  4. Zigbee iobroker Error while opening serialport
    6.6k
231 Beiträge 28 Kommentatoren 64.1k Aufrufe 24 Beobachtet
    @greenhorn
    Genaues Log vom Adapter-Start?
    Greenhorn
    #109
    Wie mein Username schon sagt bin ich ein absolutes Greenhorn und google mir mein Raspberry-Wissen zusammen. Zum Auslesen der Log-Datei des IOBrokers habe ich jetzt aber keinen Befehl gefunden...
    • G Greenhorn
      #110
      @greenhorn
      iob logs --watch
      in dein Terminal hacken und dann den Adapter starten.
      G 1 Antwort Letzte Antwort
        @greenhorn
        iob logs --watch
        Greenhorn
        #111
        @thomas-braun sagte in Zigbee iobroker Error while opening serialport:
        Hoffe, das ist brauchbar:
        iob logs --watch
        2024-01-14 17:19:42.262 - info: host.iobroker "system.adapter.zigbee.0" enabled
        2024-01-14 17:19:42.390 - info: host.iobroker instance system.adapter.zigbee.0 started with pid 2671
        2024-01-14 17:19:44.883 - warn: shelly.0 (718) [authEnabled] 192.168.178.37 (shellyplus1pm / shellyplus1pm-b0b21c1b1e9c / shellyplus1pm#b0b21c1b1e9c#1): This device is not protected via restricted login (see adapter documentation for details)
        2024-01-14 17:19:46.988 - info: zigbee.0 (2671) starting. Version 1.9.7 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.17.1, js-controller: 4.0.24
        2024-01-14 17:19:47.137 - info: zigbee.0 (2671) delete old Backup files. keep only last 10
        2024-01-14 17:19:47.139 - info: zigbee.0 (2671) Starting Zigbee npm ...
        2024-01-14 17:19:47.464 - error: zigbee.0 (2671) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_c4d856ba1ab6ed1196ded60ea8669f5d-if00-port0'"
        2024-01-14 17:19:47.465 - error: zigbee.0 (2671) Failed to start Zigbee
        2024-01-14 17:19:47.466 - error: zigbee.0 (2671) Error herdsman start
        2024-01-14 17:19:47.930 - info: zigbee.0 (2671) Installed Version: iobroker.zigbee@1.9.7
        Thomas BraunT Meister MopperM 2 Antworten Letzte Antwort
        • G Greenhorn
          iob logs --watch
          #112
          @greenhorn
          Finde den Unterschied:
          Richtig wäre:
          /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_c4d856ba1ab6ed1196ded60ea8669f5d-if00-port0
          • G Greenhorn
            iob logs --watch
            Meister MopperM Online
            Meister Mopper
            #113
            @greenhorn
            As i thought.
            Proxmox und HA ...
              @greenhorn
              As i thought.
              Greenhorn
              #114
              @meister-mopper
              🤦 Meine Augen waren auch schonmal besser...
              Aber leider gehts immer noch nicht:
              2024-01-14 17:41:08.404 - error: zigbee.0 (2895) Configuration is not consistent with adapter state/backup!
              2024-01-14 17:41:08.405 - error: zigbee.0 (2895) - PAN ID: configured=1964, adapter=1964
              2024-01-14 17:41:08.405 - error: zigbee.0 (2895) - Extended PAN ID: configured=24dddddddfddddab, adapter=00124b002c3a7ef1
              2024-01-14 17:41:08.406 - error: zigbee.0 (2895) - Network Key: configured=01030507090b0d0f00020406080a0c0d, adapter=01030507090b0d0f00020406080a0c0d
              2024-01-14 17:41:08.407 - error: zigbee.0 (2895) - Channel List: configured=11, adapter=11
              2024-01-14 17:41:08.408 - error: zigbee.0 (2895) Please update configuration to prevent further issues.
              2024-01-14 17:41:08.409 - error: zigbee.0 (2895) If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
              2024-01-14 17:41:08.410 - error: zigbee.0 (2895) Re-commissioning your network will require re-pairing of all devices!
              2024-01-14 17:41:08.514 - error: zigbee.0 (2895) Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
              2024-01-14 17:41:08.515 - error: zigbee.0 (2895) Failed to start Zigbee
              2024-01-14 17:41:08.516 - error: zigbee.0 (2895) Error herdsman start
              2024-01-14 17:41:08.210 - info: zigbee.0 (2895) Installed Version: iobroker.zigbee@1.9.7
              • G Greenhorn
                @meister-mopper
                #115
                @greenhorn sagte in Zigbee iobroker Error while opening serialport:
                Die PAN ID muss im Adapter angepasst werden.
                  Greenhorn
                  #116
                  Oh je, jetzt wirds noch komplizierter (für mich ;-) )...wie mach ich das ?
                  • G Greenhorn
                    #117
                    @greenhorn
                    In den Einstellungen des Adapters schauen was da jetzt drin ist und die andere ID eintragen.
                      @greenhorn
                      Greenhorn
                      #118
                      👍 Et jeht ! 😀
                      Hatte irgendwo gelesen, man könne sich irgendeine freie PAN ID erstellen.
                      Herzlichen Dank für die Hilfe !!!
                      • G Greenhorn
                        👍 Et jeht ! 😀
                        #119
                        Bei der Erstinstallation.
                        • F Offline
                          flodirmann
                          #120
                          Hallo miteinander,
                          ich habe ein scheinbar sehr ähnliches Problem mit meinem "Sonoff Zigbee 3.0 USB Dongle Plus" an einem Raspi 4B, jedoch haben mir die bisherigen Lösungsansätze nicht zu einer Lösung verholfen.
                          Der genaue Pfad meines Dongles ist (mit PuTTY ausgelesen):
                          /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20231214212123-if00
                          mit diesem Pfad in den Einstellungen funktioniert es aber nicht, der Adapter steht auf orange.
                          Folgende Fehler sind im Log:
                          2024-03-27 19:55:20.975 - error: zigbee.0 (1865) getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
                          2024-03-27 19:55:21.147 - info: zigbee.0 (1865) List of port: [{"path":"/dev/ttyACM0","manufacturer":"ITEAD","serialNumber":"20231214212123","pnpId":"usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20231214212123-if00","vendorId":"1a86","productId":"55d4"},{"path":"/dev/ttyAMA0"}]
                          2024-03-27 19:55:30.426 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 (force=false, process=true)
                          2024-03-27 19:55:30.434 - info: zigbee.0 (1865) Got terminate signal TERMINATE_YOURSELF
                          2024-03-27 19:55:30.435 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 send kill signal
                          2024-03-27 19:55:30.438 - info: zigbee.0 (1865) cleaned everything up...
                          2024-03-27 19:55:30.446 - info: zigbee.0 (1865) Zigbee: disabling joining new devices.
                          2024-03-27 19:55:30.500 - warn: zigbee.0 (1865) Failed to stop zigbee during startup
                          2024-03-27 19:55:30.501 - info: zigbee.0 (1865) terminating
                          2024-03-27 19:55:30.503 - info: zigbee.0 (1865) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                          2024-03-27 19:55:30.612 - info: admin.0 (1215) <== Disconnect system.user.admin from ::ffff:192.168.188.195
                          2024-03-27 19:55:31.049 - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                          2024-03-27 19:55:32.851 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 1884
                          2024-03-27 19:55:36.840 - info: zigbee.0 (1884) starting. Version 1.10.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.8.0, js-controller: 4.0.19
                          2024-03-27 19:55:36.960 - info: zigbee.0 (1884) delete old Backup files. keep only last 10
                          2024-03-27 19:55:36.962 - info: zigbee.0 (1884) Starting Zigbee npm ...
                          2024-03-27 19:55:37.247 - error: zigbee.0 (1884) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20231314212123-if00'"
                          2024-03-27 19:55:37.248 - error: zigbee.0 (1884) Failed to start Zigbee
                          2024-03-27 19:55:37.248 - error: zigbee.0 (1884) Error herdsman start
                          2024-03-27 19:55:37.631 - info: zigbee.0 (1884) Installed Version: iobroker.zigbee@1.10.1
                          2024-03-27 19:55:47.252 - info: zigbee.0 (1884) Try to reconnect. 1 attempts left
                          2024-03-27 19:55:47.254 - info: zigbee.0 (1884) Starting Zigbee npm ...
                          2024-03-27 19:55:47.272 - error: zigbee.0 (1884) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20231314212123-if00'"
                          2024-03-27 19:55:47.276 - error: zigbee.0 (1884) Failed to start Zigbee
                          2024-03-27 19:55:47.278 - error: zigbee.0 (1884) Error herdsman start
                          2024-03-27 19:55:47.310 - info: zigbee.0 (1884) Installed Version: iobroker.zigbee@1.10.1
                          Hier noch meine Einstellungen:
                          Könnt Ihr mir dabei weiterhelfen?
                          Beste Grüße und Danke im Voraus,
                          flo
                          MOD-Edit: Logs in Code-Tags setzen
                          • F flodirmann
                            Hallo miteinander,
                            flo
                            #121
                            @flodirmann sagte in Zigbee iobroker Error while opening serialport:
                            Beides steinalt, beides aktualisieren.
                            Und den Rest vom Fest auch auf Stand brigen.
                            ...plagt euch doch nicht immer mit uralten Versionen herum...
                            Auch 'running systems' müssen regelmäßig gewartet werden, damit sie eben weiter 'runnen'.
                            • F flodirmann
                              Hallo miteinander,
                              flo
                              #122
                              Das funktioniert deswegen nicht, weil die Meldung
                              volkommen korrekt ist. Die Datei heißt nämlich:
                              "Ich kann aus dämlichen Screenshots nichts kopieren, deswegen darfst du den Fehler nun selber suchen"
                              • F Offline
                                flodirmann
                                #123
                                Danke für die schnelle Antwort.
                                Auch nach den notwendigen Updates bleibt der Fehler bestehen (ich denke mal, innerhalb der Major-Version 18 zu bleiben zählt noch als aktuell?)
                                2024-03-27 21:15:58.928 - info: zigbee.0 (3067) terminating
                                2024-03-27 21:15:58.929 - info: zigbee.0 (3067) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                2024-03-27 21:15:59.279 - info: zigbee.0 (3067) terminating
                                2024-03-27 21:15:59.495 - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                2024-03-27 21:16:01.859 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 3142
                                2024-03-27 21:16:06.599 - info: zigbee.0 (3142) starting. Version 1.10.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.20.0, js-controller: 5.0.19
                                2024-03-27 21:16:06.701 - info: zigbee.0 (3142) delete old Backup files. keep only last 10
                                2024-03-27 21:16:06.703 - info: zigbee.0 (3142) Starting Zigbee npm ...
                                2024-03-27 21:16:07.105 - error: zigbee.0 (3142) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20231314212123-if00'"
                                2024-03-27 21:16:07.107 - error: zigbee.0 (3142) Failed to start Zigbee
                                2024-03-27 21:16:07.107 - error: zigbee.0 (3142) Error herdsman start
                                2024-03-27 21:16:07.113 - info: zigbee.0 (3142) Installed Version: iobroker.zigbee@1.10.1
                                2024-03-27 21:16:17.113 - info: zigbee.0 (3142) Try to reconnect. 1 attempts left
                                2024-03-27 21:16:17.114 - info: zigbee.0 (3142) Starting Zigbee npm ...
                                2024-03-27 21:16:17.127 - error: zigbee.0 (3142) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20231314212123-if00'"
                                2024-03-27 21:16:17.128 - error: zigbee.0 (3142) Failed to start Zigbee
                                2024-03-27 21:16:17.128 - error: zigbee.0 (3142) Error herdsman start
                                2024-03-27 21:16:17.135 - info: zigbee.0 (3142) Installed Version: iobroker.zigbee@1.10.1
                                @thomas-braun said in Zigbee iobroker Error while opening serialport:
                                Warum eigentlich immer alles so passiv aggressiv?
                                Ich habe doch oben den pfad, wie ihn PuTTY mir ausspuckt, in textform geschrieben:
                                @flodirmann said in Zigbee iobroker Error while opening serialport:
                                Oder was bräuchtest du genauer, um mir weiterhelfen zu können?
                                Thomas BraunT arteckA 2 Antworten Letzte Antwort
                                • F flodirmann
                                  #124
                                  Der steht aber nicht so in den Einstellungen des Adapters drin. Finde den Tippfehler.
                                  Sowas kopiert man auch aus dem Terminal und pinnt das nicht manuell ab.
                                  • F flodirmann
                                    arteckA Offline
                                    arteckA Offline
                                    arteck
                                    #125
                                    @flodirmann wenn du schon abschreibst dann machs richtig und kontrolliere es 5 mal
                                    F 1 Antwort Letzte Antwort
                                    • arteckA arteck
                                      flodirmann
                                      #126
                                      @arteck
                                      Danke für den Hinweis auf meinen, zugegebenermaßen tatsächlich echt vermeidbaren, Fehler. 😖
                                      Leider kann ich noch nicht vermelden, ob jetzt alles klappt, weil ich augenscheinlich nebenbei bei den Updates des raspis in den wohl im Forum schon bekannteren udev-Bug hineingelaufen bin, es gibt jetzt kein /by-id/ mehr...
                                      Jetzt muss dabei erst mal eine Lösung her.
                                      • F flodirmann
                                        @arteck
                                        #127
                                        Aktuelles System verwenden, das hat den Fehler nicht.
                                          flodirmann
                                          schrieb am zuletzt editiert von flodirmann
                                          #128
                                          So. Auch nach komplettem Neuaufsetzen des Systems mit Debian 12 Bookworm und dem Korrigieren eigenverschuldeter Rechtschreibfehler (diesmal aus PuTTY direkt rauskopiert) funktioniert es noch nicht besser.
                                          Egal ob ich in den Einstellungen den by-id path verwende "/dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20231214212123-if00" oder die alternative Adresse "/dev/ttyACM0", in beiden Fällen tritt der identische Fehler auf:
                                          2024-03-28 15:51:59.165 - info: admin.0 (1017) ==> Connected system.user.admin from ::ffff:192.168.188.23
                                          2024-03-28 15:51:59.266 - error: zigbee.0 (2510) getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
                                          2024-03-28 15:51:59.379 - info: zigbee.0 (2510) List of port: [{"path":"/dev/ttyACM0","manufacturer":"ITEAD","serialNumber":"20231214212123","pnpId":"usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20231214212123-if00","vendorId":"1a86","productId":"55d4"}]
                                          2024-03-28 15:52:38.919 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 (force=false, process=true)
                                          2024-03-28 15:52:38.926 - info: zigbee.0 (2510) Got terminate signal TERMINATE_YOURSELF
                                          2024-03-28 15:52:38.930 - info: zigbee.0 (2510) cleaned everything up...
                                          2024-03-28 15:52:38.934 - info: zigbee.0 (2510) Zigbee: disabling joining new devices.
                                          2024-03-28 15:52:38.958 - warn: zigbee.0 (2510) Failed to stop zigbee during startup
                                          2024-03-28 15:52:38.960 - info: zigbee.0 (2510) terminating
                                          2024-03-28 15:52:38.963 - info: zigbee.0 (2510) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                          2024-03-28 15:52:38.967 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 send kill signal
                                          2024-03-28 15:52:39.042 - info: admin.0 (1017) <== Disconnect system.user.admin from ::ffff:192.168.188.23
                                          2024-03-28 15:52:39.431 - info: zigbee.0 (2510) terminating
                                          2024-03-28 15:52:39.519 - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                          2024-03-28 15:52:42.016 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 2586
                                          2024-03-28 15:52:45.840 - info: zigbee.0 (2586) starting. Version 1.10.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.12.0, js-controller: 5.0.19
                                          2024-03-28 15:52:45.922 - info: zigbee.0 (2586) delete old Backup files. keep only last 10
                                          2024-03-28 15:52:45.925 - info: zigbee.0 (2586) Starting Zigbee npm ...
                                          2024-03-28 15:52:46.171 - info: zigbee.0 (2586) Installed Version: iobroker.zigbee@1.10.1
                                          2024-03-28 15:53:06.711 - error: zigbee.0 (2586) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
                                          2024-03-28 15:53:06.712 - error: zigbee.0 (2586) Failed to start Zigbee
                                          2024-03-28 15:53:06.712 - error: zigbee.0 (2586) Error herdsman start
                                          2024-03-28 15:53:16.717 - info: zigbee.0 (2586) Try to reconnect. 1 attempts left
                                          2024-03-28 15:53:16.721 - info: zigbee.0 (2586) Starting Zigbee npm ...
                                          2024-03-28 15:53:16.751 - info: zigbee.0 (2586) Installed Version: iobroker.zigbee@1.10.1
                                          2024-03-28 15:53:16.959 - error: zigbee.0 (2586) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
                                          2024-03-28 15:53:16.960 - error: zigbee.0 (2586) Failed to start Zigbee
                                          2024-03-28 15:53:16.961 - error: zigbee.0 (2586) Error herdsman start
                                          Hier noch ein Screenshot der Adaptereinstellungen:
                                          Könnt ihr mir da irgendwie weiterhelfen? Falls weitere Informationen benötigt werden, gerne Bescheid geben.
                                          DJMarc75D AsgothianA 2 Antworten Letzte Antwort
