  3. Off Topic
  4. Proxmox
  5. [Erledigt]proxmox-Datensicherung Fehlermeldung ?
    1.0k
    3.2k
Geplant Angeheftet Gesperrt Verschoben Proxmox
62 Beiträge 4 Kommentatoren 10.0k Aufrufe 4 Beobachtet
  • G GOETSCHHOFER
    @meister-mopper
    sorry, jetzt ist mir klar, was du mit Hinweis auf die Skriptsammlung bezüglich clean Kernel gemeint hast.
    Diese Link-Sammlung finde ich echt super !!!👍
    GOETSCHHOFER
    schrieb am zuletzt editiert von GOETSCHHOFER
    @crunchip
    • G GOETSCHHOFER
      @crunchip
      Bei proxmox in der shell hat er jetzt folgende Meldung gebracht.
      Last login: Fri May  6 16:21:51 CEST 2022 on pts/2
      Linux NUC 5.4.143-1-pve #1 SMP PVE 5.4.143-1 (Tue, 28 Sep 2021 09:10:37 +0200) x86_64
      The programs included with the Debian GNU/Linux system are free software;
      the exact distribution terms for each program are described in the
      individual files in /usr/share/doc/*/copyright.
      Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
      permitted by applicable law.
      root@NUC:~# apt autoremove
      Reading package lists... Done
      Building dependency tree
      The following packages will be REMOVED:
        pve-kernel-5.4.114-1-pve
      0 upgraded, 0 newly installed, 1 to remove and 66 not upgraded.
      After this operation, 289 MB disk space will be freed.
      Do you want to continue? [Y/n] y
      (Reading database ... 64823 files and directories currently installed.)
      Removing pve-kernel-5.4.114-1-pve (5.4.114-1) ...
      Examining /etc/kernel/postrm.d.
      run-parts: executing /etc/kernel/postrm.d/initramfs-tools 5.4.114-1-pve /boot/vmlinuz-5.4.114-1-pve
      update-initramfs: Deleting /boot/initrd.img-5.4.114-1-pve
      run-parts: executing /etc/kernel/postrm.d/proxmox-auto-removal 5.4.114-1-pve /boot/vmlinuz-5.4.114-1-pve
      run-parts: executing /etc/kernel/postrm.d/zz-proxmox-boot 5.4.114-1-pve /boot/vmlinuz-5.4.114-1-pve
      Re-executing '/etc/kernel/postrm.d/zz-proxmox-boot' in new private mount namespace..
      No /etc/kernel/proxmox-boot-uuids found, skipping ESP sync.
      run-parts: executing /etc/kernel/postrm.d/zz-update-grub 5.4.114-1-pve /boot/vmlinuz-5.4.114-1-pve
      Generating grub configuration file ...
      Found linux image: /boot/vmlinuz-5.4.143-1-pve
      Found initrd image: /boot/initrd.img-5.4.143-1-pve
      Found linux image: /boot/vmlinuz-5.4.124-1-pve
      Found initrd image: /boot/initrd.img-5.4.124-1-pve
      Found linux image: /boot/vmlinuz-5.4.106-1-pve
      Found initrd image: /boot/initrd.img-5.4.106-1-pve
      Found memtest86+ image: /boot/memtest86+.bin
      Found memtest86+ multiboot image: /boot/memtest86+_multiboot.bin
      Adding boot menu entry for EFI firmware configuration
      done
      root@NUC:~#
      Bei autoremove bei meiner VM-iobroker bekomme ich eine Fehlermeldung ?
      crunchipC Abwesend
      crunchipC Abwesend
      @goetschhofer sagte in proxmox-Datensicherung Fehlermeldung ?:
      auf dem Host ist root, auf deiner VM dein User Karl, also musst du das mit sudo ausführen
      G 1 Antwort Letzte Antwort
        GOETSCHHOFER
        @crunchip said in proxmox-Datensicherung Fehlermeldung ?:
        Ja, auf dem host habe ich dies mit root ausgeführt, da es nur so funktioniert hat.
        Auf der VM hat er aber auch nicht sehr viel gefunden.
          @goetschhofer unabhängig davon ob dein local voll ist, dein eigentliches Problem ist der thin pool pve/data
          und selbst wenn du die alten Kernel und auch deine zwei templates + die eine iso aus dem local löscht, ist da immer noch zuviel in local.
          local hat nichts mit deinem thin pool zu tun
          ich tippe darauf, das du backups auf local abgelegt hast. Die siehst du aber nur wenn das noch angehakt ist. klick dort mal alle an.
          wenn du dann auf local klickst, siehst du alles in der Übersicht
          GOETSCHHOFER
          @crunchip
          Könnten es diese 50 GB sein ?
          • G GOETSCHHOFER
            @crunchip
            crunchipC Abwesend
            crunchipC Abwesend
            Könnten es
            dazu musst du im ersten screen alles auswählen, sonst wird dir das im zweiten screen nicht angezeigt
              Könnten es
              GOETSCHHOFER
              Könnten es
              Ich weiß nicht, ob ich dich richtig verstanden habe ?
              • G GOETSCHHOFER
                Könnten es
                crunchipC Abwesend
                crunchipC Abwesend
                ja, und siehe da, es liegen backups auf deinem local(rund 7GB), die können weg
                jetzt kannst du in der Übersicht durchklicken und siehst alles was noch so vorhanden ist
                Wenn du alles bereinigt hast, deaktivierst du wieder die entsprechenden, die du nicht für local brauchst, vor allem backup, somit steht dann local gar nicht in der Auswahl zur Verfügung, wenn du ein backup machen möchtest.
                  GOETSCHHOFER
                  @crunchip
                  Ja, dies waren gleich mal ca. 8 GB.
                  Es sind aber immer noch 47 GB, ist dies realistisch ?
                  Aber was ist sollte man dann sinnvollerweise aktivieren ?
                  • G GOETSCHHOFER
                    @crunchip
                    crunchipC Abwesend
                    crunchipC Abwesend
                    nein, sollte sich so zwischen 10 und 11GB belaufen, wenn man sonst nichts weiter auf dem Host zusätzlich installiert hat.
                    hast du noch was bei den anderen drin?
                    theoretisch bräuchte man local gar nicht und könnte es in der Ansicht deaktivieren
                    in deinem Fall, da du keine weiteren Laufwerke hast, benötigst du local und aktivierst am Schluss nur template und iso.
                    G 2 Antworten Letzte Antwort
                      GOETSCHHOFER
                      @crunchip
                      In Container Templates könnte ich sicherlich auch noch die 244 MB Debian 11 löschen.
                      Aber in den restlichen Bereichen ist nichts mehr enthalten.
                        GOETSCHHOFER
                        @crunchip
                        Könnte es eventuell an folgenden Einstellungen liegen ?
                        Bei beiden Back-up-Sticks ist VZdump backup-File aktiviert ?
                        Ist dies korrekt ?
                        120GB-backup-Stick - Einstellungen:
                        • G GOETSCHHOFER
                          @crunchip
                          Ist dies korrekt ?
                          crunchipC Abwesend
                          crunchipC Abwesend
                          Ist dies korrekt
                          Ja, du möchtest ja die backups dort ablegen, daher die Auswahl backup.
                          Du kannst auch template mit auswählen, dann hättest du die Möglichkeit. Ein template auf den Stick abzulegen.
                          Letztendlich, mit dem Auswahlmenü de/aktivierst du die Funktion/Möglichkeit.
                          Zum Verständnis
                          Du hattest auf local die backup Funktion aktiv, dort auch backups abgelegt.
                          Zwischenzeitlich einen usb Stick angeschlossen, dort ebenfalls die Funktion aktiviert, gleichzeitig aber bei local deaktiviert. So das, wenn du manuell ein backup machen möchtest, gar kein Auswahlmenü mehr erscheint, wohin das backup soll.
                          Durchs deaktivieren bei local, siehst du in der Übersicht die backups, die ja trotzdem dort noch abgelegt sind, ja nicht mehr.
                          Hoffe das sorgt etwas für Klarheit
                            Ist dies korrekt
                            Zum Verständnis
                            GOETSCHHOFER
                            Kann ich die dort abgelegten, offenbar jetzt nicht mehr sichtbaren, backups auf local noch löschen ?
                            Local hat ja jetzt immer noch 47 GB.
                            • G GOETSCHHOFER
                              crunchipC Abwesend
                              crunchipC Abwesend
                              @goetschhofer die hast du doch vorhin "sichtbar" gemacht und gelöscht, das waren doch deine rund 8GB.
                              Was noch auf deinem local abgelegt ist, keine Ahnung.
                              Deinen Screens zu entnehmen jedenfalls nichts was man per Gui sieht.
                              Da müsste man dann mal per Konsole schauen.
                                GOETSCHHOFER
                                Mit welchem Befehl kann ich in der Konsole abfragen, was sich auf local alles verbirgt ?
                                • G GOETSCHHOFER
                                  crunchipC Abwesend
                                  crunchipC Abwesend
                                  @goetschhofer mit ncdu, glaub das hatten wir bei dir schon mal in Verwendung
                                  Wenn es nicht installiert ist, dann auf dem Proxmox Host
                                  apt install ncdu
                                    @meister-mopper hab drei nodes, alle haben die selbe Speicherbelegung, wenn das so wäre, müsste ja bei allen das selbe schief gegangen sein.
                                    Meister MopperM Online
                                    Meister Mopper
                                    @crunchip sagte in proxmox-Datensicherung Fehlermeldung ?:
                                    Einige Kernel bleiben offenbar und können nur manuell entfernt werden. Feststellen kannst Du das ja mit dpkg --list|grep pve-kernel.
                                    Proxmox und HA - dank KI/AI endlich "blocklyfrei"
                                      crunchipC Abwesend
                                      crunchipC Abwesend
                                      @meister-mopper das zeigt zwar alles Mögliche an( was auch immer das bedeutet), aber installiert ist doch nur einer
                                        apt install ncdu
                                        GOETSCHHOFER
                                        apt install ncdu
                                        Musste ich erst in proxmox über die Shell installieren.
                                        Mit ncdu zeigt er mir dies an ?
                                        @Meister-Mopper Feststellen kannst Du das ja mit dpkg --list|grep pve-kernel.
                                        Das Warning nach dem Backup habe ich für beide USB-sticks immer noch.
                                        INFO: starting new backup job: vzdump 100 200 210 --storage usb_backup_120GB --mailnotification always --quiet 1 --mode snapshot --mailto --node NUC --compress zstd
                                        INFO: Starting Backup of VM 100 (qemu)
                                        INFO: Backup started at 2022-05-11 21:00:01
                                        INFO: status = running
                                        INFO: VM Name: VM-IOBROKER-192.168.1.140
                                        INFO: include disk 'scsi0' 'local-lvm:vm-100-disk-0' 20G
                                        INFO: backup mode: snapshot
                                        INFO: ionice priority: 7
                                        INFO: creating vzdump archive '/media/usb_backup/dump/vzdump-qemu-100-2022_05_11-21_00_01.vma.zst'
                                        INFO: started backup task '79f197ef-621b-43db-b4ff-0755ac3210fa'
                                        INFO: resuming VM again
                                        INFO: 1% (275.5 MiB of 20.0 GiB) in 3s, read: 91.8 MiB/s, write: 40.4 MiB/s
                                        INFO: 2% (445.9 MiB of 20.0 GiB) in 8s, read: 34.1 MiB/s, write: 22.2 MiB/s
                                        INFO: 3% (616.2 MiB of 20.0 GiB) in 15s, read: 24.3 MiB/s, write: 15.9 MiB/s
                                        INFO: 4% (819.2 MiB of 20.0 GiB) in 24s, read: 22.6 MiB/s, write: 18.5 MiB/s
                                        INFO: 5% (1.0 GiB of 20.0 GiB) in 30s, read: 37.5 MiB/s, write: 27.1 MiB/s
                                        INFO: 6% (1.2 GiB of 20.0 GiB) in 38s, read: 25.8 MiB/s, write: 21.1 MiB/s
                                        INFO: 7% (1.4 GiB of 20.0 GiB) in 43s, read: 40.6 MiB/s, write: 34.0 MiB/s
                                        INFO: 8% (1.6 GiB of 20.0 GiB) in 49s, read: 33.2 MiB/s, write: 24.7 MiB/s
                                        INFO: 9% (1.8 GiB of 20.0 GiB) in 58s, read: 23.4 MiB/s, write: 20.7 MiB/s
                                        INFO: 10% (2.0 GiB of 20.0 GiB) in 1m 6s, read: 23.1 MiB/s, write: 21.0 MiB/s
                                        INFO: 11% (2.2 GiB of 20.0 GiB) in 1m 9s, read: 76.1 MiB/s, write: 39.1 MiB/s
                                        INFO: 12% (2.4 GiB of 20.0 GiB) in 1m 14s, read: 41.1 MiB/s, write: 30.2 MiB/s
                                        INFO: 13% (2.6 GiB of 20.0 GiB) in 1m 25s, read: 17.9 MiB/s, write: 17.2 MiB/s
                                        INFO: 15% (3.1 GiB of 20.0 GiB) in 1m 28s, read: 148.6 MiB/s, write: 15.5 MiB/s
                                        INFO: 16% (3.2 GiB of 20.0 GiB) in 1m 34s, read: 27.8 MiB/s, write: 17.1 MiB/s
                                        INFO: 17% (3.4 GiB of 20.0 GiB) in 1m 43s, read: 21.8 MiB/s, write: 18.8 MiB/s
                                        INFO: 18% (3.6 GiB of 20.0 GiB) in 1m 57s, read: 15.3 MiB/s, write: 15.3 MiB/s
                                        INFO: 19% (3.8 GiB of 20.0 GiB) in 2m 8s, read: 17.5 MiB/s, write: 15.9 MiB/s
                                        INFO: 20% (4.0 GiB of 20.0 GiB) in 2m 19s, read: 18.5 MiB/s, write: 14.4 MiB/s
                                        INFO: 21% (4.2 GiB of 20.0 GiB) in 2m 22s, read: 68.9 MiB/s, write: 27.7 MiB/s
                                        INFO: 22% (4.4 GiB of 20.0 GiB) in 2m 26s, read: 52.6 MiB/s, write: 45.8 MiB/s
                                        INFO: 23% (4.6 GiB of 20.0 GiB) in 2m 34s, read: 26.3 MiB/s, write: 25.7 MiB/s
                                        INFO: 24% (4.8 GiB of 20.0 GiB) in 2m 41s, read: 33.1 MiB/s, write: 20.6 MiB/s
                                        INFO: 25% (5.0 GiB of 20.0 GiB) in 2m 47s, read: 27.8 MiB/s, write: 24.0 MiB/s
                                        INFO: 26% (5.2 GiB of 20.0 GiB) in 2m 52s, read: 40.6 MiB/s, write: 34.0 MiB/s
                                        INFO: 27% (5.4 GiB of 20.0 GiB) in 3m 4s, read: 17.2 MiB/s, write: 16.7 MiB/s
                                        INFO: 28% (5.8 GiB of 20.0 GiB) in 3m 14s, read: 40.2 MiB/s, write: 15.1 MiB/s
                                        INFO: 29% (5.9 GiB of 20.0 GiB) in 3m 17s, read: 33.8 MiB/s, write: 18.9 MiB/s
                                        INFO: 30% (6.0 GiB of 20.0 GiB) in 3m 24s, read: 15.5 MiB/s, write: 15.5 MiB/s
                                        INFO: 31% (6.2 GiB of 20.0 GiB) in 3m 27s, read: 77.3 MiB/s, write: 30.3 MiB/s
                                        INFO: 32% (6.4 GiB of 20.0 GiB) in 3m 32s, read: 35.5 MiB/s, write: 28.5 MiB/s
                                        INFO: 33% (6.6 GiB of 20.0 GiB) in 3m 42s, read: 21.8 MiB/s, write: 17.9 MiB/s
                                        INFO: 34% (6.8 GiB of 20.0 GiB) in 3m 55s, read: 15.3 MiB/s, write: 15.3 MiB/s
                                        INFO: 35% (7.0 GiB of 20.0 GiB) in 4m 5s, read: 21.0 MiB/s, write: 17.1 MiB/s
                                        INFO: 36% (7.2 GiB of 20.0 GiB) in 4m 14s, read: 26.2 MiB/s, write: 18.6 MiB/s
                                        INFO: 38% (7.7 GiB of 20.0 GiB) in 4m 17s, read: 146.2 MiB/s, write: 16.0 MiB/s
                                        INFO: 39% (7.8 GiB of 20.0 GiB) in 4m 26s, read: 16.5 MiB/s, write: 16.5 MiB/s
                                        INFO: 41% (8.3 GiB of 20.0 GiB) in 4m 29s, read: 168.0 MiB/s, write: 67.0 MiB/s
                                        INFO: 42% (8.4 GiB of 20.0 GiB) in 4m 33s, read: 32.6 MiB/s, write: 26.5 MiB/s
                                        INFO: 44% (8.9 GiB of 20.0 GiB) in 4m 36s, read: 170.4 MiB/s, write: 22.4 MiB/s
                                        INFO: 45% (9.0 GiB of 20.0 GiB) in 4m 41s, read: 15.2 MiB/s, write: 15.2 MiB/s
                                        INFO: 46% (9.2 GiB of 20.0 GiB) in 4m 53s, read: 16.9 MiB/s, write: 16.3 MiB/s
                                        INFO: 47% (9.4 GiB of 20.0 GiB) in 5m 5s, read: 16.9 MiB/s, write: 16.3 MiB/s
                                        INFO: 48% (9.6 GiB of 20.0 GiB) in 5m 17s, read: 17.5 MiB/s, write: 17.1 MiB/s
                                        INFO: 49% (9.8 GiB of 20.0 GiB) in 5m 30s, read: 15.6 MiB/s, write: 15.6 MiB/s
                                        INFO: 51% (10.2 GiB of 20.0 GiB) in 5m 33s, read: 146.1 MiB/s, write: 39.4 MiB/s
                                        INFO: 52% (10.5 GiB of 20.0 GiB) in 5m 37s, read: 69.9 MiB/s, write: 41.7 MiB/s
                                        INFO: 53% (10.7 GiB of 20.0 GiB) in 5m 41s, read: 58.9 MiB/s, write: 21.1 MiB/s
                                        INFO: 58% (11.8 GiB of 20.0 GiB) in 5m 44s, read: 360.1 MiB/s, write: 27.8 MiB/s
                                        INFO: 60% (12.2 GiB of 20.0 GiB) in 5m 47s, read: 122.0 MiB/s, write: 42.8 MiB/s
                                        INFO: 61% (12.3 GiB of 20.0 GiB) in 5m 50s, read: 49.5 MiB/s, write: 39.5 MiB/s
                                        INFO: 62% (12.5 GiB of 20.0 GiB) in 5m 53s, read: 60.4 MiB/s, write: 44.7 MiB/s
                                        INFO: 63% (12.6 GiB of 20.0 GiB) in 5m 56s, read: 45.9 MiB/s, write: 37.5 MiB/s
                                        INFO: 64% (12.8 GiB of 20.0 GiB) in 6m 1s, read: 39.9 MiB/s, write: 32.2 MiB/s
                                        INFO: 70% (14.0 GiB of 20.0 GiB) in 6m 4s, read: 409.5 MiB/s, write: 28.0 MiB/s
                                        INFO: 71% (14.3 GiB of 20.0 GiB) in 6m 7s, read: 110.1 MiB/s, write: 46.5 MiB/s
                                        INFO: 80% (16.0 GiB of 20.0 GiB) in 6m 10s, read: 574.0 MiB/s, write: 25.1 MiB/s
                                        INFO: 81% (16.3 GiB of 20.0 GiB) in 6m 13s, read: 99.1 MiB/s, write: 53.8 MiB/s
                                        INFO: 82% (16.5 GiB of 20.0 GiB) in 6m 16s, read: 85.8 MiB/s, write: 47.3 MiB/s
                                        INFO: 86% (17.2 GiB of 20.0 GiB) in 6m 19s, read: 223.5 MiB/s, write: 43.6 MiB/s
                                        INFO: 92% (18.5 GiB of 20.0 GiB) in 6m 22s, read: 455.5 MiB/s, write: 19.7 MiB/s
                                        INFO: 93% (18.6 GiB of 20.0 GiB) in 6m 26s, read: 17.2 MiB/s, write: 17.2 MiB/s
                                        INFO: 94% (18.8 GiB of 20.0 GiB) in 6m 36s, read: 21.0 MiB/s, write: 16.2 MiB/s
                                        INFO: 95% (19.0 GiB of 20.0 GiB) in 6m 49s, read: 15.6 MiB/s, write: 15.6 MiB/s
                                        INFO: 100% (20.0 GiB of 20.0 GiB) in 6m 52s, read: 337.9 MiB/s, write: 13.4 MiB/s
                                        INFO: backup is sparse: 11.16 GiB (55%) total zero data
                                        INFO: transferred 20.00 GiB in 412 seconds (49.7 MiB/s)
                                        INFO: archive file size: 6.07GB
                                        INFO: Finished Backup of VM 100 (00:06:53)
                                        INFO: Backup finished at 2022-05-11 21:06:54
                                        INFO: Starting Backup of VM 200 (lxc)
                                        INFO: Backup started at 2022-05-11 21:06:54
                                        INFO: CT Name: LXC-INFLUXDB-192.168.1.177
                                        INFO: including mount point rootfs ('/') in backup
                                        INFO: create storage snapshot 'vzdump'
                                        WARNING: You have not turned on protection against thin pools running out of space.
                                        WARNING: Set activation/thin_pool_autoextend_threshold below 100 to trigger automatic extension of thin pools before they get full.
                                        Logical volume "snap_vm-200-disk-1_vzdump" created.
                                        WARNING: Sum of all thin volume sizes (148.00 GiB) exceeds the size of thin pool pve/data and the amount of free space in volume group (16.00 GiB).
                                        INFO: creating vzdump archive '/media/usb_backup/dump/vzdump-lxc-200-2022_05_11-21_06_54.tar.zst'
                                        INFO: Total bytes written: 7836293120 (7.3GiB, 58MiB/s)
                                        INFO: archive file size: 1.61GB
                                        INFO: cleanup temporary 'vzdump' snapshot
                                        Logical volume "snap_vm-200-disk-1_vzdump" successfully removed
                                        INFO: Finished Backup of VM 200 (00:02:13)
                                        INFO: Backup finished at 2022-05-11 21:09:07
                                        INFO: Starting Backup of VM 210 (lxc)
                                        INFO: Backup started at 2022-05-11 21:09:07
                                        INFO: CT Name: LXC-GRAFANA-192.168.1.178
                                        Logical volume "snap_vm-210-disk-0_vzdump" created.
                                        INFO: creating vzdump archive '/media/usb_backup/dump/vzdump-lxc-210-2022_05_11-21_09_07.tar.zst'
                                        INFO: Total bytes written: 1238763520 (1.2GiB, 35MiB/s)
                                        INFO: archive file size: 452MB
                                        Logical volume "snap_vm-210-disk-0_vzdump" successfully removed
                                        INFO: Finished Backup of VM 210 (00:00:37)
                                        INFO: Backup finished at 2022-05-11 21:09:44
                                        INFO: Backup job finished successfully
                                        TASK OK
                                        INFO: starting new backup job: vzdump 200 210 --storage Backup-USB-Stick --compress zstd --node NUC --mailto --mailnotification always --quiet 1 --mode snapshot
                                        INFO: Backup started at 2022-05-11 20:00:02
                                        INFO: creating vzdump archive '/media/USB-NUC-NAS/dump/vzdump-lxc-200-2022_05_11-20_00_02.tar.zst'
                                        INFO: Total bytes written: 7845120000 (7.4GiB, 203MiB/s)
                                        INFO: archive file size: 1.63GB
                                        INFO: removing backup 'Backup-USB-Stick:backup/vzdump-lxc-200-2022_05_08-20_01_55.tar.zst'
                                        INFO: Finished Backup of VM 200 (00:00:40)
                                        INFO: Backup finished at 2022-05-11 20:00:42
                                        INFO: Backup started at 2022-05-11 20:00:42
                                        INFO: creating vzdump archive '/media/USB-NUC-NAS/dump/vzdump-lxc-210-2022_05_11-20_00_42.tar.zst'
                                        INFO: Total bytes written: 1238763520 (1.2GiB, 108MiB/s)
                                        INFO: removing backup 'Backup-USB-Stick:backup/vzdump-lxc-210-2022_05_08-20_02_38.tar.zst'
                                        INFO: Finished Backup of VM 210 (00:00:15)
                                        INFO: Backup finished at 2022-05-11 20:00:57
                                        TASK OK
                                        • G GOETSCHHOFER
                                          apt install ncdu
                                          TASK OK
                                          TASK OK
                                          crunchipC Abwesend
                                          crunchipC Abwesend
                                          du stehst im root Verzeichnis, wechsel auf die Gesamtplatte mit
                                          cd /
                                          und danach nochmal
                                          ncdu
                                          danach siehst du die einzelnen Verzeichnisse incl Größe und kannst mit den Pfeiltasten hin und her blättern
                                          Spoiler
                                          hab ich ja schon bereits geschrieben, dein volles local hat nichts damit zu tun, dein thin pool ist belegt
                                          zeig mal den Inhalt von local-lvm
                                          bzw auch
