  4. Zigbee iobroker Error while opening serialport
    6.6k
231 Beiträge 28 Kommentatoren 64.2k Aufrufe 24 Beobachtet
    @stauber
    Poste die Langfassung in Gänze.
    stauber
    schrieb am zuletzt editiert von stauber
    #146
    Skript v.2024-05-22
    *** BASE SYSTEM ***
       Static hostname: raspberrypi
             Icon name: computer
      Operating System: Raspbian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    Model           : Raspberry Pi 4 Model B Rev 1.2
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 32 bit
    Systemuptime and Load:
     19:48:08 up 23:11,  1 user,  load average: 0.64, 0.87, 0.91
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Sun 2024-07-14 19:48:08 CEST
               Universal time: Sun 2024-07-14 17:48:08 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    pi
    HOME=/home/pi
    GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** Display-Server-Setup ***
    Display-Server: false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            3.8G        1.0G        1.5G        0.0K        1.2G        2.7G
    Swap:            99M          0B         99M
    Total:          3.9G        1.0G        1.6G
    Active iob-Instances:   22
             3793 M total memory
             1018 M used memory
             1067 M active memory
              957 M inactive memory
             1540 M free memory
              251 M buffer memory
              981 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    top - 19:48:09 up 23:11,  1 user,  load average: 0.67, 0.87, 0.91
    Tasks: 174 total,   1 running, 173 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  2.9 us,  2.9 sy,  0.0 ni, 94.2 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   3793.3 total,   1540.2 free,   1019.4 used,   1233.7 buff/cache
    MiB Swap:    100.0 total,    100.0 free,      0.0 used.   2697.6 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    /dev/root      ext4      220G  8.2G  203G   4% /
    devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
    tmpfs          tmpfs     759M  892K  758M   1% /run
    /dev/sda1      vfat      253M   51M  202M  20% /boot
    tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
    [Sat Jul 13 20:36:26 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:5B:D6:24 vc_mem.mem_base        =0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=61bf9d36-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Sat Jul 13 20:36:28 2024] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
    [Sat Jul 13 20:36:28 2024] EXT4-fs (sda2): write access will be enabled during recovery
    [Sat Jul 13 20:36:28 2024] EXT4-fs (sda2): recovery complete
    [Sat Jul 13 20:36:28 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
    [Sat Jul 13 20:36:28 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [Sat Jul 13 20:36:30 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
    Show mounted filesystems:
    TARGET                       SOURCE     FSTYPE     OPTIONS
    /                            /dev/sda2  ext4       rw,noatime
    |-/dev                       devtmpfs   devtmpfs   rw,relatime,size=1677960k,nr_inodes=419490,mode=755
    | |-/dev/shm                 tmpfs      tmpfs      rw,nosuid,nodev
    | |-/dev/pts                 devpts     devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
    | `-/dev/mqueue              mqueue     mqueue     rw,nosuid,nodev,noexec,relatime
    |-/proc                      proc       proc       rw,relatime
    | `-/proc/sys/fs/binfmt_misc systemd-1  autofs     rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
    |-/sys                       sysfs      sysfs      rw,nosuid,nodev,noexec,relatime
    | |-/sys/kernel/security     securityfs securityfs rw,nosuid,nodev,noexec,relatime
    | |-/sys/fs/cgroup           cgroup2    cgroup2    rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
    | |-/sys/fs/pstore           pstore     pstore     rw,nosuid,nodev,noexec,relatime
    | |-/sys/fs/bpf              bpf        bpf        rw,nosuid,nodev,noexec,relatime,mode=700
    | |-/sys/kernel/debug        debugfs    debugfs    rw,nosuid,nodev,noexec,relatime
    | |-/sys/kernel/tracing      tracefs    tracefs    rw,nosuid,nodev,noexec,relatime
    | |-/sys/fs/fuse/connections fusectl    fusectl    rw,nosuid,nodev,noexec,relatime
    | `-/sys/kernel/config       configfs   configfs   rw,nosuid,nodev,noexec,relatime
    |-/run                       tmpfs      tmpfs      rw,nosuid,nodev,size=776876k,nr_inodes=819200,mode=755
    | |-/run/lock                tmpfs      tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k
    | |-/run/rpc_pipefs          sunrpc     rpc_pipefs rw,relatime
    | `-/run/user/1000           tmpfs      tmpfs      rw,nosuid,nodev,relatime,size=388436k,nr_inodes=97109,mode=700,uid=1000,gid=1000
    `-/boot                      /dev/sda1  vfat       rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
    /var:
    2.6G    /var/
    1.3G    /var/log/journal/3e23e34d17484a28b9473f69f7d9d21c
    1.3G    /var/log
    1.2G    /var/cache/apt
    Archived and active journals take up 1.2G in the file system.
    /opt/iobroker/backups:
    121M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    604M    /opt/iobroker/iobroker-data/
    439M    /opt/iobroker/iobroker-data/files
    138M    /opt/iobroker/iobroker-data/files/javascript.admin
    136M    /opt/iobroker/iobroker-data/backup-objects
    118M    /opt/iobroker/iobroker-data/files/javascript.admin/static
    38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
    26M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.8947f24d.js.map
    24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.18__Embed_with_CMSIS-DAP_L1100PJ1-if03
    /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.18__Embed_with_CMSIS-DAP_L1100PJ1-if00
    HINT:
    Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
    /dev/ttyACM0
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.15.1
    /usr/bin/node           v20.15.1
    /usr/bin/npm            10.7.0
    /usr/bin/npx            10.7.0
    /usr/bin/corepack       0.28.1
    nodejs:
      Installed: 20.15.1-1nodesource1
      Candidate: 20.15.1-1nodesource1
      Version table:
     *** 20.15.1-1nodesource1 600
            500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
         20.15.0-1nodesource1 600
         20.14.0-1nodesource1 600
         20.13.1-1nodesource1 600
         20.13.0-1nodesource1 600
         20.12.2-1nodesource1 600
         20.12.1-1nodesource1 600
         20.12.0-1nodesource1 600
         20.11.1-1nodesource1 600
         20.11.0-1nodesource1 600
         20.10.0-1nodesource1 600
         20.9.0-1nodesource1 600
         20.8.1-1nodesource1 600
         20.8.0-1nodesource1 600
         20.7.0-1nodesource1 600
         20.6.1-1nodesource1 600
         20.6.0-1nodesource1 600
         20.5.1-1nodesource1 600
         20.5.0-1nodesource1 600
         20.4.0-1nodesource1 600
         20.3.1-1nodesource1 600
         20.3.0-1nodesource1 600
         20.2.0-1nodesource1 600
         20.1.0-1nodesource1 600
         20.0.0-1nodesource1 600
         12.22.12~dfsg-1~deb11u4 500
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.19
    admin:          6.17.14
    javascript:     8.3.1
    nodejs modules from github:     0
    Adapter State
      system.adapter.alexa2.0                 : alexa2                : raspberrypi                              - disabled
    + system.adapter.awtrix-light.0           : awtrix-light          : raspberrypi                              -  enabled
    + system.adapter.awtrix-light.1           : awtrix-light          : raspberrypi                              -  enabled
      system.adapter.birthdays.0              : birthdays             : raspberrypi                              -  enabled
      system.adapter.cloud.0                  : cloud                 : raspberrypi                              - disabled
      system.adapter.denon.0                  : denon                 : raspberrypi                              - disabled
      system.adapter.devices.0                : devices               : raspberrypi                              -  enabled
    + system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled
    + system.adapter.fullcalendar.0           : fullcalendar          : raspberrypi                              -  enabled
    + system.adapter.govee-local.0            : govee-local           : raspberrypi                              -  enabled
      system.adapter.heatingcontrol.0         : heatingcontrol        : raspberrypi                              - disabled
    + system.adapter.hmip.0                   : hmip                  : raspberrypi                              -  enabled
      system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
      system.adapter.iot.0                    : iot                   : raspberrypi                              - disabled
    + system.adapter.klf200.0                 : klf200                : raspberrypi                              -  enabled
      system.adapter.mihome-vacuum.0          : mihome-vacuum         : raspberrypi                              - disabled, port: 54321
    + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.nuki-extended.0          : nuki-extended         : raspberrypi                              - disabled
      system.adapter.nuki.0                   : nuki                  : raspberrypi                              - disabled
      system.adapter.places.0                 : places                : raspberrypi                              - disabled
    + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
    + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1886, bind: 0.0.0.0
    + system.adapter.statistics.0             : statistics            : raspberrypi                              -  enabled
    + system.adapter.text2command.0           : text2command          : raspberrypi                              -  enabled
    + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
      system.adapter.web.0                    : web                   : raspberrypi                              - disabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.yr.0                     : yr                    : raspberrypi                              -  enabled
    + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/ttyACM0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.17.14  , installed 6.17.14
    Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
    Adapter    "alias-manager": 1.2.6    , installed 1.2.6
    Adapter    "awtrix-light" : 1.2.0    , installed 1.2.0
    Adapter    "backitup"     : 2.11.0   , installed 2.11.0
    Adapter    "birthdays"    : 3.0.0    , installed 3.0.0
    Adapter    "denon"        : 1.15.5   , installed 1.15.5
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "discovery"    : 4.5.0    , installed 4.5.0
    Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
    Adapter    "fullcalendar" : 2.3.17   , installed 2.3.17
    Adapter    "govee-local"  : 0.2.6    , installed 0.2.6
    Adapter    "heatingcontrol": 2.12.8  , installed 2.12.8
    Adapter    "heos"         : 2.2.1    , installed 2.2.1
    Adapter    "hmip"         : 1.23.3   , installed 1.23.3
    Adapter    "ical"         : 1.15.0   , installed 1.15.0
    Adapter    "iot"          : 3.3.0    , installed 3.3.0
    Adapter    "javascript"   : 8.3.1    , installed 8.3.1
    Controller "js-controller": 5.0.19   , installed 5.0.19
    Adapter    "klf200"       : 1.2.0    , installed 1.2.0
    Adapter    "mihome-vacuum": 4.2.0    , installed 4.2.0
    Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
    Adapter    "nuki"         : 2.0.0    , installed 2.0.0
    Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
    Adapter    "places"       : 1.2.0    , installed 1.2.0
    Adapter    "rest-api"     : 2.0.1    , installed 2.0.1
    Adapter    "scenes"       : 3.0.4    , installed 3.0.4
    Adapter    "shelly"       : 7.0.0    , installed 7.0.0
    Adapter    "socketio"     : 6.7.0    , installed 6.7.0
    Adapter    "statistics"   : 2.4.0    , installed 2.4.0
    Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
    Adapter    "telegram"     : 3.3.2    , installed 3.3.2
    Adapter    "text2command" : 3.0.3    , installed 3.0.3
    Adapter    "trashschedule": 3.3.0    , installed 3.3.0
    Adapter    "web"          : 6.2.5    , installed 6.2.5
    Adapter    "ws"           : 2.6.1    , installed 2.6.1
    Adapter    "yr"           : 5.3.0    , installed 5.3.0
    Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
    Objects and States
    Objects:        9591
    States:         7847
    Hit:1 http://deb.debian.org/debian bullseye-proposed-updates InRelease
    Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      109        14805      522/mosquitto
    tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       703780     4069/io.shelly.0
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12860      524/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       702593     3884/iobroker.js-co
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       702596     3884/iobroker.js-co
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       701671     3902/io.admin.0
    tcp6       0      0 :::1883                 :::*                    LISTEN      109        14806      522/mosquitto
    tcp6       0      0 :::22                   :::*                    LISTEN      0          12862      524/sshd: /usr/sbin
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        15505      394/avahi-daemon: r
    udp        0      0 127.0.0.1:4002          0.0.0.0:*                           1001       705775     4736/io.govee-local
    udp        0      0 0.0.0.0:34863           0.0.0.0:*                           108        15507      394/avahi-daemon: r
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14846      734/dhcpcd
    udp6       0      0 :::5353                 :::*                                108        15506      394/avahi-daemon: r
    udp6       0      0 :::50567                :::*                                108        15508      394/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          15746      734/dhcpcd
    2024-07-14 19:46:11.260  - info: zigbee.0 (4000) Got terminate signal TERMINATE_YOURSELF
    2024-07-14 19:46:11.381  - info: host.raspberrypi stopInstance system.adapter.zigbee.0 send kill signal
    2024-07-14 19:46:11.263  - info: zigbee.0 (4000) cleaned everything up...
    2024-07-14 19:46:11.285  - info: zigbee.0 (4000) Zigbee: disabling joining new devices.
    2024-07-14 19:46:11.529  - warn: zigbee.0 (4000) Failed to stop zigbee during startup
    2024-07-14 19:46:11.530  - info: zigbee.0 (4000) terminating
    2024-07-14 19:46:11.531  - info: zigbee.0 (4000) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2024-07-14 19:46:11.601  - info: zigbee.0 (4000) debug devices set to []
    2024-07-14 19:46:11.765  - info: zigbee.0 (4000) terminating
    2024-07-14 19:46:12.143  - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2024-07-14 19:46:12.272  - info: host.raspberrypi "system.adapter.zigbee.0" enabled
    2024-07-14 19:46:12.522  - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 5046
    2024-07-14 19:46:18.289  - info: zigbee.0 (5046) starting. Version 1.10.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.15.1, js-controller: 5.0.19
    2024-07-14 19:46:18.399  - info: zigbee.0 (5046) delete old Backup files. keep only last 10
    2024-07-14 19:46:18.402  - info: zigbee.0 (5046) Starting Zigbee  npm ...
    2024-07-14 19:46:18.831  - info: zigbee.0 (5046) Installed Version: iobroker.zigbee@1.10.3
    2024-07-14 19:46:39.534  - error: zigbee.0 (5046) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
    2024-07-14 19:46:39.535  - error: zigbee.0 (5046) Failed to start Zigbee
    2024-07-14 19:46:39.536  - error: zigbee.0 (5046) Error herdsman start
    2024-07-14 19:46:49.540  - info: zigbee.0 (5046) Try to reconnect. 1 attempts left
    2024-07-14 19:46:49.541  - info: zigbee.0 (5046) Starting Zigbee  npm ...
    2024-07-14 19:46:49.555  - info: zigbee.0 (5046) Installed Version: iobroker.zigbee@1.10.3
    2024-07-14 19:46:49.827  - error: zigbee.0 (5046) Starting zigbee-herdsman problem : "Error Resource temporarily unavailable Cannot lock port"
    2024-07-14 19:46:49.828  - error: zigbee.0 (5046) Failed to start Zigbee
    2024-07-14 19:46:49.829  - error: zigbee.0 (5046) Error herdsman start
    • S stauber
      Skript v.2024-05-22
      *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm64
      Docker          : false
      Kernel          : aarch64
      Userland        : 32 bit
      CPU threads: 4
      Current issues:
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      pi
      HOME=/home/pi
      iobroker
      HOME=/home/iobroker
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:            99M          0B         99M
               3793 M total memory
               1018 M used memory
               1540 M free memory
                251 M buffer memory
                981 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      *** FILESYSTEM ***
      /var:
      2.6G    /var/
      1.3G    /var/log
      1.2G    /var/cache/apt
      USB-Devices by-id:
      HINT:
      /dev/ttyACM0
      /usr/bin/npm            10.7.0
      /usr/bin/npx            10.7.0
      nodejs:
        Version table:
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.17.14
      javascript:     8.3.1
      Adapter State
      + instance is alive
      Objects and States
      Objects:        9591
      States:         7847
      Pending Updates: 0
      #147
      @stauber sagte in Zigbee iobroker Error while opening serialport:
      Userland : 32 bit
      Beizeiten mal komplett neuaufsetzen, dann in einer reinen 64Bit-Version.
      Boot Target: graphical.target
      sudo systemctl set-default multi-user.target
      Dein Dateisystem hat Einschläge.
      by-id:
      einer der beiden Einträge muss in den Einstellungen eingetragen werden. Musst du mal ausprobieren, ob if03 oder if00 passt.
      Schmeiß die Quelle
      raus.
      S arteckA 2 Antworten Letzte Antwort
        Userland : 32 bit
        by-id:
        Schmeiß die Quelle
        raus.
        stauber
        #148
        by-id:
        Nein bleibt Orange bei beiden Einträgen
        kann es sein das die Erweiterte Pan falsch ist? Hab ein Backupgeladen das vor 2 Tagen da ist alles noch gelaufen.
        Schmeiß die Quelle
        raus.
        Wie mach ich das?
        Vielen Dank für deine Unterstützung und deine Mühen
        • S stauber
          by-id:
          Schmeiß die Quelle
          raus.
          Wie mach ich das?
          #149
          Wie mach ich das?
          Lösch die entsprechende Zeile in der Datei /etc/apt/sources.list raus.
            Wie mach ich das?
            stauber
            #150
            @thomas-braun sagte in Zigbee iobroker Error while opening serialport:
            pi@raspberrypi:~ $ /etc/apt/sources.list
            -bash: /etc/apt/sources.list: Keine Berechtigung
            pi@raspberrypi:~ $
            er sagt ich habe keine Berechtigung
            • S stauber
              pi@raspberrypi:~ $
              #151
              Du verwendest ja auch kein Kommando...
              sudo nano /etc/apt/sources.list
              Speichern mit Strg-O, nano verlassen mit Strg-X
                Userland : 32 bit
                by-id:
                Schmeiß die Quelle
                raus.
                arteckA Offline
                arteckA Offline
                arteck
                #152
                -if00
                ist es immer
                  stauber
                  #153
                  tut mir leid das ich mich jetzt erst melde hatte viel zu tun in der Arbeit.
                  Heute hab ich einen Stick von Sonoff ausprobiert und siehe das es läuft wieder ich vermute das das Board einfach defekt ist.
                  Danke nochmal für eure Hilfe
                    searcher57
                    #154
                    @thomas-braun said in Zigbee iobroker Error while opening serialport:
                    Hallo Thomas,
                    jetzt bin ich am Ende! Nachdem ich Probleme mit dem Smartmeter-Adapter (Stromwerte), RPI2 Adapter (Gaswerte) kommt jetzt auch noch der Zigbee Adapter hinzu. Ich habe alles rauf und runter mit einem Raspi 5 8GB probiert. Danach habe ich den Raspi 4 8GB getestet. Auch da bekomme ich den Adapter nicht ans laufen.
                    Hier das Log des Raspi 5:
                    zigbee.0
                    	2024-09-26 15:45:02.137	error	Error herdsman start
                    zigbee.0
                    	2024-09-26 15:45:02.137	error	Failed to start Zigbee
                    zigbee.0
                    	2024-09-26 15:45:02.136	error	Starting zigbee-herdsman problem : "Error Resource temporarily unavailable Cannot lock port"
                    zigbee.0
                    	2024-09-26 15:45:02.061	info	Installed Version: iobroker.zigbee@1.10.3
                    zigbee.0
                    	2024-09-26 15:45:02.054	info	Starting Zigbee npm ...
                    zigbee.0
                    	2024-09-26 15:45:02.053	info	Try to reconnect. 1 attempts left
                    zigbee.0
                    	2024-09-26 15:44:52.052	error	Error herdsman start
                    zigbee.0
                    	2024-09-26 15:44:52.052	error	Failed to start Zigbee
                    zigbee.0
                    	2024-09-26 15:44:52.051	error	Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
                    zigbee.0
                    	2024-09-26 15:44:51.664	info	Installed Version: iobroker.zigbee@1.10.3
                    zigbee.0
                    	2024-09-26 15:44:51.465	info	Starting Zigbee npm ...
                    zigbee.0
                    	2024-09-26 15:44:51.464	info	delete old Backup files. keep only last 10
                    zigbee.0
                    	2024-09-26 15:44:51.433	info	starting. Version 1.10.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.17.0, js-controller: 6.0.11
                    zigbee.0
                    	2024-09-26 15:43:06.087	info	terminating
                    zigbee.0
                    	2024-09-26 15:43:05.820	info	Terminated (NO_ERROR): Without reason
                    zigbee.0
                    	2024-09-26 15:43:05.819	info	terminating
                    zigbee.0
                    	2024-09-26 15:43:05.818	info	debug devices set to []
                    zigbee.0
                    	2024-09-26 15:43:05.815	info	Got terminate signal TERMINATE_YOURSELF
                    zigbee.0
                    	2024-09-26 15:43:05.808	warn	Failed to stop zigbee during startup
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    iob diag:
                    Skript v.2024-05-22
                    *** BASE SYSTEM ***
                     Static hostname: Raspi58GB
                           Icon name: computer
                              Kernel: Linux 6.6.47+rpt-rpi-2712
                        Architecture: arm64
                    Model           : Raspberry Pi 5 Model B Rev 1.0
                    Docker          : false
                    Kernel          : aarch64
                    Userland        : 64 bit
                     15:47:28 up 4 min,  2 users,  load average: 0.37, 0.65, 0.33
                    CPU threads: 4
                    Current issues:
                                   Local time: Thu 2024-09-26 15:47:28 CEST
                               Universal time: Thu 2024-09-26 13:47:28 UTC
                                     RTC time: Thu 2024-09-26 13:47:28
                                  NTP service: active
                              RTC in local TZ: no
                    pi
                    HOME=/home/pi
                    GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                    iobroker
                    HOME=/home/iobroker
                    Desktop:
                    Terminal:       tty
                    Boot Target:    multi-user.target
                    *** MEMORY ***
                    Mem:            8.4G        2.1G        5.6G        5.6M        792M        6.3G
                    Swap:           209M          0B        209M
                    Total:          8.7G        2.1G        5.8G
                    Active iob-Instances:   25
                             8052 M total memory
                             2020 M used memory
                             2032 M active memory
                              401 M inactive memory
                             5370 M free memory
                               61 M buffer memory
                              693 M swap cache
                              199 M total swap
                                0 M used swap
                              199 M free swap
                    top - 15:47:28 up 4 min,  2 users,  load average: 0.37, 0.65, 0.33
                    Tasks: 197 total,   2 running, 195 sleeping,   0 stopped,   0 zombie
                    %Cpu(s): 40.0 us,  0.0 sy,  0.0 ni, 40.0 id, 20.0 wa,  0.0 hi,  0.0 si,  0.0 st
                    MiB Mem :   8052.3 total,   5367.8 free,   2023.6 used,    755.4 buff/cache
                    MiB Swap:    200.0 total,    200.0 free,      0.0 used.   6028.8 avail Mem
                    *** FILESYSTEM ***
                    udev           devtmpfs  3.8G     0  3.8G   0% /dev
                    tmpfs          tmpfs     806M  5.3M  800M   1% /run
                    /dev/mmcblk0p2 ext4       59G   14G   42G  25% /
                    tmpfs          tmpfs     4.0G     0  4.0G   0% /dev/shm
                    tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
                    /dev/sda1      exfat      29G  379M   29G   2% /mnt/usb0
                    /dev/mmcblk0p1 vfat      510M   64M  447M  13% /boot/firmware
                    tmpfs          tmpfs     806M     0  806M   0% /run/user/1000
                    [Thu Sep 26 15:43:19 2024] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe  smsc95xx.macaddr=2C:CF:67:2F:A6:31 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=4e8600df-02 rootfstype=ext4 fsck.repair=yes rootwait
                    [Thu Sep 26 15:43:20 2024] EXT4-fs (mmcblk0p2): mounted filesystem 93c89e92-8f2e-4522-ad32-68faed883d2f ro with ordered data mode. Quota mode: none.
                    [Thu Sep 26 15:43:22 2024] EXT4-fs (mmcblk0p2): re-mounted 93c89e92-8f2e-4522-ad32-68faed883d2f r/w. Quota mode: none.
                    /                                                       /dev/mmcblk0p2 ext4        rw,noatime
                    | `-/sys/fs/fuse/connections                            fusectl        fusectl     rw,nosuid,nodev,noexec,relatime
                    | `-/proc/sys/fs/binfmt_misc                            systemd-1      autofs      rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=4766
                    |   `-/proc/sys/fs/binfmt_misc                          binfmt_misc    binfmt_misc rw,nosuid,nodev,noexec,relatime
                    |-/dev                                                  udev           devtmpfs    rw,nosuid,relatime,size=3950672k,nr_inodes=246917,mode=755
                    |-/run                                                  tmpfs          tmpfs       rw,nosuid,nodev,noexec,relatime,size=824560k,mode=755
                    | |-/run/credentials/systemd-sysctl.service             ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                    | |-/run/credentials/systemd-sysusers.service           ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                    | |-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                    | |-/run/credentials/systemd-tmpfiles-setup.service     ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                    | `-/run/user/1000                                      tmpfs          tmpfs       rw,nosuid,nodev,relatime,size=824544k,nr_inodes=206136,mode=700,uid=1000,gid=1000
                    |-/mnt/usb0                                             /dev/sda1      exfat       rw,relatime,fmask=0000,dmask=0000,allow_utime=0022,iocharset=utf8,errors=remount-ro
                    `-/boot/firmware                                        /dev/mmcblk0p1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                    /var:
                    6.4G    /var/
                    5.3G    /var/lib
                    5.1G    /var/lib/influxdb/engine/data
                    Archived and active journals take up 634.8M in the file system.
                    45M     /opt/iobroker/backups/
                    1.2G    /opt/iobroker/iobroker-data/
                    1.1G    /opt/iobroker/iobroker-data/files
                    441M    /opt/iobroker/iobroker-data/files/javascript.admin
                    409M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                    408M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                    26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
                    26M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
                    USB-Devices by-id:
                    /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0867d5d6b78ded11959b02f6b86ce6f8-if00-port0
                    Your zigbee.0 COM-Port is matching 'by-id'. Very good!
                    /usr/bin/nodejs         v20.17.0
                    /usr/bin/node           v20.17.0
                    /usr/bin/npm            10.8.2
                    /usr/bin/npx            10.8.2
                    /usr/bin/corepack       0.29.3
                    nodejs:
                      Installed: 20.17.0-1nodesource1
                      Candidate: 20.17.0-1nodesource1
                      Version table:
                     *** 20.17.0-1nodesource1 1001
                            500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                         20.16.0-1nodesource1 1001
                         20.15.1-1nodesource1 1001
                         20.15.0-1nodesource1 1001
                         20.14.0-1nodesource1 1001
                         20.13.1-1nodesource1 1001
                         20.13.0-1nodesource1 1001
                         20.12.2-1nodesource1 1001
                         20.12.1-1nodesource1 1001
                         20.12.0-1nodesource1 1001
                         20.11.1-1nodesource1 1001
                         20.11.0-1nodesource1 1001
                         20.10.0-1nodesource1 1001
                         20.9.0-1nodesource1 1001
                         20.8.1-1nodesource1 1001
                         20.8.0-1nodesource1 1001
                         20.7.0-1nodesource1 1001
                         20.6.1-1nodesource1 1001
                         20.6.0-1nodesource1 1001
                         20.5.1-1nodesource1 1001
                         20.5.0-1nodesource1 1001
                         20.4.0-1nodesource1 1001
                         20.3.1-1nodesource1 1001
                         20.3.0-1nodesource1 1001
                         20.2.0-1nodesource1 1001
                         20.1.0-1nodesource1 1001
                         20.0.0-1nodesource1 1001
                         18.19.0+dfsg-6~deb12u2 500
                            500 http://deb.debian.org/debian bookworm/main arm64 Packages
                         18.19.0+dfsg-6~deb12u1 500
                            500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
                    Errors in npm tree:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    admin:          7.1.2
                    javascript:     8.7.6
                    Adapter State
                    + system.adapter.admin.0                  : admin                 : Raspi58GB                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                    + system.adapter.alexa2.0                 : alexa2                : Raspi58GB                                -  enabled
                      system.adapter.alias-manager.0          : alias-manager         : Raspi58GB                                - disabled
                    + system.adapter.awtrix-light.0           : awtrix-light          : Raspi58GB                                -  enabled
                    + system.adapter.backitup.0               : backitup              : Raspi58GB                                -  enabled
                    + system.adapter.broadlink2.0             : broadlink2            : Raspi58GB                                -  enabled
                      system.adapter.devices.0                : devices               : Raspi58GB                                - disabled
                      system.adapter.discovery.0              : discovery             : Raspi58GB                                - disabled
                    + system.adapter.doorbird.0               : doorbird              : Raspi58GB                                -  enabled
                    + system.adapter.echarts.0                : echarts               : Raspi58GB                                -  enabled
                    + system.adapter.followthesun.0           : followthesun          : Raspi58GB                                -  enabled
                    + system.adapter.frontier_silicon.0       : frontier_silicon      : Raspi58GB                                -  enabled
                      system.adapter.frontier_silicon.1       : frontier_silicon      : Raspi58GB                                - disabled
                      system.adapter.frontier_silicon.2       : frontier_silicon      : Raspi58GB                                - disabled
                      system.adapter.frontier_silicon.3       : frontier_silicon      : Raspi58GB                                - disabled
                    + system.adapter.hm-rega.0                : hm-rega               : Raspi58GB                                -  enabled
                    + system.adapter.hm-rpc.0                 : hm-rpc                : Raspi58GB                                -  enabled, port: 0
                    + system.adapter.hm-rpc.1                 : hm-rpc                : Raspi58GB                                -  enabled, port: 0
                    + system.adapter.influxdb.0               : influxdb              : Raspi58GB                                -  enabled, port: 8086
                    + system.adapter.iot.0                    : iot                   : Raspi58GB                                -  enabled
                    + system.adapter.javascript.0             : javascript            : Raspi58GB                                -  enabled
                    + system.adapter.mqtt.0                   : mqtt                  : Raspi58GB                                -  enabled, port: 1883, bind: 0.0.0.0
                    + system.adapter.rpi2.0                   : rpi2                  : Raspi58GB                                -  enabled
                    + system.adapter.shelly.0                 : shelly                : Raspi58GB                                -  enabled, port: 1883, bind: 0.0.0.0
                    + system.adapter.simple-api.0             : simple-api            : Raspi58GB                                -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                      system.adapter.smartmeter.0             : smartmeter            : Raspi58GB                                - disabled
                    + system.adapter.tankerkoenig.0           : tankerkoenig          : Raspi58GB                                -  enabled
                    + system.adapter.telegram.0               : telegram              : Raspi58GB                                -  enabled, port: 8443, bind: 0.0.0.0
                    + system.adapter.vis-2.0                  : vis-2                 : Raspi58GB                                -  enabled
                      system.adapter.vis.0                    : vis                   : Raspi58GB                                -  enabled
                    + system.adapter.web.0                    : web                   : Raspi58GB                                -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                      system.adapter.yr.0                     : yr                    : Raspi58GB                                -  enabled
                    + system.adapter.zigbee.0                 : zigbee                : Raspi58GB                                -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0867d5d6b78ded11959b02f6b86ce6f8-if00-port0
                    + instance is alive
                    Upgrade policy: none
                    Adapter    "admin"        : 7.1.2    , installed 7.1.2
                    Adapter    "awtrix-light" : 1.3.0    , installed 1.3.0
                    Adapter    "backitup"     : 3.0.22   , installed 3.0.22
                    Adapter    "broadlink2"   : 2.3.0    , installed 2.3.0
                    Adapter    "doorbird"     : 1.7.0    , installed 1.7.0
                    Adapter    "echarts"      : 1.9.2    , installed 1.9.2
                    Adapter    "followthesun" : 0.5.1    , installed 0.5.1
                    Adapter    "frontier_silicon": 0.3.0 , installed 0.3.0
                    Adapter    "hm-rega"      : 5.0.0    , installed 5.0.0
                    Adapter    "hm-rpc"       : 1.17.0   , installed 1.17.0
                    Adapter    "javascript"   : 8.7.6    , installed 8.7.6
                    Controller "js-controller": 6.0.11   , installed 6.0.11
                    Adapter    "rpi2"         : 1.3.2    , installed 2.0.0
                    Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
                    Adapter    "telegram"     : 3.9.0    , installed 3.9.0
                    Adapter    "vis-2"        : 2.9.32   , installed 2.9.32
                    Objects and States
                    Objects:        11825
                    States:         9324
                    Hit:1 http://archive.raspberrypi.com/debian bookworm InRelease
                    Hit:2 http://deb.debian.org/debian bookworm InRelease
                    Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
                    Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
                    Hit:5 http://deb.debian.org/debian bullseye-proposed-updates InRelease
                    Hit:6 https://repos.influxdata.com/debian stable InRelease
                    Hit:7 https://deb.nodesource.com/node_20.x nodistro InRelease
                    Pending Updates: 0
                    tcp        0      0 192.168.178.57:2001     0.0.0.0:*               LISTEN      1001       6795       1179/io.hm-rpc.1
                    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      106        7371       814/mosquitto
                    tcp        0      0 192.168.178.57:42010    0.0.0.0:*               LISTEN      1001       6776       1164/io.hm-rpc.0
                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          5765       829/sshd: /usr/sbin
                    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       7487       946/iobroker.js-con
                    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       7492       946/iobroker.js-con
                    tcp        0      0 192.168.178.57:8100     0.0.0.0:*               LISTEN      1001       8840       1313/io.doorbird.0
                    tcp6       0      0 :::1883                 :::*                    LISTEN      106        7372       814/mosquitto
                    tcp6       0      0 :::22                   :::*                    LISTEN      0          5767       829/sshd: /usr/sbin
                    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       9544       1359/io.simple-api.
                    tcp6       0      0 :::8086                 :::*                    LISTEN      999        8359       884/influxd
                    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       9610       1421/io.web.0
                    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       7530       965/io.admin.0
                    udp        0      0 0.0.0.0:37934           0.0.0.0:*                           1001       6727       1119/io.broadlink2.
                    udp        0      0 0.0.0.0:50257           0.0.0.0:*                           1001       7729       1119/io.broadlink2.
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        5702       671/avahi-daemon: r
                    udp        0      0 0.0.0.0:38186           0.0.0.0:*                           1001       6721       1119/io.broadlink2.
                    udp        0      0 0.0.0.0:46537           0.0.0.0:*                           1001       6726       1119/io.broadlink2.
                    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       7818       1252/io.shelly.0
                    udp        0      0 0.0.0.0:55117           0.0.0.0:*                           1001       6723       1119/io.broadlink2.
                    udp        0      0 0.0.0.0:39374           0.0.0.0:*                           104        5704       671/avahi-daemon: r
                    udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       6717       1119/io.broadlink2.
                    udp        0      0 0.0.0.0:39813           0.0.0.0:*                           1001       6722       1119/io.broadlink2.
                    udp        0      0 0.0.0.0:44924           0.0.0.0:*                           1001       6725       1119/io.broadlink2.
                    udp        0      0 0.0.0.0:57524           0.0.0.0:*                           1001       6720       1119/io.broadlink2.
                    udp        0      0 0.0.0.0:53786           0.0.0.0:*                           1001       6724       1119/io.broadlink2.
                    udp        0      0 0.0.0.0:58130           0.0.0.0:*                           1001       6729       1119/io.broadlink2.
                    udp        0      0 0.0.0.0:45874           0.0.0.0:*                           1001       6728       1119/io.broadlink2.
                    udp6       0      0 :::5353                 :::*                                104        5703       671/avahi-daemon: r
                    udp6       0      0 :::59656                :::*                                104        5705       671/avahi-daemon: r
                    2024-09-26 15:45:09.621  - info: simple-api.0 (1359) Allow states only when user is owner: false
                    2024-09-26 15:45:09.628  - info: simple-api.0 (1359) http server listening on port 8087
                    2024-09-26 15:45:12.658  - info: host.Raspi58GB instance system.adapter.tankerkoenig.0 in version "3.4.0" started with pid 1374
                    2024-09-26 15:45:13.651  - info: tankerkoenig.0 (1374) starting. Version 3.4.0 in /opt/iobroker/node_modules/iobroker.tankerkoenig, node: v20.17.0, js-controller: 6.0.11
                    2024-09-26 15:45:13.670  - info: tankerkoenig.0 (1374) Adapter is already in daemon mode
                    2024-09-26 15:45:13.671  - info: tankerkoenig.0 (1374) Sync time set to 30 minutes or 1800000 ms
                    2024-09-26 15:45:16.680  - info: host.Raspi58GB instance system.adapter.vis-2.0 in version "2.9.32" started with pid 1389
                    2024-09-26 15:45:17.906  - info: vis-2.0 (1389) starting. Version 2.9.32 in /opt/iobroker/node_modules/iobroker.vis-2, node: v20.17.0, js-controller: 6.0.11
                    2024-09-26 15:45:18.068  - error: vis-2.0 (1389) License is invalid! Nothing updated. Error: serial number (UUID) in license is for other device
                    2024-09-26 15:45:18.153  - info: tankerkoenig.0 (1374) Start first request
                    2024-09-26 15:45:21.336  - info: yr.0 (1267) Data updated.
                    2024-09-26 15:45:21.337  - info: yr.0 (1267) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2024-09-26 15:45:21.523  - info: vis.0 (1405) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.vis, node: v20.17.0, js-controller: 6.0.11
                    2024-09-26 15:45:21.906  - info: host.Raspi58GB instance system.adapter.yr.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2024-09-26 15:45:22.663  - info: vis.0 (1405) Terminated (NO_ERROR): Without reason
                    2024-09-26 15:45:23.198  - info: host.Raspi58GB instance system.adapter.vis.0 terminated while should be started once
                    2024-09-26 15:45:24.723  - info: host.Raspi58GB instance system.adapter.web.0 in version "6.2.5" started with pid 1421
                    2024-09-26 15:45:25.655  - info: web.0 (1421) starting. Version 6.2.5 in /opt/iobroker/node_modules/iobroker.web, node: v20.17.0, js-controller: 6.0.11
                    2024-09-26 15:45:25.777  - info: web.0 (1421) socket.io server listening on port 8082
                    2024-09-26 15:45:25.779  - info: web.0 (1421) http server listening on port 8082
                    2024-09-26 15:45:28.675  - info: host.Raspi58GB instance system.adapter.followthesun.0 in version "0.5.1" started with pid 1436
                    2024-09-26 15:45:29.606  - info: followthesun.0 (1436) starting. Version 0.5.1 in /opt/iobroker/node_modules/iobroker.followthesun, node: v20.17.0, js-controller: 6.0.11
                    2024-09-26 15:45:29.615  - info: followthesun.0 (1436) Started with JSON-Explorer version 0.1.16
                    2024-09-26 15:45:29.615  - info: followthesun.0 (1436) Sun position calculation will be done every 60 seconds
                    2024-09-26 15:45:29.616  - info: followthesun.0 (1436) Daily sun parameter calculation scheduled for 00:00:39
                    die Einstellungen des Adapters:
                    Erkennst Du einen Fehler? Ich möchte doch wenigstens die Zigbee-Aktoren wieder nutzen.
                    Meister MopperM Thomas BraunT 2 Antworten Letzte Antwort
                    • S searcher57
                      Hallo Thomas,
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      iob diag:
                      Skript v.2024-05-22
                      *** BASE SYSTEM ***
                             Icon name: computer
                          Architecture: arm64
                      Docker          : false
                      Kernel          : aarch64
                      Userland        : 64 bit
                      CPU threads: 4
                      Current issues:
                                    NTP service: active
                                RTC in local TZ: no
                      pi
                      HOME=/home/pi
                      iobroker
                      HOME=/home/iobroker
                      Desktop:
                      Terminal:       tty
                      *** MEMORY ***
                      Swap:           209M          0B        209M
                               8052 M total memory
                               2020 M used memory
                               5370 M free memory
                                 61 M buffer memory
                                693 M swap cache
                                199 M total swap
                                  0 M used swap
                                199 M free swap
                      *** FILESYSTEM ***
                      /var:
                      6.4G    /var/
                      5.3G    /var/lib
                      USB-Devices by-id:
                      /usr/bin/npm            10.8.2
                      /usr/bin/npx            10.8.2
                      nodejs:
                        Version table:
                      Errors in npm tree:
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      admin:          7.1.2
                      javascript:     8.7.6
                      Adapter State
                      + instance is alive
                      Objects and States
                      Objects:        11825
                      States:         9324
                      Pending Updates: 0
                      Meister MopperM Online
                      Meister Mopper
                      #155
                      @searcher57
                      Läuft da vielleicht ein ModemManager? Der hat hier auch schon den Start verhindert.
                      systemctl status ModemManager.service
                      Proxmox und HA ...
                        @searcher57
                        searcher57
                        #156
                        @meister-mopper said in Zigbee iobroker Error while opening serialport:
                        @searcher57
                        Was ist das? Und wie kann ich den deaktivieren?
                        • S searcher57
                          Hallo Thomas,
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          iob diag:
                          Skript v.2024-05-22
                          *** BASE SYSTEM ***
                                 Icon name: computer
                              Architecture: arm64
                          Docker          : false
                          Kernel          : aarch64
                          Userland        : 64 bit
                          CPU threads: 4
                          Current issues:
                                        NTP service: active
                                    RTC in local TZ: no
                          pi
                          HOME=/home/pi
                          iobroker
                          HOME=/home/iobroker
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                          Swap:           209M          0B        209M
                                   8052 M total memory
                                   2020 M used memory
                                   5370 M free memory
                                     61 M buffer memory
                                    693 M swap cache
                                    199 M total swap
                                      0 M used swap
                                    199 M free swap
                          *** FILESYSTEM ***
                          /var:
                          6.4G    /var/
                          5.3G    /var/lib
                          USB-Devices by-id:
                          /usr/bin/npm            10.8.2
                          /usr/bin/npx            10.8.2
                          nodejs:
                            Version table:
                          Errors in npm tree:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          admin:          7.1.2
                          javascript:     8.7.6
                          Adapter State
                          + instance is alive
                          Objects and States
                          Objects:        11825
                          States:         9324
                          Pending Updates: 0
                          #157
                          @searcher57
                          Die extended PAN-ID ist mit Sicherheit falsch, zumindest ist DDDDDDDDDDDDDDDDDDD ungünstig.
                          S 2 Antworten Letzte Antwort
                            @searcher57
                            searcher57
                            #158
                            @searcher57
                            Es kann sein, dass ich bei der Ersteinrichtung da etwas verändert habe. Kannst Du mir sagen, wie ich die abfrage?
                              @searcher57
                              searcher57
                              #159
                              @searcher57
                              Ich habe sie jetzt in DDADDDDDDD2DFDDD geändert.
                              • S searcher57
                                @searcher57
                                #160
                                @searcher57 sagte in Zigbee iobroker Error while opening serialport:
                                Im nv_backup stehen die alten Werte drin, soweit ich weiß.
                                • S searcher57
                                  @searcher57
                                  Meister Mopper
                                  #161
                                  @searcher57
                                  Zeig erstmal das Ergebnis der Abfrage.
                                  Proxmox und HA ...
                                    searcher57
                                    #162
                                    Entschuldige das verstehe ich nicht.
                                    • S searcher57
                                      #163
                                      @searcher57
                                      Hab den exakten Pfad nicht parat. Schau mal in /opt/iobroker/iobroker-data/zigbee oder so ähnlich.
                                        @searcher57
                                        searcher57
                                        #164
                                        @searcher57
        v.2024-05-22
                                               Icon name: computer
                                            Architecture: arm64
                                        Kernel:                 aarch64
                                        Userland:               64 bit
                                        User-ID:                1000
                                        Pending OS-Updates:     0
                                        Pending iob updates:    0
                                        Nodejs-Installation:
                                        /usr/bin/npm            10.8.2
                                        /usr/bin/npx            10.8.2
                                        Recommended versions are nodejs 20.17.0 and npm 10.8.2
                                        MEMORY:
                                        Mem:            8.4G        2.4G        5.1G        5.6M        1.1G        6.1G
                                        Swap:           209M          0B        209M
                                        Total:          8.7G        2.4G        5.3G
                                        ioBroker Core:          js-controller           6.0.11
        admin                   7.1.2
                                        Objects type: jsonl
                                        States  type: jsonl
                                        Objects:                11825
                                        States:                 9324
                                        Size of iob-Database:
                                        32M     /opt/iobroker/iobroker-data/objects.jsonl
                                        10M     /opt/iobroker/iobroker-data/states.jsonl
                                        === Mark text until here for copying ===
                                        pi@Raspi58GB:~ $ systemctl status ModemManager.service
                                        ● ModemManager.service - Modem Manager
                                        Loaded: loaded (/lib/systemd/system/ModemManager.service; enabled; preset: enabled)
                                        Active: active (running) since Thu 2024-09-26 15:43:30 CEST; 1h 8min ago
                                        Main PID: 790 (ModemManager)
                                        Tasks: 3 (limit: 9259)
                                        CPU: 47ms
                                        CGroup: /system.slice/ModemManager.service
                                        └─790 /usr/sbin/ModemManager
                                        Sep 26 15:43:27 Raspi58GB systemd[1]: Starting ModemManager.service - Modem Manager...
                                        Sep 26 15:43:28 Raspi58GB ModemManager[790]: <info> ModemManager (version 1.20.4) starting in system bus...
                                        Sep 26 15:43:30 Raspi58GB systemd[1]: Started ModemManager.service - Modem Manager.
                                        Sep 26 15:43:32 Raspi58GB ModemManager[790]: <info> [base-manager] couldn't check support for device '/sys/devices/platform/axi/1000120000.pcie/1f00300000.usb/xhci-hcd.1/usb3/3-1': not supported>
                                        Sep 26 15:43:32 Raspi58GB ModemManager[790]: <info> [base-manager] couldn't check support for device '/sys/devices/platform/axi/1000120000.pcie/1f00100000.ethernet': not supported by any plugin
                                        Sep 26 15:43:32 Raspi58GB ModemManager[790]: <info> [base-manager] couldn't check support for device '/sys/devices/platform/axi/1001100000.mmc/mmc_host/mmc1/mmc1:0001/mmc1:0001:1': not supported>
                                        lines 1-15/15 (END)
                                        • S searcher57
                                          @searcher57
        v.2024-05-22
                                                 Icon name: computer
                                              Architecture: arm64
                                          Kernel:                 aarch64
                                          Userland:               64 bit
                                          User-ID:                1000
                                          /usr/bin/npm            10.8.2
                                          /usr/bin/npx            10.8.2
                                          MEMORY:
                                          Swap:           209M          0B        209M
        admin                   7.1.2
                                          Objects type: jsonl
                                          States  type: jsonl
                                          Objects:                11825
                                          States:                 9324
                                          CPU: 47ms
                                          lines 1-15/15 (END)
                                          Meister Mopper
                                          #165
                                          @searcher57
                                          Den kannst du mal mit
                                          sudo systemctl stop ModemManager.service
                                          ausschalten und schauen, ob es dann lüpt.
                                          Proxmox und HA ...
