  4. [ESPHome] Beta release
    6.3k
591 Beiträge 48 Kommentatoren 230.8k Aufrufe 39 Beobachtet
  • A arne007
    @thomas-braun falsche Version installiert? Wenn ja, welche sollte ich nehmen?
    #401
    @arne007
    Steht in meiner Signatur.
    Lies insbesondere den Teil mit den falschen Pfaden besonders gründlich.
    Johannes BauerstatterJ 1 Antwort Letzte Antwort
      @arne007
      Johannes BauerstatterJ Offline
      #402
      Hallo, irgendwie mags bei mir auch nicht. Welche Version ist falsch?
      npm: 6.14.15
      node: 14.18.2
      python: 3.9.7
      $ ./iobroker add esphome  --host raspberrypi
      NPM version: 6.14.15
      npm install iobroker.esphome@0.2.4 --loglevel error --prefix "/opt/iobroker" (System call)
      Exception:
      Traceback (most recent call last):  File "/tmp/tmpvlou37m4/pip.zip/pip/basecommand.py", line 215, in main    status = self.run(options, args)  File "/tmp/tmpvlou37m4/pip.zip/pip/commands/install.py", line 272, in run    with self._build_session(options) as session:  File "/tmp/tmpvlou37m4/pip.zip/pip/basecommand.py", line 66, in _build_session    session = PipSession(  File "/tmp/tmpvlou37m4/pip.zip/pip/download.py", line 329, in __init__    self.headers["User-Agent"] = user_agent()  File "/tmp/tmpvlou37m4/pip.zip/pip/download.py", line 93, in user_agent    from pip._vendor import distro  File "<frozen importlib._bootstrap>", line 1007, in _find_and_load  File "<frozen importlib._bootstrap>", line 986, in _find_and_load_unlocked  File "<frozen importlib._bootstrap>", line 664, in _load_unlocked  File "<frozen importlib._bootstrap>", line 627, in _load_backward_compatible  File "<frozen zipimport>", line 259, in load_module  File "/tmp/tmpvlou37m4/pip.zip/pip/_vendor/distro.py", line 1050, in <module>    _distro = LinuxDistribution()  File "/tmp/tmpvlou37m4/pip.zip/pip/_vendor/distro.py", line 593, in __init__    self._lsb_release_info = self._get_lsb_release_info() \  File "/tmp/tmpvlou37m4/pip.zip/pip/_vendor/distro.py", line 931, in _get_lsb_release_info    raise subprocess.CalledProcessError(code, cmd, stdout, stderr)subprocess.CalledProcessError: Command 'lsb_release -a' returned non-zero exit status 1.
        File "/opt/iobroker/node_modules/nopy/src/get-pip.py", line 20061, in <module>
          main()
        File "/opt/iobroker/node_modules/nopy/src/get-pip.py", line 194, in main    bootstrap(tmpdir=tmpdir)
        File "/opt/iobroker/node_modules/nopy/src/get-pip.py", line 172, in bootstrap    sys.exit(pip.main(["install", "--upgrade"] + args))  File "/tmp/tmpvlou37m4/pip.zip/pip/__init__.py", line 233, in main  File "/tmp/tmpvlou37m4/pip.zip/pip/basecommand.py", line 248, in main  File "/tmp/tmpvlou37m4/pip.zip/pip/basecommand.py", line 66, in _build_session  File "/tmp/tmpvlou37m4/pip.zip/pip/download.py", line 329, in __init__
        File "/tmp/tmpvlou37m4/pip.zip/pip/download.py", line 93, in user_agent  File "<frozen importlib._bootstrap>", line 1007, in _find_and_load  File "<frozen importlib._bootstrap>", line 986, in _find_and_load_unlocked  File "<frozen importlib._bootstrap>", line 664, in _load_unlocked  File "<frozen importlib._bootstrap>", line 627, in _load_backward_compatible
        File "<frozen zipimport>", line 259, in load_module  File "/tmp/tmpvlou37m4/pip.zip/pip/_vendor/distro.py", line 1050, in <module>  File "/tmp/tmpvlou37m4/pip.zip/pip/_vendor/distro.py", line 593, in __init__  File "/tmp/tmpvlou37m4/pip.zip/pip/_vendor/distro.py", line 931, in _get_lsb_release_info
      Error: Exited with code 1.
          at ChildProcess.<anonymous> (/opt/iobroker/node_modules/nopy/src/api.js:277:20)    at ChildProcess.emit (events.js:400:28)    at maybeClose (internal/child_process.js:1058:16)    at Process.ChildProcess._handle.onexit (internal/child_process.js:293:5)
      npm ERR! code ELIFECYCLE
      npm ERR! errno 1
      npm ERR! iobroker.esphome@0.2.4 install: `npip install`
      npm ERR! Exit status 1npm ERR! npm ERR! Failed at the iobroker.esphome@0.2.4 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
      npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2021-12-03T11_34_34_767Z-debug.log
      ERROR: host.raspberrypi Cannot install iobroker.esphome@0.2.4: 1
      • Johannes BauerstatterJ Johannes Bauerstatter
        npm: 6.14.15
        node: 14.18.2
        python: 3.9.7
        Exception:
            main()
        npm ERR! errno 1
        #403
        @johannes-bauerstatter sagte in [ESPHome] Beta release:
        lsb_release -a
        Was kommt da in der Konsole zurück?
          lsb_release -a
          #404
          pi@raspberrypi:~ $ lsb_release -a
            File "/usr/bin/lsb_release", line 25, in <module>
              import lsb_release
          ModuleNotFoundError: No module named 'lsb_release'
                import lsb_release
            #405
            Da ist irgendwas kaputt.
            sudo apt update
            sudo apt install --reinstall lsb-release
              sudo apt update
              schrieb am zuletzt editiert von Johannes Bauerstatter
              #406
              Ist eine ganz frische Installation auf einem Raspi 4.
              pi@raspberrypi:~ $ sudo apt install --reinstall lsb-release
              Reading package lists... Done
              Building dependency tree... Done
              0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 0 not upgraded.
              Need to get 28.1 kB of archives.
              After this operation, 0 B of additional disk space will be used.
              Get:1 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf lsb-release all 11.1.0+rpi1 [28.1 kB]
              Fetched 28.1 kB in 1s (19.0 kB/s)
                File "/usr/bin/apt-listchanges", line 29, in <module>
                  import apt_pkg
              ModuleNotFoundError: No module named 'apt_pkg'
              (Reading database ... 50809 files and directories currently installed.)
              Preparing to unpack .../lsb-release_11.1.0+rpi1_all.deb ...
              Unpacking lsb-release (11.1.0+rpi1) over (11.1.0+rpi1) ...
              Setting up lsb-release (11.1.0+rpi1) ...
              Processing triggers for man-db (2.9.4-2) ...
              pi@raspberrypi:~ $
              Exception:Traceback (most recent call last):  File "/tmp/tmpys8yyc8z/pip.zip/pip/basecommand.py", line 215, in main    status = self.run(options, args)  File "/tmp/tmpys8yyc8z/pip.zip/pip/commands/install.py", line 272, in run    with self._build_session(options) as session:  File "/tmp/tmpys8yyc8z/pip.zip/pip/basecommand.py", line 66, in _build_session    session = PipSession(  File "/tmp/tmpys8yyc8z/pip.zip/pip/download.py", line 329, in __init__    self.headers["User-Agent"] = user_agent()  File "/tmp/tmpys8yyc8z/pip.zip/pip/download.py", line 93, in user_agent    from pip._vendor import distro  File "<frozen importlib._bootstrap>", line 1007, in _find_and_load  File "<frozen importlib._bootstrap>", line 986, in _find_and_load_unlocked  File "<frozen importlib._bootstrap>", line 664, in _load_unlocked  File "<frozen importlib._bootstrap>", line 627, in _load_backward_compatible  File "<frozen zipimport>", line 259, in load_module  File "/tmp/tmpys8yyc8z/pip.zip/pip/_vendor/distro.py", line 1050, in <module>    _distro = LinuxDistribution()  File "/tmp/tmpys8yyc8z/pip.zip/pip/_vendor/distro.py", line 593, in __init__    self._lsb_release_info = self._get_lsb_release_info() \  File "/tmp/tmpys8yyc8z/pip.zip/pip/_vendor/distro.py", line 931, in _get_lsb_release_info    raise subprocess.CalledProcessError(code, cmd, stdout, stderr)subprocess.CalledProcessError: Command 'lsb_release -a' returned non-zero exit status 1.
              Traceback (most recent call last):  File "/opt/iobroker/node_modules/nopy/src/get-pip.py", line 20061, in <module>
                  main()  File "/opt/iobroker/node_modules/nopy/src/get-pip.py", line 194, in main    bootstrap(tmpdir=tmpdir)  File "/opt/iobroker/node_modules/nopy/src/get-pip.py", line 172, in bootstrap    sys.exit(pip.main(["install", "--upgrade"] + args))  File "/tmp/tmpys8yyc8z/pip.zip/pip/__init__.py", line 233, in main  File "/tmp/tmpys8yyc8z/pip.zip/pip/basecommand.py", line 248, in main  File "/tmp/tmpys8yyc8z/pip.zip/pip/basecommand.py", line 66, in _build_session  File "/tmp/tmpys8yyc8z/pip.zip/pip/download.py", line 329, in __init__  File "/tmp/tmpys8yyc8z/pip.zip/pip/download.py", line 93, in user_agent  File "<frozen importlib._bootstrap>", line 1007, in _find_and_load  File "<frozen importlib._bootstrap>", line 986, in _find_and_load_unlocked  File "<frozen importlib._bootstrap>", line 664, in _load_unlocked  File "<frozen importlib._bootstrap>", line 627, in _load_backward_compatible  File "<frozen zipimport>", line 259, in load_module  File "/tmp/tmpys8yyc8z/pip.zip/pip/_vendor/distro.py", line 1050, in <module>  File "/tmp/tmpys8yyc8z/pip.zip/pip/_vendor/distro.py", line 593, in __init__  File "/tmp/tmpys8yyc8z/pip.zip/pip/_vendor/distro.py", line 931, in _get_lsb_release_infosubprocess.CalledProcessError: Command 'lsb_release -a' returned non-zero exit status 1.
              Error: Exited with code 1.    at ChildProcess.<anonymous> (/opt/iobroker/node_modules/nopy/src/api.js:277:20)    at ChildProcess.emit (events.js:400:28)
              npm ERR! errno 1
              npm ERR! iobroker.esphome@0.2.4 install: `npip install`npm ERR! Exit status 1
              npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2021-12-03T15_55_36_557Z-debug.log
                    import apt_pkg
                pi@raspberrypi:~ $
                npm ERR! errno 1
                #407
                ModuleNotFoundError: No module named 'apt_pkg'        (Reading database ... 50809 files and directories currently installed.)
                Gaaaaaaanz merkwürdige Meldungen. Was zur Hölle hast du da wie installiert?
                Ich würd's nochmal ganz frisch installieren.
                Johannes BauerstatterJ O 2 Antworten Letzte Antwort
                  #408
                  @thomas-braun Ok. Welche Python Version soll ich nehmen?
                    #409
                    Die vorgesehene/vorinstallierte?
                    Da ist was total schräg bei dir. Hier ist das ganz fluffig:
                    echad@chet:~ $ iobroker install esphome
                    NPM version: 8.1.4
                    host.chet install adapter esphome
                    upload [5] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/words.js words.js application/javascript
                    upload [4] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/style.css style.css text/css
                    upload [3] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/index_m.html index_m.html text/html
                    upload [2] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/img/dashboard.png img/dashboard.png image/png
                    upload [1] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/esphome.png esphome.png image/png
                    upload [0] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/admin.d.ts admin.d.ts video/mp2t
                    host.chet object system.adapter.esphome created/updated
                    Aus der Readme:
                    Required
                    • NodeJS >= 12.x
                    • Python >=3.7, <4.0
                    • API is activated in YAML
                      Anzic
                      schrieb am zuletzt editiert von Anzic
                      #410
                      Switched to NodeJS version 14 frome 12. The dashboard stopped working. Although the adapter itself works. There is such an error in the log:
                      esphome.0
                      2021-12-03 19:55:22.625	warn	ESPHome Dashboard deactivated
                      esphome.0
                      2021-12-03 19:55:22.589	error	[dashboardProcess ERROR] from esphome.__main__ import mainModuleNotFoundError: No module named 'esphome'
                      esphome.0
                      2021-12-03 19:55:22.588	error	[dashboardProcess ERROR] Traceback (most recent call last): File "/opt/iobroker/node_modules/iobroker.esphome/python_modules/bin/esphome", line 5, in <module>
                      I try to execute iobroker rebuild esphome and iobroker rebuild esphome --install I get this error:
                      root@iobroker:/opt/iobroker# iobroker rebuild esphome --install
                      npm install --loglevel error --production (System call1) in "/opt/iobroker/node_modules/iobroker.esphome"
                      /usr/bin/python3: No module named pip
                      npm ERR! errno 1
                      npm ERR!
                      npm ERR!     /opt/iobroker/.npm/_logs/2021-12-03T17_03_35_839Z-debug.log
                      What you need to do to "rebuild" the adapter and the dashboard works
                      Docker image baunet 6.0.0beta1
                      I managed it myself. this command helped - sudo apt install python3-pip
                        NPM version: 8.1.4
                        Aus der Readme:
                        Required
                        • NodeJS >= 12.x
                        marsmännchen
                        #411
                        @Dutchman
                        Danke für die Aktualisierung. Funktioniert jetzt auf dem Slave.
                        Aber hast du vielleicht eine Idee darüber :
                        https://forum.iobroker.net/topic/49960/esphome-probe-request-unsuccessful
                        MfG
                        Patrick
                        Raspberry Pi 4 8GB, Debian 11, js-controller: 5.0.12, Nodejs: v18.18.2, NPM: 9.8.1 (Multihost),
                        Wago PFC200 mit Dali Lichtsteuerung.
                        • FeuersturmF Offline
                          FeuersturmF Offline
                          Feuersturm
                          schrieb am zuletzt editiert von Feuersturm
                          #412
                          @Dutchman Ich hatte heute folgende Fehlermeldung im Log
                          Ist für die Fargebung rot / gelb der Adapter oder der Admin verantwortlich? Warum wird beim esphome Fehler gelb statt z.B. des Orange (wie bei den Warnungen ) verwendet?
                          Hier mal der Fehler in lesbarer Form ;-)
                          Bisher hab ich es noch nicht gesehen, dass innerhalb einer Warnung / Fehlers die Farbe wechselt.
                          • FeuersturmF Feuersturm
                            #413
                            Hab heute den Pi 5x neu aufgesetzt und bring es einfach nicht zum laufen. Iobroker läuft.
                            Bei einer Installation war nach 4h Schluss.
                            Bevor ich jetzt wieder alles mache.
                            So wäre meine Ausgangslage:
                            Linux raspberrypi 5.10.63-v7l+ #1488 SMP Thu Nov 18 16:15:28 GMT 2021 armv7l
                            pi@raspberrypi:~ $ npm -v
                            6.14.15
                            pi@raspberrypi:~ $ node -v
                            v14.18.2
                            pi@raspberrypi:~ $ python
                            Python 2.7.18 (default, Jul 14 2021, 08:11:37)
                            [GCC 10.2.1 20210110] on linux2
                            Type "help", "copyright", "credits" or "license" for more information.
                            >>> quit()
                            pi@raspberrypi:~ $ python3
                            Python 3.9.2 (default, Mar 12 2021, 04:06:34)
                            >>> quit()
                            pi@raspberrypi:~ $
                            Ist das so OK? Soll ich lieber im Broker den Adapter installieren oder per npm i ....?
                              6.14.15
                              v14.18.2
                              >>> quit()
                              >>> quit()
                              pi@raspberrypi:~ $
                              #414
                              Was soll das aussagen?
                              Die Versionsnummer sehen aber i. O. aus.
                                #415
                                @thomas-braun Der Adapter hat im Iobroker 4h lang installiert und hat sich dann beendet ohne das es installiert wurde. Ich versuch es nochmal.
                                  #416
                                  Und wie hast du das gemacht?
                                  Entweder über die Admin-GUI oder in der Konsole per
                                  Das Beta-Repo muss allerdings dazu aktiv sein.
                                    #417
                                    @thomas-braun Habs über die UI gemacht. Jetzt hab ich es mal über die Konsole per
                                    gestartet.
                                          creating build/temp.linux-armv7l-3.9
                                          creating build/temp.linux-armv7l-3.9/c
                                          arm-linux-gnueabihf-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -DUSE__THREAD -DHAVE_SYNC_SYNCHRONIZE -I/usr/include/python3.9 -c c/_cffi_backend.c -o build/temp.linux-armv7l-3.9/c/_cffi_backend.o
                                          c/_cffi_backend.c:2:10: fatal error: Python.h: No such file or directory
                                              2 | #include <Python.h>
                                          compilation terminated.
                                          error: command '/usr/bin/arm-linux-gnueabihf-gcc' failed with exit code 1
                                      ERROR: Command errored out with exit status 1: /usr/bin/python3 -u -c 'import io, os, sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-5ijkwnli/cffi_16d10301de7c4069acead825ae282b6b/setup.py'"'"'; __file__='"'"'/tmp/pip-install-5ijkwnli/cffi_16d10301de7c4069acead825ae282b6b/setup.py'"'"';f = getattr(tokenize, '"'"'open'"'"', open)(__file__) if os.path.exists(__file__) else io.StringIO('"'"'from setuptools import setup; setup()'"'"');code = f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-opvq9x1b/install-record.txt --single-version-externally-managed --prefix /tmp/pip-build-env-lf7bqq4f/overlay --compile --install-headers /tmp/pip-build-env-lf7bqq4f/overlay/include/python3.9/cffi Check the logs for full command output.
                                    WARNING: Discarding https://files.pythonhosted.org/packages/9b/77/461087a514d2e8ece1c975d8216bc03f7048e6090c5166bc34115afdaa53/cryptography-3.4.7.tar.gz#sha256=3d10de8116d25649631977cb37da6cbdd2d6fa0e0281d014a5b7d337255ca713 (from https://pypi.org/simple/cryptography/) (requires-python:>=3.6). Command errored out with exit status 1: /usr/bin/python3 /tmp/pip-standalone-pip-eo94u2mi/__env_pip__.zip/pip install --ignore-installed --no-user --prefix /tmp/pip-build-env-lf7bqq4f/overlay --no-warn-script-location --no-binary :none: --only-binary :none: -i https://pypi.org/simple -- 'setuptools>=40.6.0' wheel 'cffi>=1.12; platform_python_implementation != '"'"'PyPy'"'"'' 'setuptools-rust>=0.11.4' Check the logs for full command output.
                                    pi@raspberrypi:~ $ iobroker update
                                    Used repository: Beta (latest)
                                    hash unchanged, use cached sources
                                    update done
                                    Adapter    "admin"         : 5.2.1    , installed 5.2.1
                                    Adapter    "backitup"      : 2.2.2    , installed 2.2.2
                                    Adapter    "discovery"     : 2.7.5    , installed 2.7.5
                                    Adapter    "esphome"       : 0.2.4    , installed 0.2.4
                                    Adapter    "info"          : 1.9.16   , installed 1.9.16
                                    Controller "js-controller" : 3.3.21   , installed 3.3.21
                                    pi@raspberrypi:~ $
                                    In der Iobroker UI wird er unter Instanzen nicht angezeigt. Bei Adapter steht er als installiert 0.2.4.
                                    Hab schon ein paar Reboots gemacht, aber er erscheint nicht auch das Dashboard kann nicht eingeblendet werden.
                                      gestartet.
                                      update done
                                      pi@raspberrypi:~ $
                                      #418
                                      Da fehlen wohl die build-essentials
                                      apt policy build-essential
                                      Wenn die fehlen:
                                      sudo apt install build-essential
                                        Wenn die fehlen:
                                        #419
                                        @thomas-braun said in [ESPHome] Beta release:
                                        pi@raspberrypi:~ $ sudo apt install build-essential
                                        build-essential is already the newest version (12.9).
                                        0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                                        pi@raspberrypi:~ $
                                          pi@raspberrypi:~ $
                                          #420
                                          Zeig mal mehr von der Fehlermeldung.
