  4. Zigbee iobroker Error while opening serialport
    6.6k
231 Beiträge 28 Kommentatoren 64.1k Aufrufe 24 Beobachtet
    @stauber
    Bitte keine Bildchen von Text.
    sudo apt update
    sudo apt install nodejs=20.15.1-1nodesource1
    stauber
    #144
    ok das hat funktioniert vielen Dank!
    jetzt mit
    iob diag
    Kannst du mir sagen wo ungefähr die by id steht?
    • S stauber
      jetzt mit
      iob diag
      #145
      @stauber
      Poste die Langfassung in Gänze.
        @stauber
        stauber
        schrieb am zuletzt editiert von stauber
        #146
        Skript v.2024-05-22
        *** BASE SYSTEM ***
           Static hostname: raspberrypi
                 Icon name: computer
          Operating System: Raspbian GNU/Linux 11 (bullseye)
                    Kernel: Linux 6.1.21-v8+
              Architecture: arm64
        Model           : Raspberry Pi 4 Model B Rev 1.2
        Docker          : false
        Virtualization  : none
        Kernel          : aarch64
        Userland        : 32 bit
        Systemuptime and Load:
         19:48:08 up 23:11,  1 user,  load average: 0.64, 0.87, 0.91
        CPU threads: 4
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** Time and Time Zones ***
                       Local time: Sun 2024-07-14 19:48:08 CEST
                   Universal time: Sun 2024-07-14 17:48:08 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        pi
        HOME=/home/pi
        GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
        iobroker
        HOME=/home/iobroker
        *** Display-Server-Setup ***
        Display-Server: false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:            3.8G        1.0G        1.5G        0.0K        1.2G        2.7G
        Swap:            99M          0B         99M
        Total:          3.9G        1.0G        1.6G
        Active iob-Instances:   22
                 3793 M total memory
                 1018 M used memory
                 1067 M active memory
                  957 M inactive memory
                 1540 M free memory
                  251 M buffer memory
                  981 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        top - 19:48:09 up 23:11,  1 user,  load average: 0.67, 0.87, 0.91
        Tasks: 174 total,   1 running, 173 sleeping,   0 stopped,   0 zombie
        %Cpu(s):  2.9 us,  2.9 sy,  0.0 ni, 94.2 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :   3793.3 total,   1540.2 free,   1019.4 used,   1233.7 buff/cache
        MiB Swap:    100.0 total,    100.0 free,      0.0 used.   2697.6 avail Mem
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** FILESYSTEM ***
        /dev/root      ext4      220G  8.2G  203G   4% /
        devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
        tmpfs          tmpfs     759M  892K  758M   1% /run
        /dev/sda1      vfat      253M   51M  202M  20% /boot
        tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
        [Sat Jul 13 20:36:26 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:5B:D6:24 vc_mem.mem_base        =0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=61bf9d36-02 rootfstype=ext4 fsck.repair=yes rootwait
        [Sat Jul 13 20:36:28 2024] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
        [Sat Jul 13 20:36:28 2024] EXT4-fs (sda2): write access will be enabled during recovery
        [Sat Jul 13 20:36:28 2024] EXT4-fs (sda2): recovery complete
        [Sat Jul 13 20:36:28 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
        [Sat Jul 13 20:36:28 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
        [Sat Jul 13 20:36:30 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
        Show mounted filesystems:
        TARGET                       SOURCE     FSTYPE     OPTIONS
        /                            /dev/sda2  ext4       rw,noatime
        |-/dev                       devtmpfs   devtmpfs   rw,relatime,size=1677960k,nr_inodes=419490,mode=755
        | |-/dev/shm                 tmpfs      tmpfs      rw,nosuid,nodev
        | |-/dev/pts                 devpts     devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
        | `-/dev/mqueue              mqueue     mqueue     rw,nosuid,nodev,noexec,relatime
        |-/proc                      proc       proc       rw,relatime
        | `-/proc/sys/fs/binfmt_misc systemd-1  autofs     rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
        |-/sys                       sysfs      sysfs      rw,nosuid,nodev,noexec,relatime
        | |-/sys/kernel/security     securityfs securityfs rw,nosuid,nodev,noexec,relatime
        | |-/sys/fs/cgroup           cgroup2    cgroup2    rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
        | |-/sys/fs/pstore           pstore     pstore     rw,nosuid,nodev,noexec,relatime
        | |-/sys/fs/bpf              bpf        bpf        rw,nosuid,nodev,noexec,relatime,mode=700
        | |-/sys/kernel/debug        debugfs    debugfs    rw,nosuid,nodev,noexec,relatime
        | |-/sys/kernel/tracing      tracefs    tracefs    rw,nosuid,nodev,noexec,relatime
        | |-/sys/fs/fuse/connections fusectl    fusectl    rw,nosuid,nodev,noexec,relatime
        | `-/sys/kernel/config       configfs   configfs   rw,nosuid,nodev,noexec,relatime
        |-/run                       tmpfs      tmpfs      rw,nosuid,nodev,size=776876k,nr_inodes=819200,mode=755
        | |-/run/lock                tmpfs      tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k
        | |-/run/rpc_pipefs          sunrpc     rpc_pipefs rw,relatime
        | `-/run/user/1000           tmpfs      tmpfs      rw,nosuid,nodev,relatime,size=388436k,nr_inodes=97109,mode=700,uid=1000,gid=1000
        `-/boot                      /dev/sda1  vfat       rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
        /var:
        2.6G    /var/
        1.3G    /var/log/journal/3e23e34d17484a28b9473f69f7d9d21c
        1.3G    /var/log
        1.2G    /var/cache/apt
        Archived and active journals take up 1.2G in the file system.
        /opt/iobroker/backups:
        121M    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        604M    /opt/iobroker/iobroker-data/
        439M    /opt/iobroker/iobroker-data/files
        138M    /opt/iobroker/iobroker-data/files/javascript.admin
        136M    /opt/iobroker/iobroker-data/backup-objects
        118M    /opt/iobroker/iobroker-data/files/javascript.admin/static
        38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
        35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
        27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
        26M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.8947f24d.js.map
        24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
        USB-Devices by-id:
        /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.18__Embed_with_CMSIS-DAP_L1100PJ1-if03
        /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.18__Embed_with_CMSIS-DAP_L1100PJ1-if00
        HINT:
        Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
        /dev/ttyACM0
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v20.15.1
        /usr/bin/node           v20.15.1
        /usr/bin/npm            10.7.0
        /usr/bin/npx            10.7.0
        /usr/bin/corepack       0.28.1
        nodejs:
          Installed: 20.15.1-1nodesource1
          Candidate: 20.15.1-1nodesource1
          Version table:
         *** 20.15.1-1nodesource1 600
                500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
             20.15.0-1nodesource1 600
             20.14.0-1nodesource1 600
             20.13.1-1nodesource1 600
             20.13.0-1nodesource1 600
             20.12.2-1nodesource1 600
             20.12.1-1nodesource1 600
             20.12.0-1nodesource1 600
             20.11.1-1nodesource1 600
             20.11.0-1nodesource1 600
             20.10.0-1nodesource1 600
             20.9.0-1nodesource1 600
             20.8.1-1nodesource1 600
             20.8.0-1nodesource1 600
             20.7.0-1nodesource1 600
             20.6.1-1nodesource1 600
             20.6.0-1nodesource1 600
             20.5.1-1nodesource1 600
             20.5.0-1nodesource1 600
             20.4.0-1nodesource1 600
             20.3.1-1nodesource1 600
             20.3.0-1nodesource1 600
             20.2.0-1nodesource1 600
             20.1.0-1nodesource1 600
             20.0.0-1nodesource1 600
             12.22.12~dfsg-1~deb11u4 500
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  5.0.19
        admin:          6.17.14
        javascript:     8.3.1
        nodejs modules from github:     0
        Adapter State
          system.adapter.alexa2.0                 : alexa2                : raspberrypi                              - disabled
        + system.adapter.awtrix-light.0           : awtrix-light          : raspberrypi                              -  enabled
        + system.adapter.awtrix-light.1           : awtrix-light          : raspberrypi                              -  enabled
          system.adapter.birthdays.0              : birthdays             : raspberrypi                              -  enabled
          system.adapter.cloud.0                  : cloud                 : raspberrypi                              - disabled
          system.adapter.denon.0                  : denon                 : raspberrypi                              - disabled
          system.adapter.devices.0                : devices               : raspberrypi                              -  enabled
        + system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled
        + system.adapter.fullcalendar.0           : fullcalendar          : raspberrypi                              -  enabled
        + system.adapter.govee-local.0            : govee-local           : raspberrypi                              -  enabled
          system.adapter.heatingcontrol.0         : heatingcontrol        : raspberrypi                              - disabled
        + system.adapter.hmip.0                   : hmip                  : raspberrypi                              -  enabled
          system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
          system.adapter.iot.0                    : iot                   : raspberrypi                              - disabled
        + system.adapter.klf200.0                 : klf200                : raspberrypi                              -  enabled
          system.adapter.mihome-vacuum.0          : mihome-vacuum         : raspberrypi                              - disabled, port: 54321
        + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
          system.adapter.nuki-extended.0          : nuki-extended         : raspberrypi                              - disabled
          system.adapter.nuki.0                   : nuki                  : raspberrypi                              - disabled
          system.adapter.places.0                 : places                : raspberrypi                              - disabled
        + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
        + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1886, bind: 0.0.0.0
        + system.adapter.statistics.0             : statistics            : raspberrypi                              -  enabled
        + system.adapter.text2command.0           : text2command          : raspberrypi                              -  enabled
        + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
        + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
          system.adapter.web.0                    : web                   : raspberrypi                              - disabled, port: 8082, bind: 0.0.0.0, run as: admin
          system.adapter.yr.0                     : yr                    : raspberrypi                              -  enabled
        + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/ttyACM0
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "admin"        : 6.17.14  , installed 6.17.14
        Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
        Adapter    "alias-manager": 1.2.6    , installed 1.2.6
        Adapter    "awtrix-light" : 1.2.0    , installed 1.2.0
        Adapter    "backitup"     : 2.11.0   , installed 2.11.0
        Adapter    "birthdays"    : 3.0.0    , installed 3.0.0
        Adapter    "denon"        : 1.15.5   , installed 1.15.5
        Adapter    "devices"      : 1.1.5    , installed 1.1.5
        Adapter    "discovery"    : 4.5.0    , installed 4.5.0
        Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
        Adapter    "fullcalendar" : 2.3.17   , installed 2.3.17
        Adapter    "govee-local"  : 0.2.6    , installed 0.2.6
        Adapter    "heatingcontrol": 2.12.8  , installed 2.12.8
        Adapter    "heos"         : 2.2.1    , installed 2.2.1
        Adapter    "hmip"         : 1.23.3   , installed 1.23.3
        Adapter    "ical"         : 1.15.0   , installed 1.15.0
        Adapter    "iot"          : 3.3.0    , installed 3.3.0
        Adapter    "javascript"   : 8.3.1    , installed 8.3.1
        Controller "js-controller": 5.0.19   , installed 5.0.19
        Adapter    "klf200"       : 1.2.0    , installed 1.2.0
        Adapter    "mihome-vacuum": 4.2.0    , installed 4.2.0
        Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
        Adapter    "nuki"         : 2.0.0    , installed 2.0.0
        Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
        Adapter    "places"       : 1.2.0    , installed 1.2.0
        Adapter    "rest-api"     : 2.0.1    , installed 2.0.1
        Adapter    "scenes"       : 3.0.4    , installed 3.0.4
        Adapter    "shelly"       : 7.0.0    , installed 7.0.0
        Adapter    "socketio"     : 6.7.0    , installed 6.7.0
        Adapter    "statistics"   : 2.4.0    , installed 2.4.0
        Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
        Adapter    "telegram"     : 3.3.2    , installed 3.3.2
        Adapter    "text2command" : 3.0.3    , installed 3.0.3
        Adapter    "trashschedule": 3.3.0    , installed 3.3.0
        Adapter    "web"          : 6.2.5    , installed 6.2.5
        Adapter    "ws"           : 2.6.1    , installed 2.6.1
        Adapter    "yr"           : 5.3.0    , installed 5.3.0
        Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
        Objects and States
        Objects:        9591
        States:         7847
        Hit:1 http://deb.debian.org/debian bullseye-proposed-updates InRelease
        Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
        Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      109        14805      522/mosquitto
        tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       703780     4069/io.shelly.0
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12860      524/sshd: /usr/sbin
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       702593     3884/iobroker.js-co
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       702596     3884/iobroker.js-co
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       701671     3902/io.admin.0
        tcp6       0      0 :::1883                 :::*                    LISTEN      109        14806      522/mosquitto
        tcp6       0      0 :::22                   :::*                    LISTEN      0          12862      524/sshd: /usr/sbin
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        15505      394/avahi-daemon: r
        udp        0      0 127.0.0.1:4002          0.0.0.0:*                           1001       705775     4736/io.govee-local
        udp        0      0 0.0.0.0:34863           0.0.0.0:*                           108        15507      394/avahi-daemon: r
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14846      734/dhcpcd
        udp6       0      0 :::5353                 :::*                                108        15506      394/avahi-daemon: r
        udp6       0      0 :::50567                :::*                                108        15508      394/avahi-daemon: r
        udp6       0      0 :::546                  :::*                                0          15746      734/dhcpcd
        2024-07-14 19:46:11.260  - info: zigbee.0 (4000) Got terminate signal TERMINATE_YOURSELF
        2024-07-14 19:46:11.381  - info: host.raspberrypi stopInstance system.adapter.zigbee.0 send kill signal
        2024-07-14 19:46:11.263  - info: zigbee.0 (4000) cleaned everything up...
        2024-07-14 19:46:11.285  - info: zigbee.0 (4000) Zigbee: disabling joining new devices.
        2024-07-14 19:46:11.529  - warn: zigbee.0 (4000) Failed to stop zigbee during startup
        2024-07-14 19:46:11.530  - info: zigbee.0 (4000) terminating
        2024-07-14 19:46:11.531  - info: zigbee.0 (4000) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2024-07-14 19:46:11.601  - info: zigbee.0 (4000) debug devices set to []
        2024-07-14 19:46:11.765  - info: zigbee.0 (4000) terminating
        2024-07-14 19:46:12.143  - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2024-07-14 19:46:12.272  - info: host.raspberrypi "system.adapter.zigbee.0" enabled
        2024-07-14 19:46:12.522  - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 5046
        2024-07-14 19:46:18.289  - info: zigbee.0 (5046) starting. Version 1.10.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.15.1, js-controller: 5.0.19
        2024-07-14 19:46:18.399  - info: zigbee.0 (5046) delete old Backup files. keep only last 10
        2024-07-14 19:46:18.402  - info: zigbee.0 (5046) Starting Zigbee  npm ...
        2024-07-14 19:46:18.831  - info: zigbee.0 (5046) Installed Version: iobroker.zigbee@1.10.3
        2024-07-14 19:46:39.534  - error: zigbee.0 (5046) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
        2024-07-14 19:46:39.535  - error: zigbee.0 (5046) Failed to start Zigbee
        2024-07-14 19:46:39.536  - error: zigbee.0 (5046) Error herdsman start
        2024-07-14 19:46:49.540  - info: zigbee.0 (5046) Try to reconnect. 1 attempts left
        2024-07-14 19:46:49.541  - info: zigbee.0 (5046) Starting Zigbee  npm ...
        2024-07-14 19:46:49.555  - info: zigbee.0 (5046) Installed Version: iobroker.zigbee@1.10.3
        2024-07-14 19:46:49.827  - error: zigbee.0 (5046) Starting zigbee-herdsman problem : "Error Resource temporarily unavailable Cannot lock port"
        2024-07-14 19:46:49.828  - error: zigbee.0 (5046) Failed to start Zigbee
        2024-07-14 19:46:49.829  - error: zigbee.0 (5046) Error herdsman start
        • S stauber
          Skript v.2024-05-22
          *** BASE SYSTEM ***
                   Icon name: computer
                Architecture: arm64
          Docker          : false
          Kernel          : aarch64
          Userland        : 32 bit
          CPU threads: 4
          Current issues:
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          pi
          HOME=/home/pi
          iobroker
          HOME=/home/iobroker
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Swap:            99M          0B         99M
                   3793 M total memory
                   1018 M used memory
                   1540 M free memory
                    251 M buffer memory
                    981 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          *** FILESYSTEM ***
          /var:
          2.6G    /var/
          1.3G    /var/log
          1.2G    /var/cache/apt
          USB-Devices by-id:
          HINT:
          /dev/ttyACM0
          /usr/bin/npm            10.7.0
          /usr/bin/npx            10.7.0
          nodejs:
            Version table:
          Errors in npm tree:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin:          6.17.14
          javascript:     8.3.1
          Adapter State
          + instance is alive
          Objects and States
          Objects:        9591
          States:         7847
          Pending Updates: 0
          #147
          @stauber sagte in Zigbee iobroker Error while opening serialport:
          Userland : 32 bit
          Beizeiten mal komplett neuaufsetzen, dann in einer reinen 64Bit-Version.
          Boot Target: graphical.target
          sudo systemctl set-default multi-user.target
          Dein Dateisystem hat Einschläge.
          by-id:
          einer der beiden Einträge muss in den Einstellungen eingetragen werden. Musst du mal ausprobieren, ob if03 oder if00 passt.
          Schmeiß die Quelle
          raus.
          S arteckA 2 Antworten Letzte Antwort
            Userland : 32 bit
            by-id:
            Schmeiß die Quelle
            raus.
            stauber
            #148
            by-id:
            Nein bleibt Orange bei beiden Einträgen
            kann es sein das die Erweiterte Pan falsch ist? Hab ein Backupgeladen das vor 2 Tagen da ist alles noch gelaufen.
            Schmeiß die Quelle
            raus.
            Wie mach ich das?
            Vielen Dank für deine Unterstützung und deine Mühen
            • S stauber
              by-id:
              Schmeiß die Quelle
              raus.
              Wie mach ich das?
              #149
              Wie mach ich das?
              Lösch die entsprechende Zeile in der Datei /etc/apt/sources.list raus.
                Wie mach ich das?
                stauber
                #150
                @thomas-braun sagte in Zigbee iobroker Error while opening serialport:
                pi@raspberrypi:~ $ /etc/apt/sources.list
                -bash: /etc/apt/sources.list: Keine Berechtigung
                pi@raspberrypi:~ $
                er sagt ich habe keine Berechtigung
                • S stauber
                  pi@raspberrypi:~ $
                  #151
                  Du verwendest ja auch kein Kommando...
                  sudo nano /etc/apt/sources.list
                  Speichern mit Strg-O, nano verlassen mit Strg-X
                    Userland : 32 bit
                    by-id:
                    Schmeiß die Quelle
                    raus.
                    arteckA Offline
                    arteckA Offline
                    arteck
                    #152
                    -if00
                    ist es immer
                      stauber
                      #153
                      tut mir leid das ich mich jetzt erst melde hatte viel zu tun in der Arbeit.
                      Heute hab ich einen Stick von Sonoff ausprobiert und siehe das es läuft wieder ich vermute das das Board einfach defekt ist.
                      Danke nochmal für eure Hilfe
                        searcher57
                        #154
                        @thomas-braun said in Zigbee iobroker Error while opening serialport:
                        Hallo Thomas,
                        jetzt bin ich am Ende! Nachdem ich Probleme mit dem Smartmeter-Adapter (Stromwerte), RPI2 Adapter (Gaswerte) kommt jetzt auch noch der Zigbee Adapter hinzu. Ich habe alles rauf und runter mit einem Raspi 5 8GB probiert. Danach habe ich den Raspi 4 8GB getestet. Auch da bekomme ich den Adapter nicht ans laufen.
                        Hier das Log des Raspi 5:
                        zigbee.0
                        	2024-09-26 15:45:02.137	error	Error herdsman start
                        zigbee.0
                        	2024-09-26 15:45:02.137	error	Failed to start Zigbee
                        zigbee.0
                        	2024-09-26 15:45:02.136	error	Starting zigbee-herdsman problem : "Error Resource temporarily unavailable Cannot lock port"
                        zigbee.0
                        	2024-09-26 15:45:02.061	info	Installed Version: iobroker.zigbee@1.10.3
                        zigbee.0
                        	2024-09-26 15:45:02.054	info	Starting Zigbee npm ...
                        zigbee.0
                        	2024-09-26 15:45:02.053	info	Try to reconnect. 1 attempts left
                        zigbee.0
                        	2024-09-26 15:44:52.052	error	Error herdsman start
                        zigbee.0
                        	2024-09-26 15:44:52.052	error	Failed to start Zigbee
                        zigbee.0
                        	2024-09-26 15:44:52.051	error	Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
                        zigbee.0
                        	2024-09-26 15:44:51.664	info	Installed Version: iobroker.zigbee@1.10.3
                        zigbee.0
                        	2024-09-26 15:44:51.465	info	Starting Zigbee npm ...
                        zigbee.0
                        	2024-09-26 15:44:51.464	info	delete old Backup files. keep only last 10
                        zigbee.0
                        	2024-09-26 15:44:51.433	info	starting. Version 1.10.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.17.0, js-controller: 6.0.11
                        zigbee.0
                        	2024-09-26 15:43:06.087	info	terminating
                        zigbee.0
                        	2024-09-26 15:43:05.820	info	Terminated (NO_ERROR): Without reason
                        zigbee.0
                        	2024-09-26 15:43:05.819	info	terminating
                        zigbee.0
                        	2024-09-26 15:43:05.818	info	debug devices set to []
                        zigbee.0
                        	2024-09-26 15:43:05.815	info	Got terminate signal TERMINATE_YOURSELF
                        zigbee.0
                        	2024-09-26 15:43:05.808	warn	Failed to stop zigbee during startup
                        zigbee.0
                        zigbee.0
                        zigbee.0
                        zigbee.0
                        zigbee.0
                        iob diag:
                        Skript v.2024-05-22
                        *** BASE SYSTEM ***
                         Static hostname: Raspi58GB
                               Icon name: computer
                                  Kernel: Linux 6.6.47+rpt-rpi-2712
                            Architecture: arm64
                        Model           : Raspberry Pi 5 Model B Rev 1.0
                        Docker          : false
                        Kernel          : aarch64
                        Userland        : 64 bit
                         15:47:28 up 4 min,  2 users,  load average: 0.37, 0.65, 0.33
                        CPU threads: 4
                        Current issues:
                                       Local time: Thu 2024-09-26 15:47:28 CEST
                                   Universal time: Thu 2024-09-26 13:47:28 UTC
                                         RTC time: Thu 2024-09-26 13:47:28
                                      NTP service: active
                                  RTC in local TZ: no
                        pi
                        HOME=/home/pi
                        GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                        iobroker
                        HOME=/home/iobroker
                        Desktop:
                        Terminal:       tty
                        Boot Target:    multi-user.target
                        *** MEMORY ***
                        Mem:            8.4G        2.1G        5.6G        5.6M        792M        6.3G
                        Swap:           209M          0B        209M
                        Total:          8.7G        2.1G        5.8G
                        Active iob-Instances:   25
                                 8052 M total memory
                                 2020 M used memory
                                 2032 M active memory
                                  401 M inactive memory
                                 5370 M free memory
                                   61 M buffer memory
                                  693 M swap cache
                                  199 M total swap
                                    0 M used swap
                                  199 M free swap
                        top - 15:47:28 up 4 min,  2 users,  load average: 0.37, 0.65, 0.33
                        Tasks: 197 total,   2 running, 195 sleeping,   0 stopped,   0 zombie
                        %Cpu(s): 40.0 us,  0.0 sy,  0.0 ni, 40.0 id, 20.0 wa,  0.0 hi,  0.0 si,  0.0 st
                        MiB Mem :   8052.3 total,   5367.8 free,   2023.6 used,    755.4 buff/cache
                        MiB Swap:    200.0 total,    200.0 free,      0.0 used.   6028.8 avail Mem
                        *** FILESYSTEM ***
                        udev           devtmpfs  3.8G     0  3.8G   0% /dev
                        tmpfs          tmpfs     806M  5.3M  800M   1% /run
                        /dev/mmcblk0p2 ext4       59G   14G   42G  25% /
                        tmpfs          tmpfs     4.0G     0  4.0G   0% /dev/shm
                        tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
                        /dev/sda1      exfat      29G  379M   29G   2% /mnt/usb0
                        /dev/mmcblk0p1 vfat      510M   64M  447M  13% /boot/firmware
                        tmpfs          tmpfs     806M     0  806M   0% /run/user/1000
                        [Thu Sep 26 15:43:19 2024] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe  smsc95xx.macaddr=2C:CF:67:2F:A6:31 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=4e8600df-02 rootfstype=ext4 fsck.repair=yes rootwait
                        [Thu Sep 26 15:43:20 2024] EXT4-fs (mmcblk0p2): mounted filesystem 93c89e92-8f2e-4522-ad32-68faed883d2f ro with ordered data mode. Quota mode: none.
                        [Thu Sep 26 15:43:22 2024] EXT4-fs (mmcblk0p2): re-mounted 93c89e92-8f2e-4522-ad32-68faed883d2f r/w. Quota mode: none.
                        /                                                       /dev/mmcblk0p2 ext4        rw,noatime
                        | `-/sys/fs/fuse/connections                            fusectl        fusectl     rw,nosuid,nodev,noexec,relatime
                        | `-/proc/sys/fs/binfmt_misc                            systemd-1      autofs      rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=4766
                        |   `-/proc/sys/fs/binfmt_misc                          binfmt_misc    binfmt_misc rw,nosuid,nodev,noexec,relatime
                        |-/dev                                                  udev           devtmpfs    rw,nosuid,relatime,size=3950672k,nr_inodes=246917,mode=755
                        |-/run                                                  tmpfs          tmpfs       rw,nosuid,nodev,noexec,relatime,size=824560k,mode=755
                        | |-/run/credentials/systemd-sysctl.service             ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                        | |-/run/credentials/systemd-sysusers.service           ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                        | |-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                        | |-/run/credentials/systemd-tmpfiles-setup.service     ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                        | `-/run/user/1000                                      tmpfs          tmpfs       rw,nosuid,nodev,relatime,size=824544k,nr_inodes=206136,mode=700,uid=1000,gid=1000
                        |-/mnt/usb0                                             /dev/sda1      exfat       rw,relatime,fmask=0000,dmask=0000,allow_utime=0022,iocharset=utf8,errors=remount-ro
                        `-/boot/firmware                                        /dev/mmcblk0p1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                        /var:
                        6.4G    /var/
                        5.3G    /var/lib
                        5.1G    /var/lib/influxdb/engine/data
                        Archived and active journals take up 634.8M in the file system.
                        45M     /opt/iobroker/backups/
                        1.2G    /opt/iobroker/iobroker-data/
                        1.1G    /opt/iobroker/iobroker-data/files
                        441M    /opt/iobroker/iobroker-data/files/javascript.admin
                        409M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                        408M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                        26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
                        26M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
                        USB-Devices by-id:
                        /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0867d5d6b78ded11959b02f6b86ce6f8-if00-port0
                        Your zigbee.0 COM-Port is matching 'by-id'. Very good!
                        /usr/bin/nodejs         v20.17.0
                        /usr/bin/node           v20.17.0
                        /usr/bin/npm            10.8.2
                        /usr/bin/npx            10.8.2
                        /usr/bin/corepack       0.29.3
                        nodejs:
                          Installed: 20.17.0-1nodesource1
                          Candidate: 20.17.0-1nodesource1
                          Version table:
                         *** 20.17.0-1nodesource1 1001
                                500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                             20.16.0-1nodesource1 1001
                             20.15.1-1nodesource1 1001
                             20.15.0-1nodesource1 1001
                             20.14.0-1nodesource1 1001
                             20.13.1-1nodesource1 1001
                             20.13.0-1nodesource1 1001
                             20.12.2-1nodesource1 1001
                             20.12.1-1nodesource1 1001
                             20.12.0-1nodesource1 1001
                             20.11.1-1nodesource1 1001
                             20.11.0-1nodesource1 1001
                             20.10.0-1nodesource1 1001
                             20.9.0-1nodesource1 1001
                             20.8.1-1nodesource1 1001
                             20.8.0-1nodesource1 1001
                             20.7.0-1nodesource1 1001
                             20.6.1-1nodesource1 1001
                             20.6.0-1nodesource1 1001
                             20.5.1-1nodesource1 1001
                             20.5.0-1nodesource1 1001
                             20.4.0-1nodesource1 1001
                             20.3.1-1nodesource1 1001
                             20.3.0-1nodesource1 1001
                             20.2.0-1nodesource1 1001
                             20.1.0-1nodesource1 1001
                             20.0.0-1nodesource1 1001
                             18.19.0+dfsg-6~deb12u2 500
                                500 http://deb.debian.org/debian bookworm/main arm64 Packages
                             18.19.0+dfsg-6~deb12u1 500
                                500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
                        Errors in npm tree:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        admin:          7.1.2
                        javascript:     8.7.6
                        Adapter State
                        + system.adapter.admin.0                  : admin                 : Raspi58GB                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                        + system.adapter.alexa2.0                 : alexa2                : Raspi58GB                                -  enabled
                          system.adapter.alias-manager.0          : alias-manager         : Raspi58GB                                - disabled
                        + system.adapter.awtrix-light.0           : awtrix-light          : Raspi58GB                                -  enabled
                        + system.adapter.backitup.0               : backitup              : Raspi58GB                                -  enabled
                        + system.adapter.broadlink2.0             : broadlink2            : Raspi58GB                                -  enabled
                          system.adapter.devices.0                : devices               : Raspi58GB                                - disabled
                          system.adapter.discovery.0              : discovery             : Raspi58GB                                - disabled
                        + system.adapter.doorbird.0               : doorbird              : Raspi58GB                                -  enabled
                        + system.adapter.echarts.0                : echarts               : Raspi58GB                                -  enabled
                        + system.adapter.followthesun.0           : followthesun          : Raspi58GB                                -  enabled
                        + system.adapter.frontier_silicon.0       : frontier_silicon      : Raspi58GB                                -  enabled
                          system.adapter.frontier_silicon.1       : frontier_silicon      : Raspi58GB                                - disabled
                          system.adapter.frontier_silicon.2       : frontier_silicon      : Raspi58GB                                - disabled
                          system.adapter.frontier_silicon.3       : frontier_silicon      : Raspi58GB                                - disabled
                        + system.adapter.hm-rega.0                : hm-rega               : Raspi58GB                                -  enabled
                        + system.adapter.hm-rpc.0                 : hm-rpc                : Raspi58GB                                -  enabled, port: 0
                        + system.adapter.hm-rpc.1                 : hm-rpc                : Raspi58GB                                -  enabled, port: 0
                        + system.adapter.influxdb.0               : influxdb              : Raspi58GB                                -  enabled, port: 8086
                        + system.adapter.iot.0                    : iot                   : Raspi58GB                                -  enabled
                        + system.adapter.javascript.0             : javascript            : Raspi58GB                                -  enabled
                        + system.adapter.mqtt.0                   : mqtt                  : Raspi58GB                                -  enabled, port: 1883, bind: 0.0.0.0
                        + system.adapter.rpi2.0                   : rpi2                  : Raspi58GB                                -  enabled
                        + system.adapter.shelly.0                 : shelly                : Raspi58GB                                -  enabled, port: 1883, bind: 0.0.0.0
                        + system.adapter.simple-api.0             : simple-api            : Raspi58GB                                -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                          system.adapter.smartmeter.0             : smartmeter            : Raspi58GB                                - disabled
                        + system.adapter.tankerkoenig.0           : tankerkoenig          : Raspi58GB                                -  enabled
                        + system.adapter.telegram.0               : telegram              : Raspi58GB                                -  enabled, port: 8443, bind: 0.0.0.0
                        + system.adapter.vis-2.0                  : vis-2                 : Raspi58GB                                -  enabled
                          system.adapter.vis.0                    : vis                   : Raspi58GB                                -  enabled
                        + system.adapter.web.0                    : web                   : Raspi58GB                                -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                          system.adapter.yr.0                     : yr                    : Raspi58GB                                -  enabled
                        + system.adapter.zigbee.0                 : zigbee                : Raspi58GB                                -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0867d5d6b78ded11959b02f6b86ce6f8-if00-port0
                        + instance is alive
                        Upgrade policy: none
                        Adapter    "admin"        : 7.1.2    , installed 7.1.2
                        Adapter    "awtrix-light" : 1.3.0    , installed 1.3.0
                        Adapter    "backitup"     : 3.0.22   , installed 3.0.22
                        Adapter    "broadlink2"   : 2.3.0    , installed 2.3.0
                        Adapter    "doorbird"     : 1.7.0    , installed 1.7.0
                        Adapter    "echarts"      : 1.9.2    , installed 1.9.2
                        Adapter    "followthesun" : 0.5.1    , installed 0.5.1
                        Adapter    "frontier_silicon": 0.3.0 , installed 0.3.0
                        Adapter    "hm-rega"      : 5.0.0    , installed 5.0.0
                        Adapter    "hm-rpc"       : 1.17.0   , installed 1.17.0
                        Adapter    "javascript"   : 8.7.6    , installed 8.7.6
                        Controller "js-controller": 6.0.11   , installed 6.0.11
                        Adapter    "rpi2"         : 1.3.2    , installed 2.0.0
                        Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
                        Adapter    "telegram"     : 3.9.0    , installed 3.9.0
                        Adapter    "vis-2"        : 2.9.32   , installed 2.9.32
                        Objects and States
                        Objects:        11825
                        States:         9324
                        Hit:1 http://archive.raspberrypi.com/debian bookworm InRelease
                        Hit:2 http://deb.debian.org/debian bookworm InRelease
                        Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
                        Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
                        Hit:5 http://deb.debian.org/debian bullseye-proposed-updates InRelease
                        Hit:6 https://repos.influxdata.com/debian stable InRelease
                        Hit:7 https://deb.nodesource.com/node_20.x nodistro InRelease
                        Pending Updates: 0
                        tcp        0      0 192.168.178.57:2001     0.0.0.0:*               LISTEN      1001       6795       1179/io.hm-rpc.1
                        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      106        7371       814/mosquitto
                        tcp        0      0 192.168.178.57:42010    0.0.0.0:*               LISTEN      1001       6776       1164/io.hm-rpc.0
                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          5765       829/sshd: /usr/sbin
                        tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       7487       946/iobroker.js-con
                        tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       7492       946/iobroker.js-con
                        tcp        0      0 192.168.178.57:8100     0.0.0.0:*               LISTEN      1001       8840       1313/io.doorbird.0
                        tcp6       0      0 :::1883                 :::*                    LISTEN      106        7372       814/mosquitto
                        tcp6       0      0 :::22                   :::*                    LISTEN      0          5767       829/sshd: /usr/sbin
                        tcp6       0      0 :::8087                 :::*                    LISTEN      1001       9544       1359/io.simple-api.
                        tcp6       0      0 :::8086                 :::*                    LISTEN      999        8359       884/influxd
                        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       9610       1421/io.web.0
                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       7530       965/io.admin.0
                        udp        0      0 0.0.0.0:37934           0.0.0.0:*                           1001       6727       1119/io.broadlink2.
                        udp        0      0 0.0.0.0:50257           0.0.0.0:*                           1001       7729       1119/io.broadlink2.
                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        5702       671/avahi-daemon: r
                        udp        0      0 0.0.0.0:38186           0.0.0.0:*                           1001       6721       1119/io.broadlink2.
                        udp        0      0 0.0.0.0:46537           0.0.0.0:*                           1001       6726       1119/io.broadlink2.
                        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       7818       1252/io.shelly.0
                        udp        0      0 0.0.0.0:55117           0.0.0.0:*                           1001       6723       1119/io.broadlink2.
                        udp        0      0 0.0.0.0:39374           0.0.0.0:*                           104        5704       671/avahi-daemon: r
                        udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       6717       1119/io.broadlink2.
                        udp        0      0 0.0.0.0:39813           0.0.0.0:*                           1001       6722       1119/io.broadlink2.
                        udp        0      0 0.0.0.0:44924           0.0.0.0:*                           1001       6725       1119/io.broadlink2.
                        udp        0      0 0.0.0.0:57524           0.0.0.0:*                           1001       6720       1119/io.broadlink2.
                        udp        0      0 0.0.0.0:53786           0.0.0.0:*                           1001       6724       1119/io.broadlink2.
                        udp        0      0 0.0.0.0:58130           0.0.0.0:*                           1001       6729       1119/io.broadlink2.
                        udp        0      0 0.0.0.0:45874           0.0.0.0:*                           1001       6728       1119/io.broadlink2.
                        udp6       0      0 :::5353                 :::*                                104        5703       671/avahi-daemon: r
                        udp6       0      0 :::59656                :::*                                104        5705       671/avahi-daemon: r
                        2024-09-26 15:45:09.621  - info: simple-api.0 (1359) Allow states only when user is owner: false
                        2024-09-26 15:45:09.628  - info: simple-api.0 (1359) http server listening on port 8087
                        2024-09-26 15:45:12.658  - info: host.Raspi58GB instance system.adapter.tankerkoenig.0 in version "3.4.0" started with pid 1374
                        2024-09-26 15:45:13.651  - info: tankerkoenig.0 (1374) starting. Version 3.4.0 in /opt/iobroker/node_modules/iobroker.tankerkoenig, node: v20.17.0, js-controller: 6.0.11
                        2024-09-26 15:45:13.670  - info: tankerkoenig.0 (1374) Adapter is already in daemon mode
                        2024-09-26 15:45:13.671  - info: tankerkoenig.0 (1374) Sync time set to 30 minutes or 1800000 ms
                        2024-09-26 15:45:16.680  - info: host.Raspi58GB instance system.adapter.vis-2.0 in version "2.9.32" started with pid 1389
                        2024-09-26 15:45:17.906  - info: vis-2.0 (1389) starting. Version 2.9.32 in /opt/iobroker/node_modules/iobroker.vis-2, node: v20.17.0, js-controller: 6.0.11
                        2024-09-26 15:45:18.068  - error: vis-2.0 (1389) License is invalid! Nothing updated. Error: serial number (UUID) in license is for other device
                        2024-09-26 15:45:18.153  - info: tankerkoenig.0 (1374) Start first request
                        2024-09-26 15:45:21.336  - info: yr.0 (1267) Data updated.
                        2024-09-26 15:45:21.337  - info: yr.0 (1267) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                        2024-09-26 15:45:21.523  - info: vis.0 (1405) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.vis, node: v20.17.0, js-controller: 6.0.11
                        2024-09-26 15:45:21.906  - info: host.Raspi58GB instance system.adapter.yr.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                        2024-09-26 15:45:22.663  - info: vis.0 (1405) Terminated (NO_ERROR): Without reason
                        2024-09-26 15:45:23.198  - info: host.Raspi58GB instance system.adapter.vis.0 terminated while should be started once
                        2024-09-26 15:45:24.723  - info: host.Raspi58GB instance system.adapter.web.0 in version "6.2.5" started with pid 1421
                        2024-09-26 15:45:25.655  - info: web.0 (1421) starting. Version 6.2.5 in /opt/iobroker/node_modules/iobroker.web, node: v20.17.0, js-controller: 6.0.11
                        2024-09-26 15:45:25.777  - info: web.0 (1421) socket.io server listening on port 8082
                        2024-09-26 15:45:25.779  - info: web.0 (1421) http server listening on port 8082
                        2024-09-26 15:45:28.675  - info: host.Raspi58GB instance system.adapter.followthesun.0 in version "0.5.1" started with pid 1436
                        2024-09-26 15:45:29.606  - info: followthesun.0 (1436) starting. Version 0.5.1 in /opt/iobroker/node_modules/iobroker.followthesun, node: v20.17.0, js-controller: 6.0.11
                        2024-09-26 15:45:29.615  - info: followthesun.0 (1436) Started with JSON-Explorer version 0.1.16
                        2024-09-26 15:45:29.615  - info: followthesun.0 (1436) Sun position calculation will be done every 60 seconds
                        2024-09-26 15:45:29.616  - info: followthesun.0 (1436) Daily sun parameter calculation scheduled for 00:00:39
                        die Einstellungen des Adapters:
                        Erkennst Du einen Fehler? Ich möchte doch wenigstens die Zigbee-Aktoren wieder nutzen.
                        Meister MopperM Thomas BraunT 2 Antworten Letzte Antwort
                        • S searcher57
                          Hallo Thomas,
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          iob diag:
                          Skript v.2024-05-22
                          *** BASE SYSTEM ***
                                 Icon name: computer
                              Architecture: arm64
                          Docker          : false
                          Kernel          : aarch64
                          Userland        : 64 bit
                          CPU threads: 4
                          Current issues:
                                        NTP service: active
                                    RTC in local TZ: no
                          pi
                          HOME=/home/pi
                          iobroker
                          HOME=/home/iobroker
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                          Swap:           209M          0B        209M
                                   8052 M total memory
                                   2020 M used memory
                                   5370 M free memory
                                     61 M buffer memory
                                    693 M swap cache
                                    199 M total swap
                                      0 M used swap
                                    199 M free swap
                          *** FILESYSTEM ***
                          /var:
                          6.4G    /var/
                          5.3G    /var/lib
                          USB-Devices by-id:
                          /usr/bin/npm            10.8.2
                          /usr/bin/npx            10.8.2
                          nodejs:
                            Version table:
                          Errors in npm tree:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          admin:          7.1.2
                          javascript:     8.7.6
                          Adapter State
                          + instance is alive
                          Objects and States
                          Objects:        11825
                          States:         9324
                          Pending Updates: 0
                          Meister MopperM Online
                          Meister Mopper
                          #155
                          @searcher57
                          Läuft da vielleicht ein ModemManager? Der hat hier auch schon den Start verhindert.
                          systemctl status ModemManager.service
                          Proxmox und HA ...
                            @searcher57
                            searcher57
                            #156
                            @meister-mopper said in Zigbee iobroker Error while opening serialport:
                            @searcher57
                            Was ist das? Und wie kann ich den deaktivieren?
                            • S searcher57
                              Hallo Thomas,
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              iob diag:
                              Skript v.2024-05-22
                              *** BASE SYSTEM ***
                                     Icon name: computer
                                  Architecture: arm64
                              Docker          : false
                              Kernel          : aarch64
                              Userland        : 64 bit
                              CPU threads: 4
                              Current issues:
                                            NTP service: active
                                        RTC in local TZ: no
                              pi
                              HOME=/home/pi
                              iobroker
                              HOME=/home/iobroker
                              Desktop:
                              Terminal:       tty
                              *** MEMORY ***
                              Swap:           209M          0B        209M
                                       8052 M total memory
                                       2020 M used memory
                                       5370 M free memory
                                         61 M buffer memory
                                        693 M swap cache
                                        199 M total swap
                                          0 M used swap
                                        199 M free swap
                              *** FILESYSTEM ***
                              /var:
                              6.4G    /var/
                              5.3G    /var/lib
                              USB-Devices by-id:
                              /usr/bin/npm            10.8.2
                              /usr/bin/npx            10.8.2
                              nodejs:
                                Version table:
                              Errors in npm tree:
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              admin:          7.1.2
                              javascript:     8.7.6
                              Adapter State
                              + instance is alive
                              Objects and States
                              Objects:        11825
                              States:         9324
                              Pending Updates: 0
                              #157
                              @searcher57
                              Die extended PAN-ID ist mit Sicherheit falsch, zumindest ist DDDDDDDDDDDDDDDDDDD ungünstig.
                              S 2 Antworten Letzte Antwort
                                @searcher57
                                searcher57
                                #158
                                @searcher57
                                Es kann sein, dass ich bei der Ersteinrichtung da etwas verändert habe. Kannst Du mir sagen, wie ich die abfrage?
                                  @searcher57
                                  searcher57
                                  #159
                                  @searcher57
                                  Ich habe sie jetzt in DDADDDDDDD2DFDDD geändert.
                                  • S searcher57
                                    @searcher57
                                    #160
                                    @searcher57 sagte in Zigbee iobroker Error while opening serialport:
                                    Im nv_backup stehen die alten Werte drin, soweit ich weiß.
                                    • S searcher57
                                      @searcher57
                                      Meister Mopper
                                      #161
                                      @searcher57
                                      Zeig erstmal das Ergebnis der Abfrage.
                                      Proxmox und HA ...
                                        searcher57
                                        #162
                                        Entschuldige das verstehe ich nicht.
                                        • S searcher57
                                          #163
                                          @searcher57
                                          Hab den exakten Pfad nicht parat. Schau mal in /opt/iobroker/iobroker-data/zigbee oder so ähnlich.
