  4. VIS - No Connection
VIS - No Connection
vis
185 Beiträge 10 Kommentatoren 22.1k Aufrufe 10 Beobachtet
    @pahan
    upgrade self erst wenn die Adapter auf Stand sind!
    Pahan
    #101
    @thomas-braun sagte in VIS - No Connection:
    @pahan
    ok, verstanden, jetzt mache ich erstmal diesen Befehl:
    iob upgrade backitup --debug
    wobei er schon seit paar Minuten hängt
    • P Pahan
      @pahan
      #102
      @pahan sagte in VIS - No Connection:
      hängt
      Ich glaube ja, die Kiste 'hängt' nicht final, die hat nur ordentlich zu kämpfen.
      P 1 Antwort Letzte Antwort
        hängt
        Pahan
        #103
        hängt
        das kann schon sein, nur was soll einen Pi4 mit 4GB so schnell aus der Ruhe bringen?
        ...jedenfalls sieht es aktuell so aus:
        pi@raspberrypi:~ $ iob upgrade backitup --debug
        This upgrade of "backitup" will introduce the following changes:
        -> 2.4.10:
        Code cleaning
        dependencies updated
        Disclaimer added
        Travis Support removed
        Fix backup-download with ssl
        -> 2.4.9:
        German Wiki added
        English Wiki added
        ignore .tar.gz files for zigbee Backups
        -> 2.4.8:
        Fix restore from local Mount path
        -> 2.4.7:
        many small bugfixes
        Fix Sentry Error Messages
        Default SMB Version 3.1.1
        Would you like to upgrade backitup from @2.4.6 to @2.4.10 now? [(y)es, (n)o]: y
        Update backitup from @2.4.6 to @2.4.10
        host.raspberrypi Adapter "system.adapter.backitup.0" is stopped.
        NPM version: 8.15.0
        npm install iobroker.backitup@2.4.10 --prefix "/opt/iobroker" (System call)
        npm WARN old lockfile
        npm WARN old lockfile The package-lock.json file was created with an old version of npm,
        npm WARN old lockfile so supplemental metadata must be fetched from the registry.
        npm WARN old lockfile This is a one-time fix-up, please be patient...
        added 10 packages, removed 64 packages, and changed 33 packages in 5m
        108 packages are looking for funding
          run `npm fund` for details
        upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
        Update "system.adapter.backitup.0"
        upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
        upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
        upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
        upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
        upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
        upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
        upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
        upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
        upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
        upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js applicati
        Adapter "backitup" updated
        host.raspberrypi Adapter "system.adapter.backitup.0" is started
          Pahan
          #104
          soll ich nochmal das versuchen?
          iobroker stop
          iobroker update
          iobroker upgrade self
          iobroker start
          • HomoranH Offline
            HomoranH Offline
            #105
            löschen
            • P Pahan
              hängt
              -> 2.4.10:
              Code cleaning
              Disclaimer added
              -> 2.4.9:
              German Wiki added
              English Wiki added
              -> 2.4.8:
              -> 2.4.7:
              many small bugfixes
              NPM version: 8.15.0
              #106
              Aufwändige Operationen im npm tree...
              iob update | grep backitup
                löschen
                #107
                Nö, wenn die Konvertierung funktioniert würde ich das auch so lassen.
                  HomoranH Offline
                  HomoranH Offline
                  #108
                  dann eben erst wenn es final hängt 😂
                    #109
                    Ich glaube das schnurrt...
                      Pahan
                      schrieb am zuletzt editiert von Pahan
                      #110
                      liefert:
                      pi@raspberrypi:~ $ iob update | grep backitup
                      Adapter    "backitup"      : 2.4.10   , installed 2.4.10
                      pi@raspberrypi:~ $
                      • P Pahan
                        liefert:
                        pi@raspberrypi:~ $
                        #111
                        @pahan
                        Schnurrt also...
                        iob update
                        iob upgrade all -y
                        Und GEDULD dann!
                          Pahan
                          #112
                          Made my day !!!
                          Ich sehe das Admin Logo über den Port 8081 !!!
                          Vielen Lieben Dank !!!
                          jetzt ist nur die Frage, ob ich das Update der Adapter über die Shell machen soll,
                          oder doch über die Admin-Oberfläche ?
                          ...wenn diese sich öffnet ...
                          • P Pahan
                            Made my day !!!
                            #113
                            Was ist denn das für eine Frage? Über die Kommandozeile natürlich. Geht das überhaupt anders?
                              Pahan
                              #114
                              Was ist denn das für eine Frage? Über die Kommandozeile natürlich. Geht das auch anders?
                              na klar, so wie früher auch, über die Admin-Oberfläche des iobrokers.
                              Meine Idee war, nur die admin Instanz upzudaten und die restlichen Adapter übers Backend upzudaten... aber das wird wohl nicht funktionieren?
                              • P Pahan
                                #115
                                Funktioniert schon. Aber über die Konsole sieht man mehr, das ist robuster und es ist schneller. Warum mit einer GUI rumschlagen? Die steht nur im Weg rum.
                                  Pahan
                                  #116
                                  Alles klar, danke.
                                  iob upgrade all -y
                                  ist nun mal gestartet...wird eine lange Nacht für den Raspi
                                  Dir nochmals vielen vielen Dank für die Unterstützung...und gute Nacht !
                                  • P Pahan
                                    Alles klar, danke.
                                    iob upgrade all -y
                                    Pahan
                                    #117
                                    iob upgrade all -y
                                    mal eine andere Frage:
                                    Nach einer Weile wurde die Verbindung zum Raspi unterbrochen.
                                    Wenn ich mich mit dem Raspi neu verbinde, dann sehe ich nicht, was (und ob) dieser noch was macht. Ich logge mich ganz normal darauf ein und sehe eine leere Kommandozeile.
                                    Aber eigentlich würde ich erwarten, dass der Raspi die Updates noch eine Zeit lang durchführt....
                                    Kann ich die "Hintergrundaufgaben" sehen?
                                    • P Pahan
                                      iob upgrade all -y
                                      #118
                                      Es gibt keine 'Hintergrundaufgaben' (jedenfalls nicht ohne weiteres). Wenn du dich ausloggst oder die Verbindung abreißt ist der Prozess tot.
                                        Pahan
                                        #119
                                        im Ernst? Dann muss ich die Konsole oder Maus in Putty alle 5 Minuten bewegen, dass weder die Verbindung abreißt noch der PC in den Standby geht?
                                        Ich dachte, sobald das Kommando abgeschickt ist, rotiert der Raspi, bis er fertig ist ?
                                        • P Pahan
                                          #120
                                          Tut er ja auch. Solange der ausführende user eingeloggt ist.
                                          Mit screen kann man sowas allerdings auch in der Konsole in den Hintergrund schieben. Ich wollte es nur nicht noch zusätzlich verkomplizieren.
