  4. Test Adapter Pylontech v0.0.10
    6.0k
226 Beiträge 32 Kommentatoren 55.1k Aufrufe 26 Beobachtet
  • hg6806H hg6806
    @plchome-0
    Hi, ich habe auch einen US3000C und würde den ganz gerne mittels deinem Adapter abfragen wollen.
    Ich habe den Pylontech über die RS232 des RJ45 an einen MAX3232 angeschlossen und die UART direkt an den Pi4.
    Muss ich das jetzt noch wie folgt konfigurieren?
    SOFTWARE USE OF THE SERIAL PORT
    If you intend to use the serial port for a software application running on the Raspberry Pi, there is a bit of configuration required to disable the console from using this port.   By default, the serial port is configured as a console port for interacting with the Linux OS shell.  The following steps will guide you through disabling the port from console access.
    First, lets make of backup of the two files that we intend to modify.
    sudo cp /boot/cmdline.txt /boot/cmdline.bak
    sudo cp /etc/inittab /etc/inittab.bak
    Next, we need to remove the "console=ttyAMA0,115200" and "kgdboc=ttyAMA0,115200" configuration parameters from the "/boot/cmdline.txt" configuration file.
    To edit the file use this command:
    sudo nano /boot/cmdline.txt
    The file probably contains this default configuration line:
    dwc_otg.lpm_enable=0 console=ttyAMA0,115200 kgdboc=ttyAMA0,115200
    console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline rootwait
    After removing the two configuration parameters, it will look similar to this:
    dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4
    The last step is to edit the "/etc/inittab" file and comment out the use of the "ttyAMA0" serial port.  To edit the file use this command:
    sudo nano /etc/inittab
    Now towards the bottom of the file, look for a configuration line that includes the "ttyAMA0" port address.
    Place a pound sign ("#") in front of the line to comment it out.  With a pound sign ("#") at the beginning of the line, Linux will ignore this configuration line.
    Save the "/etc/inittab" file and then issue this command to reboot the Raspberry Pi:
    sudo reboot
    Now you are ready to use the serial port with a software application and the operating system won't interfere with the port.  Use the device address "ttyAMA0" in your application to access this serial port.
    Und gebe ich dann unter lokaler Geräteadresse "ttyAMA0" ein?
    PLCHome 0P Offline
    PLCHome 0P Offline
    PLCHome 0
    #61
    @hg6806 ich kenne es so https://www.abelectronics.co.uk/kb/article/1035/serial-port-setup-in-raspberry-pi-os
    Dann ist der Port /dev/ttyS0
    • hg6806H Offline
      hg6806H Offline
      hg6806
      #62
      Adapter meldet "Error: Error: Input/output error setting custom baud rate of 115200"
      Seltsamerweise sehe ich mit dem Scope weder beim Pylontech noch bei dem Pi irgendetwas tackern auf der UART.
      PLCHome 0P 1 Antwort Letzte Antwort
      • hg6806H hg6806
        PLCHome 0P Offline
        PLCHome 0P Offline
        PLCHome 0
        schrieb am zuletzt editiert von PLCHome 0
        #63
        @hg6806 also der Stack kann die Geschwindigkeit nicht setzen. Kann auch an rechten liegen mach mal einen
        sudo chmod 777 /dev/ttyS0
        Du kannst die Schnittstelle auch von der Console öffnen
        sudo apt install cu
        cu -l /dev/ttyS0 -s 115200
        Oder sudo cu
        Die Schnittstelle bitte noch gegen deine tauschen..
        hg6806H 1 Antwort Letzte Antwort
        • PLCHome 0P PLCHome 0
          sudo apt install cu
          Oder sudo cu
          hg6806H Offline
          hg6806H Offline
          hg6806
          #64
          @plchome-0
          Rechte gesetzt, Fehler ist noch da.
          Ich dachte /dev/ttyS0 wäre meine Schnittstelle?
          • hg6806H hg6806
            @plchome-0
            PLCHome 0P Offline
            PLCHome 0P Offline
            PLCHome 0
            #65
            @hg6806 hi, da ich aktuell keinen Pi im Einsatz habe kann ich nur Ratschläge geben. Gehe eine Anleitung für dein Pi Modell und die Linux Version durch um die Schnittstelle einzurichten.
            Am besten testen kannst du die Kommunikation mit einen Terminalprogramm wie cu. Du brückst rx und tx (gpio 14 und gpio 15) wenn du das siehst was du schreibst funktioniert der Port. Danach schließt du den Max an und Brückst dort rx und tx. Solltest du da auch das sehen was du schreibst kannst du den Akku anschließen. Im CU kann man dann Enter drücken und sieht die Konsole. Bingo dann den Adaper einrichten.
              hg6806H Offline
              hg6806H Offline
              hg6806
              #66
              @plchome-0
              Hi, hatte noch ein paar andere Baustellen.
              Also über die UART habe ich es leider nicht hinbekommen. Da ist irgendwas im Argen, CU hatte direkt ein HangUp gemeldet.
              Aber egal, ich habe es über einen USB-RS232 Adapter hinbekommen und direkt alle Daten von beiden Speichern bekommen.
              Danke dafür, coole Sache!
              Sag mal, wie hast du die Visualisierung im 1. Post gemacht. Kannst du das evtl. zur Verfügung stellen?
              kletternautK PLCHome 0P 2 Antworten Letzte Antwort
              • hg6806H hg6806
                @plchome-0
                kletternautK Offline
                kletternaut
                #67
                @hg6806 sagte in Test Adapter Pylontech v0.0.7:
                @plchome-0
                Ja, das fände ich auch ganz prima! :)
                • hg6806H hg6806
                  @plchome-0
                  PLCHome 0P Offline
                  PLCHome 0P Offline
                  PLCHome 0
                  #68
                  @kletternaut
                  Ich habe grafana und den ioB mit einer MySql laufen, weil sich influx immer bei einer Million Datenpunkten auf meinem alten PI aufgehängt hat. Der Fehler ist wohl weg, ich habs aber nie mehr geändert.
                  Unter mysql hab ich für alle Datentypen je eine View, in grafana brauch ich dann nur die Datenpunkte in das Diagramm einzufügen.
                  • L l1berty
                    Hi, Der Adapter läuft sauber bei mir.
                    Initial mit nem ESP32 der die Daten auf einem Port über Wifi zur Verfügung gestellt hat.
                    Nun mit Waveshare RS232/485/422 TO POE ETH (B).
                    Hersteller Link
                    POE powered mit Hutschienenmontage sieht das ganze schon ganz nett aus !
                    (Das Webinterface von dem Ding ist eine Katastrophe, mit der Software vom Hersteller lässt es sich aber gut parametrieren, bei Switches die kein 10 Mbit mehr unterstützen kann es Probleme geben).
                    Viele Grüße
                    BananaJoeB Online
                    BananaJoeB Online
                    BananaJoe
                    #69
                    @l1berty sagte in Test Adapter Pylontech v0.0.7:
                    Hersteller Link
                    Viele Grüße
                    Moin,
                    könntest du mal deine genauen Einstellungen des Waveshare und im Adapter posten?
                    • JLegJ Offline
                      JLegJ Offline
                      JLeg
                      #70
                      Nur als kleine Info - der billo RS232-nach-WLAN-Adapter EW10A funktioniert einwandfrei mit diesem Adapter und den Pylons, ohne besondere Konfiguration (ausser WLAN-Daten natürlich).
                      (ich habe die Variante EW10A-0 genommen mit externer Antenne - unter diesem Suchbegriff findet sich das Ding bei Ebay und Ali).
                      • JLegJ JLeg
                        PLCHome 0P Offline
                        PLCHome 0P Offline
                        PLCHome 0
                        #71
                        @jleg sagte in Test Adapter Pylontech v0.0.7:
                        billo
                        Finde ich nicht, nur Elfin?
                        JLegJ 1 Antwort Letzte Antwort
                          billo
                          JLegJ Offline
                          JLegJ Offline
                          JLeg
                          schrieb am zuletzt editiert von JLeg
                          #72
                          @plchome-0 Jo, so heisst der Hersteller - und das Modul eben EW10A...
                          z.B. https://www.ebay.de/itm/256178207417?var=556155538447
                          (ah, falls du "billo" meintest - schlampiger Slang für "billig" ;-)
                          • JLegJ JLeg
                            PLCHome 0P Offline
                            PLCHome 0P Offline
                            PLCHome 0
                            #73
                            @jleg und was ist dann "billo" wenn Elfin der hersteller ist?
                            • JLegJ JLeg
                              PLCHome 0P Offline
                              PLCHome 0P Offline
                              PLCHome 0
                              #74
                              jetzt ja :-)
                              Dauert manchmal was ...
                                jetzt ja :-)
                                JLegJ Offline
                                JLegJ Offline
                                JLeg
                                #75
                                @plchome-0 ...verdorben durch übermässigem Umgang mit 14jährigen ;-)
                                • JLegJ JLeg
                                  PLCHome 0P Offline
                                  PLCHome 0P Offline
                                  PLCHome 0
                                  #76
                                  @jleg Kenne ich eigentlich musste letztens auch googlen was Flexen bedeutet...
                                    JLegJ Offline
                                    JLegJ Offline
                                    JLeg
                                    #77
                                    @plchome-0 ...bin zufällig gerade am Basteln mit dem Ding - per Default sind wohl 3 Verbindungen gleichzeitig möglich. Kann also in der "Telnet-Konsole" sehen, was der Adapter so macht, und gleichzeitig mit Multisibcontrol oder Batteryview von meinem Win-Rechner aus rumspielen.
                                    Aber die eigentliche Arbeit wäre jetzt, die Adapter-Datenpunkte in meiner Vis unterzubringen...
                                    • JLegJ JLeg
                                      PLCHome 0P Offline
                                      PLCHome 0P Offline
                                      PLCHome 0
                                      #78
                                      Ja benutze ich leider nicht... Benutze den IOB nur als Drehscheibe.
                                      Aber was anderes, welche Pylons hast du dran?
                                      • JLegJ JLeg
                                        PLCHome 0P Offline
                                        PLCHome 0P Offline
                                        PLCHome 0
                                        #79
                                          JLegJ Offline
                                          JLegJ Offline
                                          JLeg
                                          #80
                                          @plchome-0 sagte in Test Adapter Pylontech v0.0.7:
                                          benutze auch nicht VIS, sondern Iqontrol; "Drehscheibe" bedeutet reiner Datensammler, und per Influx nach Grafana oder sowas?
                                          6 x US5000 (Firmware 1.3)
