  4. Admin Interface nicht mehr erreichbar
49 Beiträge 7 Kommentatoren 6.9k Aufrufe 5 Beobachtet
    @hilei
    iobroker stop
    iobroker fix
    iobroker start
    Und dann nochmal
    iobroker diag
    hilei
    @thomas-braun said in Admin Interface nicht mehr erreichbar:
        iobroker stop        iobroker fix        iobroker start
    Last login: Sun Dec 31 14:16:18 2023
    homematic@linuxserver:~$ iobroker stop
    iobroker controller daemon is not running
    homematic@linuxserver:~$ iobroker fix
    iobroker fix
    Execute the installation fixer script, this updates your ioBroker installation
    Options:
      --help  Show help  [boolean]
    homematic@linuxserver:~$ iobroker start
    Starting iobroker controller daemon...
    iobroker controller daemon started. PID: 9299
    homematic@linuxserver:~$ iobroker diag
    iobroker [command]
    Commands:
      iobroker setup                                               Setup ioBroker
      iobroker start [all|<adapter>.<instance>]                    Starts the js-controller or a specified adapter instance
      iobroker stop [<adapter>.<instance>]                         stops the js-controller or a specified adapter instance
      iobroker restart [<adapter>.<instance>]                      Restarts js-controller or a specified adapter instance  [aliases: r]
      iobroker debug <adapter>[.<instance>]                        Starts a Node.js debugging session for the adapter instance
      iobroker info                                                Shows the host info
      iobroker logs [<adapter>]                                    Monitor log
      iobroker add <adapter> [desiredNumber]                       Add instance of adapter  [aliases: a]
      iobroker install <adapter>                                   Installs a specified adapter  [aliases: i]
      iobroker rebuild [<module>]                                  Rebuild all native modules or path
      iobroker url <url> [<name>]                                  Install adapter from specified url, e.g. GitHub
      iobroker del <adapter>                                       Remove adapter and all instances from this host  [aliases: delete]
      iobroker del <adapter>.<instance>                            Remove adapter instance  [aliases: delete]
      iobroker update [<repositoryUrl>]                            Update repository and list adapters
      iobroker upgrade                                             Upgrade management
      iobroker upload [all|<adapter>]                              Upload management  [aliases: u]
      iobroker object                                              Object management  [aliases: o]
      iobroker state                                               State management  [aliases: s]
      iobroker message <adapter>[.instance] <command> [<message>]  Send message to adapter instance/s
      iobroker list <type> [<filter>]                              List all entries, like objects
      iobroker chmod <mode> <file>                                 Change file rights
      iobroker chown <user> <group> <file>                         Change file ownership
      iobroker touch <file>                                        Touch file
      iobroker rm <file>                                           Remove file
      iobroker file                                                File management
      iobroker user                                                User commands
      iobroker group                                               group management
      iobroker host <hostname>                                     Set host to given hostname
      iobroker set <adapter>.<instance>                            Change settings of adapter config
      iobroker license <license.file or license.text>              Update license by given file
      iobroker cert                                                Certificate management
      iobroker clean <yes>                                         Clears all objects and states
      iobroker backup                                              Create backup
      iobroker restore <backup name or path>                       Restore a specified backup
      iobroker validate <backup name or path>                      Validate a specified backup
      iobroker status [all|<adapter>.<instance>]                   Status of ioBroker or adapter instance  [aliases: isrun]
      iobroker repo [<name>]                                       Show repo information
      iobroker uuid                                                Show uuid of the installation  [aliases: id]
      iobroker unsetup                                             Reset license, installation secret and language
      iobroker fix                                                 Execute the installation fixer script, this updates your ioBroker installation
      iobroker multihost                                           Multihost management
      iobroker compact                                             compact group management
      iobroker plugin                                              Plugin management
      iobroker version [<adapter>]                                 Show version of js-controller or specified adapter  [aliases: v]
    Options:
    • H hilei
      iobroker fix
      Options:
      iobroker [command]
      Commands:
      Options:
      @hilei
      Was ist das für ein komisches System da bei dir?
      • H Offline
        hilei
        rennt schon eine weile ohne dass ich mich viel darum gekümmert habe - never change a running system ;-)
        jetzt rennt scheinbar nimmer :-(
        • H hilei
          @hilei sagte in Admin Interface nicht mehr erreichbar:
          Das ist eigentlich das Zeichen mich dann auch nicht mehr weiter um dein System zu kümmern. Wenn du es schon selber nicht tust, warum sollten sich andere um den versumpften Krampf scheren?
          H 1 Antwort Letzte Antwort
            @hilei
            @thomas-braun sagte in Admin Interface nicht mehr erreichbar:
            @hilei
            habe ioBroker in einer VM mit VMWareplayer laufen. Habe den VMWareplayer gestern von Version 15 auf Version 17 upgegraded. Host System ist Windows 10.
            kommt vom nävva tatschen.
            • H hilei
              @hilei
              curl -sLf -o diag.sh https://iobroker.net/diag.sh && bash diag.sh
              funktioniert wenigstens?
                hilei
                danke für deine hilfe aber kein grund so zu reagieren. hat bis dato super funktioniert und wenn ich updates für irgendwas gebraucht habe, habe das auch gemacht. aber ich habe einfach nicht die zeit mich laufend mit diesen dingen zu beschäftigen und updates zu machen wenns nicht unbedingt nötig ist die dann vielleicht zu problemen führen können und ich wieder stunden damit verbringe das wieder hinzubekommen - wäre nicht das erste mal.
                und ausser runterfahren vmwareplayer update habe ich nichts gemacht - da rechne ich nicht unbedingt damit dass nacher zwar der iobroker noch rennt aber nicht mehr aufs admin interface komme.
                ich werde das backup dass ich vor der umstellung gemacht habe einfach auf einem anderen windows pc mit vmwareplayer 15 nochmal probieren...
                Samson71S HomoranH 2 Antworten Letzte Antwort
                  @hilei
                  hilei
                  homematic@linuxserver:~$ curl -sLf -o diag.sh https://iobroker.net/diag.sh && bash diag.sh
                  Thomas BraunT H 2 Antworten Letzte Antwort
                  • H hilei
                    @hilei
                    Dann mach es halt neu.
                    Und halt das Zeuch auf einem aktuellen Stand.
                    'Never tatsch irgendwas' ist ganz schlecht. Die Entwicklung geht dafür zu schnell weiter.
                    • H hilei
                      hilei
                      @hilei
                      was ich komisch finde ist dass er die Meldung
                      ERR_CONNECTION_REFUSED
                      bringt. sprich erreichbar dürfte sie ja sein? vielleicht irgendein windows security setting. na mal schauen...
                        @hilei
                        hilei
                        ohne admin kann ich ja nicht mal ein backup ziehen und einspielen oder?
                        • H hilei
                          @hilei
                          In einem gesunden System über die Kommandozeile.
                            @hilei
                            hilei
                            danke vorerst - dass muss jetzt mal auf nächstes Jahr warten ;-)
                            bildschirmzeit für heute ausgeschöpft laut chefin und kindern ;-)
                            werde berichten...
                            • H hilei
                              Samson71S Offline
                              Samson71S Offline
                              Samson71
                              Auch wenn es gemein klingt: Doch ist es!
                              Du bist beibliebe nicht der erste der mit "never touch und so weiter" so richtig auf die Schn..... fällt. Und wenn dann einer wie @Thomas-Braun zum drölfzichsten Mal dasselbe dazu predigen muss, dann ist irgendwann vermutlich mal eine persönliche Grenze erreicht. Und helfen tut er trotzdem, auch wenn er sich die Haare rauft.
                              Dazu könnte ich auch etwas schreiben, dass dann genauso gemein klingt wie die Einleitung, daher verkneife ich mir das besser. Dass das der falsche Weg ist, solltest Du jetzt ja begriffen haben.
                              Markus
                              Bitte beachten:
                              • Samson71S Samson71
                                Jan1
                                @samson71
                                Das ist doch recht einfach, wer keine Zeit hat regelmäßig mal ein Update zu machen, der opfert ein mehrfaches an Zeit um dann die Probleme, die ausgelassene Updates verursachen, zu bekämpfen ;)
                                • H hilei
                                  crunchipC Abwesend
                                  crunchipC Abwesend
                                  testweise mal nen 2ten admin installieren und schauen ob dieser läuft/iobroker damit erreichbar ist
                                  iobroker add admin --enabled --port 8089
                                  • H hilei
                                    wie?
                                    und beim curl-Befehl kommt wirklich keine Reaktion?
                                    ist das überhaupt ein vollständiges Linux?
                                    oder hat sich das ggf. durch zu spätes updaten zerlegt, weil due Repos nicht mehr erreichbar waren?
                                    • J Jan1
                                      @samson71
                                      Samson71S Offline
                                      Samson71S Offline
                                      Samson71
                                      @jan1 sagte in Admin Interface nicht mehr erreichbar:
                                      Damit könnte ich noch gut leben, aber das Zeitopfer müssen dann immer die Helfer (sinnlos) zusätzlich erbringen. Das ist das eigentliche Ärgernis dabei. Was der Verursacher dafür an Mehraufwand hat ist mir offen gestanden egal.
                                      Markus
                                      Bitte beachten:
                                        Mich triggert immer dieses saudämliche 'never touch a running system'.
                                        Wenn die Software wie vorgesehen funktionieren würde, dann gäbe es auch keine Updates dafür. Aber alleine die Tatsache, das jemand, der den Code viel besser kennt als der User, erkannt hat, dass da was geändert werden muss, spricht dafür das man da auch als User was 'tatschen' muss.
                                        'Never tatsch a running system' wird immer dann ins Feld geführt, wenn die komplette Blauäugig- und Ahnungslosigkeit was sein verwendetes System angeht möglichst eindrucksvoll kaschiert werden soll.
                                          und dann noch in Verbindung mit "hat bisher immer problemlos funktioniert." und in der extended version dann noch "nur durch das Update läuft jetzt nichts mehr"
