  4. Test Adapter telegram-menu v.1.6.x
1.9k Beiträge 65 Kommentatoren 986.9k Aufrufe 63 Beobachtet
  • Michael RolingM Michael Roling
    @liv-in-sky so funktioniert wieder
    liv-in-skyL Offline
    liv-in-skyL Offline
    liv-in-sky
    #601
    @michael-roling
    leider nein - jetzt kommt das:
    telegram-menu.0
    	2023-10-14 22:21:00.579	debug	SubmenuData3[]
    telegram-menu.0
    	2023-10-14 22:21:00.579	debug	Submenu data [null,null,null,[]]
    telegram-menu.0
    	2023-10-14 22:21:00.579	error	Error Switch{}
    telegram-menu.0
    	2023-10-14 22:21:00.578	debug	{"device2Switch":"","data":{"an":{"nav":[["Lüfter5","outSide","getStandort"],["TestDP"],["IN","OUT"],["Clear","CompAus","➡ Grüner"]],"text":"Startseite aktualisiert ...."},"➡ Grüner":{"nav":[["MelPic","MelSet"],["SonderBeginn","SonderEnde","SonderPic"],["MelBild","PostGPS"],["BACK ↩"]],"text":"Wähle eine Aktion"},"BACK ↩":{"nav":[["menu:back"]],"text":"Wähle eine Aktion"},"outSide":{"nav":[["menu:number0-6-1- :Aussen:"]],"text":"Wähle eine Aktion"},"Lüfter5":{"switch":[{"id":"0_userdata.0.CONTROL-OWN.Luefter5","value":"!","toggle":true,"confirm":"true","returnText":"Lüfter ist jetzt: && ack:true"}]},"TestDP":{"switch":[{"id":"0_userdata.0.CONTROL-OWN.Luefter5","value":true,"toggle":true,"confirm":"true","returnText":"{\"id\":\"0_userdata.0.CONTROL-OWN.AAATEST.TestString4\",\"text\":\"wert ist &&\"}"}]},"IN":{"switch":[{"id":"0_userdata.0.CONTROL-OWN.AAATEST.telegramInnen","value":"!","toggle":true,"confirm":"true","returnText":"ack:true"}]},"OUT":{"switch":[{"id":"0_userdata.0.CONTROL-OWN.AAATEST.telegramAUSSEN","value":"!","toggle":true,"confirm":"true","returnText":"ack:true"}]},"MelBild":{"switch":[{"id":"0_userdata.0.CONTROL-OWN.TRACCAR.sendTelegramMelikeGesamtBild","value":"-","toggle":true,"confirm":"true","returnText":"-"}]},"Clear":{"switch":[{"id":"0_userdata.0.CONTROL-OWN.TelegramDelete3Chat","value":"-","toggle":true,"confirm":"true","returnText":"lösche Verlauf"}]},"CompAus":{"switch":[{"id":"0_userdata.0.CONTROL-OWN.fx6300","value":false,"toggle":true,"confirm":"true","returnText":"Computer wird abgeschalten! Value: &&"}]},"SonderBeginn":{"switch":[{"id":"0_userdata.0.CONTROL-OWN.TRACCAR.SONDERFAHRT.SonderfahrtBeginn","value":true,"toggle":false,"confirm":"true","returnText":"Name und Kilometer (mit Komma){\"id\":\"0_userdata.0.CONTROL-OWN.TRACCAR.SONDERFAHRT.BeginnKM\",\"text\":\"Kilometer Start ist &&\"}"}]},"SonderEnde":{"switch":[{"id":"0_userdata.0.CONTROL-OWN.TRACCAR.SONDERFAHRT.SonderfahrtEnde","value":true,"toggle":false,"confirm":"true","returnText":"{\"id\":\"0_userdata.0.CONTROL-OWN.TRACCAR.SONDERFAHRT.EndeKM\",\"text\":\"Kilometer Ende ist &&\"}"}]},"MelSet":{"switch":[{"id":"0_userdata.0.CONTROL-OWN.TRACCAR.MelikeSchreiben","value":"-","toggle":true,"confirm":"true","returnText":"Wert ist &&"}]},"PostGPS":{"switch":[{"id":"0_userdata.0.CONTROL-OWN.TRACCAR.postGPSData","value":true,"toggle":false,"confirm":"true","returnText":"{\"id\":\"0_userdata.0.CONTROL-OWN.TRACCAR.postGPSResult\",\"text\":\"GPS Post ist:\\n&&\"}"}]},"Aussen":{"switch":[{"id":"0_userdata.0.CONTROL-OWN.MOTION.Standort","value":"!","toggle":false,"confirm":"true","returnText":"Standort: && ack:true"}]},"getStandort":{"getData":[{"id":"0_userdata.0.CONTROL-OWN.MOTION.Standort","text":"Standort ist momentan: &&","newline":"true"}]},"MelPic":{"sendPic":[{"id":"-","delay":"5000","fileName":"/opt/iobroker/iobrokerMelike.png"}]},"SonderPic":{"sendPic":[{"id":"-","delay":"5000","fileName":"/opt/iobroker/iobrokerSonder.png"}]}},"user":"liv-in-sky","value":6}
      @liv-in-sky dann erscheint ja nur die neu installierte version. 🙈🙈 lade den code von github und dann schaue noch mal in die browser console
      liv-in-skyL Offline
      liv-in-skyL Offline
      liv-in-sky
      #602
      @michael-roling
      EDIT - FALSCHMELDUNG
      jetzt funktioniert auch der rückgbewert mit einer anderen id nicht mehr
      • liv-in-skyL Offline
        liv-in-skyL Offline
        liv-in-sky
        #603
        @michael-roling
        vergiss den post mit dem rückgabewert - jetzt funktioniert es wieder - keine ahnung was eben los war
        Michael RolingM 1 Antwort Letzte Antwort
        • liv-in-skyL liv-in-sky
          @michael-roling
          Michael RolingM Offline
          Michael Roling
          #604
          @liv-in-sky also funktioniert alles wieder?
            liv-in-skyL Offline
            liv-in-skyL Offline
            liv-in-sky
            #605
            @michael-roling
            guten morgen
            nein - das inline keyboard nicht
            https://forum.iobroker.net/post/1060702
              @michael-roling
              guten morgen
              Michael Roling
              #606
              @liv-in-sky ein neuer Test steht bereit
                liv-in-skyL Offline
                liv-in-skyL Offline
                liv-in-sky
                #607
                @michael-roling
                vielen dank - jetzt flutscht das wieder mit dem inline-keyboard :-)
                ps
                die funktion mit dem rückgabewert eines anderen dp-tes ist echt gold wert !!!
                  @michael-roling
                  ps
                  Michael Roling
                  #608
                  @liv-in-sky freut mich wenn es dir gefällt
                  • Michael RolingM Offline
                    Michael Roling
                    schrieb am zuletzt editiert von Michael Roling
                    #609
                    Neues Feature:
                    Wenn man beim öffnen den Status einer bestimmenten ID bekommen möchte kann man diese Config im Textfeld nutzen, egal ob in einer normalen Navigation oder in einen Submenu! Der Text kann frei gewählt werden, und die Position des {status:...} ebenso, dieses wird dann einfach durch den Wert ersetzt.
                    Das Ergebnis sieht dann so aus!
                    Als nächstes wäre der Gedanke die ID selbst in einen Untermenu einzutragen, und in dem Textfeld durch einen eindeutigen Platzhalter zu ersetzen. Vorteil wäre dann, das ich mehrere IDs für die selbe Abfrage in die Unterliste eintragen könnte.
                    Nächstes angedachtes Feature wäre, das ich ein kleines Icon in Zelle habe in der ich FeatureTexte eintragen kann, wenn ich dort drauf klicke hätte ich eine Auswahlliste mit einem add button, damit ich die Texte direkt hinzufügen kann und sie nicht irgendwo suchen muss. Evtl. eine kleine Beschreibung integriert. Denn es wird immer komplexer.
                    Ich würde mich über Eure Gedanken dazu freuen
                      Neues Feature:
                      liv-in-skyL Offline
                      liv-in-skyL Offline
                      liv-in-sky
                      #610
                      @michael-roling
                      weitere frage:
                      wäre es möglich, im textfeld auch wieder ein script zu starten - so wie bei setState-funktion
                      beispiel:
                      ich rufe heizung auf und habe dann 4 zur auswahl - zusätzlich ist das menu übersichtheizung - den muss ich aufrufen, um den zustand zu sehen
                      schöner wäre, ich klicke auf heizung und die übersicht würde auch erscheinen (die übersicht wird über ein script erstellt, welches über einen boolean getriggert wird
                      hoffe, du verstehst, was ich meine - bei klick auf heizung soll die übersicht kommen und das menu geöffnet werden
                        @michael-roling
                        weitere frage:
                        beispiel:
                        Michael Roling
                        #611
                        @liv-in-sky was passiert denn wenn du auf übersichtheizung drückst, wenn ich das richtig verstehe setzt du einen boolean auf true und dann schickt dir ein script ein Json ?
                        Kannst du denn nicht einfach das Json in der zu schickenden form in einen datenpunkt ablegen und dann mit meinem neuen feature die daten abrufen? oder wird es dann nicht richtig dargestellt?
                          liv-in-skyL Offline
                          liv-in-skyL Offline
                          liv-in-sky
                          #612
                          @michael-roling nee das script wird getriggert und schickt mir ein inline-keyboard - das mache ich nur, damit ich eine "schöne" übersicht bekomme - das inline-k. hat im moment keine callback funktion und soll als tabelle dienen
                          das schickst das script direkt an den telegram bot
                          kann ich ein json in einen dp schreiben, welches diese "inline-tabelle" so anzeigt ?
                          das script sieht so aus:
                          valueArray=['fritzdect.0.DECT_119590311304.tsoll','zigbee2mqtt.0.0x540f57fffef3faff.current_heating_setpoint','fritzdect.0.DECT_119610737080.tsoll','fritzdect.0.DECT_119590404152.tsoll',]
                          roomArray=["Küche","Flur","Bad","Room"]
                          let telegramInstanz="3"
                          let testArr=[]
                          let testArrInner=[]
                          let ArrSend=[];
                          testArr.push({
                                               "text":"RAUM ",
                                               "callback_data": 'HeizungTelegramtest'},
                                               "text":"🌡 TEMP",
                                               "callback_data": 'HeizungTelegramtest'});
                                               log(testArr)
                          ArrSend.push(testArr)   ;
                          testArr=[];
                          for (let i =0;i<valueArray.length;i++){
        testArr.push({
        "text":String(roomArray[i]),
        "callback_data": 'HeizungTelegramtest'+i},
        "text":String(getState(valueArray[i]).val),
        "callback_data": 'HeizungTelegramtest'+i},);
                                             ArrSend.push(testArr)     ;testArr=[]            }
                                log(JSON.stringify(ArrSend))
                           sendTo('telegram.'+telegramInstanz, {
                                                   text: "Heizungszustände", //"\u{26f8} ALARM  von Eislaufhalle \u{26f8}" ,
                                                   parse_mode:"Markdown",
                                                   reply_markup: {
        inline_keyboard: ArrSend,
        resize_keyboard:      false,
        one_time_keyboard:    true,
        disable_notification: false,
        remove_Keyboard:      true
                            let testArr=[]
                            let testArrInner=[]
                            let ArrSend=[];
                            testArr.push({
                                                 "text":"RAUM ",
                                                 "text":"🌡 TEMP",
                                                 log(testArr)
                            testArr=[];
        testArr.push({
                                                     reply_markup: {
                            Michael Roling
                            #613
                            @liv-in-sky also soll einfach beim öffnen der Menüs ein Datenpunkt auf true gesetzt werden? damit dein Script aktiviert wird?
                              liv-in-skyL Offline
                              liv-in-skyL Offline
                              liv-in-sky
                              #614
                              @michael-roling sagte in Test Adapter telegram-menu v.0.6.x:
                              das geht nicht - es fehlen ja "api commands" um das inline keyboard zu erstellen - das json wird einfach nur als text angezeigt
                              ja genau - für meinen zweck würde das reichen - irgenwie einen unterschied einführen, dass man evtl einfach einen dp sendet oder wie in deinem neuen feature einen status abfrägt
                                Michael Roling
                                #615
                                @liv-in-sky im prinzip würde man dann sagen anstatt {status:..}, dann {set:"id"","val"}, so könnte ich mir das vorstellen
                                  liv-in-skyL Offline
                                  liv-in-skyL Offline
                                  liv-in-sky
                                  #616
                                  @michael-roling ja genau das meine ich
                                  Michael RolingM 3 Antworten Letzte Antwort
                                    Michael Roling
                                    #617
                                    @liv-in-sky das ist machbar, dann muss ich aber echt was machen wegen der übersichtlichkeit! Ich muss selbst schon immer in der Doku nachlesen 🙈
                                      Michael Roling
                                      #618
                                      @liv-in-sky So es ist vollbracht, die neue Funktion ist implementiert, incl. einfachem einfügen in die Input Felder.
                                      Wenn man einen Block mit ID hat einfach den Block einfügen und dann die ID auswählen, die ID wird an die richtige stelle gesetzt, wenn der Block passt, ansonsten wird sie hinten dran gehängt. Dazu muss ich die Info noch mal eben anpassen.
                                      Viel Spaß beim Testen, ich freue mich auf eure, deine Meinung
                                        Michael Roling
                                        #619
                                        @liv-in-sky ich habe den code gerade nochmals hoch geladen, am besten noch mal updaten
                                          liv-in-skyL Offline
                                          liv-in-skyL Offline
                                          liv-in-sky
                                          #620
                                          @michael-roling
                                          das gefällt mir sehr gut - danke dir
                                          die neue "hilfe" funktion ist auch cool - sehr gute idee der umsetzung :-)
                                          jetzt kommt die übersicht sofort beim anklicken des menu's
