  4. [ESPHome] Beta release
591 Beiträge 48 Kommentatoren 238.9k Aufrufe 39 Beobachtet
    @arne007
    Steht in meiner Signatur.
    Lies insbesondere den Teil mit den falschen Pfaden besonders gründlich.
    Johannes BauerstatterJ Offline
    #402
    Hallo, irgendwie mags bei mir auch nicht. Welche Version ist falsch?
    npm: 6.14.15
    node: 14.18.2
    python: 3.9.7
    $ ./iobroker add esphome  --host raspberrypi
    NPM version: 6.14.15
    npm install iobroker.esphome@0.2.4 --loglevel error --prefix "/opt/iobroker" (System call)
    Exception:
    Traceback (most recent call last):  File "/tmp/tmpvlou37m4/pip.zip/pip/basecommand.py", line 215, in main    status = self.run(options, args)  File "/tmp/tmpvlou37m4/pip.zip/pip/commands/install.py", line 272, in run    with self._build_session(options) as session:  File "/tmp/tmpvlou37m4/pip.zip/pip/basecommand.py", line 66, in _build_session    session = PipSession(  File "/tmp/tmpvlou37m4/pip.zip/pip/download.py", line 329, in __init__    self.headers["User-Agent"] = user_agent()  File "/tmp/tmpvlou37m4/pip.zip/pip/download.py", line 93, in user_agent    from pip._vendor import distro  File "<frozen importlib._bootstrap>", line 1007, in _find_and_load  File "<frozen importlib._bootstrap>", line 986, in _find_and_load_unlocked  File "<frozen importlib._bootstrap>", line 664, in _load_unlocked  File "<frozen importlib._bootstrap>", line 627, in _load_backward_compatible  File "<frozen zipimport>", line 259, in load_module  File "/tmp/tmpvlou37m4/pip.zip/pip/_vendor/distro.py", line 1050, in <module>    _distro = LinuxDistribution()  File "/tmp/tmpvlou37m4/pip.zip/pip/_vendor/distro.py", line 593, in __init__    self._lsb_release_info = self._get_lsb_release_info() \  File "/tmp/tmpvlou37m4/pip.zip/pip/_vendor/distro.py", line 931, in _get_lsb_release_info    raise subprocess.CalledProcessError(code, cmd, stdout, stderr)subprocess.CalledProcessError: Command 'lsb_release -a' returned non-zero exit status 1.
      File "/opt/iobroker/node_modules/nopy/src/get-pip.py", line 20061, in <module>
        main()
      File "/opt/iobroker/node_modules/nopy/src/get-pip.py", line 194, in main    bootstrap(tmpdir=tmpdir)
      File "/opt/iobroker/node_modules/nopy/src/get-pip.py", line 172, in bootstrap    sys.exit(pip.main(["install", "--upgrade"] + args))  File "/tmp/tmpvlou37m4/pip.zip/pip/__init__.py", line 233, in main  File "/tmp/tmpvlou37m4/pip.zip/pip/basecommand.py", line 248, in main  File "/tmp/tmpvlou37m4/pip.zip/pip/basecommand.py", line 66, in _build_session  File "/tmp/tmpvlou37m4/pip.zip/pip/download.py", line 329, in __init__
      File "/tmp/tmpvlou37m4/pip.zip/pip/download.py", line 93, in user_agent  File "<frozen importlib._bootstrap>", line 1007, in _find_and_load  File "<frozen importlib._bootstrap>", line 986, in _find_and_load_unlocked  File "<frozen importlib._bootstrap>", line 664, in _load_unlocked  File "<frozen importlib._bootstrap>", line 627, in _load_backward_compatible
      File "<frozen zipimport>", line 259, in load_module  File "/tmp/tmpvlou37m4/pip.zip/pip/_vendor/distro.py", line 1050, in <module>  File "/tmp/tmpvlou37m4/pip.zip/pip/_vendor/distro.py", line 593, in __init__  File "/tmp/tmpvlou37m4/pip.zip/pip/_vendor/distro.py", line 931, in _get_lsb_release_info
    Error: Exited with code 1.
        at ChildProcess.<anonymous> (/opt/iobroker/node_modules/nopy/src/api.js:277:20)    at ChildProcess.emit (events.js:400:28)    at maybeClose (internal/child_process.js:1058:16)    at Process.ChildProcess._handle.onexit (internal/child_process.js:293:5)
    npm ERR! code ELIFECYCLE
    npm ERR! errno 1
    npm ERR! iobroker.esphome@0.2.4 install: `npip install`
    npm ERR! Exit status 1npm ERR! npm ERR! Failed at the iobroker.esphome@0.2.4 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
    npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2021-12-03T11_34_34_767Z-debug.log
    ERROR: host.raspberrypi Cannot install iobroker.esphome@0.2.4: 1
    • Johannes BauerstatterJ Johannes Bauerstatter
      npm: 6.14.15
      node: 14.18.2
      python: 3.9.7
      Exception:
          main()
      npm ERR! errno 1
      #403
      @johannes-bauerstatter sagte in [ESPHome] Beta release:
      lsb_release -a
      Was kommt da in der Konsole zurück?
      Johannes BauerstatterJ 1 Antwort Letzte Antwort
        lsb_release -a
        #404
        pi@raspberrypi:~ $ lsb_release -a
          File "/usr/bin/lsb_release", line 25, in <module>
            import lsb_release
        ModuleNotFoundError: No module named 'lsb_release'
              import lsb_release
          #405
          Da ist irgendwas kaputt.
          sudo apt update
          sudo apt install --reinstall lsb-release
            sudo apt update
            schrieb am zuletzt editiert von Johannes Bauerstatter
            #406
            Ist eine ganz frische Installation auf einem Raspi 4.
            pi@raspberrypi:~ $ sudo apt install --reinstall lsb-release
            Reading package lists... Done
            0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 0 not upgraded.
            Need to get 28.1 kB of archives.
            After this operation, 0 B of additional disk space will be used.
            Get:1 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf lsb-release all 11.1.0+rpi1 [28.1 kB]
            Fetched 28.1 kB in 1s (19.0 kB/s)
              File "/usr/bin/apt-listchanges", line 29, in <module>
                import apt_pkg
            ModuleNotFoundError: No module named 'apt_pkg'
            (Reading database ... 50809 files and directories currently installed.)
            Preparing to unpack .../lsb-release_11.1.0+rpi1_all.deb ...
            Unpacking lsb-release (11.1.0+rpi1) over (11.1.0+rpi1) ...
            Setting up lsb-release (11.1.0+rpi1) ...
            Processing triggers for man-db (2.9.4-2) ...
            pi@raspberrypi:~ $
            Exception:Traceback (most recent call last):  File "/tmp/tmpys8yyc8z/pip.zip/pip/basecommand.py", line 215, in main    status = self.run(options, args)  File "/tmp/tmpys8yyc8z/pip.zip/pip/commands/install.py", line 272, in run    with self._build_session(options) as session:  File "/tmp/tmpys8yyc8z/pip.zip/pip/basecommand.py", line 66, in _build_session    session = PipSession(  File "/tmp/tmpys8yyc8z/pip.zip/pip/download.py", line 329, in __init__    self.headers["User-Agent"] = user_agent()  File "/tmp/tmpys8yyc8z/pip.zip/pip/download.py", line 93, in user_agent    from pip._vendor import distro  File "<frozen importlib._bootstrap>", line 1007, in _find_and_load  File "<frozen importlib._bootstrap>", line 986, in _find_and_load_unlocked  File "<frozen importlib._bootstrap>", line 664, in _load_unlocked  File "<frozen importlib._bootstrap>", line 627, in _load_backward_compatible  File "<frozen zipimport>", line 259, in load_module  File "/tmp/tmpys8yyc8z/pip.zip/pip/_vendor/distro.py", line 1050, in <module>    _distro = LinuxDistribution()  File "/tmp/tmpys8yyc8z/pip.zip/pip/_vendor/distro.py", line 593, in __init__    self._lsb_release_info = self._get_lsb_release_info() \  File "/tmp/tmpys8yyc8z/pip.zip/pip/_vendor/distro.py", line 931, in _get_lsb_release_info    raise subprocess.CalledProcessError(code, cmd, stdout, stderr)subprocess.CalledProcessError: Command 'lsb_release -a' returned non-zero exit status 1.
            Traceback (most recent call last):  File "/opt/iobroker/node_modules/nopy/src/get-pip.py", line 20061, in <module>
                main()  File "/opt/iobroker/node_modules/nopy/src/get-pip.py", line 194, in main    bootstrap(tmpdir=tmpdir)  File "/opt/iobroker/node_modules/nopy/src/get-pip.py", line 172, in bootstrap    sys.exit(pip.main(["install", "--upgrade"] + args))  File "/tmp/tmpys8yyc8z/pip.zip/pip/__init__.py", line 233, in main  File "/tmp/tmpys8yyc8z/pip.zip/pip/basecommand.py", line 248, in main  File "/tmp/tmpys8yyc8z/pip.zip/pip/basecommand.py", line 66, in _build_session  File "/tmp/tmpys8yyc8z/pip.zip/pip/download.py", line 329, in __init__  File "/tmp/tmpys8yyc8z/pip.zip/pip/download.py", line 93, in user_agent  File "<frozen importlib._bootstrap>", line 1007, in _find_and_load  File "<frozen importlib._bootstrap>", line 986, in _find_and_load_unlocked  File "<frozen importlib._bootstrap>", line 664, in _load_unlocked  File "<frozen importlib._bootstrap>", line 627, in _load_backward_compatible  File "<frozen zipimport>", line 259, in load_module  File "/tmp/tmpys8yyc8z/pip.zip/pip/_vendor/distro.py", line 1050, in <module>  File "/tmp/tmpys8yyc8z/pip.zip/pip/_vendor/distro.py", line 593, in __init__  File "/tmp/tmpys8yyc8z/pip.zip/pip/_vendor/distro.py", line 931, in _get_lsb_release_infosubprocess.CalledProcessError: Command 'lsb_release -a' returned non-zero exit status 1.
            Error: Exited with code 1.    at ChildProcess.<anonymous> (/opt/iobroker/node_modules/nopy/src/api.js:277:20)    at ChildProcess.emit (events.js:400:28)
            npm ERR! errno 1
            npm ERR! iobroker.esphome@0.2.4 install: `npip install`npm ERR! Exit status 1
            npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2021-12-03T15_55_36_557Z-debug.log
                  import apt_pkg
              pi@raspberrypi:~ $
              npm ERR! errno 1
              #407
              ModuleNotFoundError: No module named 'apt_pkg'        (Reading database ... 50809 files and directories currently installed.)
              Gaaaaaaanz merkwürdige Meldungen. Was zur Hölle hast du da wie installiert?
              Ich würd's nochmal ganz frisch installieren.
              Johannes BauerstatterJ O 2 Antworten Letzte Antwort
                #408
                @thomas-braun Ok. Welche Python Version soll ich nehmen?
                  #409
                  Die vorgesehene/vorinstallierte?
                  Da ist was total schräg bei dir. Hier ist das ganz fluffig:
                  echad@chet:~ $ iobroker install esphome
                  NPM version: 8.1.4
                  host.chet install adapter esphome
                  upload [5] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/words.js words.js application/javascript
                  upload [4] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/style.css style.css text/css
                  upload [3] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/index_m.html index_m.html text/html
                  upload [2] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/img/dashboard.png img/dashboard.png image/png
                  upload [1] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/esphome.png esphome.png image/png
                  upload [0] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/admin.d.ts admin.d.ts video/mp2t
                  host.chet object system.adapter.esphome created/updated
                  Aus der Readme:
                  Required
                  • NodeJS >= 12.x
                  • Python >=3.7, <4.0
                  • API is activated in YAML
                    Anzic
                    schrieb am zuletzt editiert von Anzic
                    #410
                    Switched to NodeJS version 14 frome 12. The dashboard stopped working. Although the adapter itself works. There is such an error in the log:
                    esphome.0
                    2021-12-03 19:55:22.625	warn	ESPHome Dashboard deactivated
                    esphome.0
                    2021-12-03 19:55:22.589	error	[dashboardProcess ERROR] from esphome.__main__ import mainModuleNotFoundError: No module named 'esphome'
                    esphome.0
                    2021-12-03 19:55:22.588	error	[dashboardProcess ERROR] Traceback (most recent call last): File "/opt/iobroker/node_modules/iobroker.esphome/python_modules/bin/esphome", line 5, in <module>
                    I try to execute iobroker rebuild esphome and iobroker rebuild esphome --install I get this error:
                    root@iobroker:/opt/iobroker# iobroker rebuild esphome --install
                    npm install --loglevel error --production (System call1) in "/opt/iobroker/node_modules/iobroker.esphome"
                    /usr/bin/python3: No module named pip
                    npm ERR! errno 1
                    npm ERR!
                    npm ERR!     /opt/iobroker/.npm/_logs/2021-12-03T17_03_35_839Z-debug.log
                    What you need to do to "rebuild" the adapter and the dashboard works
                    Docker image baunet 6.0.0beta1
                    I managed it myself. this command helped - sudo apt install python3-pip
                      NPM version: 8.1.4
                      Aus der Readme:
                      Required
                      • NodeJS >= 12.x
                      marsmännchen
                      #411
                      @Dutchman
                      Danke für die Aktualisierung. Funktioniert jetzt auf dem Slave.
                      Aber hast du vielleicht eine Idee darüber :
                      https://forum.iobroker.net/topic/49960/esphome-probe-request-unsuccessful
                      MfG
                      Patrick
                      Raspberry Pi 4 8GB, Debian 11, js-controller: 5.0.12, Nodejs: v18.18.2, NPM: 9.8.1 (Multihost),
                      Wago PFC200 mit Dali Lichtsteuerung.
                      • FeuersturmF Offline
                        FeuersturmF Offline
                        Feuersturm
                        #412
                        @Dutchman Ich hatte heute folgende Fehlermeldung im Log
                        Ist für die Fargebung rot / gelb der Adapter oder der Admin verantwortlich? Warum wird beim esphome Fehler gelb statt z.B. des Orange (wie bei den Warnungen ) verwendet?
                        Hier mal der Fehler in lesbarer Form ;-)
                        Bisher hab ich es noch nicht gesehen, dass innerhalb einer Warnung / Fehlers die Farbe wechselt.
                        • FeuersturmF Feuersturm
                          #413
                          Hab heute den Pi 5x neu aufgesetzt und bring es einfach nicht zum laufen. Iobroker läuft.
                          Bei einer Installation war nach 4h Schluss.
                          Bevor ich jetzt wieder alles mache.
                          So wäre meine Ausgangslage:
                          Linux raspberrypi 5.10.63-v7l+ #1488 SMP Thu Nov 18 16:15:28 GMT 2021 armv7l
                          pi@raspberrypi:~ $ npm -v
                          6.14.15
                          pi@raspberrypi:~ $ node -v
                          v14.18.2
                          pi@raspberrypi:~ $ python
                          Python 2.7.18 (default, Jul 14 2021, 08:11:37)
                          [GCC 10.2.1 20210110] on linux2
                          Type "help", "copyright", "credits" or "license" for more information.
                          >>> quit()
                          pi@raspberrypi:~ $ python3
                          Python 3.9.2 (default, Mar 12 2021, 04:06:34)
                          >>> quit()
                          pi@raspberrypi:~ $
                          Ist das so OK? Soll ich lieber im Broker den Adapter installieren oder per npm i ....?
                            6.14.15
                            v14.18.2
                            >>> quit()
                            >>> quit()
                            pi@raspberrypi:~ $
                            #414
                            Was soll das aussagen?
                            Die Versionsnummer sehen aber i. O. aus.
                              #415
                              @thomas-braun Der Adapter hat im Iobroker 4h lang installiert und hat sich dann beendet ohne das es installiert wurde. Ich versuch es nochmal.
                                #416
                                Und wie hast du das gemacht?
                                Entweder über die Admin-GUI oder in der Konsole per
                                Das Beta-Repo muss allerdings dazu aktiv sein.
                                  #417
                                  @thomas-braun Habs über die UI gemacht. Jetzt hab ich es mal über die Konsole per
                                  gestartet.
                                        creating build/temp.linux-armv7l-3.9
                                        creating build/temp.linux-armv7l-3.9/c
                                        arm-linux-gnueabihf-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -DUSE__THREAD -DHAVE_SYNC_SYNCHRONIZE -I/usr/include/python3.9 -c c/_cffi_backend.c -o build/temp.linux-armv7l-3.9/c/_cffi_backend.o
                                        c/_cffi_backend.c:2:10: fatal error: Python.h: No such file or directory
                                            2 | #include <Python.h>
                                        compilation terminated.
                                        error: command '/usr/bin/arm-linux-gnueabihf-gcc' failed with exit code 1
                                    ERROR: Command errored out with exit status 1: /usr/bin/python3 -u -c 'import io, os, sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-5ijkwnli/cffi_16d10301de7c4069acead825ae282b6b/setup.py'"'"'; __file__='"'"'/tmp/pip-install-5ijkwnli/cffi_16d10301de7c4069acead825ae282b6b/setup.py'"'"';f = getattr(tokenize, '"'"'open'"'"', open)(__file__) if os.path.exists(__file__) else io.StringIO('"'"'from setuptools import setup; setup()'"'"');code = f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-opvq9x1b/install-record.txt --single-version-externally-managed --prefix /tmp/pip-build-env-lf7bqq4f/overlay --compile --install-headers /tmp/pip-build-env-lf7bqq4f/overlay/include/python3.9/cffi Check the logs for full command output.
                                  WARNING: Discarding https://files.pythonhosted.org/packages/9b/77/461087a514d2e8ece1c975d8216bc03f7048e6090c5166bc34115afdaa53/cryptography-3.4.7.tar.gz#sha256=3d10de8116d25649631977cb37da6cbdd2d6fa0e0281d014a5b7d337255ca713 (from https://pypi.org/simple/cryptography/) (requires-python:>=3.6). Command errored out with exit status 1: /usr/bin/python3 /tmp/pip-standalone-pip-eo94u2mi/__env_pip__.zip/pip install --ignore-installed --no-user --prefix /tmp/pip-build-env-lf7bqq4f/overlay --no-warn-script-location --no-binary :none: --only-binary :none: -i https://pypi.org/simple -- 'setuptools>=40.6.0' wheel 'cffi>=1.12; platform_python_implementation != '"'"'PyPy'"'"'' 'setuptools-rust>=0.11.4' Check the logs for full command output.
                                  pi@raspberrypi:~ $ iobroker update
                                  Used repository: Beta (latest)
                                  hash unchanged, use cached sources
                                  update done
                                  Adapter    "admin"         : 5.2.1    , installed 5.2.1
                                  Adapter    "backitup"      : 2.2.2    , installed 2.2.2
                                  Adapter    "discovery"     : 2.7.5    , installed 2.7.5
                                  Adapter    "esphome"       : 0.2.4    , installed 0.2.4
                                  Adapter    "info"          : 1.9.16   , installed 1.9.16
                                  Controller "js-controller" : 3.3.21   , installed 3.3.21
                                  pi@raspberrypi:~ $
                                  In der Iobroker UI wird er unter Instanzen nicht angezeigt. Bei Adapter steht er als installiert 0.2.4.
                                  Hab schon ein paar Reboots gemacht, aber er erscheint nicht auch das Dashboard kann nicht eingeblendet werden.
                                    gestartet.
                                    update done
                                    pi@raspberrypi:~ $
                                    #418
                                    Da fehlen wohl die build-essentials
                                    apt policy build-essential
                                    Wenn die fehlen:
                                    sudo apt install build-essential
                                      Wenn die fehlen:
                                      #419
                                      @thomas-braun said in [ESPHome] Beta release:
                                      pi@raspberrypi:~ $ sudo apt install build-essential
                                      build-essential is already the newest version (12.9).
                                      0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                                      pi@raspberrypi:~ $
                                        pi@raspberrypi:~ $
                                        #420
                                        Zeig mal mehr von der Fehlermeldung.
                                          pi@raspberrypi:~ $
                                          #421
                                          apt policy python3-pip
