  4. [ESPHome] Beta release
591 Beiträge 48 Kommentatoren 238.9k Aufrufe 39 Beobachtet
  • Johannes BauerstatterJ Johannes Bauerstatter
    Ist eine ganz frische Installation auf einem Raspi 4.
    pi@raspberrypi:~ $ sudo apt install --reinstall lsb-release
    Reading package lists... Done
    0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 0 not upgraded.
    Need to get 28.1 kB of archives.
    After this operation, 0 B of additional disk space will be used.
    Get:1 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf lsb-release all 11.1.0+rpi1 [28.1 kB]
    Fetched 28.1 kB in 1s (19.0 kB/s)
    Traceback (most recent call last):
      File "/usr/bin/apt-listchanges", line 29, in <module>
        import apt_pkg
    ModuleNotFoundError: No module named 'apt_pkg'
    (Reading database ... 50809 files and directories currently installed.)
    Preparing to unpack .../lsb-release_11.1.0+rpi1_all.deb ...
    Unpacking lsb-release (11.1.0+rpi1) over (11.1.0+rpi1) ...
    Setting up lsb-release (11.1.0+rpi1) ...
    Processing triggers for man-db (2.9.4-2) ...
    pi@raspberrypi:~ $
    NPM version: 6.14.15
    npm install iobroker.esphome@0.2.4 --loglevel error --prefix "/opt/iobroker" (System call)
    Exception:Traceback (most recent call last):  File "/tmp/tmpys8yyc8z/pip.zip/pip/basecommand.py", line 215, in main    status = self.run(options, args)  File "/tmp/tmpys8yyc8z/pip.zip/pip/commands/install.py", line 272, in run    with self._build_session(options) as session:  File "/tmp/tmpys8yyc8z/pip.zip/pip/basecommand.py", line 66, in _build_session    session = PipSession(  File "/tmp/tmpys8yyc8z/pip.zip/pip/download.py", line 329, in __init__    self.headers["User-Agent"] = user_agent()  File "/tmp/tmpys8yyc8z/pip.zip/pip/download.py", line 93, in user_agent    from pip._vendor import distro  File "<frozen importlib._bootstrap>", line 1007, in _find_and_load  File "<frozen importlib._bootstrap>", line 986, in _find_and_load_unlocked  File "<frozen importlib._bootstrap>", line 664, in _load_unlocked  File "<frozen importlib._bootstrap>", line 627, in _load_backward_compatible  File "<frozen zipimport>", line 259, in load_module  File "/tmp/tmpys8yyc8z/pip.zip/pip/_vendor/distro.py", line 1050, in <module>    _distro = LinuxDistribution()  File "/tmp/tmpys8yyc8z/pip.zip/pip/_vendor/distro.py", line 593, in __init__    self._lsb_release_info = self._get_lsb_release_info() \  File "/tmp/tmpys8yyc8z/pip.zip/pip/_vendor/distro.py", line 931, in _get_lsb_release_info    raise subprocess.CalledProcessError(code, cmd, stdout, stderr)subprocess.CalledProcessError: Command 'lsb_release -a' returned non-zero exit status 1.
    Traceback (most recent call last):  File "/opt/iobroker/node_modules/nopy/src/get-pip.py", line 20061, in <module>
        main()  File "/opt/iobroker/node_modules/nopy/src/get-pip.py", line 194, in main    bootstrap(tmpdir=tmpdir)  File "/opt/iobroker/node_modules/nopy/src/get-pip.py", line 172, in bootstrap    sys.exit(pip.main(["install", "--upgrade"] + args))  File "/tmp/tmpys8yyc8z/pip.zip/pip/__init__.py", line 233, in main  File "/tmp/tmpys8yyc8z/pip.zip/pip/basecommand.py", line 248, in main  File "/tmp/tmpys8yyc8z/pip.zip/pip/basecommand.py", line 66, in _build_session  File "/tmp/tmpys8yyc8z/pip.zip/pip/download.py", line 329, in __init__  File "/tmp/tmpys8yyc8z/pip.zip/pip/download.py", line 93, in user_agent  File "<frozen importlib._bootstrap>", line 1007, in _find_and_load  File "<frozen importlib._bootstrap>", line 986, in _find_and_load_unlocked  File "<frozen importlib._bootstrap>", line 664, in _load_unlocked  File "<frozen importlib._bootstrap>", line 627, in _load_backward_compatible  File "<frozen zipimport>", line 259, in load_module  File "/tmp/tmpys8yyc8z/pip.zip/pip/_vendor/distro.py", line 1050, in <module>  File "/tmp/tmpys8yyc8z/pip.zip/pip/_vendor/distro.py", line 593, in __init__  File "/tmp/tmpys8yyc8z/pip.zip/pip/_vendor/distro.py", line 931, in _get_lsb_release_infosubprocess.CalledProcessError: Command 'lsb_release -a' returned non-zero exit status 1.
    Error: Exited with code 1.    at ChildProcess.<anonymous> (/opt/iobroker/node_modules/nopy/src/api.js:277:20)    at ChildProcess.emit (events.js:400:28)
        at maybeClose (internal/child_process.js:1058:16)    at Process.ChildProcess._handle.onexit (internal/child_process.js:293:5)
    npm ERR! code ELIFECYCLE
    npm ERR! errno 1
    npm ERR! iobroker.esphome@0.2.4 install: `npip install`npm ERR! Exit status 1
    npm ERR! npm ERR! Failed at the iobroker.esphome@0.2.4 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
    npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2021-12-03T15_55_36_557Z-debug.log
    ERROR: host.raspberrypi Cannot install iobroker.esphome@0.2.4: 1
    #407
    @johannes-bauerstatter sagte in [ESPHome] Beta release:
    ModuleNotFoundError: No module named 'apt_pkg'        (Reading database ... 50809 files and directories currently installed.)
    Gaaaaaaanz merkwürdige Meldungen. Was zur Hölle hast du da wie installiert?
    Ich würd's nochmal ganz frisch installieren.
    Johannes BauerstatterJ O 2 Antworten Letzte Antwort
      Johannes BauerstatterJ Offline
      #408
      @thomas-braun Ok. Welche Python Version soll ich nehmen?
        #409
        Die vorgesehene/vorinstallierte?
        Da ist was total schräg bei dir. Hier ist das ganz fluffig:
        echad@chet:~ $ iobroker install esphome
        NPM version: 8.1.4
        host.chet install adapter esphome
        upload [5] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/words.js words.js application/javascript
        upload [4] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/style.css style.css text/css
        upload [3] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/index_m.html index_m.html text/html
        upload [2] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/img/dashboard.png img/dashboard.png image/png
        upload [1] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/esphome.png esphome.png image/png
        upload [0] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/admin.d.ts admin.d.ts video/mp2t
        host.chet object system.adapter.esphome created/updated
        Aus der Readme:
        Required
        • NodeJS >= 12.x
        • Python >=3.7, <4.0
        • API is activated in YAML
          Anzic
          schrieb am zuletzt editiert von Anzic
          #410
          Switched to NodeJS version 14 frome 12. The dashboard stopped working. Although the adapter itself works. There is such an error in the log:
          esphome.0
          2021-12-03 19:55:22.625	warn	ESPHome Dashboard deactivated
          esphome.0
          2021-12-03 19:55:22.589	error	[dashboardProcess ERROR] from esphome.__main__ import mainModuleNotFoundError: No module named 'esphome'
          esphome.0
          2021-12-03 19:55:22.588	error	[dashboardProcess ERROR] Traceback (most recent call last): File "/opt/iobroker/node_modules/iobroker.esphome/python_modules/bin/esphome", line 5, in <module>
          I try to execute iobroker rebuild esphome and iobroker rebuild esphome --install I get this error:
          root@iobroker:/opt/iobroker# iobroker rebuild esphome --install
          npm install --loglevel error --production (System call1) in "/opt/iobroker/node_modules/iobroker.esphome"
          /usr/bin/python3: No module named pip
          npm ERR! errno 1
          npm ERR!
          npm ERR!     /opt/iobroker/.npm/_logs/2021-12-03T17_03_35_839Z-debug.log
          What you need to do to "rebuild" the adapter and the dashboard works
          Docker image baunet 6.0.0beta1
          I managed it myself. this command helped - sudo apt install python3-pip
            NPM version: 8.1.4
            Aus der Readme:
            Required
            • NodeJS >= 12.x
            marsmännchen
            #411
            @Dutchman
            Danke für die Aktualisierung. Funktioniert jetzt auf dem Slave.
            Aber hast du vielleicht eine Idee darüber :
            https://forum.iobroker.net/topic/49960/esphome-probe-request-unsuccessful
            MfG
            Patrick
            Raspberry Pi 4 8GB, Debian 11, js-controller: 5.0.12, Nodejs: v18.18.2, NPM: 9.8.1 (Multihost),
            Wago PFC200 mit Dali Lichtsteuerung.
            • FeuersturmF Offline
              FeuersturmF Offline
              Feuersturm
              #412
              @Dutchman Ich hatte heute folgende Fehlermeldung im Log
              Ist für die Fargebung rot / gelb der Adapter oder der Admin verantwortlich? Warum wird beim esphome Fehler gelb statt z.B. des Orange (wie bei den Warnungen ) verwendet?
              Hier mal der Fehler in lesbarer Form ;-)
              Bisher hab ich es noch nicht gesehen, dass innerhalb einer Warnung / Fehlers die Farbe wechselt.
              Johannes BauerstatterJ 1 Antwort Letzte Antwort
              • FeuersturmF Feuersturm
                #413
                Hab heute den Pi 5x neu aufgesetzt und bring es einfach nicht zum laufen. Iobroker läuft.
                Bei einer Installation war nach 4h Schluss.
                Bevor ich jetzt wieder alles mache.
                So wäre meine Ausgangslage:
                Linux raspberrypi 5.10.63-v7l+ #1488 SMP Thu Nov 18 16:15:28 GMT 2021 armv7l
                pi@raspberrypi:~ $ npm -v
                6.14.15
                pi@raspberrypi:~ $ node -v
                v14.18.2
                pi@raspberrypi:~ $ python
                Python 2.7.18 (default, Jul 14 2021, 08:11:37)
                [GCC 10.2.1 20210110] on linux2
                Type "help", "copyright", "credits" or "license" for more information.
                >>> quit()
                pi@raspberrypi:~ $ python3
                Python 3.9.2 (default, Mar 12 2021, 04:06:34)
                >>> quit()
                pi@raspberrypi:~ $
                Ist das so OK? Soll ich lieber im Broker den Adapter installieren oder per npm i ....?
                  6.14.15
                  v14.18.2
                  >>> quit()
                  >>> quit()
                  pi@raspberrypi:~ $
                  #414
                  Was soll das aussagen?
                  Die Versionsnummer sehen aber i. O. aus.
                    #415
                    @thomas-braun Der Adapter hat im Iobroker 4h lang installiert und hat sich dann beendet ohne das es installiert wurde. Ich versuch es nochmal.
                      #416
                      Und wie hast du das gemacht?
                      Entweder über die Admin-GUI oder in der Konsole per
                      Das Beta-Repo muss allerdings dazu aktiv sein.
                        schrieb am zuletzt editiert von Johannes Bauerstatter
                        #417
                        @thomas-braun Habs über die UI gemacht. Jetzt hab ich es mal über die Konsole per
                        gestartet.
                              creating build/temp.linux-armv7l-3.9
                              creating build/temp.linux-armv7l-3.9/c
                              arm-linux-gnueabihf-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -DUSE__THREAD -DHAVE_SYNC_SYNCHRONIZE -I/usr/include/python3.9 -c c/_cffi_backend.c -o build/temp.linux-armv7l-3.9/c/_cffi_backend.o
                              c/_cffi_backend.c:2:10: fatal error: Python.h: No such file or directory
                                  2 | #include <Python.h>
                              compilation terminated.
                              error: command '/usr/bin/arm-linux-gnueabihf-gcc' failed with exit code 1
                          ERROR: Command errored out with exit status 1: /usr/bin/python3 -u -c 'import io, os, sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-5ijkwnli/cffi_16d10301de7c4069acead825ae282b6b/setup.py'"'"'; __file__='"'"'/tmp/pip-install-5ijkwnli/cffi_16d10301de7c4069acead825ae282b6b/setup.py'"'"';f = getattr(tokenize, '"'"'open'"'"', open)(__file__) if os.path.exists(__file__) else io.StringIO('"'"'from setuptools import setup; setup()'"'"');code = f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-opvq9x1b/install-record.txt --single-version-externally-managed --prefix /tmp/pip-build-env-lf7bqq4f/overlay --compile --install-headers /tmp/pip-build-env-lf7bqq4f/overlay/include/python3.9/cffi Check the logs for full command output.
                        WARNING: Discarding https://files.pythonhosted.org/packages/9b/77/461087a514d2e8ece1c975d8216bc03f7048e6090c5166bc34115afdaa53/cryptography-3.4.7.tar.gz#sha256=3d10de8116d25649631977cb37da6cbdd2d6fa0e0281d014a5b7d337255ca713 (from https://pypi.org/simple/cryptography/) (requires-python:>=3.6). Command errored out with exit status 1: /usr/bin/python3 /tmp/pip-standalone-pip-eo94u2mi/__env_pip__.zip/pip install --ignore-installed --no-user --prefix /tmp/pip-build-env-lf7bqq4f/overlay --no-warn-script-location --no-binary :none: --only-binary :none: -i https://pypi.org/simple -- 'setuptools>=40.6.0' wheel 'cffi>=1.12; platform_python_implementation != '"'"'PyPy'"'"'' 'setuptools-rust>=0.11.4' Check the logs for full command output.
                        pi@raspberrypi:~ $ iobroker update
                        Used repository: Beta (latest)
                        hash unchanged, use cached sources
                        update done
                        Adapter    "admin"         : 5.2.1    , installed 5.2.1
                        Adapter    "backitup"      : 2.2.2    , installed 2.2.2
                        Adapter    "discovery"     : 2.7.5    , installed 2.7.5
                        Adapter    "esphome"       : 0.2.4    , installed 0.2.4
                        Adapter    "info"          : 1.9.16   , installed 1.9.16
                        Controller "js-controller" : 3.3.21   , installed 3.3.21
                        pi@raspberrypi:~ $
                        In der Iobroker UI wird er unter Instanzen nicht angezeigt. Bei Adapter steht er als installiert 0.2.4.
                        Hab schon ein paar Reboots gemacht, aber er erscheint nicht auch das Dashboard kann nicht eingeblendet werden.
                          gestartet.
                          update done
                          pi@raspberrypi:~ $
                          #418
                          Da fehlen wohl die build-essentials
                          apt policy build-essential
                          Wenn die fehlen:
                          sudo apt install build-essential
                            Wenn die fehlen:
                            #419
                            @thomas-braun said in [ESPHome] Beta release:
                            pi@raspberrypi:~ $ sudo apt install build-essential
                            build-essential is already the newest version (12.9).
                            0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                            pi@raspberrypi:~ $
                              pi@raspberrypi:~ $
                              #420
                              Zeig mal mehr von der Fehlermeldung.
                                pi@raspberrypi:~ $
                                #421
                                apt policy python3-pip
                                  #422
                                  Nach einigen Neustarts und nochmaligen
                                  scheint es jetzt geklappt zu haben.
                                  Jetzt hab ich noch Probleme mit dem Dashboard.
                                  esphome.0	2021-12-04 21:00:05.313	warn	(1443) ESPHome Dashboard deactivated
                                  esphome.0	2021-12-04 21:00:05.199	error	(1443) [dashboardProcess ERROR] Error: ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.esphome/python_modules/bin/esphome'
                                    #423
                                    Das ist offenbar nicht gebaut worden. Siehe die entsprechenden Fehlermeldungen weiter oben.
                                    Johannes BauerstatterJ 2 Antworten Letzte Antwort
                                      #424
                                      pi@raspberrypi:~ $ apt policy python3-pip
                                      python3-pip:
                                        Installed: 20.3.4-4+rpt1
                                        Candidate: 20.3.4-4+rpt1
                                        Version table:
                                       *** 20.3.4-4+rpt1 500
                                              500 http://archive.raspberrypi.org/debian bullseye/main armhf Packages
                                           20.3.4-4 500
                                      pi@raspberrypi:~ $
                                      Komisch auf meinem Proxmox System hat es immer ohne irgendwelche Probleme funktioniert. Kann es an der Kombi Raspi 4 mit Bullseye liegen? Hab deinen super Adapter schon oft in Proxmox eingesetzt aber sowas wie mit dem Raspi hat ich noch nie...
                                      Ich versuch nochmal im Iobroker Web de-installieren und neu installieren.
                                        python3-pip:
                                          Version table:
                                             20.3.4-4 500
                                        pi@raspberrypi:~ $
                                        #425
                                        Nein, die Kombi hab ich hier auch.
                                        Der ist nicht von mir.
                                          #426
                                          @thomas-braun Vielen, vielen Dank für deine Bemühungen. Es läuft jetzt. Im Endeffekt musste ich es ein paar mal installieren - deinstallieren, zwischendurch Neustarten bis es funktioniert hat.
                                          @Dutchman Danke für den Adapter.
