  4. Admin Interface nicht mehr erreichbar
49 Beiträge 7 Kommentatoren 6.9k Aufrufe 5 Beobachtet
  • H hilei
    @thomas-braun said in Admin Interface nicht mehr erreichbar:
    iob diag
    homematic@linuxserver:/opt/iobroker$ iob diag
    No command 'iob' found, did you mean:
     Command 'iok' from package 'iok' (universe)
     Command 'irb' from package 'ruby' (main)
     Command 'iog' from package 'iog' (universe)
     Command 'bob' from package 'python-sponge' (universe)
    iob: command not found
    @hilei
    iobroker stop
    iobroker fix
    iobroker start
    Und dann nochmal
    iobroker diag
    H 1 Antwort Letzte Antwort
      @hilei
      iobroker stop
      iobroker fix
      iobroker start
      Und dann nochmal
      iobroker diag
      hilei
        iobroker stop        iobroker fix        iobroker start
      Last login: Sun Dec 31 14:16:18 2023
      homematic@linuxserver:~$ iobroker stop
      iobroker controller daemon is not running
      homematic@linuxserver:~$ iobroker fix
      iobroker fix
      Execute the installation fixer script, this updates your ioBroker installation
      Options:
        --help  Show help  [boolean]
      homematic@linuxserver:~$ iobroker start
      Starting iobroker controller daemon...
      iobroker controller daemon started. PID: 9299
      homematic@linuxserver:~$ iobroker diag
      iobroker [command]
      Commands:
        iobroker setup                                               Setup ioBroker
        iobroker start [all|<adapter>.<instance>]                    Starts the js-controller or a specified adapter instance
        iobroker stop [<adapter>.<instance>]                         stops the js-controller or a specified adapter instance
        iobroker restart [<adapter>.<instance>]                      Restarts js-controller or a specified adapter instance  [aliases: r]
        iobroker debug <adapter>[.<instance>]                        Starts a Node.js debugging session for the adapter instance
        iobroker info                                                Shows the host info
        iobroker logs [<adapter>]                                    Monitor log
        iobroker add <adapter> [desiredNumber]                       Add instance of adapter  [aliases: a]
        iobroker install <adapter>                                   Installs a specified adapter  [aliases: i]
        iobroker rebuild [<module>]                                  Rebuild all native modules or path
        iobroker url <url> [<name>]                                  Install adapter from specified url, e.g. GitHub
        iobroker del <adapter>                                       Remove adapter and all instances from this host  [aliases: delete]
        iobroker del <adapter>.<instance>                            Remove adapter instance  [aliases: delete]
        iobroker update [<repositoryUrl>]                            Update repository and list adapters
        iobroker upgrade                                             Upgrade management
        iobroker upload [all|<adapter>]                              Upload management  [aliases: u]
        iobroker object                                              Object management  [aliases: o]
        iobroker state                                               State management  [aliases: s]
        iobroker message <adapter>[.instance] <command> [<message>]  Send message to adapter instance/s
        iobroker list <type> [<filter>]                              List all entries, like objects
        iobroker chmod <mode> <file>                                 Change file rights
        iobroker chown <user> <group> <file>                         Change file ownership
        iobroker touch <file>                                        Touch file
        iobroker rm <file>                                           Remove file
        iobroker file                                                File management
        iobroker user                                                User commands
        iobroker group                                               group management
        iobroker host <hostname>                                     Set host to given hostname
        iobroker set <adapter>.<instance>                            Change settings of adapter config
        iobroker license <license.file or license.text>              Update license by given file
        iobroker cert                                                Certificate management
        iobroker clean <yes>                                         Clears all objects and states
        iobroker backup                                              Create backup
        iobroker restore <backup name or path>                       Restore a specified backup
        iobroker validate <backup name or path>                      Validate a specified backup
        iobroker status [all|<adapter>.<instance>]                   Status of ioBroker or adapter instance  [aliases: isrun]
        iobroker repo [<name>]                                       Show repo information
        iobroker uuid                                                Show uuid of the installation  [aliases: id]
        iobroker unsetup                                             Reset license, installation secret and language
        iobroker fix                                                 Execute the installation fixer script, this updates your ioBroker installation
        iobroker multihost                                           Multihost management
        iobroker compact                                             compact group management
        iobroker plugin                                              Plugin management
        iobroker version [<adapter>]                                 Show version of js-controller or specified adapter  [aliases: v]
      Options:
      • H hilei
        iobroker fix
        Options:
        iobroker [command]
        Commands:
        Options:
        @hilei
        Was ist das für ein komisches System da bei dir?
        • H Offline
          hilei
          rennt schon eine weile ohne dass ich mich viel darum gekümmert habe - never change a running system ;-)
          jetzt rennt scheinbar nimmer :-(
          • H hilei
            @hilei sagte in Admin Interface nicht mehr erreichbar:
            Das ist eigentlich das Zeichen mich dann auch nicht mehr weiter um dein System zu kümmern. Wenn du es schon selber nicht tust, warum sollten sich andere um den versumpften Krampf scheren?
              @hilei
              @thomas-braun sagte in Admin Interface nicht mehr erreichbar:
              @hilei
              habe ioBroker in einer VM mit VMWareplayer laufen. Habe den VMWareplayer gestern von Version 15 auf Version 17 upgegraded. Host System ist Windows 10.
              kommt vom nävva tatschen.
              • H hilei
                @hilei
                curl -sLf -o diag.sh https://iobroker.net/diag.sh && bash diag.sh
                funktioniert wenigstens?
                  hilei
                  danke für deine hilfe aber kein grund so zu reagieren. hat bis dato super funktioniert und wenn ich updates für irgendwas gebraucht habe, habe das auch gemacht. aber ich habe einfach nicht die zeit mich laufend mit diesen dingen zu beschäftigen und updates zu machen wenns nicht unbedingt nötig ist die dann vielleicht zu problemen führen können und ich wieder stunden damit verbringe das wieder hinzubekommen - wäre nicht das erste mal.
                  und ausser runterfahren vmwareplayer update habe ich nichts gemacht - da rechne ich nicht unbedingt damit dass nacher zwar der iobroker noch rennt aber nicht mehr aufs admin interface komme.
                  ich werde das backup dass ich vor der umstellung gemacht habe einfach auf einem anderen windows pc mit vmwareplayer 15 nochmal probieren...
                  Samson71S HomoranH 2 Antworten Letzte Antwort
                    @hilei
                    hilei
                    homematic@linuxserver:~$ curl -sLf -o diag.sh https://iobroker.net/diag.sh && bash diag.sh
                    Thomas BraunT H 2 Antworten Letzte Antwort
                    • H hilei
                      @hilei
                      Dann mach es halt neu.
                      Und halt das Zeuch auf einem aktuellen Stand.
                      'Never tatsch irgendwas' ist ganz schlecht. Die Entwicklung geht dafür zu schnell weiter.
                      • H hilei
                        hilei
                        @hilei
                        was ich komisch finde ist dass er die Meldung
                        ERR_CONNECTION_REFUSED
                        bringt. sprich erreichbar dürfte sie ja sein? vielleicht irgendein windows security setting. na mal schauen...
                          @hilei
                          hilei
                          ohne admin kann ich ja nicht mal ein backup ziehen und einspielen oder?
                          • H hilei
                            @hilei
                            In einem gesunden System über die Kommandozeile.
                              @hilei
                              hilei
                              danke vorerst - dass muss jetzt mal auf nächstes Jahr warten ;-)
                              bildschirmzeit für heute ausgeschöpft laut chefin und kindern ;-)
                              werde berichten...
                              • H hilei
                                Samson71S Offline
                                Samson71S Offline
                                Samson71
                                Auch wenn es gemein klingt: Doch ist es!
                                Du bist beibliebe nicht der erste der mit "never touch und so weiter" so richtig auf die Schn..... fällt. Und wenn dann einer wie @Thomas-Braun zum drölfzichsten Mal dasselbe dazu predigen muss, dann ist irgendwann vermutlich mal eine persönliche Grenze erreicht. Und helfen tut er trotzdem, auch wenn er sich die Haare rauft.
                                Dazu könnte ich auch etwas schreiben, dass dann genauso gemein klingt wie die Einleitung, daher verkneife ich mir das besser. Dass das der falsche Weg ist, solltest Du jetzt ja begriffen haben.
                                Markus
                                Bitte beachten:
                                J 1 Antwort Letzte Antwort
                                • Samson71S Samson71
                                  Jan1
                                  @samson71
                                  Das ist doch recht einfach, wer keine Zeit hat regelmäßig mal ein Update zu machen, der opfert ein mehrfaches an Zeit um dann die Probleme, die ausgelassene Updates verursachen, zu bekämpfen ;)
                                  • H hilei
                                    crunchipC Abwesend
                                    crunchipC Abwesend
                                    testweise mal nen 2ten admin installieren und schauen ob dieser läuft/iobroker damit erreichbar ist
                                    iobroker add admin --enabled --port 8089
                                    • H hilei
                                      wie?
                                      und beim curl-Befehl kommt wirklich keine Reaktion?
                                      ist das überhaupt ein vollständiges Linux?
                                      oder hat sich das ggf. durch zu spätes updaten zerlegt, weil due Repos nicht mehr erreichbar waren?
                                      • J Jan1
                                        @samson71
                                        Samson71S Offline
                                        Samson71S Offline
                                        Samson71
                                        @jan1 sagte in Admin Interface nicht mehr erreichbar:
                                        Damit könnte ich noch gut leben, aber das Zeitopfer müssen dann immer die Helfer (sinnlos) zusätzlich erbringen. Das ist das eigentliche Ärgernis dabei. Was der Verursacher dafür an Mehraufwand hat ist mir offen gestanden egal.
                                        Markus
                                        Bitte beachten:
                                          Mich triggert immer dieses saudämliche 'never touch a running system'.
                                          Wenn die Software wie vorgesehen funktionieren würde, dann gäbe es auch keine Updates dafür. Aber alleine die Tatsache, das jemand, der den Code viel besser kennt als der User, erkannt hat, dass da was geändert werden muss, spricht dafür das man da auch als User was 'tatschen' muss.
                                          'Never tatsch a running system' wird immer dann ins Feld geführt, wenn die komplette Blauäugig- und Ahnungslosigkeit was sein verwendetes System angeht möglichst eindrucksvoll kaschiert werden soll.
