  4. VIS - No Connection
VIS - No Connection
vis
185 Beiträge 10 Kommentatoren 22.1k Aufrufe 10 Beobachtet
    @pahan sagte in VIS - No Connection:
    hängt
    Ich glaube ja, die Kiste 'hängt' nicht final, die hat nur ordentlich zu kämpfen.
    Pahan
    #103
    @thomas-braun sagte in VIS - No Connection:
    hängt
    das kann schon sein, nur was soll einen Pi4 mit 4GB so schnell aus der Ruhe bringen?
    ...jedenfalls sieht es aktuell so aus:
    pi@raspberrypi:~ $ iob upgrade backitup --debug
    This upgrade of "backitup" will introduce the following changes:
    -> 2.4.10:
    Code cleaning
    dependencies updated
    Disclaimer added
    Travis Support removed
    Fix backup-download with ssl
    -> 2.4.9:
    German Wiki added
    English Wiki added
    ignore .tar.gz files for zigbee Backups
    -> 2.4.8:
    Fix restore from local Mount path
    -> 2.4.7:
    many small bugfixes
    Fix Sentry Error Messages
    Default SMB Version 3.1.1
    Would you like to upgrade backitup from @2.4.6 to @2.4.10 now? [(y)es, (n)o]: y
    Update backitup from @2.4.6 to @2.4.10
    host.raspberrypi Adapter "system.adapter.backitup.0" is stopped.
    NPM version: 8.15.0
    npm install iobroker.backitup@2.4.10 --prefix "/opt/iobroker" (System call)
    npm WARN old lockfile
    npm WARN old lockfile The package-lock.json file was created with an old version of npm,
    npm WARN old lockfile so supplemental metadata must be fetched from the registry.
    npm WARN old lockfile This is a one-time fix-up, please be patient...
    added 10 packages, removed 64 packages, and changed 33 packages in 5m
    108 packages are looking for funding
      run `npm fund` for details
    upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
    Update "system.adapter.backitup.0"
    upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
    upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
    upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
    upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
    upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
    upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
    upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
    upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
    upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
    upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js applicati
    Adapter "backitup" updated
    host.raspberrypi Adapter "system.adapter.backitup.0" is started
    • P Offline
      Pahan
      #104
      soll ich nochmal das versuchen?
      iobroker stop
      iobroker update
      iobroker upgrade self
      iobroker start
      • HomoranH Offline
        HomoranH Offline
        #105
        löschen
        • P Pahan
          hängt
          -> 2.4.10:
          Code cleaning
          Disclaimer added
          -> 2.4.9:
          German Wiki added
          English Wiki added
          -> 2.4.8:
          -> 2.4.7:
          many small bugfixes
          NPM version: 8.15.0
          #106
          Aufwändige Operationen im npm tree...
          iob update | grep backitup
          P 1 Antwort Letzte Antwort
            löschen
            #107
            Nö, wenn die Konvertierung funktioniert würde ich das auch so lassen.
              HomoranH Offline
              HomoranH Offline
              #108
              dann eben erst wenn es final hängt 😂
                #109
                Ich glaube das schnurrt...
                  Pahan
                  schrieb am zuletzt editiert von Pahan
                  #110
                  liefert:
                  pi@raspberrypi:~ $ iob update | grep backitup
                  Adapter    "backitup"      : 2.4.10   , installed 2.4.10
                  pi@raspberrypi:~ $
                  • P Pahan
                    liefert:
                    pi@raspberrypi:~ $
                    #111
                    @pahan
                    Schnurrt also...
                    iob update
                    iob upgrade all -y
                    Und GEDULD dann!
                    • P Offline
                      Pahan
                      #112
                      Made my day !!!
                      Ich sehe das Admin Logo über den Port 8081 !!!
                      Vielen Lieben Dank !!!
                      jetzt ist nur die Frage, ob ich das Update der Adapter über die Shell machen soll,
                      oder doch über die Admin-Oberfläche ?
                      ...wenn diese sich öffnet ...
                      • P Pahan
                        Made my day !!!
                        #113
                        Was ist denn das für eine Frage? Über die Kommandozeile natürlich. Geht das überhaupt anders?
                          Pahan
                          #114
                          Was ist denn das für eine Frage? Über die Kommandozeile natürlich. Geht das auch anders?
                          na klar, so wie früher auch, über die Admin-Oberfläche des iobrokers.
                          Meine Idee war, nur die admin Instanz upzudaten und die restlichen Adapter übers Backend upzudaten... aber das wird wohl nicht funktionieren?
                          • P Pahan
                            #115
                            Funktioniert schon. Aber über die Konsole sieht man mehr, das ist robuster und es ist schneller. Warum mit einer GUI rumschlagen? Die steht nur im Weg rum.
                              Pahan
                              #116
                              Alles klar, danke.
                              iob upgrade all -y
                              ist nun mal gestartet...wird eine lange Nacht für den Raspi
                              Dir nochmals vielen vielen Dank für die Unterstützung...und gute Nacht !
                              • P Pahan
                                Alles klar, danke.
                                iob upgrade all -y
                                Pahan
                                #117
                                iob upgrade all -y
                                mal eine andere Frage:
                                Nach einer Weile wurde die Verbindung zum Raspi unterbrochen.
                                Wenn ich mich mit dem Raspi neu verbinde, dann sehe ich nicht, was (und ob) dieser noch was macht. Ich logge mich ganz normal darauf ein und sehe eine leere Kommandozeile.
                                Aber eigentlich würde ich erwarten, dass der Raspi die Updates noch eine Zeit lang durchführt....
                                Kann ich die "Hintergrundaufgaben" sehen?
                                • P Pahan
                                  iob upgrade all -y
                                  #118
                                  Es gibt keine 'Hintergrundaufgaben' (jedenfalls nicht ohne weiteres). Wenn du dich ausloggst oder die Verbindung abreißt ist der Prozess tot.
                                    Pahan
                                    #119
                                    im Ernst? Dann muss ich die Konsole oder Maus in Putty alle 5 Minuten bewegen, dass weder die Verbindung abreißt noch der PC in den Standby geht?
                                    Ich dachte, sobald das Kommando abgeschickt ist, rotiert der Raspi, bis er fertig ist ?
                                    • P Pahan
                                      #120
                                      Tut er ja auch. Solange der ausführende user eingeloggt ist.
                                      Mit screen kann man sowas allerdings auch in der Konsole in den Hintergrund schieben. Ich wollte es nur nicht noch zusätzlich verkomplizieren.
                                      • P Pahan
                                        #121
                                        Aber warum muss man die Maus bewegen? Die Netzwerkverbindung bleibt auch so oben. Oder ist das ein Notebook, das sich nach 5 Minuten Schlafen legt und die Arbeit einstellt?
                                          Pahan
                                          #122
                                          ja, ist ein Notebook, aber das mit dem Upgrade ging soweit durch.
                                          Ich komme nun auf die Admin Oberfläche, dort sind zwei Adapter geblieben : Müllabfuhr und SNMP, aber die verlangen wohl einen neueren js-controller, den ich noch nicht habe. Dieser wurde über die Shell nicht installiert.
                                          Es bleiben jedoch sehr viele Instanzen auf rot, darunter auch die VIS
