  4. Zigbee iobroker Error while opening serialport
    6.6k
231 Beiträge 28 Kommentatoren 64.1k Aufrufe 24 Beobachtet
  • G Greenhorn
    @meister-mopper
    🤦 Meine Augen waren auch schonmal besser...
    Aber leider gehts immer noch nicht:
    2024-01-14 17:41:08.404 - error: zigbee.0 (2895) Configuration is not consistent with adapter state/backup!
    2024-01-14 17:41:08.405 - error: zigbee.0 (2895) - PAN ID: configured=1964, adapter=1964
    2024-01-14 17:41:08.405 - error: zigbee.0 (2895) - Extended PAN ID: configured=24dddddddfddddab, adapter=00124b002c3a7ef1
    2024-01-14 17:41:08.406 - error: zigbee.0 (2895) - Network Key: configured=01030507090b0d0f00020406080a0c0d, adapter=01030507090b0d0f00020406080a0c0d
    2024-01-14 17:41:08.407 - error: zigbee.0 (2895) - Channel List: configured=11, adapter=11
    2024-01-14 17:41:08.408 - error: zigbee.0 (2895) Please update configuration to prevent further issues.
    2024-01-14 17:41:08.409 - error: zigbee.0 (2895) If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
    2024-01-14 17:41:08.410 - error: zigbee.0 (2895) Re-commissioning your network will require re-pairing of all devices!
    2024-01-14 17:41:08.514 - error: zigbee.0 (2895) Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
    2024-01-14 17:41:08.515 - error: zigbee.0 (2895) Failed to start Zigbee
    2024-01-14 17:41:08.516 - error: zigbee.0 (2895) Error herdsman start
    2024-01-14 17:41:08.210 - info: zigbee.0 (2895) Installed Version: iobroker.zigbee@1.9.7
    #115
    @greenhorn sagte in Zigbee iobroker Error while opening serialport:
    Die PAN ID muss im Adapter angepasst werden.
    G 1 Antwort Letzte Antwort
      Greenhorn
      #116
      Oh je, jetzt wirds noch komplizierter (für mich ;-) )...wie mach ich das ?
      • G Greenhorn
        #117
        @greenhorn
        In den Einstellungen des Adapters schauen was da jetzt drin ist und die andere ID eintragen.
          @greenhorn
          Greenhorn
          #118
          👍 Et jeht ! 😀
          Hatte irgendwo gelesen, man könne sich irgendeine freie PAN ID erstellen.
          Herzlichen Dank für die Hilfe !!!
          • G Greenhorn
            👍 Et jeht ! 😀
            #119
            Bei der Erstinstallation.
            • F Offline
              flodirmann
              #120
              Hallo miteinander,
              ich habe ein scheinbar sehr ähnliches Problem mit meinem "Sonoff Zigbee 3.0 USB Dongle Plus" an einem Raspi 4B, jedoch haben mir die bisherigen Lösungsansätze nicht zu einer Lösung verholfen.
              Der genaue Pfad meines Dongles ist (mit PuTTY ausgelesen):
              /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20231214212123-if00
              mit diesem Pfad in den Einstellungen funktioniert es aber nicht, der Adapter steht auf orange.
              Folgende Fehler sind im Log:
              2024-03-27 19:55:20.975 - error: zigbee.0 (1865) getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
              2024-03-27 19:55:21.147 - info: zigbee.0 (1865) List of port: [{"path":"/dev/ttyACM0","manufacturer":"ITEAD","serialNumber":"20231214212123","pnpId":"usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20231214212123-if00","vendorId":"1a86","productId":"55d4"},{"path":"/dev/ttyAMA0"}]
              2024-03-27 19:55:30.426 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 (force=false, process=true)
              2024-03-27 19:55:30.434 - info: zigbee.0 (1865) Got terminate signal TERMINATE_YOURSELF
              2024-03-27 19:55:30.435 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 send kill signal
              2024-03-27 19:55:30.438 - info: zigbee.0 (1865) cleaned everything up...
              2024-03-27 19:55:30.446 - info: zigbee.0 (1865) Zigbee: disabling joining new devices.
              2024-03-27 19:55:30.500 - warn: zigbee.0 (1865) Failed to stop zigbee during startup
              2024-03-27 19:55:30.501 - info: zigbee.0 (1865) terminating
              2024-03-27 19:55:30.503 - info: zigbee.0 (1865) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              2024-03-27 19:55:30.612 - info: admin.0 (1215) <== Disconnect system.user.admin from ::ffff:192.168.188.195
              2024-03-27 19:55:31.049 - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2024-03-27 19:55:32.851 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 1884
              2024-03-27 19:55:36.840 - info: zigbee.0 (1884) starting. Version 1.10.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.8.0, js-controller: 4.0.19
              2024-03-27 19:55:36.960 - info: zigbee.0 (1884) delete old Backup files. keep only last 10
              2024-03-27 19:55:36.962 - info: zigbee.0 (1884) Starting Zigbee npm ...
              2024-03-27 19:55:37.247 - error: zigbee.0 (1884) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20231314212123-if00'"
              2024-03-27 19:55:37.248 - error: zigbee.0 (1884) Failed to start Zigbee
              2024-03-27 19:55:37.248 - error: zigbee.0 (1884) Error herdsman start
              2024-03-27 19:55:37.631 - info: zigbee.0 (1884) Installed Version: iobroker.zigbee@1.10.1
              2024-03-27 19:55:47.252 - info: zigbee.0 (1884) Try to reconnect. 1 attempts left
              2024-03-27 19:55:47.254 - info: zigbee.0 (1884) Starting Zigbee npm ...
              2024-03-27 19:55:47.272 - error: zigbee.0 (1884) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20231314212123-if00'"
              2024-03-27 19:55:47.276 - error: zigbee.0 (1884) Failed to start Zigbee
              2024-03-27 19:55:47.278 - error: zigbee.0 (1884) Error herdsman start
              2024-03-27 19:55:47.310 - info: zigbee.0 (1884) Installed Version: iobroker.zigbee@1.10.1
              Hier noch meine Einstellungen:
              Könnt Ihr mir dabei weiterhelfen?
              Beste Grüße und Danke im Voraus,
              flo
              MOD-Edit: Logs in Code-Tags setzen
              • F flodirmann
                Hallo miteinander,
                flo
                #121
                @flodirmann sagte in Zigbee iobroker Error while opening serialport:
                Beides steinalt, beides aktualisieren.
                Und den Rest vom Fest auch auf Stand brigen.
                ...plagt euch doch nicht immer mit uralten Versionen herum...
                Auch 'running systems' müssen regelmäßig gewartet werden, damit sie eben weiter 'runnen'.
                • F flodirmann
                  Hallo miteinander,
                  flo
                  #122
                  Das funktioniert deswegen nicht, weil die Meldung
                  volkommen korrekt ist. Die Datei heißt nämlich:
                  "Ich kann aus dämlichen Screenshots nichts kopieren, deswegen darfst du den Fehler nun selber suchen"
                  • F Offline
                    flodirmann
                    #123
                    Danke für die schnelle Antwort.
                    Auch nach den notwendigen Updates bleibt der Fehler bestehen (ich denke mal, innerhalb der Major-Version 18 zu bleiben zählt noch als aktuell?)
                    2024-03-27 21:15:58.928 - info: zigbee.0 (3067) terminating
                    2024-03-27 21:15:58.929 - info: zigbee.0 (3067) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2024-03-27 21:15:59.279 - info: zigbee.0 (3067) terminating
                    2024-03-27 21:15:59.495 - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2024-03-27 21:16:01.859 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 3142
                    2024-03-27 21:16:06.599 - info: zigbee.0 (3142) starting. Version 1.10.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.20.0, js-controller: 5.0.19
                    2024-03-27 21:16:06.701 - info: zigbee.0 (3142) delete old Backup files. keep only last 10
                    2024-03-27 21:16:06.703 - info: zigbee.0 (3142) Starting Zigbee npm ...
                    2024-03-27 21:16:07.105 - error: zigbee.0 (3142) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20231314212123-if00'"
                    2024-03-27 21:16:07.107 - error: zigbee.0 (3142) Failed to start Zigbee
                    2024-03-27 21:16:07.107 - error: zigbee.0 (3142) Error herdsman start
                    2024-03-27 21:16:07.113 - info: zigbee.0 (3142) Installed Version: iobroker.zigbee@1.10.1
                    2024-03-27 21:16:17.113 - info: zigbee.0 (3142) Try to reconnect. 1 attempts left
                    2024-03-27 21:16:17.114 - info: zigbee.0 (3142) Starting Zigbee npm ...
                    2024-03-27 21:16:17.127 - error: zigbee.0 (3142) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20231314212123-if00'"
                    2024-03-27 21:16:17.128 - error: zigbee.0 (3142) Failed to start Zigbee
                    2024-03-27 21:16:17.128 - error: zigbee.0 (3142) Error herdsman start
                    2024-03-27 21:16:17.135 - info: zigbee.0 (3142) Installed Version: iobroker.zigbee@1.10.1
                    @thomas-braun said in Zigbee iobroker Error while opening serialport:
                    Warum eigentlich immer alles so passiv aggressiv?
                    Ich habe doch oben den pfad, wie ihn PuTTY mir ausspuckt, in textform geschrieben:
                    @flodirmann said in Zigbee iobroker Error while opening serialport:
                    Oder was bräuchtest du genauer, um mir weiterhelfen zu können?
                    Thomas BraunT arteckA 2 Antworten Letzte Antwort
                    • F flodirmann
                      #124
                      Der steht aber nicht so in den Einstellungen des Adapters drin. Finde den Tippfehler.
                      Sowas kopiert man auch aus dem Terminal und pinnt das nicht manuell ab.
                      • F flodirmann
                        arteckA Offline
                        arteckA Offline
                        arteck
                        #125
                        @flodirmann wenn du schon abschreibst dann machs richtig und kontrolliere es 5 mal
                        F 1 Antwort Letzte Antwort
                        • arteckA arteck
                          flodirmann
                          #126
                          @arteck
                          Danke für den Hinweis auf meinen, zugegebenermaßen tatsächlich echt vermeidbaren, Fehler. 😖
                          Leider kann ich noch nicht vermelden, ob jetzt alles klappt, weil ich augenscheinlich nebenbei bei den Updates des raspis in den wohl im Forum schon bekannteren udev-Bug hineingelaufen bin, es gibt jetzt kein /by-id/ mehr...
                          Jetzt muss dabei erst mal eine Lösung her.
                          • F flodirmann
                            @arteck
                            #127
                            Aktuelles System verwenden, das hat den Fehler nicht.
                              flodirmann
                              schrieb am zuletzt editiert von flodirmann
                              #128
                              So. Auch nach komplettem Neuaufsetzen des Systems mit Debian 12 Bookworm und dem Korrigieren eigenverschuldeter Rechtschreibfehler (diesmal aus PuTTY direkt rauskopiert) funktioniert es noch nicht besser.
                              Egal ob ich in den Einstellungen den by-id path verwende "/dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20231214212123-if00" oder die alternative Adresse "/dev/ttyACM0", in beiden Fällen tritt der identische Fehler auf:
                              2024-03-28 15:51:59.165 - info: admin.0 (1017) ==> Connected system.user.admin from ::ffff:192.168.188.23
                              2024-03-28 15:51:59.266 - error: zigbee.0 (2510) getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
                              2024-03-28 15:51:59.379 - info: zigbee.0 (2510) List of port: [{"path":"/dev/ttyACM0","manufacturer":"ITEAD","serialNumber":"20231214212123","pnpId":"usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20231214212123-if00","vendorId":"1a86","productId":"55d4"}]
                              2024-03-28 15:52:38.919 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 (force=false, process=true)
                              2024-03-28 15:52:38.926 - info: zigbee.0 (2510) Got terminate signal TERMINATE_YOURSELF
                              2024-03-28 15:52:38.930 - info: zigbee.0 (2510) cleaned everything up...
                              2024-03-28 15:52:38.934 - info: zigbee.0 (2510) Zigbee: disabling joining new devices.
                              2024-03-28 15:52:38.958 - warn: zigbee.0 (2510) Failed to stop zigbee during startup
                              2024-03-28 15:52:38.960 - info: zigbee.0 (2510) terminating
                              2024-03-28 15:52:38.963 - info: zigbee.0 (2510) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                              2024-03-28 15:52:38.967 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 send kill signal
                              2024-03-28 15:52:39.042 - info: admin.0 (1017) <== Disconnect system.user.admin from ::ffff:192.168.188.23
                              2024-03-28 15:52:39.431 - info: zigbee.0 (2510) terminating
                              2024-03-28 15:52:39.519 - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                              2024-03-28 15:52:42.016 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 2586
                              2024-03-28 15:52:45.840 - info: zigbee.0 (2586) starting. Version 1.10.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.12.0, js-controller: 5.0.19
                              2024-03-28 15:52:45.922 - info: zigbee.0 (2586) delete old Backup files. keep only last 10
                              2024-03-28 15:52:45.925 - info: zigbee.0 (2586) Starting Zigbee npm ...
                              2024-03-28 15:52:46.171 - info: zigbee.0 (2586) Installed Version: iobroker.zigbee@1.10.1
                              2024-03-28 15:53:06.711 - error: zigbee.0 (2586) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
                              2024-03-28 15:53:06.712 - error: zigbee.0 (2586) Failed to start Zigbee
                              2024-03-28 15:53:06.712 - error: zigbee.0 (2586) Error herdsman start
                              2024-03-28 15:53:16.717 - info: zigbee.0 (2586) Try to reconnect. 1 attempts left
                              2024-03-28 15:53:16.721 - info: zigbee.0 (2586) Starting Zigbee npm ...
                              2024-03-28 15:53:16.751 - info: zigbee.0 (2586) Installed Version: iobroker.zigbee@1.10.1
                              2024-03-28 15:53:16.959 - error: zigbee.0 (2586) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
                              2024-03-28 15:53:16.960 - error: zigbee.0 (2586) Failed to start Zigbee
                              2024-03-28 15:53:16.961 - error: zigbee.0 (2586) Error herdsman start
                              Hier noch ein Screenshot der Adaptereinstellungen:
                              Könnt ihr mir da irgendwie weiterhelfen? Falls weitere Informationen benötigt werden, gerne Bescheid geben.
                              DJMarc75D AsgothianA 2 Antworten Letzte Antwort
                              • F flodirmann
                                DJMarc75D Offline
                                DJMarc75D Offline
                                DJMarc75
                                #129
                                node: v20.12.0
                                hmpf... da bist Du schon zu aktuell und hast Dein System wohl nicht korrekt aufgesetzt
                                Lehrling seit 1975 !!!
                                • DJMarc75D DJMarc75
                                  node: v20.12.0
                                  flodirmann
                                  #130
                                  @djmarc75
                                  Mensch, na super. Da dachte ich, da 20 ja die aktuellste geradzahlige Major ist...
                                  Also wieder zurück auf 18.x?
                                  DJMarc75D Meister MopperM Thomas BraunT 3 Antworten Letzte Antwort
                                  • F flodirmann
                                    @djmarc75
                                    DJMarc75D Offline
                                    DJMarc75D Offline
                                    DJMarc75
                                    #131
                                    jawoll :)
                                    • F flodirmann
                                      @djmarc75
                                      Meister MopperM Online
                                      Meister Mopper
                                      #132
                                      Mit dem "Einzeiler" aus der Doku wäre das auf einem neuen System nicht passiert.
                                      Proxmox und HA ...
                                      • F flodirmann
                                        @djmarc75
                                        #133
                                        iob nodejs-update 18
                                        • F flodirmann
                                          AsgothianA Offline
                                          AsgothianA Offline
                                          Asgothian
                                          #134
                                          Stell mal bitte die Firmware im zigbee-Adapter auf EZSP (oder ähnlich) um - der sonoff dongle V2 nutzt meines Wissens nach nicht den TI Chip Satz
                                          A.
