensaver-flags' for glob 'gnome*'
                                          Note, selecting 'gnome-bluetooth-sendto' for glob 'gnome*'
                                          Note, selecting 'gnome-screenshot' for glob 'gnome*'
                                          Note, selecting 'gnome-calls' for glob 'gnome*'
                                          Note, selecting 'gnome-shell-common' for glob 'gnome*'
                                          Note, selecting 'gnome-media' for glob 'gnome*'
                                          Note, selecting 'gnome-control-center-data' for glob 'gnome*'
                                          Note, selecting 'gnome-music' for glob 'gnome*'
                                          Note, selecting 'gnome-tetravex' for glob 'gnome*'
                                          Note, selecting 'gnome-platform-devel' for glob 'gnome*'
                                          Note, selecting 'gnome-theme-gilouche' for glob 'gnome*'
                                          Note, selecting 'gnome-keyring' for glob 'gnome*'
                                          Note, selecting 'gnome-icon-theme-symbolic' for glob 'gnome*'
                                          Note, selecting 'gnome-hwp-support' for glob 'gnome*'
                                          Note, selecting 'gnome-authenticator' for glob 'gnome*'
                                          Note, selecting 'gnome-mpv' for glob 'gnome*'
                                          Note, selecting 'gnome-pkg-tools' for glob 'gnome*'
                                          Note, selecting 'gnome-shell-extension-manager' for glob 'gnome*'
                                          Note, selecting 'gnome-shell-extension-workspaces-to-dock' for glob 'gnome*'
                                          Note, selecting 'gnome-menus' for glob 'gnome*'
                                          Note, selecting 'gnome-shell-extension-arc-menu' for glob 'gnome*'
                                          Note, selecting 'gnome-wise-icon-theme' for glob 'gnome*'
                                          Note, selecting 'gnome-shell-extension-hibernate-status' for glob 'gnome*'
                                          Note, selecting 'gnome-panel-control' for glob 'gnome*'
                                          Note, selecting 'gnome-pie' for glob 'gnome*'
                                          Note, selecting 'gnome-shell-extension-windows-navigator' for glob 'gnome*'
                                          Note, selecting 'gnome-shell-extension-shortcuts' for glob 'gnome*'
                                          Note, selecting 'gnome-brave-icon-theme' for glob 'gnome*'
                                          Note, selecting 'gnome-shell-extension-dash-to-panel' for glob 'gnome*'
                                          Note, selecting 'gnome-video-effects' for glob 'gnome*'
                                          Note, selecting 'gnome-session' for glob 'gnome*'
                                          Note, selecting 'gnome-common' for glob 'gnome*'
                                          Note, selecting 'gnome-dust-icon-theme' for glob 'gnome*'
                                          Note, selecting 'gnome-control-center' for glob 'gnome*'
                                          Note, selecting 'gnome-shell-extension-gamemode' for glob 'gnome*'
                                          Note, selecting 'gnome-terminal-data' for glob 'gnome*'
                                          Note, selecting 'gnome-settings-daemon-schemas' for glob 'gnome*'
                                          Note, selecting 'gnome-shell-extension-drive-menu' for glob 'gnome*'
                                          Note, selecting 'gnome-www-browser' for glob 'gnome*'
                                          Note, selecting 'gnome-games' for glob 'gnome*'
                                          Note, selecting 'gnome-flashback' for glob 'gnome*'
                                          Note, selecting 'gnome-session-canberra' for glob 'gnome*'
                                          Note, selecting 'gnome-genius' for glob 'gnome*'
                                          Note, selecting 'gnome-shell-extension-blur-my-shell' for glob 'gnome*'
                                          Note, selecting 'gnome-browser-connector' for glob 'gnome*'
                                          Note, selecting 'gnome-video-effects-dev' for glob 'gnome*'
                                          Note, selecting 'gnome-core' for glob 'gnome*'
                                          Note, selecting 'gnome-shell-extension-system-monitor' for glob 'gnome*'
                                          Note, selecting 'gnome-terminal' for glob 'gnome*'
                                          Note, selecting 'gnome-software-plugin-flatpak' for glob 'gnome*'
                                          Note, selecting 'gnome-shell-extension-impatience' for glob 'gnome*'
                                          Note, selecting 'gnome-characters' for glob 'gnome*'
                                          Note, selecting 'gnome-bluetooth' for glob 'gnome*'
                                          Note, selecting 'gnome-packagekit-common' for glob 'gnome*'
                                          Note, selecting 'gnome-sushi' for glob 'gnome*'
                                          Note, selecting 'gnome-activity-journal' for glob 'gnome*'
                                          Note, selecting 'gnome-shell-extension-onboard' for glob 'gnome*'
                                          Note, selecting 'gnome-api-docs' for glob 'gnome*'
                                          Note, selecting 'gnome-accessibility-themes' for glob 'gnome*'
                                          Note, selecting 'gnome-keysign' for glob 'gnome*'
                                          Note, selecting 'gnome-model-thumbnailer' for glob 'gnome*'
                                          Note, selecting 'gnome-themes-extra' for glob 'gnome*'
                                          Note, selecting 'gnome-shell-extensions-common' for glob 'gnome*'
                                          Note, selecting 'gnome-mousetrap' for glob 'gnome*'
                                          Note, selecting 'gnome-recipes' for glob 'gnome*'
                                          Note, selecting 'gnome-nettool' for glob 'gnome*'
                                          Note, selecting 'gnome-keyring-pkcs11' for glob 'gnome*'
                                          Note, selecting 'gnome-shell-extension-prefs' for glob 'gnome*'
                                          Note, selecting 'gnome-chess' for glob 'gnome*'
                                          Note, selecting 'gnome-shell-extension-no-overview' for glob 'gnome*'
                                          Note, selecting 'gnome-taquin' for glob 'gnome*'
                                          Note, selecting 'gnome-shell-extension-user-theme' for glob 'gnome*'
                                          Note, selecting 'gnome-decoder' for glob 'gnome*'
                                          Note, selecting 'gnome-shell-extension-caffeine' for glob 'gnome*'
                                          Note, selecting 'gnome-video-effects-extra' for glob 'gnome*'
                                          Note, selecting 'gnome-todo' for glob 'gnome*'
                                          Note, selecting 'gnome-shell-extension-hamster' for glob 'gnome*'
                                          Note, selecting 'gnome-tour' for glob 'gnome*'
                                          Note, selecting 'gnome-shell-extensions-gpaste' for glob 'gnome*'
                                          Note, selecting 'gnome-builder' for glob 'gnome*'
                                          Note, selecting 'gnome-shell-extension-hide-activities' for glob 'gnome*'
                                          Note, selecting 'gnome-shell-extension-gsconnect' for glob 'gnome*'
                                          Note, selecting 'gnome-console' for glob 'gnome*'
                                          Note, selecting 'gnome-nds-thumbnailer' for glob 'gnome*'
                                          Note, selecting 'gnome-recipes-data' for glob 'gnome*'
                                          Note, selecting 'gnome-photos-tests' for glob 'gnome*'
                                          Note, selecting 'gnome-calls-doc' for glob 'gnome*'
                                          Note, selecting 'gnome-control-center-dev' for glob 'gnome*'
                                          Note, selecting 'gnome-clocks' for glob 'gnome*'
                                          Note, selecting 'gnome-session-common' for glob 'gnome*'
                                          Note, selecting 'gnome-latex' for glob 'gnome*'
                                          Note, selecting 'gnome-codec-install' for glob 'gnome*'
                                          Note, selecting 'gnome-kiosk-search-appliance' for glob 'gnome*'
                                          Package 'gnome-themes-standard-data' is not installed, so not removed
                                          Note, selecting 'adwaita-icon-theme' instead of 'gnome-icon-theme-symbolic'
                                          Package 'gnome-bluetooth' is not installed, so not removed
                                          Package 'gnome-power-statistics' is not installed, so not removed
                                          Package 'gnome-control-center-signon' is not installed, so not removed
                                          Note, selecting 'bijiben' instead of 'gnome-notes'
                                          Package 'gnome-mpv' is not installed, so not removed
                                          Package 'gnome-mime-data' is not installed, so not removed
                                          Package 'gnome-video-arcade' is not installed, so not removed
                                          Package 'gnome-dictionary' is not installed, so not removed
                                          Package 'gnome-mplayer' is not installed, so not removed
                                          Note, selecting 'endeavour' instead of 'gnome-todo'
                                          Note, selecting 'enter-tex' instead of 'gnome-latex'
                                          Package 'gnome-packagekit-data' is not installed, so not removed
                                          Note, selecting 'gnome-settings-daemon-common' instead of 'gnome-settings-daemon-schemas'
                                          Package 'gnome-shell-extension-desktop-icons' is not installed, so not removed
                                          Package 'gnome-shell-extension-taskbar' is not installed, so not removed
                                          Package 'gnome-shell-extension-top-icons-plus' is not installed, so not removed
                                          Package 'gnome-shell-extension-workspaces-to-dock' is not installed, so not removed
                                          Note, selecting 'gnome-shell-extension-prefs' instead of 'gnome-extensions-app'
                                          Note, selecting 'gnome-shell-extension-dashtodock' instead of 'gnome-shell-extension-dash-to-dock'
                                          Note, selecting 'gnome-shell-extensions-extra' instead of 'gnome-shell-extension-disable-workspace-switcher'
                                          Note, selecting 'gnome-shell-extensions-extra' instead of 'gnome-shell-extension-hibernate-status'
                                          Note, selecting 'gnome-shell-extensions-extra' instead of 'gnome-shell-extension-just-perfection'
                                          Note, selecting 'gnome-shell-extensions-extra' instead of 'gnome-shell-extension-middleclickclose'
                                          Note, selecting 'gnome-shell-extensions-extra' instead of 'gnome-shell-extension-no-overview'
                                          Note, selecting 'gnome-shell-extensions-extra' instead of 'gnome-shell-extension-vertical-workspaces'
                                          Package 'gnome-media' is not installed, so not removed
                                          Note, selecting 'gnome-tweaks' instead of 'gnome-tweak-tool'
                                          Package 'gnome-video-effects-extra' is not installed, so not removed
                                          Package 'gnome-shell-extensions-gpaste' is not installed, so not removed
                                          Package 'gnome-games-app' is not installed, so not removed
                                          Package 'gnome-core-devel' is not installed, so not removed
                                          Package 'gnome-shell-extension-onboard' is not installed, so not removed
                                          Package 'gnome-codec-install' is not installed, so not removed
                                          Package 'gnome-icon-theme-full' is not installed, so not removed
                                          Package 'gnome-alsamixer' is not installed, so not removed
                                          Package 'gnome-themes-extras' is not installed, so not removed
                                          Package 'gnome-themes-standard' is not installed, so not removed
                                          Note, selecting 'gstreamer1.0-qt5' for glob 'gstreamer*'
                                          Note, selecting 'gstreamer1.0-qt6' for glob 'gstreamer*'
                                          Note, selecting 'gstreamer1.0-wpe' for glob 'gstreamer*'
                                          Note, selecting 'gstreamer1.0-plugins-ugly' for glob 'gstreamer*'
                                          Note, selecting 'gstreamer1.0-packagekit' for glob 'gstreamer*'
                                          Note, selecting 'gstreamer1.0-plugins-bad-apps-dbgsym' for glob 'gstreamer*'
                                          Note, selecting 'gstreamer1.0-gl' for glob 'gstreamer*'
                                          Note, selecting 'gstreamer1.0-plugins-base-apps-dbgsym' for glob 'gstreamer*'
                                          Note, selecting 'gstreamer1.0-fluendo-mp3' for glob 'gstreamer*'
                                          Note, selecting 'gstreamer1.0-clutter-3.0' for glob 'gstreamer*'
                                          Note, selecting 'gstreamer1.0-autogain-pulseeffects' for glob 'gstreamer*'
                                          Note, selecting 'gstreamer1.0-python-dbg-plugin-loader' for glob 'gstreamer*'
                                          Note, selecting 'gstreamer1.0-plugins-base-dbgsym' for glob 'gstreamer*'
                                          Note, selecting 'gstreamer1.0-plugins-bad-videoparsers' for glob 'gstreamer*'
                                          Note, selecting 'gstreamer1.0-pispconvert' for glob 'gstreamer*'
                                          Note, selecting 'gstreamer1.0-adapter-pulseeffects' for glob 'gstreamer*'
                                          Note, selecting 'gstreamer1.0-videosource' for glob 'gstreamer*'
                                          Note, selecting 'gstreamer1.0-tools' for glob 'gstreamer*'
                                          Note, selecting 'gstreamer1.0-espeak' for glob 'gstreamer*'
                                          Note, selecting 'gstreamer1.0-plugins-really-bad' for glob 'gstreamer*'
                                          Note, selecting 'gstreamer1.0-lame' for glob 'gstreamer*'
                                          Note, selecting 'gstreamer1.0-plugins-base-apps' for glob 'gstreamer*'
                                          Note, selecting 'gstreamer1.0-alsa' for glob 'gstreamer*'
                                          Note, selecting 'gstreamer1.0-pipewire-dbgsym' for glob 'gstreamer*'
                                          Note, selecting 'gstreamer1.0-audiosource' for glob 'gstreamer*'
                                          Note, selecting 'gstreamer1.0-gl-dbgsym' for glob 'gstreamer*'
                                          Note, selecting 'gstreamer1.0-audiosink' for glob 'gstreamer*'
                                          Note, selecting 'gstreamer1.0-visualization' for glob 'gstreamer*'
                                          Note, selecting 'gstreamer1.0-x' for glob 'gstreamer*'
                                          Note, selecting 'gstreamer1.0-gtk3' for glob 'gstreamer*'
                                          Note, selecting 'gstreamer1.0-gtk4' for glob 'gstreamer*'
                                          Note, selecting 'gstreamer1.0-pocketsphinx' for glob 'gstreamer*'
                                          Note, selecting 'gstreamer1.0-rtsp' for glob 'gstreamer*'
                                          Note, selecting 'gstreamer1.0-libcamera' for glob 'gstreamer*'
                                          Note, selecting 'gstreamer1.0-plugins-good' for glob 'gstreamer*'
                                          Note, selecting 'gstreamer1.0-plugins-bad-faad' for glob 'gstreamer*'
                                          Note, selecting 'gstreamer1.0-plugins-base' for glob 'gstreamer*'
                                          Note, selecting 'gstreamer1.0-crystalhd' for glob 'gstreamer*'
                                          Note, selecting 'gstreamer1.0-pipewire' for glob 'gstreamer*'
                                          Note, selecting 'gstreamer1.0-python3-plugin-loader' for glob 'gstreamer*'
                                          Note, selecting 'gstreamer0.10-packagekit' for glob 'gstreamer*'
                                          Note, selecting 'gstreamer1.0-plugins-bad-dbgsym' for glob 'gstreamer*'
                                          Note, selecting 'gstreamer1.0-vaapi-doc' for glob 'gstreamer*'
                                          Note, selecting 'gstreamer1.0-videosink' for glob 'gstreamer*'
                                          Note, selecting 'gstreamer1.0-plugins-base-doc' for glob 'gstreamer*'
                                          Note, selecting 'gstreamer1.0-x-dbgsym' for glob 'gstreamer*'
                                          Note, selecting 'gstreamer1.0-opencv-dbgsym' for glob 'gstreamer*'
                                          Note, selecting 'gstreamer1.0-convolver-pulseeffects' for glob 'gstreamer*'
                                          Note, selecting 'gstreamer1.0-pispconvert-dbgsym' for glob 'gstreamer*'
                                          Note, selecting 'gstreamer1.0-python3-dbg-plugin-loader' for glob 'gstreamer*'
                                          Note, selecting 'gstreamer1.0-plugins-bad-apps' for glob 'gstreamer*'
                                          Note, selecting 'gstreamer1.0-opencv' for glob 'gstreamer*'
                                          Note, selecting 'gstreamer1.0-vaapi' for glob 'gstreamer*'
                                          Note, selecting 'gstreamer1.0-nice' for glob 'gstreamer*'
                                          Note, selecting 'gstreamer1.0-libcamera-dbgsym' for glob 'gstreamer*'
                                          Note, selecting 'gstreamer1.0-crystalizer-pulseeffects' for glob 'gstreamer*'
                                          Note, selecting 'gstreamer1.0-plugins-bad' for glob 'gstreamer*'
                                          Note, selecting 'gstreamer1.0-pulseaudio' for glob 'gstreamer*'
                                          Note, selecting 'gstreamer1.0-python-plugin-loader' for glob 'gstreamer*'
                                          Note, selecting 'gstreamer1.0-libav' for glob 'gstreamer*'
                                          Note, selecting 'gstreamer1.0-alsa-dbgsym' for glob 'gstreamer*'
                                          Note, selecting 'gstreamer1.0-plugins-rtp' for glob 'gstreamer*'
                                          Note, selecting 'gstreamer1.0-doc' for glob 'gstreamer*'
                                          Note, selecting 'gstreamer1.0-fdkaac' for glob 'gstreamer*'
                                          Note, selecting 'gstreamer1.0-wpe-dbgsym' for glob 'gstreamer*'
                                          Note, selecting 'gstreamer-sharp-1.0' for glob 'gstreamer*'
                                          Package 'gstreamer1.0-doc' is not installed, so not removed
                                          Package 'gstreamer1.0-plugins-base-doc' is not installed, so not removed
                                          Package 'gstreamer-sharp-1.0' is not installed, so not removed
                                          Package 'gstreamer1.0-crystalhd' is not installed, so not removed
                                          Note, selecting 'gstreamer1.0-plugins-bad' instead of 'gstreamer1.0-plugins-bad-faad'
                                          Note, selecting 'gstreamer1.0-plugins-bad' instead of 'gstreamer1.0-plugins-bad-videoparsers'
                                          Package 'gstreamer1.0-python-dbg-plugin-loader' is not installed, so not removed
                                          Package 'gstreamer1.0-python-plugin-loader' is not installed, so not removed
                                          Package 'gstreamer1.0-python3-dbg-plugin-loader' is not installed, so not removed
                                          Package 'gstreamer1.0-vaapi-doc' is not installed, so not removed
                                          Package 'gstreamer1.0-fluendo-mp3' is not installed, so not removed
                                          Package 'gstreamer0.10-packagekit' is not installed, so not removed
                                          Package 'gstreamer1.0-lame' is not installed, so not removed
                                          Package 'gstreamer1.0-plugins-really-bad' is not installed, so not removed
                                          Note, selecting 'gtk-3-examples-dbgsym' for glob 'gtk*'
                                          Note, selecting 'gtkmorph-example' for glob 'gtk*'
                                          Note, selecting 'gtk2-engines-clearlookspix-dbgsym' for glob 'gtk*'
                                          Note, selecting 'gtk-layer-shell-doc' for glob 'gtk*'
                                          Note, selecting 'gtk2-engines-qtcurve' for glob 'gtk*'
                                          Note, selecting 'gtkhash' for glob 'gtk*'
                                          Note, selecting 'gtk2-engines-clearlookspix' for glob 'gtk*'
                                          Note, selecting 'gtk4-layer-shell-examples' for glob 'gtk*'
                                          Note, selecting 'gtk3-binver-3.0.0' for glob 'gtk*'
                                          Note, selecting 'gtkatlantic' for glob 'gtk*'
                                          Note, selecting 'gtk-im-libthai' for glob 'gtk*'
                                          Note, selecting 'gtklock-userinfo-module' for glob 'gtk*'
                                          Note, selecting 'gtkterm' for glob 'gtk*'
                                          Note, selecting 'gtk2-engines-pixbuf-dbgsym' for glob 'gtk*'
                                          Note, selecting 'gtk2hs-buildtools' for glob 'gtk*'
                                          Note, selecting 'gtklock-playerctl-module' for glob 'gtk*'
                                          Note, selecting 'gtk-nop' for glob 'gtk*'
                                          Note, selecting 'gtkballs' for glob 'gtk*'
                                          Note, selecting 'gtk2-engines-aurora' for glob 'gtk*'
                                          Note, selecting 'gtkam' for glob 'gtk*'
                                          Note, selecting 'gtk-redshift' for glob 'gtk*'
                                          Note, selecting 'gtklp' for glob 'gtk*'
                                          Note, selecting 'gtk-meshtastic-client' for glob 'gtk*'
                                          Note, selecting 'gtk4-binver-4.0.0' for glob 'gtk*'
                                          Note, selecting 'gtkguitune' for glob 'gtk*'
                                          Note, selecting 'gtk2-engines-murrine' for glob 'gtk*'
                                          Note, selecting 'gtk4-layer-shell-doc' for glob 'gtk*'
                                          Note, selecting 'gtk3-nocsd' for glob 'gtk*'
                                          Note, selecting 'gtk-4-examples' for glob 'gtk*'
                                          Note, selecting 'gtkgreet' for glob 'gtk*'
                                          Note, selecting 'gtk-nop-dbgsym' for glob 'gtk*'
                                          Note, selecting 'gtkpool' for glob 'gtk*'
                                          Note, selecting 'gtk-session-lock-examples' for glob 'gtk*'
                                          Note, selecting 'gtk2-engines' for glob 'gtk*'
                                          Note, selecting 'gtk2-engines-sugar' for glob 'gtk*'
                                          Note, selecting 'gtkman' for glob 'gtk*'
                                          Note, selecting 'gtk-layer-shell-examples' for glob 'gtk*'
                                          Note, selecting 'gtkpod' for glob 'gtk*'
                                          Note, selecting 'gtkcrypto' for glob 'gtk*'
                                          Note, selecting 'gtk-theme-switch' for glob 'gtk*'
                                          Note, selecting 'gtkmm-documentation' for glob 'gtk*'
                                          Note, selecting 'gtk2-engines-pixbuf' for glob 'gtk*'
                                          Note, selecting 'gtk-3-examples' for glob 'gtk*'
                                          Note, selecting 'gtk-chtheme' for glob 'gtk*'
                                          Note, selecting 'gtk-update-icon-cache' for glob 'gtk*'
                                          Note, selecting 'gtk-doc-tools' for glob 'gtk*'
                                          Note, selecting 'gtkwave' for glob 'gtk*'
                                          Note, selecting 'gtk2-engines-pixflat' for glob 'gtk*'
                                          Note, selecting 'gtklick' for glob 'gtk*'
                                          Note, selecting 'gtkboard' for glob 'gtk*'
                                          Note, selecting 'gtklock' for glob 'gtk*'
                                          Note, selecting 'gtk3-im-libthai' for glob 'gtk*'
                                          Note, selecting 'gtk2-engines-pixflat-dbgsym' for glob 'gtk*'
                                          Note, selecting 'gtk-4-tests' for glob 'gtk*'
                                          Note, selecting 'gtk-recordmydesktop' for glob 'gtk*'
                                          Note, selecting 'gtk2.0-binver-2.10.0' for glob 'gtk*'
                                          Note, selecting 'gtk2-engines-gartoon' for glob 'gtk*'
                                          Package 'gtkboard' is not installed, so not removed
                                          Package 'gtkpool' is not installed, so not removed
                                          Package 'gtkguitune' is not installed, so not removed
                                          Package 'gtklick' is not installed, so not removed
                                          Note, selecting 'gnome-icon-theme-gartoon' instead of 'gtk2-engines-gartoon'
                                          Package 'gtkpod' is not installed, so not removed
                                          Note, selecting 'libgtk-4-1' instead of 'gtk4-binver-4.0.0'
                                          Package 'gtk-recordmydesktop' is not installed, so not removed
                                          Package 'gtk-redshift' is not installed, so not removed
                                          Package 'gtk2-engines-sugar' is not installed, so not removed
                                          Note, selecting 'hicolor-icon-theme' for glob 'hicolor-icon-theme*'
                                          Note, selecting 'lxplug-ejecter' for glob 'lx*'
                                          Note, selecting 'lxpanel-pi-dbgsym' for glob 'lx*'
                                          Note, selecting 'lxd-tools' for glob 'lx*'
                                          Note, selecting 'lxqt-powermanagement-l10n' for glob 'lx*'
                                          Note, selecting 'lxpanel-pi' for glob 'lx*'
                                          Note, selecting 'lxplug-volumepulse' for glob 'lx*'
                                          Note, selecting 'lximage-qt-l10n' for glob 'lx*'
                                          Note, selecting 'lxpanel-dev' for glob 'lx*'
                                          Note, selecting 'lxqt-panel' for glob 'lx*'
                                          Note, selecting 'lxlauncher' for glob 'lx*'
                                          Note, selecting 'lxpanel-data' for glob 'lx*'
                                          Note, selecting 'lxqt-theme-debian' for glob 'lx*'
                                          Note, selecting 'lxqt-archiver' for glob 'lx*'
                                          Note, selecting 'lxterminal' for glob 'lx*'
                                          Note, selecting 'lxqt-system-theme' for glob 'lx*'
                                          Note, selecting 'lxc' for glob 'lx*'
                                          Note, selecting 'lxd' for glob 'lx*'
                                          Note, selecting 'lxqt-admin' for glob 'lx*'
                                          Note, selecting 'lxi-tools' for glob 'lx*'
                                          Note, selecting 'lxqt-openssh-askpass-l10n' for glob 'lx*'
                                          Note, selecting 'lxpolkit' for glob 'lx*'
                                          Note, selecting 'lxqt-powermanagement' for glob 'lx*'
                                          Note, selecting 'lxsession' for glob 'lx*'
                                          Note, selecting 'lxsession-data' for glob 'lx*'
                                          Note, selecting 'lxde-settings-daemon-dbgsym' for glob 'lx*'
                                          Note, selecting 'lxde-common' for glob 'lx*'
                                          Note, selecting 'lxlock' for glob 'lx*'
                                          Note, selecting 'lxqt-sudo-l10n' for glob 'lx*'
                                          Note, selecting 'lxcfs' for glob 'lx*'
                                          Note, selecting 'lxctl' for glob 'lx*'
                                          Note, selecting 'lxqt-openssh-askpass' for glob 'lx*'
                                          Note, selecting 'lxmenu-data' for glob 'lx*'
                                          Note, selecting 'lxd-client' for glob 'lx*'
                                          Note, selecting 'lxqt-qtplugin' for glob 'lx*'
                                          Note, selecting 'lxde-core' for glob 'lx*'
                                          Note, selecting 'lxqt-qtplugin6' for glob 'lx*'
                                          Note, selecting 'lxplug-updater' for glob 'lx*'
                                          Note, selecting 'lxplug-cpu' for glob 'lx*'
                                          Note, selecting 'lxqt-runner-l10n' for glob 'lx*'
                                          Note, selecting 'lxd-migrate' for glob 'lx*'
                                          Note, selecting 'lxpanel' for glob 'lx*'
                                          Note, selecting 'lxqt-sudo' for glob 'lx*'
                                          Note, selecting 'lxc-dev' for glob 'lx*'
                                          Note, selecting 'lxqt-admin-l10n' for glob 'lx*'
                                          Note, selecting 'lxsession-edit' for glob 'lx*'
                                          Note, selecting 'lxqt-policykit-l10n' for glob 'lx*'
                                          Note, selecting 'lxrandr' for glob 'lx*'
                                          Note, selecting 'lxqt-core' for glob 'lx*'
                                          Note, selecting 'lxqt-archiver-l10n' for glob 'lx*'
                                          Note, selecting 'lxqt-theme' for glob 'lx*'
                                          Note, selecting 'lxplug-bluetooth' for glob 'lx*'
                                          Note, selecting 'lxplug-cputemp' for glob 'lx*'
                                          Note, selecting 'lxqt-globalkeys-l10n' for glob 'lx*'
                                          Note, selecting 'lxappearance-obconf' for glob 'lx*'
                                          Note, selecting 'lxqt-branding-debian' for glob 'lx*'
                                          Note, selecting 'lxde' for glob 'lx*'
                                          Note, selecting 'lxdm' for glob 'lx*'
                                          Note, selecting 'lxqt' for glob 'lx*'
                                          Note, selecting 'lxplug-magnifier' for glob 'lx*'
                                          Note, selecting 'lxinput' for glob 'lx*'
                                          Note, selecting 'lxshortcut' for glob 'lx*'
                                          Note, selecting 'lxpolkit-dbgsym' for glob 'lx*'
                                          Note, selecting 'lxqt-branding' for glob 'lx*'
                                          Note, selecting 'lxqt-qt5plugin' for glob 'lx*'
                                          Note, selecting 'lxtask' for glob 'lx*'
                                          Note, selecting 'lxqt-policykit' for glob 'lx*'
                                          Note, selecting 'lxplug-netman' for glob 'lx*'
                                          Note, selecting 'lxsession-logout' for glob 'lx*'
                                          Note, selecting 'lxplug-batt' for glob 'lx*'
                                          Note, selecting 'lxqt-panel-l10n' for glob 'lx*'
                                          Note, selecting 'lxpanel-pi-dev-dbgsym' for glob 'lx*'
                                          Note, selecting 'lx-gdb' for glob 'lx*'
                                          Note, selecting 'lxc-tests' for glob 'lx*'
                                          Note, selecting 'lxplug-menu' for glob 'lx*'
                                          Note, selecting 'lxhotkey-core' for glob 'lx*'
                                          Note, selecting 'lxqt-common' for glob 'lx*'
                                          Note, selecting 'lxsession-default-apps' for glob 'lx*'
                                          Note, selecting 'lxsession-edit-dbgsym' for glob 'lx*'
                                          Note, selecting 'lxqt-about' for glob 'lx*'
                                          Note, selecting 'lxde-icon-theme' for glob 'lx*'
                                          Note, selecting 'lxc-templates' for glob 'lx*'
                                          Note, selecting 'lxhotkey-data' for glob 'lx*'
                                          Note, selecting 'lxqt-session-l10n' for glob 'lx*'
                                          Note, selecting 'lximage-qt' for glob 'lx*'
                                          Note, selecting 'lxhotkey-dev' for glob 'lx*'
                                          Note, selecting 'lxqt-runner' for glob 'lx*'
                                          Note, selecting 'lxqt-build-tools-qt5' for glob 'lx*'
                                          Note, selecting 'lxhotkey-gtk' for glob 'lx*'
                                          Note, selecting 'lxhotkey-gui' for glob 'lx*'
                                          Note, selecting 'lxqt-menu-data' for glob 'lx*'
                                          Note, selecting 'lxplug-ptbatt' for glob 'lx*'
                                          Note, selecting 'lxsession-dbgsym' for glob 'lx*'
                                          Note, selecting 'lxqt-themes' for glob 'lx*'
                                          Note, selecting 'lxhotkey-plugin-openbox' for glob 'lx*'
                                          Note, selecting 'lxqt-build-tools' for glob 'lx*'
                                          Note, selecting 'lxqt-config' for glob 'lx*'
                                          Note, selecting 'lxpanel-pi-dev' for glob 'lx*'
                                          Note, selecting 'lxtask-dbgsym' for glob 'lx*'
                                          Note, selecting 'lxqt-about-l10n' for glob 'lx*'
                                          Note, selecting 'lxqt-session' for glob 'lx*'
                                          Note, selecting 'lxde-settings-daemon' for glob 'lx*'
                                          Note, selecting 'lxqt-config-l10n' for glob 'lx*'
                                          Note, selecting 'lxd-agent' for glob 'lx*'
                                          Note, selecting 'lxqt-globalkeys' for glob 'lx*'
                                          Note, selecting 'lxmusic' for glob 'lx*'
                                          Note, selecting 'lxde-session' for glob 'lx*'
                                          Note, selecting 'lxsession-logout-dbgsym' for glob 'lx*'
                                          Note, selecting 'lxqt-notificationd' for glob 'lx*'
                                          Note, selecting 'lxsession-default-apps-dbgsym' for glob 'lx*'
                                          Note, selecting 'lxappearance' for glob 'lx*'
                                          Note, selecting 'lxterminal-dbgsym' for glob 'lx*'
                                          Note, selecting 'lxqt-notificationd-l10n' for glob 'lx*'
                                          Note, selecting 'libfm-tools' instead of 'lxshortcut'
                                          Note, selecting 'lxhotkey-gtk' instead of 'lxhotkey-gui'
                                          Note, selecting 'lxqt-branding-debian' instead of 'lxqt-branding'
                                          Package 'lxqt-qtplugin6' is not installed, so not removed
                                          Package 'lxqt-common' is not installed, so not removed
                                          Package 'lxplug-ptbatt' is not installed, so not removed
                                          Package 'lxplug-menu' is not installed, so not removed
                                          Note, selecting 'mesa-opencl-icd' for glob 'mesa*'
                                          Note, selecting 'mesa-test-tools' for glob 'mesa*'
                                          Note, selecting 'mesa-glide2-dev' for glob 'mesa*'
                                          Note, selecting 'mesag-dev' for glob 'mesa*'
                                          Note, selecting 'mesa-common-dev' for glob 'mesa*'
                                          Note, selecting 'mesa-vulkan-drivers-dbgsym' for glob 'mesa*'
                                          Note, selecting 'mesag3+ggi-dev' for glob 'mesa*'
                                          Note, selecting 'mesa-libgallium' for glob 'mesa*'
                                          Note, selecting 'mesa-drm-shim' for glob 'mesa*'
                                          Note, selecting 'mesa-va-drivers' for glob 'mesa*'
                                          Note, selecting 'mesa-libgallium-dbgsym' for glob 'mesa*'
                                          Note, selecting 'mesaflash' for glob 'mesa*'
                                          Note, selecting 'mesa-utils-bin' for glob 'mesa*'
                                          Note, selecting 'mesa-vulkan-drivers' for glob 'mesa*'
                                          Note, selecting 'mesa-drm-shim-dbgsym' for glob 'mesa*'
                                          Note, selecting 'mesa-utils-extra' for glob 'mesa*'
                                          Note, selecting 'mesa-teflon-delegate' for glob 'mesa*'
                                          Note, selecting 'mesa-opencl-icd-dbgsym' for glob 'mesa*'
                                          Note, selecting 'mesa-teflon-delegate-dbgsym' for glob 'mesa*'
                                          Note, selecting 'mesag3-widgets' for glob 'mesa*'
                                          Note, selecting 'mesa-utils' for glob 'mesa*'
                                          Note, selecting 'mesag3' for glob 'mesa*'
                                          Note, selecting 'mesa-vdpau-drivers' for glob 'mesa*'
                                          Note, selecting 'mesag-widgets-dev' for glob 'mesa*'
                                          Package 'mesa-test-tools' is not installed, so not removed
                                          Note, selecting 'libglw1-mesa-dev' instead of 'mesag-widgets-dev'
                                          Note, selecting 'libglw1-mesa-dev' instead of 'mesag3-widgets'
                                          Package 'mesag3' is not installed, so not removed
                                          Package 'mesa-glide2-dev' is not installed, so not removed
                                          Package 'mesag-dev' is not installed, so not removed
                                          Package 'mesag3+ggi-dev' is not installed, so not removed
                                          Note, selecting 'mesa-utils' instead of 'mesa-utils-extra'
                                          Package 'xserver-xephyr' is not installed, so not removed
                                          Package 'xserver-xorg-input-wacom' is not installed, so not removed
                                          Package 'xserver-xorg-input-synaptics' is not installed, so not removed
                                          Package 'xserver-x2gokdrive' is not installed, so not removed
                                          Package 'xserver-xorg-input-mtrack' is not installed, so not removed
                                          Package 'xserver-xorg-input-multitouch' is not installed, so not removed
                                          Package 'xserver-xorg-input-xwiimote' is not installed, so not removed
                                          Package 'xserver-xorg-dev' is not installed, so not removed
                                          Package 'xserver-xorg-legacy' is not installed, so not removed
                                          Package 'xserver-xorg-input-aiptek' is not installed, so not removed
                                          Package 'xserver-xorg-input-elographics' is not installed, so not removed
                                          Package 'xserver-xorg-input-evdev' is not installed, so not removed
                                          Package 'xserver-xorg-input-evdev-dev' is not installed, so not removed
                                          Package 'xserver-xorg-input-joystick' is not installed, so not removed
                                          Package 'xserver-xorg-input-joystick-dev' is not installed, so not removed
                                          Package 'xserver-xorg-input-kbd' is not installed, so not removed
                                          Package 'xserver-xorg-input-libinput-dev' is not installed, so not removed
                                          Package 'xserver-xorg-input-mouse' is not installed, so not removed
                                          Package 'xserver-xorg-input-synaptics-dev' is not installed, so not removed
                                          Package 'xserver-xorg-video-r128' is not installed, so not removed
                                          Package 'xserver-xorg-video-mach64' is not installed, so not removed
                                          Package 'xserver-xorg-video-cirrus' is not installed, so not removed
                                          Package 'xserver-xorg-video-dummy' is not installed, so not removed
                                          Package 'xserver-xorg-video-mga' is not installed, so not removed
                                          Package 'xserver-xorg-video-neomagic' is not installed, so not removed
                                          Package 'xserver-xorg-video-qxl' is not installed, so not removed
                                          Package 'xserver-xorg-video-savage' is not installed, so not removed
                                          Package 'xserver-xorg-video-siliconmotion' is not installed, so not removed
                                          Package 'xserver-xorg-video-sisusb' is not installed, so not removed
                                          Package 'xserver-xorg-video-nvidia' is not installed, so not removed
                                          Package 'xserver-xorg-video-nvidia-tesla-535' is not installed, so not removed
                                          Package 'xserver-xephyr-dbgsym' is not installed, so not removed
                                          Package 'xserver-xorg-core-dbgsym' is not installed, so not removed
                                          Package 'xserver-xorg-legacy-dbgsym' is not installed, so not removed
                                          Package 'xserver-xorg-video-fbturbo-dbgsym' is not installed, so not removed
                                          Package 'lightdm-remote-session-x2go' is not installed, so not removed
                                          Package 'lightdm-vala' is not installed, so not removed
                                          Package 'lightdm-autologin-greeter' is not installed, so not removed
                                          Package 'lightdm-gtk-greeter-settings' is not installed, so not removed
                                          Package 'lightdm-settings' is not installed, so not removed
                                          Package 'lightdm-dbgsym' is not installed, so not removed
                                          Package 'vlc-plugin-jack' is not installed, so not removed
                                          Package 'vlc-plugin-fluidsynth' is not installed, so not removed
                                          Package 'vlc-plugin-pipewire' is not installed, so not removed
                                          Package 'vlc-plugin-svg' is not installed, so not removed
                                          Package 'vlc-plugin-bittorrent' is not installed, so not removed
                                          Package 'vlc-bin-dbgsym' is not installed, so not removed
                                          Package 'vlc-plugin-access-extra-dbgsym' is not installed, so not removed
                                          Package 'vlc-plugin-base-dbgsym' is not installed, so not removed
                                          Package 'vlc-plugin-fluidsynth-dbgsym' is not installed, so not removed
                                          Package 'vlc-plugin-jack-dbgsym' is not installed, so not removed
                                          Package 'vlc-plugin-notify-dbgsym' is not installed, so not removed
                                          Package 'vlc-plugin-qt-dbgsym' is not installed, so not removed
                                          Package 'vlc-plugin-samba-dbgsym' is not installed, so not removed
                                          Package 'vlc-plugin-skins2-dbgsym' is not installed, so not removed
                                          Package 'vlc-plugin-svg-dbgsym' is not installed, so not removed
                                          Package 'vlc-plugin-video-output-dbgsym' is not installed, so not removed
                                          Package 'vlc-plugin-video-splitter-dbgsym' is not installed, so not removed
                                          Package 'vlc-plugin-visualization-dbgsym' is not installed, so not removed
                                          Package 'lxde-settings-daemon' is not installed, so not removed
                                          Package 'lxde-settings-daemon-dbgsym' is not installed, so not removed
                                          Package 'chromium-lwn4chrome' is not installed, so not removed
                                          Package 'chromium-shell' is not installed, so not removed
                                          Package 'chromium-driver' is not installed, so not removed
                                          Package 'chromium-headless-shell' is not installed, so not removed
                                          Package 'chromium-bsu' is not installed, so not removed
                                          Package 'chromium-bsu-data' is not installed, so not removed
                                          Package 'chromium-browser-l10n' is not installed, so not removed
                                          Package 'chromium-chromedriver' is not installed, so not removed
                                          Package 'chromium-common-dbgsym' is not installed, so not removed
                                          Package 'chromium-dbgsym' is not installed, so not removed
                                          Package 'chromium-headless-shell-dbgsym' is not installed, so not removed
                                          Package 'chromium-sandbox-dbgsym' is not installed, so not removed
                                          Package 'chromium-shell-dbgsym' is not installed, so not removed
                                          Package 'desktop-autoloader' is not installed, so not removed
                                          Package 'desktopfolder' is not installed, so not removed
                                          Package 'gnome-control-center' is not installed, so not removed
                                          Package 'gnome-screensaver' is not installed, so not removed
                                          Package 'gnome-themes-extra' is not installed, so not removed
                                          Package 'gnome-cards-data' is not installed, so not removed
                                          Package 'gnome-package-updater' is not installed, so not removed
                                          Package 'gnome-terminal' is not installed, so not removed
                                          Package 'gnome-panel-data' is not installed, so not removed
                                          Package 'gnome-common' is not installed, so not removed
                                          Package 'gnome-shell-extension-appindicator' is not installed, so not removed
                                          Package 'gnome-session-canberra' is not installed, so not removed
                                          Package 'gnome-settings-daemon' is not installed, so not removed
                                          Package 'gnome-user-docs' is not installed, so not removed
                                          Package 'gnome-user-share' is not installed, so not removed
                                          Package 'gnome-software' is not installed, so not removed
                                          Package 'gnome-packagekit' is not installed, so not removed
                                          Package 'gnome-calculator' is not installed, so not removed
                                          Package 'gnome-power-manager' is not installed, so not removed
                                          Package 'gnome-calls' is not installed, so not removed
                                          Package 'gnome-video-effects' is not installed, so not removed
                                          Package 'gnome-video-effects-frei0r' is not installed, so not removed
                                          Package 'gnome-backgrounds' is not installed, so not removed
                                          Package 'gnome-online-accounts-gtk' is not installed, so not removed
                                          Package 'gnome-text-editor' is not installed, so not removed
                                          Package 'gnome-screenshot' is not installed, so not removed
                                          Package 'gnome-snapshot' is not installed, so not removed
                                          Package 'gnome-characters' is not installed, so not removed
                                          Package 'gnome-disk-utility' is not installed, so not removed
                                          Package 'gnome-font-viewer' is not installed, so not removed
                                          Package 'gnome-games' is not installed, so not removed
                                          Package 'gnome-logs' is not installed, so not removed
                                          Package 'gnome-sound-recorder' is not installed, so not removed
                                          Package 'gnome-system-monitor' is not installed, so not removed
                                          Package 'gnome-connections' is not installed, so not removed
                                          Package 'gnome-color-manager' is not installed, so not removed
                                          Package 'gnome-desktop-testing' is not installed, so not removed
                                          Package 'gnome-accessibility-themes' is not installed, so not removed
                                          Package 'gnome-builder' is not installed, so not removed
                                          Package 'gnome-mines' is not installed, so not removed
                                          Package 'gnome-mahjongg' is not installed, so not removed
                                          Package 'gnomekiss' is not installed, so not removed
                                          Package 'gnome-clocks' is not installed, so not removed
                                          Package 'gnome-nibbles' is not installed, so not removed
                                          Package 'gnome-sudoku' is not installed, so not removed
                                          Package 'gnome-metronome' is not installed, so not removed
                                          Package 'gnome-pkg-tools' is not installed, so not removed
                                          Package 'gnome' is not installed, so not removed
                                          Package 'gnome-ponytail-daemon' is not installed, so not removed
                                          Package 'gnome-human-icon-theme' is not installed, so not removed
                                          Package 'gnome-epub-thumbnailer' is not installed, so not removed
                                          Package 'gnome-shell-extension-gamemode' is not installed, so not removed
                                          Package 'gnome-icon-theme-gartoon' is not installed, so not removed
                                          Package 'gnome-session' is not installed, so not removed
                                          Package 'gnome-session-bin' is not installed, so not removed
                                          Package 'gnome-session-common' is not installed, so not removed
                                          Package 'gnome-shell' is not installed, so not removed
                                          Package 'gnome-genius' is not installed, so not removed
                                          Package 'gnome-initial-setup' is not installed, so not removed
                                          Package 'gnome-maps' is not installed, so not removed
                                          Package 'gnome-2048' is not installed, so not removed
                                          Package 'gnome-activity-journal' is not installed, so not removed
                                          Package 'gnome-applets' is not installed, so not removed
                                          Package 'gnome-applets-data' is not installed, so not removed
                                          Package 'gnome-panel' is not installed, so not removed
                                          Package 'gnome-flashback' is not installed, so not removed
                                          Package 'gnome-audio' is not installed, so not removed
                                          Package 'gnome-core' is not installed, so not removed
                                          Package 'gnome-authenticator' is not installed, so not removed
                                          Package 'gnome-bluetooth-3-common' is not installed, so not removed
                                          Package 'gnome-bluetooth-sendto' is not installed, so not removed
                                          Package 'gnome-boxes' is not installed, so not removed
                                          Package 'gnome-breakout' is not installed, so not removed
                                          Package 'gnome-browser-connector' is not installed, so not removed
                                          Package 'gnome-calendar' is not installed, so not removed
                                          Package 'gnome-contacts' is not installed, so not removed
                                          Package 'gnome-calls-doc' is not installed, so not removed
                                          Package 'gnome-chess' is not installed, so not removed
                                          Package 'gnome-brave-icon-theme' is not installed, so not removed
                                          Package 'gnome-colors-common' is not installed, so not removed
                                          Package 'gnome-colors' is not installed, so not removed
                                          Package 'gnome-dust-icon-theme' is not installed, so not removed
                                          Package 'gnome-illustrious-icon-theme' is not installed, so not removed
                                          Package 'gnome-noble-icon-theme' is not installed, so not removed
                                          Package 'gnome-wine-icon-theme' is not installed, so not removed
                                          Package 'gnome-wise-icon-theme' is not installed, so not removed
                                          Package 'gnome-commander' is not installed, so not removed
                                          Package 'gnome-commander-data' is not installed, so not removed
                                          Package 'gnome-console' is not installed, so not removed
                                          Package 'gnome-control-center-data' is not installed, so not removed
                                          Package 'gnome-online-accounts' is not installed, so not removed
                                          Package 'gnome-remote-desktop' is not installed, so not removed
                                          Package 'gnome-control-center-dev' is not installed, so not removed
                                          Package 'gnome-decoder' is not installed, so not removed
                                          Package 'gnome-desktop-3-tests' is not installed, so not removed
                                          Package 'gnome-extra-icons' is not installed, so not removed
                                          Package 'gnome-feeds' is not installed, so not removed
                                          Package 'gnome-firmware' is not installed, so not removed
                                          Package 'gnome-flashback-common' is not installed, so not removed
                                          Package 'gnome-session-flashback' is not installed, so not removed
                                          Package 'gnome-hwp-support' is not installed, so not removed
                                          Package 'gnome-icon-theme-nuovo' is not installed, so not removed
                                          Package 'gnome-icon-theme-yasis' is not installed, so not removed
                                          Package 'gnome-keyring-pkcs11' is not installed, so not removed
                                          Package 'gnome-keysign' is not installed, so not removed
                                          Package 'gnome-kiosk' is not installed, so not removed
                                          Package 'gnome-kiosk-search-appliance' is not installed, so not removed
                                          Package 'gnome-kiosk-script-session' is not installed, so not removed
                                          Package 'gnome-klotski' is not installed, so not removed
                                          Package 'gnome-mastermind' is not installed, so not removed
                                          Package 'gnome-model-thumbnailer' is not installed, so not removed
                                          Package 'gnome-mousetrap' is not installed, so not removed
                                          Package 'gnome-multi-writer' is not installed, so not removed
                                          Package 'gnome-music' is not installed, so not removed
                                          Package 'gnome-nds-thumbnailer' is not installed, so not removed
                                          Package 'gnome-nettool' is not installed, so not removed
                                          Package 'gnome-network-displays' is not installed, so not removed
                                          Package 'gnome-packagekit-common' is not installed, so not removed
                                          Package 'gnome-pass-search-provider' is not installed, so not removed
                                          Package 'gnome-photos' is not installed, so not removed
                                          Package 'gnome-photos-tests' is not installed, so not removed
                                          Package 'gnome-pie' is not installed, so not removed
                                          Package 'gnome-podcasts' is not installed, so not removed
                                          Package 'gnome-settings-daemon-common' is not installed, so not removed
                                          Package 'gnome-recipes' is not installed, so not removed
                                          Package 'gnome-recipes-data' is not installed, so not removed
                                          Package 'gnome-robots' is not installed, so not removed
                                          Package 'gnome-screensaver-flags' is not installed, so not removed
                                          Package 'gnome-session-xsession' is not installed, so not removed
                                          Package 'gnome-settings-daemon-dev' is not installed, so not removed
                                          Package 'gnome-shell-common' is not installed, so not removed
                                          Package 'gnome-shell-extension-dash-to-panel' is not installed, so not removed
                                          Package 'gnome-shell-extension-dashtodock' is not installed, so not removed
                                          Package 'gnome-shell-extension-desktop-icons-ng' is not installed, so not removed
                                          Package 'gnome-shell-extensions' is not installed, so not removed
                                          Package 'gnome-shell-extension-prefs' is not installed, so not removed
                                          Package 'gnome-shell-extension-arc-menu' is not installed, so not removed
                                          Package 'gnome-shell-extension-autohidetopbar' is not installed, so not removed
                                          Package 'gnome-shell-extension-blur-my-shell' is not installed, so not removed
                                          Package 'gnome-shell-extension-caffeine' is not installed, so not removed
                                          Package 'gnome-shell-extension-manager' is not installed, so not removed
                                          Package 'gnome-shell-extension-easyscreencast' is not installed, so not removed
                                          Package 'gnome-shell-extension-flypie' is not installed, so not removed
                                          Package 'gnome-shell-extension-freon' is not installed, so not removed
                                          Package 'gnome-shell-extension-gsconnect' is not installed, so not removed
                                          Package 'gnome-shell-extension-gsconnect-browsers' is not installed, so not removed
                                          Package 'gnome-shell-extension-hamster' is not installed, so not removed
                                          Package 'gnome-shell-extension-hard-disk-led' is not installed, so not removed
                                          Package 'gnome-shell-extension-hide-activities' is not installed, so not removed
                                          Package 'gnome-shell-extension-impatience' is not installed, so not removed
                                          Package 'gnome-shell-extension-kimpanel' is not installed, so not removed
                                          Package 'gnome-shell-extension-no-annoyance' is not installed, so not removed
                                          Package 'gnome-shell-extension-runcat' is not installed, so not removed
                                          Package 'gnome-shell-extension-shortcuts' is not installed, so not removed
                                          Package 'gnome-shell-extension-tiling-assistant' is not installed, so not removed
                                          Package 'gnome-shell-extension-weather' is not installed, so not removed
                                          Package 'gnome-classic' is not installed, so not removed
                                          Package 'gnome-shell-extension-apps-menu' is not installed, so not removed
                                          Package 'gnome-shell-extension-places-menu' is not installed, so not removed
                                          Package 'gnome-shell-extension-launch-new-instance' is not installed, so not removed
                                          Package 'gnome-shell-extension-window-list' is not installed, so not removed
                                          Package 'gnome-classic-xsession' is not installed, so not removed
                                          Package 'gnome-shell-extensions-common' is not installed, so not removed
                                          Package 'gnome-shell-extension-auto-move-windows' is not installed, so not removed
                                          Package 'gnome-shell-extension-drive-menu' is not installed, so not removed
                                          Package 'gnome-shell-extension-light-style' is not installed, so not removed
                                          Package 'gnome-shell-extension-native-window-placement' is not installed, so not removed
                                          Package 'gnome-shell-extension-screenshot-window-sizer' is not installed, so not removed
                                          Package 'gnome-shell-extension-status-icons' is not installed, so not removed
                                          Package 'gnome-shell-extension-system-monitor' is not installed, so not removed
                                          Package 'gnome-shell-extension-user-theme' is not installed, so not removed
                                          Package 'gnome-shell-extension-windows-navigator' is not installed, so not removed
                                          Package 'gnome-shell-extension-workspace-indicator' is not installed, so not removed
                                          Package 'gnome-shell-extensions-extra' is not installed, so not removed
                                          Package 'gnome-tweaks' is not installed, so not removed
                                          Package 'gnome-shell-pomodoro' is not installed, so not removed
                                          Package 'gnome-shell-pomodoro-data' is not installed, so not removed
                                          Package 'gnome-software-plugin-deb' is not installed, so not removed
                                          Package 'gnome-software-common' is not installed, so not removed
                                          Package 'gnome-software-plugin-fwupd' is not installed, so not removed
                                          Package 'gnome-software-plugin-flatpak' is not installed, so not removed
                                          Package 'gnome-software-plugin-snap' is not installed, so not removed
                                          Package 'gnome-software-dev' is not installed, so not removed
                                          Package 'gnome-software-doc' is not installed, so not removed
                                          Package 'gnome-sushi' is not installed, so not removed
                                          Package 'gnome-system-tools' is not installed, so not removed
                                          Package 'gnome-taquin' is not installed, so not removed
                                          Package 'gnome-terminal-data' is not installed, so not removed
                                          Package 'gnome-tetravex' is not installed, so not removed
                                          Package 'gnome-tour' is not installed, so not removed
                                          Package 'gnome-usage' is not installed, so not removed
                                          Package 'gnome-video-effects-dev' is not installed, so not removed
                                          Package 'gnome-video-trimmer' is not installed, so not removed
                                          Package 'gnome-weather' is not installed, so not removed
                                          Package 'gnome-shell-extension-gpaste' is not installed, so not removed
                                          Package 'gnome-api-docs' is not installed, so not removed
                                          Package 'gnome-devel' is not installed, so not removed
                                          Package 'gnome-platform-devel' is not installed, so not removed
                                          Package 'gnome-theme-gilouche' is not installed, so not removed
                                          Package 'gnome-panel-control' is not installed, so not removed
                                          Package 'gnome-icon-theme-suede' is not installed, so not removed
                                          Package 'gnome-panel-control-dbgsym' is not installed, so not removed
                                          Package 'gstreamer1.0-plugins-ugly' is not installed, so not removed
                                          Package 'gstreamer1.0-pipewire' is not installed, so not removed
                                          Package 'gstreamer1.0-pulseaudio' is not installed, so not removed
                                          Package 'gstreamer1.0-tools' is not installed, so not removed
                                          Package 'gstreamer1.0-clutter-3.0' is not installed, so not removed
                                          Package 'gstreamer1.0-nice' is not installed, so not removed
                                          Package 'gstreamer1.0-gl' is not installed, so not removed
                                          Package 'gstreamer1.0-gtk3' is not installed, so not removed
                                          Package 'gstreamer1.0-gtk4' is not installed, so not removed
                                          Package 'gstreamer1.0-libcamera' is not installed, so not removed
                                          Package 'gstreamer1.0-opencv' is not installed, so not removed
                                          Package 'gstreamer1.0-plugins-bad-apps' is not installed, so not removed
                                          Package 'gstreamer1.0-wpe' is not installed, so not removed
                                          Package 'gstreamer1.0-plugins-base-apps' is not installed, so not removed
                                          Package 'gstreamer1.0-espeak' is not installed, so not removed
                                          Package 'gstreamer1.0-qt5' is not installed, so not removed
                                          Package 'gstreamer1.0-qt6' is not installed, so not removed
                                          Package 'gstreamer1.0-plugins-rtp' is not installed, so not removed
                                          Package 'gstreamer1.0-python3-plugin-loader' is not installed, so not removed
                                          Package 'gstreamer1.0-rtsp' is not installed, so not removed
                                          Package 'gstreamer1.0-vaapi' is not installed, so not removed
                                          Package 'gstreamer1.0-packagekit' is not installed, so not removed
                                          Package 'gstreamer1.0-pocketsphinx' is not installed, so not removed
                                          Package 'gstreamer1.0-adapter-pulseeffects' is not installed, so not removed
                                          Package 'gstreamer1.0-autogain-pulseeffects' is not installed, so not removed
                                          Package 'gstreamer1.0-convolver-pulseeffects' is not installed, so not removed
                                          Package 'gstreamer1.0-crystalizer-pulseeffects' is not installed, so not removed
                                          Package 'gstreamer1.0-fdkaac' is not installed, so not removed
                                          Package 'gstreamer1.0-alsa-dbgsym' is not installed, so not removed
                                          Package 'gstreamer1.0-gl-dbgsym' is not installed, so not removed
                                          Package 'gstreamer1.0-libcamera-dbgsym' is not installed, so not removed
                                          Package 'gstreamer1.0-opencv-dbgsym' is not installed, so not removed
                                          Package 'gstreamer1.0-pipewire-dbgsym' is not installed, so not removed
                                          Package 'gstreamer1.0-pispconvert' is not installed, so not removed
                                          Package 'gstreamer1.0-pispconvert-dbgsym' is not installed, so not removed
                                          Package 'gstreamer1.0-plugins-bad-apps-dbgsym' is not installed, so not removed
                                          Package 'gstreamer1.0-plugins-bad-dbgsym' is not installed, so not removed
                                          Package 'gstreamer1.0-plugins-base-apps-dbgsym' is not installed, so not removed
                                          Package 'gstreamer1.0-plugins-base-dbgsym' is not installed, so not removed
                                          Package 'gstreamer1.0-wpe-dbgsym' is not installed, so not removed
                                          Package 'gstreamer1.0-x-dbgsym' is not installed, so not removed
                                          Package 'gtk2-engines-murrine' is not installed, so not removed
                                          Package 'gtkmm-documentation' is not installed, so not removed
                                          Package 'gtkwave' is not installed, so not removed
                                          Package 'gtkatlantic' is not installed, so not removed
                                          Package 'gtkballs' is not installed, so not removed
                                          Package 'gtklp' is not installed, so not removed
                                          Package 'gtk-3-examples' is not installed, so not removed
                                          Package 'gtk-chtheme' is not installed, so not removed
                                          Package 'gtk-doc-tools' is not installed, so not removed
                                          Package 'gtk-im-libthai' is not installed, so not removed
                                          Package 'gtk3-im-libthai' is not installed, so not removed
                                          Package 'gtk-layer-shell-doc' is not installed, so not removed
                                          Package 'gtk-layer-shell-examples' is not installed, so not removed
                                          Package 'gtk-meshtastic-client' is not installed, so not removed
                                          Package 'gtk-session-lock-examples' is not installed, so not removed
                                          Package 'gtk-theme-switch' is not installed, so not removed
                                          Package 'gtk2-engines-aurora' is not installed, so not removed
                                          Package 'gtk2hs-buildtools' is not installed, so not removed
                                          Package 'gtk3-nocsd' is not installed, so not removed
                                          Package 'gtk-4-examples' is not installed, so not removed
                                          Package 'gtk-4-tests' is not installed, so not removed
                                          Package 'gtk4-layer-shell-doc' is not installed, so not removed
                                          Package 'gtk4-layer-shell-examples' is not installed, so not removed
                                          Package 'gtkam' is not installed, so not removed
                                          Package 'gtkcrypto' is not installed, so not removed
                                          Package 'gtkgreet' is not installed, so not removed
                                          Package 'gtkhash' is not installed, so not removed
                                          Package 'gtklock' is not installed, so not removed
                                          Package 'gtklock-playerctl-module' is not installed, so not removed
                                          Package 'gtklock-userinfo-module' is not installed, so not removed
                                          Package 'gtkman' is not installed, so not removed
                                          Package 'gtkterm' is not installed, so not removed
                                          Package 'gtk2-engines-qtcurve' is not installed, so not removed
                                          Package 'gtkmorph-example' is not installed, so not removed
                                          Package 'gtk-3-examples-dbgsym' is not installed, so not removed
                                          Package 'gtk-nop-dbgsym' is not installed, so not removed
                                          Package 'gtk2-engines-clearlookspix' is not installed, so not removed
                                          Package 'gtk2-engines-clearlookspix-dbgsym' is not installed, so not removed
                                          Package 'gtk2-engines-pixbuf-dbgsym' is not installed, so not removed
                                          Package 'gtk2-engines-pixflat-dbgsym' is not installed, so not removed
                                          Package 'lxc' is not installed, so not removed
                                          Package 'lxd' is not installed, so not removed
                                          Package 'lxqt-policykit' is not installed, so not removed
                                          Package 'lxi-tools' is not installed, so not removed
                                          Package 'lxc-dev' is not installed, so not removed
                                          Package 'lxqt-menu-data' is not installed, so not removed
                                          Package 'lxcfs' is not installed, so not removed
                                          Package 'lxd-tools' is not installed, so not removed
                                          Package 'lxqt-build-tools' is not installed, so not removed
                                          Package 'lx-gdb' is not installed, so not removed
                                          Package 'lxc-templates' is not installed, so not removed
                                          Package 'lxc-tests' is not installed, so not removed
                                          Package 'lxctl' is not installed, so not removed
                                          Package 'lxd-client' is not installed, so not removed
                                          Package 'lxd-agent' is not installed, so not removed
                                          Package 'lxd-migrate' is not installed, so not removed
                                          Package 'lxlock' is not installed, so not removed
                                          Package 'lxlauncher' is not installed, so not removed
                                          Package 'lxinput' is not installed, so not removed
                                          Package 'lxmusic' is not installed, so not removed
                                          Package 'lxdm' is not installed, so not removed
                                          Package 'lxhotkey-plugin-openbox' is not installed, so not removed
                                          Package 'lxhotkey-data' is not installed, so not removed
                                          Package 'lxhotkey-dev' is not installed, so not removed
                                          Package 'lximage-qt' is not installed, so not removed
                                          Package 'lximage-qt-l10n' is not installed, so not removed
                                          Package 'lxpanel-dev' is not installed, so not removed
                                          Package 'lxqt-about' is not installed, so not removed
                                          Package 'lxqt-about-l10n' is not installed, so not removed
                                          Package 'lxqt-qtplugin' is not installed, so not removed
                                          Package 'lxqt-admin' is not installed, so not removed
                                          Package 'lxqt-admin-l10n' is not installed, so not removed
                                          Package 'lxqt-archiver' is not installed, so not removed
                                          Package 'lxqt-archiver-l10n' is not installed, so not removed
                                          Package 'lxqt-branding-debian' is not installed, so not removed
                                          Package 'lxqt-theme-debian' is not installed, so not removed
                                          Package 'lxqt-system-theme' is not installed, so not removed
                                          Package 'lxqt-build-tools-qt5' is not installed, so not removed
                                          Package 'lxqt-config' is not installed, so not removed
                                          Package 'lxqt-config-l10n' is not installed, so not removed
                                          Package 'lxqt-powermanagement' is not installed, so not removed
                                          Package 'lxqt-session' is not installed, so not removed
                                          Package 'lxqt' is not installed, so not removed
                                          Package 'lxqt-core' is not installed, so not removed
                                          Package 'lxqt-globalkeys' is not installed, so not removed
                                          Package 'lxqt-globalkeys-l10n' is not installed, so not removed
                                          Package 'lxqt-panel' is not installed, so not removed
                                          Package 'lxqt-openssh-askpass' is not installed, so not removed
                                          Package 'lxqt-sudo' is not installed, so not removed
                                          Package 'lxqt-themes' is not installed, so not removed
                                          Package 'lxqt-notificationd' is not installed, so not removed
                                          Package 'lxqt-runner' is not installed, so not removed
                                          Package 'lxqt-notificationd-l10n' is not installed, so not removed
                                          Package 'lxqt-openssh-askpass-l10n' is not installed, so not removed
                                          Package 'lxqt-panel-l10n' is not installed, so not removed
                                          Package 'lxqt-policykit-l10n' is not installed, so not removed
                                          Package 'lxqt-powermanagement-l10n' is not installed, so not removed
                                          Package 'lxqt-qt5plugin' is not installed, so not removed
                                          Package 'lxqt-runner-l10n' is not installed, so not removed
                                          Package 'lxqt-session-l10n' is not installed, so not removed
                                          Package 'lxqt-sudo-l10n' is not installed, so not removed
                                          Package 'lxsession-default-apps' is not installed, so not removed
                                          Package 'lxpanel-pi' is not installed, so not removed
                                          Package 'lxpanel-pi-dbgsym' is not installed, so not removed
                                          Package 'lxpanel-pi-dev' is not installed, so not removed
                                          Package 'lxpanel-pi-dev-dbgsym' is not installed, so not removed
                                          Package 'lxpolkit-dbgsym' is not installed, so not removed
                                          Package 'lxsession-dbgsym' is not installed, so not removed
                                          Package 'lxsession-default-apps-dbgsym' is not installed, so not removed
                                          Package 'lxsession-edit-dbgsym' is not installed, so not removed
                                          Package 'lxsession-logout-dbgsym' is not installed, so not removed
                                          Package 'lxtask-dbgsym' is not installed, so not removed
                                          Package 'lxterminal-dbgsym' is not installed, so not removed
                                          Package 'mesa-utils' is not installed, so not removed
                                          Package 'mesa-common-dev' is not installed, so not removed
                                          Package 'mesa-opencl-icd' is not installed, so not removed
                                          Package 'mesa-va-drivers' is not installed, so not removed
                                          Package 'mesaflash' is not installed, so not removed
                                          Package 'mesa-drm-shim' is not installed, so not removed
                                          Package 'mesa-teflon-delegate' is not installed, so not removed
                                          Package 'mesa-vulkan-drivers' is not installed, so not removed
                                          Package 'mesa-utils-bin' is not installed, so not removed
                                          Package 'mesa-drm-shim-dbgsym' is not installed, so not removed
                                          Package 'mesa-libgallium-dbgsym' is not installed, so not removed
                                          Package 'mesa-opencl-icd-dbgsym' is not installed, so not removed
                                          Package 'mesa-teflon-delegate-dbgsym' is not installed, so not removed
                                          Package 'mesa-vulkan-drivers-dbgsym' is not installed, so not removed
                                          You might want to run 'apt --fix-broken install' to correct these.
                                          The following packages have unmet dependencies:
                                           adwaita-icon-theme : Depends: gtk-update-icon-cache
        Depends: hicolor-icon-theme but it is not going to be installed
                                           alacarte : Depends: gnome-menus (>= 3.5.3) but it is not going to be installed
                                           evince : Depends: libglib2.0-0t64 (>= 2.83.0) but it is not going to be installed
                                                    Depends: libgtk-3-0t64 (>= 3.22.0) but it is not going to be installed
                                           galculator : Depends: libglib2.0-0t64 (>= 2.16.0) but it is not going to be installed
                                                        Depends: libgtk-3-0t64 (>= 3.3.16) but it is not going to be installed
                                           gcr : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                           gcr4 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                           geany : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                                   Depends: libgtk-3-0t64 (>= 3.21.5) but it is not going to be installed
                                           gir1.2-glib-2.0 : Depends: libglib2.0-0t64 (= 2.84.4-3~deb13u3) but it is not going to be installed
                                           gir1.2-gtk-3.0 : Depends: libgtk-3-0t64 (>= 3.24.36-2+rpt1) but it is not going to be installed
                                           girepository-tools : Depends: libglib2.0-0t64 (= 2.84.4-3~deb13u3) but it is not going to be installed
                                           gui-pkinst : Depends: libglib2.0-0t64 (>= 2.22.0) but it is not going to be installed
                                                        Depends: libgtk-3-0t64 (>= 3.24) but it is not going to be installed
                                           gui-updater : Depends: libglib2.0-0t64 (>= 2.14.0) but it is not going to be installed
                                           gvfs : Depends: libglib2.0-0t64 (>= 2.83.0) but it is not going to be installed
                                           gvfs-backends : Depends: libglib2.0-0t64 (>= 2.83.0) but it is not going to be installed
                                                           Recommends: gnome-keyring or
        kwalletmanager but it is not going to be installed
                                                           Recommends: wsdd but it is not installable
                                           gvfs-common : Depends: desktop-file-utils
                                           gvfs-daemons : Depends: libglib2.0-0t64 (>= 2.83.0) but it is not going to be installed
                                           gvfs-fuse : Depends: libglib2.0-0t64 (>= 2.83.0) but it is not going to be installed
                                           gvfs-libs : Depends: libglib2.0-0t64 (>= 2.83.0) but it is not going to be installed
                                           libadwaita-1-0 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                           libappstream5 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                           libatk1.0-0t64 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                           libatkmm-1.6-1v5 : Depends: libglib2.0-0t64 (>= 2.34.0) but it is not going to be installed
                                           libavahi-glib1 : Depends: libglib2.0-0t64 (>= 2.16.0) but it is not going to be installed
                                           libavcodec61 : Depends: libglib2.0-0t64 (>= 2.12.0) but it is not going to be installed
                                           libayatana-ido3-0.4-0 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
        Depends: libgtk-3-0t64 (>= 3.21.4) but it is not going to be installed
                                           libayatana-indicator3-7 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                           libbabeltrace1 : Depends: libglib2.0-0t64 (>= 2.76.0) but it is not going to be installed
                                           libcairo-gobject2 : Depends: libglib2.0-0t64 (>= 2.68.0) but it is not going to be installed
                                           libcamera0.5 : Depends: libcamera-ipa (= 0.5.2+rpt20250903-1~bpo12+1) but 0.7.1+rpt20260609-1 is to be installed
                                           libcloudproviders0 : Depends: libglib2.0-0t64 (>= 2.56.0) but it is not going to be installed
                                           libegl-mesa0 : Depends: mesa-libgallium (= 25.0.7-2+rpt4) but it is not going to be installed
                                           libevdocument3-4t64 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                           libevview3-3t64 : Depends: gstreamer1.0-plugins-base but it is not going to be installed
                                           libfm-extra4t64 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                           libfm-gtk3-4t64 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                           libfm-modules : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                                           Depends: libgtk-3-0t64 (>= 3.0.0) but it is not going to be installed
                                           libfm4t64 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                                       Depends: lxmenu-data but it is not going to be installed
                                           libgbm1 : Depends: mesa-libgallium (= 25.0.7-2+rpt4) but it is not going to be installed
                                           libgck-1-0 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                           libgck-2-2 : Depends: libglib2.0-0t64 (>= 2.74.0) but it is not going to be installed
                                           libgcr-4-4 : Depends: libglib2.0-0t64 (>= 2.74.0) but it is not going to be installed
                                           libgcr-base-3-1 : Depends: libglib2.0-0t64 (>= 2.83.0) but it is not going to be installed
                                           libgcr-ui-3-1 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                           libgio-2.0-dev : Depends: libglib2.0-0t64 (= 2.84.4-3~deb13u3) but it is not going to be installed
                                           libgio-2.0-dev-bin : Depends: libglib2.0-0t64 (= 2.84.4-3~deb13u3) but it is not going to be installed
                                           libgirepository-1.0-1 : Depends: libglib2.0-0t64 (>= 2.82.0) but it is not going to be installed
                                           libgirepository-2.0-0 : Depends: libglib2.0-0t64 (= 2.84.4-3~deb13u3) but it is not going to be installed
                                           libglib2.0-bin : Depends: libglib2.0-0t64 (= 2.84.4-3~deb13u3) but it is not going to be installed
                                           libglibmm-2.4-1t64 : Depends: libglib2.0-0t64 (>= 2.62.0) but it is not going to be installed
                                           libglx-mesa0 : Depends: mesa-libgallium (= 25.0.7-2+rpt4) but it is not going to be installed
                                           libgnome-desktop-3-20t64 : Depends: gnome-desktop3-data (>= 44.3-3) but it is not going to be installed
        Depends: gnome-desktop3-data (< 45~) but it is not going to be installed
        Depends: libgtk-3-0t64 (>= 3.9.10) but it is not going to be installed
                                           libgoa-1.0-0b : Depends: libglib2.0-0t64 (>= 2.83.0) but it is not going to be installed
                                           libgraphene-1.0-0 : Depends: libglib2.0-0t64 (>= 2.14.0) but it is not going to be installed
                                           libgspell-1-3 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                                           Depends: libgtk-3-0t64 (>= 3.20) but it is not going to be installed
                                           libgstreamer-gl1.0-0 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
        Recommends: gstreamer1.0-gl but it is not going to be installed
                                           libgstreamer-plugins-bad1.0-0 : Depends: libglib2.0-0t64 (>= 2.81.1) but it is not going to be installed
                                           libgstreamer-plugins-base1.0-0 : Depends: libglib2.0-0t64 (>= 2.81.1) but it is not going to be installed
        Recommends: gstreamer1.0-plugins-base but it is not going to be installed
                                           libgstreamer1.0-0 : Depends: libglib2.0-0t64 (>= 2.81.1) but it is not going to be installed
                                           libgtk-3-0 : Depends: hicolor-icon-theme but it is not going to be installed
                                                        Recommends: libgtk-3-bin
                                           libgtk-4-1 : Depends: hicolor-icon-theme but it is not going to be installed
                                                        Recommends: libgtk-4-bin
                                                        Recommends: libgtk-4-media-gstreamer
                                           libgtk-layer-shell0 : Depends: libglib2.0-0t64 (>= 2.42.0) but it is not going to be installed
        Depends: libgtk-3-0t64 (>= 3.24.48) but it is not going to be installed
                                           libgtk2.0-0 : Depends: hicolor-icon-theme but it is not going to be installed
                                                         Recommends: libgail-common but it is not going to be installed
                                           libgtk2.0-bin : Depends: gtk-update-icon-cache
                                           libgtkmm-3.0-1t64 : Depends: libglib2.0-0t64 (>= 2.42.0) but it is not going to be installed
                                                               Depends: libgtk-3-0t64 (>= 3.24.0) but it is not going to be installed
                                           libgtksourceview-4-0 : Depends: libglib2.0-0t64 (>= 2.48.0) but it is not going to be installed
                                           libgxps2t64 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                           libhandy-1-0 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                                          Depends: libgtk-3-0t64 (>= 3.23.1) but it is not going to be installed
                                           libharfbuzz-gobject0 : Depends: libglib2.0-0t64 (>= 2.14.0) but it is not going to be installed
                                           libharfbuzz0b : Depends: libglib2.0-0t64 (>= 2.32.0) but it is not going to be installed
                                           libinput-tools : Depends: libglib2.0-0t64 (>= 2.30.0) but it is not going to be installed
                                                            Depends: libgtk-3-0t64 (>= 3.19.12) but it is not going to be installed
                                           libinput10 : Depends: libmtdev1t64 (>= 1.1.0) but it is not going to be installed
                                           libjavascriptcoregtk-4.1-0 : Depends: libglib2.0-0t64 (>= 2.66.0) but it is not going to be installed
                                           libkeybinder-3.0-0 : Depends: libglib2.0-0t64 (>= 2.12.0) but it is not going to be installed
                                           libmate-desktop-2-17t64 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                           libmenu-cache-bin : Depends: libglib2.0-0t64 (>= 2.76.0) but it is not going to be installed
                                           libmousepad0 : Depends: libglib2.0-0t64 (>= 2.56.0) but it is not going to be installed
                                           libmsgraph-1-1 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                           libnetplan1 : Depends: libglib2.0-0t64 (>= 2.76.0) but it is not going to be installed
                                           libnm0 : Depends: libglib2.0-0t64 (>= 2.44.0) but it is not going to be installed
                                           libnma0 : Depends: libglib2.0-0t64 (>= 2.38.0) but it is not going to be installed
                                           libpango-1.0-0 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                           libpangocairo-1.0-0 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                           libpangoft2-1.0-0 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                           libpangomm-1.4-1v5 : Depends: libglib2.0-0t64 (>= 2.34.0) but it is not going to be installed
                                           libpangoxft-1.0-0 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                           libpeas-1.0-0 : Depends: libglib2.0-0t64 (>= 2.44.0) but it is not going to be installed
                                           libpipewire-0.3-modules : Depends: libglib2.0-0t64 (>= 2.32.0) but it is not going to be installed
                                           libpoppler-glib8t64 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                           libproxy1v5 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                           libqt5ct-common1.8 : Depends: libqt5core5t64 (>= 5.9~) but it is not going to be installed
        Depends: libqt5gui5t64 (>= 5.9~) but it is not going to be installed or
        libqt5gui5-gles (>= 5.9~) but it is not going to be installed
                                           libqt6core6t64 : Depends: libglib2.0-0t64 (>= 2.26.0) but it is not going to be installed
                                           libqt6gui6 : Depends: libglib2.0-0t64 (>= 2.26.0) but it is not going to be installed
                                                        Depends: libmtdev1t64 (>= 1.0.8) but it is not going to be installed
                                                        Recommends: qt6-svg-plugins but it is not going to be installed
                                                        Recommends: qt6-wayland but it is not going to be installed
                                           libqt6network6 : Depends: libglib2.0-0t64 (>= 2.46.0) but it is not going to be installed
                                           libqt6opengl6 : Depends: libmtdev1t64 (>= 1.0.8) but it is not going to be installed
                                           libsane1 : Depends: libglib2.0-0t64 (>= 2.34.0) but it is not going to be installed
                                           libspa-0.2-bluetooth : Depends: libglib2.0-0t64 (>= 2.83.0) but it is not going to be installed
                                           libudev-dev : Depends: libudev1 (= 257.13-1~deb13u1) but 252.39-1~deb12u2 is to be installed
                                           libvolume-key1 : Depends: libglib2.0-0t64 (>= 2.18.0) but it is not going to be installed
                                           libvte-2.91-0 : Depends: libglib2.0-0t64 (>= 2.78.0) but it is not going to be installed
                                           libwacom9 : Depends: libglib2.0-0t64 (>= 2.68.0) but it is not going to be installed
                                           libwebkit2gtk-4.1-0 : Depends: gstreamer1.0-plugins-base but it is not going to be installed
        Depends: gstreamer1.0-plugins-good but it is not going to be installed
        Depends: libgtk-3-0t64 (>= 3.23.0) but it is not going to be installed
        Recommends: gstreamer1.0-libav but it is not going to be installed
        Recommends: gstreamer1.0-plugins-bad but it is not going to be installed
                                           libwnck-3-0 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                           libxfce4ui-2-0 : Depends: libglib2.0-0t64 (>= 2.70.0) but it is not going to be installed
                                           libxfce4util7 : Depends: libglib2.0-0t64 (>= 2.70.0) but it is not going to be installed
                                                           Recommends: libxfce4util-bin but it is not going to be installed
                                           libxfconf-0-3 : Depends: libglib2.0-0t64 (>= 2.56.0) but it is not going to be installed
                                           libxmlb2 : Depends: libglib2.0-0t64 (>= 2.54.0) but it is not going to be installed
                                           lp-connection-editor : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                           mate-polkit : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                                         Depends: libgtk-3-0t64 (>= 3.16.2) but it is not going to be installed
                                           mousepad : Depends: libglib2.0-0t64 (>= 2.38.0) but it is not going to be installed
                                                      Depends: libgtk-3-0t64 (>= 3.13.7) but it is not going to be installed
                                           netplan-generator : Depends: libglib2.0-0t64 (>= 2.70.0) but it is not going to be installed
                                           netplan.io : Depends: libglib2.0-0t64 (>= 2.70.0) but it is not going to be installed
                                                        Recommends: python3-rich but it is not going to be installed
                                           network-manager : Depends: libglib2.0-0t64 (>= 2.68.0) but it is not going to be installed
                                                             Recommends: network-manager-l10n but it is not going to be installed
                                           notification-daemon : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                           obconf : Depends: libglib2.0-0t64 (>= 2.36.0) but it is not going to be installed
                                           openbox-lxde-session : Depends: lxde-common but it is not going to be installed
        Depends: lxsession but it is not going to be installed
                                           openssh-sftp-server : Depends: openssh-client (= 1:9.2p1-2+deb12u10)
                                           pango1.0-tools : Depends: libglib2.0-0t64 (>= 2.80) but it is not going to be installed
                                           pcmanfm : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                                     Recommends: lxde-icon-theme but it is not going to be installed or
        gnome-icon-theme but it is not going to be installed or
        oxygen-icon-theme but it is not going to be installed or
        tango-icon-theme but it is not going to be installed
                                           pi-package : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                           pi-package-session : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                           piclone : Depends: libglib2.0-0t64 (>= 2.32.0) but it is not going to be installed
                                           pipanel : Depends: libglib2.0-0t64 (>= 2.36.0) but it is not going to be installed
                                           pishutdown : Depends: libglib2.0-0t64 (>= 2.26.0) but it is not going to be installed
                                           piwiz : Depends: libglib2.0-0t64 (>= 2.32.0) but it is not going to be installed
                                           pixflat-theme : Depends: gtk2-engines-pixbuf but it is not going to be installed
                                                           Depends: gtk2-engines-pixflat but it is not going to be installed
                                           pplug-ejecter-data : Depends: gtk-update-icon-cache
                                           pplug-power-data : Depends: gtk-update-icon-cache
                                           pplug-updater-data : Depends: gtk-update-icon-cache
                                           python3-dbus : Depends: libglib2.0-0t64 (>= 2.16.0) but it is not going to be installed
                                           python3-gi : Depends: libglib2.0-0t64 (>= 2.78.0) but it is not going to be installed
                                           python3-pyqt5 : Depends: libqt5printsupport5 (>= 5.15)
                                           qt5-gtk-platformtheme : Depends: libglib2.0-0t64 (>= 2.34.0) but it is not going to be installed
        Depends: libqt5core5t64 (>= 5.15.1) but it is not going to be installed
        Depends: libqt5dbus5t64 (>= 5.14.1) but it is not going to be installed
        Depends: libqt5gui5t64 (>= 5.14.1) but it is not going to be installed or
        libqt5gui5-gles (>= 5.14.1) but it is not going to be installed
        Depends: qtbase-abi-5-15-15
                                           qt6-gtk-platformtheme : Depends: gnome-themes-extra-data but it is not going to be installed
                                           raindrop : Depends: libglib2.0-0t64 (>= 2.40.0) but it is not going to be installed
                                                      Depends: lightdm but it is not going to be installed
                                           rasputin : Depends: libglib2.0-0t64 (>= 2.26.0) but it is not going to be installed
                                           rc-gui : Depends: libglib2.0-0t64 (>= 2.32.0) but it is not going to be installed
                                           rp-bookshelf : Depends: libglib2.0-0t64 (>= 2.36.0) but it is not going to be installed
                                           rp-prefapps : Depends: libglib2.0-0t64 (>= 2.26.0) but it is not going to be installed
                                           rpi-chromium-mods : Depends: chromium (>= 92) but it is not going to be installed
                                           sudopwd : Depends: libglib2.0-0t64 (>= 2.32.0) but it is not going to be installed
                                           vdpau-driver-all : Depends: mesa-vdpau-drivers but it is not going to be installed
                                           wayfire : Depends: libglib2.0-0t64 (>= 2.12.0) but it is not going to be installed
                                           wf-panel-pi : Depends: libglib2.0-0t64 (>= 2.74.0) but it is not going to be installed
                                                         Recommends: wfplug-clock but it is not going to be installed
                                           wfplug-batt : Depends: libglib2.0-0t64 (>= 2.16.0) but it is not going to be installed
                                           wfplug-bluetooth : Depends: libglib2.0-0t64 (>= 2.30.0) but it is not going to be installed
                                           wfplug-connect : Depends: libglib2.0-0t64 (>= 2.28.0) but it is not going to be installed
                                           wfplug-cpu : Depends: libglib2.0-0t64 (>= 2.12.0) but it is not going to be installed
                                           wfplug-cputemp : Depends: libglib2.0-0t64 (>= 2.12.0) but it is not going to be installed
                                           wfplug-ejecter : Depends: libglib2.0-0t64 (>= 2.28.0) but it is not going to be installed
                                           wfplug-gpu : Depends: libglib2.0-0t64 (>= 2.12.0) but it is not going to be installed
                                           wfplug-menu : Depends: libglib2.0-0t64 (>= 2.36.0) but it is not going to be installed
                                           wfplug-netman : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                           wfplug-power : Depends: libglib2.0-0t64 (>= 2.36.0) but it is not going to be installed
                                           wfplug-squeek : Depends: libglib2.0-0t64 (>= 2.26.0) but it is not going to be installed
                                           wfplug-updater : Depends: libglib2.0-0t64 (>= 2.32.0) but it is not going to be installed
                                           wfplug-volumepulse : Depends: libglib2.0-0t64 (>= 2.30.0) but it is not going to be installed
                                           xarchiver : Depends: libglib2.0-0t64 (>= 2.76.0) but it is not going to be installed
                                                       Recommends: 7zip but it is not going to be installed
                                           xdg-desktop-portal-gtk : Depends: libglib2.0-0t64 (>= 2.83.0) but it is not going to be installed
                                           xfconf : Depends: libglib2.0-0t64 (>= 2.56.0) but it is not going to be installed
                                           xorg : Depends: xserver-xorg (>= 1:7.7+24+deb13u1) but it is not going to be installed
                                                  Depends: xterm or
                                                           x-terminal-emulator
                                           xorgxrdp : Depends: xorg-input-abi-24
                                                      Depends: xorg-video-abi-25
                                                      Depends: xserver-xorg-core (>= 2:21.1.1) but it is not going to be installed
                                           xwayland : Depends: xserver-common but it is not going to be installed
                                           zenity : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                           zenoty : Depends: libglib2.0-0t64 (>= 2.12.0) but it is not going to be installed
                                          E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
                                          Thomas BraunT Offline
                                          #240
                                          @Hadebe
                                          Installier das Ding komplett neu.
                                          Ist eh die Empfehlung von RaspberryOS.
                                          In-line-upgrades sind nicht vorgesehen.
                                          Und lass dann den Desktop-Mumpitz direkt vom System. Installier die Lite-Version von RaspberryOS 13 'Trixie'.
