  4. Zigbee iobroker Error while opening serialport
    2.5k
    4.5k
231 Beiträge 28 Kommentatoren 60.7k Aufrufe 24 Beobachtet
  • S stauber
    @thomas-braun sagte in Zigbee iobroker Error while opening serialport:
    iob nodejs-update 20
    Das mach ich auch
    nur er Zeigt immer noch v22.4
    ioBroker nodejs fixer 2024-05-23
    You requested to install latest version from nodejs v20 tree.
    Your current setup is:
    /usr/bin/nodejs         v22.4.1
    /usr/bin/node           v22.4.1
    /usr/bin/npm            10.8.1
    /usr/bin/npx            10.8.1
    /usr/bin/corepack       0.28.2
    We found these nodejs versions available for installation:
    nodejs:
      Installed: 22.4.1-1nodesource1
      Candidate: 22.4.1-1nodesource1
      Version table:
     *** 22.4.1-1nodesource1 100
            100 /var/lib/dpkg/status
         20.15.1-1nodesource1 600
            500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
         20.15.0-1nodesource1 600
         20.14.0-1nodesource1 600
         20.13.1-1nodesource1 600
         20.13.0-1nodesource1 600
         20.12.2-1nodesource1 600
         20.12.1-1nodesource1 600
         20.12.0-1nodesource1 600
         20.11.1-1nodesource1 600
         20.11.0-1nodesource1 600
         20.10.0-1nodesource1 600
         20.9.0-1nodesource1 600
         20.8.1-1nodesource1 600
         20.8.0-1nodesource1 600
         20.7.0-1nodesource1 600
         20.6.1-1nodesource1 600
         20.6.0-1nodesource1 600
         20.5.1-1nodesource1 600
         20.5.0-1nodesource1 600
         20.4.0-1nodesource1 600
         20.3.1-1nodesource1 600
         20.3.0-1nodesource1 600
         20.2.0-1nodesource1 600
         20.1.0-1nodesource1 600
         20.0.0-1nodesource1 600
         12.22.12~dfsg-1~deb11u4 500
            500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
    Nothing to do - Your installation is using the correct paths.
    You are running nodejs v22.4.1. Do you want to install latest version from nodejs v.20 tree?
    Press <y> to continue or any other key to quit
    Trying to fix your installation now. Please be patient.
    rm: cannot remove '/usr/share/keyrings/nodesource.gpg'$'\n''/etc/apt/keyrings/nodesource.gpg': No such file or directory
    Waiting for ioBroker to shut down - Give me a minute...
    *** These repos are active on your system:
    Hit:1 http://deb.debian.org/debian bullseye-proposed-updates InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
    Reading package lists... Done
    *** Installing ca-certificates, curl and gnupg, just in case they are missing.
    *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
    deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_20.x nodistro main
    Package: nodejs
    Pin: origin deb.nodesource.com
    Pin-Priority: 1001
    *** These repos are active after the adjustments:
    Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Get:4 https://deb.nodesource.com/node_20.x nodistro InRelease [12.1 kB]
    Get:5 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages [8461 B]
    Fetched 20.6 kB in 1s (20.3 kB/s)
    Installing nodejs now!
    Installing the nodejs!
    We tried our best to fix your nodejs. Please run iob diag again to verify.
    *** RESTARTING ioBroker NOW! ***
     Please refresh or restart your browser in a few moments.
    #141
    @stauber sagte in Zigbee iobroker Error while opening serialport:
    node -v
    sagt?
      node -v
      sagt?
      stauber
      #142
      auch 22
      • S stauber
        auch 22
        #143
        @stauber
        Bitte keine Bildchen von Text.
        sudo apt update
        sudo apt install nodejs=20.15.1-1nodesource1
          @stauber
          sudo apt update
          stauber
          #144
          ok das hat funktioniert vielen Dank!
          jetzt mit
          iob diag
          Kannst du mir sagen wo ungefähr die by id steht?
          • S stauber
            jetzt mit
            iob diag
            #145
            @stauber
            Poste die Langfassung in Gänze.
              @stauber
              stauber
              schrieb am zuletzt editiert von stauber
              #146
              Skript v.2024-05-22
              *** BASE SYSTEM ***
                 Static hostname: raspberrypi
                       Icon name: computer
                Operating System: Raspbian GNU/Linux 11 (bullseye)
                          Kernel: Linux 6.1.21-v8+
                    Architecture: arm64
              Model           : Raspberry Pi 4 Model B Rev 1.2
              Docker          : false
              Virtualization  : none
              Kernel          : aarch64
              Userland        : 32 bit
              Systemuptime and Load:
               19:48:08 up 23:11,  1 user,  load average: 0.64, 0.87, 0.91
              CPU threads: 4
              *** RASPBERRY THROTTLING ***
              Current issues:
              Previously detected issues:
              *** Time and Time Zones ***
                             Local time: Sun 2024-07-14 19:48:08 CEST
                         Universal time: Sun 2024-07-14 17:48:08 UTC
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              *** Users and Groups ***
              User that called 'iob diag':
              pi
              HOME=/home/pi
              GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
              iobroker
              HOME=/home/iobroker
              *** Display-Server-Setup ***
              Display-Server: false
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Mem:            3.8G        1.0G        1.5G        0.0K        1.2G        2.7G
              Swap:            99M          0B         99M
              Total:          3.9G        1.0G        1.6G
              Active iob-Instances:   22
                       3793 M total memory
                       1018 M used memory
                       1067 M active memory
                        957 M inactive memory
                       1540 M free memory
                        251 M buffer memory
                        981 M swap cache
                         99 M total swap
                          0 M used swap
                         99 M free swap
              top - 19:48:09 up 23:11,  1 user,  load average: 0.67, 0.87, 0.91
              Tasks: 174 total,   1 running, 173 sleeping,   0 stopped,   0 zombie
              %Cpu(s):  2.9 us,  2.9 sy,  0.0 ni, 94.2 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
              MiB Mem :   3793.3 total,   1540.2 free,   1019.4 used,   1233.7 buff/cache
              MiB Swap:    100.0 total,    100.0 free,      0.0 used.   2697.6 avail Mem
              *** FAILED SERVICES ***
              0 loaded units listed.
              *** FILESYSTEM ***
              /dev/root      ext4      220G  8.2G  203G   4% /
              devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
              tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
              tmpfs          tmpfs     759M  892K  758M   1% /run
              /dev/sda1      vfat      253M   51M  202M  20% /boot
              tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
              [Sat Jul 13 20:36:26 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:5B:D6:24 vc_mem.mem_base        =0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=61bf9d36-02 rootfstype=ext4 fsck.repair=yes rootwait
              [Sat Jul 13 20:36:28 2024] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
              [Sat Jul 13 20:36:28 2024] EXT4-fs (sda2): write access will be enabled during recovery
              [Sat Jul 13 20:36:28 2024] EXT4-fs (sda2): recovery complete
              [Sat Jul 13 20:36:28 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
              [Sat Jul 13 20:36:28 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
              [Sat Jul 13 20:36:30 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
              Show mounted filesystems:
              TARGET                       SOURCE     FSTYPE     OPTIONS
              /                            /dev/sda2  ext4       rw,noatime
              |-/dev                       devtmpfs   devtmpfs   rw,relatime,size=1677960k,nr_inodes=419490,mode=755
              | |-/dev/shm                 tmpfs      tmpfs      rw,nosuid,nodev
              | |-/dev/pts                 devpts     devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
              | `-/dev/mqueue              mqueue     mqueue     rw,nosuid,nodev,noexec,relatime
              |-/proc                      proc       proc       rw,relatime
              | `-/proc/sys/fs/binfmt_misc systemd-1  autofs     rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
              |-/sys                       sysfs      sysfs      rw,nosuid,nodev,noexec,relatime
              | |-/sys/kernel/security     securityfs securityfs rw,nosuid,nodev,noexec,relatime
              | |-/sys/fs/cgroup           cgroup2    cgroup2    rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
              | |-/sys/fs/pstore           pstore     pstore     rw,nosuid,nodev,noexec,relatime
              | |-/sys/fs/bpf              bpf        bpf        rw,nosuid,nodev,noexec,relatime,mode=700
              | |-/sys/kernel/debug        debugfs    debugfs    rw,nosuid,nodev,noexec,relatime
              | |-/sys/kernel/tracing      tracefs    tracefs    rw,nosuid,nodev,noexec,relatime
              | |-/sys/fs/fuse/connections fusectl    fusectl    rw,nosuid,nodev,noexec,relatime
              | `-/sys/kernel/config       configfs   configfs   rw,nosuid,nodev,noexec,relatime
              |-/run                       tmpfs      tmpfs      rw,nosuid,nodev,size=776876k,nr_inodes=819200,mode=755
              | |-/run/lock                tmpfs      tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k
              | |-/run/rpc_pipefs          sunrpc     rpc_pipefs rw,relatime
              | `-/run/user/1000           tmpfs      tmpfs      rw,nosuid,nodev,relatime,size=388436k,nr_inodes=97109,mode=700,uid=1000,gid=1000
              `-/boot                      /dev/sda1  vfat       rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
              /var:
              2.6G    /var/
              1.3G    /var/log/journal/3e23e34d17484a28b9473f69f7d9d21c
              1.3G    /var/log
              1.2G    /var/cache/apt
              Archived and active journals take up 1.2G in the file system.
              /opt/iobroker/backups:
              121M    /opt/iobroker/backups/
              /opt/iobroker/iobroker-data:
              604M    /opt/iobroker/iobroker-data/
              439M    /opt/iobroker/iobroker-data/files
              138M    /opt/iobroker/iobroker-data/files/javascript.admin
              136M    /opt/iobroker/iobroker-data/backup-objects
              118M    /opt/iobroker/iobroker-data/files/javascript.admin/static
              38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
              35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
              27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
              26M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.8947f24d.js.map
              24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
              USB-Devices by-id:
              /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.18__Embed_with_CMSIS-DAP_L1100PJ1-if03
              /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.18__Embed_with_CMSIS-DAP_L1100PJ1-if00
              HINT:
              Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
              /dev/ttyACM0
              *** NodeJS-Installation ***
              /usr/bin/nodejs         v20.15.1
              /usr/bin/node           v20.15.1
              /usr/bin/npm            10.7.0
              /usr/bin/npx            10.7.0
              /usr/bin/corepack       0.28.1
              nodejs:
                Installed: 20.15.1-1nodesource1
                Candidate: 20.15.1-1nodesource1
                Version table:
               *** 20.15.1-1nodesource1 600
              No problems detected
              Errors in npm tree:
              *** ioBroker-Installation ***
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Core adapters versions
              js-controller:  5.0.19
              admin:          6.17.14
              javascript:     8.3.1
              nodejs modules from github:     0
              Adapter State
              + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                system.adapter.alexa2.0                 : alexa2                : raspberrypi                              - disabled
              + system.adapter.awtrix-light.0           : awtrix-light          : raspberrypi                              -  enabled
              + system.adapter.awtrix-light.1           : awtrix-light          : raspberrypi                              -  enabled
              + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
                system.adapter.birthdays.0              : birthdays             : raspberrypi                              -  enabled
                system.adapter.cloud.0                  : cloud                 : raspberrypi                              - disabled
                system.adapter.denon.0                  : denon                 : raspberrypi                              - disabled
                system.adapter.devices.0                : devices               : raspberrypi                              -  enabled
              + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
              + system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled
              + system.adapter.fullcalendar.0           : fullcalendar          : raspberrypi                              -  enabled
              + system.adapter.govee-local.0            : govee-local           : raspberrypi                              -  enabled
                system.adapter.heatingcontrol.0         : heatingcontrol        : raspberrypi                              - disabled
              + system.adapter.hmip.0                   : hmip                  : raspberrypi                              -  enabled
                system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
              + system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
                system.adapter.iot.0                    : iot                   : raspberrypi                              - disabled
              + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
              + system.adapter.klf200.0                 : klf200                : raspberrypi                              -  enabled
                system.adapter.mihome-vacuum.0          : mihome-vacuum         : raspberrypi                              - disabled, port: 54321
              + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
                system.adapter.nuki-extended.0          : nuki-extended         : raspberrypi                              - disabled
                system.adapter.nuki.0                   : nuki                  : raspberrypi                              - disabled
                system.adapter.places.0                 : places                : raspberrypi                              - disabled
              + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
              + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1886, bind: 0.0.0.0
              + system.adapter.statistics.0             : statistics            : raspberrypi                              -  enabled
              + system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
              + system.adapter.text2command.0           : text2command          : raspberrypi                              -  enabled
              + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
              + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
                system.adapter.web.0                    : web                   : raspberrypi                              - disabled, port: 8082, bind: 0.0.0.0, run as: admin
                system.adapter.yr.0                     : yr                    : raspberrypi                              -  enabled
              + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/ttyACM0
              + instance is alive
              ioBroker-Repositories
              Active repo(s): stable
              Installed ioBroker-Instances
              Used repository: stable
              Adapter    "admin"        : 6.17.14  , installed 6.17.14
              Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
              Adapter    "alias-manager": 1.2.6    , installed 1.2.6
              Adapter    "awtrix-light" : 1.2.0    , installed 1.2.0
              Adapter    "backitup"     : 2.11.0   , installed 2.11.0
              Adapter    "birthdays"    : 3.0.0    , installed 3.0.0
              Adapter    "cloud"        : 5.0.1    , installed 5.0.1
              Adapter    "denon"        : 1.15.5   , installed 1.15.5
              Adapter    "devices"      : 1.1.5    , installed 1.1.5
              Adapter    "discovery"    : 4.5.0    , installed 4.5.0
              Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
              Adapter    "fullcalendar" : 2.3.17   , installed 2.3.17
              Adapter    "govee-local"  : 0.2.6    , installed 0.2.6
              Adapter    "heatingcontrol": 2.12.8  , installed 2.12.8
              Adapter    "heos"         : 2.2.1    , installed 2.2.1
              Adapter    "hmip"         : 1.23.3   , installed 1.23.3
              Adapter    "ical"         : 1.15.0   , installed 1.15.0
              Adapter    "iot"          : 3.3.0    , installed 3.3.0
              Adapter    "javascript"   : 8.3.1    , installed 8.3.1
              Controller "js-controller": 5.0.19   , installed 5.0.19
              Adapter    "klf200"       : 1.2.0    , installed 1.2.0
              Adapter    "mihome-vacuum": 4.2.0    , installed 4.2.0
              Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
              Adapter    "nuki"         : 2.0.0    , installed 2.0.0
              Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
              Adapter    "places"       : 1.2.0    , installed 1.2.0
              Adapter    "rest-api"     : 2.0.1    , installed 2.0.1
              Adapter    "scenes"       : 3.0.4    , installed 3.0.4
              Adapter    "shelly"       : 7.0.0    , installed 7.0.0
              Adapter    "socketio"     : 6.7.0    , installed 6.7.0
              Adapter    "statistics"   : 2.4.0    , installed 2.4.0
              Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
              Adapter    "telegram"     : 3.3.2    , installed 3.3.2
              Adapter    "text2command" : 3.0.3    , installed 3.0.3
              Adapter    "trashschedule": 3.3.0    , installed 3.3.0
              Adapter    "ws"           : 2.6.1    , installed 2.6.1
              Adapter    "yr"           : 5.3.0    , installed 5.3.0
              Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
              Objects and States
              Objects:        9591
              States:         7847
              Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
              Pending Updates: 0
              *** Listening Ports ***
              tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      109        14805      522/mosquitto
              tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       703780     4069/io.shelly.0
              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12860      524/sshd: /usr/sbin
              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       702593     3884/iobroker.js-co
              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       702596     3884/iobroker.js-co
              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       701671     3902/io.admin.0
              tcp6       0      0 :::1883                 :::*                    LISTEN      109        14806      522/mosquitto
              tcp6       0      0 :::22                   :::*                    LISTEN      0          12862      524/sshd: /usr/sbin
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        15505      394/avahi-daemon: r
              udp        0      0 127.0.0.1:4002          0.0.0.0:*                           1001       705775     4736/io.govee-local
              udp        0      0 0.0.0.0:34863           0.0.0.0:*                           108        15507      394/avahi-daemon: r
              udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14846      734/dhcpcd
              udp6       0      0 :::5353                 :::*                                108        15506      394/avahi-daemon: r
              udp6       0      0 :::50567                :::*                                108        15508      394/avahi-daemon: r
              udp6       0      0 :::546                  :::*                                0          15746      734/dhcpcd
              2024-07-14 19:46:11.260  - info: zigbee.0 (4000) Got terminate signal TERMINATE_YOURSELF
              2024-07-14 19:46:11.381  - info: host.raspberrypi stopInstance system.adapter.zigbee.0 send kill signal
              2024-07-14 19:46:11.263  - info: zigbee.0 (4000) cleaned everything up...
              2024-07-14 19:46:11.285  - info: zigbee.0 (4000) Zigbee: disabling joining new devices.
              2024-07-14 19:46:11.529  - warn: zigbee.0 (4000) Failed to stop zigbee during startup
              2024-07-14 19:46:11.530  - info: zigbee.0 (4000) terminating
              2024-07-14 19:46:11.531  - info: zigbee.0 (4000) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              2024-07-14 19:46:11.601  - info: zigbee.0 (4000) debug devices set to []
              2024-07-14 19:46:11.765  - info: zigbee.0 (4000) terminating
              2024-07-14 19:46:12.143  - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2024-07-14 19:46:12.272  - info: host.raspberrypi "system.adapter.zigbee.0" enabled
              2024-07-14 19:46:12.522  - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 5046
              2024-07-14 19:46:18.289  - info: zigbee.0 (5046) starting. Version 1.10.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.15.1, js-controller: 5.0.19
              2024-07-14 19:46:18.399  - info: zigbee.0 (5046) delete old Backup files. keep only last 10
              2024-07-14 19:46:18.402  - info: zigbee.0 (5046) Starting Zigbee  npm ...
              2024-07-14 19:46:18.831  - info: zigbee.0 (5046) Installed Version: iobroker.zigbee@1.10.3
              2024-07-14 19:46:39.534  - error: zigbee.0 (5046) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
              2024-07-14 19:46:39.535  - error: zigbee.0 (5046) Failed to start Zigbee
              2024-07-14 19:46:39.536  - error: zigbee.0 (5046) Error herdsman start
              2024-07-14 19:46:49.540  - info: zigbee.0 (5046) Try to reconnect. 1 attempts left
              2024-07-14 19:46:49.541  - info: zigbee.0 (5046) Starting Zigbee  npm ...
              2024-07-14 19:46:49.555  - info: zigbee.0 (5046) Installed Version: iobroker.zigbee@1.10.3
              2024-07-14 19:46:49.827  - error: zigbee.0 (5046) Starting zigbee-herdsman problem : "Error Resource temporarily unavailable Cannot lock port"
              2024-07-14 19:46:49.828  - error: zigbee.0 (5046) Failed to start Zigbee
              2024-07-14 19:46:49.829  - error: zigbee.0 (5046) Error herdsman start
              • S stauber
                Skript v.2024-05-22
                *** BASE SYSTEM ***
                         Icon name: computer
                      Architecture: arm64
                Docker          : false
                Kernel          : aarch64
                Userland        : 32 bit
                CPU threads: 4
                Current issues:
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                pi
                HOME=/home/pi
                iobroker
                HOME=/home/iobroker
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Swap:            99M          0B         99M
                         3793 M total memory
                         1018 M used memory
                         1540 M free memory
                          251 M buffer memory
                          981 M swap cache
                           99 M total swap
                            0 M used swap
                           99 M free swap
                *** FILESYSTEM ***
                /var:
                2.6G    /var/
                1.3G    /var/log
                1.2G    /var/cache/apt
                USB-Devices by-id:
                HINT:
                /dev/ttyACM0
                /usr/bin/npm            10.7.0
                /usr/bin/npx            10.7.0
                nodejs:
                  Version table:
                Errors in npm tree:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                admin:          6.17.14
                javascript:     8.3.1
                Adapter State
                + instance is alive
                Objects and States
                Objects:        9591
                States:         7847
                Pending Updates: 0
                #147
                Userland : 32 bit
                Beizeiten mal komplett neuaufsetzen, dann in einer reinen 64Bit-Version.
                Boot Target: graphical.target
                sudo systemctl set-default multi-user.target
                Dein Dateisystem hat Einschläge.
                by-id:
                einer der beiden Einträge muss in den Einstellungen eingetragen werden. Musst du mal ausprobieren, ob if03 oder if00 passt.
                Schmeiß die Quelle
                raus.
                S arteckA 2 Antworten Letzte Antwort
                  Userland : 32 bit
                  by-id:
                  Schmeiß die Quelle
                  raus.
                  stauber
                  #148
                  by-id:
                  Nein bleibt Orange bei beiden Einträgen
                  kann es sein das die Erweiterte Pan falsch ist? Hab ein Backupgeladen das vor 2 Tagen da ist alles noch gelaufen.
                  Schmeiß die Quelle
                  raus.
                  Wie mach ich das?
                  Vielen Dank für deine Unterstützung und deine Mühen
                  • S stauber
                    by-id:
                    Schmeiß die Quelle
                    raus.
                    Wie mach ich das?
                    #149
                    Wie mach ich das?
                    Lösch die entsprechende Zeile in der Datei /etc/apt/sources.list raus.
                      Wie mach ich das?
                      stauber
                      #150
                      pi@raspberrypi:~ $ /etc/apt/sources.list
                      -bash: /etc/apt/sources.list: Keine Berechtigung
                      pi@raspberrypi:~ $
                      er sagt ich habe keine Berechtigung
                      • S stauber
                        pi@raspberrypi:~ $
                        #151
                        Du verwendest ja auch kein Kommando...
                        sudo nano /etc/apt/sources.list
                        Speichern mit Strg-O, nano verlassen mit Strg-X
                          Userland : 32 bit
                          by-id:
                          Schmeiß die Quelle
                          raus.
                          arteckA Offline
                          arteckA Offline
                          arteck
                          #152
                          -if00
                          ist es immer
                            stauber
                            #153
                            tut mir leid das ich mich jetzt erst melde hatte viel zu tun in der Arbeit.
                            Heute hab ich einen Stick von Sonoff ausprobiert und siehe das es läuft wieder ich vermute das das Board einfach defekt ist.
                            Danke nochmal für eure Hilfe
                              searcher57
                              #154
                              @thomas-braun said in Zigbee iobroker Error while opening serialport:
                              Hallo Thomas,
                              jetzt bin ich am Ende! Nachdem ich Probleme mit dem Smartmeter-Adapter (Stromwerte), RPI2 Adapter (Gaswerte) kommt jetzt auch noch der Zigbee Adapter hinzu. Ich habe alles rauf und runter mit einem Raspi 5 8GB probiert. Danach habe ich den Raspi 4 8GB getestet. Auch da bekomme ich den Adapter nicht ans laufen.
                              Hier das Log des Raspi 5:
                              zigbee.0
                              	2024-09-26 15:45:02.137	error	Error herdsman start
                              zigbee.0
                              	2024-09-26 15:45:02.137	error	Failed to start Zigbee
                              zigbee.0
                              	2024-09-26 15:45:02.136	error	Starting zigbee-herdsman problem : "Error Resource temporarily unavailable Cannot lock port"
                              zigbee.0
                              	2024-09-26 15:45:02.061	info	Installed Version: iobroker.zigbee@1.10.3
                              zigbee.0
                              	2024-09-26 15:45:02.054	info	Starting Zigbee npm ...
                              zigbee.0
                              	2024-09-26 15:45:02.053	info	Try to reconnect. 1 attempts left
                              zigbee.0
                              	2024-09-26 15:44:52.052	error	Error herdsman start
                              zigbee.0
                              	2024-09-26 15:44:52.052	error	Failed to start Zigbee
                              zigbee.0
                              	2024-09-26 15:44:52.051	error	Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
                              zigbee.0
                              	2024-09-26 15:44:51.664	info	Installed Version: iobroker.zigbee@1.10.3
                              zigbee.0
                              	2024-09-26 15:44:51.465	info	Starting Zigbee npm ...
                              zigbee.0
                              	2024-09-26 15:44:51.464	info	delete old Backup files. keep only last 10
                              zigbee.0
                              	2024-09-26 15:44:51.433	info	starting. Version 1.10.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.17.0, js-controller: 6.0.11
                              zigbee.0
                              	2024-09-26 15:43:06.087	info	terminating
                              zigbee.0
                              	2024-09-26 15:43:05.820	info	Terminated (NO_ERROR): Without reason
                              zigbee.0
                              	2024-09-26 15:43:05.819	info	terminating
                              zigbee.0
                              	2024-09-26 15:43:05.818	info	debug devices set to []
                              zigbee.0
                              	2024-09-26 15:43:05.815	info	Got terminate signal TERMINATE_YOURSELF
                              zigbee.0
                              	2024-09-26 15:43:05.808	warn	Failed to stop zigbee during startup
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              iob diag:
                              Skript v.2024-05-22
                              *** BASE SYSTEM ***
                               Static hostname: Raspi58GB
                                     Icon name: computer
                                        Kernel: Linux 6.6.47+rpt-rpi-2712
                                  Architecture: arm64
                              Model           : Raspberry Pi 5 Model B Rev 1.0
                              Docker          : false
                              Kernel          : aarch64
                              Userland        : 64 bit
                               15:47:28 up 4 min,  2 users,  load average: 0.37, 0.65, 0.33
                              CPU threads: 4
                              Current issues:
                                             Local time: Thu 2024-09-26 15:47:28 CEST
                                         Universal time: Thu 2024-09-26 13:47:28 UTC
                                               RTC time: Thu 2024-09-26 13:47:28
                                            NTP service: active
                                        RTC in local TZ: no
                              pi
                              HOME=/home/pi
                              GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                              iobroker
                              HOME=/home/iobroker
                              Desktop:
                              Terminal:       tty
                              Boot Target:    multi-user.target
                              *** MEMORY ***
                              Mem:            8.4G        2.1G        5.6G        5.6M        792M        6.3G
                              Swap:           209M          0B        209M
                              Total:          8.7G        2.1G        5.8G
                              Active iob-Instances:   25
                                       8052 M total memory
                                       2020 M used memory
                                       2032 M active memory
                                        401 M inactive memory
                                       5370 M free memory
                                         61 M buffer memory
                                        693 M swap cache
                                        199 M total swap
                                          0 M used swap
                                        199 M free swap
                              top - 15:47:28 up 4 min,  2 users,  load average: 0.37, 0.65, 0.33
                              Tasks: 197 total,   2 running, 195 sleeping,   0 stopped,   0 zombie
                              %Cpu(s): 40.0 us,  0.0 sy,  0.0 ni, 40.0 id, 20.0 wa,  0.0 hi,  0.0 si,  0.0 st
                              MiB Mem :   8052.3 total,   5367.8 free,   2023.6 used,    755.4 buff/cache
                              MiB Swap:    200.0 total,    200.0 free,      0.0 used.   6028.8 avail Mem
                              *** FILESYSTEM ***
                              udev           devtmpfs  3.8G     0  3.8G   0% /dev
                              tmpfs          tmpfs     806M  5.3M  800M   1% /run
                              /dev/mmcblk0p2 ext4       59G   14G   42G  25% /
                              tmpfs          tmpfs     4.0G     0  4.0G   0% /dev/shm
                              tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
                              /dev/sda1      exfat      29G  379M   29G   2% /mnt/usb0
                              /dev/mmcblk0p1 vfat      510M   64M  447M  13% /boot/firmware
                              tmpfs          tmpfs     806M     0  806M   0% /run/user/1000
                              [Thu Sep 26 15:43:19 2024] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe  smsc95xx.macaddr=2C:CF:67:2F:A6:31 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=4e8600df-02 rootfstype=ext4 fsck.repair=yes rootwait
                              [Thu Sep 26 15:43:20 2024] EXT4-fs (mmcblk0p2): mounted filesystem 93c89e92-8f2e-4522-ad32-68faed883d2f ro with ordered data mode. Quota mode: none.
                              [Thu Sep 26 15:43:22 2024] EXT4-fs (mmcblk0p2): re-mounted 93c89e92-8f2e-4522-ad32-68faed883d2f r/w. Quota mode: none.
                              /                                                       /dev/mmcblk0p2 ext4        rw,noatime
                              | `-/sys/fs/fuse/connections                            fusectl        fusectl     rw,nosuid,nodev,noexec,relatime
                              | `-/proc/sys/fs/binfmt_misc                            systemd-1      autofs      rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=4766
                              |   `-/proc/sys/fs/binfmt_misc                          binfmt_misc    binfmt_misc rw,nosuid,nodev,noexec,relatime
                              |-/dev                                                  udev           devtmpfs    rw,nosuid,relatime,size=3950672k,nr_inodes=246917,mode=755
                              |-/run                                                  tmpfs          tmpfs       rw,nosuid,nodev,noexec,relatime,size=824560k,mode=755
                              | |-/run/credentials/systemd-sysctl.service             ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                              | |-/run/credentials/systemd-sysusers.service           ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                              | |-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                              | |-/run/credentials/systemd-tmpfiles-setup.service     ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                              | `-/run/user/1000                                      tmpfs          tmpfs       rw,nosuid,nodev,relatime,size=824544k,nr_inodes=206136,mode=700,uid=1000,gid=1000
                              |-/mnt/usb0                                             /dev/sda1      exfat       rw,relatime,fmask=0000,dmask=0000,allow_utime=0022,iocharset=utf8,errors=remount-ro
                              `-/boot/firmware                                        /dev/mmcblk0p1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                              /var:
                              6.4G    /var/
                              5.3G    /var/lib
                              5.1G    /var/lib/influxdb/engine/data
                              Archived and active journals take up 634.8M in the file system.
                              45M     /opt/iobroker/backups/
                              1.2G    /opt/iobroker/iobroker-data/
                              1.1G    /opt/iobroker/iobroker-data/files
                              441M    /opt/iobroker/iobroker-data/files/javascript.admin
                              409M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                              408M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                              26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
                              26M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
                              USB-Devices by-id:
                              /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0867d5d6b78ded11959b02f6b86ce6f8-if00-port0
                              Your zigbee.0 COM-Port is matching 'by-id'. Very good!
                              /usr/bin/nodejs         v20.17.0
                              /usr/bin/node           v20.17.0
                              /usr/bin/npm            10.8.2
                              /usr/bin/npx            10.8.2
                              /usr/bin/corepack       0.29.3
                              nodejs:
                                Installed: 20.17.0-1nodesource1
                                Candidate: 20.17.0-1nodesource1
                                Version table:
                               *** 20.17.0-1nodesource1 1001
                                      500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                                   20.16.0-1nodesource1 1001
                                   20.15.1-1nodesource1 1001
                                   20.15.0-1nodesource1 1001
                                   20.14.0-1nodesource1 1001
                                   20.13.1-1nodesource1 1001
                                   20.13.0-1nodesource1 1001
                                   20.12.2-1nodesource1 1001
                                   20.12.1-1nodesource1 1001
                                   20.12.0-1nodesource1 1001
                                   20.11.1-1nodesource1 1001
                                   20.11.0-1nodesource1 1001
                                   20.10.0-1nodesource1 1001
                                   20.9.0-1nodesource1 1001
                                   20.8.1-1nodesource1 1001
                                   20.8.0-1nodesource1 1001
                                   20.7.0-1nodesource1 1001
                                   20.6.1-1nodesource1 1001
                                   20.6.0-1nodesource1 1001
                                   20.5.1-1nodesource1 1001
                                   20.5.0-1nodesource1 1001
                                   20.4.0-1nodesource1 1001
                                   20.3.1-1nodesource1 1001
                                   20.3.0-1nodesource1 1001
                                   20.2.0-1nodesource1 1001
                                   20.1.0-1nodesource1 1001
                                   20.0.0-1nodesource1 1001
                                   18.19.0+dfsg-6~deb12u2 500
                                   18.19.0+dfsg-6~deb12u1 500
                              Errors in npm tree:
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              admin:          7.1.2
                              javascript:     8.7.6
                              Adapter State
                              + system.adapter.admin.0                  : admin                 : Raspi58GB                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                              + system.adapter.alexa2.0                 : alexa2                : Raspi58GB                                -  enabled
                                system.adapter.alias-manager.0          : alias-manager         : Raspi58GB                                - disabled
                              + system.adapter.awtrix-light.0           : awtrix-light          : Raspi58GB                                -  enabled
                              + system.adapter.backitup.0               : backitup              : Raspi58GB                                -  enabled
                              + system.adapter.broadlink2.0             : broadlink2            : Raspi58GB                                -  enabled
                                system.adapter.devices.0                : devices               : Raspi58GB                                - disabled
                                system.adapter.discovery.0              : discovery             : Raspi58GB                                - disabled
                              + system.adapter.doorbird.0               : doorbird              : Raspi58GB                                -  enabled
                              + system.adapter.echarts.0                : echarts               : Raspi58GB                                -  enabled
                              + system.adapter.followthesun.0           : followthesun          : Raspi58GB                                -  enabled
                              + system.adapter.frontier_silicon.0       : frontier_silicon      : Raspi58GB                                -  enabled
                                system.adapter.frontier_silicon.1       : frontier_silicon      : Raspi58GB                                - disabled
                                system.adapter.frontier_silicon.2       : frontier_silicon      : Raspi58GB                                - disabled
                                system.adapter.frontier_silicon.3       : frontier_silicon      : Raspi58GB                                - disabled
                              + system.adapter.hm-rega.0                : hm-rega               : Raspi58GB                                -  enabled
                              + system.adapter.hm-rpc.0                 : hm-rpc                : Raspi58GB                                -  enabled, port: 0
                              + system.adapter.hm-rpc.1                 : hm-rpc                : Raspi58GB                                -  enabled, port: 0
                              + system.adapter.influxdb.0               : influxdb              : Raspi58GB                                -  enabled, port: 8086
                              + system.adapter.iot.0                    : iot                   : Raspi58GB                                -  enabled
                              + system.adapter.javascript.0             : javascript            : Raspi58GB                                -  enabled
                              + system.adapter.mqtt.0                   : mqtt                  : Raspi58GB                                -  enabled, port: 1883, bind: 0.0.0.0
                              + system.adapter.rpi2.0                   : rpi2                  : Raspi58GB                                -  enabled
                              + system.adapter.shelly.0                 : shelly                : Raspi58GB                                -  enabled, port: 1883, bind: 0.0.0.0
                              + system.adapter.simple-api.0             : simple-api            : Raspi58GB                                -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                                system.adapter.smartmeter.0             : smartmeter            : Raspi58GB                                - disabled
                              + system.adapter.tankerkoenig.0           : tankerkoenig          : Raspi58GB                                -  enabled
                              + system.adapter.telegram.0               : telegram              : Raspi58GB                                -  enabled, port: 8443, bind: 0.0.0.0
                              + system.adapter.vis-2.0                  : vis-2                 : Raspi58GB                                -  enabled
                                system.adapter.vis.0                    : vis                   : Raspi58GB                                -  enabled
                              + system.adapter.web.0                    : web                   : Raspi58GB                                -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                system.adapter.yr.0                     : yr                    : Raspi58GB                                -  enabled
                              + system.adapter.zigbee.0                 : zigbee                : Raspi58GB                                -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0867d5d6b78ded11959b02f6b86ce6f8-if00-port0
                              + instance is alive
                              Upgrade policy: none
                              Adapter    "admin"        : 7.1.2    , installed 7.1.2
                              Adapter    "awtrix-light" : 1.3.0    , installed 1.3.0
                              Adapter    "backitup"     : 3.0.22   , installed 3.0.22
                              Adapter    "broadlink2"   : 2.3.0    , installed 2.3.0
                              Adapter    "doorbird"     : 1.7.0    , installed 1.7.0
                              Adapter    "echarts"      : 1.9.2    , installed 1.9.2
                              Adapter    "followthesun" : 0.5.1    , installed 0.5.1
                              Adapter    "frontier_silicon": 0.3.0 , installed 0.3.0
                              Adapter    "hm-rega"      : 5.0.0    , installed 5.0.0
                              Adapter    "hm-rpc"       : 1.17.0   , installed 1.17.0
                              Adapter    "javascript"   : 8.7.6    , installed 8.7.6
                              Controller "js-controller": 6.0.11   , installed 6.0.11
                              Adapter    "rpi2"         : 1.3.2    , installed 2.0.0
                              Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
                              Adapter    "socketio"     : 6.7.1    , installed 6.7.1
                              Adapter    "telegram"     : 3.9.0    , installed 3.9.0
                              Adapter    "vis-2"        : 2.9.32   , installed 2.9.32
                              Adapter    "ws"           : 2.6.2    , installed 2.6.2
                              Objects and States
                              Objects:        11825
                              States:         9324
                              Hit:1 http://archive.raspberrypi.com/debian bookworm InRelease
                              Hit:2 http://deb.debian.org/debian bookworm InRelease
                              Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
                              Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
                              Hit:5 http://deb.debian.org/debian bullseye-proposed-updates InRelease
                              Hit:6 https://repos.influxdata.com/debian stable InRelease
                              Hit:7 https://deb.nodesource.com/node_20.x nodistro InRelease
                              Pending Updates: 0
                              tcp        0      0 192.168.178.57:2001     0.0.0.0:*               LISTEN      1001       6795       1179/io.hm-rpc.1
                              tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      106        7371       814/mosquitto
                              tcp        0      0 192.168.178.57:42010    0.0.0.0:*               LISTEN      1001       6776       1164/io.hm-rpc.0
                              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          5765       829/sshd: /usr/sbin
                              tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       7487       946/iobroker.js-con
                              tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       7492       946/iobroker.js-con
                              tcp        0      0 192.168.178.57:8100     0.0.0.0:*               LISTEN      1001       8840       1313/io.doorbird.0
                              tcp6       0      0 :::1883                 :::*                    LISTEN      106        7372       814/mosquitto
                              tcp6       0      0 :::22                   :::*                    LISTEN      0          5767       829/sshd: /usr/sbin
                              tcp6       0      0 :::8087                 :::*                    LISTEN      1001       9544       1359/io.simple-api.
                              tcp6       0      0 :::8086                 :::*                    LISTEN      999        8359       884/influxd
                              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       9610       1421/io.web.0
                              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       7530       965/io.admin.0
                              udp        0      0 0.0.0.0:37934           0.0.0.0:*                           1001       6727       1119/io.broadlink2.
                              udp        0      0 0.0.0.0:50257           0.0.0.0:*                           1001       7729       1119/io.broadlink2.
                              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        5702       671/avahi-daemon: r
                              udp        0      0 0.0.0.0:38186           0.0.0.0:*                           1001       6721       1119/io.broadlink2.
                              udp        0      0 0.0.0.0:46537           0.0.0.0:*                           1001       6726       1119/io.broadlink2.
                              udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       7818       1252/io.shelly.0
                              udp        0      0 0.0.0.0:55117           0.0.0.0:*                           1001       6723       1119/io.broadlink2.
                              udp        0      0 0.0.0.0:39374           0.0.0.0:*                           104        5704       671/avahi-daemon: r
                              udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       6717       1119/io.broadlink2.
                              udp        0      0 0.0.0.0:39813           0.0.0.0:*                           1001       6722       1119/io.broadlink2.
                              udp        0      0 0.0.0.0:44924           0.0.0.0:*                           1001       6725       1119/io.broadlink2.
                              udp        0      0 0.0.0.0:57524           0.0.0.0:*                           1001       6720       1119/io.broadlink2.
                              udp        0      0 0.0.0.0:53786           0.0.0.0:*                           1001       6724       1119/io.broadlink2.
                              udp        0      0 0.0.0.0:58130           0.0.0.0:*                           1001       6729       1119/io.broadlink2.
                              udp        0      0 0.0.0.0:45874           0.0.0.0:*                           1001       6728       1119/io.broadlink2.
                              udp6       0      0 :::5353                 :::*                                104        5703       671/avahi-daemon: r
                              udp6       0      0 :::59656                :::*                                104        5705       671/avahi-daemon: r
                              2024-09-26 15:45:09.621  - info: simple-api.0 (1359) Allow states only when user is owner: false
                              2024-09-26 15:45:09.628  - info: simple-api.0 (1359) http server listening on port 8087
                              2024-09-26 15:45:12.658  - info: host.Raspi58GB instance system.adapter.tankerkoenig.0 in version "3.4.0" started with pid 1374
                              2024-09-26 15:45:13.651  - info: tankerkoenig.0 (1374) starting. Version 3.4.0 in /opt/iobroker/node_modules/iobroker.tankerkoenig, node: v20.17.0, js-controller: 6.0.11
                              2024-09-26 15:45:13.670  - info: tankerkoenig.0 (1374) Adapter is already in daemon mode
                              2024-09-26 15:45:13.671  - info: tankerkoenig.0 (1374) Sync time set to 30 minutes or 1800000 ms
                              2024-09-26 15:45:16.680  - info: host.Raspi58GB instance system.adapter.vis-2.0 in version "2.9.32" started with pid 1389
                              2024-09-26 15:45:17.906  - info: vis-2.0 (1389) starting. Version 2.9.32 in /opt/iobroker/node_modules/iobroker.vis-2, node: v20.17.0, js-controller: 6.0.11
                              2024-09-26 15:45:18.068  - error: vis-2.0 (1389) License is invalid! Nothing updated. Error: serial number (UUID) in license is for other device
                              2024-09-26 15:45:18.153  - info: tankerkoenig.0 (1374) Start first request
                              2024-09-26 15:45:21.336  - info: yr.0 (1267) Data updated.
                              2024-09-26 15:45:21.337  - info: yr.0 (1267) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                              2024-09-26 15:45:21.523  - info: vis.0 (1405) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.vis, node: v20.17.0, js-controller: 6.0.11
                              2024-09-26 15:45:21.906  - info: host.Raspi58GB instance system.adapter.yr.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                              2024-09-26 15:45:22.663  - info: vis.0 (1405) Terminated (NO_ERROR): Without reason
                              2024-09-26 15:45:23.198  - info: host.Raspi58GB instance system.adapter.vis.0 terminated while should be started once
                              2024-09-26 15:45:24.723  - info: host.Raspi58GB instance system.adapter.web.0 in version "6.2.5" started with pid 1421
                              2024-09-26 15:45:25.655  - info: web.0 (1421) starting. Version 6.2.5 in /opt/iobroker/node_modules/iobroker.web, node: v20.17.0, js-controller: 6.0.11
                              2024-09-26 15:45:25.777  - info: web.0 (1421) socket.io server listening on port 8082
                              2024-09-26 15:45:25.779  - info: web.0 (1421) http server listening on port 8082
                              2024-09-26 15:45:28.675  - info: host.Raspi58GB instance system.adapter.followthesun.0 in version "0.5.1" started with pid 1436
                              2024-09-26 15:45:29.606  - info: followthesun.0 (1436) starting. Version 0.5.1 in /opt/iobroker/node_modules/iobroker.followthesun, node: v20.17.0, js-controller: 6.0.11
                              2024-09-26 15:45:29.615  - info: followthesun.0 (1436) Started with JSON-Explorer version 0.1.16
                              2024-09-26 15:45:29.615  - info: followthesun.0 (1436) Sun position calculation will be done every 60 seconds
                              2024-09-26 15:45:29.616  - info: followthesun.0 (1436) Daily sun parameter calculation scheduled for 00:00:39
                              die Einstellungen des Adapters:
                              Erkennst Du einen Fehler? Ich möchte doch wenigstens die Zigbee-Aktoren wieder nutzen.
                              Meister MopperM Thomas BraunT 2 Antworten Letzte Antwort
                              • S searcher57
                                Hallo Thomas,
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                iob diag:
                                Skript v.2024-05-22
                                *** BASE SYSTEM ***
                                       Icon name: computer
                                    Architecture: arm64
                                Docker          : false
                                Kernel          : aarch64
                                Userland        : 64 bit
                                CPU threads: 4
                                Current issues:
                                              NTP service: active
                                          RTC in local TZ: no
                                pi
                                HOME=/home/pi
                                iobroker
                                HOME=/home/iobroker
                                Desktop:
                                Terminal:       tty
                                *** MEMORY ***
                                Swap:           209M          0B        209M
                                         8052 M total memory
                                         2020 M used memory
                                         5370 M free memory
                                           61 M buffer memory
                                          693 M swap cache
                                          199 M total swap
                                            0 M used swap
                                          199 M free swap
                                *** FILESYSTEM ***
                                /var:
                                6.4G    /var/
                                5.3G    /var/lib
                                USB-Devices by-id:
                                /usr/bin/npm            10.8.2
                                /usr/bin/npx            10.8.2
                                nodejs:
                                  Version table:
                                Errors in npm tree:
                                ioBroker Status
                                Objects type: jsonl
                                States  type: jsonl
                                admin:          7.1.2
                                javascript:     8.7.6
                                Adapter State
                                + instance is alive
                                Objects and States
                                Objects:        11825
                                States:         9324
                                Pending Updates: 0
                                Meister MopperM Online
                                Meister Mopper
                                #155
                                @searcher57
                                Läuft da vielleicht ein ModemManager? Der hat hier auch schon den Start verhindert.
                                systemctl status ModemManager.service
                                Proxmox und HA - dank KI/AI endlich "blocklyfrei"
                                  @searcher57
                                  searcher57
                                  #156
                                  @meister-mopper said in Zigbee iobroker Error while opening serialport:
                                  @searcher57
                                  Was ist das? Und wie kann ich den deaktivieren?
                                  • S searcher57
                                    Hallo Thomas,
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    iob diag:
                                    Skript v.2024-05-22
                                    *** BASE SYSTEM ***
                                           Icon name: computer
                                        Architecture: arm64
                                    Docker          : false
                                    Kernel          : aarch64
                                    Userland        : 64 bit
                                    CPU threads: 4
                                    Current issues:
                                                  NTP service: active
                                              RTC in local TZ: no
                                    pi
                                    HOME=/home/pi
                                    iobroker
                                    HOME=/home/iobroker
                                    Desktop:
                                    Terminal:       tty
                                    *** MEMORY ***
                                    Swap:           209M          0B        209M
                                             8052 M total memory
                                             2020 M used memory
                                             5370 M free memory
                                               61 M buffer memory
                                              693 M swap cache
                                              199 M total swap
                                                0 M used swap
                                              199 M free swap
                                    *** FILESYSTEM ***
                                    /var:
                                    6.4G    /var/
                                    5.3G    /var/lib
                                    USB-Devices by-id:
                                    /usr/bin/npm            10.8.2
                                    /usr/bin/npx            10.8.2
                                    nodejs:
                                      Version table:
                                    Errors in npm tree:
                                    ioBroker Status
                                    Objects type: jsonl
                                    States  type: jsonl
                                    admin:          7.1.2
                                    javascript:     8.7.6
                                    Adapter State
                                    + instance is alive
                                    Objects and States
                                    Objects:        11825
                                    States:         9324
                                    Pending Updates: 0
                                    #157
                                    @searcher57
                                    Die extended PAN-ID ist mit Sicherheit falsch, zumindest ist DDDDDDDDDDDDDDDDDDD ungünstig.
                                    S 2 Antworten Letzte Antwort
                                      @searcher57
                                      searcher57
                                      #158
                                      @searcher57
                                      Es kann sein, dass ich bei der Ersteinrichtung da etwas verändert habe. Kannst Du mir sagen, wie ich die abfrage?
                                        @searcher57
                                        searcher57
                                        #159
                                        @searcher57
                                        Ich habe sie jetzt in DDADDDDDDD2DFDDD geändert.
                                        • S searcher57
                                          @searcher57
                                          #160
                                          @searcher57 sagte in Zigbee iobroker Error while opening serialport:
                                          Im nv_backup stehen die alten Werte drin, soweit ich weiß.
