  4. Zigbee iobroker Error while opening serialport
    6.6k
231 Beiträge 28 Kommentatoren 64.1k Aufrufe 24 Beobachtet
  • F flodirmann
    So. Auch nach komplettem Neuaufsetzen des Systems mit Debian 12 Bookworm und dem Korrigieren eigenverschuldeter Rechtschreibfehler (diesmal aus PuTTY direkt rauskopiert) funktioniert es noch nicht besser.
    Egal ob ich in den Einstellungen den by-id path verwende "/dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20231214212123-if00" oder die alternative Adresse "/dev/ttyACM0", in beiden Fällen tritt der identische Fehler auf:
    2024-03-28 15:51:59.165 - info: admin.0 (1017) ==> Connected system.user.admin from ::ffff:192.168.188.23
    2024-03-28 15:51:59.266 - error: zigbee.0 (2510) getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
    2024-03-28 15:51:59.379 - info: zigbee.0 (2510) List of port: [{"path":"/dev/ttyACM0","manufacturer":"ITEAD","serialNumber":"20231214212123","pnpId":"usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20231214212123-if00","vendorId":"1a86","productId":"55d4"}]
    2024-03-28 15:52:38.919 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 (force=false, process=true)
    2024-03-28 15:52:38.926 - info: zigbee.0 (2510) Got terminate signal TERMINATE_YOURSELF
    2024-03-28 15:52:38.930 - info: zigbee.0 (2510) cleaned everything up...
    2024-03-28 15:52:38.934 - info: zigbee.0 (2510) Zigbee: disabling joining new devices.
    2024-03-28 15:52:38.958 - warn: zigbee.0 (2510) Failed to stop zigbee during startup
    2024-03-28 15:52:38.960 - info: zigbee.0 (2510) terminating
    2024-03-28 15:52:38.963 - info: zigbee.0 (2510) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2024-03-28 15:52:38.967 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 send kill signal
    2024-03-28 15:52:39.042 - info: admin.0 (1017) <== Disconnect system.user.admin from ::ffff:192.168.188.23
    2024-03-28 15:52:39.431 - info: zigbee.0 (2510) terminating
    2024-03-28 15:52:39.519 - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2024-03-28 15:52:42.016 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 2586
    2024-03-28 15:52:45.840 - info: zigbee.0 (2586) starting. Version 1.10.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.12.0, js-controller: 5.0.19
    2024-03-28 15:52:45.922 - info: zigbee.0 (2586) delete old Backup files. keep only last 10
    2024-03-28 15:52:45.925 - info: zigbee.0 (2586) Starting Zigbee npm ...
    2024-03-28 15:52:46.171 - info: zigbee.0 (2586) Installed Version: iobroker.zigbee@1.10.1
    2024-03-28 15:53:06.711 - error: zigbee.0 (2586) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
    2024-03-28 15:53:06.712 - error: zigbee.0 (2586) Failed to start Zigbee
    2024-03-28 15:53:06.712 - error: zigbee.0 (2586) Error herdsman start
    2024-03-28 15:53:16.717 - info: zigbee.0 (2586) Try to reconnect. 1 attempts left
    2024-03-28 15:53:16.721 - info: zigbee.0 (2586) Starting Zigbee npm ...
    2024-03-28 15:53:16.751 - info: zigbee.0 (2586) Installed Version: iobroker.zigbee@1.10.1
    2024-03-28 15:53:16.959 - error: zigbee.0 (2586) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
    2024-03-28 15:53:16.960 - error: zigbee.0 (2586) Failed to start Zigbee
    2024-03-28 15:53:16.961 - error: zigbee.0 (2586) Error herdsman start
    Hier noch ein Screenshot der Adaptereinstellungen:
    Könnt ihr mir da irgendwie weiterhelfen? Falls weitere Informationen benötigt werden, gerne Bescheid geben.
    DJMarc75D Offline
    DJMarc75D Offline
    DJMarc75
    #129
    @flodirmann sagte in Zigbee iobroker Error while opening serialport:
    node: v20.12.0
    hmpf... da bist Du schon zu aktuell und hast Dein System wohl nicht korrekt aufgesetzt
    Lehrling seit 1975 !!!
    F 1 Antwort Letzte Antwort
    • DJMarc75D DJMarc75
      node: v20.12.0
      flodirmann
      #130
      @djmarc75
      Mensch, na super. Da dachte ich, da 20 ja die aktuellste geradzahlige Major ist...
      Also wieder zurück auf 18.x?
      DJMarc75D Meister MopperM Thomas BraunT 3 Antworten Letzte Antwort
      • F flodirmann
        @djmarc75
        DJMarc75D Offline
        DJMarc75D Offline
        DJMarc75
        #131
        jawoll :)
        • F flodirmann
          @djmarc75
          Meister MopperM Online
          Meister Mopper
          #132
          Mit dem "Einzeiler" aus der Doku wäre das auf einem neuen System nicht passiert.
          Proxmox und HA ...
          • F flodirmann
            @djmarc75
            #133
            iob nodejs-update 18
            • F flodirmann
              AsgothianA Offline
              AsgothianA Offline
              Asgothian
              #134
              Stell mal bitte die Firmware im zigbee-Adapter auf EZSP (oder ähnlich) um - der sonoff dongle V2 nutzt meines Wissens nach nicht den TI Chip Satz
              A.
              • AsgothianA Asgothian
                A.
                flodirmann
                #135
                @asgothian
                Danke danke danke!
                Das hat tatsächlich endlich geholfen. 👍
                  stauber
                  #136
                  seit gestern läuft der Zigbee Adapter nicht mehr ich musste gestern Router und Rasp abstecken und seitdem wird er nur noch Orange.
                  Bei mir stand die ganze Zeit das Node js v22.x empfohlen wird seit dem letzten Update wird nun die 18.x empfohlen im Forum wiederum die 20.x welche soll ich jetzt Installieren?
                  Mit den Befehl iob Node js-update 18 bleibt er bei 22.x hab ich schon Probiert gibt es noch eine andere Möglichkeit?
                  Hardware
                  Raspberry4 und das CC26x02R1
                  Ansonsten könntet ihr mir irgendwie weiterhelfen?
                  • S stauber
                    Hardware
                    #137
                    @stauber
                    iob nodejs-update 20
                    Und dann mal die Ausgabe von
                    iob diag
                    Da kannst du den Link 'by-id' herausnehmen und in den Einstellungen des Adapters statt /dev/ttyACM0 eintragen.
                      @stauber
                      iob diag
                      stauber
                      #138
                      Hallo Thomas
                      bleib weiterhin auf 22.4
                      nochmal zur Verständnis ich Kopiere den Text danach y
                      oder mach ich was Falsch?
                      • S stauber
                        Hallo Thomas
                        #139
                        @stauber sagte in Zigbee iobroker Error while opening serialport:
                        Ich weiß nicht was du machst...
                        Du sollst
                        in dein Terminal hacken.
                          Du sollst
                          stauber
                          #140
                          @thomas-braun sagte in Zigbee iobroker Error while opening serialport:
                          Das mach ich auch
                          nur er Zeigt immer noch v22.4
                          ioBroker nodejs fixer 2024-05-23
                          You requested to install latest version from nodejs v20 tree.
                          Your current setup is:
                          /usr/bin/nodejs         v22.4.1
                          /usr/bin/node           v22.4.1
                          /usr/bin/npm            10.8.1
                          /usr/bin/npx            10.8.1
                          /usr/bin/corepack       0.28.2
                          We found these nodejs versions available for installation:
                          nodejs:
                            Installed: 22.4.1-1nodesource1
                            Candidate: 22.4.1-1nodesource1
                            Version table:
                           *** 22.4.1-1nodesource1 100
                               20.15.1-1nodesource1 600
                                  500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
                               20.15.0-1nodesource1 600
                               20.14.0-1nodesource1 600
                               20.13.1-1nodesource1 600
                               20.13.0-1nodesource1 600
                               20.12.2-1nodesource1 600
                               20.12.1-1nodesource1 600
                               20.12.0-1nodesource1 600
                               20.11.1-1nodesource1 600
                               20.11.0-1nodesource1 600
                               20.10.0-1nodesource1 600
                               20.9.0-1nodesource1 600
                               20.8.1-1nodesource1 600
                               20.8.0-1nodesource1 600
                               20.7.0-1nodesource1 600
                               20.6.1-1nodesource1 600
                               20.6.0-1nodesource1 600
                               20.5.1-1nodesource1 600
                               20.5.0-1nodesource1 600
                               20.4.0-1nodesource1 600
                               20.3.1-1nodesource1 600
                               20.3.0-1nodesource1 600
                               20.2.0-1nodesource1 600
                               20.1.0-1nodesource1 600
                               20.0.0-1nodesource1 600
                               12.22.12~dfsg-1~deb11u4 500
                          Nothing to do - Your installation is using the correct paths.
                          You are running nodejs v22.4.1. Do you want to install latest version from nodejs v.20 tree?
                          Press <y> to continue or any other key to quit
                          Trying to fix your installation now. Please be patient.
                          rm: cannot remove '/usr/share/keyrings/nodesource.gpg'$'\n''/etc/apt/keyrings/nodesource.gpg': No such file or directory
                          Waiting for ioBroker to shut down - Give me a minute...
                          *** These repos are active on your system:
                          Hit:1 http://deb.debian.org/debian bullseye-proposed-updates InRelease
                          Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                          Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
                          Reading package lists... Done
                          *** Installing ca-certificates, curl and gnupg, just in case they are missing.
                          *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
                          deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_20.x nodistro main
                          Package: nodejs
                          Pin: origin deb.nodesource.com
                          Pin-Priority: 1001
                          *** These repos are active after the adjustments:
                          Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                          Hit:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                          Get:4 https://deb.nodesource.com/node_20.x nodistro InRelease [12.1 kB]
                          Get:5 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages [8461 B]
                          Fetched 20.6 kB in 1s (20.3 kB/s)
                          Installing nodejs now!
                          Installing the nodejs!
                          We tried our best to fix your nodejs. Please run iob diag again to verify.
                          *** RESTARTING ioBroker NOW! ***
                           Please refresh or restart your browser in a few moments.
                          • S stauber
                            Das mach ich auch
                            /usr/bin/npm            10.8.1
                            /usr/bin/npx            10.8.1
                            nodejs:
                              Version table:
                            Package: nodejs
                            Pin-Priority: 1001
                            #141
                            node -v
                            sagt?
                              node -v
                              sagt?
                              stauber
                              #142
                              auch 22
                              • S stauber
                                auch 22
                                #143
                                @stauber
                                Bitte keine Bildchen von Text.
                                sudo apt update
                                sudo apt install nodejs=20.15.1-1nodesource1
                                  @stauber
                                  sudo apt update
                                  stauber
                                  #144
                                  ok das hat funktioniert vielen Dank!
                                  jetzt mit
                                  iob diag
                                  Kannst du mir sagen wo ungefähr die by id steht?
                                  • S stauber
                                    jetzt mit
                                    iob diag
                                    #145
                                    @stauber
                                    Poste die Langfassung in Gänze.
                                      @stauber
                                      stauber
                                      schrieb am zuletzt editiert von stauber
                                      #146
                                      Skript v.2024-05-22
                                      *** BASE SYSTEM ***
                                         Static hostname: raspberrypi
                                               Icon name: computer
                                        Operating System: Raspbian GNU/Linux 11 (bullseye)
                                                  Kernel: Linux 6.1.21-v8+
                                            Architecture: arm64
                                      Model           : Raspberry Pi 4 Model B Rev 1.2
                                      Docker          : false
                                      Virtualization  : none
                                      Kernel          : aarch64
                                      Userland        : 32 bit
                                      Systemuptime and Load:
                                       19:48:08 up 23:11,  1 user,  load average: 0.64, 0.87, 0.91
                                      CPU threads: 4
                                      *** RASPBERRY THROTTLING ***
                                      Current issues:
                                      Previously detected issues:
                                      *** Time and Time Zones ***
                                                     Local time: Sun 2024-07-14 19:48:08 CEST
                                                 Universal time: Sun 2024-07-14 17:48:08 UTC
                                                       RTC time: n/a
                                                    NTP service: active
                                                RTC in local TZ: no
                                      *** Users and Groups ***
                                      User that called 'iob diag':
                                      pi
                                      HOME=/home/pi
                                      GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
                                      iobroker
                                      HOME=/home/iobroker
                                      *** Display-Server-Setup ***
                                      Display-Server: false
                                      Desktop:
                                      Terminal:       tty
                                      *** MEMORY ***
                                      Mem:            3.8G        1.0G        1.5G        0.0K        1.2G        2.7G
                                      Swap:            99M          0B         99M
                                      Total:          3.9G        1.0G        1.6G
                                      Active iob-Instances:   22
                                               3793 M total memory
                                               1018 M used memory
                                               1067 M active memory
                                                957 M inactive memory
                                               1540 M free memory
                                                251 M buffer memory
                                                981 M swap cache
                                                 99 M total swap
                                                  0 M used swap
                                                 99 M free swap
                                      top - 19:48:09 up 23:11,  1 user,  load average: 0.67, 0.87, 0.91
                                      Tasks: 174 total,   1 running, 173 sleeping,   0 stopped,   0 zombie
                                      %Cpu(s):  2.9 us,  2.9 sy,  0.0 ni, 94.2 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                      MiB Mem :   3793.3 total,   1540.2 free,   1019.4 used,   1233.7 buff/cache
                                      MiB Swap:    100.0 total,    100.0 free,      0.0 used.   2697.6 avail Mem
                                      *** FAILED SERVICES ***
                                      0 loaded units listed.
                                      *** FILESYSTEM ***
                                      /dev/root      ext4      220G  8.2G  203G   4% /
                                      devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
                                      tmpfs          tmpfs     759M  892K  758M   1% /run
                                      /dev/sda1      vfat      253M   51M  202M  20% /boot
                                      tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
                                      [Sat Jul 13 20:36:26 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:5B:D6:24 vc_mem.mem_base        =0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=61bf9d36-02 rootfstype=ext4 fsck.repair=yes rootwait
                                      [Sat Jul 13 20:36:28 2024] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
                                      [Sat Jul 13 20:36:28 2024] EXT4-fs (sda2): write access will be enabled during recovery
                                      [Sat Jul 13 20:36:28 2024] EXT4-fs (sda2): recovery complete
                                      [Sat Jul 13 20:36:28 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
                                      [Sat Jul 13 20:36:28 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                                      [Sat Jul 13 20:36:30 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
                                      Show mounted filesystems:
                                      TARGET                       SOURCE     FSTYPE     OPTIONS
                                      /                            /dev/sda2  ext4       rw,noatime
                                      |-/dev                       devtmpfs   devtmpfs   rw,relatime,size=1677960k,nr_inodes=419490,mode=755
                                      | |-/dev/shm                 tmpfs      tmpfs      rw,nosuid,nodev
                                      | |-/dev/pts                 devpts     devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
                                      | `-/dev/mqueue              mqueue     mqueue     rw,nosuid,nodev,noexec,relatime
                                      |-/proc                      proc       proc       rw,relatime
                                      | `-/proc/sys/fs/binfmt_misc systemd-1  autofs     rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
                                      |-/sys                       sysfs      sysfs      rw,nosuid,nodev,noexec,relatime
                                      | |-/sys/kernel/security     securityfs securityfs rw,nosuid,nodev,noexec,relatime
                                      | |-/sys/fs/cgroup           cgroup2    cgroup2    rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
                                      | |-/sys/fs/pstore           pstore     pstore     rw,nosuid,nodev,noexec,relatime
                                      | |-/sys/fs/bpf              bpf        bpf        rw,nosuid,nodev,noexec,relatime,mode=700
                                      | |-/sys/kernel/debug        debugfs    debugfs    rw,nosuid,nodev,noexec,relatime
                                      | |-/sys/kernel/tracing      tracefs    tracefs    rw,nosuid,nodev,noexec,relatime
                                      | |-/sys/fs/fuse/connections fusectl    fusectl    rw,nosuid,nodev,noexec,relatime
                                      | `-/sys/kernel/config       configfs   configfs   rw,nosuid,nodev,noexec,relatime
                                      |-/run                       tmpfs      tmpfs      rw,nosuid,nodev,size=776876k,nr_inodes=819200,mode=755
                                      | |-/run/lock                tmpfs      tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k
                                      | |-/run/rpc_pipefs          sunrpc     rpc_pipefs rw,relatime
                                      | `-/run/user/1000           tmpfs      tmpfs      rw,nosuid,nodev,relatime,size=388436k,nr_inodes=97109,mode=700,uid=1000,gid=1000
                                      `-/boot                      /dev/sda1  vfat       rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
                                      /var:
                                      2.6G    /var/
                                      1.3G    /var/log/journal/3e23e34d17484a28b9473f69f7d9d21c
                                      1.3G    /var/log
                                      1.2G    /var/cache/apt
                                      Archived and active journals take up 1.2G in the file system.
                                      /opt/iobroker/backups:
                                      121M    /opt/iobroker/backups/
                                      /opt/iobroker/iobroker-data:
                                      604M    /opt/iobroker/iobroker-data/
                                      439M    /opt/iobroker/iobroker-data/files
                                      138M    /opt/iobroker/iobroker-data/files/javascript.admin
                                      136M    /opt/iobroker/iobroker-data/backup-objects
                                      118M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                                      38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
                                      35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                                      27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
                                      26M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.8947f24d.js.map
                                      24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                                      USB-Devices by-id:
                                      /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.18__Embed_with_CMSIS-DAP_L1100PJ1-if03
                                      /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.18__Embed_with_CMSIS-DAP_L1100PJ1-if00
                                      HINT:
                                      Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
                                      /dev/ttyACM0
                                      *** NodeJS-Installation ***
                                      /usr/bin/nodejs         v20.15.1
                                      /usr/bin/node           v20.15.1
                                      /usr/bin/npm            10.7.0
                                      /usr/bin/npx            10.7.0
                                      /usr/bin/corepack       0.28.1
                                      nodejs:
                                        Installed: 20.15.1-1nodesource1
                                        Candidate: 20.15.1-1nodesource1
                                        Version table:
                                       *** 20.15.1-1nodesource1 600
                                      No problems detected
                                      Errors in npm tree:
                                      *** ioBroker-Installation ***
                                      ioBroker Status
                                      Objects type: jsonl
                                      States  type: jsonl
                                      Core adapters versions
                                      admin:          6.17.14
                                      javascript:     8.3.1
                                      nodejs modules from github:     0
                                      Adapter State
                                        system.adapter.alexa2.0                 : alexa2                : raspberrypi                              - disabled
                                      + system.adapter.awtrix-light.0           : awtrix-light          : raspberrypi                              -  enabled
                                      + system.adapter.awtrix-light.1           : awtrix-light          : raspberrypi                              -  enabled
                                        system.adapter.birthdays.0              : birthdays             : raspberrypi                              -  enabled
                                        system.adapter.cloud.0                  : cloud                 : raspberrypi                              - disabled
                                        system.adapter.denon.0                  : denon                 : raspberrypi                              - disabled
                                        system.adapter.devices.0                : devices               : raspberrypi                              -  enabled
                                      + system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled
                                      + system.adapter.fullcalendar.0           : fullcalendar          : raspberrypi                              -  enabled
                                      + system.adapter.govee-local.0            : govee-local           : raspberrypi                              -  enabled
                                        system.adapter.heatingcontrol.0         : heatingcontrol        : raspberrypi                              - disabled
                                      + system.adapter.hmip.0                   : hmip                  : raspberrypi                              -  enabled
                                        system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
                                        system.adapter.iot.0                    : iot                   : raspberrypi                              - disabled
                                      + system.adapter.klf200.0                 : klf200                : raspberrypi                              -  enabled
                                        system.adapter.mihome-vacuum.0          : mihome-vacuum         : raspberrypi                              - disabled, port: 54321
                                      + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
                                        system.adapter.nuki-extended.0          : nuki-extended         : raspberrypi                              - disabled
                                        system.adapter.nuki.0                   : nuki                  : raspberrypi                              - disabled
                                        system.adapter.places.0                 : places                : raspberrypi                              - disabled
                                      + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
                                      + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1886, bind: 0.0.0.0
                                      + system.adapter.statistics.0             : statistics            : raspberrypi                              -  enabled
                                      + system.adapter.text2command.0           : text2command          : raspberrypi                              -  enabled
                                      + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
                                      + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
                                        system.adapter.web.0                    : web                   : raspberrypi                              - disabled, port: 8082, bind: 0.0.0.0, run as: admin
                                        system.adapter.yr.0                     : yr                    : raspberrypi                              -  enabled
                                      + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/ttyACM0
                                      + instance is alive
                                      ioBroker-Repositories
                                      Active repo(s): stable
                                      Installed ioBroker-Instances
                                      Used repository: stable
                                      Adapter    "admin"        : 6.17.14  , installed 6.17.14
                                      Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                                      Adapter    "alias-manager": 1.2.6    , installed 1.2.6
                                      Adapter    "awtrix-light" : 1.2.0    , installed 1.2.0
                                      Adapter    "backitup"     : 2.11.0   , installed 2.11.0
                                      Adapter    "birthdays"    : 3.0.0    , installed 3.0.0
                                      Adapter    "denon"        : 1.15.5   , installed 1.15.5
                                      Adapter    "devices"      : 1.1.5    , installed 1.1.5
                                      Adapter    "discovery"    : 4.5.0    , installed 4.5.0
                                      Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
                                      Adapter    "fullcalendar" : 2.3.17   , installed 2.3.17
                                      Adapter    "govee-local"  : 0.2.6    , installed 0.2.6
                                      Adapter    "heatingcontrol": 2.12.8  , installed 2.12.8
                                      Adapter    "heos"         : 2.2.1    , installed 2.2.1
                                      Adapter    "hmip"         : 1.23.3   , installed 1.23.3
                                      Adapter    "ical"         : 1.15.0   , installed 1.15.0
                                      Adapter    "iot"          : 3.3.0    , installed 3.3.0
                                      Adapter    "javascript"   : 8.3.1    , installed 8.3.1
                                      Controller "js-controller": 5.0.19   , installed 5.0.19
                                      Adapter    "klf200"       : 1.2.0    , installed 1.2.0
                                      Adapter    "mihome-vacuum": 4.2.0    , installed 4.2.0
                                      Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                                      Adapter    "nuki"         : 2.0.0    , installed 2.0.0
                                      Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
                                      Adapter    "places"       : 1.2.0    , installed 1.2.0
                                      Adapter    "rest-api"     : 2.0.1    , installed 2.0.1
                                      Adapter    "scenes"       : 3.0.4    , installed 3.0.4
                                      Adapter    "shelly"       : 7.0.0    , installed 7.0.0
                                      Adapter    "socketio"     : 6.7.0    , installed 6.7.0
                                      Adapter    "statistics"   : 2.4.0    , installed 2.4.0
                                      Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
                                      Adapter    "telegram"     : 3.3.2    , installed 3.3.2
                                      Adapter    "text2command" : 3.0.3    , installed 3.0.3
                                      Adapter    "trashschedule": 3.3.0    , installed 3.3.0
                                      Adapter    "web"          : 6.2.5    , installed 6.2.5
                                      Adapter    "ws"           : 2.6.1    , installed 2.6.1
                                      Adapter    "yr"           : 5.3.0    , installed 5.3.0
                                      Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
                                      Objects and States
                                      Objects:        9591
                                      States:         7847
                                      Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
                                      Pending Updates: 0
                                      *** Listening Ports ***
                                      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      109        14805      522/mosquitto
                                      tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       703780     4069/io.shelly.0
                                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12860      524/sshd: /usr/sbin
                                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       702593     3884/iobroker.js-co
                                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       702596     3884/iobroker.js-co
                                      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       701671     3902/io.admin.0
                                      tcp6       0      0 :::1883                 :::*                    LISTEN      109        14806      522/mosquitto
                                      tcp6       0      0 :::22                   :::*                    LISTEN      0          12862      524/sshd: /usr/sbin
                                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        15505      394/avahi-daemon: r
                                      udp        0      0 127.0.0.1:4002          0.0.0.0:*                           1001       705775     4736/io.govee-local
                                      udp        0      0 0.0.0.0:34863           0.0.0.0:*                           108        15507      394/avahi-daemon: r
                                      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14846      734/dhcpcd
                                      udp6       0      0 :::5353                 :::*                                108        15506      394/avahi-daemon: r
                                      udp6       0      0 :::50567                :::*                                108        15508      394/avahi-daemon: r
                                      udp6       0      0 :::546                  :::*                                0          15746      734/dhcpcd
                                      2024-07-14 19:46:11.260  - info: zigbee.0 (4000) Got terminate signal TERMINATE_YOURSELF
                                      2024-07-14 19:46:11.381  - info: host.raspberrypi stopInstance system.adapter.zigbee.0 send kill signal
                                      2024-07-14 19:46:11.263  - info: zigbee.0 (4000) cleaned everything up...
                                      2024-07-14 19:46:11.285  - info: zigbee.0 (4000) Zigbee: disabling joining new devices.
                                      2024-07-14 19:46:11.529  - warn: zigbee.0 (4000) Failed to stop zigbee during startup
                                      2024-07-14 19:46:11.530  - info: zigbee.0 (4000) terminating
                                      2024-07-14 19:46:11.531  - info: zigbee.0 (4000) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                      2024-07-14 19:46:11.601  - info: zigbee.0 (4000) debug devices set to []
                                      2024-07-14 19:46:11.765  - info: zigbee.0 (4000) terminating
                                      2024-07-14 19:46:12.143  - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                      2024-07-14 19:46:12.272  - info: host.raspberrypi "system.adapter.zigbee.0" enabled
                                      2024-07-14 19:46:12.522  - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 5046
                                      2024-07-14 19:46:18.289  - info: zigbee.0 (5046) starting. Version 1.10.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.15.1, js-controller: 5.0.19
                                      2024-07-14 19:46:18.399  - info: zigbee.0 (5046) delete old Backup files. keep only last 10
                                      2024-07-14 19:46:18.402  - info: zigbee.0 (5046) Starting Zigbee  npm ...
                                      2024-07-14 19:46:18.831  - info: zigbee.0 (5046) Installed Version: iobroker.zigbee@1.10.3
                                      2024-07-14 19:46:39.534  - error: zigbee.0 (5046) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
                                      2024-07-14 19:46:39.535  - error: zigbee.0 (5046) Failed to start Zigbee
                                      2024-07-14 19:46:39.536  - error: zigbee.0 (5046) Error herdsman start
                                      2024-07-14 19:46:49.540  - info: zigbee.0 (5046) Try to reconnect. 1 attempts left
                                      2024-07-14 19:46:49.541  - info: zigbee.0 (5046) Starting Zigbee  npm ...
                                      2024-07-14 19:46:49.555  - info: zigbee.0 (5046) Installed Version: iobroker.zigbee@1.10.3
                                      2024-07-14 19:46:49.827  - error: zigbee.0 (5046) Starting zigbee-herdsman problem : "Error Resource temporarily unavailable Cannot lock port"
                                      2024-07-14 19:46:49.828  - error: zigbee.0 (5046) Failed to start Zigbee
                                      2024-07-14 19:46:49.829  - error: zigbee.0 (5046) Error herdsman start
                                      • S stauber
                                        Skript v.2024-05-22
                                        *** BASE SYSTEM ***
                                                 Icon name: computer
                                              Architecture: arm64
                                        Docker          : false
                                        Kernel          : aarch64
                                        Userland        : 32 bit
                                        CPU threads: 4
                                        Current issues:
                                                         RTC time: n/a
                                                      NTP service: active
                                                  RTC in local TZ: no
                                        pi
                                        HOME=/home/pi
                                        iobroker
                                        HOME=/home/iobroker
                                        Desktop:
                                        Terminal:       tty
                                        *** MEMORY ***
                                        Swap:            99M          0B         99M
                                                 3793 M total memory
                                                 1018 M used memory
                                                 1540 M free memory
                                                  251 M buffer memory
                                                  981 M swap cache
                                                   99 M total swap
                                                    0 M used swap
                                                   99 M free swap
                                        *** FILESYSTEM ***
                                        /var:
                                        2.6G    /var/
                                        1.3G    /var/log
                                        1.2G    /var/cache/apt
                                        USB-Devices by-id:
                                        HINT:
                                        /dev/ttyACM0
                                        /usr/bin/npm            10.7.0
                                        /usr/bin/npx            10.7.0
                                        nodejs:
                                          Version table:
                                        Errors in npm tree:
                                        ioBroker Status
                                        Objects type: jsonl
                                        States  type: jsonl
                                        admin:          6.17.14
                                        javascript:     8.3.1
                                        Adapter State
                                        + instance is alive
                                        Objects and States
                                        Objects:        9591
                                        States:         7847
                                        Pending Updates: 0
                                        #147
                                        Userland : 32 bit
                                        Beizeiten mal komplett neuaufsetzen, dann in einer reinen 64Bit-Version.
                                        Boot Target: graphical.target
                                        sudo systemctl set-default multi-user.target
                                        Dein Dateisystem hat Einschläge.
                                        by-id:
                                        einer der beiden Einträge muss in den Einstellungen eingetragen werden. Musst du mal ausprobieren, ob if03 oder if00 passt.
                                        Schmeiß die Quelle
                                        raus.
                                        S arteckA 2 Antworten Letzte Antwort
                                          Userland : 32 bit
                                          by-id:
                                          Schmeiß die Quelle
                                          raus.
                                          stauber
                                          #148
                                          by-id:
                                          Nein bleibt Orange bei beiden Einträgen
                                          kann es sein das die Erweiterte Pan falsch ist? Hab ein Backupgeladen das vor 2 Tagen da ist alles noch gelaufen.
                                          Schmeiß die Quelle
                                          raus.
                                          Wie mach ich das?
                                          Vielen Dank für deine Unterstützung und deine Mühen
