  4. Zigbee iobroker Error while opening serialport
    6.6k
231 Beiträge 28 Kommentatoren 64.1k Aufrufe 24 Beobachtet
  • F flodirmann
    So. Auch nach komplettem Neuaufsetzen des Systems mit Debian 12 Bookworm und dem Korrigieren eigenverschuldeter Rechtschreibfehler (diesmal aus PuTTY direkt rauskopiert) funktioniert es noch nicht besser.
    Egal ob ich in den Einstellungen den by-id path verwende "/dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20231214212123-if00" oder die alternative Adresse "/dev/ttyACM0", in beiden Fällen tritt der identische Fehler auf:
    2024-03-28 15:51:59.165 - info: admin.0 (1017) ==> Connected system.user.admin from ::ffff:192.168.188.23
    2024-03-28 15:51:59.266 - error: zigbee.0 (2510) getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
    2024-03-28 15:51:59.379 - info: zigbee.0 (2510) List of port: [{"path":"/dev/ttyACM0","manufacturer":"ITEAD","serialNumber":"20231214212123","pnpId":"usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20231214212123-if00","vendorId":"1a86","productId":"55d4"}]
    2024-03-28 15:52:38.919 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 (force=false, process=true)
    2024-03-28 15:52:38.926 - info: zigbee.0 (2510) Got terminate signal TERMINATE_YOURSELF
    2024-03-28 15:52:38.930 - info: zigbee.0 (2510) cleaned everything up...
    2024-03-28 15:52:38.934 - info: zigbee.0 (2510) Zigbee: disabling joining new devices.
    2024-03-28 15:52:38.958 - warn: zigbee.0 (2510) Failed to stop zigbee during startup
    2024-03-28 15:52:38.960 - info: zigbee.0 (2510) terminating
    2024-03-28 15:52:38.963 - info: zigbee.0 (2510) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2024-03-28 15:52:38.967 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 send kill signal
    2024-03-28 15:52:39.042 - info: admin.0 (1017) <== Disconnect system.user.admin from ::ffff:192.168.188.23
    2024-03-28 15:52:39.431 - info: zigbee.0 (2510) terminating
    2024-03-28 15:52:39.519 - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2024-03-28 15:52:42.016 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 2586
    2024-03-28 15:52:45.840 - info: zigbee.0 (2586) starting. Version 1.10.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.12.0, js-controller: 5.0.19
    2024-03-28 15:52:45.922 - info: zigbee.0 (2586) delete old Backup files. keep only last 10
    2024-03-28 15:52:45.925 - info: zigbee.0 (2586) Starting Zigbee npm ...
    2024-03-28 15:52:46.171 - info: zigbee.0 (2586) Installed Version: iobroker.zigbee@1.10.1
    2024-03-28 15:53:06.711 - error: zigbee.0 (2586) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
    2024-03-28 15:53:06.712 - error: zigbee.0 (2586) Failed to start Zigbee
    2024-03-28 15:53:06.712 - error: zigbee.0 (2586) Error herdsman start
    2024-03-28 15:53:16.717 - info: zigbee.0 (2586) Try to reconnect. 1 attempts left
    2024-03-28 15:53:16.721 - info: zigbee.0 (2586) Starting Zigbee npm ...
    2024-03-28 15:53:16.751 - info: zigbee.0 (2586) Installed Version: iobroker.zigbee@1.10.1
    2024-03-28 15:53:16.959 - error: zigbee.0 (2586) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
    2024-03-28 15:53:16.960 - error: zigbee.0 (2586) Failed to start Zigbee
    2024-03-28 15:53:16.961 - error: zigbee.0 (2586) Error herdsman start
    Hier noch ein Screenshot der Adaptereinstellungen:
    Könnt ihr mir da irgendwie weiterhelfen? Falls weitere Informationen benötigt werden, gerne Bescheid geben.
    AsgothianA Offline
    AsgothianA Offline
    Asgothian
    #134
    @flodirmann sagte in Zigbee iobroker Error while opening serialport:
    Stell mal bitte die Firmware im zigbee-Adapter auf EZSP (oder ähnlich) um - der sonoff dongle V2 nutzt meines Wissens nach nicht den TI Chip Satz
    A.
    F 1 Antwort Letzte Antwort
    • AsgothianA Asgothian
      A.
      flodirmann
      #135
      @asgothian
      Danke danke danke!
      Das hat tatsächlich endlich geholfen. 👍
        stauber
        #136
        seit gestern läuft der Zigbee Adapter nicht mehr ich musste gestern Router und Rasp abstecken und seitdem wird er nur noch Orange.
        Bei mir stand die ganze Zeit das Node js v22.x empfohlen wird seit dem letzten Update wird nun die 18.x empfohlen im Forum wiederum die 20.x welche soll ich jetzt Installieren?
        Mit den Befehl iob Node js-update 18 bleibt er bei 22.x hab ich schon Probiert gibt es noch eine andere Möglichkeit?
        Hardware
        Raspberry4 und das CC26x02R1
        Ansonsten könntet ihr mir irgendwie weiterhelfen?
        • S stauber
          Hardware
          #137
          @stauber
          iob nodejs-update 20
          Und dann mal die Ausgabe von
          iob diag
          Da kannst du den Link 'by-id' herausnehmen und in den Einstellungen des Adapters statt /dev/ttyACM0 eintragen.
            @stauber
            iob diag
            stauber
            #138
            Hallo Thomas
            bleib weiterhin auf 22.4
            nochmal zur Verständnis ich Kopiere den Text danach y
            oder mach ich was Falsch?
            • S stauber
              Hallo Thomas
              #139
              @stauber sagte in Zigbee iobroker Error while opening serialport:
              Ich weiß nicht was du machst...
              Du sollst
              in dein Terminal hacken.
                Du sollst
                stauber
                #140
                @thomas-braun sagte in Zigbee iobroker Error while opening serialport:
                Das mach ich auch
                nur er Zeigt immer noch v22.4
                ioBroker nodejs fixer 2024-05-23
                You requested to install latest version from nodejs v20 tree.
                Your current setup is:
                /usr/bin/nodejs         v22.4.1
                /usr/bin/node           v22.4.1
                /usr/bin/npm            10.8.1
                /usr/bin/npx            10.8.1
                /usr/bin/corepack       0.28.2
                We found these nodejs versions available for installation:
                nodejs:
                  Installed: 22.4.1-1nodesource1
                  Candidate: 22.4.1-1nodesource1
                  Version table:
                 *** 22.4.1-1nodesource1 100
                     20.15.1-1nodesource1 600
                        500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
                     20.15.0-1nodesource1 600
                     20.14.0-1nodesource1 600
                     20.13.1-1nodesource1 600
                     20.13.0-1nodesource1 600
                     20.12.2-1nodesource1 600
                     20.12.1-1nodesource1 600
                     20.12.0-1nodesource1 600
                     20.11.1-1nodesource1 600
                     20.11.0-1nodesource1 600
                     20.10.0-1nodesource1 600
                     20.9.0-1nodesource1 600
                     20.8.1-1nodesource1 600
                     20.8.0-1nodesource1 600
                     20.7.0-1nodesource1 600
                     20.6.1-1nodesource1 600
                     20.6.0-1nodesource1 600
                     20.5.1-1nodesource1 600
                     20.5.0-1nodesource1 600
                     20.4.0-1nodesource1 600
                     20.3.1-1nodesource1 600
                     20.3.0-1nodesource1 600
                     20.2.0-1nodesource1 600
                     20.1.0-1nodesource1 600
                     20.0.0-1nodesource1 600
                     12.22.12~dfsg-1~deb11u4 500
                Nothing to do - Your installation is using the correct paths.
                You are running nodejs v22.4.1. Do you want to install latest version from nodejs v.20 tree?
                Press <y> to continue or any other key to quit
                Trying to fix your installation now. Please be patient.
                rm: cannot remove '/usr/share/keyrings/nodesource.gpg'$'\n''/etc/apt/keyrings/nodesource.gpg': No such file or directory
                Waiting for ioBroker to shut down - Give me a minute...
                *** These repos are active on your system:
                Hit:1 http://deb.debian.org/debian bullseye-proposed-updates InRelease
                Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
                Reading package lists... Done
                *** Installing ca-certificates, curl and gnupg, just in case they are missing.
                *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
                deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_20.x nodistro main
                Package: nodejs
                Pin: origin deb.nodesource.com
                Pin-Priority: 1001
                *** These repos are active after the adjustments:
                Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                Hit:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                Get:4 https://deb.nodesource.com/node_20.x nodistro InRelease [12.1 kB]
                Get:5 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages [8461 B]
                Fetched 20.6 kB in 1s (20.3 kB/s)
                Installing nodejs now!
                Installing the nodejs!
                We tried our best to fix your nodejs. Please run iob diag again to verify.
                *** RESTARTING ioBroker NOW! ***
                 Please refresh or restart your browser in a few moments.
                • S stauber
                  Das mach ich auch
                  /usr/bin/npm            10.8.1
                  /usr/bin/npx            10.8.1
                  nodejs:
                    Version table:
                  Package: nodejs
                  Pin-Priority: 1001
                  #141
                  node -v
                  sagt?
                    node -v
                    sagt?
                    stauber
                    #142
                    auch 22
                    • S stauber
                      auch 22
                      #143
                      @stauber
                      Bitte keine Bildchen von Text.
                      sudo apt update
                      sudo apt install nodejs=20.15.1-1nodesource1
                        @stauber
                        sudo apt update
                        stauber
                        #144
                        ok das hat funktioniert vielen Dank!
                        jetzt mit
                        iob diag
                        Kannst du mir sagen wo ungefähr die by id steht?
                        • S stauber
                          jetzt mit
                          iob diag
                          #145
                          @stauber
                          Poste die Langfassung in Gänze.
                            @stauber
                            stauber
                            schrieb am zuletzt editiert von stauber
                            #146
                            Skript v.2024-05-22
                            *** BASE SYSTEM ***
                               Static hostname: raspberrypi
                                     Icon name: computer
                              Operating System: Raspbian GNU/Linux 11 (bullseye)
                                        Kernel: Linux 6.1.21-v8+
                                  Architecture: arm64
                            Model           : Raspberry Pi 4 Model B Rev 1.2
                            Docker          : false
                            Virtualization  : none
                            Kernel          : aarch64
                            Userland        : 32 bit
                            Systemuptime and Load:
                             19:48:08 up 23:11,  1 user,  load average: 0.64, 0.87, 0.91
                            CPU threads: 4
                            *** RASPBERRY THROTTLING ***
                            Current issues:
                            Previously detected issues:
                            *** Time and Time Zones ***
                                           Local time: Sun 2024-07-14 19:48:08 CEST
                                       Universal time: Sun 2024-07-14 17:48:08 UTC
                                             RTC time: n/a
                                          NTP service: active
                                      RTC in local TZ: no
                            *** Users and Groups ***
                            User that called 'iob diag':
                            pi
                            HOME=/home/pi
                            GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
                            iobroker
                            HOME=/home/iobroker
                            *** Display-Server-Setup ***
                            Display-Server: false
                            Desktop:
                            Terminal:       tty
                            *** MEMORY ***
                            Mem:            3.8G        1.0G        1.5G        0.0K        1.2G        2.7G
                            Swap:            99M          0B         99M
                            Total:          3.9G        1.0G        1.6G
                            Active iob-Instances:   22
                                     3793 M total memory
                                     1018 M used memory
                                     1067 M active memory
                                      957 M inactive memory
                                     1540 M free memory
                                      251 M buffer memory
                                      981 M swap cache
                                       99 M total swap
                                        0 M used swap
                                       99 M free swap
                            top - 19:48:09 up 23:11,  1 user,  load average: 0.67, 0.87, 0.91
                            Tasks: 174 total,   1 running, 173 sleeping,   0 stopped,   0 zombie
                            %Cpu(s):  2.9 us,  2.9 sy,  0.0 ni, 94.2 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                            MiB Mem :   3793.3 total,   1540.2 free,   1019.4 used,   1233.7 buff/cache
                            MiB Swap:    100.0 total,    100.0 free,      0.0 used.   2697.6 avail Mem
                            *** FAILED SERVICES ***
                            0 loaded units listed.
                            *** FILESYSTEM ***
                            /dev/root      ext4      220G  8.2G  203G   4% /
                            devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
                            tmpfs          tmpfs     759M  892K  758M   1% /run
                            /dev/sda1      vfat      253M   51M  202M  20% /boot
                            tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
                            [Sat Jul 13 20:36:26 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:5B:D6:24 vc_mem.mem_base        =0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=61bf9d36-02 rootfstype=ext4 fsck.repair=yes rootwait
                            [Sat Jul 13 20:36:28 2024] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
                            [Sat Jul 13 20:36:28 2024] EXT4-fs (sda2): write access will be enabled during recovery
                            [Sat Jul 13 20:36:28 2024] EXT4-fs (sda2): recovery complete
                            [Sat Jul 13 20:36:28 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
                            [Sat Jul 13 20:36:28 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                            [Sat Jul 13 20:36:30 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
                            Show mounted filesystems:
                            TARGET                       SOURCE     FSTYPE     OPTIONS
                            /                            /dev/sda2  ext4       rw,noatime
                            |-/dev                       devtmpfs   devtmpfs   rw,relatime,size=1677960k,nr_inodes=419490,mode=755
                            | |-/dev/shm                 tmpfs      tmpfs      rw,nosuid,nodev
                            | |-/dev/pts                 devpts     devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
                            | `-/dev/mqueue              mqueue     mqueue     rw,nosuid,nodev,noexec,relatime
                            |-/proc                      proc       proc       rw,relatime
                            | `-/proc/sys/fs/binfmt_misc systemd-1  autofs     rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
                            |-/sys                       sysfs      sysfs      rw,nosuid,nodev,noexec,relatime
                            | |-/sys/kernel/security     securityfs securityfs rw,nosuid,nodev,noexec,relatime
                            | |-/sys/fs/cgroup           cgroup2    cgroup2    rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
                            | |-/sys/fs/pstore           pstore     pstore     rw,nosuid,nodev,noexec,relatime
                            | |-/sys/fs/bpf              bpf        bpf        rw,nosuid,nodev,noexec,relatime,mode=700
                            | |-/sys/kernel/debug        debugfs    debugfs    rw,nosuid,nodev,noexec,relatime
                            | |-/sys/kernel/tracing      tracefs    tracefs    rw,nosuid,nodev,noexec,relatime
                            | |-/sys/fs/fuse/connections fusectl    fusectl    rw,nosuid,nodev,noexec,relatime
                            | `-/sys/kernel/config       configfs   configfs   rw,nosuid,nodev,noexec,relatime
                            |-/run                       tmpfs      tmpfs      rw,nosuid,nodev,size=776876k,nr_inodes=819200,mode=755
                            | |-/run/lock                tmpfs      tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k
                            | |-/run/rpc_pipefs          sunrpc     rpc_pipefs rw,relatime
                            | `-/run/user/1000           tmpfs      tmpfs      rw,nosuid,nodev,relatime,size=388436k,nr_inodes=97109,mode=700,uid=1000,gid=1000
                            `-/boot                      /dev/sda1  vfat       rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
                            /var:
                            2.6G    /var/
                            1.3G    /var/log/journal/3e23e34d17484a28b9473f69f7d9d21c
                            1.3G    /var/log
                            1.2G    /var/cache/apt
                            Archived and active journals take up 1.2G in the file system.
                            /opt/iobroker/backups:
                            121M    /opt/iobroker/backups/
                            /opt/iobroker/iobroker-data:
                            604M    /opt/iobroker/iobroker-data/
                            439M    /opt/iobroker/iobroker-data/files
                            138M    /opt/iobroker/iobroker-data/files/javascript.admin
                            136M    /opt/iobroker/iobroker-data/backup-objects
                            118M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                            38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
                            35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                            27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
                            26M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.8947f24d.js.map
                            24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                            USB-Devices by-id:
                            /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.18__Embed_with_CMSIS-DAP_L1100PJ1-if03
                            /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.18__Embed_with_CMSIS-DAP_L1100PJ1-if00
                            HINT:
                            Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
                            /dev/ttyACM0
                            *** NodeJS-Installation ***
                            /usr/bin/nodejs         v20.15.1
                            /usr/bin/node           v20.15.1
                            /usr/bin/npm            10.7.0
                            /usr/bin/npx            10.7.0
                            /usr/bin/corepack       0.28.1
                            nodejs:
                              Installed: 20.15.1-1nodesource1
                              Candidate: 20.15.1-1nodesource1
                              Version table:
                             *** 20.15.1-1nodesource1 600
                            No problems detected
                            Errors in npm tree:
                            *** ioBroker-Installation ***
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            Core adapters versions
                            admin:          6.17.14
                            javascript:     8.3.1
                            nodejs modules from github:     0
                            Adapter State
                              system.adapter.alexa2.0                 : alexa2                : raspberrypi                              - disabled
                            + system.adapter.awtrix-light.0           : awtrix-light          : raspberrypi                              -  enabled
                            + system.adapter.awtrix-light.1           : awtrix-light          : raspberrypi                              -  enabled
                              system.adapter.birthdays.0              : birthdays             : raspberrypi                              -  enabled
                              system.adapter.cloud.0                  : cloud                 : raspberrypi                              - disabled
                              system.adapter.denon.0                  : denon                 : raspberrypi                              - disabled
                              system.adapter.devices.0                : devices               : raspberrypi                              -  enabled
                            + system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled
                            + system.adapter.fullcalendar.0           : fullcalendar          : raspberrypi                              -  enabled
                            + system.adapter.govee-local.0            : govee-local           : raspberrypi                              -  enabled
                              system.adapter.heatingcontrol.0         : heatingcontrol        : raspberrypi                              - disabled
                            + system.adapter.hmip.0                   : hmip                  : raspberrypi                              -  enabled
                              system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
                              system.adapter.iot.0                    : iot                   : raspberrypi                              - disabled
                            + system.adapter.klf200.0                 : klf200                : raspberrypi                              -  enabled
                              system.adapter.mihome-vacuum.0          : mihome-vacuum         : raspberrypi                              - disabled, port: 54321
                            + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
                              system.adapter.nuki-extended.0          : nuki-extended         : raspberrypi                              - disabled
                              system.adapter.nuki.0                   : nuki                  : raspberrypi                              - disabled
                              system.adapter.places.0                 : places                : raspberrypi                              - disabled
                            + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
                            + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1886, bind: 0.0.0.0
                            + system.adapter.statistics.0             : statistics            : raspberrypi                              -  enabled
                            + system.adapter.text2command.0           : text2command          : raspberrypi                              -  enabled
                            + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
                            + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
                              system.adapter.web.0                    : web                   : raspberrypi                              - disabled, port: 8082, bind: 0.0.0.0, run as: admin
                              system.adapter.yr.0                     : yr                    : raspberrypi                              -  enabled
                            + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/ttyACM0
                            + instance is alive
                            ioBroker-Repositories
                            Active repo(s): stable
                            Installed ioBroker-Instances
                            Used repository: stable
                            Adapter    "admin"        : 6.17.14  , installed 6.17.14
                            Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                            Adapter    "alias-manager": 1.2.6    , installed 1.2.6
                            Adapter    "awtrix-light" : 1.2.0    , installed 1.2.0
                            Adapter    "backitup"     : 2.11.0   , installed 2.11.0
                            Adapter    "birthdays"    : 3.0.0    , installed 3.0.0
                            Adapter    "denon"        : 1.15.5   , installed 1.15.5
                            Adapter    "devices"      : 1.1.5    , installed 1.1.5
                            Adapter    "discovery"    : 4.5.0    , installed 4.5.0
                            Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
                            Adapter    "fullcalendar" : 2.3.17   , installed 2.3.17
                            Adapter    "govee-local"  : 0.2.6    , installed 0.2.6
                            Adapter    "heatingcontrol": 2.12.8  , installed 2.12.8
                            Adapter    "heos"         : 2.2.1    , installed 2.2.1
                            Adapter    "hmip"         : 1.23.3   , installed 1.23.3
                            Adapter    "ical"         : 1.15.0   , installed 1.15.0
                            Adapter    "iot"          : 3.3.0    , installed 3.3.0
                            Adapter    "javascript"   : 8.3.1    , installed 8.3.1
                            Controller "js-controller": 5.0.19   , installed 5.0.19
                            Adapter    "klf200"       : 1.2.0    , installed 1.2.0
                            Adapter    "mihome-vacuum": 4.2.0    , installed 4.2.0
                            Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                            Adapter    "nuki"         : 2.0.0    , installed 2.0.0
                            Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
                            Adapter    "places"       : 1.2.0    , installed 1.2.0
                            Adapter    "rest-api"     : 2.0.1    , installed 2.0.1
                            Adapter    "scenes"       : 3.0.4    , installed 3.0.4
                            Adapter    "shelly"       : 7.0.0    , installed 7.0.0
                            Adapter    "socketio"     : 6.7.0    , installed 6.7.0
                            Adapter    "statistics"   : 2.4.0    , installed 2.4.0
                            Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
                            Adapter    "telegram"     : 3.3.2    , installed 3.3.2
                            Adapter    "text2command" : 3.0.3    , installed 3.0.3
                            Adapter    "trashschedule": 3.3.0    , installed 3.3.0
                            Adapter    "web"          : 6.2.5    , installed 6.2.5
                            Adapter    "ws"           : 2.6.1    , installed 2.6.1
                            Adapter    "yr"           : 5.3.0    , installed 5.3.0
                            Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
                            Objects and States
                            Objects:        9591
                            States:         7847
                            Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
                            Pending Updates: 0
                            *** Listening Ports ***
                            tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      109        14805      522/mosquitto
                            tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       703780     4069/io.shelly.0
                            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12860      524/sshd: /usr/sbin
                            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       702593     3884/iobroker.js-co
                            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       702596     3884/iobroker.js-co
                            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       701671     3902/io.admin.0
                            tcp6       0      0 :::1883                 :::*                    LISTEN      109        14806      522/mosquitto
                            tcp6       0      0 :::22                   :::*                    LISTEN      0          12862      524/sshd: /usr/sbin
                            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        15505      394/avahi-daemon: r
                            udp        0      0 127.0.0.1:4002          0.0.0.0:*                           1001       705775     4736/io.govee-local
                            udp        0      0 0.0.0.0:34863           0.0.0.0:*                           108        15507      394/avahi-daemon: r
                            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14846      734/dhcpcd
                            udp6       0      0 :::5353                 :::*                                108        15506      394/avahi-daemon: r
                            udp6       0      0 :::50567                :::*                                108        15508      394/avahi-daemon: r
                            udp6       0      0 :::546                  :::*                                0          15746      734/dhcpcd
                            2024-07-14 19:46:11.260  - info: zigbee.0 (4000) Got terminate signal TERMINATE_YOURSELF
                            2024-07-14 19:46:11.381  - info: host.raspberrypi stopInstance system.adapter.zigbee.0 send kill signal
                            2024-07-14 19:46:11.263  - info: zigbee.0 (4000) cleaned everything up...
                            2024-07-14 19:46:11.285  - info: zigbee.0 (4000) Zigbee: disabling joining new devices.
                            2024-07-14 19:46:11.529  - warn: zigbee.0 (4000) Failed to stop zigbee during startup
                            2024-07-14 19:46:11.530  - info: zigbee.0 (4000) terminating
                            2024-07-14 19:46:11.531  - info: zigbee.0 (4000) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                            2024-07-14 19:46:11.601  - info: zigbee.0 (4000) debug devices set to []
                            2024-07-14 19:46:11.765  - info: zigbee.0 (4000) terminating
                            2024-07-14 19:46:12.143  - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                            2024-07-14 19:46:12.272  - info: host.raspberrypi "system.adapter.zigbee.0" enabled
                            2024-07-14 19:46:12.522  - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 5046
                            2024-07-14 19:46:18.289  - info: zigbee.0 (5046) starting. Version 1.10.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.15.1, js-controller: 5.0.19
                            2024-07-14 19:46:18.399  - info: zigbee.0 (5046) delete old Backup files. keep only last 10
                            2024-07-14 19:46:18.402  - info: zigbee.0 (5046) Starting Zigbee  npm ...
                            2024-07-14 19:46:18.831  - info: zigbee.0 (5046) Installed Version: iobroker.zigbee@1.10.3
                            2024-07-14 19:46:39.534  - error: zigbee.0 (5046) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
                            2024-07-14 19:46:39.535  - error: zigbee.0 (5046) Failed to start Zigbee
                            2024-07-14 19:46:39.536  - error: zigbee.0 (5046) Error herdsman start
                            2024-07-14 19:46:49.540  - info: zigbee.0 (5046) Try to reconnect. 1 attempts left
                            2024-07-14 19:46:49.541  - info: zigbee.0 (5046) Starting Zigbee  npm ...
                            2024-07-14 19:46:49.555  - info: zigbee.0 (5046) Installed Version: iobroker.zigbee@1.10.3
                            2024-07-14 19:46:49.827  - error: zigbee.0 (5046) Starting zigbee-herdsman problem : "Error Resource temporarily unavailable Cannot lock port"
                            2024-07-14 19:46:49.828  - error: zigbee.0 (5046) Failed to start Zigbee
                            2024-07-14 19:46:49.829  - error: zigbee.0 (5046) Error herdsman start
                            • S stauber
                              Skript v.2024-05-22
                              *** BASE SYSTEM ***
                                       Icon name: computer
                                    Architecture: arm64
                              Docker          : false
                              Kernel          : aarch64
                              Userland        : 32 bit
                              CPU threads: 4
                              Current issues:
                                               RTC time: n/a
                                            NTP service: active
                                        RTC in local TZ: no
                              pi
                              HOME=/home/pi
                              iobroker
                              HOME=/home/iobroker
                              Desktop:
                              Terminal:       tty
                              *** MEMORY ***
                              Swap:            99M          0B         99M
                                       3793 M total memory
                                       1018 M used memory
                                       1540 M free memory
                                        251 M buffer memory
                                        981 M swap cache
                                         99 M total swap
                                          0 M used swap
                                         99 M free swap
                              *** FILESYSTEM ***
                              /var:
                              2.6G    /var/
                              1.3G    /var/log
                              1.2G    /var/cache/apt
                              USB-Devices by-id:
                              HINT:
                              /dev/ttyACM0
                              /usr/bin/npm            10.7.0
                              /usr/bin/npx            10.7.0
                              nodejs:
                                Version table:
                              Errors in npm tree:
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              admin:          6.17.14
                              javascript:     8.3.1
                              Adapter State
                              + instance is alive
                              Objects and States
                              Objects:        9591
                              States:         7847
                              Pending Updates: 0
                              #147
                              Userland : 32 bit
                              Beizeiten mal komplett neuaufsetzen, dann in einer reinen 64Bit-Version.
                              Boot Target: graphical.target
                              sudo systemctl set-default multi-user.target
                              Dein Dateisystem hat Einschläge.
                              by-id:
                              einer der beiden Einträge muss in den Einstellungen eingetragen werden. Musst du mal ausprobieren, ob if03 oder if00 passt.
                              Schmeiß die Quelle
                              raus.
                              S arteckA 2 Antworten Letzte Antwort
                                Userland : 32 bit
                                by-id:
                                Schmeiß die Quelle
                                raus.
                                stauber
                                #148
                                by-id:
                                Nein bleibt Orange bei beiden Einträgen
                                kann es sein das die Erweiterte Pan falsch ist? Hab ein Backupgeladen das vor 2 Tagen da ist alles noch gelaufen.
                                Schmeiß die Quelle
                                raus.
                                Wie mach ich das?
                                Vielen Dank für deine Unterstützung und deine Mühen
                                • S stauber
                                  by-id:
                                  Schmeiß die Quelle
                                  raus.
                                  Wie mach ich das?
                                  #149
                                  Wie mach ich das?
                                  Lösch die entsprechende Zeile in der Datei /etc/apt/sources.list raus.
                                    Wie mach ich das?
                                    stauber
                                    #150
                                    pi@raspberrypi:~ $ /etc/apt/sources.list
                                    -bash: /etc/apt/sources.list: Keine Berechtigung
                                    pi@raspberrypi:~ $
                                    er sagt ich habe keine Berechtigung
                                    • S stauber
                                      pi@raspberrypi:~ $
                                      #151
                                      Du verwendest ja auch kein Kommando...
                                      sudo nano /etc/apt/sources.list
                                      Speichern mit Strg-O, nano verlassen mit Strg-X
                                        Userland : 32 bit
                                        by-id:
                                        Schmeiß die Quelle
                                        raus.
                                        arteckA Offline
                                        arteckA Offline
                                        arteck
                                        #152
                                        -if00
                                        ist es immer
                                          stauber
                                          #153
                                          tut mir leid das ich mich jetzt erst melde hatte viel zu tun in der Arbeit.
                                          Heute hab ich einen Stick von Sonoff ausprobiert und siehe das es läuft wieder ich vermute das das Board einfach defekt ist.
                                          Danke nochmal für eure Hilfe
