  4. VIS - No Connection
VIS - No Connection
vis
185 Beiträge 10 Kommentatoren 22.1k Aufrufe 10 Beobachtet
  • P Offline
    Pahan
    #104
    soll ich nochmal das versuchen?
    iobroker stop
    iobroker update
    iobroker upgrade self
    iobroker start
    • HomoranH Offline
      HomoranH Offline
      #105
      @pahan sagte in VIS - No Connection:
      npm WARN old lockfile The package-lock.json file was created with an old version of npm,
      löschen
      • P Pahan
        @thomas-braun sagte in VIS - No Connection:
        hängt
        Ich glaube ja, die Kiste 'hängt' nicht final, die hat nur ordentlich zu kämpfen.
        das kann schon sein, nur was soll einen Pi4 mit 4GB so schnell aus der Ruhe bringen?
        ...jedenfalls sieht es aktuell so aus:
        pi@raspberrypi:~ $ iob upgrade backitup --debug
        This upgrade of "backitup" will introduce the following changes:
        -> 2.4.10:
        Code cleaning
        dependencies updated
        Disclaimer added
        Travis Support removed
        Fix backup-download with ssl
        -> 2.4.9:
        German Wiki added
        English Wiki added
        ignore .tar.gz files for zigbee Backups
        -> 2.4.8:
        Fix restore from local Mount path
        -> 2.4.7:
        many small bugfixes
        Fix Sentry Error Messages
        Default SMB Version 3.1.1
        Would you like to upgrade backitup from @2.4.6 to @2.4.10 now? [(y)es, (n)o]: y
        Update backitup from @2.4.6 to @2.4.10
        host.raspberrypi Adapter "system.adapter.backitup.0" is stopped.
        NPM version: 8.15.0
        npm install iobroker.backitup@2.4.10 --prefix "/opt/iobroker" (System call)
        npm WARN old lockfile so supplemental metadata must be fetched from the registry.
        npm WARN old lockfile This is a one-time fix-up, please be patient...
        added 10 packages, removed 64 packages, and changed 33 packages in 5m
        108 packages are looking for funding
          run `npm fund` for details
        upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
        Update "system.adapter.backitup.0"
        upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
        upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
        upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
        upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
        upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
        upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
        upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
        upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
        upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
        upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js applicati
        Adapter "backitup" updated
        host.raspberrypi Adapter "system.adapter.backitup.0" is started
        #106
        Aufwändige Operationen im npm tree...
        iob update | grep backitup
        P 1 Antwort Letzte Antwort
          löschen
          #107
          Nö, wenn die Konvertierung funktioniert würde ich das auch so lassen.
            HomoranH Offline
            HomoranH Offline
            #108
            dann eben erst wenn es final hängt 😂
              #109
              Ich glaube das schnurrt...
                Pahan
                schrieb am zuletzt editiert von Pahan
                #110
                liefert:
                pi@raspberrypi:~ $ iob update | grep backitup
                Adapter    "backitup"      : 2.4.10   , installed 2.4.10
                pi@raspberrypi:~ $
                • P Pahan
                  liefert:
                  pi@raspberrypi:~ $
                  #111
                  @pahan
                  Schnurrt also...
                  iob update
                  iob upgrade all -y
                  Und GEDULD dann!
                  • P Offline
                    Pahan
                    #112
                    Made my day !!!
                    Ich sehe das Admin Logo über den Port 8081 !!!
                    Vielen Lieben Dank !!!
                    jetzt ist nur die Frage, ob ich das Update der Adapter über die Shell machen soll,
                    oder doch über die Admin-Oberfläche ?
                    ...wenn diese sich öffnet ...
                    • P Pahan
                      Made my day !!!
                      #113
                      Was ist denn das für eine Frage? Über die Kommandozeile natürlich. Geht das überhaupt anders?
                        Pahan
                        #114
                        Was ist denn das für eine Frage? Über die Kommandozeile natürlich. Geht das auch anders?
                        na klar, so wie früher auch, über die Admin-Oberfläche des iobrokers.
                        Meine Idee war, nur die admin Instanz upzudaten und die restlichen Adapter übers Backend upzudaten... aber das wird wohl nicht funktionieren?
                        • P Pahan
                          #115
                          Funktioniert schon. Aber über die Konsole sieht man mehr, das ist robuster und es ist schneller. Warum mit einer GUI rumschlagen? Die steht nur im Weg rum.
                            Pahan
                            #116
                            Alles klar, danke.
                            iob upgrade all -y
                            ist nun mal gestartet...wird eine lange Nacht für den Raspi
                            Dir nochmals vielen vielen Dank für die Unterstützung...und gute Nacht !
                            • P Pahan
                              Alles klar, danke.
                              iob upgrade all -y
                              Pahan
                              #117
                              iob upgrade all -y
                              mal eine andere Frage:
                              Nach einer Weile wurde die Verbindung zum Raspi unterbrochen.
                              Wenn ich mich mit dem Raspi neu verbinde, dann sehe ich nicht, was (und ob) dieser noch was macht. Ich logge mich ganz normal darauf ein und sehe eine leere Kommandozeile.
                              Aber eigentlich würde ich erwarten, dass der Raspi die Updates noch eine Zeit lang durchführt....
                              Kann ich die "Hintergrundaufgaben" sehen?
                              • P Pahan
                                iob upgrade all -y
                                #118
                                Es gibt keine 'Hintergrundaufgaben' (jedenfalls nicht ohne weiteres). Wenn du dich ausloggst oder die Verbindung abreißt ist der Prozess tot.
                                  Pahan
                                  #119
                                  im Ernst? Dann muss ich die Konsole oder Maus in Putty alle 5 Minuten bewegen, dass weder die Verbindung abreißt noch der PC in den Standby geht?
                                  Ich dachte, sobald das Kommando abgeschickt ist, rotiert der Raspi, bis er fertig ist ?
                                  • P Pahan
                                    #120
                                    Tut er ja auch. Solange der ausführende user eingeloggt ist.
                                    Mit screen kann man sowas allerdings auch in der Konsole in den Hintergrund schieben. Ich wollte es nur nicht noch zusätzlich verkomplizieren.
                                    • P Pahan
                                      #121
                                      Aber warum muss man die Maus bewegen? Die Netzwerkverbindung bleibt auch so oben. Oder ist das ein Notebook, das sich nach 5 Minuten Schlafen legt und die Arbeit einstellt?
                                        Pahan
                                        #122
                                        ja, ist ein Notebook, aber das mit dem Upgrade ging soweit durch.
                                        Ich komme nun auf die Admin Oberfläche, dort sind zwei Adapter geblieben : Müllabfuhr und SNMP, aber die verlangen wohl einen neueren js-controller, den ich noch nicht habe. Dieser wurde über die Shell nicht installiert.
                                        Es bleiben jedoch sehr viele Instanzen auf rot, darunter auch die VIS
                                        • P Pahan
                                          #123
                                          @pahan
                                          iobroker update
