  4. Zigbee iobroker Error while opening serialport
    6.6k
231 Beiträge 28 Kommentatoren 64.1k Aufrufe 24 Beobachtet
  • F flodirmann
    Danke für die schnelle Antwort.
    Auch nach den notwendigen Updates bleibt der Fehler bestehen (ich denke mal, innerhalb der Major-Version 18 zu bleiben zählt noch als aktuell?)
    2024-03-27 21:15:58.928 - info: zigbee.0 (3067) terminating
    2024-03-27 21:15:58.929 - info: zigbee.0 (3067) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2024-03-27 21:15:59.279 - info: zigbee.0 (3067) terminating
    2024-03-27 21:15:59.495 - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2024-03-27 21:16:01.859 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 3142
    2024-03-27 21:16:06.599 - info: zigbee.0 (3142) starting. Version 1.10.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.20.0, js-controller: 5.0.19
    2024-03-27 21:16:06.701 - info: zigbee.0 (3142) delete old Backup files. keep only last 10
    2024-03-27 21:16:06.703 - info: zigbee.0 (3142) Starting Zigbee npm ...
    2024-03-27 21:16:07.105 - error: zigbee.0 (3142) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20231314212123-if00'"
    2024-03-27 21:16:07.107 - error: zigbee.0 (3142) Failed to start Zigbee
    2024-03-27 21:16:07.107 - error: zigbee.0 (3142) Error herdsman start
    2024-03-27 21:16:07.113 - info: zigbee.0 (3142) Installed Version: iobroker.zigbee@1.10.1
    2024-03-27 21:16:17.113 - info: zigbee.0 (3142) Try to reconnect. 1 attempts left
    2024-03-27 21:16:17.114 - info: zigbee.0 (3142) Starting Zigbee npm ...
    2024-03-27 21:16:17.127 - error: zigbee.0 (3142) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20231314212123-if00'"
    2024-03-27 21:16:17.128 - error: zigbee.0 (3142) Failed to start Zigbee
    2024-03-27 21:16:17.128 - error: zigbee.0 (3142) Error herdsman start
    2024-03-27 21:16:17.135 - info: zigbee.0 (3142) Installed Version: iobroker.zigbee@1.10.1
    @thomas-braun said in Zigbee iobroker Error while opening serialport:
    @flodirmann sagte in Zigbee iobroker Error while opening serialport:
    mit diesem Pfad in den Einstellungen funktioniert es aber nicht,
    Das funktioniert deswegen nicht, weil die Meldung
    volkommen korrekt ist. Die Datei heißt nämlich:
    "Ich kann aus dämlichen Screenshots nichts kopieren, deswegen darfst du den Fehler nun selber suchen"
    Warum eigentlich immer alles so passiv aggressiv?
    Ich habe doch oben den pfad, wie ihn PuTTY mir ausspuckt, in textform geschrieben:
    @flodirmann said in Zigbee iobroker Error while opening serialport:
    Der genaue Pfad meines Dongles ist (mit PuTTY ausgelesen):
    /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20231214212123-if00
    Oder was bräuchtest du genauer, um mir weiterhelfen zu können?
    #124
    Der steht aber nicht so in den Einstellungen des Adapters drin. Finde den Tippfehler.
    Sowas kopiert man auch aus dem Terminal und pinnt das nicht manuell ab.
    • F flodirmann
      arteckA Offline
      arteckA Offline
      arteck
      #125
      @flodirmann wenn du schon abschreibst dann machs richtig und kontrolliere es 5 mal
      F 1 Antwort Letzte Antwort
      • arteckA arteck
        flodirmann
        #126
        @arteck
        Danke für den Hinweis auf meinen, zugegebenermaßen tatsächlich echt vermeidbaren, Fehler. 😖
        Leider kann ich noch nicht vermelden, ob jetzt alles klappt, weil ich augenscheinlich nebenbei bei den Updates des raspis in den wohl im Forum schon bekannteren udev-Bug hineingelaufen bin, es gibt jetzt kein /by-id/ mehr...
        Jetzt muss dabei erst mal eine Lösung her.
        • F flodirmann
          @arteck
          #127
          Aktuelles System verwenden, das hat den Fehler nicht.
            flodirmann
            schrieb am zuletzt editiert von flodirmann
            #128
            So. Auch nach komplettem Neuaufsetzen des Systems mit Debian 12 Bookworm und dem Korrigieren eigenverschuldeter Rechtschreibfehler (diesmal aus PuTTY direkt rauskopiert) funktioniert es noch nicht besser.
            Egal ob ich in den Einstellungen den by-id path verwende "/dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20231214212123-if00" oder die alternative Adresse "/dev/ttyACM0", in beiden Fällen tritt der identische Fehler auf:
            2024-03-28 15:51:59.165 - info: admin.0 (1017) ==> Connected system.user.admin from ::ffff:192.168.188.23
            2024-03-28 15:51:59.266 - error: zigbee.0 (2510) getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
            2024-03-28 15:51:59.379 - info: zigbee.0 (2510) List of port: [{"path":"/dev/ttyACM0","manufacturer":"ITEAD","serialNumber":"20231214212123","pnpId":"usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20231214212123-if00","vendorId":"1a86","productId":"55d4"}]
            2024-03-28 15:52:38.919 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 (force=false, process=true)
            2024-03-28 15:52:38.926 - info: zigbee.0 (2510) Got terminate signal TERMINATE_YOURSELF
            2024-03-28 15:52:38.930 - info: zigbee.0 (2510) cleaned everything up...
            2024-03-28 15:52:38.934 - info: zigbee.0 (2510) Zigbee: disabling joining new devices.
            2024-03-28 15:52:38.958 - warn: zigbee.0 (2510) Failed to stop zigbee during startup
            2024-03-28 15:52:38.960 - info: zigbee.0 (2510) terminating
            2024-03-28 15:52:38.963 - info: zigbee.0 (2510) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2024-03-28 15:52:38.967 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 send kill signal
            2024-03-28 15:52:39.042 - info: admin.0 (1017) <== Disconnect system.user.admin from ::ffff:192.168.188.23
            2024-03-28 15:52:39.431 - info: zigbee.0 (2510) terminating
            2024-03-28 15:52:39.519 - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2024-03-28 15:52:42.016 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 2586
            2024-03-28 15:52:45.840 - info: zigbee.0 (2586) starting. Version 1.10.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.12.0, js-controller: 5.0.19
            2024-03-28 15:52:45.922 - info: zigbee.0 (2586) delete old Backup files. keep only last 10
            2024-03-28 15:52:45.925 - info: zigbee.0 (2586) Starting Zigbee npm ...
            2024-03-28 15:52:46.171 - info: zigbee.0 (2586) Installed Version: iobroker.zigbee@1.10.1
            2024-03-28 15:53:06.711 - error: zigbee.0 (2586) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
            2024-03-28 15:53:06.712 - error: zigbee.0 (2586) Failed to start Zigbee
            2024-03-28 15:53:06.712 - error: zigbee.0 (2586) Error herdsman start
            2024-03-28 15:53:16.717 - info: zigbee.0 (2586) Try to reconnect. 1 attempts left
            2024-03-28 15:53:16.721 - info: zigbee.0 (2586) Starting Zigbee npm ...
            2024-03-28 15:53:16.751 - info: zigbee.0 (2586) Installed Version: iobroker.zigbee@1.10.1
            2024-03-28 15:53:16.959 - error: zigbee.0 (2586) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
            2024-03-28 15:53:16.960 - error: zigbee.0 (2586) Failed to start Zigbee
            2024-03-28 15:53:16.961 - error: zigbee.0 (2586) Error herdsman start
            Hier noch ein Screenshot der Adaptereinstellungen:
            Könnt ihr mir da irgendwie weiterhelfen? Falls weitere Informationen benötigt werden, gerne Bescheid geben.
            DJMarc75D AsgothianA 2 Antworten Letzte Antwort
            • F flodirmann
              DJMarc75D Offline
              DJMarc75D Offline
              DJMarc75
              #129
              node: v20.12.0
              hmpf... da bist Du schon zu aktuell und hast Dein System wohl nicht korrekt aufgesetzt
              Lehrling seit 1975 !!!
              • DJMarc75D DJMarc75
                node: v20.12.0
                flodirmann
                #130
                @djmarc75
                Mensch, na super. Da dachte ich, da 20 ja die aktuellste geradzahlige Major ist...
                Also wieder zurück auf 18.x?
                DJMarc75D Meister MopperM Thomas BraunT 3 Antworten Letzte Antwort
                • F flodirmann
                  @djmarc75
                  DJMarc75D Offline
                  DJMarc75D Offline
                  DJMarc75
                  #131
                  jawoll :)
                  • F flodirmann
                    @djmarc75
                    Meister MopperM Online
                    Meister Mopper
                    #132
                    Mit dem "Einzeiler" aus der Doku wäre das auf einem neuen System nicht passiert.
                    Proxmox und HA ...
                    • F flodirmann
                      @djmarc75
                      #133
                      iob nodejs-update 18
                      • F flodirmann
                        AsgothianA Offline
                        AsgothianA Offline
                        Asgothian
                        #134
                        Stell mal bitte die Firmware im zigbee-Adapter auf EZSP (oder ähnlich) um - der sonoff dongle V2 nutzt meines Wissens nach nicht den TI Chip Satz
                        A.
                        • AsgothianA Asgothian
                          A.
                          flodirmann
                          #135
                          @asgothian
                          Danke danke danke!
                          Das hat tatsächlich endlich geholfen. 👍
                            stauber
                            #136
                            seit gestern läuft der Zigbee Adapter nicht mehr ich musste gestern Router und Rasp abstecken und seitdem wird er nur noch Orange.
                            Bei mir stand die ganze Zeit das Node js v22.x empfohlen wird seit dem letzten Update wird nun die 18.x empfohlen im Forum wiederum die 20.x welche soll ich jetzt Installieren?
                            Mit den Befehl iob Node js-update 18 bleibt er bei 22.x hab ich schon Probiert gibt es noch eine andere Möglichkeit?
                            Hardware
                            Raspberry4 und das CC26x02R1
                            Ansonsten könntet ihr mir irgendwie weiterhelfen?
                            • S stauber
                              Hardware
                              #137
                              @stauber
                              iob nodejs-update 20
                              Und dann mal die Ausgabe von
                              iob diag
                              Da kannst du den Link 'by-id' herausnehmen und in den Einstellungen des Adapters statt /dev/ttyACM0 eintragen.
                                @stauber
                                iob diag
                                stauber
                                #138
                                Hallo Thomas
                                bleib weiterhin auf 22.4
                                nochmal zur Verständnis ich Kopiere den Text danach y
                                oder mach ich was Falsch?
                                • S stauber
                                  Hallo Thomas
                                  #139
                                  @stauber sagte in Zigbee iobroker Error while opening serialport:
                                  Ich weiß nicht was du machst...
                                  Du sollst
                                  in dein Terminal hacken.
                                    Du sollst
                                    stauber
                                    #140
                                    @thomas-braun sagte in Zigbee iobroker Error while opening serialport:
                                    Das mach ich auch
                                    nur er Zeigt immer noch v22.4
                                    ioBroker nodejs fixer 2024-05-23
                                    You requested to install latest version from nodejs v20 tree.
                                    Your current setup is:
                                    /usr/bin/nodejs         v22.4.1
                                    /usr/bin/node           v22.4.1
                                    /usr/bin/npm            10.8.1
                                    /usr/bin/npx            10.8.1
                                    /usr/bin/corepack       0.28.2
                                    We found these nodejs versions available for installation:
                                    nodejs:
                                      Installed: 22.4.1-1nodesource1
                                      Candidate: 22.4.1-1nodesource1
                                      Version table:
                                     *** 22.4.1-1nodesource1 100
                                         20.15.1-1nodesource1 600
                                            500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
                                         20.15.0-1nodesource1 600
                                         20.14.0-1nodesource1 600
                                         20.13.1-1nodesource1 600
                                         20.13.0-1nodesource1 600
                                         20.12.2-1nodesource1 600
                                         20.12.1-1nodesource1 600
                                         20.12.0-1nodesource1 600
                                         20.11.1-1nodesource1 600
                                         20.11.0-1nodesource1 600
                                         20.10.0-1nodesource1 600
                                         20.9.0-1nodesource1 600
                                         20.8.1-1nodesource1 600
                                         20.8.0-1nodesource1 600
                                         20.7.0-1nodesource1 600
                                         20.6.1-1nodesource1 600
                                         20.6.0-1nodesource1 600
                                         20.5.1-1nodesource1 600
                                         20.5.0-1nodesource1 600
                                         20.4.0-1nodesource1 600
                                         20.3.1-1nodesource1 600
                                         20.3.0-1nodesource1 600
                                         20.2.0-1nodesource1 600
                                         20.1.0-1nodesource1 600
                                         20.0.0-1nodesource1 600
                                         12.22.12~dfsg-1~deb11u4 500
                                    Nothing to do - Your installation is using the correct paths.
                                    You are running nodejs v22.4.1. Do you want to install latest version from nodejs v.20 tree?
                                    Press <y> to continue or any other key to quit
                                    Trying to fix your installation now. Please be patient.
                                    rm: cannot remove '/usr/share/keyrings/nodesource.gpg'$'\n''/etc/apt/keyrings/nodesource.gpg': No such file or directory
                                    Waiting for ioBroker to shut down - Give me a minute...
                                    *** These repos are active on your system:
                                    Hit:1 http://deb.debian.org/debian bullseye-proposed-updates InRelease
                                    Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                                    Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
                                    Reading package lists... Done
                                    *** Installing ca-certificates, curl and gnupg, just in case they are missing.
                                    *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
                                    deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_20.x nodistro main
                                    Package: nodejs
                                    Pin: origin deb.nodesource.com
                                    Pin-Priority: 1001
                                    *** These repos are active after the adjustments:
                                    Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                                    Hit:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                                    Get:4 https://deb.nodesource.com/node_20.x nodistro InRelease [12.1 kB]
                                    Get:5 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages [8461 B]
                                    Fetched 20.6 kB in 1s (20.3 kB/s)
                                    Installing nodejs now!
                                    Installing the nodejs!
                                    We tried our best to fix your nodejs. Please run iob diag again to verify.
                                    *** RESTARTING ioBroker NOW! ***
                                     Please refresh or restart your browser in a few moments.
                                    • S stauber
                                      Das mach ich auch
                                      /usr/bin/npm            10.8.1
                                      /usr/bin/npx            10.8.1
                                      nodejs:
                                        Version table:
                                      Package: nodejs
                                      Pin-Priority: 1001
                                      #141
                                      node -v
                                      sagt?
                                        node -v
                                        sagt?
                                        stauber
                                        #142
                                        auch 22
                                        • S stauber
                                          auch 22
                                          #143
                                          @stauber
                                          Bitte keine Bildchen von Text.
                                          sudo apt update
                                          sudo apt install nodejs=20.15.1-1nodesource1
